Hello, I am working with ti-dvsdk_dm3730-evm_04_03_00_06 and I am trying to boot board from SD card according to TMS320DM3730_Software_Developers_Guide.pdf.
The boot process doesn't finish ok: the magrix-gui is not launched and you are no able to log in. The calibration of LCD is done ok.
This is how I created the SD card (host ubuntu 10.04):
user@HP:~$ echo 'Testing TMDXEVM3730 with ti-dvsdk_dm3730-evm_04_03_00_06'
user@HP:~$ echo 'Creating SD card according to TMS320DM3730_Software_Developers_Guide.pdf'
user@HP:~$ export DVSDK="/home/user/ti-dvsdk_dm3730-evm_04_03_00_06"
user@HP:~$ echo 'Now I insert SD card'
user@HP:~$ dmesg | grep sd
[ 1.240358] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.240434] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 1.240471] sd 0:0:0:0: [sda] Write Protect is off
[ 1.240473] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.240492] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.240600] sda: sda1 sda3 < sda5 sda6 sda7 sda8
[ 1.326780] sda9 sda10 > sda4
[ 1.338376] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.970728] EXT4-fs (sda10): mounted filesystem with ordered data mode
[ 13.172641] Adding 3999736k swap on /dev/sda7. Priority:-1 extents:1 across:3999736k
[ 16.478252] EXT3 FS on sda6, internal journal
[ 18.455041] EXT3 FS on sda1, internal journal
[ 18.591364] EXT3 FS on sda4, internal journal
[ 18.716466] type=1505 audit(1327494450.761:14): operation="profile_load" pid=1157 name="/usr/sbin/cupsd"
[ 19.041435] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 172.708545] nfsd: last server has exited, flushing export cache
[16995.113491] nfsd: last server has exited, flushing export cache
[18342.076970] nfsd: last server has exited, flushing export cache
[18512.486703] nfsd: last server has exited, flushing export cache
[19390.012028] nfsd: last server has exited, flushing export cache
[20715.824114] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20715.824247] sd 0:0:0:0: [sda] Stopping disk
[20716.231791] PM: suspend of drv:sd dev:0:0:0:0 complete after 407.679 msecs
[20719.619369] sd 0:0:0:0: [sda] Starting disk
[20720.743998] PM: resume of drv:sd dev:0:0:0:0 complete after 1124.630 msecs
[23465.076303] sd 6:0:0:0: Attached scsi generic sg2 type 0
[23465.268078] sd 6:0:0:0: [sdb] 7744512 512-byte logical blocks: (3.96 GB/3.69 GiB)
[23465.272661] sd 6:0:0:0: [sdb] Write Protect is off
[23465.272671] sd 6:0:0:0: [sdb] Mode Sense: 23 00 00 00
[23465.272679] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[23465.287534] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[23465.287549] sdb: sdb1 sdb2
[23465.303315] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[23465.303329] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[23466.619232] EXT3 FS on sdb2, internal journal
[23961.330151] sd 7:0:0:0: Attached scsi generic sg2 type 0
[23961.526639] sd 7:0:0:0: [sdb] 7744512 512-byte logical blocks: (3.96 GB/3.69 GiB)
[23961.530999] sd 7:0:0:0: [sdb] Write Protect is off
[23961.531009] sd 7:0:0:0: [sdb] Mode Sense: 23 00 00 00
[23961.531016] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[23961.546223] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[23961.546238] sdb: sdb1 sdb2
[23961.561516] sd 7:0:0:0: [sdb] Assuming drive cache: write through
[23961.561528] sd 7:0:0:0: [sdb] Attached SCSI removable disk
[23962.279593] EXT3 FS on sdb2, internal journal
user@HP:~$ sudo ${DVSDK}/bin/mksdboot.sh --device /dev/sdb --sdk ${DVSDK}
[sudo] password for user:
* THIS WILL DELETE ALL THE DATA ON /dev/sdb *
* WARNING! Make sure your computer does not go *
* in to idle mode while this script is *
* running. The script will complete, *
* but your SD card may be corrupted. *
* Press <ENTER> to confirm.... *
unmounting device '/dev/sdb1'
unmounting device '/dev/sdb2'
1024+0 records in
1024+0 records out
1048576 bytes (1.0 MB) copied, 0.760277 s, 1.4 MB/s
Disk /dev/sdb doesn't contain a valid partition table
Checking that no-one is using this disk right now ...
OK
Disk /dev/sdb: 482 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 0 does not have an MSDOS signature
/dev/sdb: unrecognised partition table type
Old situation:
No partitions found
New situation:
Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0
Device Boot Start End #cyls #blocks Id System
/dev/sdb1 * 0+ 4 5- 40131 c W95 FAT32 (LBA)
/dev/sdb2 5 481 477 3831502+ 83 Linux
/dev/sdb3 0 - 0 0 0 Empty
/dev/sdb4 0 - 0 0 0 Empty
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
Formating /dev/sdb1 ...
Formating /dev/sdb2 ...
mke2fs 1.41.11 (14-Mar-2010)
Image Name: Execute uImage.bin
Created: Thu Jan 26 09:01:22 2012
Image Type: ARM Linux Script (uncompressed)
Data Size: 238 Bytes = 0.23 kB = 0.00 MB
Load Address: 0x00000000
Entry Point: 0x00000000
Contents:
Image 0: 230 Bytes = 0 kB = 0 MB
Data Size: 295 Bytes = 0.29 kB = 0.00 MB
Contents:
Image 0: 287 Bytes = 0 kB = 0 MB
Select Primary display output:
1: LCD
2: DVI
[ 1 ]
Copying u-boot/mlo/uImage on /dev/sdb1
unmounting /dev/sdb1
Extracting filesystem on /dev/sdb2 ...
Creating matrix-gui-e symbolic link...done
unmounting /dev/sdb2
completed!
user@HP:~$ echo 'Now I am going to insert the SD card into evm'
This is the boot log of EVM:
Texas Instruments X-Loader 1.51 (Dec 22 2011 - 23:00:39)
Starting X-loader on MMC
Reading boot sector
229036 Bytes Read from MMC
Starting OS Bootloader from MMC...
Starting OS Bootloader...
