Part Number: AM2432
#1. build any open pru project, generate the same error.
Building file: "../example.syscfg"
Invoking: SysConfig
"C:/ti/sysconfig_1.24.1/sysconfig_cli.bat" --script "C:/ti/workspace_v12/spi_loopback_am243x-lp_r5fss0-0_nortos_ti-arm-clang/example.syscfg" -o "syscfg" -s "C:/ti/open-pru-main/.metadata/product.json" -s "C:/ti/mcu_plus_sdk_am243x_09_02_01_05/.metadata/product.json" --context "r5fss0-0" --part ALX --package ALX --compiler ticlang
Warning: SysConfig has been updated to use standard TI part numbers. The device AM2434 has been automatically selected. If this is not the desired please open SysConfig to change it.
Running script...
subdir_rules.mk:9: recipe for target 'build-111670223' failed
Error: Exception occurred calling scripting.addModule(): No such resource: /kernel/dpl/dpl_cfg.syscfg.js
Paths searched:
C:\ti\open-pru-main\source\kernel\dpl\dpl_cfg.syscfg.js
C:\ti\open-pru-main\source\kernel\dpl\.meta\dpl_cfg.syscfg.js
C:\ti\open-pru-main\source\kernel\.meta\dpl\dpl_cfg.syscfg.js
C:\ti\open-pru-main\source\.meta\kernel\dpl\dpl_cfg.syscfg.js
C:\ti\mcu_plus_sdk_am243x_09_02_01_05\source\kernel\dpl\dpl_cfg.syscfg.js
C:\ti\mcu_plus_sdk_am243x_09_02_01_05\source\kernel\dpl\.meta\dpl_cfg.syscfg.js
C:\ti\mcu_plus_sdk_am243x_09_02_01_05\source\kernel\.meta\dpl\dpl_cfg.syscfg.js
C:\ti\mcu_plus_sdk_am243x_09_02_01_05\source\.meta\kernel\dpl\dpl_cfg.syscfg.js
C:\ti\workspace_v12\spi_loopback_am243x-lp_r5fss0-0_nortos_ti-arm-clang\kernel\dpl\dpl_cfg.syscfg.js
C:\ti\workspace_v12\spi_loopback_am243x-lp_r5fss0-0_nortos_ti-arm-clang\kernel\dpl\.meta\dpl_cfg.syscfg.js
C:\ti\workspace_v12\spi_loopback_am243x-lp_r5fss0-0_nortos_ti-arm-clang\kernel\.meta\dpl\dpl_cfg.syscfg.js
C:\ti\workspace_v12\spi_loopback_am243x-lp_r5fss0-0_nortos_ti-arm-clang\.meta\kernel\dpl\dpl_cfg.syscfg.js
at Object.addModule (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\pinmux\services\scripting\scriptingGuard.ts:52:10)
at scriptFunc (C:\ti\workspace_v12\spi_loopback_am243x-lp_r5fss0-0_nortos_ti-arm-clang\example.syscfg:14:35)
at cb (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\pinmux\services\scripting\runScript.ts:123:13)
at withDeprecatedAccessAsync (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\pinmux\services\deprecatedAccessGuard.ts:24:16)
at runAsUserScriptAsync (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\pinmux\services\scripting\scriptingGuard.ts:93:16)
at runScripts (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\pinmux\services\scripting\runScript.ts:121:11)
at sysConfig (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\pinmux\services\scripting\runScript.ts:83:8)
at status (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\cli\cli_core.ts:103:8)
at t.runCLI (C:\ti\sysconfig_1.24.1\dist\webpack:\sysconfig\src\cli\runCli.ts:48:4)
gmake: *** [build-111670223] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
#2. The example.syscfg file
* These arguments were used when this file was generated. They will be automatically applied on subsequent loads
* via the GUI or CLI. Run CLI with '--help' for additional information on how to override these arguments.
