AM623: am623: Boot failure DDR4 CKE not going high
Part Number: AM623
Other Parts Discussed in Thread: SYSCONFIG, SK-AM62B-P1
we have some custom board with am623 and 8Go DDR4. u-boot used is from SDK 11.0.15
when booting from the same SD card some of this board are booting and working fine but others are stuck in an early stage in the SPL :
U-Boot SPL 2025.01 (Jan 13 2026 - 17:47:24 +0100)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
Changed A53 CPU frequency to 1000000000Hz (S grade) in DT
SPL initial stack usage: 13424 bytes <<<<<<<<<<<< stuck here
whene looking at DDR controller with scope on RESET and CKE signal we saw that CKE was not going high but when zooming it seems that controller is trying to start after ~600us (glitch at 42 mV)
when we look at a normal board that is able to boot we saw that indeet the CKE is released 600us after reset is is releasedcke_normal.png
we measure also DDR power during the reset of the board that can't boot :
vddr_core : 855 mV
VPP: 2.51 V
vddrefca : 603mV
vdds_ddr : 1.205V
and no glitch or instability is visible during this period,
clock used is 800Mhz and is present at reset
can you help us on this topic,
thank you
best regards
  • Thread is been assigned but you may see some delays as the assigned expert is out of office this week
  • Greetings,
    Mukul is correct, the expert is out of office at the moment. In the meantime, a few basic questions:
    • Can you share the datasheet for the DRAM on your custom board?
    • Can you also share the DDR register config (.sysconfig or .dts file) you built your image with for your board?
    • Does your board have JTAG access for something like CCS/Lauterbach?
    Sincerely,
    Lucas
  • Hi Lucas,
    we are using kingston DRAM (D5116AN9CXGXNI-U), please find the datasheet attached. You will also find our .dtsi file that is mainly an export of the sysconfig file with the reference design NT5AD512M16C4 on SK-AM62B-P1. In fact the manufacturer was not able to give us specific timing for the 1600 profile (the lowest rate was 1866).
    We don't have jtag accessible on our custom board
    Sincerly,
    Thomas
    k3-am62x-tdt7-ddr4-1600MTs.zip
    DDR4_8Gb_C_x8x16_D5116AN9CXGRK-U (VerO).pdf
  • Hi Thomas,
    does a failing board always show the poor CKE signal?  Or is the boot up intermittent (sometimes works and sometimes doesn't).
    If you have a set of boards that always show a poor CKE signal, i would suspect some kind of assembly issue.  Maybe try replacing the processor on a bad board.
    also, do you have any other circuitry on CKE (pullup or otherwise)?  Try removing this if it is present.
    There is certainly something wrong with CKE.  You may still need to do some configuration changes in .dtsi, but you should be getting well past the point of CKE going high before you consider config changes.
    James
  • Hi James,
    we had a 10k pull down on CKE, unfortunatly it s not resolving the CKE issue. Our board assembler did RX analysis on all 9 failing boards and no anomaly were found. Nevertheless we will try to change CPU on 4 of this boards to see if this can solve this issue.
    concerning the timings what are your recommendations for this particular DDR ?
    thank you for your help,
    Thomas
  • Ideally, you should work thru each of the parameters in the DDR register config tool and compare with the Kingston datasheet.  I think starting with the Nanya timings should be good, you may only have to tweak one or two parameters.  Ensure the termination and drive strength settings align with your board design.  I will try to review later today.
    James
  • Hi James,
    we just changed the CPU on 4 boards with the CKE problem, and now 3 of 4 are booting.
    Still we have 1 board where the CKE is not starting. It s definitely a problem around the CPU.
    Our Pcb assembler did extra rx and confirm that everything was ok on failling board so they tell us its not a assembly issue. So it's look like an electronic issue.
    On the R5 spl we add the #define DEBUG and we get extra message during the boot
    U-Boot SPL 2025.01-g7088c9e465b9-dirty (Feb 06 2026 - 11:27:22 +0100)
    k3_ddrss_probe(dev=43c349e8)
    k3_ddrss_ofdata_to_priv(dev=43c349e8)
    k3_ddrss memorycontroller@f300000: ddr freq0 not populated, using bypass frequency.
    k3_ddrss_power_on(ddrss=43c3a2c0)
    k3_ddrss memorycontroller@f300000: vtt-supply not found.
    k3_lpddr4_probe: PASS
    k3_lpddr4_init: PASS
    --->>> LPDDR4 Initialization is in progress ... <<<---
    k3_lpddr4_start: Post start PASS
    SPL initial stack usage: 13424 bytes <<<<<<<<<<< Stuck here
    the message is exactly the same on a working board. The strange thing here is that we configure DDR4 on the sysconfig file and we get a message of LPDDR4 Initialization.
    Is this a normal behaviour ?
    Thank for your help
    yes, i think that is normal, just a debug statement from a driver that supports both DDR4 and LPDDR4.  DOes the CKE signal look correct on the failing board (this is where the original boards failed as well)?  If the RESET and CKE signal look good, you might still have a configuration issue.
    Also, check the working boards with linux memtester to ensure the configuration is robust.
    James
  • Hi James,
    you were right, we check the remaining failing board and the CKE was ok. We assumed that all boards had the same issue but we were wrong... So it seems that we have 2 differents problems :
    - one is the CKE not going high -> we change the Proc  it solve the problem on the 3 boards, why ? We don't know yet (not a process issue according to our manufacturer)
    - one is another problem -> maybe configuration problem ?
    In both case the product get stuck while trying to init DDR,
    We did memtester on a working board:
    memtester 600M 1
    memtester version 4.5.1 (64-bit)
    Copyright (C) 2001-2020 Charles Cazabon.
    Licensed under the GNU General Public License version 2 (only).
    pagesize is 4096
    pagesizemask is 0xfffffffffffff000
    want 600MB (629145600 bytes)
    got  600MB (629145600 bytes), trying mlock ...locked.
    Loop 1/1:
      Stuck Address       : ok
      Random Value        : ok
      Compare XOR         : ok
      Compare SUB         : ok
      Compare MUL         : ok
      Compare DIV         : ok
      Compare OR          : ok
      Compare AND         : ok
      Sequential Increment: ok
      Solid Bits          : ok
      Block Sequential    : ok
      Checkerboard        : ok
      Bit Spread          : ok
      Bit Flip            : ok
      Walking Ones        : ok
      Walking Zeroes      : ok
      8-bit Writes        : ok
      16-bit Writes       : ok
    Done.
    so everything look fine. We did some test at 60°C same result.
    what's do you think?
    thanks for your help,
    Thomas
  • Hi Thomas, the memtester run looks fine.  I would run it for longer, maybe even overnight, to ensure robustness.
    As for the failing board, can you provide a register dump by implementing the patch shown on this page: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1358039/faq-board-bring-up-tips-for-sitara-devices-am64x-am243x-am62x-am62l-am62ax-am62d-q1-am62px#:~:text=Getting%20DDR%20register%20dump%20after%20initialization
    This will output all DDR registers after init.  Post the output here so i can check where the init is failing.
    James
  • Hi James,
    please find attached the dump for different boards, one for a board not showing CKE signal, another is with CKE signal but still stuck at "SPL initial stack usage: 13424 bytes" message and the last one is a board that boot Linux correctly
    U-Boot SPL 2025.01-g89419a54e5de-dirty (Mar 04 2026 - 09:49:38 +0100)
    k3_ddrss memorycontroller@f300000: ddr freq0 not populated, using bypass frequen        cy.
    Begin DDR Register Dump
    0x0f308000 0x10460a01  //DDRSS_CTL_0_DATA
    0x0f308004 0x5d1af3c3  //DDRSS_CTL_1_DATA
    0x0f308008 0x0171a610  //DDRSS_CTL_2_DATA
    0x0f30800c 0x40020a11  //DDRSS_CTL_3_DATA
    0x0f308010 0x00052006  //DDRSS_CTL_4_DATA
    0x0f308014 0x02050020  //DDRSS_CTL_5_DATA
    0x0f308018 0x03070101  //DDRSS_CTL_6_DATA
    0x0f30801c 0x000890b8  //DDRSS_CTL_7_DATA
    0x0f308020 0x00000000  //DDRSS_CTL_8_DATA
    0x0f308024 0x00000000  //DDRSS_CTL_9_DATA
    0x0f308028 0x00000000  //DDRSS_CTL_10_DATA
    0x0f30802c 0x000890b8  //DDRSS_CTL_11_DATA
    0x0f308030 0x00000000  //DDRSS_CTL_12_DATA
    0x0f308034 0x00000000  //DDRSS_CTL_13_DATA
    0x0f308038 0x00000000  //DDRSS_CTL_14_DATA
    0x0f30803c 0x000890b8  //DDRSS_CTL_15_DATA
    0x0f308040 0x00000000  //DDRSS_CTL_16_DATA
    0x0f308044 0x00000000  //DDRSS_CTL_17_DATA
    0x0f308048 0x00000000  //DDRSS_CTL_18_DATA
    0x0f30804c 0x01010100  //DDRSS_CTL_19_DATA
    0x0f308050 0x01000101  //DDRSS_CTL_20_DATA
    0x0f308054 0x01000110  //DDRSS_CTL_21_DATA
    0x0f308058 0x02010002  //DDRSS_CTL_22_DATA
    0x0f30805c 0x00027100  //DDRSS_CTL_23_DATA
    0x0f308060 0x00061a80  //DDRSS_CTL_24_DATA
    0x0f308064 0x02550255  //DDRSS_CTL_25_DATA
    0x0f308068 0x00000255  //DDRSS_CTL_26_DATA
    0x0f30806c 0x00000000  //DDRSS_CTL_27_DATA
    0x0f308070 0x00000000  //DDRSS_CTL_28_DATA
    0x0f308074 0x00000000  //DDRSS_CTL_29_DATA
    0x0f308078 0x00000000  //DDRSS_CTL_30_DATA
    0x0f30807c 0x00000000  //DDRSS_CTL_31_DATA
    0x0f308080 0x00000000  //DDRSS_CTL_32_DATA
    0x0f308084 0x00000000  //DDRSS_CTL_33_DATA
    0x0f308088 0x00000000  //DDRSS_CTL_34_DATA
    0x0f30808c 0x00000000  //DDRSS_CTL_35_DATA
    0x0f308090 0x00000000  //DDRSS_CTL_36_DATA
    0x0f308094 0x00000000  //DDRSS_CTL_37_DATA
    0x0f308098 0x04000918  //DDRSS_CTL_38_DATA
    0x0f30809c 0x1c1c1c1c  //DDRSS_CTL_39_DATA
    0x0f3080a0 0x04000918  //DDRSS_CTL_40_DATA
    0x0f3080a4 0x1c1c1c1c  //DDRSS_CTL_41_DATA
    0x0f3080a8 0x04000918  //DDRSS_CTL_42_DATA
    0x0f3080ac 0x1c1c1c1c  //DDRSS_CTL_43_DATA
    0x0f3080b0 0x05050404  //DDRSS_CTL_44_DATA
    0x0f3080b4 0x00002806  //DDRSS_CTL_45_DATA
    0x0f3080b8 0x0602001d  //DDRSS_CTL_46_DATA
    0x0f3080bc 0x05001d0c  //DDRSS_CTL_47_DATA
    0x0f3080c0 0x00280605  //DDRSS_CTL_48_DATA