U-Boot 2010.06 (Dec 22 2011 - 23:11:38)
OMAP34xx/35xx-GP ES2.0, CPU-OPP2 L3-165MHz
OMAP3 EVM board + LPDDR/NAND
I2C: ready
DRAM: 256 MiB
NAND: HW ECC [Kernel/FS layout] selected
512 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Read back SMSC id 0x92200000
Die ID #578400011ff00000015a5e590e01a02f
Net: smc911x-0
Hit any key to stop autoboot: 10 9 8 0
OMAP3_EVM # nand erase
NAND erase: device 0 whole chip
Erasing at 0x0 -- 0% complete.Erasing at 0x500000 -- 1% complete.Erasing at 0xa20000 -- 2% complete.Erasing at 0xf40000 -- 3% complete.Erasing at 0x1460000 -- 4% complete.Erasing at 0x1980000 -- 5% complete.Erasing at 0x1ea0000 -- 6% complete.Erasing at 0x23c0000 -- 7% complete.Erasing at 0x28e0000 -- 8% complete.Erasing at 0x2e00000 -- 9% complete.Erasing at 0x3320000 -- 10% complete.Erasing at 0x3840000 -- 11% complete.Erasing at 0x3d60000 -- 12% complete.Erasing at 0x4280000 -- 13% complete.Erasing at 0x47a0000 -- 14% complete.Erasing at 0x4cc0000 -- 15% complete.Erasing at 0x51e0000 -- 16% complete.Erasing at 0x5700000 -- 17% complete.Erasing at 0x5c20000 -- 18% complete.Erasing at 0x6140000 -- 19% complete.Erasing at 0x6660000 -- 20% complete.Erasing at 0x6b80000 -- 21% complete.Erasing at 0x70a0000 -- 22% complete.Erasing at 0x75c0000 -- 23% complete.Erasing at 0x7ae0000 -- 24% complete.Erasing at 0x7fe0000 -- 25% complete.Erasing at 0x8500000 -- 26% complete.Erasing at 0x8a20000 -- 27% complete.Erasing at 0x8f40000 -- 28% complete.Erasing at 0x9460000 -- 29% complete.Erasing at 0x9980000 -- 30% complete.Erasing at 0x9ea0000 -- 31% complete.Erasing at 0xa3c0000 -- 32% complete.Erasing at 0xa8e0000 -- 33% complete.Erasing at 0xae00000 -- 34% complete.Erasing at 0xb320000 -- 35% complete.Erasing at 0xb840000 -- 36% complete.Erasing at 0xbd60000 -- 37% complete.Erasing at 0xc280000 -- 38% complete.Erasing at 0xc7a0000 -- 39% complete.Erasing at 0xccc0000 -- 40% complete.Erasing at 0xd1e0000 -- 41% complete.Erasing at 0xd700000 -- 42% complete.Erasing at 0xdc20000 -- 43% complete.Erasing at 0xe140000 -- 44% complete.Erasing at 0xe660000 -- 45% complete.Erasing at 0xeb80000 -- 46% complete.Erasing at 0xf0a0000 -- 47% complete.Erasing at 0xf5c0000 -- 48% complete.Erasing at 0xfae0000 -- 49% complete.Erasing at 0xffe0000 -- 50% complete.Erasing at 0x10500000 -- 51% complete.Erasing at 0x10a20000 -- 52% complete.Erasing at 0x10f40000 -- 53% complete.Erasing at 0x11460000 -- 54% complete.Erasing at 0x11980000 -- 55% complete.Erasing at 0x11ea0000 -- 56% complete.Erasing at 0x123c0000 -- 57% complete.Erasing at 0x128e0000 -- 58% complete.Erasing at 0x12e00000 -- 59% complete.Erasing at 0x13320000 -- 60% complete.Erasing at 0x13840000 -- 61% complete.Erasing at 0x13d60000 -- 62% complete.Erasing at 0x14280000 -- 63% complete.Skipping bad block at 0x14300000
Erasing at 0x147a0000 -- 64% complete.Erasing at 0x14cc0000 -- 65% complete.Erasing at 0x151e0000 -- 66% complete.Erasing at 0x15700000 -- 67% complete.Erasing at 0x15c20000 -- 68% complete.Erasing at 0x16140000 -- 69% complete.Erasing at 0x16660000 -- 70% complete.Erasing at 0x16b80000 -- 71% complete.Erasing at 0x170a0000 -- 72% complete.Erasing at 0x175c0000 -- 73% complete.Erasing at 0x17ae0000 -- 74% complete.Erasing at 0x17fe0000 -- 75% complete.Erasing at 0x18500000 -- 76% complete.Erasing at 0x18a20000 -- 77% complete.Erasing at 0x18f40000 -- 78% complete.Erasing at 0x19460000 -- 79% complete.Erasing at 0x19980000 -- 80% complete.Erasing at 0x19ea0000 -- 81% complete.Erasing at 0x1a3c0000 -- 82% complete.Erasing at 0x1a8e0000 -- 83% complete.Erasing at 0x1ae00000 -- 84% complete.Erasing at 0x1b320000 -- 85% complete.Erasing at 0x1b840000 -- 86% complete.Erasing at 0x1bd60000 -- 87% complete.Erasing at 0x1c280000 -- 88% complete.Erasing at 0x1c7a0000 -- 89% complete.Erasing at 0x1ccc0000 -- 90% complete.Erasing at 0x1d1e0000 -- 91% complete.Erasing at 0x1d700000 -- 92% complete.Erasing at 0x1dc20000 -- 93% complete.Erasing at 0x1e140000 -- 94% complete.Erasing at 0x1e660000 -- 95% complete.Erasing at 0x1eb80000 -- 96% complete.Erasing at 0x1f0a0000 -- 97% complete.Erasing at 0x1f5c0000 -- 98% complete.Erasing at 0x1fae0000 -- 99% complete.Erasing at 0x1ffe0000 -- 100% complete.
OK
OMAP3_EVM # boot
mmc1 is available
reading boot.scr
302 bytes read
Running bootscript from mmc ...
