[FAQ] TDA4VH: Enable Falcon Boot Mode in J784S4
Part Number: TDA4VH
How to enable falcon boot on J784S4 11.02 Linux SDK ?
Boot Flow:
R5 SPL -> ATF -> OPTEE -> Kernel
Gokul
  • Hi Gokul,
    Applying the below patches will enable the above mention boot flow on J784S4 EVM on 11.02 SDK: This supports booting tifalcon.bin and fitImage from SD card.
    U-BOOT Patch:
    From 9152c4df3eafa4f4b7cb8020f98b629689206254 Mon Sep 17 00:00:00 2001
    Date: Fri, 13 Mar 2026 13:58:06 +0530
    Subject: [PATCH] Enable Falcon Boot Mode.
    tifalcon.bin and fitImage is fetched from SD card.
     Makefile                                   |  2 +-
     arch/arm/dts/k3-j784s4-binman.dtsi         | 54 ++++++++++++++++++++++
     arch/arm/dts/k3-j784s4-evm-u-boot.dtsi     | 14 ++++++
     arch/arm/mach-k3/include/mach/j784s4_spl.h |  1 +
     arch/arm/mach-k3/r5/sysfw-loader.c         |  9 +++-
     board/ti/j784s4/evm.c                      |  2 +-
     configs/am62x_r5_falcon.config             | 38 +++++++++++++++
     configs/j784s4_evm_r5_defconfig            |  5 ++
     8 files changed, 121 insertions(+), 4 deletions(-)
     create mode 100644 configs/am62x_r5_falcon.config
    diff --git a/Makefile b/Makefile
    index 77ae3ced..c585e067 100644
    --- a/Makefile
    +++ b/Makefile
    @@ -2224,7 +2224,7 @@ CLEAN_FILES += include/autoconf.mk* include/bmp_logo.h include/bmp_logo_data.h \
     	       include/config.h include/generated/env.* drivers/video/u_boot_logo.S \
     	       tools/version.h u-boot* MLO* SPL System.map fit-dtb.blob* \
     	       u-boot-ivt.img.log u-boot-dtb.imx.log SPL.log u-boot.imx.log \
    -	       lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* \
    +	       lpc32xx-* bl31.c bl31.elf bl31_*.bin image.map tispl.bin* tifalcon.bin* \
     	       idbloader.img flash.bin flash.log defconfig keep-syms-lto.c \
     	       mkimage-out.spl.mkimage mkimage.spl.mkimage imx-boot.map \
     	       itb.fit.fit itb.fit.itb itb.map spl.map mkimage-out.rom.mkimage \
    diff --git a/arch/arm/dts/k3-j784s4-binman.dtsi b/arch/arm/dts/k3-j784s4-binman.dtsi
    index fe3483bd..aef4c28e 100644
    --- a/arch/arm/dts/k3-j784s4-binman.dtsi
    +++ b/arch/arm/dts/k3-j784s4-binman.dtsi
    @@ -314,6 +314,7 @@
     &binman {
     	u_boot_unsigned: template-15 {
     		insert-template = <&u_boot_unsigned_template>;
    @@ -353,4 +354,57 @@
    +&binman {
    +	ti_falcon: template-16 {
    +		insert-template = <&ti_falcon_template>;
    +		fit {
    +			images {
    +#ifdef CONFIG_K3_HSM_FW
    +				hsm {
    +					hsm: blob-ext {
    +						filename = "ti-hsm/hsm-demo-firmware-j784s4-hs.bin";
    +#endif
    +				dm {
    +					ti-secure {
    +						content = <&dm_falcon>;
    +						keyfile = "custMpk.pem";
    +					dm_falcon: ti-dm {
    +						optional;
    +			configurations {
    +				default = "conf-0";
    +				conf-0 {
    +					description = BOARD_DESCRIPTION;
    +					firmware = "atf";
    +					loadables = "hsm", "tee", "dm";
    +#else
    +					loadables = "tee", "dm";
    +#endif
    +				conf-1 {
    +					description = "k3-lpm";
    +					loadables = "hsm", "dm";
    +#else
    +					loadables = "dm";
    +#endif
     #endif
    diff --git a/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi b/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi
    index e69b911f..6a102cd7 100644
    --- a/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi
    +++ b/arch/arm/dts/k3-j784s4-evm-u-boot.dtsi
