Problem executing C6Accel example with TI8148 evm
I am trying to program DSP application with latest EZSDK and 8148EVM,
so i compiled last C6accel, and modify memory map (config.bld file) to match my linux memory map (512MB),
Anyway the application hungs system when executed, this is the log obtained with CE_DEBUG=2:
root@dm814x-evm:/opt/c6accel_app/c6accel_dsplib_testapp# modprobe syslink
SysLink version : 2.00.05.85
SysLink module created on Date:Jan 24 2012 Time:15:35:13
root@dm814x-evm:/opt/c6accel_app/c6accel_dsplib_testapp# insmod cmemk.ko phys_st
art=0x96C00000 phys_end=0x98000000 pools=20x4096
CMEMK module: built on Jan 24 2012 at 15:34:50
Reference Linux version 2.6.37
File /home/fv4dmv0/staup/component-sources/linuxutils_3_21_00_04/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
allocated heap buffer 0xd2000000 of size 0x13ec000
cmemk initialized
root@dm814x-evm:/opt/c6accel_app/c6accel_dsplib_testapp# echo $CE_DEBUG
2
root@dm814x-evm:/opt/c6accel_app/c6accel_dsplib_testapp# ./c6accel_dsplib_testap
p
Sample application for testing kernels in C6Accel started.
[t=0x00000243] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_init> Enter
[t=0x000002c7] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] Global_init> This program was built with the following packages:
[t=0x00000319] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package gnu.targets (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/gnu/targets/) [1, 0, 1]
[t=0x00000381] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package gnu.targets.arm (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/gnu/targets/arm/) [1, 0, 0, 0]
[t=0x000003ed] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package gnu.targets.arm.rtsv7A (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/gnu/targets/arm/rtsv7A/) [1, 0, 0, 0]
[t=0x00000460] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.xdcruntime.linux (/home/fv4dmv0/staup/component-sources/osal_1_21_01_08/packages/ti/sdo/xdcruntime/linux/) [1, 0, 0]
[t=0x000004de] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.syslink (/home/fv4dmv0/staup/component-sources/syslink_2_00_05_85/packages/ti/syslink/) [1, 0, 0, 0]
[t=0x00000547] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.c6accel (/home/fv4dmv0/c6accel_2_01_00_10/soc/packages/ti/c6accel/) [1, 0, 0]
[t=0x000005a1] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.utils.loggers (/home/fv4dmv0/staup/component-sources/osal_1_21_01_08/packages/ti/sdo/utils/loggers/) [1, 0, 0]
[t=0x0000060e] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.global (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/global/) [1, 0, 0]
[t=0x0000067a] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.xdais.dm (/home/fv4dmv0/staup/component-sources/xdais_7_21_01_07/packages/ti/xdais/dm/) [1, 0, 7]
[t=0x000006f6] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.utils.xdm (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
[t=0x00000768] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.xdais (/home/fv4dmv0/staup/component-sources/xdais_7_21_01_07/packages/ti/xdais/) [1, 2.0, 1]
[t=0x000007cb] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.node (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/node/) [1, 0, 0]
[t=0x00000836] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.fc.global (/home/fv4dmv0/staup/component-sources/framework_components_3_21_03_34/packages/ti/sdo/fc/global/) [1, 0, 0]
[t=0x000008a7] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.linuxutils.cmem (/home/fv4dmv0/staup/component-sources/linuxutils_3_21_00_04/packages/ti/sdo/linuxutils/cmem/) [2, 2, 0]
[t=0x00000918] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.catalog.arm.cortexa8 (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/catalog/arm/cortexa8/) [1, 0, 0]
[t=0x0000098a] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.catalog.peripherals.hdvicp2 (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/catalog/peripherals/hdvicp2/) []
[t=0x000009ff] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.catalog (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/catalog/) [1, 0, 0]
[t=0x00000a63] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.catalog.c6000 (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/catalog/c6000/) [1, 0, 0, 0]
[t=0x00000ad0] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.catalog.arm.peripherals.timers (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/catalog/arm/peripherals/timers/) []
[t=0x00000b47] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.catalog.arm.cortexm3 (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/catalog/arm/cortexm3/) [1, 0, 0]
[t=0x00052a24] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.platforms.evmTI814X (/home/fv4dmv0/staup/component-sources/xdctools_3_22_04_46/packages/ti/platforms/evmTI814X/) [1, 0, 0]
[t=0x00052aa0] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.osal.linux (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/osal/linux/) [2, 0, 1]
[t=0x00052b11] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.ipc.dsplink (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/ipc/dsplink/) [2, 0, 1]
[t=0x00052b83] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.ipc (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/ipc/) [2, 0, 1]
[t=0x00052bed] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.osal (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/osal/) [2, 0, 2]
[t=0x00052c58] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.alg (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/alg/) [1, 0, 1]
[t=0x00052cc2] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/) [1, 0, 6]
[t=0x00052d27] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.sdo.ce.universal (/home/fv4dmv0/staup/component-sources/codec_engine_3_21_02_25/packages/ti/sdo/ce/universal/) [1, 0, 0]
[t=0x00052d97] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package ti.c6accel.ce (/home/fv4dmv0/c6accel_2_01_00_10/soc/packages/ti/c6accel/ce/) [1, 0, 0]
[t=0x00052df4] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+4] package c6accel_dsplib_testapp_config (/home/fv4dmv0/c6accel_2_01_00_10/soc/app/c6accel_dsplib_testapp/c6accel_dsplib_testapp_config/) []
[t=0x00052f1e] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x63e24)
[t=0x00052fbf] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x5f298)
[t=0x00053054] [tid=0x4007f000] ti.sdo.ce.ipc.Processor: [+2] Processor_init> SysLink_setup()...