* @cliArgs --device "AM243x_ALX_beta" --package "ALX" --part "ALX" --context "r5fss0-0" --product "MCU_PLUS_SDK_AM243x@10.00.00"
* @versions {"tool":"1.20.0+3587"}
* Import the modules used in this configuration.
const pruicss = scripting.addModule("/drivers/pruicss/pruicss", {}, false);
const pruicss1 = pruicss.addInstance();
const debug_log = scripting.addModule("/kernel/dpl/debug_log");
const dpl_cfg = scripting.addModule("/kernel/dpl/dpl_cfg");
const mpu_armv7 = scripting.addModule("/kernel/dpl/mpu_armv7", {}, false);
const mpu_armv71 = mpu_armv7.addInstance();
const mpu_armv72 = mpu_armv7.addInstance();
const mpu_armv73 = mpu_armv7.addInstance();
const mpu_armv74 = mpu_armv7.addInstance();
const mpu_armv75 = mpu_armv7.addInstance();
const default_linker = scripting.addModule("/memory_configurator/default_linker", {}, false);
const default_linker1 = default_linker.addInstance();
const general = scripting.addModule("/memory_configurator/general", {}, false);
const general1 = general.addInstance();
const region = scripting.addModule("/memory_configurator/region", {}, false);
const region1 = region.addInstance();
const section = scripting.addModule("/memory_configurator/section", {}, false);
const section1 = section.addInstance();
const section2 = section.addInstance();
const section3 = section.addInstance();
const section4 = section.addInstance();
const section5 = section.addInstance();
const section6 = section.addInstance();
const section7 = section.addInstance();
const section8 = section.addInstance();
const section9 = section.addInstance();
const section10 = section.addInstance();
const section11 = section.addInstance();
* Write custom configuration values to the imported modules.
pruicss1.$name = "CONFIG_PRU_ICSS0";
pruicss1.coreClk = 333333333;
pruicss1.iepClk = 500000000;
pruicss1.AdditionalICSSSettings[0].$name = "CONFIG_PRU_ICSS_IO0";
pruicss1.AdditionalICSSSettings[0].PruGPIO.create(2);
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].$name = "CONFIG_PRU_ICSS_GPIO0";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.$assign = "PRU_ICSSG0_PRU0";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPI14.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO13.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO15.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO3.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO4.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO5.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].$name = "CONFIG_PRU_ICSS_GPIO1";
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPI1.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPI11.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPI6.$used = true;
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPO2.$used = true;
debug_log.enableUartLog = true;
debug_log.uartLog.$name = "CONFIG_UART_CONSOLE";
debug_log.uartLog.UART.$assign = "USART0";
const uart_v0_template = scripting.addModule("/drivers/uart/v0/uart_v0_template", {}, false);
const uart_v0_template1 = uart_v0_template.addInstance({}, false);
uart_v0_template1.$name = "drivers_uart_v0_uart_v0_template0";
debug_log.uartLog.child = uart_v0_template1;
mpu_armv71.$name = "CONFIG_MPU_REGION0";
mpu_armv71.size = 31;
mpu_armv71.attributes = "Device";
mpu_armv71.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv71.allowExecute = false;
mpu_armv72.$name = "CONFIG_MPU_REGION1";
mpu_armv72.size = 15;
mpu_armv72.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv73.$name = "CONFIG_MPU_REGION2";
mpu_armv73.baseAddr = 0x41010000;
mpu_armv73.size = 15;
mpu_armv73.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.$name = "CONFIG_MPU_REGION3";
mpu_armv74.accessPermissions = "Supervisor RD+WR, User RD";
mpu_armv74.baseAddr = 0x70000000;
mpu_armv74.size = 21;
mpu_armv75.$name = "CONFIG_MPU_REGION4";
mpu_armv75.baseAddr = 0x60000000;
mpu_armv75.size = 28;
mpu_armv75.accessPermissions = "Supervisor RD, User RD";
default_linker1.$name = "memory_configurator_default_linker0";
general1.$name = "CONFIG_GENERAL0";
general1.linker.$name = "TIARMCLANG0";
region1.$name = "MEMORY_REGION_CONFIGURATION0";
region1.memory_region.create(9);
region1.memory_region[0].type = "TCMA_R5F";