## Executing script at 82000000
reading uImage
3289936 bytes read
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Arago/2.6.37-psp04.02.00.07.sdk/
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3289872 Bytes = 3.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 2.6.37 (a0876316@bangdvsdkdev01) (gcc version 4.3.3 (GCC) ) #1 Thu Dec 22 23:02:19 IST 2011
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP3 EVM
[ 0.000000] Reserving 4194304 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3630 ES1.1 (l2cache iva sgx neon isp 192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 45312
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw ip=off mem=55M@0x80000000 mpurate=1000 omap_vout.vid1_static_vrfb_alloc=y omapfb.vram=0:4M mem=128M@0x88000000 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 55MB 124MB = 179MB total
[ 0.000000] Memory: 167756k/167756k available, 19636k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xd0800000 - 0xf8000000 ( 632 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc003f000 ( 220 kB)
[ 0.000000] .text : 0xc003f000 - 0xc06254ec (6042 kB)
[ 0.000000] .data : 0xc0626000 - 0xc07e8560 (1802 kB)
[ 0.000000] NR_IRQS:409
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/400/1000 MHz
[ 0.000000] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.000000] Reprogramming SDRC clock to 400000000 Hz
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ402
[ 0.000000] Trying to install interrupt handler for IRQ403
[ 0.000000] Trying to install interrupt handler for IRQ404
[ 0.000000] Trying to install interrupt handler for IRQ405
[ 0.000000] Trying to install interrupt handler for IRQ406
[ 0.000000] Trying to install interrupt handler for IRQ407
[ 0.000000] Trying to install interrupt handler for IRQ408
[ 0.000000] Trying to install type control for IRQ409
[ 0.000000] Trying to set irq flags for IRQ409
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.000000] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.000000] ... MAX_LOCK_DEPTH: 48
[ 0.000000] ... MAX_LOCKDEP_KEYS: 8191
[ 0.000000] ... CLASSHASH_SIZE: 4096
[ 0.000000] ... MAX_LOCKDEP_ENTRIES: 16384
[ 0.000000] ... MAX_LOCKDEP_CHAINS: 32768
[ 0.000000] ... CHAINHASH_SIZE: 16384
[ 0.000000] memory used by lock dependency info: 3951 kB
[ 0.000000] per task-struct memory footprint: 2304 bytes
[ 0.000000] Calibrating delay loop... 998.84 BogoMIPS (lpj=3899392)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] ------------[ cut here ]------------
[ 0.000000] WARNING: at arch/arm/mach-omap2/clock.c:438 omap2_clk_switch_mpurate_at_boot+0x80/0xb4()
[ 0.000000] clock: dpll1_ck: unable to set MPU rate to 1000: -22
[ 0.000000] Modules linked in:
[ 0.000000] [<c004faf0>] (unwind_backtrace+0x0/0xec) from [<c00790c4>] (warn_slowpath_common+0x4c/0x64)
[ 0.000000] [<c00790c4>] (warn_slowpath_common+0x4c/0x64) from [<c0079170>] (warn_slowpath_fmt+0x30/0x40)
[ 0.000000] [<c0079170>] (warn_slowpath_fmt+0x30/0x40) from [<c00138ac>] (omap2_clk_switch_mpurate_at_boot+0x80/0xb4)
[ 0.000000] [<c00138ac>] (omap2_clk_switch_mpurate_at_boot+0x80/0xb4) from [<c00138ec>] (omap3xxx_clk_arch_init+0xc/0x3c)
[ 0.000000] [<c00138ec>] (omap3xxx_clk_arch_init+0xc/0x3c) from [<c003f3c8>] (do_one_initcall+0xc8/0x198)
[ 0.000000] [<c003f3c8>] (do_one_initcall+0xc8/0x198) from [<c000869c>] (kernel_init+0x98/0x150)
[ 0.000000] [<c000869c>] (kernel_init+0x98/0x150) from [<c004ad10>] (kernel_thread_exit+0x0/0x8)
[ 0.000000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.000000] OMAP DMA hardware revision 5.0
[ 0.078857] bio: create slab <bio-0> at 0
[ 0.082305] regulator: vwl1271: 1800 mV
[ 0.086029] SCSI subsystem initialized
[ 0.094757] usbcore: registered new interface driver usbfs
[ 0.095703] usbcore: registered new interface driver hub
[ 0.096313] usbcore: registered new device driver usb
[ 0.099731] omap_device: omap_i2c.1: new worst case activate latency 0: 30517
[ 0.099853] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.107604] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.107727] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.109344] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.121398] regulator: VIO: 1800 mV normal standby
[ 0.123291] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.125213] regulator: VDAC: 1800 mV normal standby
[ 0.127014] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.128967] regulator: VPLL2: 1800 mV normal standby
[ 0.130828] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.132690] regulator: VAUX3: 2800 mV normal standby
[ 0.133544] omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
[ 0.133789] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.144165] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.148468] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.151031] Bluetooth: Core ver 2.15
[ 0.151580] NET: Registered protocol family 31
[ 0.151611] Bluetooth: HCI device and connection manager initialized
[ 0.151702] Bluetooth: HCI socket layer initialized
[ 0.153411] Switching to clocksource 32k_counter
[ 0.237396] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.237670] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.238403] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.239868] NET: Registered protocol family 2
[ 0.240264] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.241424] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.241668] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[ 0.244201] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.244262] TCP reno registered
[ 0.244293] UDP hash table entries: 128 (order: 1, 12288 bytes)
[ 0.244476] UDP-Lite hash table entries: 128 (order: 1, 12288 bytes)
[ 0.245117] NET: Registered protocol family 1
[ 0.246124] RPC: Registered udp transport module.
[ 0.246154] RPC: Registered tcp transport module.
[ 0.246154] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.246826] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.249633] omap_device: omap_i2c.1: new worst case activate latency 0: 61035
[ 0.251770] omap3evm camera init done successfully...
[ 0.252288] omap-iommu omap-iommu.0: isp registered
[ 0.252868] AM37x/DM37x Linux PSP version 04.02.00.07 (OMAP3EVM)
[ 0.356445] VFS: Disk quotas dquot_6.5.2
[ 0.356536] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.358306] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.358978] msgmni has been set to 327
[ 0.362915] io scheduler noop registered
[ 0.362915] io scheduler deadline registered
[ 0.363067] io scheduler cfq registered (default)
[ 0.427215] OMAP DSS rev 2.0
[ 0.427581] OMAP DISPC rev 3.0
[ 0.427642] OMAP VENC rev 2
[ 0.428405] OMAP DSI rev 1.0
[ 0.758117] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.763885] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.605010] console [ttyO0] enabled
[ 1.609954] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.618347] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.626708] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.663604] brd: module loaded
[ 1.680969] loop: module loaded
[ 1.690307] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.697204] omap2-nand driver initializing
[ 1.702056] NAND device: Manufacturer ID: 0xad, Chip ID: 0xbc (Hynix )
[ 1.708984] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.714538] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.726715] 0x000000080000-0x0000001c0000 : "U-Boot-NAND"
[ 1.737182] 0x0000001c0000-0x000000280000 : "Boot Env-NAND"
[ 1.747741] 0x000000280000-0x000000780000 : "Kernel-NAND"
[ 1.759796] 0x000000780000-0x000020000000 : "File System - NAND"
[ 2.009979] OneNAND driver initializing
[ 2.014282] omap2-onenand omap2-onenand: Cannot request GPMC CS
[ 2.020629] omap2-onenand: probe of omap2-onenand failed with error -16
[ 2.030517] smsc911x: Driver version 2008-10-21.
[ 2.040344] smsc911x-mdio: probed
[ 2.044250] eth0: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=ffffffff:01, irq=-1)
[ 2.054443] net eth0: MAC Address: 00:50:c2:7e:94:86
[ 2.060791] usbcore: registered new interface driver asix
[ 2.066894] usbcore: registered new interface driver cdc_ether
[ 2.073516] usbcore: registered new interface driver net1080
[ 2.079925] usbcore: registered new interface driver cdc_subset
[ 2.086608] usbcore: registered new interface driver zaurus
[ 2.092529] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.106658] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.113800] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.122100] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.138000] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.144592] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.151733] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.159332] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.164916] usb usb1: Manufacturer: Linux 2.6.37 ehci_hcd
[ 3.170562] usb usb1: SerialNumber: ehci-omap.0
[ 3.178924] hub 1-0:1.0: USB hub found
[ 3.182983] hub 1-0:1.0: 3 ports detected
[ 3.216766] Initializing USB Mass Storage driver...
