SK-AM62-LP: Flash issue
Part Number: SK-AM62-LP
There is a issue in AM62A device. It will log the following error after reflash and power on.
"omap_i2c 20010000.i2c: timeout waiting for bus ready"
"t1v320aic3x 1-001b: ASoC: error at snd_soc_component_update_bits on t1v320aic3x.1-001b for register: [0x00000013]-16"Image (1).jpg
    Can you let us know if the SoC you are using is AM62A or AM62? Also, what software version are you verifying with? Is it a custom board or TI's EVM?
    These will help to support you better.
    Best Regards
    Suren
  • Hi Suren:
    The SOC is "AM62A"
    The software image file is " tisdk-edgeai-image-am62a-evm-11.01.07.05.rootfs.wic.xz "
    It is TI''s EVM board
    Puyuan
    Are you seeing these errors on the dmesg upon boot with default image?
    Best Regards
    Suren
  • Hi:
    I'm not sure what is dmesg
    But there is no screen displayed from AM62A HDMI port, the above error message is from PuTTY.
    Thanks!
    Can you reflash the SD card with the default image and try again, as I don't see the issue on my boot logs when booting up AM62A EVM board.
    Does this happen on all the boot?
    Boot Log:
    U-Boot SPL 2025.01-00547-g3bcfad6cee95 (Jul 23 2025 - 16:49:22 +0000)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)')
    SPL initial stack usage: 13568 bytes
    Trying to boot from MMC2
    Authentication passed
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903b-dirty
    NOTICE:  BL31: Built : 07:01:36, Jul  1 2025
    DM ABI: 3.0 (firmware ver 0x000b 'MSDK.11.01.00.16-dirty--v11.01.02' patch_ver: 2)
    U-Boot 2025.01-00547-g3bcfad6cee95 (Jul 23 2025 - 16:49:22 +0000)
    SoC:   AM62AX SR1.0 HS-FS
    Model: Texas Instruments AM62A7 SK
    DRAM:  2 GiB (total 4 GiB)
    Core:  88 devices, 30 uclasses, devicetree: separate
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1
    Hit any key to stop autoboot:  0
    switch to partitions #0, OK
    mmc1 is current device
    SD/MMC found on device 1
    574 bytes read in 1 ms (560.5 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc1 ...
    22323712 bytes read in 231 ms (92.2 MiB/s)
    61919 bytes read in 4 ms (14.8 MiB/s)
    Working FDT set to 88000000
    564 bytes read in 3 ms (183.6 KiB/s)
       Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK
    Working FDT set to 8feed000
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.12.35-ti-00946-g72f48d59b8f0 (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Jul 22 20:20:40 UTC 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM62A7 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000e3ffffff (589824 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000adc00000, size 292 MiB
    [    0.000000] OF: reserved mem: initialized node edgeai-core-heap-memory@adc00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000adc00000..0x00000000bfffffff (299008 KiB) nomap non-reusable edgeai-core-heap-memory@adc00000
    [    0.000000] OF: reserved mem: initialized node edgeai_shared-memories, compatible id dma-heap-carveout
    [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000adbfffff (176128 KiB) map non-reusable edgeai_shared-memories
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 32 MiB
    [    0.000000] OF: reserved mem: initialized node edgeai-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a2ffffff (32768 KiB) nomap non-reusable edgeai-dma-memory@a1000000
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-dma-memory@99800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x0000000099800000..0x00000000998fffff (1024 KiB) nomap non-reusable c7x-dma-memory@99800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000099900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c7x-memory@99900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x0000000099900000..0x000000009a7fffff (15360 KiB) nomap non-reusable c7x-memory@99900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b800000..0x000000009b8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9b800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009b900000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9b900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009b900000..0x000000009c7fffff (15360 KiB) nomap non-reusable r5f-dma-memory@9b900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009c8fffff (1024 KiB) nomap non-reusable r5f-dma-memory@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c900000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9c900000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c900000..0x000000009e6fffff (30720 KiB) nomap non-reusable r5f-dma-memory@9c900000
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 16 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a0ffffff (16384 KiB) nomap non-reusable ipc-memories@a0000000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x00000000997fffff]
    [    0.000000]   node   0: [mem 0x0000000099800000-0x000000009a7fffff]
    [    0.000000]   node   0: [mem 0x000000009a800000-0x000000009b7fffff]
    [    0.000000]   node   0: [mem 0x000000009b800000-0x000000009e6fffff]
    [    0.000000]   node   0: [mem 0x000000009e700000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a2ffffff]
    [    0.000000]   node   0: [mem 0x00000000a3000000-0x00000000adbfffff]
    [    0.000000]   node   0: [mem 0x00000000adc00000-0x00000000bfffffff]
    [    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 22 pages/cpu s51672 r8192 d30248 u90112
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Unknown kernel command line parameters "mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern)", will be passed to user space.
