Other Parts Discussed in Thread: OMAP3530
my platform is omap3530,
when I use C6Runlib tool and compile my C code, main.c and cal.c,
(here is my code7026.source_code.zip)
because I want main.c execute on ARM and call function code cal.c on DSP,
thus I key following command on my x86 host
/home/lan/C6Run/C6Run_0_98_03_03/bin/c6runlib-cc -c -O3 -o cal.o cal.c
/home/lan/C6Run/C6Run_0_98_03_03/bin/c6runlib-ar rcs cal.lib cal.o
arm-none-linux-gnueabi-gcc -c -o main.o main.c
arm-none-linux-gnueabi-gcc -lpthread -o cal_arr.out main.o cal.lib
cp cal_arr.out /home/lan/NFS
then I get cal_arr.out successfully,
put cal_arr.out on my target platform omap3530,
but it has error,
" ./cal.gpp_stub.c: C6RUN_SHAREDMEM_lookupBuffer() failed for pointer 0x000642E0 ",
what should I try to do to solve this problem,
thanks,
Jason Lan.