[ 3.222473] usbcore: registered new interface driver usb-storage
[ 3.228790] USB Mass Storage support registered.
[ 3.234222] usbcore: registered new interface driver usbtest
[ 3.240264] g_ether gadget: using random self ethernet address
[ 3.246398] g_ether gadget: using random host ethernet address
[ 3.253997] usb0: MAC 56:7d:e7:54:4d:55
[ 3.258087] usb0: HOST MAC 06:44:f4:59:39:4f
[ 3.262573] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 3.269561] g_ether gadget: g_ether ready
[ 3.273773] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.279541] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 3.288269] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.295440] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.303009] usb usb2: Product: MUSB HDRC host driver
[ 3.308197] usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
[ 3.313873] usb usb2: SerialNumber: musb-hdrc.0
[ 3.321136] hub 2-0:1.0: USB hub found
[ 3.325195] hub 2-0:1.0: 1 port detected
[ 3.333160] mice: PS/2 mouse device common for all mice
[ 3.341400] input: TWL4030 Keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 3.359161] ads7846 spi1.0: touchscreen, irq 335
[ 3.365966] input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input1
[ 3.380249] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input2
[ 3.394470] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.401184] twl_rtc twl_rtc: Power up reset detected.
[ 3.407226] twl_rtc twl_rtc: Enabling TWL-RTC.
[ 3.413543] i2c /dev entries driver
[ 3.421783] Linux media interface: v0.10
[ 3.426361] Linux video capture interface: v2.00
[ 3.433258] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 3.440368] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 3.447784] omap3isp omap3isp: Revision 15.0 found
[ 3.453063] omap-iommu omap-iommu.0: isp: version 1.1
[ 3.526184] mt9t111 2-003c: Unable to detectmt9t111sensor
[ 3.536956] isp_register_subdev_group: Unable to register subdev mt9t111
[ 3.545349] tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
[ 3.556304] tvp514x 3-005c: tvp5146m2 (Version - 0x03) found at 0xb8 (OMAP I2C adapter)
[ 3.571594] usbcore: registered new interface driver uvcvideo
[ 3.577667] USB Video Class driver (v1.0.0)
[ 3.582305] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
[ 3.591369] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.597686] omap_device: omap_wdt.-1: new worst case deactivate latency 0: 30517
[ 3.606018] Bluetooth: HCI UART driver ver 2.2
[ 3.610717] Bluetooth: HCI H4 protocol initialized
[ 3.615753] Bluetooth: HCILL protocol initialized
[ 3.628753] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[ 3.641601] usbcore: registered new interface driver usbhid
[ 3.647491] usbhid: USB HID core driver
[ 3.654083] usbcore: registered new interface driver snd-usb-audio
[ 3.664184] OMAP3 EVM SoC init
[ 3.764343] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 3.775787] ALSA device list:
[ 3.778991] #0: omap3evm
[ 3.781829] oprofile: hardware counters not available
[ 3.787139] oprofile: using timer interrupt.
[ 3.791748] nf_conntrack version 0.5.0 (2621 buckets, 10484 max)
[ 3.799377] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.805480] TCP cubic registered
[ 3.808868] Initializing XFRM netlink socket
[ 3.813507] NET: Registered protocol family 17
[ 3.818267] NET: Registered protocol family 15
[ 3.823791] Bluetooth: L2CAP ver 2.15
[ 3.827667] Bluetooth: L2CAP socket layer initialized
[ 3.833007] Bluetooth: SCO (Voice Link) ver 0.6
[ 3.837768] Bluetooth: SCO socket layer initialized
[ 3.843322] Bluetooth: RFCOMM TTY layer initialized
[ 3.848480] Bluetooth: RFCOMM socket layer initialized
[ 3.853912] Bluetooth: RFCOMM ver 1.11
[ 3.857849] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.863403] Bluetooth: BNEP filters: protocol multicast
[ 3.868896] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.877624] Registering the dns_resolver key type
[ 3.883087] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 3.894165] ThumbEE CPU extension supported.
[ 3.913543] Power Management for TI OMAP3.
[ 3.918426] sr_init: No PMIC hook to init smartreflex
[ 3.924133] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 3.932769] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 3.941894] SmartReflex Class3 initialized
[ 3.976715] clock: disabling unused clocks to save power
[ 3.984222] platform mpu.0: omap_voltage_scale: Already at the requestedrate 1000000000
[ 4.086486] twl_rtc twl_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 4.095275] omap_vout omap_vout: Buffer Size = 3686400
[ 4.113739] omap_vout omap_vout: : registered and initialized video device 16
[ 4.121337] omap_vout omap_vout: Buffer Size = 3686400
[ 4.128570] omap_vout omap_vout: : registered and initialized video device 17
[ 4.139953] Waiting for root device /dev/mmcblk0p2...
[ 4.161529] mmc0: new SDHC card at address ea7e
[ 4.168182] mmcblk0: mmc0:ea7e SD04G 3.69 GiB
[ 4.181121] mmcblk0: p1 p2
[ 4.274536] EXT3-fs: barriers not enabled
[ 4.281066] kjournald starting. Commit interval 5 seconds
[ 4.291412] EXT3-fs (mmcblk0p2): using internal journal
[ 4.297302] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 4.304931] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 4.311370] Freeing init memory: 220K
[ 4.320465] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 4.351348] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.359771] mmc1: new SDIO card at address 0001
INIT: version 2.86 booting
Please wait: booting...
Starting udev
WARNING: -e needs -E or -F
[ 6.447937] udevd (737): /proc/737/oom_adj is deprecated, please use /proc/737/oom_score_adj instead.
[ 7.460296] cfg80211: Calling CRDA to update world regulatory domain
[ 7.785980] Compat-wireless backport release: compat-wireless-2011-04-26-3-g6542f4c
[ 7.794097] Backport based on wl12xx.git v2.6.35-33527-g1bbadc2
[ 11.426177] cfg80211: World regulatory domain updated:
[ 11.431640] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 11.440429] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 11.448760] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 11.457061] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 11.465362] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 11.473663] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 16.522338] wl1271: loaded
[ 16.525177] wl1271: initialized
Remounting root file system...
Caching udev devnodes
Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
ALSA: Restoring mixer settings...
No state is present for card omap3evm
Found hardware: "" "" "" "" ""
Hardware is initialized using a generic method
Configuring dbus.
