Other Parts Discussed in Thread: 4460
What is the maximum current output on the GPIO pins on the OMAP 4460? Is there an electric spec datasheet with this information? I cannot find one.
I want to switch on/off a solid-state relay (http://www.irf.com/product-info/datasheets/data/pvn012.pdf) using a GPIO pin on the Pandaboard ES. The required control current is 4-5mA with a voltage drop of 1.1V across the input. Is this output possible from a GPIO on the OMAP4460 (Pandabord ES) ?
Thank you,
Jake