    0x0f3080c4 0x0602001d  //DDRSS_CTL_49_DATA
    0x0f3080c8 0x05001d0c  //DDRSS_CTL_50_DATA
    0x0f3080cc 0x00280605  //DDRSS_CTL_51_DATA
    0x0f3080d0 0x0602001d  //DDRSS_CTL_52_DATA
    0x0f3080d4 0x07001d0c  //DDRSS_CTL_53_DATA
    0x0f3080d8 0x00180807  //DDRSS_CTL_54_DATA
    0x0f3080dc 0x0400db60  //DDRSS_CTL_55_DATA
    0x0f3080e0 0x07070009  //DDRSS_CTL_56_DATA
    0x0f3080e4 0x00001808  //DDRSS_CTL_57_DATA
    0x0f3080e8 0x0400db60  //DDRSS_CTL_58_DATA
    0x0f3080ec 0x07070009  //DDRSS_CTL_59_DATA
    0x0f3080f0 0x00001808  //DDRSS_CTL_60_DATA
    0x0f3080f4 0x0400db60  //DDRSS_CTL_61_DATA
    0x0f3080f8 0x03000009  //DDRSS_CTL_62_DATA
    0x0f3080fc 0x0d0d0002  //DDRSS_CTL_63_DATA
    0x0f308100 0x0d0d0d0d  //DDRSS_CTL_64_DATA
    0x0f308104 0x01010000  //DDRSS_CTL_65_DATA
    0x0f308108 0x031a1a1a  //DDRSS_CTL_66_DATA
    0x0f30810c 0x0c0c0c0c  //DDRSS_CTL_67_DATA
    0x0f308110 0x00000c0c  //DDRSS_CTL_68_DATA
    0x0f308114 0x00000101  //DDRSS_CTL_69_DATA
    0x0f308118 0x00000000  //DDRSS_CTL_70_DATA
    0x0f30811c 0x01000000  //DDRSS_CTL_71_DATA
    0x0f308120 0x01180803  //DDRSS_CTL_72_DATA
    0x0f308124 0x00001860  //DDRSS_CTL_73_DATA
    0x0f308128 0x00000118  //DDRSS_CTL_74_DATA
    0x0f30812c 0x00001860  //DDRSS_CTL_75_DATA
    0x0f308130 0x00000118  //DDRSS_CTL_76_DATA
    0x0f308134 0x00001860  //DDRSS_CTL_77_DATA
    0x0f308138 0x00000005  //DDRSS_CTL_78_DATA
    0x0f30813c 0x00000000  //DDRSS_CTL_79_DATA
    0x0f308140 0x00000000  //DDRSS_CTL_80_DATA
    0x0f308144 0x00000000  //DDRSS_CTL_81_DATA
    0x0f308148 0x00000000  //DDRSS_CTL_82_DATA
    0x0f30814c 0x00000000  //DDRSS_CTL_83_DATA
    0x0f308150 0x00000000  //DDRSS_CTL_84_DATA
    0x0f308154 0x00000000  //DDRSS_CTL_85_DATA
    0x0f308158 0x00000000  //DDRSS_CTL_86_DATA
    0x0f30815c 0x00090009  //DDRSS_CTL_87_DATA
    0x0f308160 0x00000009  //DDRSS_CTL_88_DATA
    0x0f308164 0x00000000  //DDRSS_CTL_89_DATA
    0x0f308168 0x00000000  //DDRSS_CTL_90_DATA
    0x0f30816c 0x00000000  //DDRSS_CTL_91_DATA
    0x0f308170 0x00000000  //DDRSS_CTL_92_DATA
    0x0f308174 0x00000000  //DDRSS_CTL_93_DATA
    0x0f308178 0x00010001  //DDRSS_CTL_94_DATA
    0x0f30817c 0x00025501  //DDRSS_CTL_95_DATA
    0x0f308180 0x02550120  //DDRSS_CTL_96_DATA
    0x0f308184 0x02550120  //DDRSS_CTL_97_DATA
    0x0f308188 0x01200120  //DDRSS_CTL_98_DATA
    0x0f30818c 0x01200120  //DDRSS_CTL_99_DATA
    0x0f308190 0x00000000  //DDRSS_CTL_100_DATA
    0x0f308194 0x00000000  //DDRSS_CTL_101_DATA
    0x0f308198 0x00000000  //DDRSS_CTL_102_DATA
    0x0f30819c 0x00000000  //DDRSS_CTL_103_DATA
    0x0f3081a0 0x00000000  //DDRSS_CTL_104_DATA
    0x0f3081a4 0x00000000  //DDRSS_CTL_105_DATA
    0x0f3081a8 0x03010000  //DDRSS_CTL_106_DATA
    0x0f3081ac 0x00010000  //DDRSS_CTL_107_DATA
    0x0f3081b0 0x00000000  //DDRSS_CTL_108_DATA
    0x0f3081b4 0x01000000  //DDRSS_CTL_109_DATA
    0x0f3081b8 0x80104002  //DDRSS_CTL_110_DATA
    0x0f3081bc 0x00040003  //DDRSS_CTL_111_DATA
    0x0f3081c0 0x00040005  //DDRSS_CTL_112_DATA
    0x0f3081c4 0x00030000  //DDRSS_CTL_113_DATA
    0x0f3081c8 0x00050004  //DDRSS_CTL_114_DATA
    0x0f3081cc 0x00000004  //DDRSS_CTL_115_DATA
    0x0f3081d0 0x00040003  //DDRSS_CTL_116_DATA
    0x0f3081d4 0x00040005  //DDRSS_CTL_117_DATA
    0x0f3081d8 0x00000000  //DDRSS_CTL_118_DATA
    0x0f3081dc 0x00061800  //DDRSS_CTL_119_DATA
    0x0f3081e0 0x00061800  //DDRSS_CTL_120_DATA
    0x0f3081e4 0x00061800  //DDRSS_CTL_121_DATA
    0x0f3081e8 0x00061800  //DDRSS_CTL_122_DATA
    0x0f3081ec 0x00061800  //DDRSS_CTL_123_DATA
    0x0f3081f0 0x00000000  //DDRSS_CTL_124_DATA
    0x0f3081f4 0x0000aaa0  //DDRSS_CTL_125_DATA
    0x0f3081f8 0x00061800  //DDRSS_CTL_126_DATA
    0x0f3081fc 0x00061800  //DDRSS_CTL_127_DATA
    0x0f308200 0x00061800  //DDRSS_CTL_128_DATA
    0x0f308204 0x00061800  //DDRSS_CTL_129_DATA
    0x0f308208 0x00061800  //DDRSS_CTL_130_DATA
    0x0f30820c 0x00000000  //DDRSS_CTL_131_DATA
    0x0f308210 0x0000aaa0  //DDRSS_CTL_132_DATA
    0x0f308214 0x00061800  //DDRSS_CTL_133_DATA
    0x0f308218 0x00061800  //DDRSS_CTL_134_DATA
    0x0f30821c 0x00061800  //DDRSS_CTL_135_DATA
    0x0f308220 0x00061800  //DDRSS_CTL_136_DATA
    0x0f308224 0x00061800  //DDRSS_CTL_137_DATA
    0x0f308228 0x00000000  //DDRSS_CTL_138_DATA
    0x0f30822c 0x0000aaa0  //DDRSS_CTL_139_DATA
    0x0f308230 0x00000000  //DDRSS_CTL_140_DATA
    0x0f308234 0x00000000  //DDRSS_CTL_141_DATA
    0x0f308238 0x00000000  //DDRSS_CTL_142_DATA
    0x0f30823c 0x00000000  //DDRSS_CTL_143_DATA
    0x0f308240 0x00000000  //DDRSS_CTL_144_DATA
    0x0f308244 0x00000000  //DDRSS_CTL_145_DATA
    0x0f308248 0x00000000  //DDRSS_CTL_146_DATA
    0x0f30824c 0x00000000  //DDRSS_CTL_147_DATA
    0x0f308250 0x00000000  //DDRSS_CTL_148_DATA
    0x0f308254 0x00000000  //DDRSS_CTL_149_DATA
    0x0f308258 0x00000000  //DDRSS_CTL_150_DATA
    0x0f30825c 0x00000000  //DDRSS_CTL_151_DATA
    0x0f308260 0x00000000  //DDRSS_CTL_152_DATA
    0x0f308264 0x00000000  //DDRSS_CTL_153_DATA
    0x0f308268 0x00000000  //DDRSS_CTL_154_DATA
    0x0f30826c 0x00000000  //DDRSS_CTL_155_DATA
    0x0f308270 0x080c0000  //DDRSS_CTL_156_DATA
    0x0f308274 0x080c080c  //DDRSS_CTL_157_DATA
    0x0f308278 0x08000000  //DDRSS_CTL_158_DATA
    0x0f30827c 0x00000808  //DDRSS_CTL_159_DATA
    0x0f308280 0x000e0000  //DDRSS_CTL_160_DATA
    0x0f308284 0x00080808  //DDRSS_CTL_161_DATA
    0x0f308288 0x0e000000  //DDRSS_CTL_162_DATA
    0x0f30828c 0x08080800  //DDRSS_CTL_163_DATA
    0x0f308290 0x00000000  //DDRSS_CTL_164_DATA
    0x0f308294 0x0000080e  //DDRSS_CTL_165_DATA
    0x0f308298 0x00040003  //DDRSS_CTL_166_DATA
    0x0f30829c 0x00004007  //DDRSS_CTL_167_DATA
    0x0f3082a0 0x00000000  //DDRSS_CTL_168_DATA
    0x0f3082a4 0x00000000  //DDRSS_CTL_169_DATA
    0x0f3082a8 0x00000000  //DDRSS_CTL_170_DATA
    0x0f3082ac 0x00000000  //DDRSS_CTL_171_DATA
    0x0f3082b0 0x00000000  //DDRSS_CTL_172_DATA
    0x0f3082b4 0x00000000  //DDRSS_CTL_173_DATA
    0x0f3082b8 0x01000000  //DDRSS_CTL_174_DATA
    0x0f3082bc 0x00000000  //DDRSS_CTL_175_DATA
    0x0f3082c0 0x00001500  //DDRSS_CTL_176_DATA
    0x0f3082c4 0x0000100e  //DDRSS_CTL_177_DATA
    0x0f3082c8 0x00000000  //DDRSS_CTL_178_DATA
    0x0f3082cc 0x00000000  //DDRSS_CTL_179_DATA
    0x0f3082d0 0x00000001  //DDRSS_CTL_180_DATA
    0x0f3082d4 0x00000002  //DDRSS_CTL_181_DATA
    0x0f3082d8 0x00000c00  //DDRSS_CTL_182_DATA
    0x0f3082dc 0x00001000  //DDRSS_CTL_183_DATA
    0x0f3082e0 0x00000c00  //DDRSS_CTL_184_DATA
    0x0f3082e4 0x00001000  //DDRSS_CTL_185_DATA
    0x0f3082e8 0x00000c00  //DDRSS_CTL_186_DATA
    0x0f3082ec 0x00001000  //DDRSS_CTL_187_DATA
    0x0f3082f0 0x00000000  //DDRSS_CTL_188_DATA
    0x0f3082f4 0x00000000  //DDRSS_CTL_189_DATA
    0x0f3082f8 0x00000000  //DDRSS_CTL_190_DATA
    0x0f3082fc 0x00000000  //DDRSS_CTL_191_DATA
    0x0f308300 0x00000000  //DDRSS_CTL_192_DATA
    0x0f308304 0x00000000  //DDRSS_CTL_193_DATA
    0x0f308308 0x00000000  //DDRSS_CTL_194_DATA
    0x0f30830c 0x00000000  //DDRSS_CTL_195_DATA
    0x0f308310 0x00000000  //DDRSS_CTL_196_DATA
    0x0f308314 0x00000000  //DDRSS_CTL_197_DATA
    0x0f308318 0x00000000  //DDRSS_CTL_198_DATA
    0x0f30831c 0x00000000  //DDRSS_CTL_199_DATA
    0x0f308320 0x00000000  //DDRSS_CTL_200_DATA
    0x0f308324 0x00000000  //DDRSS_CTL_201_DATA
    0x0f308328 0x00000000  //DDRSS_CTL_202_DATA
    0x0f30832c 0x00000000  //DDRSS_CTL_203_DATA
    0x0f308330 0x00041400  //DDRSS_CTL_204_DATA
    0x0f308334 0x00000301  //DDRSS_CTL_205_DATA
    0x0f308338 0x00000080  //DDRSS_CTL_206_DATA
    0x0f30833c 0x00000414  //DDRSS_CTL_207_DATA
    0x0f308340 0x00000301  //DDRSS_CTL_208_DATA
    0x0f308344 0x00000080  //DDRSS_CTL_209_DATA
    0x0f308348 0x00000414  //DDRSS_CTL_210_DATA
    0x0f30834c 0x00000301  //DDRSS_CTL_211_DATA
    0x0f308350 0x00000080  //DDRSS_CTL_212_DATA
    0x0f308354 0x00000414  //DDRSS_CTL_213_DATA
    0x0f308358 0x00000301  //DDRSS_CTL_214_DATA
    0x0f30835c 0x00000080  //DDRSS_CTL_215_DATA
    0x0f308360 0x00000414  //DDRSS_CTL_216_DATA
    0x0f308364 0x00000301  //DDRSS_CTL_217_DATA
    0x0f308368 0x00000080  //DDRSS_CTL_218_DATA
    0x0f30836c 0x00000414  //DDRSS_CTL_219_DATA
    0x0f308370 0x00000301  //DDRSS_CTL_220_DATA
    0x0f308374 0x00000080  //DDRSS_CTL_221_DATA
    0x0f308378 0x00000000  //DDRSS_CTL_222_DATA
    0x0f30837c 0x00000000  //DDRSS_CTL_223_DATA
    0x0f308380 0x00000000  //DDRSS_CTL_224_DATA
    0x0f308384 0x00000000  //DDRSS_CTL_225_DATA
    0x0f308388 0x00000000  //DDRSS_CTL_226_DATA
    0x0f30838c 0x00000000  //DDRSS_CTL_227_DATA
    0x0f308390 0x00000000  //DDRSS_CTL_228_DATA
    0x0f308394 0x00000000  //DDRSS_CTL_229_DATA
    0x0f308398 0x00000004  //DDRSS_CTL_230_DATA
    0x0f30839c 0x00000004  //DDRSS_CTL_231_DATA
    0x0f3083a0 0x00000004  //DDRSS_CTL_232_DATA
    0x0f3083a4 0x00000004  //DDRSS_CTL_233_DATA
    0x0f3083a8 0x00000004  //DDRSS_CTL_234_DATA
    0x0f3083ac 0x00000004  //DDRSS_CTL_235_DATA
    0x0f3083b0 0x00000401  //DDRSS_CTL_236_DATA
    0x0f3083b4 0x00000401  //DDRSS_CTL_237_DATA
    0x0f3083b8 0x00000401  //DDRSS_CTL_238_DATA
    0x0f3083bc 0x00000401  //DDRSS_CTL_239_DATA
    0x0f3083c0 0x00000401  //DDRSS_CTL_240_DATA
    0x0f3083c4 0x00000401  //DDRSS_CTL_241_DATA
    0x0f3083c8 0x00000493  //DDRSS_CTL_242_DATA
    0x0f3083cc 0x00000493  //DDRSS_CTL_243_DATA
    0x0f3083d0 0x00000493  //DDRSS_CTL_244_DATA
    0x0f3083d4 0x00000493  //DDRSS_CTL_245_DATA
    0x0f3083d8 0x00000493  //DDRSS_CTL_246_DATA
    0x0f3083dc 0x00000493  //DDRSS_CTL_247_DATA
    0x0f3083e0 0x00000000  //DDRSS_CTL_248_DATA
    0x0f3083e4 0x00000000  //DDRSS_CTL_249_DATA
    0x0f3083e8 0x00000000  //DDRSS_CTL_250_DATA
    0x0f3083ec 0x00000000  //DDRSS_CTL_251_DATA
    0x0f3083f0 0x00000000  //DDRSS_CTL_252_DATA
    0x0f3083f4 0x00000000  //DDRSS_CTL_253_DATA
    0x0f3083f8 0x00000000  //DDRSS_CTL_254_DATA
    0x0f3083fc 0x00000000  //DDRSS_CTL_255_DATA
    0x0f308400 0x00000000  //DDRSS_CTL_256_DATA
    0x0f308404 0x00000000  //DDRSS_CTL_257_DATA
    0x0f308408 0x00000000  //DDRSS_CTL_258_DATA
    0x0f30840c 0x00000000  //DDRSS_CTL_259_DATA
    0x0f308410 0x00000000  //DDRSS_CTL_260_DATA
    0x0f308414 0x00000000  //DDRSS_CTL_261_DATA
    0x0f308418 0x00000000  //DDRSS_CTL_262_DATA