Adding system startup for /etc/init.d/dbus-1.
Configuring qt4-embedded-demos.
Configuring qt4-embedded-blitrix.
Configuring update-modules.
Configuring omap3-sgx-modules.
Configuring wl1271-bluetooth.
Configuring ti-dsplink-module.
Configuring ti-lpm-module.
Configuring kernel-module-gspca-main.
Configuring ti-cmem-module.
Configuring kernel-module-cryptodev.
Configuring kernel-module-scsi-wait-scan.
Configuring kernel-module-generic-bl.
Configuring ti-dvsdk-demos.
Configuring ti-dvtb.
Configuring ti-sdma-module.
Configuring ti-dmai-apps.
Configuring ti-ocf-crypto-module.
Configuring wpa-supplicant.
Configuring kernel-image-2.6.37.
Configuring ti-compat-wireless-wl12xx.
Configuring network interfaces... [ 23.946533] net eth0: SMSC911x/921x identified at 0xd0884000, IRQ: 336
eth0 no wireless extensions.
udhcpc (v1.13.2) started
Sending discover...
Sending discover...
Sending discover...
No lease, forking to background
done.
Setting up IP spoofing protection: rp_filter.
Fri Dec 23 00:34:00 UTC 2011
[ 33.481750] omap_device: omap_i2c.1: new worst case deactivate latency 0: 61035
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Creating Dropbear SSH server RSA host key.
Will output 1024 bit rsa secret key to '/etc/dropbear/dropbear_rsa_host_key'
Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwCcX5jGGEZ6rsEgt06I20bMt7wsn6i2gzn1CM70zpPG4KW4P55hdR3ImCA4mciTvJncwStzWR8SF6Re/0/hjNJU1MVrXyPIsFIhlXGTvC2Yoj0mEC2Iqb1ZmkqLUaFuOezBNsNkuTx4Cb4Z8ZKjVDXXWgOlilYrwgMdtgiCYlWWfzrB root@dm37x-evm
Fingerprint: md5 52:39:4f:9d:93:7a:66:75:ac:ed:ca:5b:6d:91:d9:2d
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting network benchmark server: netserver.
Starting syslogd/klogd: done
Starting thttpd.
Starting PVR
Starting SGX fixup for ES5.x
[ 36.156433]
[ 36.156463] =============================================
[ 36.163635] [ INFO: possible recursive locking detected ]
[ 36.169281] 2.6.37 #1
[ 36.171661] ---------------------------------------------
[ 36.177276] pvrsrvinit/2552 is trying to acquire lock:
[ 36.182647] (psPVRSRVMutex){+.+.+.}, at: [<bf16abc8>] PVRMMapRegisterArea+0x14/0x68 [pvrsrvkm]
[ 36.191894]
[ 36.191894] but task is already holding lock:
[ 36.197967] (psPVRSRVMutex){+.+.+.}, at: [<bf16db34>] PVRSRV_BridgeDispatchKM+0x20/0x16c [pvrsrvkm]
[ 36.207580]
[ 36.207611] other info that might help us debug this:
[ 36.214416] 1 lock held by pvrsrvinit/2552:
[ 36.218780] #0: (psPVRSRVMutex){+.+.+.}, at: [<bf16db34>] PVRSRV_BridgeDispatchKM+0x20/0x16c [pvrsrvkm]
[ 36.228851]
[ 36.228851] stack backtrace:
[ 36.233428] [<c004faf0>] (unwind_backtrace+0x0/0xec) from [<c00a91ac>] (__lock_acquire+0xf98/0x18d0)
[ 36.242980] [<c00a91ac>] (__lock_acquire+0xf98/0x18d0) from [<c00a9bb8>] (lock_acquire+0xd4/0xf4)
[ 36.252258] [<c00a9bb8>] (lock_acquire+0xd4/0xf4) from [<c047375c>] (mutex_lock_nested+0x5c/0x2d8)
[ 36.261688] [<c047375c>] (mutex_lock_nested+0x5c/0x2d8) from [<bf16abc8>] (PVRMMapRegisterArea+0x14/0x68 [pvrsrvkm])
[ 36.272766] [<bf16abc8>] (PVRMMapRegisterArea+0x14/0x68 [pvrsrvkm]) from [<bf16d944>] (OSAllocPages_Impl+0x68/0xa4 [pvrsrvkm])
[ 36.284759] [<bf16d944>] (OSAllocPages_Impl+0x68/0xa4 [pvrsrvkm]) from [<bf1642e8>] (BM_ImportMemory+0xe4/0x290 [pvrsrvkm])
[ 36.296478] [<bf1642e8>] (BM_ImportMemory+0xe4/0x290 [pvrsrvkm]) from [<bf168b0c>] (RA_Alloc+0xb4/0x288 [pvrsrvkm])
[ 36.307464] [<bf168b0c>] (RA_Alloc+0xb4/0x288 [pvrsrvkm]) from [<bf163cb0>] (BM_Alloc+0xa8/0x280 [pvrsrvkm])
[ 36.317810] [<bf163cb0>] (BM_Alloc+0xa8/0x280 [pvrsrvkm]) from [<bf169ac0>] (AllocDeviceMem+0x80/0x108 [pvrsrvkm])
[ 36.328735] [<bf169ac0>] (AllocDeviceMem+0x80/0x108 [pvrsrvkm]) from [<bf169fd8>] (_PVRSRVAllocDeviceMemKM+0x80/0x158 [pvrsrvkm])
[ 36.341003] [<bf169fd8>] (_PVRSRVAllocDeviceMemKM+0x80/0x158 [pvrsrvkm]) from [<bf174190>] (PVRSRVAllocDeviceMemBW+0x9c/0x1a0 [pvrsrvkm])
[ 36.354034] [<bf174190>] (PVRSRVAllocDeviceMemBW+0x9c/0x1a0 [pvrsrvkm]) from [<bf171d24>] (BridgedDispatchKM+0xd4/0x12c [pvrsrvkm])
[ 36.366485] [<bf171d24>] (BridgedDispatchKM+0xd4/0x12c [pvrsrvkm]) from [<bf16dc28>] (PVRSRV_BridgeDispatchKM+0x114/0x16c [pvrsrvkm])
[ 36.379089] [<bf16dc28>] (PVRSRV_BridgeDispatchKM+0x114/0x16c [pvrsrvkm]) from [<c0116cf8>] (do_vfs_ioctl+0x4e0/0x54c)
[ 36.390289] [<c0116cf8>] (do_vfs_ioctl+0x4e0/0x54c) from [<c0116db4>] (sys_ioctl+0x50/0x74)
[ 36.399017] [<c0116db4>] (sys_ioctl+0x50/0x74) from [<c0049cc0>] (ret_fast_syscall+0x0/0x3c)
Reading boot sector
I2C: ready
DRAM: 256 MiB
512 MiB
In: serial
Out: serial
Err: serial
Net: smc911x-0
Hit any key to stop autoboot: 10 9 8 7 6 5 4 3 2 1 0
mmc1 is available
reading boot.scr
302 bytes read
reading uImage
3289936 bytes read
OK
Starting kernel ...