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1048576
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000880050000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880060000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008641] Console: colour dummy device 80x25
    [    0.013238] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023920] pid_max: default: 32768 minimum: 301
    [    0.028725] LSM: initializing lsm=capability,selinux
    [    0.033854] SELinux:  Initializing.
    [    0.037835] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.045415] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.055525] rcu: Hierarchical SRCU implementation.
    [    0.060470] rcu:     Max phase no-delay instances is 1000.
    [    0.065993] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [    0.074688] EFI services will not be available.
    [    0.079550] smp: Bringing up secondary CPUs ...
    [    0.084759] Detected VIPT I-cache on CPU1
    [    0.084834] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.084850] GICv3: CPU1: using allocated LPI pending table @0x0000000880070000
    [    0.084896] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.085596] Detected VIPT I-cache on CPU2
    [    0.085656] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.085670] GICv3: CPU2: using allocated LPI pending table @0x0000000880080000
    [    0.085701] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.086336] Detected VIPT I-cache on CPU3
    [    0.086392] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.086405] GICv3: CPU3: using allocated LPI pending table @0x0000000880090000
    [    0.086437] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.086558] smp: Brought up 1 node, 4 CPUs
    [    0.166281] SMP: Total of 4 processors activated.
    [    0.171094] CPU: All CPU(s) started at EL2
    [    0.175299] CPU features: detected: 32-bit EL0 Support
    [    0.180558] CPU features: detected: CRC32 instructions
    [    0.185858] alternatives: applying system-wide alternatives
    [    0.192136] Memory: 2813032K/4194304K available (12992K kernel code, 1256K rwdata, 4668K rodata, 2752K init, 642K bss, 782460K reserved, 589824K cma-reserved)
    [    0.207619] devtmpfs: initialized
    [    0.219830] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.229836] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.250556] 27136 pages in range for non-PLT usage
    [    0.250576] 518656 pages in range for PLT usage
    [    0.255739] pinctrl core: initialized pinctrl subsystem
    [    0.266272] DMI not present or invalid.
    [    0.272348] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.279213] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
    [    0.286553] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.294632] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.302789] audit: initializing netlink subsys (disabled)
    [    0.308495] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
    [    0.308909] thermal_sys: Registered thermal governor 'step_wise'
    [    0.316432] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.322616] cpuidle: using governor menu
    [    0.333473] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.340502] ASID allocator initialised with 65536 entries
    [    0.351696] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.363200] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.376323] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.386250] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.399412] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.414699] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.427993] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.438723] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    0.453572] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.463520] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.475185] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.484434] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.494440] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.501420] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.507840] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.514782] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.521192] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.528133] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.534545] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.541486] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.549509] k3-chipinfo 43000014.chipid: Family:AM62AX rev:SR1.0 JTAGID[0x0bb8d02f] Detected
    [    0.558752] iommu: Default domain type: Translated
    [    0.563671] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.570433] SCSI subsystem initialized
    [    0.574639] usbcore: registered new interface driver usbfs
    [    0.580286] usbcore: registered new interface driver hub
    [    0.585743] usbcore: registered new device driver usb
    [    0.591391] pps_core: LinuxPPS API ver. 1 registered
    [    0.596471] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.605821] PTP clock support registered
    [    0.609862] EDAC MC: Ver: 3.0.0
    [    0.613442] scmi_core: SCMI protocol bus registered
    [    0.618702] FPGA manager framework
    [    0.622254] Advanced Linux Sound Architecture Driver Initialized.
    [    0.629354] vgaarb: loaded
    [    0.632440] clocksource: Switched to clocksource arch_sys_counter
    [    0.638931] VFS: Disk quotas dquot_6.6.0
    [    0.642969] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.657026] Carveout Heap: Exported 172 MiB at 0x00000000a3000000
    [    0.663365] NET: Registered PF_INET protocol family
    [    0.668540] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.678908] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
    [    0.687714] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.695652] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.703949] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
    [    0.712300] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.719158] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.726111] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
    [    0.733626] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.739883] RPC: Registered named UNIX socket transport module.
    [    0.745962] RPC: Registered udp transport module.
    [    0.750774] RPC: Registered tcp transport module.
    [    0.755584] RPC: Registered tcp-with-tls transport module.