    0x0f30841c 0x00000000  //DDRSS_CTL_263_DATA
    0x0f308420 0x00000000  //DDRSS_CTL_264_DATA
    0x0f308424 0x00000000  //DDRSS_CTL_265_DATA
    0x0f308428 0x00000000  //DDRSS_CTL_266_DATA
    0x0f30842c 0x00000000  //DDRSS_CTL_267_DATA
    0x0f308430 0x00000000  //DDRSS_CTL_268_DATA
    0x0f308434 0x00000000  //DDRSS_CTL_269_DATA
    0x0f308438 0x00000000  //DDRSS_CTL_270_DATA
    0x0f30843c 0x00000000  //DDRSS_CTL_271_DATA
    0x0f308440 0x00000000  //DDRSS_CTL_272_DATA
    0x0f308444 0x00000000  //DDRSS_CTL_273_DATA
    0x0f308448 0x00000000  //DDRSS_CTL_274_DATA
    0x0f30844c 0x00000000  //DDRSS_CTL_275_DATA
    0x0f308450 0x00000000  //DDRSS_CTL_276_DATA
    0x0f308454 0x00010000  //DDRSS_CTL_277_DATA
    0x0f308458 0x00000000  //DDRSS_CTL_278_DATA
    0x0f30845c 0x00000100  //DDRSS_CTL_279_DATA
    0x0f308460 0x00000000  //DDRSS_CTL_280_DATA
    0x0f308464 0x00000101  //DDRSS_CTL_281_DATA
    0x0f308468 0x00000000  //DDRSS_CTL_282_DATA
    0x0f30846c 0x00000000  //DDRSS_CTL_283_DATA
    0x0f308470 0x00000000  //DDRSS_CTL_284_DATA
    0x0f308474 0x00000000  //DDRSS_CTL_285_DATA
    0x0f308478 0x00000000  //DDRSS_CTL_286_DATA
    0x0f30847c 0x00000000  //DDRSS_CTL_287_DATA
    0x0f308480 0x00000000  //DDRSS_CTL_288_DATA
    0x0f308484 0x00000000  //DDRSS_CTL_289_DATA
    0x0f308488 0x0c181511  //DDRSS_CTL_290_DATA
    0x0f30848c 0x00000304  //DDRSS_CTL_291_DATA
    0x0f308490 0x00000000  //DDRSS_CTL_292_DATA
    0x0f308494 0x00000000  //DDRSS_CTL_293_DATA
    0x0f308498 0x00000000  //DDRSS_CTL_294_DATA
    0x0f30849c 0x00000000  //DDRSS_CTL_295_DATA
    0x0f3084a0 0x00000000  //DDRSS_CTL_296_DATA
    0x0f3084a4 0x00000000  //DDRSS_CTL_297_DATA
    0x0f3084a8 0x00000000  //DDRSS_CTL_298_DATA
    0x0f3084ac 0x00000000  //DDRSS_CTL_299_DATA
    0x0f3084b0 0x00000000  //DDRSS_CTL_300_DATA
    0x0f3084b4 0x00000000  //DDRSS_CTL_301_DATA
    0x0f3084b8 0x00000000  //DDRSS_CTL_302_DATA
    0x0f3084bc 0x00000000  //DDRSS_CTL_303_DATA
    0x0f3084c0 0x00000000  //DDRSS_CTL_304_DATA
    0x0f3084c4 0x00040000  //DDRSS_CTL_305_DATA
    0x0f3084c8 0x00800200  //DDRSS_CTL_306_DATA
    0x0f3084cc 0x00000000  //DDRSS_CTL_307_DATA
    0x0f3084d0 0x02000400  //DDRSS_CTL_308_DATA
    0x0f3084d4 0x00000080  //DDRSS_CTL_309_DATA
    0x0f3084d8 0x00040000  //DDRSS_CTL_310_DATA
    0x0f3084dc 0x00800200  //DDRSS_CTL_311_DATA
    0x0f3084e0 0x00000000  //DDRSS_CTL_312_DATA
    0x0f3084e4 0x00000000  //DDRSS_CTL_313_DATA
    0x0f3084e8 0x00000000  //DDRSS_CTL_314_DATA
    0x0f3084ec 0x00000100  //DDRSS_CTL_315_DATA
    0x0f3084f0 0x01010000  //DDRSS_CTL_316_DATA
    0x0f3084f4 0x00000101  //DDRSS_CTL_317_DATA
    0x0f3084f8 0x1fff0000  //DDRSS_CTL_318_DATA
    0x0f3084fc 0x000fff00  //DDRSS_CTL_319_DATA
    0x0f308500 0xffffffff  //DDRSS_CTL_320_DATA
    0x0f308504 0x00ffff00  //DDRSS_CTL_321_DATA
    0x0f308508 0x0a000000  //DDRSS_CTL_322_DATA
    0x0f30850c 0x0001ffff  //DDRSS_CTL_323_DATA
    0x0f308510 0x01010101  //DDRSS_CTL_324_DATA
    0x0f308514 0x01010101  //DDRSS_CTL_325_DATA
    0x0f308518 0x00000118  //DDRSS_CTL_326_DATA
    0x0f30851c 0x00000c01  //DDRSS_CTL_327_DATA
    0x0f308520 0x00000000  //DDRSS_CTL_328_DATA
    0x0f308524 0x00000000  //DDRSS_CTL_329_DATA
    0x0f308528 0x00000000  //DDRSS_CTL_330_DATA
    0x0f30852c 0x01000000  //DDRSS_CTL_331_DATA
    0x0f308530 0x00010000  //DDRSS_CTL_332_DATA
    0x0f308534 0x00010004  //DDRSS_CTL_333_DATA
    0x0f308538 0x80000400  //DDRSS_CTL_334_DATA
    0x0f30853c 0x00000000  //DDRSS_CTL_335_DATA
    0x0f308540 0x00000000  //DDRSS_CTL_336_DATA
    0x0f308544 0x00000000  //DDRSS_CTL_337_DATA
    0x0f308548 0x00000000  //DDRSS_CTL_338_DATA
    0x0f30854c 0x00000000  //DDRSS_CTL_339_DATA
    0x0f308550 0x00000000  //DDRSS_CTL_340_DATA
    0x0f308554 0x00000000  //DDRSS_CTL_341_DATA
    0x0f308558 0x00000004  //DDRSS_CTL_342_DATA
    0x0f30855c 0x00000000  //DDRSS_CTL_343_DATA
    0x0f308560 0x00000000  //DDRSS_CTL_344_DATA
    0x0f308564 0x00000000  //DDRSS_CTL_345_DATA
    0x0f308568 0x00000000  //DDRSS_CTL_346_DATA
    0x0f30856c 0x00000000  //DDRSS_CTL_347_DATA
    0x0f308570 0x00000000  //DDRSS_CTL_348_DATA
    0x0f308574 0x00000000  //DDRSS_CTL_349_DATA
    0x0f308578 0x00000000  //DDRSS_CTL_350_DATA
    0x0f30857c 0x00000000  //DDRSS_CTL_351_DATA
    0x0f308580 0x00000000  //DDRSS_CTL_352_DATA
    0x0f308584 0x00000000  //DDRSS_CTL_353_DATA
    0x0f308588 0x00000000  //DDRSS_CTL_354_DATA
    0x0f30858c 0x00000000  //DDRSS_CTL_355_DATA
    0x0f308590 0x00000000  //DDRSS_CTL_356_DATA
    0x0f308594 0x00000000  //DDRSS_CTL_357_DATA
    0x0f308598 0x00000000  //DDRSS_CTL_358_DATA
    0x0f30859c 0x00000000  //DDRSS_CTL_359_DATA
    0x0f3085a0 0x00000000  //DDRSS_CTL_360_DATA
    0x0f3085a4 0x00000000  //DDRSS_CTL_361_DATA
    0x0f3085a8 0x00000000  //DDRSS_CTL_362_DATA
    0x0f3085ac 0x00000000  //DDRSS_CTL_363_DATA
    0x0f3085b0 0x00000000  //DDRSS_CTL_364_DATA
    0x0f3085b4 0x00000000  //DDRSS_CTL_365_DATA
    0x0f3085b8 0x00000000  //DDRSS_CTL_366_DATA
    0x0f3085bc 0x00000000  //DDRSS_CTL_367_DATA
    0x0f3085c0 0x00000000  //DDRSS_CTL_368_DATA
    0x0f3085c4 0x00000000  //DDRSS_CTL_369_DATA
    0x0f3085c8 0x0c000000  //DDRSS_CTL_370_DATA
    0x0f3085cc 0x060c0606  //DDRSS_CTL_371_DATA
    0x0f3085d0 0x06060c06  //DDRSS_CTL_372_DATA
    0x0f3085d4 0x00010101  //DDRSS_CTL_373_DATA
    0x0f3085d8 0x02000000  //DDRSS_CTL_374_DATA
    0x0f3085dc 0x03020101  //DDRSS_CTL_375_DATA
    0x0f3085e0 0x00000303  //DDRSS_CTL_376_DATA
    0x0f3085e4 0x02020200  //DDRSS_CTL_377_DATA
    0x0f3085e8 0x02020202  //DDRSS_CTL_378_DATA
    0x0f3085ec 0x02020202  //DDRSS_CTL_379_DATA
    0x0f3085f0 0x02020202  //DDRSS_CTL_380_DATA
    0x0f3085f4 0x00000000  //DDRSS_CTL_381_DATA
    0x0f3085f8 0x00000000  //DDRSS_CTL_382_DATA
    0x0f3085fc 0x04000100  //DDRSS_CTL_383_DATA
    0x0f308600 0x1e000304  //DDRSS_CTL_384_DATA
    0x0f308604 0x000030c0  //DDRSS_CTL_385_DATA
    0x0f308608 0x00000200  //DDRSS_CTL_386_DATA
    0x0f30860c 0x00000200  //DDRSS_CTL_387_DATA
    0x0f308610 0x00000200  //DDRSS_CTL_388_DATA
    0x0f308614 0x00000200  //DDRSS_CTL_389_DATA
    0x0f308618 0x0000db60  //DDRSS_CTL_390_DATA
    0x0f30861c 0x0001e780  //DDRSS_CTL_391_DATA
    0x0f308620 0x0a0b0302  //DDRSS_CTL_392_DATA
    0x0f308624 0x001e090a  //DDRSS_CTL_393_DATA
    0x0f308628 0x000030c0  //DDRSS_CTL_394_DATA
    0x0f30862c 0x00000200  //DDRSS_CTL_395_DATA
    0x0f308630 0x00000200  //DDRSS_CTL_396_DATA
    0x0f308634 0x00000200  //DDRSS_CTL_397_DATA
    0x0f308638 0x00000200  //DDRSS_CTL_398_DATA
    0x0f30863c 0x0000db60  //DDRSS_CTL_399_DATA
    0x0f308640 0x0001e780  //DDRSS_CTL_400_DATA
    0x0f308644 0x0a0b0302  //DDRSS_CTL_401_DATA
    0x0f308648 0x001e090a  //DDRSS_CTL_402_DATA
    0x0f30864c 0x000030c0  //DDRSS_CTL_403_DATA
    0x0f308650 0x00000200  //DDRSS_CTL_404_DATA
    0x0f308654 0x00000200  //DDRSS_CTL_405_DATA
    0x0f308658 0x00000200  //DDRSS_CTL_406_DATA
    0x0f30865c 0x00000200  //DDRSS_CTL_407_DATA
    0x0f308660 0x0000db60  //DDRSS_CTL_408_DATA
    0x0f308664 0x0001e780  //DDRSS_CTL_409_DATA
    0x0f308668 0x0a0b0302  //DDRSS_CTL_410_DATA
    0x0f30866c 0x0000090a  //DDRSS_CTL_411_DATA
    0x0f308670 0x00000000  //DDRSS_CTL_412_DATA
    0x0f308674 0x0302000a  //DDRSS_CTL_413_DATA
    0x0f308678 0x01000500  //DDRSS_CTL_414_DATA
    0x0f30867c 0x01010001  //DDRSS_CTL_415_DATA
    0x0f308680 0x00010001  //DDRSS_CTL_416_DATA
    0x0f308684 0x01010001  //DDRSS_CTL_417_DATA
    0x0f308688 0x02010000  //DDRSS_CTL_418_DATA
    0x0f30868c 0x00000200  //DDRSS_CTL_419_DATA
    0x0f308690 0x02000201  //DDRSS_CTL_420_DATA
    0x0f308694 0x00000000  //DDRSS_CTL_421_DATA
    0x0f308698 0x00202020  //DDRSS_CTL_422_DATA
    0x0f30a000 0x00000a01  //DDRSS_PI_0_DATA
    0x0f30a004 0xae8d79e2  //DDRSS_PI_1_DATA
    0x0f30a008 0x0714b570  //DDRSS_PI_2_DATA
    0x0f30a00c 0x01011387  //DDRSS_PI_3_DATA
    0x0f30a010 0x00000001  //DDRSS_PI_4_DATA
    0x0f30a014 0x00010064  //DDRSS_PI_5_DATA
    0x0f30a018 0x00000000  //DDRSS_PI_6_DATA
    0x0f30a01c 0x00000000  //DDRSS_PI_7_DATA
    0x0f30a020 0x00000000  //DDRSS_PI_8_DATA
    0x0f30a024 0x00000000  //DDRSS_PI_9_DATA
    0x0f30a028 0x00000000  //DDRSS_PI_10_DATA
    0x0f30a02c 0x00000000  //DDRSS_PI_11_DATA
    0x0f30a030 0x00000000  //DDRSS_PI_12_DATA
    0x0f30a034 0x00010001  //DDRSS_PI_13_DATA
    0x0f30a038 0x00000000  //DDRSS_PI_14_DATA
    0x0f30a03c 0x00010001  //DDRSS_PI_15_DATA
    0x0f30a040 0x00000005  //DDRSS_PI_16_DATA
    0x0f30a044 0x00010000  //DDRSS_PI_17_DATA
    0x0f30a048 0x00000000  //DDRSS_PI_18_DATA
    0x0f30a04c 0x00000000  //DDRSS_PI_19_DATA
    0x0f30a050 0x00000000  //DDRSS_PI_20_DATA
    0x0f30a054 0x00000000  //DDRSS_PI_21_DATA
    0x0f30a058 0x00000000  //DDRSS_PI_22_DATA
    0x0f30a05c 0x00000000  //DDRSS_PI_23_DATA
    0x0f30a060 0x280d0001  //DDRSS_PI_24_DATA
    0x0f30a064 0x00000000  //DDRSS_PI_25_DATA
    0x0f30a068 0x00010000  //DDRSS_PI_26_DATA
    0x0f30a06c 0x00003200  //DDRSS_PI_27_DATA
    0x0f30a070 0x00000000  //DDRSS_PI_28_DATA
    0x0f30a074 0x00000000  //DDRSS_PI_29_DATA
    0x0f30a078 0x00060602  //DDRSS_PI_30_DATA
    0x0f30a07c 0x00000000  //DDRSS_PI_31_DATA
    0x0f30a080 0x00000000  //DDRSS_PI_32_DATA
    0x0f30a084 0x00000000  //DDRSS_PI_33_DATA
    0x0f30a088 0x00000001  //DDRSS_PI_34_DATA
    0x0f30a08c 0x00000055  //DDRSS_PI_35_DATA
    0x0f30a090 0x000000aa  //DDRSS_PI_36_DATA
    0x0f30a094 0x000000ad  //DDRSS_PI_37_DATA
    0x0f30a098 0x00000052  //DDRSS_PI_38_DATA
    0x0f30a09c 0x0000006a  //DDRSS_PI_39_DATA
    0x0f30a0a0 0x00000095  //DDRSS_PI_40_DATA
    0x0f30a0a4 0x00000095  //DDRSS_PI_41_DATA
    0x0f30a0a8 0x000000ad  //DDRSS_PI_42_DATA
    0x0f30a0ac 0x00000000  //DDRSS_PI_43_DATA
    0x0f30a0b0 0x00000000  //DDRSS_PI_44_DATA
    0x0f30a0b4 0x00010100  //DDRSS_PI_45_DATA
    0x0f30a0b8 0x00000014  //DDRSS_PI_46_DATA
    0x0f30a0bc 0x000007d0  //DDRSS_PI_47_DATA
    0x0f30a0c0 0x00000300  //DDRSS_PI_48_DATA
    0x0f30a0c4 0x00000000  //DDRSS_PI_49_DATA
    0x0f30a0c8 0x00000000  //DDRSS_PI_50_DATA
    0x0f30a0cc 0x01000000  //DDRSS_PI_51_DATA
    0x0f30a0d0 0x00010101  //DDRSS_PI_52_DATA
    0x0f30a0d4 0x0100090a  //DDRSS_PI_53_DATA