[ 0.078887] bio: create slab <bio-0> at 0
[ 0.082366] regulator: vwl1271: 1800 mV
[ 0.086090] SCSI subsystem initialized
[ 0.094848] usbcore: registered new interface driver usbfs
[ 0.095764] usbcore: registered new interface driver hub
[ 0.096496] usbcore: registered new device driver usb
[ 0.099792] omap_device: omap_i2c.1: new worst case activate latency 0: 30517
[ 0.112915] omap_i2c omap_i2c.1: bus 1 rev4.0 at 2600 kHz
[ 0.120819] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 0.120941] twl4030: power (irq 373) chaining IRQs 376..383
[ 0.122589] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 0.134582] regulator: VIO: 1800 mV normal standby
[ 0.136535] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal standby
[ 0.138458] regulator: VDAC: 1800 mV normal standby
[ 0.140289] regulator: VAUX2_4030: 2800 mV normal standby
[ 0.142181] regulator: VPLL2: 1800 mV normal standby
[ 0.144073] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal standby
[ 0.145935] regulator: VAUX3: 2800 mV normal standby
[ 0.147033] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.147857] omap_device: omap_i2c.2: new worst case deactivate latency 0: 30517
[ 0.159698] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.163970] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.166534] Bluetooth: Core ver 2.15
[ 0.167083] NET: Registered protocol family 31
[ 0.167114] Bluetooth: HCI device and connection manager initialized
[ 0.167205] Bluetooth: HCI socket layer initialized
[ 0.168914] Switching to clocksource 32k_counter
[ 0.252929] musb-hdrc: version 6.0, otg (peripheral+host), debug=0
[ 0.253204] musb-hdrc musb-hdrc.0: dma type: dma-inventra
[ 0.253936] musb-hdrc musb-hdrc.0: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
[ 0.255371] NET: Registered protocol family 2
[ 0.255767] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.256927] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.257202] TCP bind hash table entries: 8192 (order: 6, 360448 bytes)
[ 0.259704] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.259765] TCP reno registered
[ 0.259796] UDP hash table entries: 128 (order: 1, 12288 bytes)
[ 0.259979] UDP-Lite hash table entries: 128 (order: 1, 12288 bytes)
[ 0.260620] NET: Registered protocol family 1
[ 0.261627] RPC: Registered udp transport module.
[ 0.261657] RPC: Registered tcp transport module.
[ 0.261657] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.262329] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.265106] omap_device: omap_i2c.1: new worst case activate latency 0: 61035
[ 0.267272] omap3evm camera init done successfully...
[ 0.267791] omap-iommu omap-iommu.0: isp registered
[ 0.268371] AM37x/DM37x Linux PSP version 04.02.00.07 (OMAP3EVM)
[ 0.371978] VFS: Disk quotas dquot_6.5.2
[ 0.372039] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.373840] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.374481] msgmni has been set to 327
[ 0.378448] io scheduler noop registered
[ 0.378448] io scheduler deadline registered
[ 0.378570] io scheduler cfq registered (default)
[ 0.442718] OMAP DSS rev 2.0
[ 0.443054] OMAP DISPC rev 3.0
[ 0.443145] OMAP VENC rev 2
[ 0.443908] OMAP DSI rev 1.0
[ 0.773529] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.779327] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.620452] console [ttyO0] enabled
[ 1.625396] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.633789] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.642181] omap_uart.3: ttyO3 at MMIO 0x49042000 (irq = 80) is a OMAP UART3
[ 1.679138] brd: module loaded
[ 1.696441] loop: module loaded
[ 1.705841] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.712707] omap2-nand driver initializing
[ 1.717559] NAND device: Manufacturer ID: 0xad, Chip ID: 0xbc (Hynix )
[ 1.724487] Creating 5 MTD partitions on "omap2-nand.0":
[ 1.730072] 0x000000000000-0x000000080000 : "X-Loader-NAND"
[ 1.742187] 0x000000080000-0x0000001c0000 : "U-Boot-NAND"
[ 1.752655] 0x0000001c0000-0x000000280000 : "Boot Env-NAND"
[ 1.763214] 0x000000280000-0x000000780000 : "Kernel-NAND"
[ 1.775238] 0x000000780000-0x000020000000 : "File System - NAND"
[ 2.025421] OneNAND driver initializing
[ 2.029754] omap2-onenand omap2-onenand: Cannot request GPMC CS
[ 2.036102] omap2-onenand: probe of omap2-onenand failed with error -16
[ 2.045989] smsc911x: Driver version 2008-10-21.
[ 2.055816] smsc911x-mdio: probed
[ 2.059753] eth0: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=ffffffff:01, irq=-1)
[ 2.068878] net eth0: MAC Address: 00:50:c2:7e:94:86
[ 2.075195] usbcore: registered new interface driver asix
[ 2.081390] usbcore: registered new interface driver cdc_ether
[ 2.087982] usbcore: registered new interface driver net1080
[ 2.094390] usbcore: registered new interface driver cdc_subset
[ 2.101074] usbcore: registered new interface driver zaurus
[ 2.106964] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.122161] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.129302] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 3.137573] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.153503] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.160095] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.167236] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.174835] usb usb1: Product: OMAP-EHCI Host Controller
[ 3.180419] usb usb1: Manufacturer: Linux 2.6.37 ehci_hcd
[ 3.186096] usb usb1: SerialNumber: ehci-omap.0
[ 3.194427] hub 1-0:1.0: USB hub found
[ 3.198486] hub 1-0:1.0: 3 ports detected
[ 3.232299] Initializing USB Mass Storage driver...
[ 3.238006] usbcore: registered new interface driver usb-storage
[ 3.244323] USB Mass Storage support registered.