    [    0.761194] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.767786] NET: Registered PF_XDP protocol family
    [    0.772703] PCI: CLS 0 bytes, default 64
    [    0.778068] Initialise system trusted keyrings
    [    0.782848] workingset: timestamp_bits=46 max_order=20 bucket_order=0
    [    0.789751] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.795971] NFS: Registering the id_resolver key type
    [    0.801172] Key type id_resolver registered
    [    0.805452] Key type id_legacy registered
    [    0.809568] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.816425] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.876770] Key type asymmetric registered
    [    0.880972] Asymmetric key parser 'x509' registered
    [    0.886036] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.893790] io scheduler mq-deadline registered
    [    0.898433] io scheduler kyber registered
    [    0.902562] io scheduler bfq registered
    [    0.909474] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.915994] pinctrl-single f4000.pinctrl: 151 pins, size 604
    [    0.923383] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.935378] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.950223] loop: module loaded
    [    0.954426] megasas: 07.727.03.00-rc1
    [    0.962123] tun: Universal TUN/TAP device driver, 1.6
    [    0.968311] VFIO - User Level meta-driver version: 0.3
    [    0.974798] usbcore: registered new interface driver usb-storage
    [    0.981529] i2c_dev: i2c /dev entries driver
    [    0.987426] sdhci: Secure Digital Host Controller Interface driver
    [    0.993768] sdhci: Copyright(c) Pierre Ossman
    [    0.998450] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.004888] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.012328] usbcore: registered new interface driver usbhid
    [    1.018047] usbhid: USB HID core driver
    [    1.023278] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
    [    1.033529] optee: probing for conduit method.
    [    1.038101] optee: revision 4.6 (71785645fa6ce42d)
    [    1.038435] optee: dynamic shared memory is enabled
    [    1.049025] optee: initialized driver
    [    1.049122] random: crng init done
    [    1.054655] Initializing XFRM netlink socket
    [    1.060677] NET: Registered PF_PACKET protocol family
    [    1.065925] Key type dns_resolver registered
    [    1.078612] registered taskstats version 1
    [    1.083015] Loading compiled-in X.509 certificates
    [    1.099759] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)')
    [    1.152272] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.165649] /bus@f0000/i2c@20000000/pmic@48: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@48/regulators/buck5
    [    1.177321] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.185021] pca953x 1-0023: supply vcc not found, using dummy regulator
    [    1.191939] pca953x 1-0023: using AI
    [    1.210659] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.219908] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.229846] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.239073] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.249160] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.256040] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.261966] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
    [    1.270299] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.279509] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.288548] ti-sci-inta 4e0a0000.interrupt-controller: Interrupt Aggregator domain 200 created
    [    1.298919] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.307539] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.318528] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.329307] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.338741] ti-udma 4e230000.dma-controller: Number of rings: 6
    [    1.345403] ti-udma 4e230000.dma-controller: Channels: 6 (bchan: 0, tchan: 0, rchan: 6)
    [    1.354856] printk: legacy console [ttyS2] disabled
    [    1.360234] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 249, base_baud = 3000000) is a 8250
    [    1.369125] printk: legacy console [ttyS2] enabled
    [    1.378835] printk: legacy bootconsole [ns16550a0] disabled
    [    1.394683] spi-nand spi0.0: Winbond SPI NAND was found.
    [    1.400041] spi-nand spi0.0: 128 MiB, block size: 256 KiB, page size: 4096, OOB size: 128
    [    1.408704] 7 fixed-partitions partitions found on MTD device spi0.0
    [    1.415081] Creating 7 MTD partitions on "spi0.0":
    [    1.419884] 0x000000000000-0x000000080000 : "ospi_nand.tiboot3"
    [    1.427223] 0x000000080000-0x000000280000 : "ospi_nand.tispl"
    [    1.434674] 0x000000280000-0x000000680000 : "ospi_nand.u-boot"
    [    1.442755] 0x000000680000-0x0000006c0000 : "ospi_nand.env"
    [    1.449473] 0x0000006c0000-0x000000700000 : "ospi_nand.env.backup"
    [    1.456901] 0x000002000000-0x000007fc0000 : "ospi_nand.rootfs"
    [    1.490964] 0x000007fc0000-0x000008000000 : "ospi_nand.phypattern"
    [    1.590446] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.636456] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.647510] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.655730] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.662862] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32
    [    1.670745] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.684562] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.694507] /bus@f0000/i2c@20000000/usb-power-controller@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.707427] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/usb-power-controller@3f/connector
    [    1.724713] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.730231] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.737997] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.744001] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010
    [    1.753427] xhci-hcd xhci-hcd.0.auto: irq 264, io mem 0x31100000
    [    1.760184] hub 1-0:1.0: USB hub found
    [    1.763969] hub 1-0:1.0: 1 port detected
    [    1.770907] mmc0: CQHCI version 5.10
    [    1.813032] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.862476] vddshv5_sdio: Bringing 1800000uV into 3300000-3300000uV
    [    1.896312] mmc0: Command Queue Engine enabled
    [    1.900779] mmc0: new HS200 MMC card at address 0001
    [    1.906277] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
    [    1.912630]  mmcblk0: p1
    [    1.915567] mmcblk0boot0: mmc0:0001 S0J56X 31.5 MiB
    [    1.921418] mmcblk0boot1: mmc0:0001 S0J56X 31.5 MiB
    [    1.927230] mmcblk0rpmb: mmc0:0001 S0J56X 4.00 MiB, chardev (239:0)
    [    2.057593] tps6594-rtc tps6594-rtc.5.auto: registered as rtc1
    [    2.064081] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    2.070836] pca953x 1-0022: using AI
    [    2.078895] clk: Disabling unused clocks
    [    2.081297] mmc1: CQHCI version 5.10
    [    2.090737] PM: genpd: Disabling unused power domains
    [    2.095892] ALSA device list:
    [    2.098917]   No soundcards found.
    [    2.125000] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.132726] Waiting for root device PARTUUID=076c4a2a-02...
    [    2.189826] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.196986] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
    [    2.206039]  mmcblk1: p1 p2
    [    2.400349] EXT4-fs (mmcblk1p2): mounted filesystem 2de87820-38c1-4f82-b29a-3612867993cc r/w with ordered data mode. Quota mode: none.
    [    2.412598] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.421201] devtmpfs: mounted
    [    2.424880] Freeing unused kernel memory: 2752K
    [    2.429498] Run /sbin/init as init process
    [    2.628838] systemd[1]: System time before build time, advancing clock.
    [    2.680427] NET: Registered PF_INET6 protocol family
    [    2.686389] Segment Routing with IPv6
    [    2.690113] In-situ OAM (IOAM) with IPv6
    [    2.724631] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.756529] systemd[1]: Detected architecture arm64.
    Welcome to Arago 2025.01!
    [    2.778882] systemd[1]: Hostname set to <am62axx-evm>.
    [    2.887173] systemd-sysv-generator[109]: SysV service '/etc/init.d/edgeai-launcher.sh' lacks a native systemd unit file, automatically generating a unit file for compatibility.
    [    2.902970] systemd-sysv-generator[109]: Please update package to include a native systemd unit file.
    [    2.912241] systemd-sysv-generator[109]: ! This compatibility logic is deprecated, expect removal soon. !
    [    3.098809] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.266397] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.329929] systemd[1]: Created slice Slice /system/getty.
    [  OK  ] Created slice Slice /system/getty.
    [    3.350706] systemd[1]: Created slice Slice /system/modprobe.
    [  OK  ] Created slice Slice /system/modprobe.
    [    3.370675] systemd[1]: Created slice Slice /system/serial-getty.
    [  OK  ] Created slice Slice /system/serial-getty.
    [    3.390172] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    3.408857] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    3.428778] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    3.448633] systemd[1]: Expecting device /dev/ttyS2...
    [    3.460673] systemd[1]: Reached target Path Units.
    [  OK  ] Reached target Path Units.
    [    3.472579] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    3.488575] systemd[1]: Reached target Slice Units.
    [  OK  ] Reached target Slice Units.
    [    3.500585] systemd[1]: Reached target Swaps.
    [  OK  ] Reached target Swaps.
    [    3.564730] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    3.584719] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    3.609230] systemd[1]: Listening on Process Core Dump Socket.
    [  OK  ] Listening on Process Core Dump Socket.
    [    3.628994] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [  OK  ] Listening on initctl Compatibility Named Pipe.
    [    3.649655] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    3.669196] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    3.689250] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    3.705374] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    3.728981] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    3.745098] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    3.761144] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    3.812781] systemd[1]: Mounting Huge Pages File System...
    [    3.828426] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.852619] systemd[1]: Mounting Kernel Debug File System...
    [    3.865104] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.884806] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.901992] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.924889] systemd[1]: Starting Load Kernel Module configfs...
    [    3.948988] systemd[1]: Starting Load Kernel Module drm...
    [    3.964967] systemd[1]: Starting Load Kernel Module fuse...
    [    3.995886] systemd[1]: Starting Start psplash boot splash screen...
             Starting Start psplash boot splash screen.[    4.002775] fuse: init (API version 7.41)
    [    4.024363] systemd[1]: Starting RPC Bind...
    [    4.036913] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    4.057002] systemd[1]: Starting Journal Service...
    [    4.076068] systemd[1]: Starting Load Kernel Modules...
    [    4.093459] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.116804] cryptodev: loading out-of-tree module taints kernel.
    [    4.117687] systemd[1]: Starting Remount Root and Kernel File Systems...
             Starting Remount Root and Kernel File Systems sysctl table check failed: ioctl/(null) procname is null
    [0m...
    [    4.141886] sysctl table check failed: ioctl/(null) No proc_handler
    [    4.147817] systemd-journald[129]: Collecting audit messages is enabled.
    [    4.148882] cryptodev: driver 1.14 loaded.
    [    4.160266] systemd[1]: Starting Coldplug All udev Devices...
    [    4.187215] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [    4.202955] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [    4.217836] EXT4-fs (mmcblk1p2): re-mounted 2de87820-38c1-4f82-b29a-3612867993cc.
    [    4.227464] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Mounted POSIX Message Queue File System.
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Temporary Directory /tmp.
    [  OK  ] Finished Create List of Static Device Nodes.
    [  OK  ] Finished Load Kernel Module configfs.
    [  OK  ] Finished Load Kernel Module drm.
    [  OK  ] Finished Load Kernel Module fuse.
    [FAILED] Failed to start Start psplash boot splash screen.
    See 'systemctl status psplash-start.service' for details.
    [DEPEND] Dependency failed for Start psplas…temd progress communication helper.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Generate network units from Kernel command line.
    [  OK  ] Finished Remount Root and Kernel File Systems.
             Mounting FUSE Control File System...
             Mounting Kernel Configuration File System...
             Starting Flush Journal to Persistent Storage...
             Starting Apply Kernel Variables...
             Starting Create Static Device Nodes in /dev gr[    4.545269] systemd-journald[129]: Received client request to flush runtime journal.
    acefully...
    [  OK  ] Mounted FUSE Control File System.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Finished Flush Journal to Persistent Storage.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
             Starting Create Static Device Nodes in /dev...
    [  OK  ] Finished Create Static Device Nodes in /dev.
    [  OK  ] Reached target Preparation for Local File Systems.
             Mounting /var/volatile...
    [    4.747034] audit: type=1334 audit(1748544504.112:2): prog-id=6 op=LOAD
    [    4.753756] audit: type=1334 audit(1748544504.120:3): prog-id=7 op=LOAD
             Starting Rule-based Manager for Device Events and Files...
    [  OK  ] Mounted /var/volatile.
             Starting Load/Save OS Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create System Files and Directories...
    [  OK  ] Finished Coldplug All udev Devices.
    [  OK  ] Finished Load/Save OS Random Seed.
    [  OK  ] Finished Create System Files and Directories.
    [    4.934229] audit: type=1334 audit(1748544504.300:4): prog-id=8 op=LOAD
             Starting Network Name Resolution...
    [    4.976395] audit: type=1334 audit(1748544504.340:5): prog-id=9 op=LOAD
             Starting Network Time Synchronization...
             Starting Record System Boot/Shutdown in UTMP...
    [    5.022832] audit: type=1334 audit(1748544504.388:6): prog-id=10 op=LOAD
    [    5.029696] audit: type=1334 audit(1748544504.400:7): prog-id=11 op=LOAD
    [    5.036509] audit: type=1334 audit(1748544504.404:8): prog-id=12 op=LOAD
             Starting User Database Manager...
    [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [  OK  ] Started User Database Manager.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
    [  OK  ] Found device /dev/ttyS2.
    [  OK  ] Started Network Time Synchronization.
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target System Time Set.[    5.527522] mtdblock: MTD device 'ospi_nand.tiboot3' is NAND, please consider using UBI block devices instead.
    [    5.548726] mtdblock: MTD device 'ospi_nand.tispl' is NAND, please consider using UBI block devices instead.
    [    5.548783] mtdblock: MTD device 'ospi_nand.env' is NAND, please consider using UBI block devices instead.
    [    5.561155] mtdblock: MTD device 'ospi_nand.rootfs' is NAND, please consider using UBI block devices instead.
    [    5.564690] mtdblock: MTD device 'ospi_nand.u-boot' is NAND, please consider using UBI block devices instead.
