AM5718: AM5718 and AM5748 spurious EMMC errors after boot
Part Number: AM5718
Other Parts Discussed in Thread: DRA722
We have examples of both the AM5718 and 5748 boards which occasionally experience SDHCI failures on mmc1 which corresponds to device tree overlay &mmc2.  Note that we boot all the way into the login prompt before these errors occur, and in some cases they are on reboot before halting.
We are using an EMMC chip MTFC32GAZAQHD and running a 5.10 kernel, I have tried the following:
Disable BKOPS entirely
Disable EMMC caching
Limiting to SD HS mode via no-1-8-v
Reduce the bus width to 1
Applying IRQ locking patches from the upstream v6.2-rc4...601363cc08da25747feb87c55573dd54de91d66a (https://lore.kernel.org/linux-arm-kernel/20230308144105.di552lbogqv2s7fk@mraw.org/#r)
Here are the device tree overlays we have:
&mmc1 {
    pinctrl-names = "default", "hs";
    pinctrl-0 = <&mmc1_pins_default>;
    pinctrl-1 = <&mmc1_pins_hs>;
    vmmc-supply = <&ldo1_reg>;
    /delete-property/ sd-uhs-sdr104;
    /delete-property/ sd-uhs-sdr50;
    /delete-property/ sd-uhs-ddr50;
    /delete-property/ sd-uhs-sdr25;
    /delete-property/ sd-uhs-sdr12;
    /delete-property/ async-probe;
    bus-width = <4>;
    cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */};
&mmc2 {
    pinctrl-names = "default", "hs", "ddr_1_8v";
    pinctrl-0 = <&mmc2_pins_default>;
    pinctrl-1 = <&mmc2_pins_hs>;
    pinctrl-2 = <&mmc2_pins_ddr_3_3v_rev11 &mmc2_iodelay_ddr_3_3v_rev11_conf>;
    vmmc-supply = <&vdd_3v3>;
    bus-width = <1>;
    ti,non-removable;
    cap-mmc-dual-data-rate;
    no-1-8-v;
   /delete-property/ mmc-hs200-1_8v;
This still occurs periodically. What other problems might be occuring here?
Note that I added a bit of extra logging to the kernel, including a stack trace at the watchdog error. The watchdog error is our biggest lead right now but I haven't tracked that down yet. It occurs only spuriously and does not correspond 100% to the SDHCI error
Stopping Session c2 of user root.
[  OK  ] Removed slice system-getty.slice.
[  OK  ] Removed slice system-sshd.slice.
[  OK  ] Stopped target Network (Pre).
[  OK  ] Stopped target Host and Network Name Lookups.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Stopped target Hardware activated USB gadget.
         Stopping Load/Save Random Seed...
         Stopping Network Name Resolution...
         Stopping weston - Running aGTX...
[  OK  ] Stopped OpenSSH Key Generation.
[  OK  ] Stopped Network Name Resolution.
[  OK  ] Stopped Serial Getty on ttyS0.
[  OK  ] Stopped weston - Running as GTX.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Session c1 of user gtx.
[  OK  ] Stopped Session c2 of user root.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Stopped target Graphical Interface.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
         Stopping Launch GTX application service...
[  OK  ] Stopped IPv6 Packet Filtering Framework.
[  OK  ] Stopped IPv4 Packet Filtering Framework.
         Stopping Login Service...
         Stopping thermal-zone-init.service...
         Stopping User Manager for UID 0...
         Stopping User Manager for UID 1000...
[  OK  ] Stopped thermal-zone-init.service.
         Stopping sshd.service...
[  OK  ] Stopped Login Service.
[  OK  ] Stopped User Manager for UID 1000.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped sshd.service.
[  OK  ] Stopped Launch GTX application service.
[  OK  ] Stopped mount service.
         Stopping detect model service...
         Stopping rc.pvr.service...
         Stopping User Runtime Directory /run/user/0...
         Stopping User Runtime Directory /run/user/1000...
[  OK  ] Unmounted /run/user/0.
[  OK  ] Unmounted /run/user/1000.
[  OK  ] Stopped detect model service.
[  OK  ] Stopped rc.pvr.service.
[  OK  ] Stopped User Runtime Directory /run/user/0.
[  OK  ] Stopped User Runtime Directory /run/user/1000.
[  OK  ] Removed slice User Slice of UID 0.
[  OK  ] Removed slice User Slice of UID 1000.
         Stopping D-Bus System Message Bus...
         Stopping Permit User Sessions...
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /media/ram...
         Unmounting /mnt/software...
         Unmounting /mnt/storage...
         Unmounting Temporary Directory (/tmp)...
         Unmounting /var/volatile...
[  OK  ] Unmounted /media/ram.
[  OK  ] Unmounted /mnt/software.
[  OK  ] Unmounted /mnt/storage.
[  OK  ] Unmounted Temporary Directory (/tmp).
[  OK  ] Unmounted /var/volatile.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped target Swap.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
[  OK  ] Started Reboot.
[  OK  ] Reached target Reboot.
[  358.388580] watchdog: watchdog0: watchdog did not stop!!
[  358.394042] CPU: 0 PID: 1 Comm: systemd Tainted: G           O      5.10.168-1-ctx #77
[  358.402099] Hardware name: Generic DRA74X (Flattened Device Tree)
[  358.408294] [<c020eac4>] (unwind_backtrace) from [<c0209d44>] (show_stack+0x10/0x14)
[  358.416198] [<c0209d44>] (show_stack) from [<c0c258c0>] (dump_stack+0x94/0xa8)
[  358.423522] [<c0c258c0>] (dump_stack) from [<c09b58f4>] (watchdog_release+0x160/0x18c)
[  358.431579] [<c09b58f4>] (watchdog_release) from [<c036b45c>] (__fput+0x78/0x234)
[  358.439208] [<c036b45c>] (__fput) from [<c0248b48>] (task_work_run+0x90/0xbc)
[  358.446472] [<c0248b48>] (task_work_run) from [<c0209a6c>] (do_work_pending+0x54c/0x554)
[  358.454681] [<c0209a6c>] (do_work_pending) from [<c02000c4>] (slow_work_pending+0xc/0x20)
[  358.463012] Exception stack(0xc1897fb0 to 0xc1897ff8)
[  358.468139] 7fa0:                                     00000000 b6f7d0a4 00000000 00000000
[  358.476440] 7fc0: 00000004 b6f7d5a0 00000000 00000006 055d4a80 00000000 000ac1b8 00112240
[  358.484771] 7fe0: 00000006 bec11ba0 b6cc0ef5 b6c41ae6 80000030 00000004
[  358.516601] systemd-shutdown[1]: Syncing filesystems and block devices.
[  358.530181] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[  358.544158] systemd-journald[146]: Received SIGTERM from PID 1 (systemd-shutdow).
[  358.571014] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[  358.583618] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[  358.593872] systemd-shutdown[1]: Unmounting file systems.
[  358.602172] [1044]: Remounting '/' read-only in with options '(null)'.
[  358.621887] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[  358.630187] systemd-shutdown[1]: All filesystems unmounted.
[  358.635955] systemd-shutdown[1]: Deactivating swaps.
[  358.642486] systemd-shutdown[1]: All swaps deactivated.
[  358.648101] systemd-shutdown[1]: Detaching loop devices.
[  358.657592] systemd-shutdown[1]: All loop devices detached.
[  358.663391] systemd-shutdown[1]: Detaching DM devices.
[  358.669036] systemd-shutdown[1]: All DM devices detached.
[  358.674560] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[  358.698669] systemd-shutdown[1]: Syncing filesystems and block devices.
[  358.708801] systemd-shutdown[1]: Rebooting.
[  358.717834] mmc1: ===== EMMC EXT_CSD INFO =====
[  358.724029] mmc1: CACHE_CTRL [33]: 0x03 00
[  358.729858] mmc1: BKOPS_STATUS [246]: 0x00 00
[  358.735870] mmc1: BKOPS_EN [163]: 0x00 00 00
[  358.741821] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00 01
[  358.748748] mmc1: EXCEPTION_STATUS [54]: 0x01 00
[  358.754974] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000 [ 0x39473030 54513936 ]
[  358.765533] mmc1: NOTE 0 calling suspend
[  358.771057] mmc1: ===== EMMC EXT_CSD INFO =====
[  358.777130] mmc1: CACHE_CTRL [33]: 0x03 00
[  358.782775] mmc1: BKOPS_STATUS [246]: 0x00 00
[  358.788604] mmc1: BKOPS_EN [163]: 0x00 00 00
[  358.794281] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00 01
[  358.801055] mmc1: EXCEPTION_STATUS [54]: 0x01 00
[  358.807159] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000 [ 0x39473030 54513936 ]
[  358.824066] mmc1: 0 err = mmc_poweroff_notify(host->card, notify_type)
[  358.832092] mmc1: 0 mmc_power_off
[  358.838134] mmc1: 0 OUT mmc_release_host
[  369.137695] mmc1: Timeout waiting for hardware cmd interrupt.
[  369.144866] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  369.152709] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  369.160583] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  369.168457] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  369.176300] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  369.184173] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  369.192047] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  369.199890] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  369.207702] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  369.215515] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  369.223297] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  369.231079] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  369.238861] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  369.246643] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  369.254394] mmc1: sdhci: Host ctl2: 0x00000000
[  369.260101] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  369.267852] Present State: 0x01f00000
[  369.272766]   DAT Line Active: NO
[  369.277282]   Write Transfer: IDLE
[  369.281890]   Read Transfer: IDLE
[  369.286376]   DAT[3:0] Line Signal Level: 0xf
[  369.291931] mmc1: ===== EMMC EXT_CSD INFO =====
[  369.297698] mmc1: CACHE_CTRL [33]: 0x03
[  369.302734] mmc1: BKOPS_STATUS [246]: 0x00
[  369.308013] mmc1: BKOPS_EN [163]: 0x00
[  369.312896] mmc1: EXCEPTION_STATUS [54]: 0x01
[  369.318359] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  369.324523] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  369.332275] mmc1: sdhci: ============================================
[  369.440155] mmc1: Reset 0x2 never completed.
[  369.445556] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  369.453155] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  369.460754] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  369.468383] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  369.475982] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  369.483581] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  369.491210] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  369.498809] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  369.506439] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  369.514038] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  369.521636] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  369.529266] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  369.536865] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  369.544494] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  369.552093] mmc1: sdhci: Host ctl2: 0x00000000
[  369.557678] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  369.565246] Present State: 0x01f00000
[  369.570037]   DAT Line Active: NO
[  369.574493]   Write Transfer: IDLE
[  369.579010]   Read Transfer: IDLE
[  369.583435]   DAT[3:0] Line Signal Level: 0xf
[  369.588897] mmc1: ===== EMMC EXT_CSD INFO =====
[  369.594573] mmc1: CACHE_CTRL [33]: 0x03
[  369.599548] mmc1: BKOPS_STATUS [246]: 0x00
[  369.604766] mmc1: BKOPS_EN [163]: 0x00
[  369.609649] mmc1: EXCEPTION_STATUS [54]: 0x01
[  369.615112] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  369.621307] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  369.629089] mmc1: sdhci: ============================================
[  369.736663] mmc1: Reset 0x4 never completed.
[  369.742034] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  369.749633] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  369.757263] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  369.764862] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  369.772491] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  369.780120] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  369.787719] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  369.795349] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  369.802947] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  369.810546] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  369.818145] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  369.825744] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  369.833374] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  369.841003] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  369.848602] mmc1: sdhci: Host ctl2: 0x00000000
[  369.854156] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  369.861755] Present State: 0x01f00000
[  369.866546]   DAT Line Active: NO
[  369.870971]   Write Transfer: IDLE
[  369.875488]   Read Transfer: IDLE
[  369.879913]   DAT[3:0] Line Signal Level: 0xf
[  369.885375] mmc1: ===== EMMC EXT_CSD INFO =====
[  369.891052] mmc1: CACHE_CTRL [33]: 0x03
[  369.896026] mmc1: BKOPS_STATUS [246]: 0x00
[  369.901245] mmc1: BKOPS_EN [163]: 0x00
[  369.906127] mmc1: EXCEPTION_STATUS [54]: 0x01
[  369.911621] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  369.917785] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  369.925537] mmc1: sdhci: ============================================
[  380.017669] mmc1: Timeout waiting for hardware cmd interrupt.
[  380.024566] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  380.032165] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  380.039794] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  380.047424] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  380.055023] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  380.062652] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  380.070251] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  380.077880] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  380.085479] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  380.093109] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  380.100708] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  380.108306] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  380.115936] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  380.123565] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  380.131164] mmc1: sdhci: Host ctl2: 0x00000000
[  380.136749] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  380.144317] Present State: 0x01f00000
[  380.149108]   DAT Line Active: NO
[  380.153533]   Write Transfer: IDLE
[  380.158081]   Read Transfer: IDLE
[  380.162506]   DAT[3:0] Line Signal Level: 0xf
[  380.167999] mmc1: ===== EMMC EXT_CSD INFO =====
[  380.173675] mmc1: CACHE_CTRL [33]: 0x03
[  380.178619] mmc1: BKOPS_STATUS [246]: 0x00
[  380.183868] mmc1: BKOPS_EN [163]: 0x00
[  380.188751] mmc1: EXCEPTION_STATUS [54]: 0x01
[  380.194244] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  380.200439] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  380.208190] mmc1: sdhci: ============================================
[  380.315826] mmc1: Reset 0x2 never completed.
[  380.321197] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  380.328796] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  380.336395] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  380.344024] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  380.351654] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  380.359252] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  380.366882] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  380.374481] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  380.382110] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  380.389709] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  380.397308] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  380.404907] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  380.412536] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  380.420135] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  380.427734] mmc1: sdhci: Host ctl2: 0x00000000
[  380.433319] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  380.440917] Present State: 0x01f00000
[  380.445678]   DAT Line Active: NO
[  380.450134]   Write Transfer: IDLE
[  380.454650]   Read Transfer: IDLE
[  380.459075]   DAT[3:0] Line Signal Level: 0xf
[  380.464569] mmc1: ===== EMMC EXT_CSD INFO =====
[  380.470214] mmc1: CACHE_CTRL [33]: 0x03
[  380.475189] mmc1: BKOPS_STATUS [246]: 0x00
[  380.480407] mmc1: BKOPS_EN [163]: 0x00
[  380.485290] mmc1: EXCEPTION_STATUS [54]: 0x01
[  380.490783] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  380.496978] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  380.504730] mmc1: sdhci: ============================================
[  380.612304] mmc1: Reset 0x4 never completed.
[  380.617675] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  380.625274] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  380.632904] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  380.640502] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  380.648132] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  380.655731] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  380.663360] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  380.670959] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  380.678558] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  380.686157] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  380.693786] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  380.701385] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  380.709014] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  380.716644] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  380.724243] mmc1: sdhci: Host ctl2: 0x00000000
[  380.729797] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  380.737365] Present State: 0x01f00000
[  380.742156]   DAT Line Active: NO
[  380.746582]   Write Transfer: IDLE
[  380.751129]   Read Transfer: IDLE
[  380.755554]   DAT[3:0] Line Signal Level: 0xf
[  380.761016] mmc1: ===== EMMC EXT_CSD INFO =====
[  380.766693] mmc1: CACHE_CTRL [33]: 0x03
[  380.771667] mmc1: BKOPS_STATUS [246]: 0x00
[  380.776885] mmc1: BKOPS_EN [163]: 0x00
[  380.781768] mmc1: EXCEPTION_STATUS [54]: 0x01
[  380.787231] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  380.793426] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  380.801177] mmc1: sdhci: ============================================
[  390.897705] mmc1: Timeout waiting for hardware cmd interrupt.
[  390.904602] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  390.912200] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  390.919830] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  390.927429] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  390.935058] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  390.942657] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  390.950286] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  390.957916] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  390.965484] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  390.973114] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  390.980712] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  390.988311] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  390.995941] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  391.003570] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  391.011169] mmc1: sdhci: Host ctl2: 0x00000000
[  391.016754] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  391.024322] Present State: 0x01f00000
[  391.029113]   DAT Line Active: NO
[  391.033569]   Write Transfer: IDLE
[  391.038085]   Read Transfer: IDLE
[  391.042541]   DAT[3:0] Line Signal Level: 0xf
[  391.048004] mmc1: ===== EMMC EXT_CSD INFO =====
[  391.053680] mmc1: CACHE_CTRL [33]: 0x03
[  391.058654] mmc1: BKOPS_STATUS [246]: 0x00
[  391.063873] mmc1: BKOPS_EN [163]: 0x00
[  391.068756] mmc1: EXCEPTION_STATUS [54]: 0x01
[  391.074249] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  391.080413] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  391.088195] mmc1: sdhci: ============================================
[  391.196044] mmc1: Reset 0x2 never completed.
[  391.201446] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  391.209045] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  391.216644] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  391.224273] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  391.231872] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  391.239501] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  391.247100] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  391.254730] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  391.262329] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  391.269927] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  391.277557] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  391.285156] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  391.292785] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  391.300415] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  391.308013] mmc1: sdhci: Host ctl2: 0x00000000
[  391.313568] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  391.321166] Present State: 0x01f00000
[  391.325958]   DAT Line Active: NO
[  391.330383]   Write Transfer: IDLE
[  391.334930]   Read Transfer: IDLE
[  391.339355]   DAT[3:0] Line Signal Level: 0xf
[  391.344848] mmc1: ===== EMMC EXT_CSD INFO =====
[  391.350494] mmc1: CACHE_CTRL [33]: 0x03
[  391.355468] mmc1: BKOPS_STATUS [246]: 0x00
[  391.360717] mmc1: BKOPS_EN [163]: 0x00
[  391.365570] mmc1: EXCEPTION_STATUS [54]: 0x01
[  391.371063] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  391.377227] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  391.385009] mmc1: sdhci: ============================================
[  391.492584] mmc1: Reset 0x4 never completed.
[  391.497955] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  391.505554] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  391.513153] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  391.520782] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  391.528381] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  391.536010] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  391.543609] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  391.551239] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  391.558837] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  391.566436] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  391.574066] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  391.581634] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  391.589263] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  391.596893] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  391.604492] mmc1: sdhci: Host ctl2: 0x00000000
[  391.610046] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  391.617645] Present State: 0x01f00000
[  391.622406]   DAT Line Active: NO
[  391.626861]   Write Transfer: IDLE
[  391.631378]   Read Transfer: IDLE
[  391.635803]   DAT[3:0] Line Signal Level: 0xf
[  391.641296] mmc1: ===== EMMC EXT_CSD INFO =====
[  391.646972] mmc1: CACHE_CTRL [33]: 0x03
[  391.651916] mmc1: BKOPS_STATUS [246]: 0x00
[  391.657165] mmc1: BKOPS_EN [163]: 0x00
[  391.662048] mmc1: EXCEPTION_STATUS [54]: 0x01
[  391.667541] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  391.673706] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  391.681457] mmc1: sdhci: ============================================
[  401.777709] mmc1: Timeout waiting for hardware cmd interrupt.
[  401.784606] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  401.792205] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  401.799804] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  401.807434] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  401.815063] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  401.822662] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  401.830291] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  401.837921] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  401.845520] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  401.853118] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  401.860717] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  401.868347] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  401.875946] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  401.883575] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  401.891174] mmc1: sdhci: Host ctl2: 0x00000000
[  401.896759] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  401.904327] Present State: 0x01f00000
[  401.909118]   DAT Line Active: NO
[  401.913574]   Write Transfer: IDLE
[  401.918090]   Read Transfer: IDLE
[  401.922515]   DAT[3:0] Line Signal Level: 0xf
[  401.928009] mmc1: ===== EMMC EXT_CSD INFO =====
[  401.933685] mmc1: CACHE_CTRL [33]: 0x03
[  401.938659] mmc1: BKOPS_STATUS [246]: 0x00
[  401.943878] mmc1: BKOPS_EN [163]: 0x00
[  401.948760] mmc1: EXCEPTION_STATUS [54]: 0x01
[  401.954254] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  401.960418] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  401.968200] mmc1: sdhci: ============================================
[  402.076110] mmc1: Reset 0x2 never completed.
[  402.081512] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  402.089080] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  402.096710] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  402.104309] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  402.111938] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  402.119537] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  402.127166] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  402.134796] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  402.142395] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  402.149993] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  402.157592] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  402.165222] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  402.172821] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  402.180480] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  402.188079] mmc1: sdhci: Host ctl2: 0x00000000
[  402.193634] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  402.201202] Present State: 0x01f00000
[  402.205993]   DAT Line Active: NO
[  402.210449]   Write Transfer: IDLE
[  402.214965]   Read Transfer: IDLE
[  402.219390]   DAT[3:0] Line Signal Level: 0xf
[  402.224884] mmc1: ===== EMMC EXT_CSD INFO =====
[  402.230529] mmc1: CACHE_CTRL [33]: 0x03
[  402.235504] mmc1: BKOPS_STATUS [246]: 0x00
[  402.240753] mmc1: BKOPS_EN [163]: 0x00
[  402.245605] mmc1: EXCEPTION_STATUS [54]: 0x01
[  402.251098] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  402.257293] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  402.265045] mmc1: sdhci: ============================================
[  402.372650] mmc1: Reset 0x4 never completed.
[  402.378021] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  402.385620] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  402.393218] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  402.400848] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  402.408447] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  402.416076] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  402.423675] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  402.431304] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  402.438903] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  402.446533] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  402.454132] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  402.461730] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  402.469360] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  402.476959] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  402.484558] mmc1: sdhci: Host ctl2: 0x00000000
[  402.490142] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  402.497711] Present State: 0x01f00000
[  402.502502]   DAT Line Active: NO
[  402.506958]   Write Transfer: IDLE
[  402.511474]   Read Transfer: IDLE
[  402.515899]   DAT[3:0] Line Signal Level: 0xf
[  402.521392] mmc1: ===== EMMC EXT_CSD INFO =====
[  402.527069] mmc1: CACHE_CTRL [33]: 0x03
[  402.532012] mmc1: BKOPS_STATUS [246]: 0x00
[  402.537261] mmc1: BKOPS_EN [163]: 0x00
[  402.542114] mmc1: EXCEPTION_STATUS [54]: 0x01
[  402.547607] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  402.553802] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  402.561553] mmc1: sdhci: ============================================
[  402.569763] mmc1: card 0001 removed
# cat /sys/kernel/debug/mmc1/ios
clock:          52000000 Hz
vdd:            21 (3.3 ~ 3.4 V)
bus mode:       2 (push-pull)
chip select:    0 (don't care)
power mode:     2 (on)
bus width:      3 (8 bits)
timing spec:    1 (mmc high-speed)
signal voltage: 0 (3.30 V)
driver type:    0 (driver type B)\
The errata i887 is taken into account as the frequency is less than 64 MHz. I'll try decreasing the frequency even more to 25MHz now and update tomorrow as this is spurious so it will take some time to determine if this is the fix.