    @@ -87,6 +87,20 @@
     	u-boot-unsigned {
     		insert-template = <&u_boot_unsigned>;
    +	tifalcon {
    +		insert-template = <&ti_falcon>;
    +		fit {
    +			images {
    +				dm {
    +					ti-dm {
    +						filename = "ti-dm/j784s4/ipc_echo_testb_mcu1_0_release_strip.xer5f";
     #endif
    diff --git a/arch/arm/mach-k3/include/mach/j784s4_spl.h b/arch/arm/mach-k3/include/mach/j784s4_spl.h
    index 197adadf..3d2e0797 100644
    --- a/arch/arm/mach-k3/include/mach/j784s4_spl.h
    +++ b/arch/arm/mach-k3/include/mach/j784s4_spl.h
    @@ -18,6 +18,7 @@
     #define BOOT_DEVICE_I2C			0x06
     #define BOOT_DEVICE_UART		0x07
     #define BOOT_DEVICE_NOR			BOOT_DEVICE_HYPERFLASH
    +#define BOOT_DEVICE_NOBOOT		0x0F
     /* With BootMode B = 1 */
     #define BOOT_DEVICE_MMC2		0x10
    diff --git a/arch/arm/mach-k3/r5/sysfw-loader.c b/arch/arm/mach-k3/r5/sysfw-loader.c
    index 188731e6..7c007039 100644
    --- a/arch/arm/mach-k3/r5/sysfw-loader.c
    +++ b/arch/arm/mach-k3/r5/sysfw-loader.c
    @@ -88,8 +88,13 @@ static void *sysfw_load_address;
     struct legacy_img_hdr *spl_get_load_buffer(ssize_t offset, size_t size)
    -	if (sysfw_loaded)
    -		return (struct legacy_img_hdr *)(CONFIG_TEXT_BASE + offset);
    +	if (sysfw_loaded){
    +		if (IS_ENABLED(CONFIG_SPL_OS_BOOT))
    +			return (struct legacy_img_hdr *)CONFIG_SYS_LOAD_ADDR;
    +		else
    +			return (struct legacy_img_hdr *)(CONFIG_TEXT_BASE +
    +							 offset);
     	else if (sysfw_load_address)
     		return sysfw_load_address;
     	else
    diff --git a/board/ti/j784s4/evm.c b/board/ti/j784s4/evm.c
    index 1ef1901c..649ad185 100644
    --- a/board/ti/j784s4/evm.c
    +++ b/board/ti/j784s4/evm.c
    @@ -111,7 +111,7 @@ void spl_perform_fixups(struct spl_image_info *spl_image)
     	} else {
     		fixup_memory_node(spl_image);
    -	detect_enable_spinand(spl_image->fdt_addr);
    +	//detect_enable_spinand(spl_image->fdt_addr);
     #endif
    diff --git a/configs/am62x_r5_falcon.config b/configs/am62x_r5_falcon.config
    new file mode 100644
    index 00000000..d31d75ea
    --- /dev/null
    +++ b/configs/am62x_r5_falcon.config
    @@ -0,0 +1,38 @@
    +# Enable falcon mode
    +CONFIG_SPL_OS_BOOT=y
    +# We use envs for setting bootargs and optionally for `falcon_(image|args)_file`
    +CONFIG_SPL_ENV_SUPPORT=y
    +# Perform FDT fixups from SPL
    +CONFIG_OF_SYSTEM_SETUP=y
    +# Enabling this causes issues with EMMC FS boot,
    +# When enabled the SPL tries to detect FS on boot[01] hw partition which fails
    +# since we need the raw tiboot3.bin there for the board to boot instead
    +CONFIG_SUPPORT_EMMC_BOOT=n
    +# Used as the 2MiB aligned load address for kernel
    +CONFIG_SYS_LOAD_ADDR=0x82000000
    +CONFIG_SPL_PAYLOAD_ARGS_ADDR=0x88000000
    +CONFIG_SPL_LOAD_FIT_ADDRESS=0x82000000
    +CONFIG_SPL_STACK_R_ADDR=0x88000000
    +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2700000
    +# We use the rootfs (i.e partition 2) for booting which is ext4 not FAT
    +CONFIG_SYS_MMCSD_FS_BOOT_PARTITION=2
    +CONFIG_SPL_FS_EXT4=y
    +CONFIG_SPL_FS_FAT=n
    +# Loading tispl_falcon instead of tispl which has fdt and A53 spl saves time
    +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="boot/tifalcon.bin"
    +CONFIG_SPL_FS_LOAD_KERNEL_NAME="boot/fitImage"
    +CONFIG_DMA=y
    +# During SPI boot, kernel and args are loaded from the eMMC or SD and not SPI,
    +# therefore we don't actually make use of these config values.
    +CONFIG_SYS_SPI_KERNEL_OFFS=0
    +CONFIG_SYS_SPI_ARGS_OFFS=0
    +CONFIG_SYS_SPI_ARGS_SIZE=0
    diff --git a/configs/j784s4_evm_r5_defconfig b/configs/j784s4_evm_r5_defconfig
    index 4e1dda06..aec410fd 100644
    --- a/configs/j784s4_evm_r5_defconfig
    +++ b/configs/j784s4_evm_r5_defconfig
    @@ -187,3 +187,8 @@ CONFIG_K3_AVS0=y
     CONFIG_DM_REGULATOR=y
     CONFIG_SPL_DM_REGULATOR=y
     CONFIG_SPL_DM_REGULATOR_TPS6287X=y
    +#include <configs/am62x_r5_falcon.config>
    +CONFIG_SPL_FS_LOAD_ARGS_NAME="boot/dtb/ti/k3-j784s4-evm.dtb"
    \ No newline at end of file
    2.34.1
    ATF Patch:
    From aaf3126c24fbb63a796759fcc069f86e53aed92a Mon Sep 17 00:00:00 2001
    Date: Fri, 13 Mar 2026 14:41:37 +0530
    Subject: [PATCH] Change jump offsets for falcon boot mode.
    Changes the offsets to kernel image and Kernel dtb address for
    falcon mode.
     plat/ti/k3/platform.mk | 4 ++--
     1 file changed, 2 insertions(+), 2 deletions(-)
    diff --git a/plat/ti/k3/platform.mk b/plat/ti/k3/platform.mk
    index 347a08894..a5f45982c 100644
    --- a/plat/ti/k3/platform.mk
    +++ b/plat/ti/k3/platform.mk
    @@ -13,10 +13,10 @@ include ${PLAT_PATH}/board/${TARGET_BOARD}/board.mk
     BL32_BASE ?= 0x9e800000
     $(eval $(call add_define,BL32_BASE))
    -PRELOADED_BL33_BASE ?= 0x80080000
    +PRELOADED_BL33_BASE ?= 0x82000000
     $(eval $(call add_define,PRELOADED_BL33_BASE))
    -K3_HW_CONFIG_BASE ?= 0x82000000
    +K3_HW_CONFIG_BASE ?= 0x88000000
     $(eval $(call add_define,K3_HW_CONFIG_BASE))
     PLAT_INCLUDES += -Iplat/ti/k3/board/${TARGET_BOARD}/include	\
    2.34.1
    Once these patches are applied:
    • Rebuild ATF using the below commands:
      • make -C $(pwd) CROSS_COMPILE="$CROSS_COMPILE_64" BUILD_BASE=$(pwd)/build clean
        rm -rf $(pwd)/build
        make CROSS_COMPILE="$CROSS_COMPILE_64" ARCH=aarch64 PLAT=k3 TARGET_BOARD=j784s4 SPD=opteed K3_USART=0x8 K3_HW_CONFIG_BASE=0x88000000 PRELOADED_BL33_BASE=0x82000000
    • Copy the bl31.bin file generated to the <SDK>/board-support/prebuilt-images directory.
    • Rebuild U-boot.
    • Copy the tiboot3.bin binary generated in the <U-BOOT FOLDER OF SDK>/build/r5 to the boot partition(FAT32) of SD card.
    • Copy the tifalcon.bin binary generated in the <U-BOOT FOLDER OF SDK>/build/a72 to the <rootfs partition of SD card>/boot directory.
    • Generate the fitImage using the below link:
    • Copy the fitImage generated to the <rootfs partition of SD card>/boot directory.
    Output logs:
    Normal Boot Flow:
    TIme taken : 8.272 sec(Upto Starting Kernel Print...)
    OPTIONS: I18n
    Port /dev/ttyUSB4, 15:58:00
    Press CTRL-A Z for help on special keys
    U-Boot SPL 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    [2026-03-10 16:07:05.972] SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 16:07:06.132] Initialized 4 DRAM controllers
    [2026-03-10 16:07:06.244] SPL initial stack usage: 13584 bytes
    [2026-03-10 16:07:06.244] Trying to boot from MMC2
    [2026-03-10 16:07:06.340] Skipping authentication on GP device
    [2026-03-10 16:07:06.356] Skipping authentication on GP device
    [2026-03-10 16:07:06.372] Skipping authentication on GP device
    [2026-03-10 16:07:06.389] Loading Environment from nowhere... OK
    [2026-03-10 16:07:06.405] Starting ATF on ARM64 core...
    [2026-03-10 16:07:06.421]
    [2026-03-10 16:07:06.421] NOTICE:  BL31: v2.13.0(release):v2.13.0-259-ge0c4d3903b-dirty
    [2026-03-10 16:07:06.421] NOTICE:  BL31: Built : 07:01:36, Jul  1 2025
    [2026-03-10 16:07:06.485] I/TC:
    [2026-03-10 16:07:06.485] I/TC: OP-TEE version: 4.7.0-47-ga9690ae39-dev (gcc version 13.4.0 (GCC)) #1 Thu Aug  7 15:25:10 UTC 2025 aarch64
    [2026-03-10 16:07:06.485] I/TC: WARNING: This OP-TEE configuration might be insecure!
    [2026-03-10 16:07:06.501] I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    [2026-03-10 16:07:06.501] I/TC: Primary CPU initializing
    [2026-03-10 16:07:06.501] I/TC: GIC redistributor base address not provided
    [2026-03-10 16:07:06.516] I/TC: Assuming default GIC group status and modifier
    [2026-03-10 16:07:06.517] I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 16:07:06.517] I/TC: Activated SA2UL device
    [2026-03-10 16:07:06.532] I/TC: Fixing SA2UL firewall owner for GP device
    [2026-03-10 16:07:06.532] I/TC: Enabled firewalls for SA2UL TRNG device
    [2026-03-10 16:07:06.533] I/TC: EIP76D TRNG initialized
    [2026-03-10 16:07:06.533] I/TC: SA2UL Drivers initialized
    [2026-03-10 16:07:06.549] I/TC: HUK Initialized
    [2026-03-10 16:07:06.549] I/TC: Primary CPU switching to normal world boot
    [2026-03-10 16:07:06.821]
    [2026-03-10 16:07:06.821] U-Boot SPL 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    [2026-03-10 16:07:06.821] SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 16:07:06.836] DM ABI: 3.0 (firmware ver 0x000b 'PSDK.11.02.00.07--v11.02.07' patch_ver: 7)
    [2026-03-10 16:07:06.884] Trying to boot from MMC2
    [2026-03-10 16:07:06.964] Skipping authentication on GP device
    [2026-03-10 16:07:06.980] Skipping authentication on GP device
    [2026-03-10 16:07:08.596]
    [2026-03-10 16:07:08.596] U-Boot 2025.01-00766-g7493977a537f (Dec 03 2025 - 15:20:36 +0000)
    [2026-03-10 16:07:08.596] SoC:   J784S4 SR1.0 GP
    [2026-03-10 16:07:08.596] Model: Texas Instruments J784S4 EVM
    [2026-03-10 16:07:08.597] DRAM:  2 GiB (total 32 GiB)
    [2026-03-10 16:07:09.748] Core:  147 devices, 36 uclasses, devicetree: separate
    [2026-03-10 16:07:09.748] Flash: 0 Bytes
    [2026-03-10 16:07:09.748] MMC:   mmc@4f80000: 0, mmc@4fb0000: 1
    [2026-03-10 16:07:09.748] Loading Environment from nowhere... OK
    [2026-03-10 16:07:09.764] In:    serial@2880000
    [2026-03-10 16:07:09.764] Out:   serial@2880000
    [2026-03-10 16:07:09.764] Err:   serial@2880000
    [2026-03-10 16:07:09.764] Net:   am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
    [2026-03-10 16:07:09.796] eth0: ethernet@46000000port@1am65_cpsw_nuss ethernet@c200000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1
    [2026-03-10 16:07:09.812] mdio_register: non unique device name 'mdio@f00'
    [2026-03-10 16:07:09.812] am65_cpsw_nuss_port ethernet@c200000port@1: phy_connect() failed
    [2026-03-10 16:07:09.813]
    [2026-03-10 16:07:09.828] Hit any key to stop autoboot:  0
    [2026-03-10 16:07:12.068] switch to partitions #0, OK
    [2026-03-10 16:07:12.068] mmc1 is current device
    [2026-03-10 16:07:12.292] SD/MMC found on device 1
    [2026-03-10 16:07:12.308] 969 bytes read in 1 ms (946.3 KiB/s)
    [2026-03-10 16:07:12.308] Loaded env from uEnv.txt
    [2026-03-10 16:07:12.308] Importing environment from mmc1 ...
    [2026-03-10 16:07:12.308] Running uenvcmd ...
    [2026-03-10 16:07:12.324] gpio: pin gpio@22_17 (gpio 188) value is 1
    [2026-03-10 16:07:12.324] gpio: pin gpio@22_16 (gpio 187) value is 0
    [2026-03-10 16:07:12.324] k3_r5f_rproc r5f@41000000: Core 1 is already in use. No rproc commands work
    [2026-03-10 16:07:12.372] Failed to load '/lib/firmware/j784s4-mcu-r5f0_1-fw'
    [2026-03-10 16:07:12.452] 1793608 bytes read in 67 ms (25.5 MiB/s)
    [2026-03-10 16:07:12.452] Load Remote Processor 2 with data@addr=0x82000000 1793608 bytes: Success!
    [2026-03-10 16:07:12.516] 371924 bytes read in 53 ms (6.7 MiB/s)
    [2026-03-10 16:07:12.532] Load Remote Processor 3 with data@addr=0x82000000 371924 bytes: Success!
    [2026-03-10 16:07:12.580] 163008 bytes read in 51 ms (3 MiB/s)
    [2026-03-10 16:07:12.596] Load Remote Processor 4 with data@addr=0x82000000 163008 bytes: Success!
    [2026-03-10 16:07:12.660] 163008 bytes read in 51 ms (3 MiB/s)
    [2026-03-10 16:07:12.660] Load Remote Processor 5 with data@addr=0x82000000 163008 bytes: Success!
    [2026-03-10 16:07:12.724] 625916 bytes read in 56 ms (10.7 MiB/s)
    [2026-03-10 16:07:12.724] Load Remote Processor 6 with data@addr=0x82000000 625916 bytes: Success!
    [2026-03-10 16:07:12.788] 163008 bytes read in 52 ms (3 MiB/s)
    [2026-03-10 16:07:12.804] Load Remote Processor 7 with data@addr=0x82000000 163008 bytes: Success!
    [2026-03-10 16:07:13.012] 14422344 bytes read in 198 ms (69.5 MiB/s)
    [2026-03-10 16:07:13.012] Load Remote Processor 8 with data@addr=0x82000000 14422344 bytes: Success!
    [2026-03-10 16:07:13.236] 14815616 bytes read in 202 ms (69.9 MiB/s)
    [2026-03-10 16:07:13.236] Load Remote Processor 9 with data@addr=0x82000000 14815616 bytes: Success!
    [2026-03-10 16:07:13.444] 14352768 bytes read in 198 ms (69.1 MiB/s)
    [2026-03-10 16:07:13.460] Load Remote Processor 10 with data@addr=0x82000000 14352768 bytes: Success!
    [2026-03-10 16:07:13.668] 14352768 bytes read in 198 ms (69.1 MiB/s)
    [2026-03-10 16:07:13.668] Load Remote Processor 11 with data@addr=0x82000000 14352768 bytes: Success!
    [2026-03-10 16:07:13.924] 22391296 bytes read in 233 ms (91.6 MiB/s)
    [2026-03-10 16:07:13.924] 130752 bytes read in 5 ms (24.9 MiB/s)
    [2026-03-10 16:07:13.940] Working FDT set to 88000000
    [2026-03-10 16:07:13.940] 2176 bytes read in 5 ms (424.8 KiB/s)
    [2026-03-10 16:07:13.972] 14561 bytes read in 4 ms (3.5 MiB/s)
    [2026-03-10 16:07:14.132] ## Flattened Device Tree blob at 88000000
    [2026-03-10 16:07:14.132]    Booting using the fdt blob at 0x88000000
    [2026-03-10 16:07:14.132] Working FDT set to 88000000
    [2026-03-10 16:07:14.228]    Loading Device Tree to 000000008fedd000, end 000000008fffffff ... OK
    [2026-03-10 16:07:14.228] Working FDT set to 8fedd000
    [2026-03-10 16:07:14.244]
    [2026-03-10 16:07:14.244] Starting kernel ...
    [2026-03-10 16:07:14.292] [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [2026-03-10 16:07:14.292] [    0.000000] Linux version 6.12.57-ti-g31b07ab8dfbc-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Thu Dec  5
    [2026-03-10 16:07:14.308] [    0.000000] KASLR disabled due to lack of seed
    [2026-03-10 16:07:14.308] [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [2026-03-10 16:07:14.324] [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002880000 (options '')
    [2026-03-10 16:07:14.324] [    0.000000] printk: legacy bootconsole [ns16550a0] enabled
    [2026-03-10 16:07:14.324] [    0.000000] efi: UEFI not found.
    [2026-03-10 16:07:14.500] [    0.000000] Reserved memory: created CMA memory pool at 0x0000000a80000000, size 1792 MiB
    [2026-03-10 16:07:14.500] [    0.000000] OF: reserved mem: initialized node linux-cma-buffers@a80000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.516] [    0.000000] OF: reserved mem: 0x0000000a80000000..0x0000000aefffffff (1835008 KiB) map reusable linux-cma-buffers@a80000000
    [2026-03-10 16:07:14.532] [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [2026-03-10 16:07:14.532] [    0.000000] OF: reserved mem: 0x0000000a00000000..0x0000000a3bffffff (983040 KiB) map non-reusable vision_apps_shared-memories
    [2026-03-10 16:07:14.548] [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 4096 MiB
    [2026-03-10 16:07:14.564] [    0.000000] OF: reserved mem: initialized node c7x-ddr-heaps-hi@880000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.564] [    0.000000] OF: reserved mem: 0x0000000880000000..0x000000097fffffff (4194304 KiB) nomap non-reusable c7x-ddr-heaps-hi@880000000
    [2026-03-10 16:07:14.580] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000be800000, size 24 MiB
    [2026-03-10 16:07:14.580] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@be800000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.596] [    0.000000] OF: reserved mem: 0x00000000be800000..0x00000000bfffffff (24576 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-buffers@be800000
    [2026-03-10 16:07:14.612] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000be000000, size 8 MiB
    [2026-03-10 16:07:14.628] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@be000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.628] [    0.000000] OF: reserved mem: 0x00000000be000000..0x00000000be7fffff (8192 KiB) nomap non-reusable vision-apps-r5f-virtual-eth-queues@be000000
    [2026-03-10 16:07:14.644] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba000000, size 64 MiB
    [2026-03-10 16:07:14.660] [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@ba000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.660] [    0.000000] OF: reserved mem: 0x00000000ba000000..0x00000000bdffffff (65536 KiB) nomap non-reusable vision-apps-core-heap-memory-lo@ba000000