[ 3.249755] usbcore: registered new interface driver usbtest
[ 3.255798] g_ether gadget: using random self ethernet address
[ 3.261932] g_ether gadget: using random host ethernet address
[ 3.269561] usb0: MAC de:fc:ed:60:01:fc
[ 3.273620] usb0: HOST MAC 06:0b:2c:0a:49:1b
[ 3.278137] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 3.285095] g_ether gadget: g_ether ready
[ 3.289337] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.295104] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 3.303833] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.311004] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.318572] usb usb2: Product: MUSB HDRC host driver
[ 3.323760] usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
[ 3.329437] usb usb2: SerialNumber: musb-hdrc.0
[ 3.336730] hub 2-0:1.0: USB hub found
[ 3.340759] hub 2-0:1.0: 1 port detected
[ 3.348785] mice: PS/2 mouse device common for all mice
[ 3.356964] input: TWL4030 Keypad as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/twl4030_keypad/input/input0
[ 3.374725] ads7846 spi1.0: touchscreen, irq 335
[ 3.381530] input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input1
[ 3.395874] input: twl4030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl4030_pwrbutton/input/input2
[ 3.410034] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 3.419219] i2c /dev entries driver
[ 3.426971] Linux media interface: v0.10
[ 3.431579] Linux video capture interface: v2.00
[ 3.438171] omap3isp supply VDD_CSIPHY1 not found, using dummy regulator
[ 3.445312] omap3isp supply VDD_CSIPHY2 not found, using dummy regulator
[ 3.452758] omap3isp omap3isp: Revision 15.0 found
[ 3.457977] omap-iommu omap-iommu.0: isp: version 1.1
[ 3.531402] mt9t111 2-003c: Unable to detectmt9t111sensor
[ 3.542083] isp_register_subdev_group: Unable to register subdev mt9t111
[ 3.550506] tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
[ 3.561462] tvp514x 3-005c: tvp5146m2 (Version - 0x03) found at 0xb8 (OMAP I2C adapter)
[ 3.576843] usbcore: registered new interface driver uvcvideo
[ 3.582824] USB Video Class driver (v1.0.0)
[ 3.587524] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
[ 3.596557] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.603485] Bluetooth: HCI UART driver ver 2.2
[ 3.608184] Bluetooth: HCI H4 protocol initialized
[ 3.613189] Bluetooth: HCILL protocol initialized
[ 3.626098] mmci-omap-hs.1 supply vmmc_aux not found, using dummy regulator
[ 3.639038] usbcore: registered new interface driver usbhid
[ 3.644866] usbhid: USB HID core driver
[ 3.651428] usbcore: registered new interface driver snd-usb-audio
[ 3.661590] OMAP3 EVM SoC init
[ 3.759246] asoc: twl4030-hifi <-> omap-mcbsp-dai.1 mapping ok
[ 3.770690] ALSA device list:
[ 3.773803] #0: omap3evm
[ 3.776641] oprofile: hardware counters not available
[ 3.781982] oprofile: using timer interrupt.
[ 3.786621] nf_conntrack version 0.5.0 (2621 buckets, 10484 max)
[ 3.794281] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.800292] TCP cubic registered
[ 3.803741] Initializing XFRM netlink socket
[ 3.808349] NET: Registered protocol family 17
[ 3.813110] NET: Registered protocol family 15
[ 3.818634] Bluetooth: L2CAP ver 2.15
[ 3.822479] Bluetooth: L2CAP socket layer initialized
[ 3.827850] Bluetooth: SCO (Voice Link) ver 0.6
[ 3.832580] Bluetooth: SCO socket layer initialized
[ 3.838104] Bluetooth: RFCOMM TTY layer initialized
[ 3.843322] Bluetooth: RFCOMM socket layer initialized
[ 3.848724] Bluetooth: RFCOMM ver 1.11
[ 3.852661] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.858245] Bluetooth: BNEP filters: protocol multicast
[ 3.863708] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.872528] Registering the dns_resolver key type
[ 3.877838] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 3.888946] ThumbEE CPU extension supported.
[ 3.906311] Power Management for TI OMAP3.
[ 3.911163] sr_init: No PMIC hook to init smartreflex
[ 3.916900] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 3.925537] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 3.935668] SmartReflex Class3 initialized
[ 3.970489] clock: disabling unused clocks to save power
[ 3.977966] platform mpu.0: omap_voltage_scale: Already at the requestedrate 1000000000
[ 4.078582] twl_rtc twl_rtc: setting system clock to 2011-12-23 00:35:08 UTC (1324600508)
[ 4.087463] omap_vout omap_vout: Buffer Size = 3686400
[ 4.105957] omap_vout omap_vout: : registered and initialized video device 16
[ 4.113525] omap_vout omap_vout: Buffer Size = 3686400
[ 4.120635] omap_vout omap_vout: : registered and initialized video device 17
[ 4.132049] Waiting for root device /dev/mmcblk0p2...
[ 4.153594] mmc0: new SDHC card at address ea7e
[ 4.160247] mmcblk0: mmc0:ea7e SD04G 3.69 GiB
[ 4.173187] mmcblk0: p1 p2
[ 4.267669] EXT3-fs: barriers not enabled
[ 4.298736] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 4.335571] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.344055] mmc1: new SDIO card at address 0001
[ 5.184814] kjournald starting. Commit interval 5 seconds
[ 5.195892] EXT3-fs (mmcblk0p2): using internal journal
[ 5.201446] EXT3-fs (mmcblk0p2): recovery complete
[ 5.211273] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 5.218902] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 5.225341] Freeing init memory: 220K
Starting udev
[ 6.533905] udevd (737): /proc/737/oom_adj is deprecated, please use /proc/737/oom_score_adj instead.
[ 7.708374] cfg80211: Calling CRDA to update world regulatory domain
[ 7.969085] Compat-wireless backport release: compat-wireless-2011-04-26-3-g6542f4c
[ 7.977172] Backport based on wl12xx.git v2.6.35-33527-g1bbadc2
[ 12.378326] cfg80211: World regulatory domain updated:
[ 12.383819] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 12.392578] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 12.400878] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 12.409210] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 12.417510] cfg80211: (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 12.425842] cfg80211: (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 16.506256] wl1271: loaded
[ 16.509094] wl1271: initialized
Configuring network interfaces... No state is present for card omap3evm
[ 19.630645] net eth0: SMSC911x/921x identified at 0xd0884000, IRQ: 336
Sending discover...
Sending discover...
Sending discover...
Sending select for 1.1.8.1...
Lease of 1.1.8.1 obtained, lease time 3600
adding dns 1.1.1.131
adding dns 1.0.0.88
done.
UUID file '/var/lib/dbus/machine-id' should contain a hex string of length 32, not length 0, with no other text
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgwCjL9JwxnS8iOx+xhgeQ4dwa3s42O8SZ7e4Nvw/yjev4E967etgw0fEXhwJfvA4ETek11Oyk8oaJghcxR9xgnxo7u9cmb9LMkNTqX1GMZIVtyGTbcpknbMthtflrVEMknSVx9nDPS7HNKjo+4kgZX/Kc05PWlpMyocxm38g3ylLzy69 root@dm37x-evm
Fingerprint: md5 a4:01:c1:a8:d7:f1:4c:b6:96:e2:1b:ea:94:fb:ca:4b
Starting thttpd.