Decompiled device tree portions relevant to MMC:
ocp {
        interconnect@4a000000 {
            compatible = "ti,dra7-l4-cfg\0simple-bus";
            reg = <0x4a000000 0x800 0x4a000800 0x800 0x4a001000 0x1000>;
            reg-names = "ap\0la\0ia0";
            #address-cells = <0x01>;
            #size-cells = <0x01>;
            ranges = <0x00 0x4a000000 0x100000 0x100000 0x4a100000 0x100000 0x200000 0x4a200000 0x100000>;
            segment@0 {
                compatible = "simple-bus";
                ranges = <0x00 0x00 0x800 0x800 0x800 0x800 0x1000 0x1000 0x1000 0x2000 0x2000 0x2000 0x4000 0x4000 0x1000 0x5000 0x5000 0x1000 0x6000 0x6000 0x1000 0x8000 0x8000 0x2000 0xa000 0xa000 0x1000 0x56000 0x56000 0x1000 0x57000 0x57000 0x1000 0x5e000 0x5e000 0x2000 0x60000 0x60000 0x1000 0x80000 0x80000 0x8000 0x88000 0x88000 0x1000 0xa0000 0xa0000 0x8000 0xa8000 0xa8000 0x1000 0xd9000 0xd9000 0x1000 0xda000 0xda000 0x1000 0xdd000 0xdd000 0x1000 0xde000 0xde000 0x1000 0xe0000 0xe0000 0x1000 0xe1000 0xe1000 0x1000 0xf4000 0xf4000 0x1000 0xf5000 0xf5000 0x1000 0xf6000 0xf6000 0x1000 0xf7000 0xf7000 0x1000 0x90000 0x90000 0x8000 0x98000 0x98000 0x1000>;
                target-module@2000 {
                    compatible = "ti,sysc-omap4\0ti,sysc";
                    reg = <0x2000 0x04>;
                    reg-names = "rev";
                    ranges = <0x00 0x2000 0x2000>;
                    scm@0 {
                        compatible = "ti,dra7-scm-core\0simple-bus";
                        reg = <0x00 0x2000>;
                        ranges = <0x00 0x00 0x2000>;
                        scm_conf@0 {
                            compatible = "syscon\0simple-bus";
                            reg = <0x00 0x1400>;
                            ranges = <0x00 0x00 0x1400>;
                            phandle = <0x09>;
                            pbias_regulator@e00 {
                                compatible = "ti,pbias-dra7\0ti,pbias-omap";
                                reg = <0xe00 0x04>;
                                syscon = <0x09>;
                                pbias_mmc_omap5 {
                                    regulator-name = "pbias_mmc_omap5";
                                    regulator-min-microvolt = <0x1b7740>;
                                    regulator-max-microvolt = <0x325aa0>;
                                    phandle = <0xb6>;
                        pinmux@1400 {
                            compatible = "ti,dra7-padconf\0pinctrl-single";
                            reg = <0x1400 0x468>;
                            #size-cells = <0x00>;
                            #pinctrl-cells = <0x01>;
                            #interrupt-cells = <0x01>;
                            interrupt-controller;
                            pinctrl-single,register-width = <0x20>;
                            pinctrl-single,function-mask = <0x3fffffff>;
                            phandle = <0xac>;
                            mmc1_pins_default {
                                pinctrl-single,pins = <0x354 0x60000 0x358 0x60000 0x35c 0x60000 0x360 0x60000 0x364 0x60000 0x368 0x60000>;
                                phandle = <0xb7>;
                            mmc1_pins_sdr12 {
                            mmc1_pins_hs {
                                pinctrl-single,pins = <0x354 0x601b0 0x358 0x601b0 0x35c 0x601b0 0x360 0x601b0 0x364 0x601b0 0x368 0x601b0>;
                                phandle = <0xb9>;
                            mmc1_pins_sdr25 {
                            mmc1_pins_sdr50 {
                                pinctrl-single,pins = <0x354 0x601a0 0x358 0x601a0 0x35c 0x601a0 0x360 0x601a0 0x364 0x601a0 0x368 0x601a0>;
                            mmc1_pins_ddr50 {
                                pinctrl-single,pins = <0x354 0x60100 0x358 0x60100 0x35c 0x60100 0x360 0x60100 0x364 0x60100 0x368 0x60100>;
                            mmc1_pins_sdr104 {
                            mmc2_pins_default {
                                pinctrl-single,pins = <0x9c 0x60001 0xb0 0x60001 0xa0 0x60001 0xa4 0x60001 0xa8 0x60001 0xac 0x60001 0x8c 0x60001 0x90 0x60001 0x94 0x60001 0x98 0x60001>;
                                phandle = <0xbb>;
                            mmc2_pins_hs {
                                phandle = <0xbd>;
                            mmc2_pins_ddr_3_3v_rev11 {
                                pinctrl-single,pins = <0x9c 0x60101 0xb0 0x60101 0xa0 0x60101 0xa4 0x60101 0xa8 0x60101 0xac 0x60101 0x8c 0x60101 0x90 0x60101 0x94 0x60101 0x98 0x60101>;
                                phandle = <0xbe>;
                            mmc2_pins_ddr_1_8v_rev11 {
                            mmc2_pins_ddr_rev20 {
                            mmc2_pins_hs200 {
                            mmc4_pins_default {
                                pinctrl-single,pins = <0x3e8 0x60103 0x3ec 0x60103 0x3f0 0x60103 0x3f4 0x60103 0x3f8 0x60103 0x3fc 0x60103>;
                            mmc4_pins_hs {
                            mmc3_pins_default {
                                pinctrl-single,pins = <0x37c 0x60100 0x380 0x60100 0x384 0x60100 0x388 0x60100 0x38c 0x60100 0x390 0x60100>;
                            mmc3_pins_hs {
                            mmc3_pins_sdr12 {
                            mmc3_pins_sdr25 {
                            mmc3_pins_sdr50 {
                            mmc4_pins_sdr12 {
                            mmc4_pins_sdr25 {
                        pinmux@4a002e8c {
                            compatible = "pinctrl-single";
                            reg = <0xe8c 0x04>;
                            pinctrl-single,function-mask = <0x7f>;
            segment@100000 {
                ranges = <0x2000 0x102000 0x1000 0x3000 0x103000 0x1000 0x8000 0x108000 0x1000 0x9000 0x109000 0x1000 0x40000 0x140000 0x10000 0x50000 0x150000 0x1000 0x51000 0x151000 0x1000 0x52000 0x152000 0x1000 0x53000 0x153000 0x1000 0x54000 0x154000 0x1000 0x55000 0x155000 0x1000 0x56000 0x156000 0x1000 0x57000 0x157000 0x1000 0x58000 0x158000 0x1000 0x5b000 0x15b000 0x1000 0x5c000 0x15c000 0x1000 0x5d000 0x15d000 0x1000 0x5e000 0x15e000 0x1000 0x5f000 0x15f000 0x1000 0x60000 0x160000 0x1000 0x61000 0x161000 0x1000 0x62000 0x162000 0x1000 0x63000 0x163000 0x1000 0x64000 0x164000 0x1000 0x65000 0x165000 0x1000 0x66000 0x166000 0x1000 0x67000 0x167000 0x1000 0x68000 0x168000 0x1000 0x6d000 0x16d000 0x1000 0x6e000 0x16e000 0x1000 0x71000 0x171000 0x1000 0x72000 0x172000 0x1000 0x73000 0x173000 0x1000 0x74000 0x174000 0x1000 0x75000 0x175000 0x1000 0x76000 0x176000 0x1000 0x77000 0x177000 0x1000 0x78000 0x178000 0x1000 0x81000 0x181000 0x1000 0x82000 0x182000 0x1000 0x83000 0x183000 0x1000 0x84000 0x184000 0x1000 0x85000 0x185000 0x1000 0x86000 0x186000 0x1000 0x87000 0x187000 0x1000 0x88000 0x188000 0x1000 0x69000 0x169000 0x1000 0x6a000 0x16a000 0x1000 0x79000 0x179000 0x1000 0x7a000 0x17a000 0x1000 0x6b000 0x16b000 0x1000 0x6c000 0x16c000 0x1000 0x7b000 0x17b000 0x1000 0x7c000 0x17c000 0x1000 0x7d000 0x17d000 0x1000 0x7e000 0x17e000 0x1000 0x59000 0x159000 0x1000 0x5a000 0x15a000 0x1000>;
                    compatible = "ti,sysc";
                    status = "disabled";
                    ranges = <0x00 0x2000 0x1000>;
                target-module@8000 {
                    reg = <0x8000 0x04>;
                    reg-names = "rev";
                    ranges = <0x00 0x8000 0x2000>;
                            l3init-clkctrl@20 {
                                compatible = "ti,clkctrl";
                                reg = <0x20 0x6c 0xe0 0x14>;
                                #clock-cells = <0x02>;
                                phandle = <0x6c>;
        interconnect@48000000 {
            compatible = "ti,dra7-l4-per1\0simple-bus";
            reg = <0x48000000 0x800 0x48000800 0x800 0x48001000 0x400 0x48001400 0x400 0x48001800 0x400 0x48001c00 0x400>;
            reg-names = "ap\0la\0ia0\0ia1\0ia2\0ia3";
            ranges = <0x00 0x48000000 0x200000 0x200000 0x48200000 0x200000>;
            segment@0 {
                ranges = <0x00 0x00 0x800 0x1000 0x1000 0x400 0x800 0x800 0x800 0x20000 0x20000 0x1000 0x21000 0x21000 0x1000 0x32000 0x32000 0x1000 0x33000 0x33000 0x1000 0x34000 0x34000 0x1000 0x35000 0x35000 0x1000 0x36000 0x36000 0x1000 0x37000 0x37000 0x1000 0x3e000 0x3e000 0x1000 0x3f000 0x3f000 0x1000 0x55000 0x55000 0x1000 0x56000 0x56000 0x1000 0x57000 0x57000 0x1000 0x58000 0x58000 0x1000 0x59000 0x59000 0x1000 0x5a000 0x5a000 0x1000 0x5b000 0x5b000 0x1000 0x5c000 0x5c000 0x1000 0x5d000 0x5d000 0x1000 0x5e000 0x5e000 0x1000 0x60000 0x60000 0x1000 0x6a000 0x6a000 0x1000 0x6b000 0x6b000 0x1000 0x6c000 0x6c000 0x1000 0x6d000 0x6d000 0x1000 0x6e000 0x6e000 0x1000 0x6f000 0x6f000 0x1000 0x70000 0x70000 0x1000 0x71000 0x71000 0x1000 0x72000 0x72000 0x1000 0x73000 0x73000 0x1000 0x61000 0x61000 0x1000 0x53000 0x53000 0x1000 0x54000 0x54000 0x1000 0xb2000 0xb2000 0x1000 0xb3000 0xb3000 0x1000 0x78000 0x78000 0x1000 0x79000 0x79000 0x1000 0x86000 0x86000 0x1000 0x87000 0x87000 0x1000 0x88000 0x88000 0x1000 0x89000 0x89000 0x1000 0x51000 0x51000 0x1000 0x52000 0x52000 0x1000 0x98000 0x98000 0x1000 0x99000 0x99000 0x1000 0x9a000 0x9a000 0x1000 0x9b000 0x9b000 0x1000 0x9c000 0x9c000 0x1000 0x9d000 0x9d000 0x1000 0x68000 0x68000 0x1000 0x69000 0x69000 0x1000 0x90000 0x90000 0x2000 0x92000 0x92000 0x1000 0xa4000 0xa4000 0x1000 0xa6000 0xa6000 0x1000 0xa8000 0xa8000 0x4000 0xac000 0xac000 0x1000 0xad000 0xad000 0x1000 0xae000 0xae000 0x1000 0x66000 0x66000 0x1000 0x67000 0x67000 0x1000 0xb4000 0xb4000 0x1000 0xb5000 0xb5000 0x1000 0xb8000 0xb8000 0x1000 0xb9000 0xb9000 0x1000 0xba000 0xba000 0x1000 0xbb000 0xbb000 0x1000 0xd1000 0xd1000 0x1000 0xd2000 0xd2000 0x1000 0xd5000 0xd5000 0x1000 0xd6000 0xd6000 0x1000 0xa2000 0xa2000 0x1000 0xa3000 0xa3000 0x1000 0x1400 0x1400 0x400 0x1800 0x1800 0x400 0x1c00 0x1c00 0x400 0xa5000 0xa5000 0x1000 0x7a000 0x7a000 0x1000 0x7b000 0x7b000 0x1000 0x7c000 0x7c000 0x1000 0x7d000 0x7d000 0x1000>;
                target-module@70000 {
                    compatible = "ti,sysc-omap2\0ti,sysc";
                    reg = <0x70000 0x08 0x70010 0x08 0x70090 0x08>;
                    reg-names = "rev\0sysc\0syss";
                    ti,sysc-mask = <0x307>;
                    ti,sysc-sidle = <0x00 0x01 0x02 0x03>;
                    ti,syss-mask = <0x01>;
                    clocks = <0xa0 0x78 0x00>;
                    clock-names = "fck";
                    ranges = <0x00 0x70000 0x1000>;
                    i2c@0 {
                        compatible = "ti,omap4-i2c";
                        reg = <0x00 0x100>;
                        interrupts = <0x00 0x33 0x04>;
                        status = "okay";
                        clock-frequency = <0x186a0>;
                        ti,no-idle;
                        ti,no-reset-on-init;
                            tps659038_pmic {
                                compatible = "ti,tps659038-pmic";
                                regulators {
                                    ldo1 {
                                        regulator-name = "ldo1";
                                        regulator-boot-on;
                                        regulator-always-on;
                                        phandle = <0xba>;
                target-module@5d000 {
                    reg = <0x5d000 0x04 0x5d010 0x04 0x5d114 0x04>;
                    ti,sysc-mask = <0x07>;
                    clocks = <0xa0 0x58 0x00 0xa0 0x58 0x08>;
                    clock-names = "fck\0dbclk";
                    ranges = <0x00 0x5d000 0x1000>;
                    gpio@0 {
                        compatible = "ti,omap4-gpio";
                        reg = <0x00 0x200>;
                        interrupts = <0x00 0x1d 0x04>;
                        gpio-controller;
                        #gpio-cells = <0x02>;
                        #interrupt-cells = <0x02>;
                        ti,no-idle-on-init;
                        phandle = <0xb8>;
                target-module@9c000 { // MMC0
                    reg = <0x9c000 0x04 0x9c010 0x04>;
                    reg-names = "rev\0sysc";
                    ti,sysc-mask = <0x03>;
                    ti,sysc-midle = <0x00 0x01 0x02 0x03>;
                    clocks = <0x6c 0x08 0x00>;
                    ranges = <0x00 0x9c000 0x1000>;
                    mmc@0 {
                        compatible = "ti,dra7-sdhci";
                        reg = <0x00 0x400>;
                        interrupts = <0x00 0x4e 0x04>;
                        status = "okay";
                        pbias-supply = <0xb6>;
                        max-frequency = <0xb71b000>;
                        mmc-ddr-1_8v;
                        mmc-ddr-3_3v;
                        pinctrl-names = "default\0hs";
                        pinctrl-0 = <0xb7>;
                        bus-width = <0x04>;
                        cd-gpios = <0xb8 0x1b 0x01>;
                        pinctrl-1 = <0xb9>;
                        vmmc-supply = <0xba>;
                target-module@ad000 {
                    reg = <0xad000 0x04 0xad010 0x04>;
                    clocks = <0xa0 0xf8 0x00>;
                    ranges = <0x00 0xad000 0x1000>;
                    mmc@0 {
                        reg = <0x00 0x400>;
                        interrupts = <0x00 0x59 0x04>;
                        max-frequency = <0x3d09000>;
                        sdhci-caps-mask = <0x00 0x400000>;
                target-module@b4000 {
                    reg = <0xb4000 0x04 0xb4010 0x04>;
                    clocks = <0x6c 0x10 0x00>;
                    ranges = <0x00 0xb4000 0x1000>;
                    mmc@0 {
                        reg = <0x00 0x400>;
                        interrupts = <0x00 0x51 0x04>;
                        status = "okay";
                        sdhci-caps-mask = <0x07 0x00>;
                        mmc-ddr-1_8v;
                        mmc-ddr-3_3v;
                        pinctrl-names = "default\0hs\0ddr_1_8v";
                        pinctrl-0 = <0xbb>;
                        vmmc-supply = <0xbc>;
                        bus-width = <0x01>;
                        ti,non-removable;
                        no-1-8-v;
                        pinctrl-1 = <0xbd>;
                        pinctrl-2 = <0xbe 0xbf>;
                target-module@d1000 {
                    reg = <0xd1000 0x04 0xd1010 0x04>;
                    clocks = <0xa0 0x100 0x00>;
                    ranges = <0x00 0xd1000 0x1000>;
                    mmc@0 {
                        reg = <0x00 0x400>;
                        interrupts = <0x00 0x5b 0x04>;
        }; // interconnect@48000000
        padconf@4844a000 {
            compatible = "ti,dra7-iodelay";
            reg = <0x4844a000 0xd1c>;
            #pinctrl-cells = <0x02>;
            mmc1_iodelay_ddr_rev11_conf {
                pinctrl-pin-array = <0x618 0x23c 0x21c 0x620 0x5f5 0x00 0x624 0x00 0x258 0x628 0x00 0x00 0x62c 0x37 0x00 0x630 0x193 0x78 0x634 0x00 0x00 0x638 0x00 0x00 0x63c 0x17 0x3c 0x640 0x00 0x00 0x644 0x00 0x00 0x648 0x19 0x3c 0x64c 0x00 0x00 0x650 0x00 0x00 0x654 0x00 0x00 0x658 0x00 0x00 0x65c 0x00 0x00>;
            mmc1_iodelay_ddr50_rev20_conf {
                pinctrl-pin-array = <0x618 0x434 0x14a 0x620 0x4f7 0x00 0x624 0x2d2 0x00 0x628 0x00 0x00 0x62c 0x00 0x00 0x630 0x2ef 0x00 0x634 0x00 0x00 0x638 0x14 0x00 0x63c 0x100 0x00 0x640 0x00 0x00 0x644 0x00 0x00 0x648 0x107 0x00 0x64c 0x00 0x00 0x650 0x00 0x00 0x654 0x00 0x00 0x658 0x00 0x00 0x65c 0x00 0x00>;
            mmc1_iodelay_sdr104_rev11_conf {
                pinctrl-pin-array = <0x620 0x427 0x11 0x628 0x00 0x00 0x62c 0x17 0x00 0x634 0x00 0x00 0x638 0x00 0x00 0x640 0x00 0x00 0x644 0x02 0x00 0x64c 0x00 0x00 0x650 0x00 0x00 0x658 0x00 0x00 0x65c 0x00 0x00>;
            mmc1_iodelay_sdr104_rev20_conf {
                pinctrl-pin-array = <0x620 0x258 0x190 0x628 0x00 0x00 0x62c 0x00 0x00 0x634 0x00 0x00 0x638 0x1e 0x00 0x640 0x00 0x00 0x644 0x00 0x00 0x64c 0x00 0x00 0x650 0x00 0x00 0x658 0x00 0x00 0x65c 0x00 0x00>;
            mmc2_iodelay_hs200_rev11_conf {
                pinctrl-pin-array = <0x190 0x26d 0x258 0x194 0x12c 0x00 0x1a8 0x2e3 0x258 0x1ac 0xf0 0x00 0x1b4 0x32c 0x258 0x1b8 0xf0 0x00 0x1c0 0x3ba 0x258 0x1c4 0x3c 0x00 0x1d0 0x53c 0x1a4 0x1d8 0x3a7 0x258 0x1dc 0x00 0x00 0x1e4 0x20d 0x258 0x1e8 0x78 0x00 0x1f0 0x2ff 0x258 0x1f4 0xe1 0x00 0x1fc 0x235 0x258 0x200 0x3c 0x00 0x364 0x3c9 0x258 0x368 0xb4 0x00>;
            mmc2_iodelay_hs200_rev20_conf {
                pinctrl-pin-array = <0x190 0x112 0x00 0x194 0xa2 0x00 0x1a8 0x191 0x00 0x1ac 0x49 0x00 0x1b4 0x1d1 0x00 0x1b8 0x73 0x00 0x1c0 0x279 0x00 0x1c4 0x2f 0x00 0x1d0 0x3a7 0x118 0x1d8 0x26d 0x00 0x1dc 0x00 0x00 0x1e4 0xb7 0x00 0x1e8 0x00 0x00 0x1f0 0x1d3 0x00 0x1f4 0x00 0x00 0x1fc 0x106 0x00 0x200 0x2e 0x00 0x364 0x2ac 0x00 0x368 0x4c 0x00>;
            mmc2_iodelay_ddr_3_3v_rev11_conf {
                pinctrl-pin-array = <0x18c 0x00 0x78 0x190 0x00 0x00 0x194 0xae 0x00 0x1a4 0x109 0x168 0x1a8 0x00 0x00 0x1ac 0xa8 0x00 0x1b0 0x00 0x78 0x1b4 0x00 0x00 0x1b8 0x88 0x00 0x1bc 0x00 0x78 0x1c0 0x00 0x00 0x1c4 0x00 0x00 0x1c8 0x11f 0x1a4 0x1d0 0x36f 0x00 0x1d4 0x90 0xf0 0x1d8 0x00 0x00 0x1dc 0x00 0x00 0x1e0 0x00 0x00 0x1e4 0x00 0x00 0x1e8 0x22 0x00 0x1ec 0x00 0x78 0x1f0 0x00 0x00 0x1f4 0x78 0x00 0x1f8 0x78 0xb4 0x1fc 0x00 0x00 0x200 0x00 0x00 0x360 0x00 0x00 0x364 0x00 0x00 0x368 0x0b 0x00>;
                phandle = <0xbf>;
            mmc2_iodelay_ddr_1_8v_rev11_conf {
                pinctrl-pin-array = <0x18c 0x00 0x00 0x190 0x00 0x00 0x194 0xae 0x00 0x1a4 0x112 0xf0 0x1a8 0x00 0x00 0x1ac 0xa8 0x00 0x1b0 0x00 0x3c 0x1b4 0x00 0x00 0x1b8 0x88 0x00 0x1bc 0x00 0x3c 0x1c0 0x00 0x00 0x1c4 0x00 0x00 0x1c8 0x202 0x168 0x1d0 0x36f 0x00 0x1d4 0xbb 0x78 0x1d8 0x00 0x00 0x1dc 0x00 0x00 0x1e0 0x00 0x00 0x1e4 0x00 0x00 0x1e8 0x22 0x00 0x1ec 0x00 0x3c 0x1f0 0x00 0x00 0x1f4 0x78 0x00 0x1f8 0x79 0x3c 0x1fc 0x00 0x00 0x200 0x00 0x00 0x360 0x00 0x00 0x364 0x00 0x00 0x368 0x0b 0x00>;
            mmc3_iodelay_manual1_conf {
                pinctrl-pin-array = <0x678 0x196 0x00 0x680 0x293 0x00 0x684 0x00 0x00 0x688 0x00 0x00 0x68c 0x00 0x00 0x690 0x82 0x00 0x694 0x00 0x00 0x698 0x00 0x00 0x69c 0xa9 0x00 0x6a0 0x00 0x00 0x6a4 0x00 0x00 0x6a8 0x00 0x00 0x6ac 0x00 0x00 0x6b0 0x00 0x00 0x6b4 0x1c9 0x00 0x6b8 0x00 0x00 0x6bc 0x00 0x00>;
            mmc4_iodelay_ds_rev11_conf {
                pinctrl-pin-array = <0x840 0x00 0x00 0x848 0x00 0x00 0x84c 0x60 0x00 0x850 0x00 0x00 0x854 0x00 0x00 0x870 0x246 0x00 0x874 0x00 0x00 0x878 0x00 0x00 0x87c 0x187 0x00 0x880 0x00 0x00 0x884 0x00 0x00 0x888 0x231 0x00 0x88c 0x00 0x00 0x890 0x00 0x00 0x894 0x24c 0x00 0x898 0x00 0x00 0x89c 0x00 0x00>;
            mmc4_iodelay_ds_rev20_conf {
                pinctrl-pin-array = <0x840 0x00 0x00 0x848 0x00 0x00 0x84c 0x133 0x00 0x850 0x00 0x00 0x854 0x00 0x00 0x870 0x311 0x00 0x874 0x00 0x00 0x878 0x00 0x00 0x87c 0x265 0x00 0x880 0x00 0x00 0x884 0x00 0x00 0x888 0x2ab 0x00 0x88c 0x00 0x00 0x890 0x00 0x00 0x894 0x343 0x00 0x898 0x00 0x00 0x89c 0x00 0x00>;
            mmc4_iodelay_sdr12_hs_sdr25_rev11_conf {
                pinctrl-pin-array = <0x840 0x00 0x00 0x848 0xa5b 0x00 0x84c 0x624 0x00 0x850 0x00 0x00 0x854 0x00 0x00 0x870 0x779 0x00 0x874 0x00 0x00 0x878 0x00 0x00 0x87c 0x6b9 0x00 0x880 0x00 0x00 0x884 0x00 0x00 0x888 0x763 0x00 0x88c 0x00 0x00 0x890 0x00 0x00 0x894 0x77f 0x00 0x898 0x00 0x00 0x89c 0x00 0x00>;
            mmc4_iodelay_sdr12_hs_sdr25_rev20_conf {
                pinctrl-pin-array = <0x840 0x00 0x00 0x848 0x47b 0x00 0x84c 0x72a 0x00 0x850 0x00 0x00 0x854 0x00 0x00 0x870 0x875 0x00 0x874 0x00 0x00 0x878 0x00 0x00 0x87c 0x789 0x40 0x880 0x00 0x00 0x884 0x00 0x00 0x888 0x78f 0x80 0x88c 0x00 0x00 0x890 0x00 0x00 0x894 0x87c 0x2c 0x898 0x00 0x00 0x89c 0x00 0x00>;
    }; // OCP
    fixedregulator-vdd_3v3 {
        compatible = "regulator-fixed";
        regulator-name = "vdd_3v3";
        vin-supply = <0xff>;
        regulator-min-microvolt = <0x325aa0>;
        phandle = <0xbc>;
#  mmc extcsd read /dev/mmcblk1
  Extended CSD rev 1.8 (MMC 5.1)
Card Supported Command sets [S_CMD_SET: 0x01]
HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13
Background operations support [BKOPS_SUPPORT: 0x01]
Max Packet Read Cmd [MAX_PACKED_READS: 0x00]
Max Packet Write Cmd [MAX_PACKED_WRITES: 0x00]
Data TAG support [DATA_TAG_SUPPORT: 0x01]
Data TAG Unit Size [TAG_UNIT_SIZE: 0x03]
Tag Resources Size [TAG_RES_SIZE: 0x00]
Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05]
Large Unit Size [LARGE_UNIT_SIZE_M1: 0x03]
Extended partition attribute support [EXT_SUPPORT: 0x03]
Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a]
Power off notification [POWER_OFF_LONG_TIME: 0x32]
Cache Size [CACHE_SIZE] is 2048 KiB
Background operations status [BKOPS_STATUS: 0x00]
1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a]
Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00]
Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00]
Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00]
Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00]
Minimum Performance for 8bit at 52MHz in DDR mode:
 [MIN_PERF_DDR_W_8_52: 0x00]
 [MIN_PERF_DDR_R_8_52: 0x00]
TRIM Multiplier [TRIM_MULT: 0x01]
Secure Feature support [SEC_FEATURE_SUPPORT: 0x51]
Boot Information [BOOT_INFO: 0x07]
 Device supports alternative boot method
 Device supports dual data rate during boot
 Device supports high speed timing during boot
Boot partition size [BOOT_SIZE_MULTI: 0xfc]
Access size [ACC_SIZE: 0x00]
High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01]
 i.e. 512 KiB
High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01]
Reliable write sector count [REL_WR_SEC_C: 0x01]
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10]
 i.e. 8192 KiB
Sleep current (VCC) [S_C_VCC: 0x00]
Sleep current (VCCQ) [S_C_VCCQ: 0x00]
Sleep/awake timeout [S_A_TIMEOUT: 0x14]
Sector Count [SEC_COUNT: 0x03b48000]
 Device is block-addressed
Minimum Write Performance for 8bit:
 [MIN_PERF_W_8_52: 0x00]
 [MIN_PERF_R_8_52: 0x00]
 [MIN_PERF_W_8_26_4_52: 0x00]
 [MIN_PERF_R_8_26_4_52: 0x00]
Minimum Write Performance for 4bit:
 [MIN_PERF_W_4_26: 0x00]
 [MIN_PERF_R_4_26: 0x00]
Power classes registers:
 [PWR_CL_26_360: 0x00]
 [PWR_CL_52_360: 0x00]
 [PWR_CL_26_195: 0x00]
 [PWR_CL_52_195: 0x00]
Partition switching timing [PARTITION_SWITCH_TIME: 0x01]
Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0f]
I/O Driver Strength [DRIVER_STRENGTH: 0x1f]
Card Type [CARD_TYPE: 0x57]
 HS200 Single Data Rate eMMC @200MHz 1.8VI/O
 HS Dual Data Rate eMMC @52MHz 1.8V or 3VI/O
 HS eMMC @52MHz - at rated device voltage(s)
 HS eMMC @26MHz - at rated device voltage(s)
CSD structure version [CSD_STRUCTURE: 0x02]
Command set [CMD_SET: 0x00]
Command set revision [CMD_SET_REV: 0x00]
Power class [POWER_CLASS: 0x00]
High-speed interface timing [HS_TIMING: 0x01]
Erased memory content [ERASED_MEM_CONT: 0x00]
Boot configuration bytes [PARTITION_CONFIG: 0x00]
 Not boot enable
 No access to boot partition
Boot config protection [BOOT_CONFIG_PROT: 0x00]
Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00]
High-density erase group definition [ERASE_GROUP_DEF: 0x01]
Boot write protection status registers [BOOT_WP_STATUS]: 0x00
Boot Area Write protection [BOOT_WP]: 0x00
 Power ro locking: possible
 Permanent ro locking: possible
 ro lock status: not locked
User area write protection register [USER_WP]: 0x00
FW configuration [FW_CONFIG]: 0x00
RPMB Size [RPMB_SIZE_MULT]: 0x20
Write reliability setting register [WR_REL_SET]: 0x1f
 user area: the device protects existing data if a power failure occurs during a write operation
 partition 1: the device protects existing data if a power failure occurs during a write operation
 partition 2: the device protects existing data if a power failure occurs during a write operation
 partition 3: the device protects existing data if a power failure occurs during a write operation
 partition 4: the device protects existing data if a power failure occurs during a write operation
Write reliability parameter register [WR_REL_PARAM]: 0x15
 Device supports writing EXT_CSD_WR_REL_SET
 Device supports the enhanced def. of reliable write
Enable background operations handshake [BKOPS_EN]: 0x00
H/W reset function [RST_N_FUNCTION]: 0x00
HPI management [HPI_MGMT]: 0x01
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
 Device support partitioning feature
 Device can have enhanced tech.
Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x0004f0
 i.e. 10354688 KiB
Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
 Device partition setting NOT complete
General Purpose Partition Size
 [GP_SIZE_MULT_4]: 0x000000
 [GP_SIZE_MULT_3]: 0x000000
 [GP_SIZE_MULT_2]: 0x000000
 [GP_SIZE_MULT_1]: 0x000000
Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000
 i.e. 0 KiB
Enhanced User Data Start Address [ENH_START_ADDR]: 0x00000000
 i.e. 0 bytes offset
Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00
Periodic Wake-up [PERIODIC_WAKEUP]: 0x00
Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[127]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[126]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[125]]: 0xfc
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[124]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[123]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[122]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[121]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[120]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[119]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[118]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[117]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[116]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[115]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[114]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[113]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[112]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[111]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[110]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[109]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[108]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[107]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[106]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[105]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[104]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[103]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[102]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[101]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[100]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[99]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[98]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[97]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[96]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[95]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[94]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[93]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[92]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[91]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[90]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[89]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[88]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[87]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[86]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[85]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[84]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[83]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[82]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[81]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[80]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[79]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[78]]: 0x19
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[77]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[76]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[75]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[74]]: 0x01
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[73]]: 0x12
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[72]]: 0x64
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[71]]: 0x05
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[70]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[69]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[68]]: 0x01
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[67]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[66]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[65]]: 0x00
Vendor Specific Fields [VENDOR_SPECIFIC_FIELD[64]]: 0x00
Native sector size [NATIVE_SECTOR_SIZE]: 0x00
Sector size emulation [USE_NATIVE_SECTOR]: 0x00
Sector size [DATA_SECTOR_SIZE]: 0x00
1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00
Class 6 commands control [CLASS_6_CTRL]: 0x00
Number of addressed group to be Released[DYNCAP_NEEDED]: 0x00
Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000
Exception events status[EXCEPTION_EVENTS_STATUS]: 0x0000
Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000
Context configuration [CONTEXT_CONF[51]]: 0x00
Context configuration [CONTEXT_CONF[50]]: 0x00
Context configuration [CONTEXT_CONF[49]]: 0x00
Context configuration [CONTEXT_CONF[48]]: 0x00
Context configuration [CONTEXT_CONF[47]]: 0x00
Context configuration [CONTEXT_CONF[46]]: 0x00
Context configuration [CONTEXT_CONF[45]]: 0x00
Context configuration [CONTEXT_CONF[44]]: 0x00
Context configuration [CONTEXT_CONF[43]]: 0x00
Context configuration [CONTEXT_CONF[42]]: 0x00
Context configuration [CONTEXT_CONF[41]]: 0x00
Context configuration [CONTEXT_CONF[40]]: 0x00
Context configuration [CONTEXT_CONF[39]]: 0x00
Context configuration [CONTEXT_CONF[38]]: 0x00
Context configuration [CONTEXT_CONF[37]]: 0x00
Packed command status [PACKED_COMMAND_STATUS]: 0x00
Packed command failure index [PACKED_FAILURE_INDEX]: 0x00
Power Off Notification [POWER_OFF_NOTIFICATION]: 0x01
Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00
eMMC Firmware Version: 69QT00G9
eMMC Life Time Estimation A [EXT_CSD_DEVICE_LIFE_TIME_EST_TYP_A]: 0x01
eMMC Life Time Estimation B [EXT_CSD_DEVICE_LIFE_TIME_EST_TYP_B]: 0x01
eMMC Pre EOL information [EXT_CSD_PRE_EOL_INFO]: 0x01
Secure Removal Type [SECURE_REMOVAL_TYPE]: 0x01
 information is configured to be removed by an erase of the physical memory
 Supported Secure Removal Type:
  information removed by an erase of the physical memory
Command Queue Support [CMDQ_SUPPORT]: 0x01
Command Queue Depth [CMDQ_DEPTH]: 32
Command Enabled [CMDQ_MODE_EN]: 0x00
Full boot log (in this one, it failed around login prompt time, as opposed to on shutdown as before. This was on the first boot of a new RFS, and when it fails to shut down it's after a new RFS install but before the reboot onto it (still on the old partition).
Note, I added some calls to print_info in :
_mmc_suspend
_mmc_resume
_mmc_hw_reset
So, the initial EXT_CSD output is not an error, it is new printing
Also, the "sync-clocks.service" failure happens consistently even when no SDHCI errors occur, so while I'm still tracking that down, I don't think this is the direct relation.
Boot fails on first boot of new RFS, if I power cycle the board afterwards it boots:
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.168-1-ctx (vagrant@0eb56e7c9d81) (arm-none-linux-gnueabihf-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #77 SMP PREEMPT Tue Feb 3 20:15:37 UTC 2026
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: COMPU AM57XX
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000be800000
[    0.000000] OMAP4: Map 0x00000000afd00000 to (ptrval) for dram barrier
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000afcfffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x00000000afd00000-0x00000000bfffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000afcfffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] On node 0 totalpages: 261376
[    0.000000]   DMA zone: 1722 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 195840 pages, LIFO batch:63
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] DRA722 ES2.0
[    0.000000] percpu: Embedded 16 pages/cpu s33292 r8192 d24052 u65536
[    0.000000] pcpu-alloc: s33292 r8192 d24052 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 259654
[    0.000000] Kernel command line: console=ttyO0,115200n8 omapdss.def_disp=lcd usbcore.autosuspend=-1 systemd.unit=graphical.target nosmp root=PARTUUID=67dc1a95-03 rw rootfstype=ext4 rootwait debug loglevel=8 console=tty0 systemd.log_level=info systemd.journald.max_level_console=notice sdhci.async_probe=0 5
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 695628K/1045504K available (12288K kernel code, 754K rwdata, 3816K rodata, 2048K init, 298K bss, 226996K reserved, 122880K cma-reserved, 237568K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] GIC CPU mask not found - kernel will fail to boot.
[    0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[    0.001342] TI gptimer clockevent: always-on 32786 Hz at /ocp/interconnect@4ae00000/segment@10000/target-module@8000
[    0.001831] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@32000
[    0.002807] Incomplete dtb for percpu dmtimer /ocp/interconnect@48800000/segment@0/target-module@2a000
[    0.002929] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2a000
[    0.003570] Console: colour dummy device 80x30
[    0.004089] printk: console [tty0] enabled
[    0.004119] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.004119] This ensures that you still see kernel messages. Please
[    0.004150] update your kernel commandline.
[    0.004180] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
[    0.061950] pid_max: default: 32768 minimum: 301
[    0.062072] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.062103] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.062713] CPU: Testing write buffer coherency: ok
[    0.062774] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.062805] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[    0.062988] /cpus/cpu@0 missing clock-frequency property
[    0.063018] missing device node for CPU 1
[    0.063018] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.063568] Setting up static identity map for 0x80200000 - 0x80200060
[    0.063659] rcu: Hierarchical SRCU implementation.
[    0.063873] EFI services will not be available.
[    0.064422] smp: Bringing up secondary CPUs ...
[    0.064453] smp: Brought up 1 node, 1 CPU
[    0.064453] SMP: Total of 1 processors activated (1993.93 BogoMIPS).
[    0.064453] CPU: All CPU(s) started in HYP mode.
[    0.064483] CPU: Virtualization extensions available.
[    0.064819] devtmpfs: initialized
[    0.085449] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.085632] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.085662] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.087799] pinctrl core: initialized pinctrl subsystem
[    0.088317] DMI not present or invalid.
[    0.088775] NET: Registered protocol family 16
[    0.089874] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.092407] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.109893] thermal_sys: Registered thermal governor 'fair_share'
[    0.109893] thermal_sys: Registered thermal governor 'bang_bang'
[    0.109924] thermal_sys: Registered thermal governor 'step_wise'
[    0.109954] thermal_sys: Registered thermal governor 'user_space'
[    0.110717] cpuidle: using governor ladder
[    0.110778] cpuidle: using governor menu
[    1.251983] No ATAGs?
[    1.252044] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    1.252044] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    1.279327] reg-fixed-voltage fixedregulator-vdd_3v3: GPIO lookup for consumer (null)
[    1.279357] reg-fixed-voltage fixedregulator-vdd_3v3: using device tree for GPIO lookup
[    1.279388] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vdd_3v3[0]'
[    1.279418] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vdd_3v3[0]'
[    1.279449] reg-fixed-voltage fixedregulator-vdd_3v3: using lookup tables for GPIO lookup
[    1.279479] reg-fixed-voltage fixedregulator-vdd_3v3: No GPIO consumer (null) found
[    1.279724] reg-fixed-voltage fixedregulator-aic_dvdd: GPIO lookup for consumer (null)
[    1.279724] reg-fixed-voltage fixedregulator-aic_dvdd: using device tree for GPIO lookup
[    1.279754] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-aic_dvdd[0]'
[    1.279785] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-aic_dvdd[0]'
[    1.279815] reg-fixed-voltage fixedregulator-aic_dvdd: using lookup tables for GPIO lookup
[    1.279846] reg-fixed-voltage fixedregulator-aic_dvdd: No GPIO consumer (null) found
[    1.280212] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    1.280242] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    1.280273] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    1.280364] reg-fixed-voltage fixedregulator-vtt: No GPIO consumer (null) found
[    1.281585] iommu: Default domain type: Passthrough
[    1.284790] SCSI subsystem initialized
[    1.284942] usbcore: registered new interface driver usbfs
[    1.285003] usbcore: registered new interface driver hub
[    1.285034] usbcore: registered new device driver usb
[    1.285644] mc: Linux media interface: v0.10
[    1.285675] videodev: Linux video capture interface: v2.00
[    1.285736] pps_core: LinuxPPS API ver. 1 registered
[    1.285766] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.285797] PTP clock support registered
[    1.285827] EDAC MC: Ver: 3.0.0
[    1.286987] Advanced Linux Sound Architecture Driver Initialized.
[    1.287658] clocksource: Switched to clocksource 32k_counter
[    1.293487] NET: Registered protocol family 2
[    1.293701] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.294525] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.294586] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.294647] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.294769] TCP: Hash tables configured (established 8192 bind 8192)
[    1.294860] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.294891] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.295043] NET: Registered protocol family 1
[    1.295440] RPC: Registered named UNIX socket transport module.
[    1.295471] RPC: Registered udp transport module.
[    1.295471] RPC: Registered tcp transport module.
[    1.295501] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.295501] PCI: CLS 0 bytes, default 64
[    1.296966] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.297088] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    1.297851] Initialise system trusted keyrings
[    1.298095] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.301910] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.302429] NFS: Registering the id_resolver key type
[    1.302490] Key type id_resolver registered
[    1.302520] Key type id_legacy registered
[    1.302581] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.302612] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.302642] ntfs: driver 2.1.32 [Flags: R/O].
[    1.303039] Key type asymmetric registered
[    1.303039] Asymmetric key parser 'x509' registered
[    1.303100] bounce: pool size: 64 pages
[    1.303131] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.303161] io scheduler mq-deadline registered
[    1.303161] io scheduler kyber registered
[    1.629394] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    1.774230] ti-sysc 4ae10000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.774261] ti-sysc 4ae10000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.781127] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
[    1.781188] gpio gpiochip0: registered GPIOs 0 to 31 on gpio-0-31
[    1.781249] OMAP GPIO hardware version 0.1
[    1.784057] ti-sysc: probe of 4ae18000.target-module failed with error -16
[    1.786773] ti-sysc: probe of 48032000.target-module failed with error -16
[    1.792388] ti-sysc 48051000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.792419] ti-sysc 48051000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.794525] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
[    1.794586] gpio gpiochip1: registered GPIOs 32 to 63 on gpio-32-63
[    1.794830] ti-sysc 48053000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.794830] ti-sysc 48053000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.796813] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
[    1.796905] gpio gpiochip2: registered GPIOs 64 to 95 on gpio-64-95
[    1.797119] ti-sysc 48055000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.797149] ti-sysc 48055000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.799285] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
[    1.799377] gpio gpiochip3: registered GPIOs 96 to 127 on gpio-96-127
[    1.799591] ti-sysc 48057000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.799621] ti-sysc 48057000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.801635] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4)
[    1.801696] gpio gpiochip4: registered GPIOs 128 to 159 on gpio-128-159
[    1.801910] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.801940] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.803833] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5)
[    1.803894] gpio gpiochip5: registered GPIOs 160 to 191 on gpio-160-191
[    1.804107] ti-sysc 4805b000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.804138] ti-sysc 4805b000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.805938] gpio gpiochip6: (gpio-192-223): added GPIO chardev (254:6)
[    1.805999] gpio gpiochip6: registered GPIOs 192 to 223 on gpio-192-223
[    1.806213] ti-sysc 4805d000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.806243] ti-sysc 4805d000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.808135] gpio gpiochip7: (gpio-224-255): added GPIO chardev (254:7)
[    1.808197] gpio gpiochip7: registered GPIOs 224 to 255 on gpio-224-255
[    1.808410] ti-sysc 48060000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.808441] ti-sysc 48060000.target-module: dts flag should be at module level for ti,no-idle
[    1.810668] i2c i2c-2: GPIO lookup for consumer scl
[    1.810668] i2c i2c-2: using device tree for GPIO lookup
[    1.810729] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.810760] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.810791] i2c i2c-2: using lookup tables for GPIO lookup
[    1.810791] i2c i2c-2: No GPIO consumer scl found
[    1.810821] i2c i2c-2: GPIO lookup for consumer sda
[    1.810852] i2c i2c-2: using device tree for GPIO lookup
[    1.810882] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.810913] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.810943] i2c i2c-2: using lookup tables for GPIO lookup
[    1.810943] i2c i2c-2: No GPIO consumer sda found
[    1.814544] omap_i2c 48060000.i2c: bus 2 rev0.12 at 100 kHz
[    1.817413] ti-sysc 48070000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.817413] ti-sysc 48070000.target-module: dts flag should be at module level for ti,no-idle
[    1.819335] i2c i2c-0: GPIO lookup for consumer scl
[    1.819335] i2c i2c-0: using device tree for GPIO lookup
[    1.819396] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.819427] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.819458] i2c i2c-0: using lookup tables for GPIO lookup
[    1.819458] i2c i2c-0: No GPIO consumer scl found
[    1.819488] i2c i2c-0: GPIO lookup for consumer sda
[    1.819519] i2c i2c-0: using device tree for GPIO lookup
[    1.819549] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.819580] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.819610] i2c i2c-0: using lookup tables for GPIO lookup
[    1.819610] i2c i2c-0: No GPIO consumer sda found
[    1.820770] palmas 0-0058: Irq flag is 0x00000008
[    1.852416] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[    1.857360] smps12: supplied by regulator-dummy
[    1.861480] smps3: supplied by regulator-dummy
[    1.865722] smps45: supplied by regulator-dummy
[    1.870269] smps6: supplied by regulator-dummy
[    1.874359] smps7: supplied by regulator-dummy
[    1.878936] smps8: supplied by regulator-dummy
[    1.883026] smps9: supplied by regulator-dummy
[    1.885437] ldo1: supplied by regulator-dummy
[    1.888916] ldo2: supplied by regulator-dummy
[    1.892364] ldo3: supplied by regulator-dummy
[    1.895843] ldo4: supplied by regulator-dummy
[    1.899444] LDO5: supplied by regulator-dummy
[    1.900115] LDO6: supplied by regulator-dummy
[    1.900787] LDO7: supplied by regulator-dummy
[    1.901458] LDO8: supplied by regulator-dummy
[    1.902465] ldo9: supplied by regulator-dummy
[    1.906402] ldoln: supplied by regulator-dummy
[    1.909881] ldousb: supplied by regulator-dummy
[    1.915771] gpiochip_find_base: found new base at 504
[    1.915924] gpio gpiochip8: (48070000.i2c:tps659038@58:tps659038_gpio): added GPIO chardev (254:8)
[    1.916015] gpio gpiochip8: registered GPIOs 504 to 511 on 48070000.i2c:tps659038@58:tps659038_gpio
[    1.917572] omap_i2c 48070000.i2c: bus 0 rev0.12 at 100 kHz
[    1.918579] ti-sysc 48072000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.918609] ti-sysc 48072000.target-module: dts flag should be at module level for ti,no-idle
[    1.920654] ti-sysc 4807a000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.920684] ti-sysc 4807a000.target-module: dts flag should be at module level for ti,no-idle
[    1.921691] i2c i2c-3: GPIO lookup for consumer scl
[    1.921722] i2c i2c-3: using device tree for GPIO lookup
[    1.921752] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.921813] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.921813] i2c i2c-3: using lookup tables for GPIO lookup
[    1.921844] i2c i2c-3: No GPIO consumer scl found
[    1.921874] i2c i2c-3: GPIO lookup for consumer sda
[    1.921874] i2c i2c-3: using device tree for GPIO lookup
[    1.921905] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.921966] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.921966] i2c i2c-3: using lookup tables for GPIO lookup
[    1.921997] i2c i2c-3: No GPIO consumer sda found
[    1.922027] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[    1.922210] ti-sysc 4807c000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.922241] ti-sysc 4807c000.target-module: dts flag should be at module level for ti,no-idle
[    1.923217] i2c i2c-4: GPIO lookup for consumer scl
[    1.923248] i2c i2c-4: using device tree for GPIO lookup
[    1.923278] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923309] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923339] i2c i2c-4: using lookup tables for GPIO lookup
[    1.923370] i2c i2c-4: No GPIO consumer scl found
[    1.923400] i2c i2c-4: GPIO lookup for consumer sda
[    1.923400] i2c i2c-4: using device tree for GPIO lookup
[    1.923431] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923492] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923492] i2c i2c-4: using lookup tables for GPIO lookup
[    1.923522] i2c i2c-4: No GPIO consumer sda found
[    1.923553] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    1.951324] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    1.952941] omap-mailbox 48846000.mailbox: omap mailbox rev 0x400
[    1.958648] edma 43300000.dma: memcpy is disabled
[    1.961364] edma 43300000.dma: TI EDMA DMA engine driver
[    1.976043] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[    1.976226] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[    1.976287] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[    1.976318] pinctrl-single 4a002e8c.pinmux: 1 pins, size 4
[    1.983764] clk-ctx160 2-004b: GPIO lookup for consumer reset
[    1.983795] clk-ctx160 2-004b: using device tree for GPIO lookup
[    1.983856] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0/clk_ctx160@4b[0]' - status (0)
[    1.983886] gpio gpiochip4: Persistence not supported for GPIO 25
[    2.008819] clk-ctx160 2-004b: Found AD9545.
[    2.008819] clk-ctx160 2-004b: Vers. 1.003
[    2.008850] clk-ctx160 2-004b: Configuration "ctx169" discovered.
[    2.008880] clk-ctx160 2-004b: XO source is board_49M152_osc.
[    2.008911] clk-ctx160 2-004b: REF_B source is board_otherside_clk.
[    2.008941] clk-ctx160 2-004b: REF_BB source is board_20M_clk.
[    2.008941] clk-ctx160 2-004b: Found 3 source clocks.
[    2.008972] clk-ctx160 2-004b: Creating output clock[0] clk_plogic_ref.
[    2.009124] clk-ctx160 2-004b: Creating output clock[1] clk_aux_sys.
[    2.009216] clk-ctx160 2-004b: Creating output clock[2] clk_audio_sys.
[    2.009307] clk-ctx160 2-004b: Creating output clock[3] clk_otherside_ref.
[    2.009368] clk-ctx160 2-004b: Creating output clock[4] clk_audio_framea.
[    2.009460] clk-ctx160 2-004b: Creating output clock[5] clk_audio_frameb.
[    2.009552] clk-ctx160 2-004b: Configuring 1169 DPLL
[    2.101348] clk-ctx160 2-004b: Added provider.
[    2.163116] clk-ctx160 2-004b: calibrated.
[    2.167419] vdd_3v3: supplied by regen1
[    2.167968] aic_dvdd_fixed: supplied by vdd_3v3
[    2.202239] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    2.206024] omap8250 4806a000.serial: GPIO lookup for consumer rs485-term
[    2.206024] omap8250 4806a000.serial: using device tree for GPIO lookup
[    2.206085] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@6a000/serial@0[0]'
[    2.206115] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@6a000/serial@0[0]'
[    2.206146] omap8250 4806a000.serial: using lookup tables for GPIO lookup
[    2.206176] omap8250 4806a000.serial: No GPIO consumer rs485-term found
[    2.206207] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 117, base_baud = 3000000) is a 8250
[    4.337799] printk: console [ttyS0] enabled
[    4.344879] omap_rng 48090000.rng: Random Number Generator ver. 20
[    4.351287] random: crng init done
[    4.363769] panel-simple display: GPIO lookup for consumer hpd
[    4.369689] panel-simple display: using device tree for GPIO lookup
[    4.376007] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/display[0]'
[    4.384521] of_get_named_gpiod_flags: can't parse 'hpd-gpio' property of node '/display[0]'
[    4.392944] panel-simple display: using lookup tables for GPIO lookup
[    4.399444] panel-simple display: No GPIO consumer hpd found
[    4.405151] panel-simple display: supply power not found, using dummy regulator
[    4.412628] panel-simple display: GPIO lookup for consumer enable
[    4.418762] panel-simple display: using device tree for GPIO lookup
[    4.425079] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display[0]'
[    4.433868] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display[0]'
[    4.442535] panel-simple display: using lookup tables for GPIO lookup
[    4.449035] panel-simple display: No GPIO consumer enable found
[    4.455017] panel-simple display: Specify missing bus_format
[    4.460723] panel-simple display: Expected bpc in {6,8} but got: 0
[    4.477905] brd: module loaded
[    4.486511] loop: module loaded
[    4.490051] at24 2-0051: supply vcc not found, using dummy regulator
[    4.496582] at24 2-0051: GPIO lookup for consumer wp
[    4.501647] at24 2-0051: using device tree for GPIO lookup
[    4.507171] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0/eeprom@51[0]'
[    4.521209] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0/eeprom@51[0]'
[    4.535125] at24 2-0051: using lookup tables for GPIO lookup
[    4.540863] at24 2-0051: No GPIO consumer wp found
[    4.546295] at24 2-0051: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    4.553161] at24 0-0050: supply vcc not found, using dummy regulator
[    4.559661] at24 0-0050: GPIO lookup for consumer wp
[    4.564666] at24 0-0050: using device tree for GPIO lookup
[    4.570220] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/eeprom@50[0]'
[    4.584259] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/eeprom@50[0]'
[    4.598175] at24 0-0050: using lookup tables for GPIO lookup
[    4.603881] at24 0-0050: No GPIO consumer wp found
[    4.609283] at24 0-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    4.616149] ctx161-codec 2-0010: assume XXXXXXXX
[    4.620910] ctx161-codec 2-0010: spkrout-1169 config required
[    4.627166] ctx161-codec 2-0010: Vers. 2.005  Rev. 52
[    4.632598] ctx161-codec 2-0010: Progamming SPKROUT 1169 codec settings
[    4.646514] ctx161-codec 0-0010: assume XXXXXXXX
[    4.651184] ctx161-codec 0-0010: aout-1169 config required
[    4.656707] ctx161-codec 0-0010: GPIO selectable at codec bus
[    4.662506] ctx161-codec 0-0010: GPIO lookup for consumer select
[    4.668579] ctx161-codec 0-0010: using device tree for GPIO lookup
[    4.674804] of_get_named_gpiod_flags: parsed 'select-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/codec@10[0]' - status (0)
[    4.689819] gpio gpiochip3: Persistence not supported for GPIO 20
[    4.696411] ctx161-codec 0-0010: Vers. 2.005  Rev. 52
[    4.701843] ctx161-codec 0-0010: Progamming AOUT 1169 codec settings
[    4.715301] ctx161-codec 0-0010: Programming mux selected seconday codec
[    4.722381] ctx161-codec 0-0010: Progamming AOUT 1169 codec settings
[    4.737243] mc68-audio16 v1.028: probing
[    4.741210] mc68-audio16 mc68-audio16: Found DSP clock.
[    4.746490] mc68-audio16 mc68-audio16: Found IPU clock.
[    4.751770] mc68-audio16 mc68-audio16: Using default DSP MMU0 @40d01000.
[    4.758514] mc68-audio16 mc68-audio16: Using default DSP MMU1 @40d02000.
[    4.765258] mc68-audio16 mc68-audio16: Using default IPU MMU @58882000.
[    4.771942] mc68-audio16 mc68-audio16: Assuming IPU Unicache @58880000.
[    4.778778] mc68-audio16 mc68-audio16: bios-timer 0 not available...yet?
[    4.785644] mc68-audio16 mc68-audio16: bios-timer 1 not available...yet?
[    4.792388] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    4.798889] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    4.805633] of_get_named_gpiod_flags: parsed 'frame-gpios' property of node '/mc68-audio16[0]' - status (0)
[    4.815460] gpio gpiochip3: Persistence not supported for GPIO 27
[    4.821624] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    4.828094] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    4.834869] of_get_named_gpiod_flags: can't parse 'frame-gpios' property of node '/mc68-audio16[1]'
[    4.843963] of_get_named_gpiod_flags: can't parse 'frame-gpio' property of node '/mc68-audio16[1]'
[    4.853027] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    4.859954] mc68-audio16 mc68-audio16: No GPIO consumer frame found
[    4.866271] mc68-audio16 mc68-audio16: Reusing frame clock gpio.