    [    5.567174] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
    [    5.592501] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Reached target Timer Units.
    [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
             Starting Docker Socket for the API...
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [    5.725427] audit: type=1334 audit(1748593655.688:9): prog-id=13 op=LOAD
             Starting D-Bus System Message Bus...
             Starting Reboot and dump vmcore via kexec...
    [  OK  ] Listening on Docker Socket for the API.
    [  OK  ] Finished Reboot and dump vmcore via kexec.
    [  OK  ] Started D-Bus System Message Bus.
    [  OK  ] Reached target Socket Units.
    [  OK  ] Reached target Basic System.
    [    6.077809] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Job spooling tools.
    [    6.115452] mtdblock: MTD device 'ospi_nand.env.backup' is NAND, please consider using UBI block devices instead.
             Starting Avahi mDNS/DNS-SD Stack...
    [    6.146787] mtdblock: MTD device 'ospi_nand.phypattern' is NAND, please consider using UBI block devices instead.
    [  OK  ] Started Periodic Command Scheduler.
             Starting Print notice about GPLv3 packages...
             Starting IPv6 Packet Filtering Framework...
             Starting IPv4 Packet Filtering Framework...
    [  OK  ] Started irqbalance daemon.
    [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
             Starting Telephony service...
             Starting PulseAudio Sound System...
             Starting Expand the rootfs partiti…to full size of the boot device....
    [  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [    6.300557] audit: type=1334 audit(1748593656.264:10): prog-id=14 op=LOAD
    [    6.307464] audit: type=1334 audit(1748593656.264:11): prog-id=15 op=LOAD
    [    6.307485] audit: type=1334 audit(1748593656.264:12): prog-id=16 op=LOAD
             Starting User Login Management...
             Starting Telnet Server...
    [  OK  ] Finished Telnet Server.
    [    6.398647] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fca100
    [    6.425728] omap-mailbox 29010000.mailbox: omap mailbox rev 0x66fca100
    [  OK  ] Finished IPv6 Packet Filtering Framework.
    [  OK  ] Finished IPv4 Packet Filtering Framework.
    [    6.447533] mc: Linux media interface: v0.10
    [    6.455607] omap-mailbox 29020000.mailbox: omap mailbox rev 0x66fca100
    [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [  OK  ] Reached target Preparation for Network.
    [    6.488809] audit: type=1334 audit(1748593656.456:13): prog-id=17 op=LOAD
    [    6.498784] omap-mailbox 29030000.mailbox: no available mbox devices found
    [    6.524509] videodev: Linux video capture interface: v2.00
             Starting Network Configuration...
    [  OK  ] Started Telephony service.
    [    6.590877] k3-dsp-rproc 7e000000.dsp: assigned reserved memory node c7x-dma-memory@99800000
    [    6.599759] k3-dsp-rproc 7e000000.dsp: configured DSP for remoteproc mode
    [    6.630892] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    6.631310] remoteproc remoteproc0: 7e000000.dsp is available
    [    6.645145] platform 79000000.r5f: configured R5F for remoteproc mode
    [    6.655026] platform 79000000.r5f: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.664085] remoteproc remoteproc1: 79000000.r5f is available
    [    6.690133] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    6.702828] platform 78000000.r5f: configured R5F for IPC-only mode
    [    6.716853] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.727574] remoteproc remoteproc2: 78000000.r5f is available
    [    6.733672] remoteproc remoteproc2: attaching to 78000000.r5f
    [    6.740120] rproc-virtio rproc-virtio.7.auto: assigned reserved memory node r5f-dma-memory@9c800000
    [    6.750024] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    6.750260] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [    6.756251] rproc-virtio rproc-virtio.7.auto: registered virtio0 (type 7)
    [    6.762915] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    6.769701] remoteproc remoteproc2: remote processor 78000000.r5f is now attached
    [    6.776858] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0x15
    [    6.792257] remoteproc remoteproc1: powering up 79000000.r5f
    [    6.798481] remoteproc remoteproc1: Booting fw image am62a-mcu-r5f0_0-fw, size 54164
    [    6.807522] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@9b800000
    [    6.852654] Bluetooth: Core ver 2.22
    [    6.859187] NET: Registered PF_BLUETOOTH protocol family
    [    6.867741] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    6.868515] Bluetooth: HCI device and connection manager initialized
    [    6.873357] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    6.884986] Bluetooth: HCI socket layer initialized
    [    6.894525] Bluetooth: L2CAP socket layer initialized
    [    6.894693] rproc-virtio rproc-virtio.8.auto: registered virtio1 (type 7)
    [    6.899693] Bluetooth: SCO socket layer initialized
    [  OK  ] Finished Expand the rootfs partitio[    6.917455] remoteproc remoteproc1: remote processor 79000000.r5f is now up
    n to full size of the boot device..
    [    6.946643] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    7.085459] remoteproc remoteproc0: powering up 7e000000.dsp
    [    7.091774] remoteproc remoteproc0: Booting fw image am62a-c71_0-fw, size 19210280
    [    7.101484] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    7.124196] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [    7.137915] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [    7.140866] vdec 30210000.video-codec: OPP table not found in device tree
    [    7.142527] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    7.142807] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    7.155204] i2c i2c-1: Added multiplexed i2c bus 3
    [    7.161197] [drm] Initialized tidss 1.0.0 for 30200000.dss on minor 0
    [    7.166980] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [    7.169266] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node c7x-dma-memory@99800000
    [    7.170307] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    7.176814] vdec 30210000.video-codec: Product Code:      0x521c
    [    7.184514] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    7.191001] vdec 30210000.video-codec: Firmware Revision: 363254
    [    7.204612] virtio_rpmsg_bus virtio2: rpmsg host is online
    [    7.215069] e5010 fd20000.jpeg-encoder: Device registered as /dev/video2
    [    7.218917] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [    7.263295] virtio_rpmsg_bus virtio0: msg received with no recipient
    [    7.267823] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
    [    7.277504] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0x15
    [    7.281007] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.285289] virtio_rpmsg_bus virtio2: msg received with no recipient
    [    7.299693] rproc-virtio rproc-virtio.9.auto: registered virtio2 (type 7)
    [    7.299712] remoteproc remoteproc0: remote processor 7e000000.dsp is now up
    [    7.310957] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.311687] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    7.514527] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    7.514550] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [  OK  ] Reached target Hardware activated USB gadget.
    [  OK  ] Started Network Configuration.
    [  OK  ] Started PulseAudio Sound System.
    [  OK  ] Started User Login Management.
    [  OK  ] Created slice Slice /system/tee-supplicant.
    [  OK  ] Reached target Network.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting Save/Restore Sound Card State...
             Starting Enable and configure wl18xx bluetooth stack...
             Starting containerd container runtime...
             Starting LLDP daemon...
    [  OK  ] Started Netperf Benchmark Server.
             Starting Simple Network Management Protocol (SNMP) Daemon....
             Starting Permit User Sessions...
             Starting Virtual Console Setup...
    [  OK  ] Started TEE Supplicant on teepriv0.
    [  OK  ] Finished Save/Restore Sound Card State.
    [  OK  ] Reached target Sound Card.
    [  OK  ] Finished Enable and configure wl18xx bluetooth stack.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started emptty display manager.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS2.
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Started LLDP daemon.
    [  OK  ] Created slice Slice /system/systemd-fsck.
             Expecting device /dev/mmcblk0p1...
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Found device /dev/mmcblk0p1.
             Starting File System Check on /dev/mmcblk0p1...
             Expecting device /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk0p1.
             Mounting /run/media/mmcblk0p1...
    [    8.668619] EXT4-fs (mmcblk0p1): mounted filesystem 500160a5-46d3-45ed-9dc4-335513a8d282 r/w with ordered data mode. Quota mode: none.
    [  OK  ] Mounted /run/media/mmcblk0p1.
    [  OK  ] Found device /dev/mmcblk1p1.
             Starting File System Check on /dev/mmcblk1p1...
    [  OK  ] Finished File System Check on /dev/mmcblk1p1.
             Mounting /run/media/BOOT-mmcblk1p1...
    [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [  OK  ] Mounted /run/media/BOOT-mmcblk1p1.
    [  OK  ] Started containerd container runtime.