    0x0f30a0d8 0x00000000  //DDRSS_PI_54_DATA
    0x0f30a0dc 0x00010000  //DDRSS_PI_55_DATA
    0x0f30a0e0 0x00000000  //DDRSS_PI_56_DATA
    0x0f30a0e4 0x00000000  //DDRSS_PI_57_DATA
    0x0f30a0e8 0x00000000  //DDRSS_PI_58_DATA
    0x0f30a0ec 0x00000000  //DDRSS_PI_59_DATA
    0x0f30a0f0 0x00001400  //DDRSS_PI_60_DATA
    0x0f30a0f4 0x00000000  //DDRSS_PI_61_DATA
    0x0f30a0f8 0x01000000  //DDRSS_PI_62_DATA
    0x0f30a0fc 0x00000404  //DDRSS_PI_63_DATA
    0x0f30a100 0x00000001  //DDRSS_PI_64_DATA
    0x0f30a104 0x0001010e  //DDRSS_PI_65_DATA
    0x0f30a108 0x02040100  //DDRSS_PI_66_DATA
    0x0f30a10c 0x00010000  //DDRSS_PI_67_DATA
    0x0f30a110 0x00000034  //DDRSS_PI_68_DATA
    0x0f30a114 0x00000000  //DDRSS_PI_69_DATA
    0x0f30a118 0x00000000  //DDRSS_PI_70_DATA
    0x0f30a11c 0x00000000  //DDRSS_PI_71_DATA
    0x0f30a120 0x00000000  //DDRSS_PI_72_DATA
    0x0f30a124 0x00000000  //DDRSS_PI_73_DATA
    0x0f30a128 0x00000000  //DDRSS_PI_74_DATA
    0x0f30a12c 0x00000005  //DDRSS_PI_75_DATA
    0x0f30a130 0x01000000  //DDRSS_PI_76_DATA
    0x0f30a134 0x04010100  //DDRSS_PI_77_DATA
    0x0f30a138 0x00020000  //DDRSS_PI_78_DATA
    0x0f30a13c 0x00010002  //DDRSS_PI_79_DATA
    0x0f30a140 0x00000001  //DDRSS_PI_80_DATA
    0x0f30a144 0x00020001  //DDRSS_PI_81_DATA
    0x0f30a148 0x00020002  //DDRSS_PI_82_DATA
    0x0f30a14c 0x29c02000  //DDRSS_PI_83_DATA
    0x0f30a150 0x00000000  //DDRSS_PI_84_DATA
    0x0f30a154 0x00000000  //DDRSS_PI_85_DATA
    0x0f30a158 0x00000000  //DDRSS_PI_86_DATA
    0x0f30a15c 0x00000000  //DDRSS_PI_87_DATA
    0x0f30a160 0x00000000  //DDRSS_PI_88_DATA
    0x0f30a164 0x00000000  //DDRSS_PI_89_DATA
    0x0f30a168 0x00000000  //DDRSS_PI_90_DATA
    0x0f30a16c 0x00000300  //DDRSS_PI_91_DATA
    0x0f30a170 0x0a090b0c  //DDRSS_PI_92_DATA
    0x0f30a174 0x04060708  //DDRSS_PI_93_DATA
    0x0f30a178 0x01000005  //DDRSS_PI_94_DATA
    0x0f30a17c 0x00000800  //DDRSS_PI_95_DATA
    0x0f30a180 0x00000000  //DDRSS_PI_96_DATA
    0x0f30a184 0x00010008  //DDRSS_PI_97_DATA
    0x0f30a188 0x00000000  //DDRSS_PI_98_DATA
    0x0f30a18c 0x0000aa00  //DDRSS_PI_99_DATA
    0x0f30a190 0x00000000  //DDRSS_PI_100_DATA
    0x0f30a194 0x00010000  //DDRSS_PI_101_DATA
    0x0f30a198 0x00000000  //DDRSS_PI_102_DATA
    0x0f30a19c 0x00000000  //DDRSS_PI_103_DATA
    0x0f30a1a0 0x00000000  //DDRSS_PI_104_DATA
    0x0f30a1a4 0x00000000  //DDRSS_PI_105_DATA
    0x0f30a1a8 0x00000000  //DDRSS_PI_106_DATA
    0x0f30a1ac 0x00000000  //DDRSS_PI_107_DATA
    0x0f30a1b0 0x00000000  //DDRSS_PI_108_DATA
    0x0f30a1b4 0x00000000  //DDRSS_PI_109_DATA
    0x0f30a1b8 0x00000000  //DDRSS_PI_110_DATA
    0x0f30a1bc 0x00000000  //DDRSS_PI_111_DATA
    0x0f30a1c0 0x00000000  //DDRSS_PI_112_DATA
    0x0f30a1c4 0x00000000  //DDRSS_PI_113_DATA
    0x0f30a1c8 0x00000000  //DDRSS_PI_114_DATA
    0x0f30a1cc 0x00000000  //DDRSS_PI_115_DATA
    0x0f30a1d0 0x00000000  //DDRSS_PI_116_DATA
    0x0f30a1d4 0x00000000  //DDRSS_PI_117_DATA
    0x0f30a1d8 0x00000000  //DDRSS_PI_118_DATA
    0x0f30a1dc 0x00000000  //DDRSS_PI_119_DATA
    0x0f30a1e0 0x00000000  //DDRSS_PI_120_DATA
    0x0f30a1e4 0x00000000  //DDRSS_PI_121_DATA
    0x0f30a1e8 0x00000000  //DDRSS_PI_122_DATA
    0x0f30a1ec 0x00000000  //DDRSS_PI_123_DATA
    0x0f30a1f0 0x00000008  //DDRSS_PI_124_DATA
    0x0f30a1f4 0x00000000  //DDRSS_PI_125_DATA
    0x0f30a1f8 0x00000000  //DDRSS_PI_126_DATA
    0x0f30a1fc 0x00000000  //DDRSS_PI_127_DATA
    0x0f30a200 0x00000000  //DDRSS_PI_128_DATA
    0x0f30a204 0x00000000  //DDRSS_PI_129_DATA
    0x0f30a208 0x00000000  //DDRSS_PI_130_DATA
    0x0f30a20c 0x00000000  //DDRSS_PI_131_DATA
    0x0f30a210 0x00000000  //DDRSS_PI_132_DATA
    0x0f30a214 0x00010100  //DDRSS_PI_133_DATA
    0x0f30a218 0x00000000  //DDRSS_PI_134_DATA
    0x0f30a21c 0x00000000  //DDRSS_PI_135_DATA
    0x0f30a220 0x00027100  //DDRSS_PI_136_DATA
    0x0f30a224 0x00061a80  //DDRSS_PI_137_DATA
    0x0f30a228 0x00000100  //DDRSS_PI_138_DATA
    0x0f30a22c 0x00000000  //DDRSS_PI_139_DATA
    0x0f30a230 0x00000000  //DDRSS_PI_140_DATA
    0x0f30a234 0x00000000  //DDRSS_PI_141_DATA
    0x0f30a238 0x00000000  //DDRSS_PI_142_DATA
    0x0f30a23c 0x00000000  //DDRSS_PI_143_DATA
    0x0f30a240 0x01000000  //DDRSS_PI_144_DATA
    0x0f30a244 0xc1010003  //DDRSS_PI_145_DATA
    0x0f30a248 0x02000101  //DDRSS_PI_146_DATA
    0x0f30a24c 0x01030101  //DDRSS_PI_147_DATA
    0x0f30a250 0x00010400  //DDRSS_PI_148_DATA
    0x0f30a254 0x06000105  //DDRSS_PI_149_DATA
    0x0f30a258 0x01070001  //DDRSS_PI_150_DATA
    0x0f30a25c 0x00000000  //DDRSS_PI_151_DATA
    0x0f30a260 0x00000000  //DDRSS_PI_152_DATA
    0x0f30a264 0x00000001  //DDRSS_PI_153_DATA
    0x0f30a268 0x00010000  //DDRSS_PI_154_DATA
    0x0f30a26c 0x00000000  //DDRSS_PI_155_DATA
    0x0f30a270 0x00000000  //DDRSS_PI_156_DATA
    0x0f30a274 0x00000000  //DDRSS_PI_157_DATA
    0x0f30a278 0x00000000  //DDRSS_PI_158_DATA
    0x0f30a27c 0x00010000  //DDRSS_PI_159_DATA
    0x0f30a280 0x00000004  //DDRSS_PI_160_DATA
    0x0f30a284 0x00000000  //DDRSS_PI_161_DATA
    0x0f30a288 0x00000000  //DDRSS_PI_162_DATA
    0x0f30a28c 0x00000000  //DDRSS_PI_163_DATA
    0x0f30a290 0x00007800  //DDRSS_PI_164_DATA
    0x0f30a294 0x00780078  //DDRSS_PI_165_DATA
    0x0f30a298 0x00141414  //DDRSS_PI_166_DATA
    0x0f30a29c 0x00000038  //DDRSS_PI_167_DATA
    0x0f30a2a0 0x00000038  //DDRSS_PI_168_DATA
    0x0f30a2a4 0x00040038  //DDRSS_PI_169_DATA
    0x0f30a2a8 0x04000400  //DDRSS_PI_170_DATA
    0x0f30a2ac 0x68040009  //DDRSS_PI_171_DATA
    0x0f30a2b0 0x04000918  //DDRSS_PI_172_DATA
    0x0f30a2b4 0x00091868  //DDRSS_PI_173_DATA
    0x0f30a2b8 0x00186804  //DDRSS_PI_174_DATA
    0x0f30a2bc 0x00000118  //DDRSS_PI_175_DATA
    0x0f30a2c0 0x00001860  //DDRSS_PI_176_DATA
    0x0f30a2c4 0x00000118  //DDRSS_PI_177_DATA
    0x0f30a2c8 0x00001860  //DDRSS_PI_178_DATA
    0x0f30a2cc 0x00000118  //DDRSS_PI_179_DATA
    0x0f30a2d0 0x04001860  //DDRSS_PI_180_DATA
    0x0f30a2d4 0x01010404  //DDRSS_PI_181_DATA
    0x0f30a2d8 0x00001901  //DDRSS_PI_182_DATA
    0x0f30a2dc 0x00190019  //DDRSS_PI_183_DATA
    0x0f30a2e0 0x010c010c  //DDRSS_PI_184_DATA
    0x0f30a2e4 0x0000010c  //DDRSS_PI_185_DATA
    0x0f30a2e8 0x00000000  //DDRSS_PI_186_DATA
    0x0f30a2ec 0x03000000  //DDRSS_PI_187_DATA
    0x0f30a2f0 0x01010303  //DDRSS_PI_188_DATA
    0x0f30a2f4 0x01010101  //DDRSS_PI_189_DATA
    0x0f30a2f8 0x00181818  //DDRSS_PI_190_DATA
    0x0f30a2fc 0x00000000  //DDRSS_PI_191_DATA
    0x0f30a300 0x00000000  //DDRSS_PI_192_DATA
    0x0f30a304 0x0b000000  //DDRSS_PI_193_DATA
    0x0f30a308 0x0a0a0b0b  //DDRSS_PI_194_DATA
    0x0f30a30c 0x0303030a  //DDRSS_PI_195_DATA
    0x0f30a310 0x00000000  //DDRSS_PI_196_DATA
    0x0f30a314 0x00000000  //DDRSS_PI_197_DATA
    0x0f30a318 0x00000000  //DDRSS_PI_198_DATA
    0x0f30a31c 0x00000000  //DDRSS_PI_199_DATA
    0x0f30a320 0x00000000  //DDRSS_PI_200_DATA
    0x0f30a324 0x00000000  //DDRSS_PI_201_DATA
    0x0f30a328 0x00000000  //DDRSS_PI_202_DATA
    0x0f30a32c 0x00000000  //DDRSS_PI_203_DATA
    0x0f30a330 0x00000000  //DDRSS_PI_204_DATA
    0x0f30a334 0x00000000  //DDRSS_PI_205_DATA
    0x0f30a338 0x00000000  //DDRSS_PI_206_DATA
    0x0f30a33c 0x00000000  //DDRSS_PI_207_DATA
    0x0f30a340 0x00000000  //DDRSS_PI_208_DATA
    0x0f30a344 0x0d090000  //DDRSS_PI_209_DATA
    0x0f30a348 0x0d09000d  //DDRSS_PI_210_DATA
    0x0f30a34c 0x0d09000d  //DDRSS_PI_211_DATA
    0x0f30a350 0x0000000d  //DDRSS_PI_212_DATA
    0x0f30a354 0x00000000  //DDRSS_PI_213_DATA
    0x0f30a358 0x00000000  //DDRSS_PI_214_DATA
    0x0f30a35c 0x00000000  //DDRSS_PI_215_DATA
    0x0f30a360 0x00000000  //DDRSS_PI_216_DATA
    0x0f30a364 0x16000000  //DDRSS_PI_217_DATA
    0x0f30a368 0x001600c8  //DDRSS_PI_218_DATA
    0x0f30a36c 0x001600c8  //DDRSS_PI_219_DATA
    0x0f30a370 0x010100c8  //DDRSS_PI_220_DATA
    0x0f30a374 0x00001b01  //DDRSS_PI_221_DATA
    0x0f30a378 0x1f0f0051  //DDRSS_PI_222_DATA
    0x0f30a37c 0x03000001  //DDRSS_PI_223_DATA
    0x0f30a380 0x001b0a0b  //DDRSS_PI_224_DATA
    0x0f30a384 0x1f0f0051  //DDRSS_PI_225_DATA
    0x0f30a388 0x03000001  //DDRSS_PI_226_DATA
    0x0f30a38c 0x001b0a0b  //DDRSS_PI_227_DATA
    0x0f30a390 0x1f0f0051  //DDRSS_PI_228_DATA
    0x0f30a394 0x03000001  //DDRSS_PI_229_DATA
    0x0f30a398 0x00000a0b  //DDRSS_PI_230_DATA
    0x0f30a39c 0x0d0c0700  //DDRSS_PI_231_DATA
    0x0f30a3a0 0x000d0605  //DDRSS_PI_232_DATA
    0x0f30a3a4 0x0000c570  //DDRSS_PI_233_DATA
    0x0f30a3a8 0x0000001d  //DDRSS_PI_234_DATA
    0x0f30a3ac 0x180a0800  //DDRSS_PI_235_DATA
    0x0f30a3b0 0x0c071c1c  //DDRSS_PI_236_DATA
    0x0f30a3b4 0x0d06050d  //DDRSS_PI_237_DATA
    0x0f30a3b8 0x0000c570  //DDRSS_PI_238_DATA
    0x0f30a3bc 0x0000001d  //DDRSS_PI_239_DATA
    0x0f30a3c0 0x180a0800  //DDRSS_PI_240_DATA
    0x0f30a3c4 0x0c071c1c  //DDRSS_PI_241_DATA
    0x0f30a3c8 0x0d06050d  //DDRSS_PI_242_DATA
    0x0f30a3cc 0x0000c570  //DDRSS_PI_243_DATA
    0x0f30a3d0 0x0000001d  //DDRSS_PI_244_DATA
    0x0f30a3d4 0x180a0800  //DDRSS_PI_245_DATA
    0x0f30a3d8 0x00001c1c  //DDRSS_PI_246_DATA
    0x0f30a3dc 0x000030c0  //DDRSS_PI_247_DATA
    0x0f30a3e0 0x0001e780  //DDRSS_PI_248_DATA
    0x0f30a3e4 0x000030c0  //DDRSS_PI_249_DATA
    0x0f30a3e8 0x0001e780  //DDRSS_PI_250_DATA
    0x0f30a3ec 0x000030c0  //DDRSS_PI_251_DATA
    0x0f30a3f0 0x0001e780  //DDRSS_PI_252_DATA
    0x0f30a3f4 0x02550255  //DDRSS_PI_253_DATA
    0x0f30a3f8 0x03030255  //DDRSS_PI_254_DATA
    0x0f30a3fc 0x00025503  //DDRSS_PI_255_DATA
    0x0f30a400 0x02550255  //DDRSS_PI_256_DATA
    0x0f30a404 0x0c080c08  //DDRSS_PI_257_DATA
    0x0f30a408 0x00000c08  //DDRSS_PI_258_DATA
    0x0f30a40c 0x000890b8  //DDRSS_PI_259_DATA
    0x0f30a410 0x00000000  //DDRSS_PI_260_DATA
    0x0f30a414 0x00000000  //DDRSS_PI_261_DATA
    0x0f30a418 0x00000000  //DDRSS_PI_262_DATA
    0x0f30a41c 0x00000120  //DDRSS_PI_263_DATA
    0x0f30a420 0x000890b8  //DDRSS_PI_264_DATA
    0x0f30a424 0x00000000  //DDRSS_PI_265_DATA
    0x0f30a428 0x00000000  //DDRSS_PI_266_DATA
    0x0f30a42c 0x00000000  //DDRSS_PI_267_DATA
    0x0f30a430 0x00000120  //DDRSS_PI_268_DATA
    0x0f30a434 0x000890b8  //DDRSS_PI_269_DATA
    0x0f30a438 0x00000000  //DDRSS_PI_270_DATA
    0x0f30a43c 0x00000000  //DDRSS_PI_271_DATA
    0x0f30a440 0x00000000  //DDRSS_PI_272_DATA
    0x0f30a444 0x02000120  //DDRSS_PI_273_DATA
    0x0f30a448 0x00000080  //DDRSS_PI_274_DATA
    0x0f30a44c 0x00020000  //DDRSS_PI_275_DATA
    0x0f30a450 0x00000080  //DDRSS_PI_276_DATA
    0x0f30a454 0x00020000  //DDRSS_PI_277_DATA
    0x0f30a458 0x00000080  //DDRSS_PI_278_DATA
    0x0f30a45c 0x00000000  //DDRSS_PI_279_DATA
    0x0f30a460 0x00000000  //DDRSS_PI_280_DATA
    0x0f30a464 0x00040404  //DDRSS_PI_281_DATA
    0x0f30a468 0x00000000  //DDRSS_PI_282_DATA
    0x0f30a46c 0x02010102  //DDRSS_PI_283_DATA
    0x0f30a470 0x67676767  //DDRSS_PI_284_DATA
    0x0f30a474 0x00000202  //DDRSS_PI_285_DATA
    0x0f30a478 0x00000000  //DDRSS_PI_286_DATA
    0x0f30a47c 0x00000000  //DDRSS_PI_287_DATA
    0x0f30a480 0x00000000  //DDRSS_PI_288_DATA
    0x0f30a484 0x00000000  //DDRSS_PI_289_DATA
    0x0f30a488 0x00000000  //DDRSS_PI_290_DATA
    0x0f30a48c 0x0d100f00  //DDRSS_PI_291_DATA
    0x0f30a490 0x0003020e  //DDRSS_PI_292_DATA
    0x0f30a494 0x00000001  //DDRSS_PI_293_DATA
    0x0f30a498 0x01000000  //DDRSS_PI_294_DATA
    0x0f30a49c 0x00020201  //DDRSS_PI_295_DATA
    0x0f30a4a0 0x00000000  //DDRSS_PI_296_DATA
    0x0f30a4a4 0x00000414  //DDRSS_PI_297_DATA
    0x0f30a4a8 0x00000301  //DDRSS_PI_298_DATA
    0x0f30a4ac 0x00000080  //DDRSS_PI_299_DATA
    0x0f30a4b0 0x00000000  //DDRSS_PI_300_DATA
    0x0f30a4b4 0x00000004  //DDRSS_PI_301_DATA
    0x0f30a4b8 0x00000401  //DDRSS_PI_302_DATA
    0x0f30a4bc 0x00000493  //DDRSS_PI_303_DATA
    0x0f30a4c0 0x00000000  //DDRSS_PI_304_DATA
    0x0f30a4c4 0x00000414  //DDRSS_PI_305_DATA
    0x0f30a4c8 0x00000301  //DDRSS_PI_306_DATA
    0x0f30a4cc 0x00000080  //DDRSS_PI_307_DATA
    0x0f30a4d0 0x00000000  //DDRSS_PI_308_DATA
    0x0f30a4d4 0x00000004  //DDRSS_PI_309_DATA
    0x0f30a4d8 0x00000401  //DDRSS_PI_310_DATA
    0x0f30a4dc 0x00000493  //DDRSS_PI_311_DATA
    0x0f30a4e0 0x00000000  //DDRSS_PI_312_DATA
    0x0f30a4e4 0x00000414  //DDRSS_PI_313_DATA
    0x0f30a4e8 0x00000301  //DDRSS_PI_314_DATA
    0x0f30a4ec 0x00000080  //DDRSS_PI_315_DATA
    0x0f30a4f0 0x00000000  //DDRSS_PI_316_DATA
    0x0f30a4f4 0x00000004  //DDRSS_PI_317_DATA
    0x0f30a4f8 0x00000401  //DDRSS_PI_318_DATA
    0x0f30a4fc 0x00000493  //DDRSS_PI_319_DATA
    0x0f30a500 0x00000000  //DDRSS_PI_320_DATA
    0x0f30a504 0x00000414  //DDRSS_PI_321_DATA
    0x0f30a508 0x00000301  //DDRSS_PI_322_DATA
    0x0f30a50c 0x00000080  //DDRSS_PI_323_DATA
    0x0f30a510 0x00000000  //DDRSS_PI_324_DATA
    0x0f30a514 0x00000004  //DDRSS_PI_325_DATA
    0x0f30a518 0x00000401  //DDRSS_PI_326_DATA
    0x0f30a51c 0x00000493  //DDRSS_PI_327_DATA
    0x0f30a520 0x00000000  //DDRSS_PI_328_DATA
    0x0f30a524 0x00000414  //DDRSS_PI_329_DATA
    0x0f30a528 0x00000301  //DDRSS_PI_330_DATA
    0x0f30a52c 0x00000080  //DDRSS_PI_331_DATA
    0x0f30a530 0x00000000  //DDRSS_PI_332_DATA
    0x0f30a534 0x00000004  //DDRSS_PI_333_DATA
    0x0f30a538 0x00000401  //DDRSS_PI_334_DATA
    0x0f30a53c 0x00000493  //DDRSS_PI_335_DATA
    0x0f30a540 0x00000000  //DDRSS_PI_336_DATA
    0x0f30a544 0x00000414  //DDRSS_PI_337_DATA
    0x0f30a548 0x00000301  //DDRSS_PI_338_DATA
    0x0f30a54c 0x00000080  //DDRSS_PI_339_DATA
    0x0f30a550 0x00000000  //DDRSS_PI_340_DATA
    0x0f30a554 0x00000004  //DDRSS_PI_341_DATA
    0x0f30a558 0x00000401  //DDRSS_PI_342_DATA
    0x0f30a55c 0x00000493  //DDRSS_PI_343_DATA
    0x0f30a560 0x00000000  //DDRSS_PI_344_DATA
    data slice 0
    0x0f30c000 0x04c00000  //DDRSS_PHY_0_DATA_F0_R0
    0x0f30c004 0x00000000  //DDRSS_PHY_1_DATA_F0_R0
    0x0f30c008 0x00000200  //DDRSS_PHY_2_DATA_F0_R0
    0x0f30c00c 0x00000000  //DDRSS_PHY_3_DATA_F0_R0
    0x0f30c010 0x00000000  //DDRSS_PHY_4_DATA_F0_R0
    0x0f30c014 0x00000000  //DDRSS_PHY_5_DATA_F0_R0
    0x0f30c018 0x00000000  //DDRSS_PHY_6_DATA_F0_R0
    0x0f30c01c 0x00000000  //DDRSS_PHY_7_DATA_F0_R0
    0x0f30c020 0x00000001  //DDRSS_PHY_8_DATA_F0_R0
    0x0f30c024 0x00000000  //DDRSS_PHY_9_DATA_F0_R0
    0x0f30c028 0x01800000  //DDRSS_PHY_10_DATA_F0_R0
    0x0f30c02c 0x010101ff  //DDRSS_PHY_11_DATA_F0_R0
    0x0f30c030 0x00010000  //DDRSS_PHY_12_DATA_F0_R0
    0x0f30c034 0x00c00004  //DDRSS_PHY_13_DATA_F0_R0
    0x0f30c038 0x00cc0008  //DDRSS_PHY_14_DATA_F0_R0
    0x0f30c03c 0x00660201  //DDRSS_PHY_15_DATA_F0_R0
    0x0f30c040 0x00000000  //DDRSS_PHY_16_DATA_F0_R0
    0x0f30c044 0x00000000  //DDRSS_PHY_17_DATA_F0_R0
    0x0f30c048 0x00000000  //DDRSS_PHY_18_DATA_F0_R0
    0x0f30c04c 0x0000aaaa  //DDRSS_PHY_19_DATA_F0_R0
    0x0f30c050 0x00005555  //DDRSS_PHY_20_DATA_F0_R0
    0x0f30c054 0x0000b5b5  //DDRSS_PHY_21_DATA_F0_R0
    0x0f30c058 0x00004a4a  //DDRSS_PHY_22_DATA_F0_R0
    0x0f30c05c 0x00005656  //DDRSS_PHY_23_DATA_F0_R0
    0x0f30c060 0x0000a9a9  //DDRSS_PHY_24_DATA_F0_R0
    0x0f30c064 0x0000b7b7  //DDRSS_PHY_25_DATA_F0_R0
    0x0f30c068 0x00004848  //DDRSS_PHY_26_DATA_F0_R0
    0x0f30c06c 0x00000000  //DDRSS_PHY_27_DATA_F0_R0
    0x0f30c070 0x00000000  //DDRSS_PHY_28_DATA_F0_R0
    0x0f30c074 0x08000000  //DDRSS_PHY_29_DATA_F0_R0
    0x0f30c078 0x0f000008  //DDRSS_PHY_30_DATA_F0_R0
    0x0f30c07c 0x00000f0f  //DDRSS_PHY_31_DATA_F0_R0
    0x0f30c080 0x00e4e400  //DDRSS_PHY_32_DATA_F0_R0
    0x0f30c084 0x00070820  //DDRSS_PHY_33_DATA_F0_R0
    0x0f30c088 0x000c0020  //DDRSS_PHY_34_DATA_F0_R0
    0x0f30c08c 0x00062000  //DDRSS_PHY_35_DATA_F0_R0
    0x0f30c090 0x00000000  //DDRSS_PHY_36_DATA_F0_R0
    0x0f30c094 0x55555555  //DDRSS_PHY_37_DATA_F0_R0
    0x0f30c098 0xaaaaaaaa  //DDRSS_PHY_38_DATA_F0_R0
    0x0f30c09c 0x55555555  //DDRSS_PHY_39_DATA_F0_R0
    0x0f30c0a0 0xaaaaaaaa  //DDRSS_PHY_40_DATA_F0_R0
    0x0f30c0a4 0x00005555  //DDRSS_PHY_41_DATA_F0_R0
    0x0f30c0a8 0x01000100  //DDRSS_PHY_42_DATA_F0_R0
    0x0f30c0ac 0x00800180  //DDRSS_PHY_43_DATA_F0_R0
    0x0f30c0b0 0x00000000  //DDRSS_PHY_44_DATA_F0_R0
    0x0f30c0b4 0x00100000  //DDRSS_PHY_45_DATA_F0_R0
    0x0f30c0b8 0x00000000  //DDRSS_PHY_46_DATA_F0_R0
    0x0f30c0bc 0xc009000d  //DDRSS_PHY_47_DATA_F0_R0
    0x0f30c0c0 0x00000000  //DDRSS_PHY_48_DATA_F0_R0
    0x0f30c0c4 0x00010500  //DDRSS_PHY_49_DATA_F0_R0
    0x0f30c0c8 0x00000000  //DDRSS_PHY_50_DATA_F0_R0
    0x0f30c0cc 0x00021cff  //DDRSS_PHY_51_DATA_F0_R0
    0x0f30c0d0 0x00000000  //DDRSS_PHY_52_DATA_F0_R0
    0x0f30c0d4 0x00000000  //DDRSS_PHY_53_DATA_F0_R0
    0x0f30c0d8 0x000000b1  //DDRSS_PHY_54_DATA_F0_R0
    0x0f30c0dc 0x01cc0000  //DDRSS_PHY_55_DATA_F0_R0
    0x0f30c0e0 0x00000000  //DDRSS_PHY_56_DATA_F0_R0
    0x0f30c0e4 0x0c000000  //DDRSS_PHY_57_DATA_F0_R0
    0x0f30c0e8 0x07ff0000  //DDRSS_PHY_58_DATA_F0_R0
    0x0f30c0ec 0x00000000  //DDRSS_PHY_59_DATA_F0_R0
    0x0f30c0f0 0x00000000  //DDRSS_PHY_60_DATA_F0_R0
    0x0f30c0f4 0x00000000  //DDRSS_PHY_61_DATA_F0_R0
    0x0f30c0f8 0x00000000  //DDRSS_PHY_62_DATA_F0_R0
    0x0f30c0fc 0x00000000  //DDRSS_PHY_63_DATA_F0_R0
    0x0f30c100 0x00000000  //DDRSS_PHY_64_DATA_F0_R0
    0x0f30c104 0x00000004  //DDRSS_PHY_65_DATA_F0_R0
    0x0f30c108 0x00000000  //DDRSS_PHY_66_DATA_F0_R0
    0x0f30c10c 0x00000000  //DDRSS_PHY_67_DATA_F0_R0
    0x0f30c110 0x00000000  //DDRSS_PHY_68_DATA_F0_R0
    0x0f30c114 0x00000000  //DDRSS_PHY_69_DATA_F0_R0
    0x0f30c118 0x00000000  //DDRSS_PHY_70_DATA_F0_R0
    0x0f30c11c 0x00000000  //DDRSS_PHY_71_DATA_F0_R0
    0x0f30c120 0x041f07ff  //DDRSS_PHY_72_DATA_F0_R0
    0x0f30c124 0x00000000  //DDRSS_PHY_73_DATA_F0_R0
    0x0f30c128 0x01ccb001  //DDRSS_PHY_74_DATA_F0_R0
    0x0f30c12c 0x2000ccb0  //DDRSS_PHY_75_DATA_F0_R0
    0x0f30c130 0x20000140  //DDRSS_PHY_76_DATA_F0_R0
    0x0f30c134 0x07ff0200  //DDRSS_PHY_77_DATA_F0_R0
    0x0f30c138 0x0000dd01  //DDRSS_PHY_78_DATA_F0_R0
    0x0f30c13c 0x10100303  //DDRSS_PHY_79_DATA_F0_R0
    0x0f30c140 0x10101010  //DDRSS_PHY_80_DATA_F0_R0
    0x0f30c144 0x10101010  //DDRSS_PHY_81_DATA_F0_R0
    0x0f30c148 0x00021010  //DDRSS_PHY_82_DATA_F0_R0
    0x0f30c14c 0x00100010  //DDRSS_PHY_83_DATA_F0_R0
    0x0f30c150 0x00100010  //DDRSS_PHY_84_DATA_F0_R0
    0x0f30c154 0x00100010  //DDRSS_PHY_85_DATA_F0_R0
    0x0f30c158 0x00100010  //DDRSS_PHY_86_DATA_F0_R0
    0x0f30c15c 0x02020010  //DDRSS_PHY_87_DATA_F0_R0
    0x0f30c160 0x51515041  //DDRSS_PHY_88_DATA_F0_R0
    0x0f30c164 0x31804000  //DDRSS_PHY_89_DATA_F0_R0
    0x0f30c168 0x04800340  //DDRSS_PHY_90_DATA_F0_R0
    0x0f30c16c 0x01008080  //DDRSS_PHY_91_DATA_F0_R0
    0x0f30c170 0x04050000  //DDRSS_PHY_92_DATA_F0_R0
    0x0f30c174 0x00000504  //DDRSS_PHY_93_DATA_F0_R0
    0x0f30c178 0x42100010  //DDRSS_PHY_94_DATA_F0_R0
    0x0f30c17c 0x010c053e  //DDRSS_PHY_95_DATA_F0_R0
    0x0f30c180 0x000f0c14  //DDRSS_PHY_96_DATA_F0_R0
    0x0f30c184 0x01000140  //DDRSS_PHY_97_DATA_F0_R0
    0x0f30c188 0x007a0120  //DDRSS_PHY_98_DATA_F0_R0
    0x0f30c18c 0x00000c00  //DDRSS_PHY_99_DATA_F0_R0
    0x0f30c190 0x000001cc  //DDRSS_PHY_100_DATA_F0_R0
    0x0f30c194 0x20100200  //DDRSS_PHY_101_DATA_F0_R0
    0x0f30c198 0x00000005  //DDRSS_PHY_102_DATA_F0_R0
    0x0f30c19c 0x64715230  //DDRSS_PHY_103_DATA_F0_R0
    0x0f30c1a0 0x00000008  //DDRSS_PHY_104_DATA_F0_R0
    0x0f30c1a4 0x02800280  //DDRSS_PHY_105_DATA_F0_R0
    0x0f30c1a8 0x02800280  //DDRSS_PHY_106_DATA_F0_R0
    0x0f30c1ac 0x02800280  //DDRSS_PHY_107_DATA_F0_R0
    0x0f30c1b0 0x02800280  //DDRSS_PHY_108_DATA_F0_R0
    0x0f30c1b4 0x00900280  //DDRSS_PHY_109_DATA_F0_R0
    0x0f30c1b8 0x0000e600  //DDRSS_PHY_110_DATA_F0_R0
    0x0f30c1bc 0x00e60000  //DDRSS_PHY_111_DATA_F0_R0
    0x0f30c1c0 0x00e60000  //DDRSS_PHY_112_DATA_F0_R0
    0x0f30c1c4 0x00e60000  //DDRSS_PHY_113_DATA_F0_R0
    0x0f30c1c8 0x00e60000  //DDRSS_PHY_114_DATA_F0_R0
    0x0f30c1cc 0x00e60000  //DDRSS_PHY_115_DATA_F0_R0
    0x0f30c1d0 0x00e60000  //DDRSS_PHY_116_DATA_F0_R0
    0x0f30c1d4 0x00e60000  //DDRSS_PHY_117_DATA_F0_R0
    0x0f30c1d8 0x00e60000  //DDRSS_PHY_118_DATA_F0_R0
    0x0f30c1dc 0x00000000  //DDRSS_PHY_119_DATA_F0_R0
    0x0f30c1e0 0x01000000  //DDRSS_PHY_120_DATA_F0_R0
    0x0f30c1e4 0x00000000  //DDRSS_PHY_121_DATA_F0_R0
    0x0f30c1e8 0x00000000  //DDRSS_PHY_122_DATA_F0_R0
    0x0f30c1ec 0x00080200  //DDRSS_PHY_123_DATA_F0_R0
    0x0f30c1f0 0x00000000  //DDRSS_PHY_124_DATA_F0_R0
    0x0f30c1f4 0x00000000  //DDRSS_PHY_125_DATA_F0_R0
    data slice 1