Starting PVR
[ 29.035491]
[ 29.035491] =============================================
[ 29.042694] [ INFO: possible recursive locking detected ]
[ 29.048339] 2.6.37 #1
[ 29.050689] ---------------------------------------------
[ 29.056335] pvrsrvinit/2180 is trying to acquire lock:
[ 29.061706] (psPVRSRVMutex){+.+.+.}, at: [<bf171bc8>] PVRMMapRegisterArea+0x14/0x68 [pvrsrvkm]
[ 29.070922]
[ 29.070922] but task is already holding lock:
[ 29.077026] (psPVRSRVMutex){+.+.+.}, at: [<bf174b34>] PVRSRV_BridgeDispatchKM+0x20/0x16c [pvrsrvkm]
[ 29.086639]
[ 29.086639] other info that might help us debug this:
[ 29.093475] 1 lock held by pvrsrvinit/2180:
[ 29.097839] #0: (psPVRSRVMutex){+.+.+.}, at: [<bf174b34>] PVRSRV_BridgeDispatchKM+0x20/0x16c [pvrsrvkm]
[ 29.107879]
[ 29.107910] stack backtrace:
[ 29.112457] [<c004faf0>] (unwind_backtrace+0x0/0xec) from [<c00a91ac>] (__lock_acquire+0xf98/0x18d0)
[ 29.122009] [<c00a91ac>] (__lock_acquire+0xf98/0x18d0) from [<c00a9bb8>] (lock_acquire+0xd4/0xf4)
[ 29.131317] [<c00a9bb8>] (lock_acquire+0xd4/0xf4) from [<c047375c>] (mutex_lock_nested+0x5c/0x2d8)
[ 29.140716] [<c047375c>] (mutex_lock_nested+0x5c/0x2d8) from [<bf171bc8>] (PVRMMapRegisterArea+0x14/0x68 [pvrsrvkm])
[ 29.151824] [<bf171bc8>] (PVRMMapRegisterArea+0x14/0x68 [pvrsrvkm]) from [<bf174944>] (OSAllocPages_Impl+0x68/0xa4 [pvrsrvkm])
[ 29.163818] [<bf174944>] (OSAllocPages_Impl+0x68/0xa4 [pvrsrvkm]) from [<bf16b2e8>] (BM_ImportMemory+0xe4/0x290 [pvrsrvkm])
[ 29.175537] [<bf16b2e8>] (BM_ImportMemory+0xe4/0x290 [pvrsrvkm]) from [<bf16fb0c>] (RA_Alloc+0xb4/0x288 [pvrsrvkm])
[ 29.186523] [<bf16fb0c>] (RA_Alloc+0xb4/0x288 [pvrsrvkm]) from [<bf16acb0>] (BM_Alloc+0xa8/0x280 [pvrsrvkm])
[ 29.196868] [<bf16acb0>] (BM_Alloc+0xa8/0x280 [pvrsrvkm]) from [<bf170ac0>] (AllocDeviceMem+0x80/0x108 [pvrsrvkm])
[ 29.207763] [<bf170ac0>] (AllocDeviceMem+0x80/0x108 [pvrsrvkm]) from [<bf170fd8>] (_PVRSRVAllocDeviceMemKM+0x80/0x158 [pvrsrvkm])
[ 29.220062] [<bf170fd8>] (_PVRSRVAllocDeviceMemKM+0x80/0x158 [pvrsrvkm]) from [<bf17b190>] (PVRSRVAllocDeviceMemBW+0x9c/0x1a0 [pvrsrvkm])
[ 29.233062] [<bf17b190>] (PVRSRVAllocDeviceMemBW+0x9c/0x1a0 [pvrsrvkm]) from [<bf178d24>] (BridgedDispatchKM+0xd4/0x12c [pvrsrvkm])
[ 29.245544] [<bf178d24>] (BridgedDispatchKM+0xd4/0x12c [pvrsrvkm]) from [<bf174c28>] (PVRSRV_BridgeDispatchKM+0x114/0x16c [pvrsrvkm])
[ 29.258148] [<bf174c28>] (PVRSRV_BridgeDispatchKM+0x114/0x16c [pvrsrvkm]) from [<c0116cf8>] (do_vfs_ioctl+0x4e0/0x54c)
[ 29.269317] [<c0116cf8>] (do_vfs_ioctl+0x4e0/0x54c) from [<c0116db4>] (sys_ioctl+0x50/0x74)
[ 29.278076] [<c0116db4>] (sys_ioctl+0x50/0x74) from [<c0049cc0>] (ret_fast_syscall+0x0/0x3c)
[ 29.347351] CMEMK module: built on Dec 22 2011 at 23:52:43
[ 29.353179] Reference Linux version 2.6.37
[ 29.357666] File /datalocal/DVSDK43_HPDL380G7/arago-tmp/work/dm37x-evm-arago-linux-gnueabi/ti-linuxutils-1_2_26_02_05-r102d/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 29.376464] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 29.382965] CMEM phys_start (0x83700000) overlaps kernel (0x80000000 -> 0x8b300000)
[ 29.392425] allocated heap buffer 0xd2000000 of size 0x2200000
[ 29.398559] heap fallback enabled - will try heap if pool buffer is not available
[ 29.406433] cmemk initialized
[ 29.614685] DSPLINK Module (1.65.01.05_eng) created on Date: Dec 22 2011 Time: 23:55:34
[ 29.703460] SDMAK module: built on Dec 22 2011 at 23:52:50
[ 29.709289] Reference Linux version 2.6.37
[ 29.713745] File /datalocal/DVSDK43_HPDL380G7/arago-tmp/work/dm37x-evm-arago-linux-gnueabi/ti-linuxutils-1_2_26_02_05-r102d/linuxutils_2_26_02_05/packages/ti/sdo/linuxutils/sdma/src/module/sdmak.c
numid=49,iface=MIXER,name='HeadsetL Mixer AudioL1'
; type=BOOLEAN,access=rw------,values=1
: values=on
numid=46,iface=MIXER,name='HeadsetR Mixer AudioR1'
: values=on
Simple mixer control 'Headset',0
Capabilities: pvolume penum
Playback channels: Front Left - Front Right
Limits: Playback 0 - 3
Mono:
Front Left: Playback 1 [33%] [-6.00dB]
Front Right: Playback 1 [33%] [-6.00dB]
Calibrating touchscreen (first time only)xres = 480, yres = 640
Took 9 samples...
Top left : X = 502 Y = 450
Took 16 samples...
Top right : X = 3449 Y = 460
Took 11 samples...
Bot right : X = 3342 Y = 3492
Took 8 samples...
Bot left : X = 490 Y = 3588
Took 7 samples...
Center : X = 1845 Y = 1955
-16.968811 0.130928 0.002440
-32.838501 0.002467 0.175007
Calibration constants: -1112068 8580 159 -2152104 161 11469 65536
Starting Matrix GUI application.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dm37x-evm ttyO0
Arago 2011.06 dm37x-evm ttyO0
dm37x-evm login:
