I am trying to merge cfgdemo.prj (C:\CCStudio_v3.3\ndk_2_0_0_0\packages\ti\ndk\example\network\cfgdemo\common) into main.prj (C:\Program Files\Texas Instruments\edma3_lld_01_11_00_03\examples\edma3_driver\evmOMAPl137\ccs3). Both of the above work fine separately. But when I merge them together I get the following error:
undefined first referenced
symbol in file
_IFIndexGetHandle C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj
_IFMaxIndex C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/contest.obj
_pppoeFree C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj
_pppoeGetStatus C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj
_pppoeNew C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj
_pppoesFree C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj
_pppoesNew C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj
error: unresolved symbols remain
error: errors encountered during linking; "C:/Program Files/Texas
ug/main.out" not built
>> Compilation failure
gmake: *** [C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/main.out] Error 1
gmake: Target `all' not remade because of errors.
Build complete for project main
I have tried out the following:
1. Right click on project
Select "Build Properties"
Under the "Tool Settings" tab, select "File Search Path"
Look for the box labeled "Include library file or command file as input" and click the icon with a green plus sign
Add the library, "stack.lib"
2.Mannualy included stack.lib by right clicking on project, "Add Files" gave the path of stack.lib (C:\packages\ti\ndk\lib\C64plus\stack.lib)
3.Checked the makefile. It had the library included
"ORDERED_OBJS += \
$(GEN_CMDS_QUOTED) \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/ping_pong.cmd" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/qdma_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/qdma_link_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/oobsrv.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/nullsrv.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/maincfg_c.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/maincfg.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/main.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/evminit.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/echosrv.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/dma_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/dma_poll_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/dma_ping_pong_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/dma_misc_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/dma_link_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/dma_chain_test.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/datasrv.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/convlan.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/contftp.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/contest.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/constat.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/console.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/consock.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conroute.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conping.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conlli.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conipv6.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conipaddr.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conecho.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/condns.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/conacct.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/common.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/cgiparse.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/usermsg.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/tibug.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/default.obj" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/Debug/config.obj" \
-l"edma3_drv_bios_c674.lib" \
-l"edma3_drv_bios_sample.lib" \
-l"edma3_rm_bios.lib" \
-l"C:\CCStudio_v3.3\ndk_2_0_0_0\packages\ti\ndk\lib\C64plus\stack.lib" \
"../evmc6747bsl.lib" \
"../hal_eth_c6747.lib" \
"../hal_ser_stub.lib" \
"../hal_timer_bios.lib" \
"../hal_userled_stub.lib" \
"C:/Program Files/Texas Instruments/edma3_lld_01_11_00_03/examples/edma3_driver/evmOMAPl137/ccs3/main.cmd" \
"../miniPrintf.lib" \
"../netctrl.lib" \
"../nettool.lib" \
"../os.lib" \
"../stack.lib" \
-include ../makefile.init"
How to get rid of the errors? I have attached my project herewith. 8787.ccs3.zip. Help please.