    0x0f30c400 0x04c00000  //DDRSS_PHY_256_DATA_F0_R0
    0x0f30c404 0x00000000  //DDRSS_PHY_257_DATA_F0_R0
    0x0f30c408 0x00000200  //DDRSS_PHY_258_DATA_F0_R0
    0x0f30c40c 0x00000000  //DDRSS_PHY_259_DATA_F0_R0
    0x0f30c410 0x00000000  //DDRSS_PHY_260_DATA_F0_R0
    0x0f30c414 0x00000000  //DDRSS_PHY_261_DATA_F0_R0
    0x0f30c418 0x00000000  //DDRSS_PHY_262_DATA_F0_R0
    0x0f30c41c 0x00000000  //DDRSS_PHY_263_DATA_F0_R0
    0x0f30c420 0x00000001  //DDRSS_PHY_264_DATA_F0_R0
    0x0f30c424 0x00000000  //DDRSS_PHY_265_DATA_F0_R0
    0x0f30c428 0x01800000  //DDRSS_PHY_266_DATA_F0_R0
    0x0f30c42c 0x010101ff  //DDRSS_PHY_267_DATA_F0_R0
    0x0f30c430 0x00010000  //DDRSS_PHY_268_DATA_F0_R0
    0x0f30c434 0x00c00004  //DDRSS_PHY_269_DATA_F0_R0
    0x0f30c438 0x00cc0008  //DDRSS_PHY_270_DATA_F0_R0
    0x0f30c43c 0x00660201  //DDRSS_PHY_271_DATA_F0_R0
    0x0f30c440 0x00000000  //DDRSS_PHY_272_DATA_F0_R0
    0x0f30c444 0x00000000  //DDRSS_PHY_273_DATA_F0_R0
    0x0f30c448 0x00000000  //DDRSS_PHY_274_DATA_F0_R0
    0x0f30c44c 0x0000aaaa  //DDRSS_PHY_275_DATA_F0_R0
    0x0f30c450 0x00005555  //DDRSS_PHY_276_DATA_F0_R0
    0x0f30c454 0x0000b5b5  //DDRSS_PHY_277_DATA_F0_R0
    0x0f30c458 0x00004a4a  //DDRSS_PHY_278_DATA_F0_R0
    0x0f30c45c 0x00005656  //DDRSS_PHY_279_DATA_F0_R0
    0x0f30c460 0x0000a9a9  //DDRSS_PHY_280_DATA_F0_R0
    0x0f30c464 0x0000b7b7  //DDRSS_PHY_281_DATA_F0_R0
    0x0f30c468 0x00004848  //DDRSS_PHY_282_DATA_F0_R0
    0x0f30c46c 0x00000000  //DDRSS_PHY_283_DATA_F0_R0
    0x0f30c470 0x00000000  //DDRSS_PHY_284_DATA_F0_R0
    0x0f30c474 0x08000000  //DDRSS_PHY_285_DATA_F0_R0
    0x0f30c478 0x0f000008  //DDRSS_PHY_286_DATA_F0_R0
    0x0f30c47c 0x00000f0f  //DDRSS_PHY_287_DATA_F0_R0
    0x0f30c480 0x00e4e400  //DDRSS_PHY_288_DATA_F0_R0
    0x0f30c484 0x00070820  //DDRSS_PHY_289_DATA_F0_R0
    0x0f30c488 0x000c0020  //DDRSS_PHY_290_DATA_F0_R0
    0x0f30c48c 0x00062000  //DDRSS_PHY_291_DATA_F0_R0
    0x0f30c490 0x00000000  //DDRSS_PHY_292_DATA_F0_R0
    0x0f30c494 0x55555555  //DDRSS_PHY_293_DATA_F0_R0
    0x0f30c498 0xaaaaaaaa  //DDRSS_PHY_294_DATA_F0_R0
    0x0f30c49c 0x55555555  //DDRSS_PHY_295_DATA_F0_R0
    0x0f30c4a0 0xaaaaaaaa  //DDRSS_PHY_296_DATA_F0_R0
    0x0f30c4a4 0x00005555  //DDRSS_PHY_297_DATA_F0_R0
    0x0f30c4a8 0x01000100  //DDRSS_PHY_298_DATA_F0_R0
    0x0f30c4ac 0x00800180  //DDRSS_PHY_299_DATA_F0_R0
    0x0f30c4b0 0x00000000  //DDRSS_PHY_300_DATA_F0_R0
    0x0f30c4b4 0x00100000  //DDRSS_PHY_301_DATA_F0_R0
    0x0f30c4b8 0x00000000  //DDRSS_PHY_302_DATA_F0_R0
    0x0f30c4bc 0xc009000d  //DDRSS_PHY_303_DATA_F0_R0
    0x0f30c4c0 0x00000000  //DDRSS_PHY_304_DATA_F0_R0
    0x0f30c4c4 0x00010500  //DDRSS_PHY_305_DATA_F0_R0
    0x0f30c4c8 0x00000000  //DDRSS_PHY_306_DATA_F0_R0
    0x0f30c4cc 0x00021cff  //DDRSS_PHY_307_DATA_F0_R0
    0x0f30c4d0 0x00000000  //DDRSS_PHY_308_DATA_F0_R0
    0x0f30c4d4 0x00000000  //DDRSS_PHY_309_DATA_F0_R0
    0x0f30c4d8 0x000000b1  //DDRSS_PHY_310_DATA_F0_R0
    0x0f30c4dc 0x01cc0000  //DDRSS_PHY_311_DATA_F0_R0
    0x0f30c4e0 0x00000000  //DDRSS_PHY_312_DATA_F0_R0
    0x0f30c4e4 0x0c000000  //DDRSS_PHY_313_DATA_F0_R0
    0x0f30c4e8 0x07ff0000  //DDRSS_PHY_314_DATA_F0_R0
    0x0f30c4ec 0x00000000  //DDRSS_PHY_315_DATA_F0_R0
    0x0f30c4f0 0x00000000  //DDRSS_PHY_316_DATA_F0_R0
    0x0f30c4f4 0x00000000  //DDRSS_PHY_317_DATA_F0_R0
    0x0f30c4f8 0x00000000  //DDRSS_PHY_318_DATA_F0_R0
    0x0f30c4fc 0x00000000  //DDRSS_PHY_319_DATA_F0_R0
    0x0f30c500 0x00000000  //DDRSS_PHY_320_DATA_F0_R0
    0x0f30c504 0x00000004  //DDRSS_PHY_321_DATA_F0_R0
    0x0f30c508 0x00000000  //DDRSS_PHY_322_DATA_F0_R0
    0x0f30c50c 0x00000000  //DDRSS_PHY_323_DATA_F0_R0
    0x0f30c510 0x00000000  //DDRSS_PHY_324_DATA_F0_R0
    0x0f30c514 0x00000000  //DDRSS_PHY_325_DATA_F0_R0
    0x0f30c518 0x00000000  //DDRSS_PHY_326_DATA_F0_R0
    0x0f30c51c 0x00000000  //DDRSS_PHY_327_DATA_F0_R0
    0x0f30c520 0x041f07ff  //DDRSS_PHY_328_DATA_F0_R0
    0x0f30c524 0x00000000  //DDRSS_PHY_329_DATA_F0_R0
    0x0f30c528 0x01ccb001  //DDRSS_PHY_330_DATA_F0_R0
    0x0f30c52c 0x2000ccb0  //DDRSS_PHY_331_DATA_F0_R0
    0x0f30c530 0x20000140  //DDRSS_PHY_332_DATA_F0_R0
    0x0f30c534 0x07ff0200  //DDRSS_PHY_333_DATA_F0_R0
    0x0f30c538 0x0000dd01  //DDRSS_PHY_334_DATA_F0_R0
    0x0f30c53c 0x10100303  //DDRSS_PHY_335_DATA_F0_R0
    0x0f30c540 0x10101010  //DDRSS_PHY_336_DATA_F0_R0
    0x0f30c544 0x10101010  //DDRSS_PHY_337_DATA_F0_R0
    0x0f30c548 0x00021010  //DDRSS_PHY_338_DATA_F0_R0
    0x0f30c54c 0x00100010  //DDRSS_PHY_339_DATA_F0_R0
    0x0f30c550 0x00100010  //DDRSS_PHY_340_DATA_F0_R0
    0x0f30c554 0x00100010  //DDRSS_PHY_341_DATA_F0_R0
    0x0f30c558 0x00100010  //DDRSS_PHY_342_DATA_F0_R0
    0x0f30c55c 0x02020010  //DDRSS_PHY_343_DATA_F0_R0
    0x0f30c560 0x51515041  //DDRSS_PHY_344_DATA_F0_R0
    0x0f30c564 0x31804000  //DDRSS_PHY_345_DATA_F0_R0
    0x0f30c568 0x04800340  //DDRSS_PHY_346_DATA_F0_R0
    0x0f30c56c 0x01008080  //DDRSS_PHY_347_DATA_F0_R0
    0x0f30c570 0x04050000  //DDRSS_PHY_348_DATA_F0_R0
    0x0f30c574 0x00000504  //DDRSS_PHY_349_DATA_F0_R0
    0x0f30c578 0x42100010  //DDRSS_PHY_350_DATA_F0_R0
    0x0f30c57c 0x010c053e  //DDRSS_PHY_351_DATA_F0_R0
    0x0f30c580 0x000f0c14  //DDRSS_PHY_352_DATA_F0_R0
    0x0f30c584 0x01000140  //DDRSS_PHY_353_DATA_F0_R0
    0x0f30c588 0x007a0120  //DDRSS_PHY_354_DATA_F0_R0
    0x0f30c58c 0x00000c00  //DDRSS_PHY_355_DATA_F0_R0
    0x0f30c590 0x000001cc  //DDRSS_PHY_356_DATA_F0_R0
    0x0f30c594 0x20100200  //DDRSS_PHY_357_DATA_F0_R0
    0x0f30c598 0x00000005  //DDRSS_PHY_358_DATA_F0_R0
    0x0f30c59c 0x21653740  //DDRSS_PHY_359_DATA_F0_R0
    0x0f30c5a0 0x00000008  //DDRSS_PHY_360_DATA_F0_R0
    0x0f30c5a4 0x02800280  //DDRSS_PHY_361_DATA_F0_R0
    0x0f30c5a8 0x02800280  //DDRSS_PHY_362_DATA_F0_R0
    0x0f30c5ac 0x02800280  //DDRSS_PHY_363_DATA_F0_R0
    0x0f30c5b0 0x02800280  //DDRSS_PHY_364_DATA_F0_R0
    0x0f30c5b4 0x00900280  //DDRSS_PHY_365_DATA_F0_R0
    0x0f30c5b8 0x0000e600  //DDRSS_PHY_366_DATA_F0_R0
    0x0f30c5bc 0x00e60000  //DDRSS_PHY_367_DATA_F0_R0
    0x0f30c5c0 0x00e60000  //DDRSS_PHY_368_DATA_F0_R0
    0x0f30c5c4 0x00e60000  //DDRSS_PHY_369_DATA_F0_R0
    0x0f30c5c8 0x00e60000  //DDRSS_PHY_370_DATA_F0_R0
    0x0f30c5cc 0x00e60000  //DDRSS_PHY_371_DATA_F0_R0
    0x0f30c5d0 0x00e60000  //DDRSS_PHY_372_DATA_F0_R0
    0x0f30c5d4 0x00e60000  //DDRSS_PHY_373_DATA_F0_R0
    0x0f30c5d8 0x00e60000  //DDRSS_PHY_374_DATA_F0_R0
    0x0f30c5dc 0x00000000  //DDRSS_PHY_375_DATA_F0_R0
    0x0f30c5e0 0x01000000  //DDRSS_PHY_376_DATA_F0_R0
    0x0f30c5e4 0x00000000  //DDRSS_PHY_377_DATA_F0_R0
    0x0f30c5e8 0x00000000  //DDRSS_PHY_378_DATA_F0_R0
    0x0f30c5ec 0x00080200  //DDRSS_PHY_379_DATA_F0_R0
    0x0f30c5f0 0x00000000  //DDRSS_PHY_380_DATA_F0_R0
    0x0f30c5f4 0x00000000  //DDRSS_PHY_381_DATA_F0_R0
    addr slice 0
    0x0f30c800 0x00000100  //DDRSS_PHY_512_DATA_F0
    0x0f30c804 0x00001000  //DDRSS_PHY_513_DATA_F0
    0x0f30c808 0x00090000  //DDRSS_PHY_514_DATA_F0
    0x0f30c80c 0x00000000  //DDRSS_PHY_515_DATA_F0
    0x0f30c810 0x00000000  //DDRSS_PHY_516_DATA_F0
    0x0f30c814 0x00000100  //DDRSS_PHY_517_DATA_F0
    0x0f30c818 0x00000000  //DDRSS_PHY_518_DATA_F0
    0x0f30c81c 0x00000000  //DDRSS_PHY_519_DATA_F0
    0x0f30c820 0x00000000  //DDRSS_PHY_520_DATA_F0
    0x0f30c824 0x00000000  //DDRSS_PHY_521_DATA_F0
    0x0f30c828 0x00000000  //DDRSS_PHY_522_DATA_F0
    0x0f30c82c 0x00000000  //DDRSS_PHY_523_DATA_F0
    0x0f30c830 0x00000000  //DDRSS_PHY_524_DATA_F0
    0x0f30c834 0x00dcba98  //DDRSS_PHY_525_DATA_F0
    0x0f30c838 0x00000000  //DDRSS_PHY_526_DATA_F0
    0x0f30c83c 0x00000000  //DDRSS_PHY_527_DATA_F0
    0x0f30c840 0x00000000  //DDRSS_PHY_528_DATA_F0
    0x0f30c844 0x00000000  //DDRSS_PHY_529_DATA_F0
    0x0f30c848 0x00000000  //DDRSS_PHY_530_DATA_F0
    0x0f30c84c 0x00000100  //DDRSS_PHY_531_DATA_F0
    0x0f30c850 0x00000000  //DDRSS_PHY_532_DATA_F0
    0x0f30c854 0x00000000  //DDRSS_PHY_533_DATA_F0
    0x0f30c858 0x00000000  //DDRSS_PHY_534_DATA_F0
    0x0f30c85c 0x00000000  //DDRSS_PHY_535_DATA_F0
    0x0f30c860 0x00000000  //DDRSS_PHY_536_DATA_F0
    0x0f30c864 0x00000000  //DDRSS_PHY_537_DATA_F0
    0x0f30c868 0x00000000  //DDRSS_PHY_538_DATA_F0
    0x0f30c86c 0x00000000  //DDRSS_PHY_539_DATA_F0
    0x0f30c870 0x0a418820  //DDRSS_PHY_540_DATA_F0
    0x0f30c874 0x103f0000  //DDRSS_PHY_541_DATA_F0
    0x0f30c878 0x000f0100  //DDRSS_PHY_542_DATA_F0
    0x0f30c87c 0x0000000f  //DDRSS_PHY_543_DATA_F0
    0x0f30c880 0x020002cc  //DDRSS_PHY_544_DATA_F0
    0x0f30c884 0x00030000  //DDRSS_PHY_545_DATA_F0
    0x0f30c888 0x00000300  //DDRSS_PHY_546_DATA_F0
    0x0f30c88c 0x00000300  //DDRSS_PHY_547_DATA_F0
    0x0f30c890 0x00000300  //DDRSS_PHY_548_DATA_F0
    0x0f30c894 0x00000300  //DDRSS_PHY_549_DATA_F0
    0x0f30c898 0x00000300  //DDRSS_PHY_550_DATA_F0
    0x0f30c89c 0x42080010  //DDRSS_PHY_551_DATA_F0
    0x0f30c8a0 0x0000003e  //DDRSS_PHY_552_DATA_F0
    0x0f30c8a4 0x00000000  //DDRSS_PHY_553_DATA_F0
    0x0f30c8a8 0x00000000  //DDRSS_PHY_554_DATA_F0
    data slice 1
    0x0f30c900 0x00000000  //DDRSS_PHY_768_DATA_F0
    0x0f30c904 0x00000000  //DDRSS_PHY_769_DATA_F0
    0x0f30c908 0x00000000  //DDRSS_PHY_770_DATA_F0
    0x0f30c90c 0x00000000  //DDRSS_PHY_771_DATA_F0
    0x0f30c910 0x00000000  //DDRSS_PHY_772_DATA_F0
    0x0f30c914 0x00000000  //DDRSS_PHY_773_DATA_F0
    0x0f30c918 0x00000000  //DDRSS_PHY_774_DATA_F0
    0x0f30c91c 0x00000000  //DDRSS_PHY_775_DATA_F0
    0x0f30c920 0x00000000  //DDRSS_PHY_776_DATA_F0
    0x0f30c924 0x00000000  //DDRSS_PHY_777_DATA_F0
    0x0f30c928 0x00000000  //DDRSS_PHY_778_DATA_F0
    0x0f30c92c 0x00000000  //DDRSS_PHY_779_DATA_F0
    0x0f30c930 0x00000000  //DDRSS_PHY_780_DATA_F0
    0x0f30c934 0x00000000  //DDRSS_PHY_781_DATA_F0
    0x0f30c938 0x00000000  //DDRSS_PHY_782_DATA_F0
    0x0f30c93c 0x00000000  //DDRSS_PHY_783_DATA_F0
    0x0f30c940 0x00000000  //DDRSS_PHY_784_DATA_F0
    0x0f30c944 0x00000000  //DDRSS_PHY_785_DATA_F0
    0x0f30c948 0x00000000  //DDRSS_PHY_786_DATA_F0
    0x0f30c94c 0x00000000  //DDRSS_PHY_787_DATA_F0
    0x0f30c950 0x00000000  //DDRSS_PHY_788_DATA_F0
    0x0f30c954 0x00000000  //DDRSS_PHY_789_DATA_F0
    0x0f30c958 0x00000000  //DDRSS_PHY_790_DATA_F0
    0x0f30c95c 0x00000000  //DDRSS_PHY_791_DATA_F0
    0x0f30c960 0x00000000  //DDRSS_PHY_792_DATA_F0
    0x0f30c964 0x00000000  //DDRSS_PHY_793_DATA_F0
    0x0f30c968 0x00000000  //DDRSS_PHY_794_DATA_F0
    0x0f30c96c 0x00000000  //DDRSS_PHY_795_DATA_F0
    0x0f30c970 0x00000000  //DDRSS_PHY_796_DATA_F0
    0x0f30c974 0x00000000  //DDRSS_PHY_797_DATA_F0
    0x0f30c978 0x00000000  //DDRSS_PHY_798_DATA_F0
    0x0f30c97c 0x00000000  //DDRSS_PHY_799_DATA_F0
    0x0f30c980 0x00000000  //DDRSS_PHY_800_DATA_F0
    0x0f30c984 0x00000000  //DDRSS_PHY_801_DATA_F0
    0x0f30c988 0x00000000  //DDRSS_PHY_802_DATA_F0
    0x0f30c98c 0x00000000  //DDRSS_PHY_803_DATA_F0
    0x0f30c990 0x00000000  //DDRSS_PHY_804_DATA_F0
    0x0f30c994 0x00000000  //DDRSS_PHY_805_DATA_F0
    0x0f30c998 0x00000000  //DDRSS_PHY_806_DATA_F0
    0x0f30c99c 0x00000000  //DDRSS_PHY_807_DATA_F0
    0x0f30c9a0 0x00000000  //DDRSS_PHY_808_DATA_F0
    0x0f30c9a4 0x00000000  //DDRSS_PHY_809_DATA_F0
    0x0f30c9a8 0x00000000  //DDRSS_PHY_810_DATA_F0
    data slice 2
    0x0f30ca00 0x00000000  //DDRSS_PHY_1024_DATA_F0
    0x0f30ca04 0x00000000  //DDRSS_PHY_1025_DATA_F0
    0x0f30ca08 0x00000000  //DDRSS_PHY_1026_DATA_F0
    0x0f30ca0c 0x00000000  //DDRSS_PHY_1027_DATA_F0
    0x0f30ca10 0x00000000  //DDRSS_PHY_1028_DATA_F0
    0x0f30ca14 0x00000000  //DDRSS_PHY_1029_DATA_F0
    0x0f30ca18 0x00000000  //DDRSS_PHY_1030_DATA_F0
    0x0f30ca1c 0x00000000  //DDRSS_PHY_1031_DATA_F0
    0x0f30ca20 0x00000000  //DDRSS_PHY_1032_DATA_F0
    0x0f30ca24 0x00000000  //DDRSS_PHY_1033_DATA_F0
    0x0f30ca28 0x00000000  //DDRSS_PHY_1034_DATA_F0
    0x0f30ca2c 0x00000000  //DDRSS_PHY_1035_DATA_F0
    0x0f30ca30 0x00000000  //DDRSS_PHY_1036_DATA_F0
    0x0f30ca34 0x00000000  //DDRSS_PHY_1037_DATA_F0
    0x0f30ca38 0x00000000  //DDRSS_PHY_1038_DATA_F0
    0x0f30ca3c 0x00000000  //DDRSS_PHY_1039_DATA_F0
    0x0f30ca40 0x00000000  //DDRSS_PHY_1040_DATA_F0
    0x0f30ca44 0x00000000  //DDRSS_PHY_1041_DATA_F0
    0x0f30ca48 0x00000000  //DDRSS_PHY_1042_DATA_F0
    0x0f30ca4c 0x00000000  //DDRSS_PHY_1043_DATA_F0
    0x0f30ca50 0x00000000  //DDRSS_PHY_1044_DATA_F0
    0x0f30ca54 0x00000000  //DDRSS_PHY_1045_DATA_F0
    0x0f30ca58 0x00000000  //DDRSS_PHY_1046_DATA_F0
    0x0f30ca5c 0x00000000  //DDRSS_PHY_1047_DATA_F0
    0x0f30ca60 0x00000000  //DDRSS_PHY_1048_DATA_F0
    0x0f30ca64 0x00000000  //DDRSS_PHY_1049_DATA_F0
    0x0f30ca68 0x00000000  //DDRSS_PHY_1050_DATA_F0
    0x0f30ca6c 0x00000000  //DDRSS_PHY_1051_DATA_F0
    0x0f30ca70 0x00000000  //DDRSS_PHY_1052_DATA_F0
    0x0f30ca74 0x00000000  //DDRSS_PHY_1053_DATA_F0
    0x0f30ca78 0x00000000  //DDRSS_PHY_1054_DATA_F0
    0x0f30ca7c 0x00000000  //DDRSS_PHY_1055_DATA_F0
    0x0f30ca80 0x00000000  //DDRSS_PHY_1056_DATA_F0
    0x0f30ca84 0x00000000  //DDRSS_PHY_1057_DATA_F0
    0x0f30ca88 0x00000000  //DDRSS_PHY_1058_DATA_F0
    0x0f30ca8c 0x00000000  //DDRSS_PHY_1059_DATA_F0
    0x0f30ca90 0x00000000  //DDRSS_PHY_1060_DATA_F0
    0x0f30ca94 0x00000000  //DDRSS_PHY_1061_DATA_F0
    0x0f30ca98 0x00000000  //DDRSS_PHY_1062_DATA_F0
    0x0f30ca9c 0x00000000  //DDRSS_PHY_1063_DATA_F0
    0x0f30caa0 0x00000000  //DDRSS_PHY_1064_DATA_F0
    0x0f30caa4 0x00000000  //DDRSS_PHY_1065_DATA_F0
    0x0f30caa8 0x00000000  //DDRSS_PHY_1066_DATA_F0
    0x0f30d400 0x00000000  //DDRSS_PHY_1280_DATA_F0
    0x0f30d404 0x00000000  //DDRSS_PHY_1281_DATA_F0
    0x0f30d408 0x00000000  //DDRSS_PHY_1282_DATA_F0
    0x0f30d40c 0x00000000  //DDRSS_PHY_1283_DATA_F0
    0x0f30d410 0x00000000  //DDRSS_PHY_1284_DATA_F0
    0x0f30d414 0x00000000  //DDRSS_PHY_1285_DATA_F0
    0x0f30d418 0x00050000  //DDRSS_PHY_1286_DATA_F0
    0x0f30d41c 0x04000100  //DDRSS_PHY_1287_DATA_F0
    0x0f30d420 0x00000055  //DDRSS_PHY_1288_DATA_F0
    0x0f30d424 0x00000000  //DDRSS_PHY_1289_DATA_F0
    0x0f30d428 0x06800000  //DDRSS_PHY_1290_DATA_F0
    0x0f30d42c 0x00000000  //DDRSS_PHY_1291_DATA_F0
    0x0f30d430 0x00000000  //DDRSS_PHY_1292_DATA_F0
    0x0f30d434 0x01002000  //DDRSS_PHY_1293_DATA_F0
    0x0f30d438 0x00004001  //DDRSS_PHY_1294_DATA_F0
    0x0f30d43c 0x00020028  //DDRSS_PHY_1295_DATA_F0
    0x0f30d440 0x00010100  //DDRSS_PHY_1296_DATA_F0
    0x0f30d444 0x00000001  //DDRSS_PHY_1297_DATA_F0
    0x0f30d448 0x00000000  //DDRSS_PHY_1298_DATA_F0
    0x0f30d44c 0x0f0f0e06  //DDRSS_PHY_1299_DATA_F0
    0x0f30d450 0x00010101  //DDRSS_PHY_1300_DATA_F0
    0x0f30d454 0x010f0004  //DDRSS_PHY_1301_DATA_F0
    0x0f30d458 0x00000000  //DDRSS_PHY_1302_DATA_F0
    0x0f30d45c 0x20125770  //DDRSS_PHY_1303_DATA_F0
    0x0f30d460 0x00000064  //DDRSS_PHY_1304_DATA_F0
    0x0f30d464 0x00000000  //DDRSS_PHY_1305_DATA_F0
    0x0f30d468 0x00000000  //DDRSS_PHY_1306_DATA_F0
    0x0f30d46c 0x01020103  //DDRSS_PHY_1307_DATA_F0
    0x0f30d470 0x03020102  //DDRSS_PHY_1308_DATA_F0
    0x0f30d474 0x03030303  //DDRSS_PHY_1309_DATA_F0
    0x0f30d478 0x03030303  //DDRSS_PHY_1310_DATA_F0
    0x0f30d47c 0x00040000  //DDRSS_PHY_1311_DATA_F0
    0x0f30d480 0x00005201  //DDRSS_PHY_1312_DATA_F0
    0x0f30d484 0x00000003  //DDRSS_PHY_1313_DATA_F0
    0x0f30d488 0x00010000  //DDRSS_PHY_1314_DATA_F0
    0x0f30d48c 0x00000000  //DDRSS_PHY_1315_DATA_F0
    0x0f30d490 0x00000003  //DDRSS_PHY_1316_DATA_F0
    0x0f30d494 0x00010000  //DDRSS_PHY_1317_DATA_F0
    0x0f30d498 0x00000000  //DDRSS_PHY_1318_DATA_F0
    0x0f30d49c 0x07070001  //DDRSS_PHY_1319_DATA_F0
    0x0f30d4a0 0x00005400  //DDRSS_PHY_1320_DATA_F0
    0x0f30d4a4 0x000040a2  //DDRSS_PHY_1321_DATA_F0
    0x0f30d4a8 0x0003784f  //DDRSS_PHY_1322_DATA_F0
    0x0f30d4ac 0x0001784f  //DDRSS_PHY_1323_DATA_F0
    0x0f30d4b0 0x0001784f  //DDRSS_PHY_1324_DATA_F0
    0x0f30d4b4 0x0001784f  //DDRSS_PHY_1325_DATA_F0
    0x0f30d4b8 0x0001784f  //DDRSS_PHY_1326_DATA_F0
    0x0f30d4bc 0x0001784f  //DDRSS_PHY_1327_DATA_F0
    0x0f30d4c0 0x0001785d  //DDRSS_PHY_1328_DATA_F0
    0x0f30d4c4 0x0001785d  //DDRSS_PHY_1329_DATA_F0
    0x0f30d4c8 0x0001784f  //DDRSS_PHY_1330_DATA_F0
    0x0f30d4cc 0x0001784f  //DDRSS_PHY_1331_DATA_F0
    0x0f30d4d0 0x00000000  //DDRSS_PHY_1332_DATA_F0
    0x0f30d4d4 0x00000046  //DDRSS_PHY_1333_DATA_F0
    0x0f30d4d8 0x00000400  //DDRSS_PHY_1334_DATA_F0
    0x0f30d4dc 0x00000008  //DDRSS_PHY_1335_DATA_F0
    0x0f30d4e0 0x0081784f  //DDRSS_PHY_1336_DATA_F0
    0x0f30d4e4 0x0081785d  //DDRSS_PHY_1337_DATA_F0
    0x0f30d4e8 0x001784f0  //DDRSS_PHY_1338_DATA_F0
    0x0f30d4ec 0x001785d8  //DDRSS_PHY_1339_DATA_F0
    0x0f30d4f0 0x00f784ff  //DDRSS_PHY_1340_DATA_F0
    0x0f30d4f4 0x03f785df  //DDRSS_PHY_1341_DATA_F0
    0x0f30d4f8 0x00000000  //DDRSS_PHY_1342_DATA_F0
    0x0f30d4fc 0x00000000  //DDRSS_PHY_1343_DATA_F0
    0x0f30d500 0xb3000000  //DDRSS_PHY_1344_DATA_F0
    0x0f30d504 0x04102006  //DDRSS_PHY_1345_DATA_F0
    0x0f30d508 0x00041020  //DDRSS_PHY_1346_DATA_F0
    0x0f30d50c 0x01c98c98  //DDRSS_PHY_1347_DATA_F0
    0x0f30d510 0x3f400000  //DDRSS_PHY_1348_DATA_F0
    0x0f30d514 0x3f3f1f3f  //DDRSS_PHY_1349_DATA_F0
    0x0f30d518 0x0000001f  //DDRSS_PHY_1350_DATA_F0
    0x0f30d51c 0x00000000  //DDRSS_PHY_1351_DATA_F0
    0x0f30d520 0x00000000  //DDRSS_PHY_1352_DATA_F0
    0x0f30d524 0x00000000  //DDRSS_PHY_1353_DATA_F0
    0x0f30d528 0x00000001  //DDRSS_PHY_1354_DATA_F0
    0x0f30d52c 0x00000000  //DDRSS_PHY_1355_DATA_F0
    0x0f30d530 0x00000000  //DDRSS_PHY_1356_DATA_F0
    0x0f30d534 0x00000000  //DDRSS_PHY_1357_DATA_F0
    0x0f30d538 0x00000000  //DDRSS_PHY_1358_DATA_F0
    0x0f30d53c 0x76543210  //DDRSS_PHY_1359_DATA_F0
    0x0f30d540 0x00000098  //DDRSS_PHY_1360_DATA_F0
    0x0f30d544 0x00000000  //DDRSS_PHY_1361_DATA_F0
    0x0f30d548 0x00000000  //DDRSS_PHY_1362_DATA_F0
    0x0f30d54c 0x00000000  //DDRSS_PHY_1363_DATA_F0
    0x0f30d550 0x00040700  //DDRSS_PHY_1364_DATA_F0
    0x0f30d554 0x00000000  //DDRSS_PHY_1365_DATA_F0
    0x0f30d558 0x00005898  //DDRSS_PHY_1366_DATA_F0
    0x0f30d55c 0x00005898  //DDRSS_PHY_1367_DATA_F0
    0x0f30d560 0x030f7102  //DDRSS_PHY_1368_DATA_F0
    0x0f30d564 0x00000100  //DDRSS_PHY_1369_DATA_F0
    0x0f30d568 0x00000000  //DDRSS_PHY_1370_DATA_F0
    0x0f30d56c 0x0001f7c2  //DDRSS_PHY_1371_DATA_F0
    0x0f30d570 0x00020002  //DDRSS_PHY_1372_DATA_F0
    0x0f30d574 0x00000000  //DDRSS_PHY_1373_DATA_F0
    0x0f30d578 0x00001142  //DDRSS_PHY_1374_DATA_F0
    0x0f30d57c 0x03020400  //DDRSS_PHY_1375_DATA_F0
    0x0f30d580 0x00000080  //DDRSS_PHY_1376_DATA_F0
    0x0f30d584 0x03900390  //DDRSS_PHY_1377_DATA_F0
    0x0f30d588 0x03900390  //DDRSS_PHY_1378_DATA_F0
    0x0f30d58c 0x03900390  //DDRSS_PHY_1379_DATA_F0
    0x0f30d590 0x03900390  //DDRSS_PHY_1380_DATA_F0
    0x0f30d594 0x03900390  //DDRSS_PHY_1381_DATA_F0
    0x0f30d598 0x03900390  //DDRSS_PHY_1382_DATA_F0
    0x0f30d59c 0x00000300  //DDRSS_PHY_1383_DATA_F0
    0x0f30d5a0 0x00000300  //DDRSS_PHY_1384_DATA_F0
    0x0f30d5a4 0x00000300  //DDRSS_PHY_1385_DATA_F0
    0x0f30d5a8 0x00000300  //DDRSS_PHY_1386_DATA_F0
    0x0f30d5ac 0x31823fc7  //DDRSS_PHY_1387_DATA_F0
    0x0f30d5b0 0x00000000  //DDRSS_PHY_1388_DATA_F0
    0x0f30d5b4 0x0c000d3f  //DDRSS_PHY_1389_DATA_F0
    0x0f30d5b8 0x30000d3f  //DDRSS_PHY_1390_DATA_F0
    0x0f30d5bc 0x300d3f11  //DDRSS_PHY_1391_DATA_F0
    0x0f30d5c0 0x01990000  //DDRSS_PHY_1392_DATA_F0
    0x0f30d5c4 0x000d3fcc  //DDRSS_PHY_1393_DATA_F0
    0x0f30d5c8 0x00000c11  //DDRSS_PHY_1394_DATA_F0
    0x0f30d5cc 0x300d3f11  //DDRSS_PHY_1395_DATA_F0
    0x0f30d5d0 0x01990000  //DDRSS_PHY_1396_DATA_F0
    0x0f30d5d4 0x300c3f11  //DDRSS_PHY_1397_DATA_F0
    0x0f30d5d8 0x01990000  //DDRSS_PHY_1398_DATA_F0
    0x0f30d5dc 0x300c3f11  //DDRSS_PHY_1399_DATA_F0
    0x0f30d5e0 0x01990000  //DDRSS_PHY_1400_DATA_F0
    0x0f30d5e4 0x300d3f11  //DDRSS_PHY_1401_DATA_F0
    0x0f30d5e8 0x01990000  //DDRSS_PHY_1402_DATA_F0
    0x0f30d5ec 0x300d3f11  //DDRSS_PHY_1403_DATA_F0
    0x0f30d5f0 0x01990000  //DDRSS_PHY_1404_DATA_F0
    0x0f30d5f4 0x20040004  //DDRSS_PHY_1405_DATA_F0
    End of DDR Register Dump
    Changed A53 CPU frequency to 1000000000Hz (S grade) in DT
    SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.7--v09.02.07 (Kool Koala)')
    k3_ddrss_probe(dev=43c349e8)
    k3_ddrss_ofdata_to_priv(dev=43c349e8)
    k3_ddrss memorycontroller@f300000: ddr freq0 not populated, using bypass frequency.