[t=0x0005486b] [tid=0x4007f000] ti.sdo.ce.ipc.Processor: [+2] Processor_init> ... SysLink_setup() done
[t=0x000549b2] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x5a9ec)
[t=0x00054a41] [tid=0x4007f000] ti.sdo.ce.alg: [+E] ALG_init> Enter
[t=0x00054b8b] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[0] = 0x0
[t=0x00054bcb] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[1] = 0x0
[t=0x00054c00] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[2] = 0x0
[t=0x00054c32] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[3] = 0x0
[t=0x00054c64] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[4] = 0x0
[t=0x00054c97] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[5] = 0x0
[t=0x00054cc9] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[6] = 0x0
[t=0x00054cfb] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[7] = 0x0
[t=0x00054d2d] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[8] = 0x0
[t=0x00054d5f] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[9] = 0x0
[t=0x00054d91] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[10] = 0x0
[t=0x00054dc4] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[11] = 0x0
[t=0x00054df7] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[12] = 0x0
[t=0x00054e2a] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[13] = 0x0
[t=0x00054e5d] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[14] = 0x0
[t=0x00054e90] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[15] = 0x0
[t=0x00054ec3] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[16] = 0x0
[t=0x00054ef6] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[17] = 0x0
[t=0x00054f29] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[18] = 0x0
[t=0x00054f5b] [tid=0x4007f000] ti.sdo.ce.alg: [+E] _ALG_sems[19] = 0x0
[t=0x000a6e58] [tid=0x4007f000] ti.sdo.ce.alg: [+X] ALG_init> Exit
[t=0x000a6e94] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x57430)
[t=0x000a6f19] [tid=0x4007f000] ti.sdo.ce.Engine: [+6] Engine_init> CE debugging on (CE_DEBUG=2; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
[t=0x000a6f7c] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x4eba0)
[t=0x000a6fe5] [tid=0x4007f000] ti.sdo.ce.Engine: [+X] Engine addEngineToList(0x101990, 1)
[t=0x000a7029] [tid=0x4007f000] ti.sdo.ce.osal.Memory: [+E] Memory_alloc> Enter(0x34)
[t=0x000a7071] [tid=0x4007f000] ti.sdo.ce.osal.Memory: [+X] Memory_alloc> return (0x13a620)
[t=0x000a70b7] [tid=0x4007f000] ti.sdo.ce.Engine: Engine addEngineToList> Adding desc: name = ti8148, remoteName = ti814x.xe674
[t=0x000a710e] [tid=0x4007f000] ti.sdo.ce.Engine: [+X] Engine addEngineToList(0x1019ac, 1)
[t=0x000a714d] [tid=0x4007f000] ti.sdo.ce.osal.Memory: [+E] Memory_alloc> Enter(0x34)
[t=0x000a7189] [tid=0x4007f000] ti.sdo.ce.osal.Memory: [+X] Memory_alloc> return (0x13a658)
[t=0x000a71c6] [tid=0x4007f000] ti.sdo.ce.Engine: Engine addEngineToList> Adding desc: name = local, remoteName = (null)
[t=0x000a7217] [tid=0x4007f000] ti.sdo.ce.osal.Memory: [+E] Memory_alloc> Enter(0x30)
[t=0x000a7254] [tid=0x4007f000] ti.sdo.ce.osal.Memory: [+X] Memory_alloc> return (0x13a690)
[t=0x000a72b7] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x603f0)
[t=0x000a731b] [tid=0x4007f000] ti.sdo.ce.Server: [+E] Server_init()
[t=0x000a7355] [tid=0x4007f000] ti.sdo.ce.Server: [+E] Server_init> Global_useLinkArbiter = 0
[t=0x000a7394] [tid=0x4007f000] ti.sdo.ce.osal.Global: [+E] Global_atexit> Enter (fxn=0x5595c)
CERuntime complete
Opening the driver.
[t=0x000a744c] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] Engine_open> Enter('ti8148', 0x0, 0xbec3bbe4)
[t=0x000a74a5] [tid=0x4007f000] ti.sdo.ce.Engine: [+1] Engine_open> desc->memMap [0x0], desc->useExtLoader [0]
[t=0x000a74fb] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> Enter(engine=0x13a6f8, ec=0xbec3bbe4)
[t=0x000a7541] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> engine->desc = 0x13a628
[t=0x000a757d] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> engine->desc->algTab = 0x101a90
[t=0x000a75bd] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> found remote alg c6accel
[t=0x000a75fa] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> engine has server!
[t=0x000a7635] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> engine->procId = DSP
[t=0x000a7673] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rmsInit> engine->coreId = 0
[t=0x000a76af] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rserverOpen('ti814x.xe674'), count = 0
[t=0x000a76ef] [tid=0x4007f000] ti.sdo.ce.Engine: [+E] rserverOpen >, memMap = 0x0, useExtLoader = 0
[t=0x000a7734] [tid=0x4007f000] ti.sdo.ce.ipc.Processor: [+E] Processor_create> Enter(imageName='ti814x.xe674', memMap='(null)', attrs=0xbec3bbc4)
[t=0x000a7976] [tid=0x4007f000] ti.sdo.ce.ipc.Processor: [+E] doCmd> Enter (cmdId=1, proc=0x13a740)
[t=0x000a79ee] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+X] getCmd_d> Exit (result=1)
[t=0x000a7a30] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+E] Processor_create_d> Enter(proc=0x13a740)
[t=0x000a7a74] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> Retrieving CPU ID for 'DSP'...
[t=0x000a7af5] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> Opening DSP ProcMgr for cpuId 0...
[t=0x000a7e2d] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> Attaching to DSP...
[t=0x000a979e] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> Loading ti814x.xe674 on DSP (1 args)...
[t=0x000e1e76] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> calling Ipc_control(LOADCALLBACK)...
[t=0x000e8e0b] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> Ipc_control(LOADCALLBACK) status: 0
[t=0x000e8e7e] [tid=0x40101490] ti.sdo.ce.ipc.Processor: [+2] Processor_create_d> Starting DSP ...
Seems that DSP is never power-up by ARM, Do you have any idea of what i am doing wrong?
WBR
dani.
  • Also i got syslink log, just in case please find it attached.
    ********************************NameServer Module already initialized!
    ********************************SharedRegion Module already initialized!
    GateMP Module already initialized!
    Sample application for testing kMessageQ Module already initialized!
    ernels in C6AcceHeapBufMP Module already initialized!
    l started.
    ****HeapMemMP Module already initialized!
    ****************ListMP Module already initialized!
    ****************ClientNotifyMgr Module already initialized!
    ****************FrameQBufMgr Module already initialized!
    ****************FrameQ Module already initialized!
     CERuntime compl    ProcMgr_getProcInfo: bootMode: [0]
    ete
     Opening thMemoryOS_map: pa=0x48180000, va=0xfa180000, sz=0x3000
    e driver.
    MemoryOS_map: pa=0x48140000, va=0xfa140000, sz=0x20000
    MemoryOS_map: pa=0x40800000, va=0xd0c80000, sz=0x40000
    DM8168DSPPROC_attach: Mapping memory regions
    MemoryOS_map: pa=0x48140048, va=0xfa140048, sz=0x4
    MemoryOS_map: pa=0x48140044, va=0xfa140044, sz=0x4
    MemoryOS_map: pa=0x48140650, va=0xfa140650, sz=0x4
    MemoryOS_map: entry already exists
        mapInfo->src  [0x48180000]
        mapInfo->dst  [0xfa180000]
        mapInfo->size [0x2fff]
    DM8168DSPPROC_attach: slave is now in reset
        mapInfo->src  [0x40800000]
        mapInfo->dst  [0xd0c80000]
        mapInfo->size [0x40000]
    MemoryOS_map: pa=0x40e00000, va=0xd0c50000, sz=0x8000
    MemoryOS_map: pa=0x40f00000, va=0xd0c60000, sz=0x8000
    MemoryOS_map: pa=0x40300000, va=0xd0d00000, sz=0x40000
    _ProcMgr_map for SlaveVirt:
        dstAddr       [0x40300000]
        sgList.paddr  [0x40300000]
        sgList.offset [0x0]
        sgList.size [0x40000]
    MemoryOS_map: pa=0x40400000, va=0xd0d80000, sz=0x40000
        dstAddr       [0x40400000]
        sgList.paddr  [0x40400000]
        sgList.offset [0x0]
    OsalDrv_mmap(): setting cache disabled for physical address 40800000
    OsalDrv_mmap(): setting cache disabled for physical address 40e00000
    OsalDrv_mmap(): setting cache disabled for physical address 40f00000
    OsalDrv_mmap(): setting cache disabled for physical address 40300000
    OsalDrv_mmap(): setting cache disabled for physical address 40400000
    DLOAD: ELF: ELF
    DLOAD: ELF file header entry point: 9829a800
    ElfLoaderTrgWrite_copy: translated 0x10800000 (sva) --> 0x40800000 (mpa)
        mapInfo->size [0xc000]
        dstAddr       [0x10800000]
        sgList.paddr  [0x40800000]
        sgList.offset [0x0]
        sgList.size [0xc000]
    ElfLoaderTrgWrite_copy: translated 0x98000000 (sva) --> 0x98000000 (mpa)
    MemoryOS_map: pa=0x98000000, va=0xd1000000, sz=0x2175a0
        dstAddr       [0x98000000]
        sgList.paddr  [0x98000000]
        sgList.offset [0x0]
        sgList.size [0x2175a0]
    ElfLoaderTrgWrite_copy: translated 0x982175a0 (sva) --> 0x982175a0 (mpa)
    MemoryOS_map: pa=0x982175a0, va=0xd0e805a0, sz=0x3fc20
        dstAddr       [0x98217000]
        sgList.paddr  [0x98217000]
        sgList.offset [0x5a0]
        sgList.size [0x401c0]
    ElfLoaderTrgWrite_copy: translated 0x982571bc (sva) --> 0x982571bc (mpa)
    MemoryOS_map: pa=0x982571bc, va=0xd0d5a1bc, sz=0x4
        dstAddr       [0x98257000]
        sgList.paddr  [0x98257000]
        sgList.offset [0x1bc]
        sgList.size [0x1c0]
    ElfLoaderTrgWrite_copy: translated 0x982571c0 (sva) --> 0x982571c0 (mpa)
    MemoryOS_map: pa=0x982571c0, va=0xd0e401c0, sz=0x37780
        sgList.offset [0x1c0]
        sgList.size [0x37940]
    ElfLoaderTrgWrite_copy: translated 0x9828e940 (sva) --> 0x9828e940 (mpa)
    MemoryOS_map: pa=0x9828e940, va=0xd0d70940, sz=0x9f92
        dstAddr       [0x9828e000]
        sgList.paddr  [0x9828e000]
        sgList.offset [0x940]
        sgList.size [0xa8d2]
    ElfLoaderTrgWrite_copy: translated 0x982988d8 (sva) --> 0x982988d8 (mpa)
    MemoryOS_map: pa=0x982988d8, va=0xd0d688d8, sz=0x1000
        dstAddr       [0x98298000]
        sgList.paddr  [0x98298000]
        sgList.offset [0x8d8]
        sgList.size [0x18d8]
    ElfLoaderTrgWrite_copy: translated 0x982998d8 (sva) --> 0x982998d8 (mpa)
    MemoryOS_map: pa=0x982998d8, va=0xd0d6c8d8, sz=0xbbc
        dstAddr       [0x98299000]
        sgList.paddr  [0x98299000]
        sgList.size [0x1494]
    ElfLoaderTrgWrite_copy: translated 0x9829a4a0 (sva) --> 0x9829a4a0 (mpa)
    MemoryOS_map: pa=0x9829a4a0, va=0xd0dc24a0, sz=0x354
        dstAddr       [0x9829a000]
        sgList.paddr  [0x9829a000]
        sgList.offset [0x4a0]
        sgList.size [0x7f4]
    ElfLoaderTrgWrite_copy: translated 0x9829a800 (sva) --> 0x9829a800 (mpa)
    MemoryOS_map: pa=0x9829a800, va=0xd0dc8800, sz=0x200
        sgList.offset [0x800]
        sgList.size [0xa00]
    ElfLoaderTrgWrite_copy: translated 0x9829aa00 (sva) --> 0x9829aa00 (mpa)
    MemoryOS_map: pa=0x9829aa00, va=0xd0dcea00, sz=0xc
        sgList.offset [0xa00]
        sgList.size [0xa0c]
    ElfLoaderTrgWrite_copy: translated 0x9829aa0c (sva) --> 0x9829aa0c (mpa)
    MemoryOS_map: pa=0x9829aa0c, va=0xd0dd4a0c, sz=0x2b0
        sgList.offset [0xa0c]
        sgList.size [0xcbc]
    ElfLoaderTrgWrite_copy: translated 0x9829acc0 (sva) --> 0x9829acc0 (mpa)
    MemoryOS_map: pa=0x9829acc0, va=0xd0ddacc0, sz=0x140
        sgList.offset [0xcc0]
        sgList.size [0xe00]
    ElfLoaderTrgWrite_copy: translated 0x9829b000 (sva) --> 0x9829b000 (mpa)
    MemoryOS_map: pa=0x9829b000, va=0xd0de0000, sz=0x4c
        dstAddr       [0x9829b000]
        sgList.paddr  [0x9829b000]
        sgList.offset [0x0]
        sgList.size [0x4c]
    ElfLoaderTrgWrite_copy: translated 0x99400000 (sva) --> 0x99400000 (mpa)
    MemoryOS_map: pa=0x99400000, va=0xd1400000, sz=0x100000
        dstAddr       [0x99400000]
        sgList.paddr  [0x99400000]
        sgList.offset [0x0]
        sgList.size [0x100000]
    ElfLoaderTrgWrite_copy: translated 0x9a200000 (sva) --> 0x9a200000 (mpa)
    MemoryOS_map: pa=0x9a200000, va=0xd4000000, sz=0x1000000
        dstAddr       [0x9a200000]
        sgList.paddr  [0x9a200000]
        sgList.offset [0x0]
        sgList.size [0x1000000]
    ElfLoader_getSymbolAddress: symName [_Ipc_ResetVector]
        ProcMgr_translateAddr: srcAddr [0x9829b000] dstAddr [0x9829b000]
        ProcMgr_translateAddr: srcAddr [0x9829b000] dstAddr [0xd0de0000]
        ProcMgr_translateAddr: srcAddr [0x9829b01c] dstAddr [0x9829b01c]
        ProcMgr_translateAddr: srcAddr [0x9829b01c] dstAddr [0xd0de001c]
    handle->slaveSRCfg[0].entryBase 9a100000
    Platform_loadCallback:
        No SharedRegion.entry[0].cacheEnable configuration value found, using default FALSE
        Mapping SharedRegion 0
        addr[ProcMgr_AddrType_MasterPhys] [0x9a100000]
        addr[ProcMgr_AddrType_SlaveVirt]  [0x9a100000]
        size                              [0x100000]
        isCached                          [0]
    MemoryOS_map: pa=0x9a100000, va=0xd1600000, sz=0x100000
        dstAddr       [0x9a100000]
        sgList.paddr  [0x9a100000]
        sgList.offset [0x0]
    handle->slaveSRCfg[1].entryBase 99500000
        No SharedRegion.entry[1].cacheEnable configuration value found, using default FALSE
        Mapping SharedRegion 1
        addr[ProcMgr_AddrType_MasterPhys] [0x99500000]
        addr[ProcMgr_AddrType_SlaveVirt]  [0x99500000]
        size                              [0xc00000]
        isCached                          [0]
    MemoryOS_map: pa=0x99500000, va=0xd6000000, sz=0xc00000
        dstAddr       [0x99500000]
        sgList.paddr  [0x99500000]
        sgList.offset [0x0]
        sgList.size [0xc00000]
        DM8168DSPPROC_start: Slave successfully started!
    Ipc_attach: Ipc_procSyncStart failed!
  • Just in case somebody is facing similar problem, finally i solved changing dmtimer  config (nothing else to be done with memory map ), i follow this link: http://processors.wiki.ti.com/index.php/SYS/BIOS_dmtimer_configuration_for_TI81xx
    still pending to have: vpss running simultaneously with DSP, memory map rewrite tough.
    WBR
  • Hi Daniel,
      I'm facing to similar peoblem, too. But my hardware platform is IPNC.
      I post my question here:
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/716/t/206025.aspx
      Can you please give me some advice?
      Thanks.
    Wei Jiang