    NOTICE: This file system contains the following GPL-3.0 packages:
            adwaita-icon-theme-symbolic
            autoconf
            bash-dev
            bash
            bc
            binutils
            cifs-utils
            coreutils-stdbuf
            coreutils
            cpio
            cpp-symlinks
            cpp
            dosfstools
            elfutils-dev
            elfutils
            findutils
            g++-symlinks
            g++
            gawk
            gcc-symlinks
            gcc
            gdb
            gdbserver
            gettext
            glmark2
            gnu-config
            grub-common
            grub-editenv
            grub-efi
            gzip
            hidapi
            kbd-dev
            kbd-keymaps-pine
            less
            libasm1
            libatomic-dev
            libatomic1
            libbfd
            libdebuginfod1
            libdw1
            libelf1
            libgcc-s-dev
            libgcc1
            libgdbm-compat4
            libgdbm-dev
            libgdbm6
            libgettextlib
            libgettextsrc
            libgmp-dev
            libgmp10
            libgmpxx4
            libgnutls-dev
            libgnutls-openssl27
            libgomp1
            libidn2-0
            libidn2-dev
            libmpc3
            libmpfr6
            libopcodes
            libqt6core5compat-plugins
            libqt6core5compat-qmlplugins
            libqt6core5compat6
            libqt6shadertools-dev
            libqt6shadertools-plugins
            libqt6shadertools-qmlplugins
            libqt6shadertools6
            libreadline-dev
            libreadline8
            libstdc++-dev
            libstdc++6
            libtasn1-dev
            libunistring-dev
            libunistring5
            m4
            make
            nettle-dev
            nettle
            parted
            piglit
            qtbase-dev
            qtbase-examples
            qtbase-plugins
            qtbase-qmlplugins
            qtbase-staticdev
            qtbase
            qtdeclarative-dev
            qtdeclarative-plugins
            qtdeclarative-qmlplugins
            qtdeclarative-staticdev
            qtdeclarative-tools
            qtdeclarative
            qtlanguageserver-dev
            qtlanguageserver-plugins
            qtlanguageserver-qmlplugins
            qtlanguageserver-staticdev
            qtlanguageserver
            qtmultimedia-plugins
            qtmultimedia-qmlplugins
            qtmultimedia
            qtquick3d-plugins
            qtquick3d-qmlplugins
            qtquick3d
            qtquicktimeline-plugins
            qtquicktimeline-qmlplugins
            qtquicktimeline
            qtsvg-dev
            qtsvg-plugins
            qtsvg-qmlplugins
            qtsvg
            qtwayland-dev
            qtwayland-plugins
            qtwayland-qmlplugins
            qtwayland
            tar
            which
    If you do not wish to distribute GPL-3.0 components please remove
    the above packages prior to distribution.  This can be done using
    the opkg remove command.  i.e.:
        opkg remove <package>
    Where <package> is the name printed in the list above
    NOTE: If the package is a dependency of another package you
          will be notified of the dependent packages.  You should
          use the --force-removal-of-dependent-packages option to
          also remove the dependent packages as well
    [  OK  ] Finished Print notice about GPLv3 packages.
    [  OK  ] Reached target Multi-User System.
    [  OK  ] Reached target Graphical Interface.
             Starting Record Runlevel Change in UTMP...
    [  OK  ] Finished Record Runlevel Change in UTMP.
    [   12.067815] audit: type=1006 audit(1748593662.032:14): pid=1043 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [   12.081673] audit: type=1300 audit(1748593662.032:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=fffffd2de2f8 a2=4 a3=1 items=0 ppid=1 pid=1043 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   12.109609] audit: type=1327 audit(1748593662.032:14): proctitle="(systemd)"
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project am62axx-evm ttyS2
    Arago 2025.01 am62axx-evm ttyS2
    am62axx-evm login: root
    [   14.876841] audit: type=1006 audit(1748593664.844:15): pid=1067 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=2 res=1
    [   14.890451] audit: type=1300 audit(1748593664.844:15): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=fffffb801b08 a2=1 a3=1 items=0 ppid=1 pid=1067 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   14.918206] audit: type=1327 audit(1748593664.844:15): proctitle="(systemd)"
    [   14.957113] audit: type=1334 audit(1748593664.924:16): prog-id=18 op=LOAD
    [   14.963951] audit: type=1300 audit(1748593664.924:16): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffc1c8e2e8 a2=90 a3=0 items=0 ppid=1 pid=1067 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   14.990815] audit: type=1327 audit(1748593664.924:16): proctitle="(systemd)"
    [   14.997990] audit: type=1334 audit(1748593664.924:17): prog-id=18 op=UNLOAD
    [   15.970574] vdec 30210000.video-codec: Runtime PM usage count underflow!
    [   16.004073] vdec 30210000.video-codec: error -ENXIO: IRQ index 0 not found
    [   16.011063] vdec 30210000.video-codec: failed to get irq resource, falling back to polling
    [   16.019580] vdec 30210000.video-codec: OPP table not found in device tree
    [   16.029454] vdec 30210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [   16.037574] vdec 30210000.video-codec: Product Code:      0x521c
    [   16.043654] vdec 30210000.video-codec: Firmware Revision: 363254
    root@am62axx-evm:/opt/edgeai-gst-apps#
    Best Regards
    Suren