    k3_ddrss_power_on(ddrss=43c3a2c0)
    k3_ddrss memorycontroller@f300000: vtt-supply not found.
    k3_lpddr4_probe: PASS
    k3_lpddr4_init: PASS
    --->>> LPDDR4 Initialization is in progress ... <<<---
    k3_lpddr4_start: Post start PASS
    data slice 0
    0x0f30c0bc 0xbf09000d  //DDRSS_PHY_47_DATA_F0_R0
    data slice 1
    addr slice 0
    data slice 1
    data slice 2
    0x0f30d4a8 0x0003690f  //DDRSS_PHY_1322_DATA_F0
    0x0f30d4ac 0x0001690f  //DDRSS_PHY_1323_DATA_F0
    0x0f30d4b0 0x0001690f  //DDRSS_PHY_1324_DATA_F0
    0x0f30d4b4 0x0001690f  //DDRSS_PHY_1325_DATA_F0
    0x0f30d4b8 0x0001690f  //DDRSS_PHY_1326_DATA_F0
    0x0f30d4bc 0x0001690f  //DDRSS_PHY_1327_DATA_F0
    0x0f30d4c0 0x0001689d  //DDRSS_PHY_1328_DATA_F0
    0x0f30d4c4 0x0001689d  //DDRSS_PHY_1329_DATA_F0
    0x0f30d4c8 0x0001690f  //DDRSS_PHY_1330_DATA_F0
    0x0f30d4cc 0x0001690f  //DDRSS_PHY_1331_DATA_F0
    0x0f30d4e0 0x0081690f  //DDRSS_PHY_1336_DATA_F0
    0x0f30d4e4 0x0081689d  //DDRSS_PHY_1337_DATA_F0
    0x0f30d4e8 0x001690f0  //DDRSS_PHY_1338_DATA_F0
    0x0f30d4ec 0x001689d8  //DDRSS_PHY_1339_DATA_F0
    0x0f30d4f0 0x00f690ff  //DDRSS_PHY_1340_DATA_F0
    0x0f30d4f4 0x03f689df  //DDRSS_PHY_1341_DATA_F0
    0x0f308530 0x00000000  //DDRSS_CTL_332_DATA
    0x0f308534 0x00010000  //DDRSS_CTL_333_DATA
    0x0f308538 0x00000000  //DDRSS_CTL_334_DATA
    0x0f308558 0x00000000  //DDRSS_CTL_342_DATA
    data slice 0
    0x0f30c028 0x016c0000  //DDRSS_PHY_10_DATA_F0_R0
    0x0f30c034 0x00c02004  //DDRSS_PHY_13_DATA_F0_R0
    0x0f30c0bc 0x0e08000f  //DDRSS_PHY_47_DATA_F0_R0
    0x0f30c0c0 0x00000002  //DDRSS_PHY_48_DATA_F0_R0
    0x0f30c0c4 0x00000600  //DDRSS_PHY_49_DATA_F0_R0
    0x0f30c0c8 0x0018000c  //DDRSS_PHY_50_DATA_F0_R0
    0x0f30c0cc 0x00000fff  //DDRSS_PHY_51_DATA_F0_R0
    0x0f30c0d4 0x0228021c  //DDRSS_PHY_53_DATA_F0_R0
    0x0f30c0d8 0x00000030  //DDRSS_PHY_54_DATA_F0_R0
    0x0f30c0dc 0x0114003c  //DDRSS_PHY_55_DATA_F0_R0
    0x0f30c168 0x04a00340  //DDRSS_PHY_90_DATA_F0_R0
    0x0f30c1b4 0x00120280  //DDRSS_PHY_109_DATA_F0_R0
    0x0f30c1b8 0x0000a800  //DDRSS_PHY_110_DATA_F0_R0
    0x0f30c1bc 0x00a8009c  //DDRSS_PHY_111_DATA_F0_R0
    0x0f30c1c0 0x00b400a2  //DDRSS_PHY_112_DATA_F0_R0
    0x0f30c1c4 0x00a800a8  //DDRSS_PHY_113_DATA_F0_R0
    0x0f30c1c8 0x00b4009c  //DDRSS_PHY_114_DATA_F0_R0
    0x0f30c1cc 0x00a800ae  //DDRSS_PHY_115_DATA_F0_R0
    0x0f30c1d0 0x00a8009c  //DDRSS_PHY_116_DATA_F0_R0
    0x0f30c1d4 0x00a800a8  //DDRSS_PHY_117_DATA_F0_R0
    0x0f30c1d8 0x00a8009c  //DDRSS_PHY_118_DATA_F0_R0
    0x0f30c1dc 0x0122009c  //DDRSS_PHY_119_DATA_F0_R0
    data slice 1
    0x0f30c428 0x016c0000  //DDRSS_PHY_266_DATA_F0_R0
    0x0f30c434 0x00c02804  //DDRSS_PHY_269_DATA_F0_R0
    0x0f30c4bc 0x0608000f  //DDRSS_PHY_303_DATA_F0_R0
    0x0f30c4c4 0x00000200  //DDRSS_PHY_305_DATA_F0_R0
    0x0f30c4c8 0x000c0000  //DDRSS_PHY_306_DATA_F0_R0
    0x0f30c4cc 0x00000fff  //DDRSS_PHY_307_DATA_F0_R0
    0x0f30c4d4 0x0228021c  //DDRSS_PHY_309_DATA_F0_R0
    0x0f30c4d8 0x00000030  //DDRSS_PHY_310_DATA_F0_R0
    0x0f30c4dc 0x0114003c  //DDRSS_PHY_311_DATA_F0_R0
    0x0f30c568 0x04a80340  //DDRSS_PHY_346_DATA_F0_R0
    0x0f30c5b4 0x00060280  //DDRSS_PHY_365_DATA_F0_R0
    0x0f30c5b8 0x0000a800  //DDRSS_PHY_366_DATA_F0_R0
    0x0f30c5bc 0x00a800a2  //DDRSS_PHY_367_DATA_F0_R0
    0x0f30c5c0 0x00a800a2  //DDRSS_PHY_368_DATA_F0_R0
    0x0f30c5c4 0x00a800a2  //DDRSS_PHY_369_DATA_F0_R0
    0x0f30c5c8 0x00b400a2  //DDRSS_PHY_370_DATA_F0_R0
    0x0f30c5cc 0x00a800ae  //DDRSS_PHY_371_DATA_F0_R0
    0x0f30c5d0 0x00ae00a2  //DDRSS_PHY_372_DATA_F0_R0
    0x0f30c5d4 0x00ae00a8  //DDRSS_PHY_373_DATA_F0_R0
    0x0f30c5d8 0x00a800a8  //DDRSS_PHY_374_DATA_F0_R0
    0x0f30c5dc 0x012200a2  //DDRSS_PHY_375_DATA_F0_R0
    addr slice 0
    0x0f30c808 0x00080000  //DDRSS_PHY_514_DATA_F0
    data slice 1
    data slice 2
    0x0f30d4a8 0x0003488f  //DDRSS_PHY_1322_DATA_F0
    0x0f30d4ac 0x0001488f  //DDRSS_PHY_1323_DATA_F0
    0x0f30d4b0 0x0001488f  //DDRSS_PHY_1324_DATA_F0
    0x0f30d4b4 0x0001488f  //DDRSS_PHY_1325_DATA_F0
    0x0f30d4b8 0x0001480e  //DDRSS_PHY_1326_DATA_F0
    0x0f30d4bc 0x0001488f  //DDRSS_PHY_1327_DATA_F0
    0x0f30d4c0 0x0001489d  //DDRSS_PHY_1328_DATA_F0
    0x0f30d4c4 0x0001489d  //DDRSS_PHY_1329_DATA_F0
    0x0f30d4c8 0x0001488f  //DDRSS_PHY_1330_DATA_F0
    0x0f30d4cc 0x0001488f  //DDRSS_PHY_1331_DATA_F0
    0x0f30d4e0 0x0081488f  //DDRSS_PHY_1336_DATA_F0
    0x0f30d4e4 0x0081489d  //DDRSS_PHY_1337_DATA_F0
    0x0f30d4e8 0x001488f0  //DDRSS_PHY_1338_DATA_F0
    0x0f30d4ec 0x001489d8  //DDRSS_PHY_1339_DATA_F0
    0x0f30d4f0 0x00f488ff  //DDRSS_PHY_1340_DATA_F0
    0x0f30d4f4 0x03f489df  //DDRSS_PHY_1341_DATA_F0
    0x0f30d558 0x00000000  //DDRSS_PHY_1366_DATA_F0
    0x0f30d55c 0x00000000  //DDRSS_PHY_1367_DATA_F0
    SPL initial stack usage: 13424 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.12.0(release):11.00.15
    NOTICE:  BL31: Built : 11:59:27, Dec 11 2025
    U-Boot SPL 2025.01 (Jan 07 2026 - 11:18:14 +0100)
    SPL initial stack usage: 1824 bytes
    Error (-2): cannot determine file size
    U-Boot 2025.01 (Jan 07 2026 - 11:18:14 +0100)
    SoC:   AM62X SR1.0 HS-FS
    Model: Etic Telecom TDT7COM board
    DRAM:  1 GiB
    Core:  82 devices, 25 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1, mmc@fa20000: 2
    Loading Environment from MMC... *** Warning - bad CRC, using default environment
    thank for your help,
    Thomas
  • Both failing regdumps are failing write leveling, which is the first training step.  I still think something fundamental is wrong with these boards.  Since one of them doesn't even produce a proper CKE, there may be an issue with the processor, possibly power issue.
    On the board that doesn't produce a rising CKE, does the RESET signal look correct?
    On the board that produces a rising CKE, does it go high and stay high until the log gets stuck, and does it remain high after failure?  What is the RESET doing on this board during this time?
    What is powering the rails on this board?  PMIC or discrete?
    Just to understand context, how many boards in total are working?  How many have CKE but fail?  How many produce no CKE?
    Is it possible to send schematic?  If we need to correspond over email, i can send you that privately.
    James
  • 6 boards out of 18 have the DDR init issue. We already changed the processor on 4 of them:
        - 3 have been repared with this rework
        - 1 is still failing. This board has a CKE ok.
    -> we don't kown the previsous state of the CKE on thos board as we thought they all had the same issue...
    So now we have 3 boards left with ddr init failure:
        - 2 with CKE ok (including the board with the processor already changed)
        - 1 with CKE not rising
    Powering is done with a PMIC (TPS6521903). I can send you the schematic by email if you send me you address.
    We will investigate the CKE / Reset / UART logs on the boards as you asked.
    Thank you,
    regards,
    Thomas
  • Thanks, i sent you an email
    Ultimately, the processor should initially drive CKE and RESET, so you should see those at appropriate levels at the beginning.  Then it will initiate initialization and training.  Another signal you should have access to is DDR clock, may want to check that as well.  You might be able to also access data, DQS or addr with a via.
    The board that doesn't show CKE rising, that is most likely a power issue on the processor (ie, one of the DDR voltage rails is not getting proper power, balls shorted or not connected to board, etc.).  I know you check a few previously, here is the full list:
    Processor Voltage Rails:
    • VDDS_DDR = VDDS_DDR_C = 1.2V
    • VDDA_PLL0 = 1.8V (AM62x)
    • VDDA_DDR_PLL0 = VDD_CORE = 0.75 or 0.85V (AM62 AMC package only)
    Memory voltage rails:
    • VTT = 0.6V
    • DDR_VREFCA = 0.6V
    • DDR_VPP = 2.5V
    James
  • We checked the reset CKE and power rails on 2 boards (one with CKE and the other not showing CKE) during all init process (see UART_TX line). What it shows is when CKE is present the init fails more rapidely (~15ms, see first image below) than with the board not showing CKE (~150ms, see second image below).
    All power rails looks ok. We don't have VTT rail as the board implemented a single DDR package.
    The 800Mhz DDR clock looks ok on 2 boards.
    I send the schematic by mail
    We will investigate a data or addr line.
    Thomas
  • Hi Thomas, i received the schematic.  The only thing i would mention is to change the DDR_RESET pull down to 10K.  We previously had 2.2K on our EVMs, but noticed this was drooping the RESET level close to Vih threshold with some silicon.  The 10K is a weaker pull which will help with the RESET voltage level.  Also, be sure to remove the pull down on CKE.  Both of these, however, probably are not the reason for the failures you are seeing.
    After RESET and CKE go high, you should see activity for the first training step which is Write Leveling.  During this training step, DQS is shifted to align it with CLK.  So the processor will output DQS, and the feedback is sent by the memory on the DQ signals (all the DQs are ORed together in this stage, so they should all be at the same level).  You should find a diagram of this in the DDR datasheet.
    If you see DQS toggling, but not DQ, there's a good chance there is something wrong with the memory, since you don't see any responses from it.  If you never see DQS, then maybe it could be a board issue (DQS inadvertently shorted) or the processor is not progressing through the training process properly.
    With these experiments, we should be able to narrow down which side of the interface is the culprit.
    James
  • Hi James,
    we measured DQS and DQ0 on several boards to see if the 0 to 1 transition on DQ during write-leveling occurs:
    - on board 002 which is a normal board we see multiple transitions... we don't know how to interpret, but the board is working
    - on board 006 which is a board with CKE but no DDR init we see DQS toggling but don't see any DQ transitions:
    - on board 008 which is a board with CKE but no DDR init we  see DQS toggling, a 0 to 1 transition:
    as there is a 0 to 1 transition on 008 board we conclude that write leveling was ok, even if the sequence is quite different... we have also seen some strange DQ waveforms on other screenshots(after write leveling) but we cannot interpret, looks like a capacitor charging :
    An other observation on all board is that DQ signals seems to be at logical 0 at 400mV offset except board 0008 which is only 100mV...
    to conclude we think that
    - DDR controller is fine on board with CKE ok (board 006 and 008) but DRAM chip is failing for different and unknown reasons
    - DDR controller is failing on board which is not showing CKE.
    what do you think ?
    thanks for your help
  • Thanks,
    yes, board 002 there is certainly something wrong with the DDR, either it is not assembled correctly, or the device is bad.  May need to swap out with a different device to revive that one.
    Board 008 is interesting.  Not sure why the pattern looks different than the working board.
    On all scope shots, it seems like there is contention going on with DQ.  It should swing rail to rail during write leveling, i don't understand why its low point is around 400mV
    The last slide is show an untermintated DQS signal (not sure it is a read or write).  DQ is unrecognizable.  If you probed near the memory, i may be a read due to all the ringing, which means the DDR is not driving DQ properly.
    May want to replace the DDR on those boards.
    The board not showing CKE is an issue with the processor.  If the RESET looks good, then this indicates the IO voltage and power is fine.  Then i would think there is still some assembly issue, maybe solder bridge or solder flow not providing good connection to board.
    Maybe some ABA swaps of devices on working/non-working boards will determine issues with either components or boards(assembly)
    James