[    4.872314] mc68-audio16 mc68-audio16: GPIO lookup for consumer footsw
[    4.878906] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    4.885650] of_get_named_gpiod_flags: can't parse 'footsw-gpios' property of node '/mc68-audio16[0]'
[    4.894866] of_get_named_gpiod_flags: can't parse 'footsw-gpio' property of node '/mc68-audio16[0]'
[    4.903991] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    4.910919] mc68-audio16 mc68-audio16: No GPIO consumer footsw found
[    4.925140] clk: failed to reparent ipu-clkctrl:0000:0 to per_abe_x1_gfclk2_div: -22
[    4.932983] davinci-mcasp8 48460000.mcasp: Configured tdm_slots=4
[    4.939147] davinci-mcasp8 48460000.mcasp: Counted num_serializer=16
[    4.945556] davinci-mcasp8 48460000.mcasp: Assigned num_serializer=16
[    4.952056] davinci-mcasp8 48460000.mcasp: IRQ common not found
[    4.958312] davinci-mcasp8 48460000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    4.966461] davinci-mcasp8 48460000.mcasp: Adding Audio McASP power
[    4.972808] davinci-mcasp8 48460000.mcasp: Vers. 1.004
[    4.978332] clk: failed to reparent l4per2-clkctrl:0154:0 to per_abe_x1_gfclk2_div: -22
[    4.986419] davinci-mcasp8 48464000.mcasp: Configured tdm_slots=4
[    4.992553] davinci-mcasp8 48464000.mcasp: Counted num_serializer=16
[    4.998992] davinci-mcasp8 48464000.mcasp: Assigned num_serializer=16
[    5.005462] davinci-mcasp8 48464000.mcasp: IRQ common not found
[    5.011627] davinci-mcasp8 48464000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.019775] davinci-mcasp8 48464000.mcasp: Adding Audio McASP power
[    5.026092] davinci-mcasp8 48464000.mcasp: Vers. 1.004
[    5.031585] clk: failed to reparent l4per2-clkctrl:015c:0 to per_abe_x1_gfclk2_div: -22
[    5.039672] davinci-mcasp8 48468000.mcasp: welcome to Burst mode=4
[    5.045898] davinci-mcasp8 48468000.mcasp: Configured tdm_slots=1
[    5.052032] davinci-mcasp8 48468000.mcasp: Counted num_serializer=4
[    5.058380] davinci-mcasp8 48468000.mcasp: Assigned num_serializer=4
[    5.064788] davinci-mcasp8 48468000.mcasp: IRQ common not found
[    5.070922] davinci-mcasp8 48468000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.079071] davinci-mcasp8 48468000.mcasp: Vers. 1.004
[    5.084564] clk: failed to reparent l4per2-clkctrl:018c:0 to per_abe_x1_gfclk2_div: -22
[    5.092681] davinci-mcasp8 4846c000.mcasp: welcome to Burst mode=4
[    5.098907] davinci-mcasp8 4846c000.mcasp: Configured tdm_slots=1
[    5.105041] davinci-mcasp8 4846c000.mcasp: Counted num_serializer=4
[    5.111358] davinci-mcasp8 4846c000.mcasp: Assigned num_serializer=4
[    5.117797] davinci-mcasp8 4846c000.mcasp: IRQ common not found
[    5.123901] davinci-mcasp8 4846c000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.132080] davinci-mcasp8 4846c000.mcasp: Vers. 1.004
[    5.137573] clk: failed to reparent l4per2-clkctrl:01f8:0 to per_abe_x1_gfclk2_div: -22
[    5.145690] davinci-mcasp8 48474000.mcasp: Configured tdm_slots=4
[    5.151855] davinci-mcasp8 48474000.mcasp: Counted num_serializer=4
[    5.158172] davinci-mcasp8 48474000.mcasp: Assigned num_serializer=4
[    5.164581] davinci-mcasp8 48474000.mcasp: IRQ common not found
[    5.170715] davinci-mcasp8 48474000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.178863] davinci-mcasp8 48474000.mcasp: Adding Audio McASP power
[    5.185180] davinci-mcasp8 48474000.mcasp: Vers. 1.004
[    5.190673] clk: failed to reparent l4per2-clkctrl:01fc:0 to per_abe_x1_gfclk2_div: -22
[    5.198760] davinci-mcasp8 48478000.mcasp: Configured tdm_slots=4
[    5.204895] davinci-mcasp8 48478000.mcasp: Counted num_serializer=4
[    5.211242] davinci-mcasp8 48478000.mcasp: Assigned num_serializer=4
[    5.217651] davinci-mcasp8 48478000.mcasp: IRQ common not found
[    5.223785] davinci-mcasp8 48478000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.231933] davinci-mcasp8 48478000.mcasp: Adding Audio McASP power
[    5.238281] davinci-mcasp8 48478000.mcasp: Vers. 1.004
[    5.243743] clk: failed to reparent l4per2-clkctrl:0184:0 to per_abe_x1_gfclk2_div: -22
[    5.251831] davinci-mcasp8 4847c000.mcasp: Configured tdm_slots=4
[    5.257995] davinci-mcasp8 4847c000.mcasp: Counted num_serializer=4
[    5.264312] davinci-mcasp8 4847c000.mcasp: Assigned num_serializer=4
[    5.270721] davinci-mcasp8 4847c000.mcasp: IRQ common not found
[    5.276855] davinci-mcasp8 4847c000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.285003] davinci-mcasp8 4847c000.mcasp: Adding Audio McASP power
[    5.291320] davinci-mcasp8 4847c000.mcasp: Vers. 1.004
[    5.303344] mdio_bus fixed-0: GPIO lookup for consumer reset
[    5.309112] mdio_bus fixed-0: using lookup tables for GPIO lookup
[    5.315246] mdio_bus fixed-0: No GPIO consumer reset found
[    5.326507] mdio_bus 48485000.mdio: GPIO lookup for consumer reset
[    5.332763] mdio_bus 48485000.mdio: using device tree for GPIO lookup
[    5.339294] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000[0]'
[    5.353820] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000[0]'
[    5.368316] mdio_bus 48485000.mdio: using lookup tables for GPIO lookup
[    5.374969] mdio_bus 48485000.mdio: No GPIO consumer reset found
[    5.437744] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    5.446197] mdio_bus 48485000.mdio:00: GPIO lookup for consumer reset
[    5.452728] mdio_bus 48485000.mdio:00: using device tree for GPIO lookup
[    5.459564] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@1[0]'
[    5.475463] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@1[0]'
[    5.491210] mdio_bus 48485000.mdio:00: using lookup tables for GPIO lookup
[    5.498168] mdio_bus 48485000.mdio:00: No GPIO consumer reset found
[    5.505920] mdio_bus 48485000.mdio:01: GPIO lookup for consumer reset
[    5.512420] mdio_bus 48485000.mdio:01: using device tree for GPIO lookup
[    5.519256] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@2[0]'
[    5.535125] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@2[0]'
[    5.550903] mdio_bus 48485000.mdio:01: using lookup tables for GPIO lookup
[    5.557861] mdio_bus 48485000.mdio:01: No GPIO consumer reset found
[    5.564880] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver XXXX
[    5.573669] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver XXXX
[    5.582763] cpsw-switch 48484000.switch: initialized cpsw ale version 1.4
[    5.589599] cpsw-switch 48484000.switch: ALE Table size 1024
[    5.595367] cpsw-switch 48484000.switch: cpts: overflow check period 500 (jiffies)
[    5.602996] cpsw-switch 48484000.switch: CPTS: ref_clk_freq:266000000 calc_mult:4036623398 calc_shift:30 error:-1 nsec/sec
[    5.614227] cpsw-switch 48484000.switch: Detected MACID = 00:0a:b6:01:82:ba
[    5.621276] cpsw-switch 48484000.switch: Detected MACID = 00:0a:b6:01:82:bb
[    5.629669] cpsw-switch 48484000.switch: initialized (regs 0x0000000048484000, pool size 256) hw_ver:0019010F 1.15 (0)
[    5.644287] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@4000
[    5.655517] dwc3 48890000.usb: changing max_speed on rev 5533202a
[    5.663208] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@5000
[    5.683044] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.689727] ehci-platform: EHCI generic platform driver
[    5.695556] ehci-omap: OMAP-EHCI Host Controller driver
[    5.701141] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.708679] usbcore: registered new interface driver ftdi_sio
[    5.714477] usbserial: USB Serial support registered for FTDI USB Serial Device
[    5.721862] usbcore: registered new interface driver ctx163
[    5.727508] usbcore: registered new interface driver ctx164
[    5.734374] g_serial gadget: Gadget Serial v2.4
[    5.738952] g_serial gadget: g_serial ready
[    5.744140] input: ar1021 I2C Touchscreen as /devices/platform/44000000.ocp/48000000.interconnect/48000000.interconnect:segment@0/48060000.target-module/48060000.i2c/i2c-2/2-004d/input/input0
[    5.762054] i2c /dev entries driver
[    5.767791] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    5.773590] Driver for 1-wire Dallas network protocol.
[    5.779296] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode
[    5.797821] vpe 489d0000.vpe: Device registered as /dev/video0
[    5.992889] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
[    6.002685] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    6.010528] power_supply bq27000-battery: power_supply_get_battery_info currently only supports devicetree
[    6.023651] sdhci: Secure Digital Host Controller Interface driver
[    6.029968] sdhci: Copyright(c) Pierre Ossman
[    6.036041] sdhci-pltfm: SDHCI platform and OF driver helper
[    6.043762] sdhci-omap 4809c000.mmc: GPIO lookup for consumer cd
[    6.050811] ledtrig-cpu: registered to indicate activity on CPUs
[    6.057464] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    6.063690] sdhci-omap 480b4000.mmc: GPIO lookup for consumer cd
[    6.069763] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup
[    6.076385] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@9c000/mmc@0[0]' - status (0)
[    6.090209] sdhci-omap 480b4000.mmc: using device tree for GPIO lookup
[    6.096801] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.110229] omap-aes 4b500000.aes: will run requests pump with realtime priority
[    6.118011] gpio gpiochip7: Persistence not supported for GPIO 27
[    6.124176] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[    6.133148] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.146575] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    6.152740] omap-aes 4b700000.aes: will run requests pump with realtime priority
[    6.160827] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    6.166900] sdhci-omap 480b4000.mmc: using lookup tables for GPIO lookup
[    6.173706] sdhci-omap 4809c000.mmc: Got CD GPIO
[    6.178405] sdhci-omap 4809c000.mmc: GPIO lookup for consumer wp
[    6.184448] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup
[    6.191040] omap-des 480a5000.des: will run requests pump with realtime priority
[    6.198516] sdhci-omap 480b4000.mmc: No GPIO consumer cd found
[    6.204376] sdhci-omap 480b4000.mmc: GPIO lookup for consumer wp
[    6.210815] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@9c000/mmc@0[0]'
[    6.225036] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    6.230926] sdhci-omap 480b4000.mmc: using device tree for GPIO lookup
[    6.237518] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.250762] omap-sham 4b101000.sham: will run requests pump with realtime priority
[    6.258605] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@9c000/mmc@0[0]'
[    6.272308] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.286163] omap-sham 42701000.sham: hw accel on OMAP rev 4.3
[    6.292053] sdhci-omap 4809c000.mmc: using lookup tables for GPIO lookup
[    6.298950] omap-sham 42701000.sham: will run requests pump with realtime priority
[    6.306610] sdhci-omap 4809c000.mmc: No GPIO consumer wp found
[    6.312499] sdhci-omap 480b4000.mmc: using lookup tables for GPIO lookup
[    6.321868] sdhci-omap 4809c000.mmc: supply vqmmc not found, using dummy regulator
[    6.330505] hid: raw HID events driver (C) Jiri Kosina
[    6.335784] usbcore: registered new interface driver usbhid
[    6.341430] sdhci-omap 480b4000.mmc: No GPIO consumer wp found
[    6.347412] sdhci-omap 480b4000.mmc: supply vqmmc not found, using dummy regulator
[    6.355377] usbhid: USB HID core driver
[    6.359680] mmc0: sdhci: Version:   0x00003302 | Present:  0x00000000
[    6.366149] mmc0: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[    6.372802] mmc1: sdhci: Version:   0x00003302 | Present:  0x01f00000
[    6.379974] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id
[    6.388427] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[    6.394958] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[    6.403961] mmc0: sdhci: Auto-CMD23 unavailable
[    6.408569] mmc1: sdhci: Auto-CMD23 unavailable
[    6.413116] sdhci-omap 480b4000.mmc: no pinctrl state for ddr_3_3v mode
[    6.419799] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[    6.426269] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[    6.432739] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]'
[    6.448699] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[    6.455078] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[    6.461578] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]'
[    6.477020] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[    6.483428] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[    6.490112] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    6.497528] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup tables for GPIO lookup
[    6.508056] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[    6.514739] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: No GPIO consumer id found
[    6.523010] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[    6.529907] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus
[    6.538818] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[    6.547943] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]'
[    6.563781] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]' - status (0)
[    6.580200] gpio gpiochip5: Persistence not supported for GPIO 21
[    6.592895] Error: Driver 'davinci-mcasp' is already registered, aborting...
[    6.600921] NET: Registered protocol family 10
[    6.606323] Segment Routing with IPv6
[    6.610260] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    6.616729] NET: Registered protocol family 17
[    6.621307] Key type dns_resolver registered
[    6.625701] Registering SWP/SWPB emulation handler
[    6.631103] omap_voltage_late_init: Voltage driver support not added
[    6.637634] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    6.645233] Power Management for TI OMAP4+ devices.
[    6.650634] Loading compiled-in X.509 certificates
[    6.682250] mmc1: EXT_CSD_BKOPS_EN 0
[    6.685882] mmc1: EXT_CSD_BKOPS_SUPPORT[502]=1 AUTO_BKOPS_EN[163]=0bit is set, card->ext_csd.auto_bkops_en 0
[    6.702026] mmc1: Command Queue supported depth 32
[    6.706939] dmm 4e000000.dmm: workaround for errata i878 in use
[    6.714843] dmm 4e000000.dmm: initialized all PAT entries
[    6.720733] mmc1: NEB MODIFICATIONS: Do not turn on Cache (0)
[    6.726531] mmc1: new high speed MMC card at address 0001
[    6.732757] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    6.740600] mmcblk1: mmc1:0001 G1M15L 29.6 GiB
[    6.745391] mmcblk1boot0: mmc1:0001 G1M15L partition 1 31.5 MiB
[    6.751403] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    6.759368] mmcblk1boot1: mmc1:0001 G1M15L partition 2 31.5 MiB
[    6.765441] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    6.774597] mmcblk1rpmb: mmc1:0001 G1M15L partition 3 4.00 MiB, chardev (242:0)
[    6.782012] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
[    6.791778] gpio gpiochip1: Persistence not supported for GPIO 11
[    6.798034] vtt_fixed: supplied by smps3
[    6.804046] i2c i2c-1: GPIO lookup for consumer scl
[    6.809204] i2c i2c-1: using device tree for GPIO lookup
[    6.814697] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.828063] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.841278]  mmcblk1: p1 p2 p3 p4 < p5 p6 p7 >
[    6.845855] i2c i2c-1: using lookup tables for GPIO lookup
[    6.852478] i2c i2c-1: No GPIO consumer scl found
[    6.857238] i2c i2c-1: GPIO lookup for consumer sda
[    6.862182] i2c i2c-1: using device tree for GPIO lookup
[    6.867553] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.880859] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.894012] i2c i2c-1: using lookup tables for GPIO lookup
[    6.899566] i2c i2c-1: No GPIO consumer sda found
[    6.904876] lm75 1-0048: supply vs not found, using dummy regulator
[    6.938354] hwmon hwmon2: temp1_input not attached to any thermal zone
[    6.944946] lm75 1-0048: hwmon2: sensor 'lm75'
[    6.949890] lm75 1-0049: supply vs not found, using dummy regulator
[    6.956878] hwmon hwmon3: temp1_input not attached to any thermal zone
[    6.963470] lm75 1-0049: hwmon3: sensor 'lm75'
[    6.968414] ctx161-codec 1-0010: assume XXXXXXXX
[    6.973083] ctx161-codec 1-0010: ain-1169 config required
[    6.978546] ctx161-codec 1-0010: GPIO selectable at codec bus
[    6.984313] ctx161-codec 1-0010: GPIO lookup for consumer select
[    6.990386] ctx161-codec 1-0010: using device tree for GPIO lookup
[    6.996643] of_get_named_gpiod_flags: parsed 'select-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/codec@10[0]' - status (0)
[    7.011627] gpio gpiochip3: Persistence not supported for GPIO 19
[    7.017791] ctx161-codec 1-0010: Panel Mic Codec Found
[    7.024230] ctx161-codec 1-0010: Vers. 2.005  Rev. 52
[    7.029449] ctx161-codec 1-0010: Progamming AIN 1169 codec settings
[    7.035766] ctx161-codec 1-0010: Progamming AIN 1169 codec settings slave timing
[    7.046356] ctx161-codec 1-0010: Programming mux selected seconday codec
[    7.053222] ctx161-codec 1-0010: Progamming AIN 1169 codec settings
[    7.059570] ctx161-codec 1-0010: Progamming AIN 1169 codec settings master timing
[    7.070709] lm75 1-004a: supply vs not found, using dummy regulator
[    7.077789] hwmon hwmon4: temp1_input not attached to any thermal zone
[    7.084350] lm75 1-004a: hwmon4: sensor 'lm75'
[    7.089538] ctx169-plogic 1-0020: Driver established
[    7.095245] ctx169-plogic 1-0020: Vers. 1.004  Rev. 1169ff02
[    7.100952] ctx169-plogic 1-0020: pd->headset_irq = 189
[    7.106262] ctx169-plogic 1-0020: pd->codec_irq = 190
[    7.111419] ctx169-plogic 1-0020: pd->panelmic_irq = 191
[    7.117645] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.123718] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.130065] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[0]' - status (0)
[    7.145660] gpio gpiochip5: Persistence not supported for GPIO 7
[    7.151702] gpio-167 (dipsw): no flags found for dipsw
[    7.156890] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.162963] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.169311] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[1]' - status (0)
[    7.184875] gpio gpiochip5: Persistence not supported for GPIO 8
[    7.190948] gpio-168 (dipsw): no flags found for dipsw
[    7.196105] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.202178] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.208526] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[2]' - status (0)
[    7.224121] gpio gpiochip5: Persistence not supported for GPIO 9
[    7.230163] gpio-169 (dipsw): no flags found for dipsw
[    7.235351] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.241394] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.247772] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[3]' - status (0)
[    7.263336] gpio gpiochip5: Persistence not supported for GPIO 10
[    7.269500] gpio-170 (dipsw): no flags found for dipsw
[    7.274658] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.280731] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.287078] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[4]' - status (0)
[    7.302673] gpio gpiochip0: Persistence not supported for GPIO 22
[    7.308837] gpio-22 (dipsw): no flags found for dipsw
[    7.313934] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.319976] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.326324] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[5]' - status (0)
[    7.341918] gpio gpiochip0: Persistence not supported for GPIO 23
[    7.348052] gpio-23 (dipsw): no flags found for dipsw
[    7.353149] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.359191] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.365539] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[6]' - status (0)
[    7.381134] gpio gpiochip0: Persistence not supported for GPIO 24
[    7.387268] gpio-24 (dipsw): no flags found for dipsw
[    7.392364] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.398437] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.404754] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[7]' - status (0)
[    7.420379] gpio gpiochip0: Persistence not supported for GPIO 25
[    7.426513] gpio-25 (dipsw): no flags found for dipsw
[    7.431610] ctx169-plogic 1-0020: GPIO lookup for consumer panel-mic-led
[    7.438354] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.444702] of_get_named_gpiod_flags: parsed 'panel-mic-led-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[0]' - status (0)
[    7.460998] gpio gpiochip1: Persistence not supported for GPIO 27
[    7.467102] gpio-59 (panel-mic-led): no flags found for panel-mic-led
[    7.473632] ctx169-plogic 1-0020: GPIO lookup for consumer panel-mic-ptt
[    7.480377] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.486724] of_get_named_gpiod_flags: parsed 'panel-mic-ptt-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[0]' - status (0)
[    7.502990] gpio gpiochip1: Persistence not supported for GPIO 26
[    7.509155] gpio-58 (panel-mic-ptt): no flags found for panel-mic-ptt
[    7.518249] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[    7.525390] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    7.533111] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    7.539489] platform 40800000.dsp: Adding to iommu group 0
[    7.546173] omap-iommu 58882000.mmu: 58882000.mmu registered
[    7.552276] platform 58820000.ipu: Adding to iommu group 1
[    7.558929] omap-iommu 55082000.mmu: 55082000.mmu registered
[    7.566223] DSS: OMAP DSS rev 6.1
[    7.573211] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    7.611328] [drm] Enabling DMM ywrap scrolling
[    7.694976] Console: switching to colour frame buffer device 100x30
[    7.719848] omapdrm omapdrm.0: [drm] fb0: omapdrmdrmfb frame buffer device
[    7.729248] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    7.738739] mc68-audio16 v1.028: probing
[    7.744506] mc68-audio16 mc68-audio16: Found DSP clock.
[    7.751617] mc68-audio16 mc68-audio16: Found IPU clock.
[    7.758636] mc68-audio16 mc68-audio16: Using default DSP MMU0 @40d01000.
[    7.767120] mc68-audio16 mc68-audio16: Using default DSP MMU1 @40d02000.
[    7.775543] mc68-audio16 mc68-audio16: Using default IPU MMU @58882000.
[    7.783813] mc68-audio16 mc68-audio16: Assuming IPU Unicache @58880000.
[    7.792297] mc68-audio16 mc68-audio16: Found BIOS timer 0 @fa820000.
[    7.800476] mc68-audio16 mc68-audio16: Found BIOS timer 1 @fa088000.
[    7.808380] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    7.816375] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    7.824645] of_get_named_gpiod_flags: parsed 'frame-gpios' property of node '/mc68-audio16[0]' - status (0)
[    7.837432] gpio gpiochip3: Persistence not supported for GPIO 27
[    7.845092] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    7.853088] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    7.861358] of_get_named_gpiod_flags: can't parse 'frame-gpios' property of node '/mc68-audio16[1]'
[    7.873596] of_get_named_gpiod_flags: can't parse 'frame-gpio' property of node '/mc68-audio16[1]'
[    7.885925] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    7.894561] mc68-audio16 mc68-audio16: No GPIO consumer frame found
[    7.902557] mc68-audio16 mc68-audio16: Reusing frame clock gpio.
[    7.910308] mc68-audio16 mc68-audio16: GPIO lookup for consumer footsw
[    7.918518] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    7.926879] of_get_named_gpiod_flags: can't parse 'footsw-gpios' property of node '/mc68-audio16[0]'
[    7.939392] of_get_named_gpiod_flags: can't parse 'footsw-gpio' property of node '/mc68-audio16[0]'
[    7.951904] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    7.960601] mc68-audio16 mc68-audio16: No GPIO consumer footsw found
[    8.061370] ALSA device list:
[    8.066314]   No soundcards found.
[    8.086669] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[    8.096984] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    8.111877] devtmpfs: mounted
[    8.118316] Freeing unused kernel memory: 2048K
[    8.124938] Run /sbin/init as init process
[    8.130920]   with arguments:
[    8.135711]     /sbin/init
[    8.140197]     5
[    8.143890]   with environment:
[    8.148803]     HOME=/
[    8.152893]     TERM=linux
[    8.955078] systemd[1]: System time before build time, advancing clock.
[    8.976654] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    9.003784] systemd[1]: Detected architecture arm.
Welcome to Linux!
[    9.058380] systemd[1]: Set hostname to <am57xx-comp>.
[    9.405639] systemd[1]: /lib/systemd/system/dhcp.service:3: Failed to add dependency on network.targer, ignoring: Invalid argument
[    9.454925] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    9.471191] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    9.484466] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    9.528869] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    9.568786] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    9.609100] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    9.647827] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    9.687805] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    9.727813] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    9.798095] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.808471] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    9.848297] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    9.888244] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    9.928039] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    9.968139] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.981689] systemd[1]: Mounting POSIX Message Queue File System...
[   10.031372] systemd[1]: Mounting Kernel Debug File System...
[   10.085693] systemd[1]: Mounting Temporary Directory (/tmp)...
[   10.128204] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[   10.156921] systemd[1]: Starting Start psplash boot splash screen...
[   10.197998] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.215240] systemd[1]: Starting Journal Service...
[   10.288513] systemd[1]: Starting Load Kernel Modules...
[   10.328643] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.353393] cmemk: loading out-of-tree module taints kernel.
[   10.374298] CMEMK module: reference Linux version 5.10.168
[   10.383148] systemd[1]: Starting udev Coldplug all Devices...
[   10.395385] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[   10.428680] allocated heap buffer 0x40300000 of size 0x80000
         Starting udev Coldplug all Devices...[   10.439819] cmemk initialized
[   10.447570] ext4 filesystem being remounted at / supports timestamps until 2038 (0x7fffffff)
[   10.473236] systemd[1]: Started Start psplash boot splash screen.
[  OK  ] Started Start psplash boot splash screen.
[   10.518493] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[   10.533264] systemd[1]: Mounted Kernel Debug File System.
[   10.557922] cryptodev: driver 1.10 loaded.
[  OK  ] Mounted Kernel Debug File System.
[   10.570220] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[   10.648376] systemd[1]: Started Load Kernel Modules.
[  OK  ] Started Load Kernel Modules.
[   10.680633] systemd[1]: Started Remount Root and Kernel File Systems.
[  OK  ] Started Remount Root and Kernel File Systems.
[   10.699890] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.731903] systemd[1]: Mounting Kernel Configuration File System...
[   10.801300] systemd[1]: Started Start psplash-systemd progress communication helper.
[  OK  ] Started Start psplash-syst…progress communication helper.
[   10.859527] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.898803] systemd[1]: Starting Apply Kernel Variables...
[   10.918029] systemd[1]: Condition check resulted in Create System Users being skipped.
[   10.947631] systemd[1]: Starting Create Static Device Nodes in /dev...
[   11.009185] systemd[1]: Mounted Kernel Configuration File System.
[  OK  ] Mounted Kernel Configuration File System.
[   11.048034] systemd[1]: Started Apply Kernel Variables.
[  OK  ] Started Apply Kernel Variables.
[   11.088256] systemd[1]: Started Create Static Device Nodes in /dev.
[  OK  ] Started Create Static Device Nodes in /dev.
[   11.184234] systemd[1]: Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems (Pre).
[   11.255798] systemd[1]: Mounting /media/ram...
[   11.315856] systemd[1]: Mounting /var/volatile...
[   11.371124] systemd[1]: Starting udev Kernel Device Manager...
[   11.400665] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
[   11.547363] systemd-journald[146]: Received client request to flush runtime journal.
[  OK  ] Reached target Local File Systems.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Load/Save Random Seed.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Name Resolution...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started D-Bus System Message Bus.
         Starting detect model service...
[  OK  ] Started DHCP service.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting rc.pvr.service...
grep: /var/lib/opkg/info/*.control: No such file or directory
         Starting Login Service...
         Starting Permit User Sessions...
         Starting OpenSSH Key Generation...
[  OK  ] Started Print notice about GPLv3 packages.
[   14.521331] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 1
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Started Permit User Sessions.
[   14.697418] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[   14.793792] XXXX 48485000.mdio:00: attached PHY driver [XXX] (mii_bus:phy_addr=48485000.mdio:00, irq=POLL)
[   14.805847] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[  OK  ] Started detect model service.
[   14.922180] cpsw-switch 48484000.switch eth0: Link is Up - 100Mbps/Full - flow control off
[  OK  ] Started rc.pvr.service.
[  OK  ] Started OpenSSH Key Generation.
[  OK  ] Started Login Service.
[  OK  ] Reached target Network (Pre).
[  OK  ] Reached target Hardware activated USB gadget.
         Starting mount service...
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
         Starting thermal-zone-init.service...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started thermal-zone-init.service.
[   20.732635] EXT4-fs (mmcblk1p7): mounted filesystem with ordered data mode. Opts: (null)
[   20.955596] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[   20.963806] ext4 filesystem being mounted at /mnt/software supports timestamps until 2038 (0x7fffffff)
[  OK  ] Started mount service.
         Starting Launch GTX application service...
         Starting Launch GTX 57xx red black data path...
[  OK  ] Started Launch GTX 57xx red black data path.
[  OK  ] Started Launch GTX application service.
[  OK  ] Reached target Multi-User System.
[  OK  ] Reached target Graphical Interface.
         Starting Update UTMP about System Runlevel Changes...
[  OK  ] Started weston - Running as GTX.
[  OK  ] Started Update UTMP about System Runlevel Changes.
[   22.649414] DSP not available, yet.
[   22.657897] IPU not available, yet.
[   22.678405] davinci-mcasp8 48474000.mcasp: codec settings
[   22.698944] davinci-mcasp8 48474000.mcasp: codecdir=00000100
[   22.710052] davinci-mcasp8 48474000.mcasp: _set_sysclk()
[   22.734497] davinci-mcasp8 48474000.mcasp: _calc_clk_div(512000)
[   22.757843] davinci-mcasp8 48474000.mcasp: _common_hw_param(1)
[   22.774841] davinci-mcasp8 48474000.mcasp: (tdm_slots=4, channels=4, num_serializer=4, max=1)
[   22.786193] davinci-mcasp8 48474000.mcasp: (setting AXR0 to transmit)
[   22.798248] davinci-mcasp8 48474000.mcasp: _common_hw_param=AFIFO(+1,>4)
[   22.806640] davinci-mcasp8 48474000.mcasp: _clr_bits(ACLKXCTL,40)...
[   22.818328] davinci-mcasp8 48474000.mcasp: set PDIR +a0000000 +14000000...
[   22.826873] davinci-mcasp8 48474000.mcasp: bus clock master , stream 0
[   22.846343] davinci-mcasp8 48474000.mcasp: _config_channel_size()
[   22.866241] davinci-mcasp8 48460000.mcasp: codec settings
[   22.879760] davinci-mcasp8 48460000.mcasp: codecdir=00000100
[   22.889251] davinci-mcasp8 48460000.mcasp: _set_sysclk()
[   22.896972] davinci-mcasp8 48460000.mcasp: _calc_clk_div(512000)
[   22.907012] davinci-mcasp8 48460000.mcasp: _common_hw_param(1)
[   22.922698] davinci-mcasp8 48460000.mcasp: (tdm_slots=4, channels=4, num_serializer=16, max=1)
[   22.938018] davinci-mcasp8 48460000.mcasp: (setting AXR0 to transmit)
[   22.957916] davinci-mcasp8 48460000.mcasp: _common_hw_param=AFIFO(+1,>4)
[   22.968994] davinci-mcasp8 48460000.mcasp: _clr_bits(ACLKXCTL,40)...
[   22.987823] davinci-mcasp8 48460000.mcasp: set PDIR +a0000000 +14000000...