region1.memory_region[0].$name = "R5F_VECS";
region1.memory_region[0].size = 0x40;
region1.memory_region[0].auto = false;
region1.memory_region[1].type = "TCMA_R5F";
region1.memory_region[1].$name = "R5F_TCMA";
region1.memory_region[1].size = 0x7FC0;
region1.memory_region[2].type = "TCMB_R5F";
region1.memory_region[2].$name = "R5F_TCMB0";
region1.memory_region[2].size = 0x8000;
region1.memory_region[3].$name = "NON_CACHE_MEM";
region1.memory_region[3].auto = false;
region1.memory_region[3].manualStartAddress = 0x70060000;
region1.memory_region[3].size = 0x8000;
region1.memory_region[4].$name = "MSRAM";
region1.memory_region[4].auto = false;
region1.memory_region[4].manualStartAddress = 0x70080000;
region1.memory_region[4].size = 0x40000;
region1.memory_region[5].type = "FLASH";
region1.memory_region[5].$name = "FLASH";
region1.memory_region[5].auto = false;
region1.memory_region[5].manualStartAddress = 0x60100000;
region1.memory_region[5].size = 0x80000;
region1.memory_region[6].$name = "USER_SHM_MEM";
region1.memory_region[6].auto = false;
region1.memory_region[6].manualStartAddress = 0x701D0000;
region1.memory_region[6].size = 0x180;
region1.memory_region[6].isShared = true;
region1.memory_region[6].shared_cores = ["m4fss0-0","r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[7].auto = false;
region1.memory_region[7].manualStartAddress = 0x701D0180;
region1.memory_region[7].size = 0x3E80;
region1.memory_region[7].$name = "LOG_SHM_MEM";
region1.memory_region[7].isShared = true;
region1.memory_region[7].shared_cores = ["m4fss0-0","r5fss0-1","r5fss1-0","r5fss1-1"];
region1.memory_region[8].auto = false;
region1.memory_region[8].manualStartAddress = 0x701D4000;
region1.memory_region[8].size = 0xC000;
region1.memory_region[8].$name = "RTOS_NORTOS_IPC_SHM_MEM";
region1.memory_region[8].isShared = true;
region1.memory_region[8].shared_cores = ["m4fss0-0","r5fss0-1","r5fss1-0","r5fss1-1"];
section1.$name = "Vector Table";
section1.load_memory = "R5F_VECS";
section1.group = false;
section1.output_section.create(1);
section1.output_section[0].$name = ".vectors";
section1.output_section[0].palignment = true;
section2.$name = "Text Segments";
section2.load_memory = "MSRAM";
section2.output_section.create(5);
section2.output_section[0].$name = ".text.hwi";
section2.output_section[0].palignment = true;
section2.output_section[1].$name = ".text.cache";
section2.output_section[1].palignment = true;
section2.output_section[2].$name = ".text.mpu";
section2.output_section[2].palignment = true;
section2.output_section[3].$name = ".text.boot";
section2.output_section[3].palignment = true;
section2.output_section[4].$name = ".text:abort";
section2.output_section[4].palignment = true;
section3.$name = "Code and Read-Only Data";
section3.load_memory = "MSRAM";
section3.output_section.create(2);
section3.output_section[0].$name = ".text";
section3.output_section[0].palignment = true;
section3.output_section[1].$name = ".rodata";
section3.output_section[1].palignment = true;
section4.$name = "Data Segment";
section4.load_memory = "MSRAM";
section4.output_section.create(1);
section4.output_section[0].$name = ".data";
section4.output_section[0].palignment = true;
section5.$name = "Memory Segments";
section5.load_memory = "MSRAM";
section5.output_section.create(3);
section5.output_section[0].$name = ".bss";
section5.output_section[0].palignment = true;
section5.output_section[0].output_sections_start = "__BSS_START";
section5.output_section[0].output_sections_end = "__BSS_END";
section5.output_section[1].$name = ".sysmem";
section5.output_section[1].palignment = true;
section5.output_section[2].$name = ".stack";
section5.output_section[2].palignment = true;
section6.$name = "Stack Segments";
section6.load_memory = "MSRAM";
section6.output_section.create(5);
section6.output_section[0].$name = ".irqstack";
section6.output_section[0].output_sections_start = "__IRQ_STACK_START";
section6.output_section[0].output_sections_end = "__IRQ_STACK_END";
section6.output_section[0].input_section.create(1);
section6.output_section[0].input_section[0].$name = ". = . + __IRQ_STACK_SIZE;";
section6.output_section[1].$name = ".fiqstack";
section6.output_section[1].output_sections_start = "__FIQ_STACK_START";