[   23.007904] davinci-mcasp8 48460000.mcasp: bus clock master , stream 0
[   23.015777] davinci-mcasp8 48460000.mcasp: _config_channel_size()
[   23.038055] davinci-mcasp8 48464000.mcasp: codec settings
[   23.044738] davinci-mcasp8 48464000.mcasp: codecdir=00010000
[   23.068023] davinci-mcasp8 48464000.mcasp: _set_sysclk()
[   23.074493] davinci-mcasp8 48464000.mcasp: setting external ACLKR
[   23.097747] davinci-mcasp8 48464000.mcasp: _common_hw_param(1)
[   23.104766] davinci-mcasp8 48464000.mcasp: (tdm_slots=4, channels=4, num_serializer=16, max=1)
[   23.127807] davinci-mcasp8 48464000.mcasp: (setting AXR0 to receive)
[   23.146514] davinci-mcasp8 48464000.mcasp: _common_hw_param=AFIFO(+1,>4)
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_[   23.167755] davinci-mcasp8 48464000.mcasp: _clr_bits(ACLKXCTL,40)...
  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project am57xx-comp [   23.187805] davinci-mcasp8 48464000.mcasp: set PDIR +a0000000 +14000000...
ttyS0
Arago 2021.09 am57xx-comp ttyS0
am57xx-comp login: [   23.217895] davinci-mcasp8 48464000.mcasp: bus clock slave
[   23.224609] davinci-mcasp8 48464000.mcasp: _config_channel_size()
[   23.247985] davinci-mcasp8 48478000.mcasp: codec settings
[   23.254577] davinci-mcasp8 48478000.mcasp: codecdir=00010000
[   23.267761] davinci-mcasp8 48478000.mcasp: _set_sysclk()
[   23.287841] davinci-mcasp8 48478000.mcasp: setting external ACLKR
[   23.295104] davinci-mcasp8 48478000.mcasp: _common_hw_param(1)
[   23.317901] davinci-mcasp8 48478000.mcasp: (tdm_slots=4, channels=4, num_serializer=4, max=1)
[   23.337738] davinci-mcasp8 48478000.mcasp: (setting AXR0 to receive)
[   23.345306] davinci-mcasp8 48478000.mcasp: _common_hw_param=AFIFO(+1,>4)
[   23.367797] davinci-mcasp8 48478000.mcasp: _clr_bits(ACLKXCTL,40)...
[   23.380004] davinci-mcasp8 48478000.mcasp: set PDIR +a0000000 +14000000...
[   23.391204] davinci-mcasp8 48478000.mcasp: bus clock slave
[   23.399322] davinci-mcasp8 48478000.mcasp: _config_channel_size()
[   23.419525] davinci-mcasp8 48478000.mcasp: GBLCTL write error: val 1
[   23.427246] davinci-mcasp8 4847c000.mcasp: codec settings
[   23.447753] davinci-mcasp8 4847c000.mcasp: codecdir=00010000
[   23.458557] davinci-mcasp8 4847c000.mcasp: _set_sysclk()
[   23.468566] davinci-mcasp8 4847c000.mcasp: setting external ACLKR
[   23.498168] davinci-mcasp8 4847c000.mcasp: _common_hw_param(1)
[   23.517761] davinci-mcasp8 4847c000.mcasp: (tdm_slots=4, channels=4, num_serializer=4, max=1)
[   23.537780] davinci-mcasp8 4847c000.mcasp: (setting AXR1 to receive)
[   23.548583] davinci-mcasp8 4847c000.mcasp: _common_hw_param=AFIFO(+1,>4)
[   23.567718] davinci-mcasp8 4847c000.mcasp: _clr_bits(ACLKXCTL,40)...
[   23.578643] davinci-mcasp8 4847c000.mcasp: set PDIR +a0000000 +14000000...
[   23.597778] davinci-mcasp8 4847c000.mcasp: bus clock slave
[   23.608581] davinci-mcasp8 4847c000.mcasp: _config_channel_size()
[   23.628875] davinci-mcasp8 4847c000.mcasp: GBLCTL write error: val 1
[   24.638854] davinci-mcasp8 48468000.mcasp: burst settings
[   24.657745] davinci-mcasp8 48468000.mcasp: burstdir=00020000
[   24.664520] davinci-mcasp8 48468000.mcasp: _set_sysclk()
[   24.677825] davinci-mcasp8 48468000.mcasp: setting external ACLKR
[   24.697845] davinci-mcasp8 48468000.mcasp: _common_hw_param(2)
[   24.706176] davinci-mcasp8 48468000.mcasp: (tdm_slots=1, channels=2, num_serializer=4, max=2)
[   24.727844] davinci-mcasp8 48468000.mcasp: (setting AXR0 to receive)
[   24.747741] davinci-mcasp8 48468000.mcasp: (setting AXR1 to receive)
[   24.758605] davinci-mcasp8 48468000.mcasp: _common_hw_param=AFIFO(+2,>32)
[   24.777801] davinci-mcasp8 48468000.mcasp: _set_bits(ACLKXCTL,40)...
[   24.797790] davinci-mcasp8 48468000.mcasp: set PDIR -a0000000 +14000000...
[   24.805877] davinci-mcasp8 48468000.mcasp: _config_channel_size()
[   24.827880] davinci-mcasp8 4846c000.mcasp: burst settings
[   24.834442] davinci-mcasp8 4846c000.mcasp: burstdir=00000200
[   24.857727] davinci-mcasp8 4846c000.mcasp: _set_sysclk()
[   24.864227] davinci-mcasp8 4846c000.mcasp: _calc_clk_div(16384000)
[   24.877807] davinci-mcasp8 4846c000.mcasp: _common_hw_param(2)
[   24.897857] davinci-mcasp8 4846c000.mcasp: (tdm_slots=1, channels=2, num_serializer=4, max=2)
[   24.917755] davinci-mcasp8 4846c000.mcasp: (setting AXR0 to transmit)
[   24.928558] davinci-mcasp8 4846c000.mcasp: (setting AXR1 to transmit)
[   24.947753] davinci-mcasp8 4846c000.mcasp: _common_hw_param=AFIFO(+2,>32)
[   24.958618] davinci-mcasp8 4846c000.mcasp: _set_bits(ACLKXCTL,40)...
[   24.977752] davinci-mcasp8 4846c000.mcasp: set PDIR -a0000000 +14000000...
[   24.988647] davinci-mcasp8 4846c000.mcasp: _config_channel_size()
[   26.056060] mc68-audio16 mc68-audio16: Enabling IPU clock.
[   26.065185] mc68-audio16 mc68-audio16: IPU clock = 425600KHz
[   26.072601] mc68-audio16 mc68-audio16: Power on IPU system.
[   26.079498] mc68-audio16 mc68-audio16: IPU GFCLK active.
[   26.084869] mc68-audio16 mc68-audio16: Initializing BIOS resources.
[   26.092742] mc68-audio16 mc68-audio16: Initializing IPU MMU.
[   26.099304] mc68-audio16 mc68-audio16: Releasing IPU Subsystem reset.
[   26.107147] mc68-audio16 mc68-audio16: IPU Subsystem Reset not released.
[   26.115386] mc68-audio16 mc68-audio16: Issuing soft resets to IPU MMUs.
[   26.122863] mc68-audio16 mc68-audio16: Filling IPU TLBs.
[   26.129394] mc68-audio16 mc68-audio16: Peeking while filling most of IPU AMMU.
[   26.136657] mc68-audio16 mc68-audio16: IPU early start completed.
[   26.144226] Running: 0
[   26.146606] dsp_check: 0
[   26.149536] ipu_check: -1
[   26.156585] ipu_running: 0
[   26.160583] cmd_linked 0, sxfer_mbox 0, shadow_rbsteer 0 0
[   26.166076] Zeroing IPU RAM space:
[   26.248596] mc68-audio16 mc68-audio16: SXfer mailbox acquired.
[   31.255554] ctx161-codec 2-0010: Progamming SPKROUT 1169 codec settings
[   31.270568] ctx161-codec 0-0010: Progamming AOUT 1169 codec settings
[   31.286987] ctx161-codec 1-0010: Progamming AIN 1169 codec settings
[   31.295135] ctx161-codec 1-0010: Progamming AIN 1169 codec settings slave timing
[   31.316986] ctx161-codec 2-0010: Progamming SPKROUT 1169 codec settings
[   31.335113] ctx161-codec 0-0010: Progamming AOUT 1169 codec settings
[   31.349945] ctx161-codec 1-0010: Progamming AIN 1169 codec settings
[   31.356292] ctx161-codec 1-0010: Progamming AIN 1169 codec settings slave timing
[   31.443542] mc68-audio16 mc68-audio16: Enabling DSP clock.
[   31.449157] mc68-audio16 mc68-audio16: DSP clock = 600000KHz
[   31.454864] mc68-audio16 mc68-audio16: Power on DSP system.
[   31.462677] mc68-audio16 mc68-audio16: DSP GFCLK not active.
[   31.469757] mc68-audio16 mc68-audio16: Initializing BIOS resources.
[   31.487640] mc68-audio16 mc68-audio16: Initializing DSP MMU.
[   31.498504] mc68-audio16 mc68-audio16: Releasing DSP System reset.
[   31.504699] mc68-audio16 mc68-audio16: Issuing soft resets to DSP MMUs.
[   31.513153] mc68-audio16 mc68-audio16: Filling DSP TLBs.
[   31.519287] Zeroing L2 space.
[   31.672546] mc68-audio16 mc68-audio16: Mixer mailbox acquired.
[   38.257995] aic_dvdd_fixed: disabling
[   38.268402] ldousb: disabling
[   43.260070] EXT4-fs (mmcblk1p5): mounted filesystem with ordered data mode. Opts: (null)
[   43.276550] ext4 filesystem being mounted at /tmp/update supports timestamps until 2038 (0x7fffffff)
am57xx-comp login: root
Password:
[  145.113311] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[  145.131561] XXXX 48485000.mdio:00: attached PHY driver [XXX] (mii_bus:phy_addr=48485000.mdio:00, irq=POLL)
[  145.153778] cpsw-switch 48484000.switch eth0: Link is Up - 100Mbps/Full - flow control off
   [  145.177856] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  145.243591] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
[  145.294189] XXX 48485000.mdio:01: attached PHY driver [XXX] (mii_bus:phy_addr=48485000.mdio:01, irq=POLL)
done.
root@am57xx-comp:~# Stopping Session c2 of user root.
[  OK  ] Removed slice system-getty.slice.
[  OK  ] Removed slice system-sshd.slice.
[  OK  ] Stopped target Network (Pre).
[  OK  ] Stopped target Host and Network Name Lookups.
[  OK  ] Stopped target Timers.
[  OK  ] Stopped Daily Cleanup of Temporary Directories.
[  OK  ] Stopped target Hardware activated USB gadget.
         Stopping Load/Save Random Seed...
         Stopping Network Name Resolution...
         Stopping weston - Running as GTX...
[  OK  ] Stopped OpenSSH Key Generation.
[  OK  ] Stopped Network Name Resolution.
[  OK  ] Stopped Serial Getty on ttyS0.
[  OK  ] Stopped weston - Running as GTX.
[  OK  ] Stopped Load/Save Random Seed.
[  OK  ] Stopped Session c1 of user gtx.
[  OK  ] Stopped Session c2 of user root.
[  OK  ] Removed slice system-serial\x2dgetty.slice.
[  OK  ] Stopped target Graphical Interface.
[  OK  ] Stopped target Multi-User System.
[  OK  ] Stopped target Login Prompts.
         Stopping Launch GTX application service...
[  OK  ] Stopped IPv6 Packet Filtering Framework.
[  OK  ] Stopped IPv4 Packet Filtering Framework.
         Stopping Login Service...
         Stopping thermal-zone-init.service...
         Stopping User Manager for UID 0...
         Stopping User Manager for UID 1000...
[  OK  ] Stopped thermal-zone-init.service.
         Stopping sshd.service...
[  OK  ] Stopped Login Service.
[  OK  ] Stopped User Manager for UID 1000.
[  OK  ] Stopped User Manager for UID 0.
[  OK  ] Stopped sshd.service.
[  OK  ] Stopped Launch GTX application service.
[  OK  ] Stopped mount service.
         Stopping detect model service...
         Stopping rc.pvr.service...
         Stopping User Runtime Directory /run/user/0...
         Stopping User Runtime Directory /run/user/1000...
[  OK  ] Unmounted /run/user/0.
[  OK  ] Unmounted /run/user/1000.
[  OK  ] Stopped detect model service.
[  OK  ] Stopped rc.pvr.service.
[  OK  ] Stopped User Runtime Directory /run/user/0.
[  OK  ] Stopped User Runtime Directory /run/user/1000.
[  OK  ] Removed slice User Slice of UID 0.
[  OK  ] Removed slice User Slice of UID 1000.
         Stopping D-Bus System Message Bus...
         Stopping Permit User Sessions...
[  OK  ] Stopped D-Bus System Message Bus.
[  OK  ] Stopped Permit User Sessions.
[  OK  ] Stopped target Basic System.
[  OK  ] Stopped target Paths.
[  OK  ] Stopped target Remote File Systems.
[  OK  ] Stopped target Slices.
[  OK  ] Removed slice User and Session Slice.
[  OK  ] Stopped target Sockets.
[  OK  ] Closed D-Bus System Message Bus Socket.
[  OK  ] Stopped target System Initialization.
[  OK  ] Stopped Apply Kernel Variables.
[  OK  ] Stopped Load Kernel Modules.
[  OK  ] Stopped Create Volatile Files and Directories.
[  OK  ] Stopped target Local File Systems.
         Unmounting /media/ram...
         Unmounting /mnt/software...
         Unmounting /mnt/storage...
         Unmounting Temporary Directory (/tmp)...
         Unmounting /var/volatile...
[  OK  ] Unmounted /media/ram.
[  OK  ] Unmounted /mnt/software.
[  OK  ] Unmounted /mnt/storage.
[  OK  ] Unmounted Temporary Directory (/tmp).
[  OK  ] Unmounted /var/volatile.
[  OK  ] Stopped target Local File Systems (Pre).
[  OK  ] Stopped target Swap.
[  OK  ] Reached target Unmount All Filesystems.
[  OK  ] Stopped Remount Root and Kernel File Systems.
[  OK  ] Stopped Create Static Device Nodes in /dev.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
[  OK  ] Started Reboot.
[  OK  ] Reached target Reboot.
[  358.388580] watchdog: watchdog0: watchdog did not stop!!
[  358.394042] CPU: 0 PID: 1 Comm: systemd Tainted: G           O      5.10.168-1-ctx #77
[  358.402099] Hardware name: Generic DRA74X (Flattened Device Tree)
[  358.408294] [<c020eac4>] (unwind_backtrace) from [<c0209d44>] (show_stack+0x10/0x14)
[  358.416198] [<c0209d44>] (show_stack) from [<c0c258c0>] (dump_stack+0x94/0xa8)
[  358.423522] [<c0c258c0>] (dump_stack) from [<c09b58f4>] (watchdog_release+0x160/0x18c)
[  358.431579] [<c09b58f4>] (watchdog_release) from [<c036b45c>] (__fput+0x78/0x234)
[  358.439208] [<c036b45c>] (__fput) from [<c0248b48>] (task_work_run+0x90/0xbc)
[  358.446472] [<c0248b48>] (task_work_run) from [<c0209a6c>] (do_work_pending+0x54c/0x554)
[  358.454681] [<c0209a6c>] (do_work_pending) from [<c02000c4>] (slow_work_pending+0xc/0x20)
[  358.463012] Exception stack(0xc1897fb0 to 0xc1897ff8)
[  358.468139] 7fa0:                                     00000000 b6f7d0a4 00000000 00000000
[  358.476440] 7fc0: 00000004 b6f7d5a0 00000000 00000006 055d4a80 00000000 000ac1b8 00112240
[  358.484771] 7fe0: 00000006 bec11ba0 b6cc0ef5 b6c41ae6 80000030 00000004
[  358.516601] systemd-shutdown[1]: Syncing filesystems and block devices.
[  358.530181] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[  358.544158] systemd-journald[146]: Received SIGTERM from PID 1 (systemd-shutdow).
[  358.571014] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[  358.583618] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[  358.593872] systemd-shutdown[1]: Unmounting file systems.
[  358.602172] [1044]: Remounting '/' read-only in with options '(null)'.
[  358.621887] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[  358.630187] systemd-shutdown[1]: All filesystems unmounted.
[  358.635955] systemd-shutdown[1]: Deactivating swaps.
[  358.642486] systemd-shutdown[1]: All swaps deactivated.
[  358.648101] systemd-shutdown[1]: Detaching loop devices.
[  358.657592] systemd-shutdown[1]: All loop devices detached.
[  358.663391] systemd-shutdown[1]: Detaching DM devices.
[  358.669036] systemd-shutdown[1]: All DM devices detached.
[  358.674560] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached.
[  358.698669] systemd-shutdown[1]: Syncing filesystems and block devices.
[  358.708801] systemd-shutdown[1]: Rebooting.
[  358.717834] mmc1: ===== EMMC EXT_CSD INFO =====
[  358.724029] mmc1: CACHE_CTRL [33]: 0x03 00
[  358.729858] mmc1: BKOPS_STATUS [246]: 0x00 00
[  358.735870] mmc1: BKOPS_EN [163]: 0x00 00 00
[  358.741821] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00 01
[  358.748748] mmc1: EXCEPTION_STATUS [54]: 0x01 00
[  358.754974] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000 [ 0x39473030 54513936 ]
[  358.765533] mmc1: NOTE 0 calling suspend
[  358.771057] mmc1: ===== EMMC EXT_CSD INFO =====
[  358.777130] mmc1: CACHE_CTRL [33]: 0x03 00
[  358.782775] mmc1: BKOPS_STATUS [246]: 0x00 00
[  358.788604] mmc1: BKOPS_EN [163]: 0x00 00 00
[  358.794281] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00 01
[  358.801055] mmc1: EXCEPTION_STATUS [54]: 0x01 00
[  358.807159] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000 [ 0x39473030 54513936 ]
[  358.824066] mmc1: 0 err = mmc_poweroff_notify(host->card, notify_type)
[  358.832092] mmc1: 0 mmc_power_off
[  358.838134] mmc1: 0 OUT mmc_release_host
[  369.137695] mmc1: Timeout waiting for hardware cmd interrupt.
[  369.144866] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  369.152709] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  369.160583] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  369.168457] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  369.176300] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  369.184173] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  369.192047] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  369.199890] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  369.207702] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  369.215515] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  369.223297] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  369.231079] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  369.238861] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  369.246643] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  369.254394] mmc1: sdhci: Host ctl2: 0x00000000
[  369.260101] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  369.267852] Present State: 0x01f00000
[  369.272766]   DAT Line Active: NO
[  369.277282]   Write Transfer: IDLE
[  369.281890]   Read Transfer: IDLE
[  369.286376]   DAT[3:0] Line Signal Level: 0xf
[  369.291931] mmc1: ===== EMMC EXT_CSD INFO =====
[  369.297698] mmc1: CACHE_CTRL [33]: 0x03
[  369.302734] mmc1: BKOPS_STATUS [246]: 0x00
[  369.308013] mmc1: BKOPS_EN [163]: 0x00
[  369.312896] mmc1: EXCEPTION_STATUS [54]: 0x01
[  369.318359] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  369.324523] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  369.332275] mmc1: sdhci: ============================================
[  369.440155] mmc1: Reset 0x2 never completed.
[  369.445556] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  369.453155] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  369.460754] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  369.468383] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  369.475982] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  369.483581] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  369.491210] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  369.498809] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  369.506439] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  369.514038] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  369.521636] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  369.529266] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  369.536865] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  369.544494] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  369.552093] mmc1: sdhci: Host ctl2: 0x00000000
[  369.557678] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  369.565246] Present State: 0x01f00000
[  369.570037]   DAT Line Active: NO
[  369.574493]   Write Transfer: IDLE
[  369.579010]   Read Transfer: IDLE
[  369.583435]   DAT[3:0] Line Signal Level: 0xf
[  369.588897] mmc1: ===== EMMC EXT_CSD INFO =====
[  369.594573] mmc1: CACHE_CTRL [33]: 0x03
[  369.599548] mmc1: BKOPS_STATUS [246]: 0x00
[  369.604766] mmc1: BKOPS_EN [163]: 0x00
[  369.609649] mmc1: EXCEPTION_STATUS [54]: 0x01
[  369.615112] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  369.621307] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  369.629089] mmc1: sdhci: ============================================
[  369.736663] mmc1: Reset 0x4 never completed.
[  369.742034] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  369.749633] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  369.757263] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  369.764862] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  369.772491] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  369.780120] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  369.787719] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  369.795349] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  369.802947] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  369.810546] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  369.818145] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  369.825744] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  369.833374] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  369.841003] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  369.848602] mmc1: sdhci: Host ctl2: 0x00000000
[  369.854156] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  369.861755] Present State: 0x01f00000
[  369.866546]   DAT Line Active: NO
[  369.870971]   Write Transfer: IDLE
[  369.875488]   Read Transfer: IDLE
[  369.879913]   DAT[3:0] Line Signal Level: 0xf
[  369.885375] mmc1: ===== EMMC EXT_CSD INFO =====
[  369.891052] mmc1: CACHE_CTRL [33]: 0x03
[  369.896026] mmc1: BKOPS_STATUS [246]: 0x00
[  369.901245] mmc1: BKOPS_EN [163]: 0x00
[  369.906127] mmc1: EXCEPTION_STATUS [54]: 0x01
[  369.911621] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  369.917785] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  369.925537] mmc1: sdhci: ============================================
[  380.017669] mmc1: Timeout waiting for hardware cmd interrupt.
[  380.024566] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  380.032165] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  380.039794] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  380.047424] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  380.055023] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  380.062652] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  380.070251] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  380.077880] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  380.085479] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  380.093109] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  380.100708] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  380.108306] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  380.115936] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  380.123565] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  380.131164] mmc1: sdhci: Host ctl2: 0x00000000
[  380.136749] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  380.144317] Present State: 0x01f00000
[  380.149108]   DAT Line Active: NO
[  380.153533]   Write Transfer: IDLE
[  380.158081]   Read Transfer: IDLE
[  380.162506]   DAT[3:0] Line Signal Level: 0xf
[  380.167999] mmc1: ===== EMMC EXT_CSD INFO =====
[  380.173675] mmc1: CACHE_CTRL [33]: 0x03
[  380.178619] mmc1: BKOPS_STATUS [246]: 0x00
[  380.183868] mmc1: BKOPS_EN [163]: 0x00
[  380.188751] mmc1: EXCEPTION_STATUS [54]: 0x01
[  380.194244] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  380.200439] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  380.208190] mmc1: sdhci: ============================================
[  380.315826] mmc1: Reset 0x2 never completed.
[  380.321197] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  380.328796] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  380.336395] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  380.344024] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  380.351654] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  380.359252] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  380.366882] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  380.374481] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  380.382110] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  380.389709] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  380.397308] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  380.404907] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  380.412536] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  380.420135] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  380.427734] mmc1: sdhci: Host ctl2: 0x00000000
[  380.433319] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  380.440917] Present State: 0x01f00000
[  380.445678]   DAT Line Active: NO
[  380.450134]   Write Transfer: IDLE
[  380.454650]   Read Transfer: IDLE
[  380.459075]   DAT[3:0] Line Signal Level: 0xf
[  380.464569] mmc1: ===== EMMC EXT_CSD INFO =====
[  380.470214] mmc1: CACHE_CTRL [33]: 0x03
[  380.475189] mmc1: BKOPS_STATUS [246]: 0x00
[  380.480407] mmc1: BKOPS_EN [163]: 0x00
[  380.485290] mmc1: EXCEPTION_STATUS [54]: 0x01
[  380.490783] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  380.496978] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  380.504730] mmc1: sdhci: ============================================
[  380.612304] mmc1: Reset 0x4 never completed.
[  380.617675] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  380.625274] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  380.632904] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  380.640502] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  380.648132] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  380.655731] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  380.663360] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  380.670959] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  380.678558] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  380.686157] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  380.693786] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  380.701385] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  380.709014] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  380.716644] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  380.724243] mmc1: sdhci: Host ctl2: 0x00000000
[  380.729797] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  380.737365] Present State: 0x01f00000
[  380.742156]   DAT Line Active: NO
[  380.746582]   Write Transfer: IDLE
[  380.751129]   Read Transfer: IDLE
[  380.755554]   DAT[3:0] Line Signal Level: 0xf
[  380.761016] mmc1: ===== EMMC EXT_CSD INFO =====
[  380.766693] mmc1: CACHE_CTRL [33]: 0x03
[  380.771667] mmc1: BKOPS_STATUS [246]: 0x00
[  380.776885] mmc1: BKOPS_EN [163]: 0x00
[  380.781768] mmc1: EXCEPTION_STATUS [54]: 0x01
[  380.787231] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  380.793426] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  380.801177] mmc1: sdhci: ============================================
[  390.897705] mmc1: Timeout waiting for hardware cmd interrupt.
[  390.904602] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  390.912200] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  390.919830] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  390.927429] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  390.935058] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  390.942657] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  390.950286] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  390.957916] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  390.965484] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  390.973114] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  390.980712] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  390.988311] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  390.995941] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  391.003570] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  391.011169] mmc1: sdhci: Host ctl2: 0x00000000
[  391.016754] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  391.024322] Present State: 0x01f00000
[  391.029113]   DAT Line Active: NO
[  391.033569]   Write Transfer: IDLE
[  391.038085]   Read Transfer: IDLE
[  391.042541]   DAT[3:0] Line Signal Level: 0xf
[  391.048004] mmc1: ===== EMMC EXT_CSD INFO =====
[  391.053680] mmc1: CACHE_CTRL [33]: 0x03
[  391.058654] mmc1: BKOPS_STATUS [246]: 0x00
[  391.063873] mmc1: BKOPS_EN [163]: 0x00
[  391.068756] mmc1: EXCEPTION_STATUS [54]: 0x01
[  391.074249] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  391.080413] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  391.088195] mmc1: sdhci: ============================================
[  391.196044] mmc1: Reset 0x2 never completed.
[  391.201446] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  391.209045] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  391.216644] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  391.224273] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  391.231872] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  391.239501] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  391.247100] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  391.254730] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  391.262329] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  391.269927] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  391.277557] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  391.285156] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  391.292785] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  391.300415] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  391.308013] mmc1: sdhci: Host ctl2: 0x00000000
[  391.313568] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  391.321166] Present State: 0x01f00000
[  391.325958]   DAT Line Active: NO
[  391.330383]   Write Transfer: IDLE
[  391.334930]   Read Transfer: IDLE
[  391.339355]   DAT[3:0] Line Signal Level: 0xf
[  391.344848] mmc1: ===== EMMC EXT_CSD INFO =====
[  391.350494] mmc1: CACHE_CTRL [33]: 0x03
[  391.355468] mmc1: BKOPS_STATUS [246]: 0x00
[  391.360717] mmc1: BKOPS_EN [163]: 0x00
[  391.365570] mmc1: EXCEPTION_STATUS [54]: 0x01
[  391.371063] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  391.377227] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  391.385009] mmc1: sdhci: ============================================
[  391.492584] mmc1: Reset 0x4 never completed.
[  391.497955] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  391.505554] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  391.513153] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  391.520782] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  391.528381] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  391.536010] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  391.543609] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  391.551239] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  391.558837] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  391.566436] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  391.574066] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  391.581634] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  391.589263] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  391.596893] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  391.604492] mmc1: sdhci: Host ctl2: 0x00000000
[  391.610046] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  391.617645] Present State: 0x01f00000
[  391.622406]   DAT Line Active: NO
[  391.626861]   Write Transfer: IDLE
[  391.631378]   Read Transfer: IDLE
[  391.635803]   DAT[3:0] Line Signal Level: 0xf
[  391.641296] mmc1: ===== EMMC EXT_CSD INFO =====
[  391.646972] mmc1: CACHE_CTRL [33]: 0x03
[  391.651916] mmc1: BKOPS_STATUS [246]: 0x00
[  391.657165] mmc1: BKOPS_EN [163]: 0x00
[  391.662048] mmc1: EXCEPTION_STATUS [54]: 0x01
[  391.667541] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  391.673706] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  391.681457] mmc1: sdhci: ============================================
[  401.777709] mmc1: Timeout waiting for hardware cmd interrupt.
[  401.784606] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  401.792205] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  401.799804] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  401.807434] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  401.815063] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  401.822662] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  401.830291] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  401.837921] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  401.845520] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  401.853118] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  401.860717] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  401.868347] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  401.875946] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  401.883575] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  401.891174] mmc1: sdhci: Host ctl2: 0x00000000
[  401.896759] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  401.904327] Present State: 0x01f00000
[  401.909118]   DAT Line Active: NO
[  401.913574]   Write Transfer: IDLE
[  401.918090]   Read Transfer: IDLE
[  401.922515]   DAT[3:0] Line Signal Level: 0xf
[  401.928009] mmc1: ===== EMMC EXT_CSD INFO =====
[  401.933685] mmc1: CACHE_CTRL [33]: 0x03
[  401.938659] mmc1: BKOPS_STATUS [246]: 0x00
[  401.943878] mmc1: BKOPS_EN [163]: 0x00
[  401.948760] mmc1: EXCEPTION_STATUS [54]: 0x01
[  401.954254] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  401.960418] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  401.968200] mmc1: sdhci: ============================================
[  402.076110] mmc1: Reset 0x2 never completed.
[  402.081512] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  402.089080] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  402.096710] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  402.104309] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  402.111938] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  402.119537] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  402.127166] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  402.134796] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  402.142395] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  402.149993] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  402.157592] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  402.165222] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  402.172821] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  402.180480] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  402.188079] mmc1: sdhci: Host ctl2: 0x00000000
[  402.193634] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  402.201202] Present State: 0x01f00000
[  402.205993]   DAT Line Active: NO
[  402.210449]   Write Transfer: IDLE
[  402.214965]   Read Transfer: IDLE
[  402.219390]   DAT[3:0] Line Signal Level: 0xf
[  402.224884] mmc1: ===== EMMC EXT_CSD INFO =====
[  402.230529] mmc1: CACHE_CTRL [33]: 0x03
[  402.235504] mmc1: BKOPS_STATUS [246]: 0x00
[  402.240753] mmc1: BKOPS_EN [163]: 0x00
[  402.245605] mmc1: EXCEPTION_STATUS [54]: 0x01
[  402.251098] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  402.257293] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  402.265045] mmc1: sdhci: ============================================
[  402.372650] mmc1: Reset 0x4 never completed.
[  402.378021] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[  402.385620] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[  402.393218] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[  402.400848] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[  402.408447] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[  402.416076] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[  402.423675] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[  402.431304] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[  402.438903] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[  402.446533] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[  402.454132] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[  402.461730] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[  402.469360] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[  402.476959] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[  402.484558] mmc1: sdhci: Host ctl2: 0x00000000
[  402.490142] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[  402.497711] Present State: 0x01f00000
[  402.502502]   DAT Line Active: NO
[  402.506958]   Write Transfer: IDLE
[  402.511474]   Read Transfer: IDLE
[  402.515899]   DAT[3:0] Line Signal Level: 0xf
[  402.521392] mmc1: ===== EMMC EXT_CSD INFO =====
[  402.527069] mmc1: CACHE_CTRL [33]: 0x03
[  402.532012] mmc1: BKOPS_STATUS [246]: 0x00
[  402.537261] mmc1: BKOPS_EN [163]: 0x00
[  402.542114] mmc1: EXCEPTION_STATUS [54]: 0x01
[  402.547607] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[  402.553802] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[  402.561553] mmc1: sdhci: ============================================
[  402.569763] mmc1: card 0001 removed
Fails after installing the new RFS but not yet switching partitions, if I power cycle it boots on new RFS
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.168-1-ctx (vagrant@0eb56e7c9d81) (arm-none-linux-gnueabihf-gcc (Arm GNU Toolchain 11.3.Rel1) 11.3.1 20220712, GNU ld (Arm GNU Toolchain 11.3.Rel1) 2.38.20220708) #77 SMP PREEMPT Tue Feb 3 20:15:37 UTC 2026
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: COMPU AM57XX
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009d000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 24 MiB at 0x00000000be800000
[    0.000000] OMAP4: Map 0x00000000afd00000 to (ptrval) for dram barrier
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000afcfffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x00000000afd00000-0x00000000bfffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000]   node   0: [mem 0x00000000a0000000-0x00000000abffffff]
[    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000afcfffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000bfffffff]
[    0.000000] On node 0 totalpages: 261376
[    0.000000]   DMA zone: 1722 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 195840 pages, LIFO batch:63
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] DRA722 ES2.0
[    0.000000] percpu: Embedded 16 pages/cpu s33292 r8192 d24052 u65536
[    0.000000] pcpu-alloc: s33292 r8192 d24052 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 259654
[    0.000000] Kernel command line: console=ttyO0,115200n8 omapdss.def_disp=lcd usbcore.autosuspend=-1 systemd.unit=graphical.target nosmp root=PARTUUID=67dc1a95-03 rw rootfstype=ext4 rootwait debug loglevel=8 console=tty0 systemd.log_level=info systemd.journald.max_level_console=notice sdhci.async_probe=0 5
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 695628K/1045504K available (12288K kernel code, 754K rwdata, 3816K rodata, 2048K init, 298K bss, 226996K reserved, 122880K cma-reserved, 237568K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] GIC CPU mask not found - kernel will fail to boot.
[    0.000000] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000000] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 65535999984741ns
[    0.001312] TI gptimer clockevent: always-on 32786 Hz at /ocp/interconnect@4ae00000/segment@10000/target-module@8000
[    0.001831] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@32000
[    0.002807] Incomplete dtb for percpu dmtimer /ocp/interconnect@48800000/segment@0/target-module@2a000
[    0.002929] TI gptimer percpu-dmtimer: 20000000 Hz at /ocp/interconnect@48800000/segment@0/target-module@2a000
[    0.003570] Console: colour dummy device 80x30
[    0.004089] printk: console [tty0] enabled
[    0.004119] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.004119] This ensures that you still see kernel messages. Please
[    0.004150] update your kernel commandline.
[    0.004180] Calibrating delay loop... 1993.93 BogoMIPS (lpj=9969664)
[    0.061950] pid_max: default: 32768 minimum: 301
[    0.062072] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.062103] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.062713] CPU: Testing write buffer coherency: ok
[    0.062774] CPU0: Spectre v2: firmware did not set auxiliary control register IBE bit, system vulnerable
[    0.062805] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[    0.062988] /cpus/cpu@0 missing clock-frequency property
[    0.062988] missing device node for CPU 1
[    0.063018] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.063568] Setting up static identity map for 0x80200000 - 0x80200060
[    0.063659] rcu: Hierarchical SRCU implementation.
[    0.063842] EFI services will not be available.
[    0.064392] smp: Bringing up secondary CPUs ...
[    0.064422] smp: Brought up 1 node, 1 CPU
[    0.064422] SMP: Total of 1 processors activated (1993.93 BogoMIPS).
[    0.064453] CPU: All CPU(s) started in HYP mode.
[    0.064453] CPU: Virtualization extensions available.
[    0.064788] devtmpfs: initialized
[    0.085418] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.085601] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.085632] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.087829] pinctrl core: initialized pinctrl subsystem
[    0.088348] DMI not present or invalid.
[    0.088806] NET: Registered protocol family 16
[    0.089874] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.092437] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.109924] thermal_sys: Registered thermal governor 'fair_share'
[    0.109954] thermal_sys: Registered thermal governor 'bang_bang'
[    0.109954] thermal_sys: Registered thermal governor 'step_wise'
[    0.109985] thermal_sys: Registered thermal governor 'user_space'
[    0.110748] cpuidle: using governor ladder
[    0.110809] cpuidle: using governor menu
[    1.252258] No ATAGs?
[    1.252288] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    1.252319] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    1.279632] reg-fixed-voltage fixedregulator-vdd_3v3: GPIO lookup for consumer (null)
[    1.279663] reg-fixed-voltage fixedregulator-vdd_3v3: using device tree for GPIO lookup
[    1.279693] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vdd_3v3[0]'
[    1.279724] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-vdd_3v3[0]'
[    1.279724] reg-fixed-voltage fixedregulator-vdd_3v3: using lookup tables for GPIO lookup
[    1.279754] reg-fixed-voltage fixedregulator-vdd_3v3: No GPIO consumer (null) found
[    1.279998] reg-fixed-voltage fixedregulator-aic_dvdd: GPIO lookup for consumer (null)
[    1.280029] reg-fixed-voltage fixedregulator-aic_dvdd: using device tree for GPIO lookup
[    1.280059] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-aic_dvdd[0]'
[    1.280059] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-aic_dvdd[0]'
[    1.280090] reg-fixed-voltage fixedregulator-aic_dvdd: using lookup tables for GPIO lookup
[    1.280120] reg-fixed-voltage fixedregulator-aic_dvdd: No GPIO consumer (null) found
[    1.280517] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    1.280517] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    1.280548] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    1.280639] reg-fixed-voltage fixedregulator-vtt: No GPIO consumer (null) found
[    1.281890] iommu: Default domain type: Passthrough
[    1.285034] SCSI subsystem initialized
[    1.285186] usbcore: registered new interface driver usbfs
[    1.285217] usbcore: registered new interface driver hub
[    1.285278] usbcore: registered new device driver usb
[    1.285858] mc: Linux media interface: v0.10
[    1.285888] videodev: Linux video capture interface: v2.00
[    1.285980] pps_core: LinuxPPS API ver. 1 registered
[    1.285980] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.286010] PTP clock support registered
[    1.286071] EDAC MC: Ver: 3.0.0
[    1.287231] Advanced Linux Sound Architecture Driver Initialized.
[    1.287902] clocksource: Switched to clocksource 32k_counter
[    1.293701] NET: Registered protocol family 2
[    1.293914] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.294738] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.294799] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.294860] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.295013] TCP: Hash tables configured (established 8192 bind 8192)
[    1.295074] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.295104] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.295257] NET: Registered protocol family 1
[    1.295654] RPC: Registered named UNIX socket transport module.
[    1.295684] RPC: Registered udp transport module.
[    1.295684] RPC: Registered tcp transport module.
[    1.295715] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.295715] PCI: CLS 0 bytes, default 64
[    1.297149] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.297271] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    1.298034] Initialise system trusted keyrings
[    1.298248] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.302093] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.302612] NFS: Registering the id_resolver key type
[    1.302673] Key type id_resolver registered
[    1.302673] Key type id_legacy registered
[    1.302764] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.302764] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.302795] ntfs: driver 2.1.32 [Flags: R/O].
[    1.303192] Key type asymmetric registered
[    1.303222] Asymmetric key parser 'x509' registered
[    1.303253] bounce: pool size: 64 pages
[    1.303314] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.303314] io scheduler mq-deadline registered
[    1.303344] io scheduler kyber registered
[    1.629974] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    1.774841] ti-sysc 4ae10000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.774902] ti-sysc 4ae10000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.781738] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
[    1.781829] gpio gpiochip0: registered GPIOs 0 to 31 on gpio-0-31
[    1.781860] OMAP GPIO hardware version 0.1
[    1.784698] ti-sysc: probe of 4ae18000.target-module failed with error -16
[    1.787414] ti-sysc: probe of 48032000.target-module failed with error -16
[    1.793029] ti-sysc 48051000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.793060] ti-sysc 48051000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.795135] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
[    1.795196] gpio gpiochip1: registered GPIOs 32 to 63 on gpio-32-63
[    1.795440] ti-sysc 48053000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.795471] ti-sysc 48053000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.797454] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
[    1.797515] gpio gpiochip2: registered GPIOs 64 to 95 on gpio-64-95
[    1.797729] ti-sysc 48055000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.797760] ti-sysc 48055000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.799896] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
[    1.799957] gpio gpiochip3: registered GPIOs 96 to 127 on gpio-96-127
[    1.800201] ti-sysc 48057000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.800231] ti-sysc 48057000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.802215] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4)
[    1.802307] gpio gpiochip4: registered GPIOs 128 to 159 on gpio-128-159
[    1.802520] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.802551] ti-sysc 48059000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.804443] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5)
[    1.804504] gpio gpiochip5: registered GPIOs 160 to 191 on gpio-160-191
[    1.804718] ti-sysc 4805b000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.804748] ti-sysc 4805b000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.806549] gpio gpiochip6: (gpio-192-223): added GPIO chardev (254:6)
[    1.806610] gpio gpiochip6: registered GPIOs 192 to 223 on gpio-192-223
[    1.806823] ti-sysc 4805d000.target-module: dts flag should be at module level for ti,no-idle-on-init
[    1.806854] ti-sysc 4805d000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.808746] gpio gpiochip7: (gpio-224-255): added GPIO chardev (254:7)
[    1.808807] gpio gpiochip7: registered GPIOs 224 to 255 on gpio-224-255
[    1.809020] ti-sysc 48060000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.809051] ti-sysc 48060000.target-module: dts flag should be at module level for ti,no-idle
[    1.811279] i2c i2c-2: GPIO lookup for consumer scl
[    1.811279] i2c i2c-2: using device tree for GPIO lookup
[    1.811340] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.811370] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.811401] i2c i2c-2: using lookup tables for GPIO lookup
[    1.811401] i2c i2c-2: No GPIO consumer scl found
[    1.811431] i2c i2c-2: GPIO lookup for consumer sda
[    1.811462] i2c i2c-2: using device tree for GPIO lookup
[    1.811492] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.811523] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0[0]'
[    1.811553] i2c i2c-2: using lookup tables for GPIO lookup
[    1.811553] i2c i2c-2: No GPIO consumer sda found
[    1.815155] omap_i2c 48060000.i2c: bus 2 rev0.12 at 100 kHz
[    1.818054] ti-sysc 48070000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.818084] ti-sysc 48070000.target-module: dts flag should be at module level for ti,no-idle
[    1.819915] i2c i2c-0: GPIO lookup for consumer scl
[    1.819946] i2c i2c-0: using device tree for GPIO lookup
[    1.819976] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.820037] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.820037] i2c i2c-0: using lookup tables for GPIO lookup
[    1.820068] i2c i2c-0: No GPIO consumer scl found
[    1.820098] i2c i2c-0: GPIO lookup for consumer sda
[    1.820098] i2c i2c-0: using device tree for GPIO lookup
[    1.820129] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.820190] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0[0]'
[    1.820190] i2c i2c-0: using lookup tables for GPIO lookup
[    1.820220] i2c i2c-0: No GPIO consumer sda found
[    1.821380] palmas 0-0058: Irq flag is 0x00000008
[    1.852661] palmas 0-0058: Muxing GPIO 2b, PWM 0, LED 0
[    1.857604] smps12: supplied by regulator-dummy
[    1.861755] smps3: supplied by regulator-dummy
[    1.865966] smps45: supplied by regulator-dummy
[    1.870544] smps6: supplied by regulator-dummy
[    1.874633] smps7: supplied by regulator-dummy
[    1.879180] smps8: supplied by regulator-dummy
[    1.883270] smps9: supplied by regulator-dummy
[    1.885650] ldo1: supplied by regulator-dummy
[    1.889129] ldo2: supplied by regulator-dummy
[    1.892608] ldo3: supplied by regulator-dummy
[    1.896087] ldo4: supplied by regulator-dummy
[    1.899688] LDO5: supplied by regulator-dummy
[    1.900360] LDO6: supplied by regulator-dummy
[    1.901031] LDO7: supplied by regulator-dummy
[    1.901702] LDO8: supplied by regulator-dummy
[    1.902709] ldo9: supplied by regulator-dummy
[    1.906646] ldoln: supplied by regulator-dummy
[    1.910125] ldousb: supplied by regulator-dummy
[    1.916015] gpiochip_find_base: found new base at 504
[    1.916168] gpio gpiochip8: (48070000.i2c:tps659038@58:tps659038_gpio): added GPIO chardev (254:8)
[    1.916229] gpio gpiochip8: registered GPIOs 504 to 511 on 48070000.i2c:tps659038@58:tps659038_gpio
[    1.917816] omap_i2c 48070000.i2c: bus 0 rev0.12 at 100 kHz
[    1.918792] ti-sysc 48072000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.918823] ti-sysc 48072000.target-module: dts flag should be at module level for ti,no-idle
[    1.920867] ti-sysc 4807a000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.920898] ti-sysc 4807a000.target-module: dts flag should be at module level for ti,no-idle
[    1.921905] i2c i2c-3: GPIO lookup for consumer scl
[    1.921936] i2c i2c-3: using device tree for GPIO lookup
[    1.921966] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.922027] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.922027] i2c i2c-3: using lookup tables for GPIO lookup
[    1.922058] i2c i2c-3: No GPIO consumer scl found
[    1.922088] i2c i2c-3: GPIO lookup for consumer sda
[    1.922088] i2c i2c-3: using device tree for GPIO lookup
[    1.922119] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.922180] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7a000/i2c@0[0]'
[    1.922210] i2c i2c-3: using lookup tables for GPIO lookup
[    1.922210] i2c i2c-3: No GPIO consumer sda found
[    1.922241] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[    1.922424] ti-sysc 4807c000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    1.922454] ti-sysc 4807c000.target-module: dts flag should be at module level for ti,no-idle
[    1.923431] i2c i2c-4: GPIO lookup for consumer scl
[    1.923461] i2c i2c-4: using device tree for GPIO lookup
[    1.923492] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923553] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923553] i2c i2c-4: using lookup tables for GPIO lookup
[    1.923583] i2c i2c-4: No GPIO consumer scl found
[    1.923614] i2c i2c-4: GPIO lookup for consumer sda
[    1.923614] i2c i2c-4: using device tree for GPIO lookup
[    1.923645] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923706] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@7c000/i2c@0[0]'
[    1.923706] i2c i2c-4: using lookup tables for GPIO lookup
[    1.923736] i2c i2c-4: No GPIO consumer sda found
[    1.923767] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    1.951477] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    1.953094] omap-mailbox 48846000.mailbox: omap mailbox rev 0x400
[    1.958801] edma 43300000.dma: memcpy is disabled
[    1.961486] edma 43300000.dma: TI EDMA DMA engine driver
[    1.976165] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[    1.976348] pinctrl-single 4a002e8c.pinmux: please update dts to use #pinctrl-cells = <1>
[    1.976409] pinctrl-single 4a002e8c.pinmux: initialized with no interrupts
[    1.976440] pinctrl-single 4a002e8c.pinmux: 1 pins, size 4
[    1.983886] clk-ctx160 2-004b: GPIO lookup for consumer reset
[    1.983917] clk-ctx160 2-004b: using device tree for GPIO lookup
[    1.983978] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0/clk_ctx160@4b[0]' - status (0)
[    1.984008] gpio gpiochip4: Persistence not supported for GPIO 25
[    2.009063] clk-ctx160 2-004b: Found AD9545.
[    2.009094] clk-ctx160 2-004b: Vers. 1.003
[    2.009094] clk-ctx160 2-004b: Configuration "ctx169" discovered.
[    2.009155] clk-ctx160 2-004b: XO source is board_49M152_osc.
[    2.009185] clk-ctx160 2-004b: REF_B source is board_otherside_clk.
[    2.009185] clk-ctx160 2-004b: REF_BB source is board_20M_clk.
[    2.009216] clk-ctx160 2-004b: Found 3 source clocks.
[    2.009246] clk-ctx160 2-004b: Creating output clock[0] clk_plogic_ref.
[    2.009399] clk-ctx160 2-004b: Creating output clock[1] clk_aux_sys.
[    2.009460] clk-ctx160 2-004b: Creating output clock[2] clk_audio_sys.
[    2.009552] clk-ctx160 2-004b: Creating output clock[3] clk_otherside_ref.
[    2.009643] clk-ctx160 2-004b: Creating output clock[4] clk_audio_framea.
[    2.009735] clk-ctx160 2-004b: Creating output clock[5] clk_audio_frameb.
[    2.009796] clk-ctx160 2-004b: Configuring 1169 DPLL
[    2.101593] clk-ctx160 2-004b: Added provider.
[    2.163391] clk-ctx160 2-004b: calibrated.
[    2.167724] vdd_3v3: supplied by regen1
[    2.168243] aic_dvdd_fixed: supplied by vdd_3v3
[    2.202606] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    2.206390] omap8250 4806a000.serial: GPIO lookup for consumer rs485-term
[    2.206420] omap8250 4806a000.serial: using device tree for GPIO lookup
[    2.206451] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@6a000/serial@0[0]'
[    2.206512] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@6a000/serial@0[0]'
[    2.206542] omap8250 4806a000.serial: using lookup tables for GPIO lookup
[    2.206542] omap8250 4806a000.serial: No GPIO consumer rs485-term found
[    2.206604] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 117, base_baud = 3000000) is a 8250
[    4.338165] printk: console [ttyS0] enabled
[    4.345275] omap_rng 48090000.rng: Random Number Generator ver. 20
[    4.351654] random: crng init done
[    4.364135] panel-simple display: GPIO lookup for consumer hpd
[    4.370056] panel-simple display: using device tree for GPIO lookup
[    4.376373] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/display[0]'
[    4.384887] of_get_named_gpiod_flags: can't parse 'hpd-gpio' property of node '/display[0]'
[    4.393310] panel-simple display: using lookup tables for GPIO lookup
[    4.399810] panel-simple display: No GPIO consumer hpd found
[    4.405548] panel-simple display: supply power not found, using dummy regulator
[    4.413024] panel-simple display: GPIO lookup for consumer enable
[    4.419158] panel-simple display: using device tree for GPIO lookup
[    4.425476] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display[0]'
[    4.434234] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display[0]'
[    4.442932] panel-simple display: using lookup tables for GPIO lookup
[    4.449432] panel-simple display: No GPIO consumer enable found
[    4.455383] panel-simple display: Specify missing bus_format
[    4.461090] panel-simple display: Expected bpc in {6,8} but got: 0
[    4.478210] brd: module loaded
[    4.486846] loop: module loaded
[    4.490386] at24 2-0051: supply vcc not found, using dummy regulator
[    4.496887] at24 2-0051: GPIO lookup for consumer wp
[    4.501953] at24 2-0051: using device tree for GPIO lookup
[    4.507507] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0/eeprom@51[0]'
[    4.521545] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/i2c@0/eeprom@51[0]'
[    4.535461] at24 2-0051: using lookup tables for GPIO lookup
[    4.541168] at24 2-0051: No GPIO consumer wp found
[    4.546630] at24 2-0051: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    4.553466] at24 0-0050: supply vcc not found, using dummy regulator
[    4.559997] at24 0-0050: GPIO lookup for consumer wp
[    4.565002] at24 0-0050: using device tree for GPIO lookup
[    4.570556] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/eeprom@50[0]'
[    4.584564] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/eeprom@50[0]'
[    4.598510] at24 0-0050: using lookup tables for GPIO lookup
[    4.604187] at24 0-0050: No GPIO consumer wp found
[    4.609619] at24 0-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[    4.616485] ctx161-codec 2-0010: assume XXXXXXXX
[    4.621246] ctx161-codec 2-0010: spkrout-1169 config required
[    4.627502] ctx161-codec 2-0010: Vers. 2.005  Rev. 52
[    4.632934] ctx161-codec 2-0010: Progamming SPKROUT 1169 codec settings
[    4.646850] ctx161-codec 0-0010: assume XXXXXXXX
[    4.651519] ctx161-codec 0-0010: aout-1169 config required
[    4.657043] ctx161-codec 0-0010: GPIO selectable at codec bus
[    4.662841] ctx161-codec 0-0010: GPIO lookup for consumer select
[    4.668884] ctx161-codec 0-0010: using device tree for GPIO lookup
[    4.675140] of_get_named_gpiod_flags: parsed 'select-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/codec@10[0]' - status (0)
[    4.690124] gpio gpiochip3: Persistence not supported for GPIO 20
[    4.696716] ctx161-codec 0-0010: Vers. 2.005  Rev. 52
[    4.702148] ctx161-codec 0-0010: Progamming AOUT 1169 codec settings
[    4.715637] ctx161-codec 0-0010: Programming mux selected seconday codec
[    4.722717] ctx161-codec 0-0010: Progamming AOUT 1169 codec settings
[    4.737548] mc68-audio16 v1.028: probing
[    4.741546] mc68-audio16 mc68-audio16: Found DSP clock.
[    4.746795] mc68-audio16 mc68-audio16: Found IPU clock.
[    4.752075] mc68-audio16 mc68-audio16: Using default DSP MMU0 @40d01000.
[    4.758850] mc68-audio16 mc68-audio16: Using default DSP MMU1 @40d02000.
[    4.765594] mc68-audio16 mc68-audio16: Using default IPU MMU @58882000.
[    4.772247] mc68-audio16 mc68-audio16: Assuming IPU Unicache @58880000.
[    4.779083] mc68-audio16 mc68-audio16: bios-timer 0 not available...yet?
[    4.785949] mc68-audio16 mc68-audio16: bios-timer 1 not available...yet?
[    4.792694] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    4.799194] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    4.805969] of_get_named_gpiod_flags: parsed 'frame-gpios' property of node '/mc68-audio16[0]' - status (0)
[    4.815765] gpio gpiochip3: Persistence not supported for GPIO 27
[    4.821929] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    4.828430] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    4.835174] of_get_named_gpiod_flags: can't parse 'frame-gpios' property of node '/mc68-audio16[1]'
[    4.844299] of_get_named_gpiod_flags: can't parse 'frame-gpio' property of node '/mc68-audio16[1]'
[    4.853363] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    4.860290] mc68-audio16 mc68-audio16: No GPIO consumer frame found
[    4.866577] mc68-audio16 mc68-audio16: Reusing frame clock gpio.