section6.output_section[1].output_sections_end = "__FIQ_STACK_END";
section6.output_section[1].input_section.create(1);
section6.output_section[1].input_section[0].$name = ". = . + __FIQ_STACK_SIZE;";
section6.output_section[2].$name = ".svcstack";
section6.output_section[2].output_sections_start = "__SVC_STACK_START";
section6.output_section[2].output_sections_end = "__SVC_STACK_END";
section6.output_section[2].input_section.create(1);
section6.output_section[2].input_section[0].$name = ". = . + __SVC_STACK_SIZE;";
section6.output_section[3].$name = ".abortstack";
section6.output_section[3].output_sections_start = "__ABORT_STACK_START";
section6.output_section[3].output_sections_end = "__ABORT_STACK_END";
section6.output_section[3].input_section.create(1);
section6.output_section[3].input_section[0].$name = ". = . + __ABORT_STACK_SIZE;";
section6.output_section[4].$name = ".undefinedstack";
section6.output_section[4].output_sections_start = "__UNDEFINED_STACK_START";
section6.output_section[4].output_sections_end = "__UNDEFINED_STACK_END";
section6.output_section[4].input_section.create(1);
section6.output_section[4].input_section[0].$name = ". = . + __UNDEFINED_STACK_SIZE;";
section7.$name = "Initialization and Exception Handling";
section7.load_memory = "MSRAM";
section7.output_section.create(3);
section7.output_section[0].$name = ".ARM.exidx";
section7.output_section[0].palignment = true;
section7.output_section[1].$name = ".init_array";
section7.output_section[1].palignment = true;
section7.output_section[2].$name = ".fini_array";
section7.output_section[2].palignment = true;
section8.$name = "User Shared Memory";
section8.type = "NOLOAD";
section8.load_memory = "USER_SHM_MEM";
section8.group = false;
section8.output_section.create(1);
section8.output_section[0].$name = ".bss.user_shared_mem";
section8.output_section[0].alignment = 0;
section9.$name = "Log Shared Memory";
section9.load_memory = "LOG_SHM_MEM";
section9.type = "NOLOAD";
section9.group = false;
section9.output_section.create(1);
section9.output_section[0].$name = ".bss.log_shared_mem";
section9.output_section[0].alignment = 0;
section10.$name = "IPC Shared Memory";
section10.type = "NOLOAD";
section10.load_memory = "RTOS_NORTOS_IPC_SHM_MEM";
section10.group = false;
section10.output_section.create(1);
section10.output_section[0].$name = ".bss.ipc_vring_mem";
section10.output_section[0].alignment = 0;
section11.$name = "Non Cacheable Memory";
section11.load_memory = "NON_CACHE_MEM";
section11.group = false;
section11.type = "NOLOAD";
section11.output_section.create(1);
section11.output_section[0].$name = ".bss.nocache";
section11.output_section[0].alignment = 0;
* Pinmux solution for unlocked pins/peripherals. This ensures that minor changes to the automatic solver in a future
* version of the tool will not impact the pinmux you originally saw. These lines can be completely deleted in order to
* re-solve from scratch.
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPI14.$suggestSolution = "PRG0_PRU0_GPO14";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO13.$suggestSolution = "PRG0_PRU0_GPO13";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO15.$suggestSolution = "PRG0_PRU0_GPO15";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO3.$suggestSolution = "PRG0_PRU0_GPO3";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO4.$suggestSolution = "PRG0_PRU0_GPO4";
pruicss1.AdditionalICSSSettings[0].PruGPIO[0].PRU_ICSSG0_PRU.GPO5.$suggestSolution = "PRG0_PRU0_GPO5";
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.$suggestSolution = "PRU_ICSSG0_PRU1";
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPI1.$suggestSolution = "PRG0_PRU1_GPO1";
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPI11.$suggestSolution = "PRG0_PRU1_GPO11";
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPI6.$suggestSolution = "PRG0_PRU1_GPO6";
pruicss1.AdditionalICSSSettings[0].PruGPIO[1].PRU_ICSSG0_PRU.GPO2.$suggestSolution = "PRG0_PRU1_GPO2";
debug_log.uartLog.UART.RXD.$suggestSolution = "UART0_RXD";
debug_log.uartLog.UART.TXD.$suggestSolution = "UART0_TXD";
How to idendify where is the problem according to the fail message?