[    4.872650] mc68-audio16 mc68-audio16: GPIO lookup for consumer footsw
[    4.879211] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    4.885955] of_get_named_gpiod_flags: can't parse 'footsw-gpios' property of node '/mc68-audio16[0]'
[    4.895172] of_get_named_gpiod_flags: can't parse 'footsw-gpio' property of node '/mc68-audio16[0]'
[    4.904296] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    4.911224] mc68-audio16 mc68-audio16: No GPIO consumer footsw found
[    4.925445] clk: failed to reparent ipu-clkctrl:0000:0 to per_abe_x1_gfclk2_div: -22
[    4.933288] davinci-mcasp8 48460000.mcasp: Configured tdm_slots=4
[    4.939453] davinci-mcasp8 48460000.mcasp: Counted num_serializer=16
[    4.945861] davinci-mcasp8 48460000.mcasp: Assigned num_serializer=16
[    4.952362] davinci-mcasp8 48460000.mcasp: IRQ common not found
[    4.958618] davinci-mcasp8 48460000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    4.966766] davinci-mcasp8 48460000.mcasp: Adding Audio McASP power
[    4.973114] davinci-mcasp8 48460000.mcasp: Vers. 1.004
[    4.978637] clk: failed to reparent l4per2-clkctrl:0154:0 to per_abe_x1_gfclk2_div: -22
[    4.986724] davinci-mcasp8 48464000.mcasp: Configured tdm_slots=4
[    4.992858] davinci-mcasp8 48464000.mcasp: Counted num_serializer=16
[    4.999298] davinci-mcasp8 48464000.mcasp: Assigned num_serializer=16
[    5.005767] davinci-mcasp8 48464000.mcasp: IRQ common not found
[    5.011932] davinci-mcasp8 48464000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.020080] davinci-mcasp8 48464000.mcasp: Adding Audio McASP power
[    5.026397] davinci-mcasp8 48464000.mcasp: Vers. 1.004
[    5.031890] clk: failed to reparent l4per2-clkctrl:015c:0 to per_abe_x1_gfclk2_div: -22
[    5.040008] davinci-mcasp8 48468000.mcasp: welcome to Burst mode=4
[    5.046203] davinci-mcasp8 48468000.mcasp: Configured tdm_slots=1
[    5.052368] davinci-mcasp8 48468000.mcasp: Counted num_serializer=4
[    5.058685] davinci-mcasp8 48468000.mcasp: Assigned num_serializer=4
[    5.065093] davinci-mcasp8 48468000.mcasp: IRQ common not found
[    5.071228] davinci-mcasp8 48468000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.079406] davinci-mcasp8 48468000.mcasp: Vers. 1.004
[    5.084899] clk: failed to reparent l4per2-clkctrl:018c:0 to per_abe_x1_gfclk2_div: -22
[    5.092987] davinci-mcasp8 4846c000.mcasp: welcome to Burst mode=4
[    5.099212] davinci-mcasp8 4846c000.mcasp: Configured tdm_slots=1
[    5.105346] davinci-mcasp8 4846c000.mcasp: Counted num_serializer=4
[    5.111694] davinci-mcasp8 4846c000.mcasp: Assigned num_serializer=4
[    5.118103] davinci-mcasp8 4846c000.mcasp: IRQ common not found
[    5.124237] davinci-mcasp8 4846c000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.132385] davinci-mcasp8 4846c000.mcasp: Vers. 1.004
[    5.137878] clk: failed to reparent l4per2-clkctrl:01f8:0 to per_abe_x1_gfclk2_div: -22
[    5.145996] davinci-mcasp8 48474000.mcasp: Configured tdm_slots=4
[    5.152160] davinci-mcasp8 48474000.mcasp: Counted num_serializer=4
[    5.158508] davinci-mcasp8 48474000.mcasp: Assigned num_serializer=4
[    5.164886] davinci-mcasp8 48474000.mcasp: IRQ common not found
[    5.171020] davinci-mcasp8 48474000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.179199] davinci-mcasp8 48474000.mcasp: Adding Audio McASP power
[    5.185516] davinci-mcasp8 48474000.mcasp: Vers. 1.004
[    5.190979] clk: failed to reparent l4per2-clkctrl:01fc:0 to per_abe_x1_gfclk2_div: -22
[    5.199096] davinci-mcasp8 48478000.mcasp: Configured tdm_slots=4
[    5.205230] davinci-mcasp8 48478000.mcasp: Counted num_serializer=4
[    5.211547] davinci-mcasp8 48478000.mcasp: Assigned num_serializer=4
[    5.217956] davinci-mcasp8 48478000.mcasp: IRQ common not found
[    5.224090] davinci-mcasp8 48478000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.232269] davinci-mcasp8 48478000.mcasp: Adding Audio McASP power
[    5.238586] davinci-mcasp8 48478000.mcasp: Vers. 1.004
[    5.244049] clk: failed to reparent l4per2-clkctrl:0184:0 to per_abe_x1_gfclk2_div: -22
[    5.252166] davinci-mcasp8 4847c000.mcasp: Configured tdm_slots=4
[    5.258300] davinci-mcasp8 4847c000.mcasp: Counted num_serializer=4
[    5.264617] davinci-mcasp8 4847c000.mcasp: Assigned num_serializer=4
[    5.271026] davinci-mcasp8 4847c000.mcasp: IRQ common not found
[    5.277160] davinci-mcasp8 4847c000.mcasp: DMA controller compatible = "ti,edma3-tpcc"
[    5.285308] davinci-mcasp8 4847c000.mcasp: Adding Audio McASP power
[    5.291656] davinci-mcasp8 4847c000.mcasp: Vers. 1.004
[    5.303710] mdio_bus fixed-0: GPIO lookup for consumer reset
[    5.309448] mdio_bus fixed-0: using lookup tables for GPIO lookup
[    5.315582] mdio_bus fixed-0: No GPIO consumer reset found
[    5.326812] mdio_bus 48485000.mdio: GPIO lookup for consumer reset
[    5.333068] mdio_bus 48485000.mdio: using device tree for GPIO lookup
[    5.339599] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000[0]'
[    5.354156] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000[0]'
[    5.368621] mdio_bus 48485000.mdio: using lookup tables for GPIO lookup
[    5.375274] mdio_bus 48485000.mdio: No GPIO consumer reset found
[    5.437988] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    5.446472] mdio_bus 48485000.mdio:00: GPIO lookup for consumer reset
[    5.453002] mdio_bus 48485000.mdio:00: using device tree for GPIO lookup
[    5.459808] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@1[0]'
[    5.475708] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@1[0]'
[    5.491485] mdio_bus 48485000.mdio:00: using lookup tables for GPIO lookup
[    5.498413] mdio_bus 48485000.mdio:00: No GPIO consumer reset found
[    5.506164] mdio_bus 48485000.mdio:01: GPIO lookup for consumer reset
[    5.512695] mdio_bus 48485000.mdio:01: using device tree for GPIO lookup
[    5.519500] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@2[0]'
[    5.535400] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@48400000/segment@0/target-module@84000/switch@0/mdio@1000/ethernet-phy@2[0]'
[    5.551147] mdio_bus 48485000.mdio:01: using lookup tables for GPIO lookup
[    5.558105] mdio_bus 48485000.mdio:01: No GPIO consumer reset found
[    5.565124] davinci_mdio 48485000.mdio: phy[0]: device 48485000.mdio:00, driver XXXX
[    5.573913] davinci_mdio 48485000.mdio: phy[1]: device 48485000.mdio:01, driver XXXX
[    5.582977] cpsw-switch 48484000.switch: initialized cpsw ale version 1.4
[    5.589843] cpsw-switch 48484000.switch: ALE Table size 1024
[    5.595611] cpsw-switch 48484000.switch: cpts: overflow check period 500 (jiffies)
[    5.603240] cpsw-switch 48484000.switch: CPTS: ref_clk_freq:266000000 calc_mult:4036623398 calc_shift:30 error:-1 nsec/sec
[    5.614471] cpsw-switch 48484000.switch: Detected MACID = 00:0a:b6:01:82:ba
[    5.621520] cpsw-switch 48484000.switch: Detected MACID = 00:0a:b6:01:82:bb
[    5.629913] cpsw-switch 48484000.switch: initialized (regs 0x0000000048484000, pool size 256) hw_ver:0019010F 1.15 (0)
[    5.644531] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@4000
[    5.655761] dwc3 48890000.usb: changing max_speed on rev 5533202a
[    5.663452] OF: graph: no port node found in /ocp/interconnect@4a000000/segment@0/target-module@80000/ocp2scp@0/phy@5000
[    5.683258] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.689941] ehci-platform: EHCI generic platform driver
[    5.695739] ehci-omap: OMAP-EHCI Host Controller driver
[    5.701354] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.708862] usbcore: registered new interface driver ftdi_sio
[    5.714660] usbserial: USB Serial support registered for FTDI USB Serial Device
[    5.722076] usbcore: registered new interface driver ctx163
[    5.727691] usbcore: registered new interface driver ctx164
[    5.734588] g_serial gadget: Gadget Serial v2.4
[    5.739166] g_serial gadget: g_serial ready
[    5.744323] input: ar1021 I2C Touchscreen as /devices/platform/44000000.ocp/48000000.interconnect/48000000.interconnect:segment@0/48060000.target-module/48060000.i2c/i2c-2/2-004d/input/input0
[    5.762268] i2c /dev entries driver
[    5.768005] vpe 489d0000.vpe: loading firmware vpdma-1b8.bin
[    5.773773] Driver for 1-wire Dallas network protocol.
[    5.779479] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode
[    5.798034] vpe 489d0000.vpe: Device registered as /dev/video0
[    5.993133] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
[    6.002929] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    6.010803] power_supply bq27000-battery: power_supply_get_battery_info currently only supports devicetree
[    6.023925] sdhci: Secure Digital Host Controller Interface driver
[    6.030242] sdhci: Copyright(c) Pierre Ossman
[    6.036285] sdhci-pltfm: SDHCI platform and OF driver helper
[    6.044006] sdhci-omap 4809c000.mmc: GPIO lookup for consumer cd
[    6.051055] ledtrig-cpu: registered to indicate activity on CPUs
[    6.057708] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[    6.063934] sdhci-omap 480b4000.mmc: GPIO lookup for consumer cd
[    6.070007] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup
[    6.076629] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@9c000/mmc@0[0]' - status (0)
[    6.090454] sdhci-omap 480b4000.mmc: using device tree for GPIO lookup
[    6.097045] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.110473] omap-aes 4b500000.aes: will run requests pump with realtime priority
[    6.118255] gpio gpiochip7: Persistence not supported for GPIO 27
[    6.124420] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[    6.133392] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.146820] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[    6.152984] omap-aes 4b700000.aes: will run requests pump with realtime priority
[    6.161071] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    6.167144] sdhci-omap 480b4000.mmc: using lookup tables for GPIO lookup
[    6.173950] sdhci-omap 4809c000.mmc: Got CD GPIO
[    6.178619] sdhci-omap 4809c000.mmc: GPIO lookup for consumer wp
[    6.184661] sdhci-omap 4809c000.mmc: using device tree for GPIO lookup
[    6.191284] omap-des 480a5000.des: will run requests pump with realtime priority
[    6.198760] sdhci-omap 480b4000.mmc: No GPIO consumer cd found
[    6.204620] sdhci-omap 480b4000.mmc: GPIO lookup for consumer wp
[    6.211059] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@9c000/mmc@0[0]'
[    6.225280] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    6.231170] sdhci-omap 480b4000.mmc: using device tree for GPIO lookup
[    6.237762] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.251007] omap-sham 4b101000.sham: will run requests pump with realtime priority
[    6.258850] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@9c000/mmc@0[0]'
[    6.272552] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@b4000/mmc@0[0]'
[    6.286376] omap-sham 42701000.sham: hw accel on OMAP rev 4.3
[    6.292297] sdhci-omap 4809c000.mmc: using lookup tables for GPIO lookup
[    6.299194] omap-sham 42701000.sham: will run requests pump with realtime priority
[    6.306823] sdhci-omap 4809c000.mmc: No GPIO consumer wp found
[    6.312744] sdhci-omap 480b4000.mmc: using lookup tables for GPIO lookup
[    6.322113] sdhci-omap 4809c000.mmc: supply vqmmc not found, using dummy regulator
[    6.330780] hid: raw HID events driver (C) Jiri Kosina
[    6.336059] usbcore: registered new interface driver usbhid
[    6.341705] sdhci-omap 480b4000.mmc: No GPIO consumer wp found
[    6.347686] sdhci-omap 480b4000.mmc: supply vqmmc not found, using dummy regulator
[    6.355651] usbhid: USB HID core driver
[    6.359954] mmc0: sdhci: Version:   0x00003302 | Present:  0x00000000
[    6.366455] mmc0: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[    6.373077] mmc1: sdhci: Version:   0x00003302 | Present:  0x01f00000
[    6.380249] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer id
[    6.388702] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[    6.395233] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[    6.404235] mmc0: sdhci: Auto-CMD23 unavailable
[    6.408843] mmc1: sdhci: Auto-CMD23 unavailable
[    6.413391] sdhci-omap 480b4000.mmc: no pinctrl state for ddr_3_3v mode
[    6.420074] sdhci-omap 4809c000.mmc: no pinctrl state for sdr104 mode
[    6.426544] sdhci-omap 4809c000.mmc: no pinctrl state for ddr50 mode
[    6.433013] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]'
[    6.448974] sdhci-omap 4809c000.mmc: no pinctrl state for sdr50 mode
[    6.455352] sdhci-omap 4809c000.mmc: no pinctrl state for sdr25 mode
[    6.461853] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]'
[    6.477294] sdhci-omap 4809c000.mmc: no pinctrl state for sdr12 mode
[    6.483703] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[    6.490386] mmc1: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    6.497772] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup tables for GPIO lookup
[    6.508300] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[    6.514984] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: No GPIO consumer id found
[    6.523254] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[    6.530181] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup for consumer vbus
[    6.539093] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device tree for GPIO lookup
[    6.548278] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]'
[    6.564147] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@70000/i2c@0/tps659038@58/tps659038_usb[0]' - status (0)
[    6.580566] gpio gpiochip5: Persistence not supported for GPIO 21
[    6.593231] Error: Driver 'davinci-mcasp' is already registered, aborting...
[    6.601226] NET: Registered protocol family 10
[    6.606658] Segment Routing with IPv6
[    6.610504] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    6.616943] NET: Registered protocol family 17
[    6.621643] Key type dns_resolver registered
[    6.626037] mmc0: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    6.633300] Registering SWP/SWPB emulation handler
[    6.639038] omap_voltage_late_init: Voltage driver support not added
[    6.645416] Power Management for TI OMAP4+ devices.
[    6.650848] Loading compiled-in X.509 certificates
[    6.677764] mmc1: EXT_CSD_BKOPS_EN 0
[    6.687957] mmc1: EXT_CSD_BKOPS_SUPPORT[502]=1 AUTO_BKOPS_EN[163]=0bit is set, card->ext_csd.auto_bkops_en 0
[    6.697875] mmc1: Command Queue supported depth 32
[    6.707153] dmm 4e000000.dmm: workaround for errata i878 in use
[    6.715087] dmm 4e000000.dmm: initialized all PAT entries
[    6.720947] mmc1: NEB MODIFICATIONS: Do not turn on Cache (0)
[    6.726745] mmc1: new high speed MMC card at address 0001
[    6.733001] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    6.740844] mmcblk1: mmc1:0001 G1M15L 29.6 GiB
[    6.745605] mmcblk1boot0: mmc1:0001 G1M15L partition 1 31.5 MiB
[    6.751617] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    6.759582] mmcblk1boot1: mmc1:0001 G1M15L partition 2 31.5 MiB
[    6.765655] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    6.774841] mmcblk1rpmb: mmc1:0001 G1M15L partition 3 4.00 MiB, chardev (242:0)
[    6.782226] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
[    6.792022] gpio gpiochip1: Persistence not supported for GPIO 11
[    6.798278] vtt_fixed: supplied by smps3
[    6.804290] i2c i2c-1: GPIO lookup for consumer scl
[    6.809417] i2c i2c-1: using device tree for GPIO lookup
[    6.814941] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.828308] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.841491]  mmcblk1: p1 p2 p3 p4 < p5 p6 p7 >
[    6.846069] i2c i2c-1: using lookup tables for GPIO lookup
[    6.852722] i2c i2c-1: No GPIO consumer scl found
[    6.857452] i2c i2c-1: GPIO lookup for consumer sda
[    6.862426] i2c i2c-1: using device tree for GPIO lookup
[    6.867797] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.881103] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0[0]'
[    6.894256] i2c i2c-1: using lookup tables for GPIO lookup
[    6.899810] i2c i2c-1: No GPIO consumer sda found
[    6.905090] lm75 1-0048: supply vs not found, using dummy regulator
[    6.938629] hwmon hwmon2: temp1_input not attached to any thermal zone
[    6.945190] lm75 1-0048: hwmon2: sensor 'lm75'
[    6.950134] lm75 1-0049: supply vs not found, using dummy regulator
[    6.957122] hwmon hwmon3: temp1_input not attached to any thermal zone
[    6.963714] lm75 1-0049: hwmon3: sensor 'lm75'
[    6.968658] ctx161-codec 1-0010: assume XXXXXXXX
[    6.973327] ctx161-codec 1-0010: ain-1169 config required
[    6.978790] ctx161-codec 1-0010: GPIO selectable at codec bus
[    6.984558] ctx161-codec 1-0010: GPIO lookup for consumer select
[    6.990631] ctx161-codec 1-0010: using device tree for GPIO lookup
[    6.996887] of_get_named_gpiod_flags: parsed 'select-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/codec@10[0]' - status (0)
[    7.011871] gpio gpiochip3: Persistence not supported for GPIO 19
[    7.018035] ctx161-codec 1-0010: Panel Mic Codec Found
[    7.024475] ctx161-codec 1-0010: Vers. 2.005  Rev. 52
[    7.029693] ctx161-codec 1-0010: Progamming AIN 1169 codec settings
[    7.036010] ctx161-codec 1-0010: Progamming AIN 1169 codec settings slave timing
[    7.046600] ctx161-codec 1-0010: Programming mux selected seconday codec
[    7.053466] ctx161-codec 1-0010: Progamming AIN 1169 codec settings
[    7.059814] ctx161-codec 1-0010: Progamming AIN 1169 codec settings master timing
[    7.070983] lm75 1-004a: supply vs not found, using dummy regulator
[    7.078033] hwmon hwmon4: temp1_input not attached to any thermal zone
[    7.084594] lm75 1-004a: hwmon4: sensor 'lm75'
[    7.089813] ctx169-plogic 1-0020: Driver established
[    7.095489] ctx169-plogic 1-0020: Vers. 1.004  Rev. 1169ff02
[    7.101226] ctx169-plogic 1-0020: pd->headset_irq = 189
[    7.106506] ctx169-plogic 1-0020: pd->codec_irq = 190
[    7.111663] ctx169-plogic 1-0020: pd->panelmic_irq = 191
[    7.117889] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.123962] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.130310] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[0]' - status (0)
[    7.145904] gpio gpiochip5: Persistence not supported for GPIO 7
[    7.151977] gpio-167 (dipsw): no flags found for dipsw
[    7.157135] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.163208] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.169555] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[1]' - status (0)
[    7.185150] gpio gpiochip5: Persistence not supported for GPIO 8
[    7.191192] gpio-168 (dipsw): no flags found for dipsw
[    7.196380] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.202423] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.208770] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[2]' - status (0)
[    7.224365] gpio gpiochip5: Persistence not supported for GPIO 9
[    7.230438] gpio-169 (dipsw): no flags found for dipsw
[    7.235595] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.241668] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.248016] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[3]' - status (0)
[    7.263610] gpio gpiochip5: Persistence not supported for GPIO 10
[    7.269744] gpio-170 (dipsw): no flags found for dipsw
[    7.274932] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.280975] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.287322] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[4]' - status (0)
[    7.302947] gpio gpiochip0: Persistence not supported for GPIO 22
[    7.309082] gpio-22 (dipsw): no flags found for dipsw
[    7.314178] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.320220] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.326568] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[5]' - status (0)
[    7.342163] gpio gpiochip0: Persistence not supported for GPIO 23
[    7.348297] gpio-23 (dipsw): no flags found for dipsw
[    7.353393] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.359466] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.365783] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[6]' - status (0)
[    7.381378] gpio gpiochip0: Persistence not supported for GPIO 24
[    7.387512] gpio-24 (dipsw): no flags found for dipsw
[    7.392608] ctx169-plogic 1-0020: GPIO lookup for consumer dipsw
[    7.398681] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.405029] of_get_named_gpiod_flags: parsed 'dipsw-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[7]' - status (0)
[    7.420623] gpio gpiochip0: Persistence not supported for GPIO 25
[    7.426757] gpio-25 (dipsw): no flags found for dipsw
[    7.431854] ctx169-plogic 1-0020: GPIO lookup for consumer panel-mic-led
[    7.438629] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.444946] of_get_named_gpiod_flags: parsed 'panel-mic-led-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[0]' - status (0)
[    7.461242] gpio gpiochip1: Persistence not supported for GPIO 27
[    7.467376] gpio-59 (panel-mic-led): no flags found for panel-mic-led
[    7.473876] ctx169-plogic 1-0020: GPIO lookup for consumer panel-mic-ptt
[    7.480621] ctx169-plogic 1-0020: using device tree for GPIO lookup
[    7.486968] of_get_named_gpiod_flags: parsed 'panel-mic-ptt-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@72000/i2c@0/ctx169_plogic@20[0]' - status (0)
[    7.503265] gpio gpiochip1: Persistence not supported for GPIO 26
[    7.509429] gpio-58 (panel-mic-ptt): no flags found for panel-mic-ptt
[    7.518493] omap_i2c 48072000.i2c: bus 1 rev0.12 at 400 kHz
[    7.525665] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    7.533386] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    7.539764] platform 40800000.dsp: Adding to iommu group 0
[    7.546447] omap-iommu 58882000.mmu: 58882000.mmu registered
[    7.552520] platform 58820000.ipu: Adding to iommu group 1
[    7.559204] omap-iommu 55082000.mmu: 55082000.mmu registered
[    7.566467] DSS: OMAP DSS rev 6.1
[    7.573455] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    7.611572] [drm] Enabling DMM ywrap scrolling
[    7.695251] Console: switching to colour frame buffer device 100x30
[    7.720123] omapdrm omapdrm.0: [drm] fb0: omapdrmdrmfb frame buffer device
[    7.729553] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    7.739013] mc68-audio16 v1.028: probing
[    7.744781] mc68-audio16 mc68-audio16: Found DSP clock.
[    7.751892] mc68-audio16 mc68-audio16: Found IPU clock.
[    7.758911] mc68-audio16 mc68-audio16: Using default DSP MMU0 @40d01000.
[    7.767364] mc68-audio16 mc68-audio16: Using default DSP MMU1 @40d02000.
[    7.775787] mc68-audio16 mc68-audio16: Using default IPU MMU @58882000.
[    7.784088] mc68-audio16 mc68-audio16: Assuming IPU Unicache @58880000.
[    7.792572] mc68-audio16 mc68-audio16: Found BIOS timer 0 @fa820000.
[    7.800720] mc68-audio16 mc68-audio16: Found BIOS timer 1 @fa088000.
[    7.808624] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    7.816619] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    7.824890] of_get_named_gpiod_flags: parsed 'frame-gpios' property of node '/mc68-audio16[0]' - status (0)
[    7.837677] gpio gpiochip3: Persistence not supported for GPIO 27
[    7.845336] mc68-audio16 mc68-audio16: GPIO lookup for consumer frame
[    7.853363] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    7.861633] of_get_named_gpiod_flags: can't parse 'frame-gpios' property of node '/mc68-audio16[1]'
[    7.873840] of_get_named_gpiod_flags: can't parse 'frame-gpio' property of node '/mc68-audio16[1]'
[    7.886169] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    7.894836] mc68-audio16 mc68-audio16: No GPIO consumer frame found
[    7.902832] mc68-audio16 mc68-audio16: Reusing frame clock gpio.
[    7.910552] mc68-audio16 mc68-audio16: GPIO lookup for consumer footsw
[    7.918792] mc68-audio16 mc68-audio16: using device tree for GPIO lookup
[    7.927154] of_get_named_gpiod_flags: can't parse 'footsw-gpios' property of node '/mc68-audio16[0]'
[    7.939666] of_get_named_gpiod_flags: can't parse 'footsw-gpio' property of node '/mc68-audio16[0]'
[    7.952178] mc68-audio16 mc68-audio16: using lookup tables for GPIO lookup
[    7.960845] mc68-audio16 mc68-audio16: No GPIO consumer footsw found
[    8.061676] ALSA device list:
[    8.066619]   No soundcards found.
[    8.087615] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[    8.097991] VFS: Mounted root (ext4 filesystem) on device 179:3.
[    8.112762] devtmpfs: mounted
[    8.119232] Freeing unused kernel memory: 2048K
[    8.125823] Run /sbin/init as init process
[    8.131805]   with arguments:
[    8.136566]     /sbin/init
[    8.141082]     5
[    8.144775]   with environment:
[    8.149658]     HOME=/
[    8.153778]     TERM=linux
[    8.955566] systemd[1]: System time before build time, advancing clock.
[    8.976898] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    9.004028] systemd[1]: Detected architecture arm.
Welcome to Linux!
[    9.058715] systemd[1]: Set hostname to <am57xx-comp>.
[    9.089569] systemd[1]: Initializing machine ID from random generator.
[    9.429931] systemd[1]: /lib/systemd/system/dhcp.service:3: Failed to add dependency on network.targer, ignoring: Invalid argument
[    9.479705] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    9.495849] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    9.509185] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    9.549102] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    9.589019] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    9.628204] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    9.668060] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    9.708099] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    9.748077] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    9.818481] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.828857] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    9.868530] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    9.908508] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    9.948303] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    9.988372] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.001953] systemd[1]: Mounting POSIX Message Queue File System...
[   10.051666] systemd[1]: Mounting Kernel Debug File System...
[   10.105895] systemd[1]: Mounting Temporary Directory (/tmp)...
[   10.148406] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[   10.176666] systemd[1]: Starting Start psplash boot splash screen...
[   10.218292] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   10.235534] systemd[1]: Starting Journal Service...
[   10.318603] systemd[1]: Starting Load Kernel Modules...
[   10.352142] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.376342] cmemk: loading out-of-tree module taints kernel.
         Starting Remount Root and Kernel File Systems CMEMK module: reference Linux version 5.10.168
[0m...
[   10.412872] EXT4-fs (mmcblk1p3): re-mounted. Opts: (null)
[   10.431701] systemd[1]: Starting udev Coldplug all Devices...
[   10.456573] allocated heap buffer 0x40300000 of size 0x80000
[   10.465820] ext4 filesystem being remounted at / supports timestamps until 2038 (0x7fffffff)
[   10.483581] systemd[1]: Started Start psplash boot splash screen.
[   10.490478] cmemk initialized
[  OK  ] Started Start psplash boot splash screen.
[   10.548706] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[   10.570983] cryptodev: driver 1.10 loaded.
[   10.598571] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[   10.638702] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[   10.670501] systemd[1]: Started Load Kernel Modules.
[  OK  ] Started Load Kernel Modules.
[   10.698425] systemd[1]: Started Remount Root and Kernel File Systems.
[  OK  ] Started Remount Root and Kernel File Systems.
[   10.719390] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.760498] systemd[1]: Mounting Kernel Configuration File System...
[   10.801910] systemd[1]: Started Start psplash-systemd progress communication helper.
[  OK  ] Started Start psplash-syst…progress communication helper.
[   10.868652] systemd[1]: Starting Rebuild Hardware Database...
[   10.908813] systemd[1]: Starting Apply Kernel Variables...
[   10.971466] systemd[1]: Starting Create System Users...
[   11.013000] systemd[1]: Mounted Kernel Configuration File System.
[  OK  ] Mounted Kernel Configuration File System.
[   11.071258] systemd[1]: Started Rebuild Hardware Database.
[  OK  ] Started Rebuild Hardware Database.
[   11.101654] systemd[1]: Started Apply Kernel Variables.
[  OK  ] Started Apply Kernel Variables.
[   11.130676] systemd[1]: Started Create System Users.
[  OK  ] Started Create System Users.
[   11.208923] systemd[1]: Starting Create Static Device Nodes in /dev...
[   11.280670] systemd[1]: Started Create Static Device Nodes in /dev.
[  OK  ] Started Create Static Device Nodes in /dev.
[   11.308563] systemd[1]: Reached target Local File Systems (Pre).
[  OK  ] Reached target Local File Systems (Pre).
[   11.356079] systemd[1]: Mounting /media/ram...
[   11.415985] systemd[1]: Mounting /var/volatile...
[   11.471343] systemd[1]: Starting udev Kernel Device Manager...
[   11.501434] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Flush Journal to Persistent Storage...
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems   11.659820] systemd-journald[146]: Received client request to flush runtime journal.
0m.
         Starting Rebuild Dynamic Linker Cache...
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
[  OK  ] Started udev Kernel Device Manager.
         Starting Rebuild Journal Catalog...
         Starting Network Name Resolution...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Reached target Hardware activated USB gadget.
[   14.972564] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 1
[  OK  ] Started Rebuild Dynamic Linker Cache.
         Starting Run pending postinsts...
         Starting Update is Completed...
[  OK  ] Started Update is Completed.
[  OK  ] Started Run pending postinsts.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started D-Bus System Message Bus.
         Starting detect model service...
[  OK  ] Started DHCP service.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
grep: /var/lib/opkg/info/*.control: No such file or directory
         Starting rc.pvr.service...
[   20.624114] cpsw-switch 48484000.switch: starting ndev. mode: dual_mac
         Starting Login Service...
         Starting Permit User Sessions...
[   20.709808] XXXX 48485000.mdio:00: attached PHY driver [XXX] (mii_bus:phy_addr=48485000.mdio:00, irq=POLL)
         Starting OpenSSH Key Generation...
[   20.759399] cpsw-switch 48484000.switch eth0: Link is Up - 100Mbps/Full - flow control off
[   20.788726] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[  OK  ] Started Print notice about GPLv3 packages.
[  OK  ] Started IPv6 Packet Filtering Framework.
[   20.875854] mmc1: ===== EMMC EXT_CSD INFO =====
[  OK  ] Started IPv4 Packet Filtering Frame[   20.887207] mmc1: CACHE_CTRL [33]: 0x03 00
work.
[   20.895233] mmc1: BKOPS_STATUS [246]: 0x00 00
[   20.907135] mmc1: BKOPS_EN [163]: 0x00 00 00
[   20.917694] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00 01
[  OK  ] Started rc.pvr.service.[   20.931213] mmc1: EXCEPTION_STATUS [54]: 0x01 00
[   20.948089] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000 [ 0x39473030 54513936 ]
[   20.956787] mmc1: NOTE 0 calling suspend
[  OK  ] Started Permit User Sessions.
[  OK  ] Reached target Network (Pre).
[   21.018188] mmc1: ===== EMMC EXT_CSD INFO =====
[   21.022766] mmc1: CACHE_CTRL [33]: 0x03 00
[   21.026885] mmc1: BKOPS_STATUS [246]: 0x00 00
[  OK  ] Started Serial Getty on ttyS0.
[   21.058258] mmc1: BKOPS_EN [163]: 0x00 00 00
[   21.062561] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00 01
[   21.067901] mmc1: EXCEPTION_STATUS [54]: 0x01 00
[  OK  ] Reached target Login Prompts.
[   21.098571] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000 [ 0x39473030 54513936 ]
         Starting Synchronize System and HW clocks...
[   21.125335] mmc1: 0 err = mmc_poweroff_notify(host->card, notify_type)
[   21.138183] mmc1: 0 mmc_power_off
[   21.146820] mmc1: 0 OUT mmc_release_host
         Starting thermal-zone-init.service...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[  OK  ] Started thermal-zone-init.service.
[   31.217926] mmc1: Timeout waiting for hardware cmd interrupt.
[   31.223724] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   31.230194] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   31.236663] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   31.243133] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   31.249603] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   31.256072] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   31.262542] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   31.269012] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   31.275512] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   31.281982] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   31.288452] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   31.294921] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   31.301391] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   31.307861] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   31.314331] mmc1: sdhci: Host ctl2: 0x00000000
[   31.318786] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   31.325256] Present State: 0x01f00000
[   31.328948]   DAT Line Active: NO
[   31.332275]   Write Transfer: IDLE
[   31.335693]   Read Transfer: IDLE
[   31.339019]   DAT[3:0] Line Signal Level: 0xf
[   31.343383] mmc1: ===== EMMC EXT_CSD INFO =====
[   31.347961] mmc1: CACHE_CTRL [33]: 0x03
[   31.351806] mmc1: BKOPS_STATUS [246]: 0x00
[   31.355926] mmc1: BKOPS_EN [163]: 0x00
[   31.359680] mmc1: EXCEPTION_STATUS [54]: 0x01
[   31.364044] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   31.369140] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   31.375793] mmc1: sdhci: ============================================
[   31.485656] mmc1: Reset 0x2 never completed.
[   31.489959] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   31.496429] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   31.502899] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   31.509368] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   31.515838] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   31.522308] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   31.528778] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   31.535247] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   31.541717] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   31.548187] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   31.554656] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   31.561126] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   31.567596] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   31.574066] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   31.580566] mmc1: sdhci: Host ctl2: 0x00000000
[   31.585021] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   31.591491] Present State: 0x01f00000
[   31.595153]   DAT Line Active: NO
[   31.598480]   Write Transfer: IDLE
[   31.601898]   Read Transfer: IDLE
[   31.605255]   DAT[3:0] Line Signal Level: 0xf
[   31.609619] mmc1: ===== EMMC EXT_CSD INFO =====
[   31.614166] mmc1: CACHE_CTRL [33]: 0x03
[   31.618011] mmc1: BKOPS_STATUS [246]: 0x00
[   31.622131] mmc1: BKOPS_EN [163]: 0x00
[   31.625915] mmc1: EXCEPTION_STATUS [54]: 0x01
[   31.630279] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   31.635345] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   31.641998] mmc1: sdhci: ============================================
[   31.748474] mmc1: Reset 0x4 never completed.
[   31.752746] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   31.759216] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   31.765716] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   31.772186] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   31.778656] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   31.785125] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   31.791595] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   31.798065] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   31.804534] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   31.811004] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   31.817474] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   31.823944] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   31.830413] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   31.836883] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   31.843353] mmc1: sdhci: Host ctl2: 0x00000000
[   31.847808] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   31.854278] Present State: 0x01f00000
[   31.857971]   DAT Line Active: NO
[   31.861297]   Write Transfer: IDLE
[   31.864715]   Read Transfer: IDLE
[   31.868041]   DAT[3:0] Line Signal Level: 0xf
[   31.872436] mmc1: ===== EMMC EXT_CSD INFO =====
[   31.876983] mmc1: CACHE_CTRL [33]: 0x03
[   31.880828] mmc1: BKOPS_STATUS [246]: 0x00
[   31.884948] mmc1: BKOPS_EN [163]: 0x00
[   31.888702] mmc1: EXCEPTION_STATUS [54]: 0x01
[   31.893096] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   31.898162] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   31.904815] mmc1: sdhci: ============================================
[   38.257995] vdd_3v3: disabling
[   38.261077] aic_dvdd_fixed: disabling
[   38.265258] ldousb: disabling
[   42.097961] mmc1: Timeout waiting for hardware cmd interrupt.
[   42.103729] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   42.110198] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   42.116668] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   42.123168] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   42.129638] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   42.136108] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   42.142578] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   42.149047] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   42.155517] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   42.161987] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   42.168457] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   42.174926] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   42.181396] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   42.187866] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   42.194335] mmc1: sdhci: Host ctl2: 0x00000000
[   42.198822] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   42.205291] Present State: 0x01f00000
[   42.208953]   DAT Line Active: NO
[   42.212280]   Write Transfer: IDLE
[   42.215698]   Read Transfer: IDLE
[   42.219024]   DAT[3:0] Line Signal Level: 0xf
[   42.223419] mmc1: ===== EMMC EXT_CSD INFO =====
[   42.227966] mmc1: CACHE_CTRL [33]: 0x03
[   42.231811] mmc1: BKOPS_STATUS [246]: 0x00
[   42.235931] mmc1: BKOPS_EN [163]: 0x00
[   42.239715] mmc1: EXCEPTION_STATUS [54]: 0x01
[   42.244079] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   42.249145] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   42.255798] mmc1: sdhci: ============================================
[   42.362304] mmc1: Reset 0x2 never completed.
[   42.366607] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   42.373077] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   42.379547] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   42.386016] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   42.392486] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   42.398956] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   42.405426] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   42.411895] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   42.418365] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   42.424835] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   42.431304] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   42.437774] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   42.444244] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   42.450714] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   42.457183] mmc1: sdhci: Host ctl2: 0x00000000
[   42.461669] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   42.468139] Present State: 0x01f00000
[   42.471801]   DAT Line Active: NO
[   42.475128]   Write Transfer: IDLE
[   42.478546]   Read Transfer: IDLE
[   42.481872]   DAT[3:0] Line Signal Level: 0xf
[   42.486267] mmc1: ===== EMMC EXT_CSD INFO =====
[   42.490814] mmc1: CACHE_CTRL [33]: 0x03
[   42.494659] mmc1: BKOPS_STATUS [246]: 0x00
[   42.498779] mmc1: BKOPS_EN [163]: 0x00
[   42.502532] mmc1: EXCEPTION_STATUS [54]: 0x01
[   42.506927] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   42.511993] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   42.518646] mmc1: sdhci: ============================================
[   42.625122] mmc1: Reset 0x4 never completed.
[   42.629394] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   42.635864] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   42.642333] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   42.648803] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   42.655273] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   42.661743] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   42.668243] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   42.674713] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   42.681182] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   42.687652] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   42.694122] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   42.700592] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   42.707061] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   42.713531] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   42.720001] mmc1: sdhci: Host ctl2: 0x00000000
[   42.724456] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   42.730926] Present State: 0x01f00000
[   42.734619]   DAT Line Active: NO
[   42.737945]   Write Transfer: IDLE
[   42.741363]   Read Transfer: IDLE
[   42.744689]   DAT[3:0] Line Signal Level: 0xf
[   42.749053] mmc1: ===== EMMC EXT_CSD INFO =====
[   42.753631] mmc1: CACHE_CTRL [33]: 0x03
[   42.757476] mmc1: BKOPS_STATUS [246]: 0x00
[   42.761596] mmc1: BKOPS_EN [163]: 0x00
[   42.765350] mmc1: EXCEPTION_STATUS [54]: 0x01
[   42.769714] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   42.774810] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   42.781433] mmc1: sdhci: ============================================
[   52.977935] mmc1: Timeout waiting for hardware cmd interrupt.
[   52.983703] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   52.990173] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   52.996643] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   53.003112] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   53.009613] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   53.016082] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   53.022552] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   53.029022] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   53.035491] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   53.041961] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   53.048431] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   53.054901] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   53.061370] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   53.067840] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   53.074310] mmc1: sdhci: Host ctl2: 0x00000000
[   53.078796] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   53.085266] Present State: 0x01f00000
[   53.088928]   DAT Line Active: NO
[   53.092254]   Write Transfer: IDLE
[   53.095672]   Read Transfer: IDLE
[   53.098999]   DAT[3:0] Line Signal Level: 0xf
[   53.103393] mmc1: ===== EMMC EXT_CSD INFO =====
[   53.107940] mmc1: CACHE_CTRL [33]: 0x03
[   53.111785] mmc1: BKOPS_STATUS [246]: 0x00
[   53.115905] mmc1: BKOPS_EN [163]: 0x00
[   53.119689] mmc1: EXCEPTION_STATUS [54]: 0x01
[   53.124053] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   53.129119] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   53.135772] mmc1: sdhci: ============================================
[   53.242340] mmc1: Reset 0x2 never completed.
[   53.246643] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   53.253112] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   53.259582] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   53.266052] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   53.272521] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   53.278991] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   53.285461] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   53.291931] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   53.298400] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   53.304870] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   53.311340] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   53.317810] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   53.324279] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   53.330749] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   53.337249] mmc1: sdhci: Host ctl2: 0x00000000
[   53.341705] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   53.348175] Present State: 0x01f00000
[   53.351837]   DAT Line Active: NO
[   53.355163]   Write Transfer: IDLE
[   53.358581]   Read Transfer: IDLE
[   53.361907]   DAT[3:0] Line Signal Level: 0xf
[   53.366302] mmc1: ===== EMMC EXT_CSD INFO =====
[   53.370849] mmc1: CACHE_CTRL [33]: 0x03
[   53.374694] mmc1: BKOPS_STATUS [246]: 0x00
[   53.378814] mmc1: BKOPS_EN [163]: 0x00
[   53.382598] mmc1: EXCEPTION_STATUS [54]: 0x01
[   53.386962] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   53.392028] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   53.398681] mmc1: sdhci: ============================================
[   53.505157] mmc1: Reset 0x4 never completed.
[   53.509429] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   53.515899] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   53.522369] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   53.528839] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   53.535339] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   53.541809] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   53.548278] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   53.554748] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   53.561218] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   53.567687] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   53.574157] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   53.580627] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   53.587097] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   53.593566] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   53.600036] mmc1: sdhci: Host ctl2: 0x00000000
[   53.604492] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   53.610961] Present State: 0x01f00000
[   53.614654]   DAT Line Active: NO
[   53.617980]   Write Transfer: IDLE
[   53.621398]   Read Transfer: IDLE
[   53.624725]   DAT[3:0] Line Signal Level: 0xf
[   53.629089] mmc1: ===== EMMC EXT_CSD INFO =====
[   53.633666] mmc1: CACHE_CTRL [33]: 0x03
[   53.637512] mmc1: BKOPS_STATUS [246]: 0x00
[   53.641632] mmc1: BKOPS_EN [163]: 0x00
[   53.645385] mmc1: EXCEPTION_STATUS [54]: 0x01
[   53.649749] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   53.654846] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   53.661499] mmc1: sdhci: ============================================
[   63.857940] mmc1: Timeout waiting for hardware cmd interrupt.
[   63.863739] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   63.870208] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   63.876678] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   63.883148] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   63.889617] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   63.896087] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   63.902557] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   63.909027] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   63.915496] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   63.921997] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   63.928466] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   63.934936] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   63.941406] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   63.947875] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   63.954345] mmc1: sdhci: Host ctl2: 0x00000000
[   63.958801] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   63.965270] Present State: 0x01f00000
[   63.968963]   DAT Line Active: NO
[   63.972290]   Write Transfer: IDLE
[   63.975708]   Read Transfer: IDLE
[   63.979034]   DAT[3:0] Line Signal Level: 0xf
[   63.983398] mmc1: ===== EMMC EXT_CSD INFO =====
[   63.987976] mmc1: CACHE_CTRL [33]: 0x03
[   63.991821] mmc1: BKOPS_STATUS [246]: 0x00
[   63.995941] mmc1: BKOPS_EN [163]: 0x00
[   63.999694] mmc1: EXCEPTION_STATUS [54]: 0x01
[   64.004058] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   64.009155] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   64.015808] mmc1: sdhci: ============================================
[   64.122314] mmc1: Reset 0x2 never completed.
[   64.126586] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   64.133056] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   64.139526] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   64.145996] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   64.152496] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   64.158966] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   64.165435] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   64.171905] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   64.178375] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   64.184844] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   64.191314] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   64.197784] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   64.204254] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   64.210723] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   64.217193] mmc1: sdhci: Host ctl2: 0x00000000
[   64.221649] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   64.228118] Present State: 0x01f00000
[   64.231811]   DAT Line Active: NO
[   64.235137]   Write Transfer: IDLE
[   64.238555]   Read Transfer: IDLE
[   64.241882]   DAT[3:0] Line Signal Level: 0xf
[   64.246246] mmc1: ===== EMMC EXT_CSD INFO =====
[   64.250823] mmc1: CACHE_CTRL [33]: 0x03
[   64.254669] mmc1: BKOPS_STATUS [246]: 0x00
[   64.258789] mmc1: BKOPS_EN [163]: 0x00
[   64.262542] mmc1: EXCEPTION_STATUS [54]: 0x01
[   64.266906] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   64.272003] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   64.278625] mmc1: sdhci: ============================================
[   64.385101] mmc1: Reset 0x4 never completed.
[   64.389373] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
[   64.395843] mmc1: sdhci: Sys addr:  0x00000000 | Version:  0x00003302
[   64.402313] mmc1: sdhci: Blk size:  0x00000000 | Blk cnt:  0x00000000
[   64.408782] mmc1: sdhci: Argument:  0x00010000 | Trn mode: 0x00000000
[   64.415283] mmc1: sdhci: Present:   0x01f00000 | Host ctl: 0x00000000
[   64.421752] mmc1: sdhci: Power:     0x00000000 | Blk gap:  0x00000000
[   64.428222] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000000
[   64.434692] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
[   64.441162] mmc1: sdhci: Int enab:  0x007f0003 | Sig enab: 0x007f0003
[   64.447631] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[   64.454101] mmc1: sdhci: Caps:      0x25e90080 | Caps_1:   0x00000f77
[   64.460571] mmc1: sdhci: Cmd:       0x00000d1a | Max curr: 0x00000000
[   64.467041] mmc1: sdhci: Resp[0]:   0x00000000 | Resp[1]:  0x00000000
[   64.473510] mmc1: sdhci: Resp[2]:   0x00000000 | Resp[3]:  0x00000000
[   64.479980] mmc1: sdhci: Host ctl2: 0x00000000
[   64.484436] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000000
[   64.490905] Present State: 0x01f00000
[   64.494598]   DAT Line Active: NO
[   64.497924]   Write Transfer: IDLE
[   64.501342]   Read Transfer: IDLE
[   64.504669]   DAT[3:0] Line Signal Level: 0xf
[   64.509033] mmc1: ===== EMMC EXT_CSD INFO =====
[   64.513610] mmc1: CACHE_CTRL [33]: 0x03
[   64.517456] mmc1: BKOPS_STATUS [246]: 0x00
[   64.521575] mmc1: BKOPS_EN [163]: 0x00
[   64.525329] mmc1: EXCEPTION_STATUS [54]: 0x01
[   64.529693] mmc1: EXT_CSD_BKOPS_SUPPORT [0x1f6]: 0x00
[   64.534790] mmc1: EXT_CSD_FIRMWARE_VERSION [0xfe]: 0x00000000 00000000
[   64.541412] mmc1: sdhci: ============================================
[   64.567535] mmc1: card 0001 removed
  • Hello Nicole,
    I will need a couple of days to study your question and confer internally.
    I will come back to you by Friday or Monday.
    -Josue
  • Nicole,
    Still getting through the information.
    Can you clarify why bus-width =<1>?
    Example setup from am57xx-idk-common.dtsi:
    &mmc1 {
    	status = "okay";
    	vmmc-supply = <&v3_3d>;
    	vqmmc-supply = <&ldo1_reg>;
    	bus-width = <4>;
    	cd-gpios = <&gpio6 27 GPIO_ACTIVE_LOW>; /* gpio 219 */
    	no-1-8-v;
    &mmc2 {
    	status = "okay";
    	bus-width = <8>;
    	ti,non-removable;
    	max-frequency = <96000000>;
    	no-1-8-v;
    	/delete-property/ mmc-hs200-1_8v;
    -Josue
  • Hi Josue,
    Thanks for getting back to me - originally, that was what I had. I reduced it following some troubleshooting steps from 3.2.3.17. MMC/SD — Processor SDK Linux for AM57X Documentation 3.2.3.17.7. Steps for working around SD card issues: Reduce the bus width. This issue occured similarly at both bus widths, though it might be slightly less frequent at 1 vs 8
  • Nicole,
    Can you please tell me what SDK version you are using? I am assuming 8.2 (based on the kernel mentioned), is that correct?
    Also, RFS mean root file system right? making sure I understand you correctly.
    Have you tried disabling the watchdog and see if issue persists?
    Can you tell me the purpose of the sdhci-caps-mask property? What's the behavior without this property?
    -Josue
  • Hi Josue,
    Thanks! Yes to my meaning root file system, and for the most part, it is 8.2. We have several layers of graphics changes in order to support QT6, so we've started pulling in some layers from 09.03 around the graphics drivers, admittedly.  There was a bit of a learning curve on some bringup, so we didn't cleanly transition SDK versions in the way that might be more ideal. Unfortunately, the test where this is happening does require the graphics software to come up and do the new Rootfs install, but I will see if I can reproduce it through pure SCP/SSH so that falling back to a pure 8.2 SDK is an option, but I'll try your watchdog suggestion first. I'm trying to understand what may be going on, though, because my main hypothesis (background operations) were disproven when I disabled that and caching in the SDHCI driver and still saw the issue. I am still learning, and I guess I assumed that the watchdog error is more likely to be a symptom of a larger EMMC connection/response issue, as opposed to a possible cause. I'll run the loop install overnight and get back to you tomorrow if I see the error again once that watchdog is disabled. That also looks like it's set in dra7-l4,  wdt2: wdt@0 , so I'll take a closer look at disabling this
    The sdhci-caps-mask is mentioned also in that troubleshooting (granted, for the 9.03 SDK as the 8.02 SDK doesn't have much info on EMMC troubleshooting that I see), although taking a closer look, I don't think that was modified in our device tree layer, I think it is set in dra7-l4.dtsi (copied into bottom)
    I see it in our compiled (unmodified from 5.10) decompiled am57xx-evm-reva3.dtb devicetree:
    target-module@9c000 {
        compatible = "ti,sysc-omap4\0ti,sysc";
        reg = <0x9c000 0x04 0x9c010 0x04>;
        reg-names = "rev\0sysc";
        ti,sysc-mask = <0x03>;
        ti,sysc-midle = <0x00 0x01 0x02 0x03>;
        ti,sysc-sidle = <0x00 0x01 0x02 0x03>;
        clocks = <0x5b 0x08 0x00>;
        clock-names = "fck";
        #address-cells = <0x01>;
        #size-cells = <0x01>;
        ranges = <0x00 0x9c000 0x1000>;
        mmc@0 {
            compatible = "ti,dra7-sdhci";
            reg = <0x00 0x400>;
            interrupts = <0x00 0x4e 0x04>;
            status = "okay";
            pbias-supply = <0x9d>;
            max-frequency = <0xb71b000>;
            mmc-ddr-1_8v;
            mmc-ddr-3_3v;
            pinctrl-names = "default\0hs";
            pinctrl-0 = <0x9e>;
            bus-width = <0x04>;
            cd-gpios = <0x9f 0x1b 0x01>;
            no-1-8-v;
            pinctrl-1 = <0xa0>;
            vmmc-supply = <0x95>;
            vqmmc-supply = <0xa1>;
            phandle = <0x19e>;
    target-module@b4000 {
        reg = <0xb4000 0x04 0xb4010 0x04>;
        clocks = <0x5b 0x10 0x00>;
        ranges = <0x00 0xb4000 0x1000>;
        mmc@0 {
            reg = <0x00 0x400>;
            interrupts = <0x00 0x51 0x04>;
            status = "okay";
            sdhci-caps-mask = <0x07 0x00>;
            mmc-hs200-1_8v;
            mmc-ddr-1_8v;
            mmc-ddr-3_3v;
            pinctrl-names = "default\0hs\0ddr_3_3v";
            pinctrl-0 = <0xa2>;
            vqmmc-supply = <0x95>;
            bus-width = <0x08>;
            non-removable;
            no-1-8-v;
            pinctrl-1 = <0xa3>;
            pinctrl-2 = <0xa4>;
            phandle = <0x1a3>;
    target-module@b8000 {
        reg = <0xb8000 0x04 0xb8010 0x04>;
        clocks = <0x91 0xd8 0x00>;
        ranges = <0x00 0xb8000 0x1000>;
        spi@0 {
            compatible = "ti,omap4-mcspi";
            reg = <0x00 0x200>;
            interrupts = <0x00 0x56 0x04>;
            #size-cells = <0x00>;
            ti,spi-num-cs = <0x02>;
            dmas = <0x92 0x0f 0x92 0x10>;
            dma-names = "tx0\0rx0";
            status = "disabled";
            phandle = <0x1a4>;
    target-module@ba000 {
        reg = <0xba000 0x04 0xba010 0x04>;
        clocks = <0x91 0xe0 0x00>;
        ranges = <0x00 0xba000 0x1000>;
        spi@0 {
            reg = <0x00 0x200>;
            interrupts = <0x00 0x2b 0x04>;
            ti,spi-num-cs = <0x01>;
            dmas = <0x92 0x46 0x92 0x47>;
            phandle = <0x1a5>;
    target-module@d1000 {
        reg = <0xd1000 0x04 0xd1010 0x04>;
        clocks = <0x91 0x100 0x00>;
        ranges = <0x00 0xd1000 0x1000>;
        mmc@0 {
            reg = <0x00 0x400>;
            interrupts = <0x00 0x5b 0x04>;
            sdhci-caps-mask = <0x00 0x400000>;
            phandle = <0x1a6>;
    target-module@d5000 {
        compatible = "ti,sysc";
        ranges = <0x00 0xd5000 0x1000>;
  • Hi Josue, Sorry for the delay on this, I've been working on some other issues. I went back and reviewed my logs, and even with the watchdog disabled, we still have several cases of the on-startup
    "[   31.217498] mmc1: Timeout waiting for hardware cmd interrupt."
    without the watchdog error happening. I'll get back to you in a bit about rolling back as many custom changes to the SDK as possible to isolate if it still happens. If you have any other places or specific portions of the drivers you suggest I look at first, I'll happily take suggestions. Thanks!
  • Sounds Good Nicole!
    Have any HW issues been ruled out? What type of SD cards are being used? I have seen issues in the past with some XC cards.
    From the post above:
    mmc@0 {
            reg = <0x00 0x400>;
            status = "okay";
            mmc-hs200-1_8v;
            mmc-ddr-1_8v;
            mmc-ddr-3_3v;
            pinctrl-0 = <0xa2>;
            bus-width = <0x08>;
            non-removable;
            no-1-8-v;
            pinctrl-1 = <0xa3>;
            pinctrl-2 = <0xa4>;
            phandle = <0x1a3>;
    mmc@0 {
            reg = <0x00 0x400>;
            status = "okay";
            mmc-ddr-1_8v;
            mmc-ddr-3_3v;
            pinctrl-0 = <0x9e>;
            bus-width = <0x04>;
            no-1-8-v;
            pinctrl-1 = <0xa0>;
            phandle = <0x19e>;
    there are conflicting speed grades:
    mmc-hs200-1_8v; // HS200 mode REQUIRES 1.8V
    mmc-ddr-1_8v; // DDR mode at 1.8V
    no-1-8-v; // FORCES 3.3V-only operation
    This might be causing issues..
    -Josue
  • Hi Josue,
    Thank you! We actually aren't using an SD card, we're using an EMMC chip MTFC32GAZAQHD.
    I did a good chunk more investigation, falling back almost entirely to a 08.02 version SDK RFS build (with a bit of customization about which packages were installed), and isolated the problem to being related to 3 major things. In short, this error actually does not seem directly kernel or device tree related, but due to RFS race conditions/timing issues*. (Or that made it significantly worse... over the process of writing this out, I got another MMC crash after 300 or so reflashes of the RFS, significantly longer than before, which was about 1 in 15 reflashes of the RFS).
    1. (Biggest correlation). Our custom udev rules: We had some debugging run echos in our udev rules which were firing on block devices, and seem to have delayed processing long enough for some mmc errors to fire off.
    2. (Semi-related kernel crash) Our systemd services and udev handshakes, especially the PVR/SGX driver. In 08.02, the PVR driver is matched via kernel module aliasing and the initialization occurred in rc.pvr (written for sysvinit, but wrapped by systemd at build-time due to ARAGO_SYSVINIT being false). There seemed to be a good bit of variability in startup time and ordering, so I disabled the rc.pvr service and added a udev BIND rule which would fire as soon as the pvr module attached... which slowed it down (this is where my relative inexperience started to bite me a bit). I added pvrsrvkm to modules-load.d so it would load earlier in the boot process, and haven't seen any more PVR-related crashes. I'm still working on deepening my understanding of any broader implications of this change
    3. Custom application systemd services not properly checking via systemd if needed partitions were mounted by udev. (REQUIRES/AFTER=mmcblk1px.device). So I think there may have been some instability there in terms of boot timing and releasing partitions properly.
    So, I think what I mostly learned is that our udev rules and interactions were having a massive effect. I didn't see this error happen with the 08.02 SDK, but I didn't reflash it 300 times, I called it good after about 50. So it's possible that there is a problem and we were just triggering it more often with our udev rules. I'll update eventually if I find that our udev rules are/are not associated with this issue every 300 (reflashes + boots) or so.
    I am out of office until tomorrow.
    Thank you for your patience.
    -Josue
    Thank you for the update.
    I am glad you are finding the root cause.
    Josue