    [2026-03-10 16:07:14.676] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8100000, size 31 MiB
    [2026-03-10 16:07:14.692] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@b8100000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.692] [    0.000000] OF: reserved mem: 0x00000000b8100000..0x00000000b9ffffff (31744 KiB) nomap non-reusable vision-apps-c71_3-memory@b8100000
    [2026-03-10 16:07:14.708] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b8000000, size 1 MiB
    [2026-03-10 16:07:14.708] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@b8000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.724] [    0.000000] OF: reserved mem: 0x00000000b8000000..0x00000000b80fffff (1024 KiB) nomap non-reusable vision-apps-c71_3-dma-memory@b8000000
    [2026-03-10 16:07:14.740] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6100000, size 31 MiB
    [2026-03-10 16:07:14.740] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@b6100000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.756] [    0.000000] OF: reserved mem: 0x00000000b6100000..0x00000000b7ffffff (31744 KiB) nomap non-reusable vision-apps-c71_2-memory@b6100000
    [2026-03-10 16:07:14.772] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b6000000, size 1 MiB
    [2026-03-10 16:07:14.772] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@b6000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.788] [    0.000000] OF: reserved mem: 0x00000000b6000000..0x00000000b60fffff (1024 KiB) nomap non-reusable vision-apps-c71_2-dma-memory@b6000000
    [2026-03-10 16:07:14.804] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 31 MiB
    [2026-03-10 16:07:14.804] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b4100000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.820] [    0.000000] OF: reserved mem: 0x00000000b4100000..0x00000000b5ffffff (31744 KiB) nomap non-reusable vision-apps-c71_1-memory@b4100000
    [2026-03-10 16:07:14.836] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
    [2026-03-10 16:07:14.836] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b4000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.852] [    0.000000] OF: reserved mem: 0x00000000b4000000..0x00000000b40fffff (1024 KiB) nomap non-reusable vision-apps-c71_1-dma-memory@b4000000
    [2026-03-10 16:07:14.868] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2100000, size 31 MiB
    [2026-03-10 16:07:14.868] [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b2100000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.884] [    0.000000] OF: reserved mem: 0x00000000b2100000..0x00000000b3ffffff (31744 KiB) nomap non-reusable vision-apps-c71_0-memory@b2100000
    [2026-03-10 16:07:14.900] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 1 MiB
    [2026-03-10 16:07:14.900] [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b2000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.916] [    0.000000] OF: reserved mem: 0x00000000b2000000..0x00000000b20fffff (1024 KiB) nomap non-reusable vision-apps-c71-dma-memory@b2000000
    [2026-03-10 16:07:14.932] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 48 MiB
    [2026-03-10 16:07:14.932] [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.948] [    0.000000] OF: reserved mem: 0x00000000af000000..0x00000000b1ffffff (49152 KiB) nomap non-reusable vision-apps-dma-memory@af000000
    [2026-03-10 16:07:14.948] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
    [2026-03-10 16:07:14.964] [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
    [2026-03-10 16:07:14.980] [    0.000000] OF: reserved mem: 0x00000000ac000000..0x00000000aeffffff (49152 KiB) nomap non-reusable vision-apps-rtos-ipc-memory-region@ac000000
    [2026-03-10 16:07:14.980] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [2026-03-10 16:07:14.996] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.012] [    0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a8100000
    [2026-03-10 16:07:15.012] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [2026-03-10 16:07:15.028] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.044] [    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a8000000
    [2026-03-10 16:07:15.044] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [2026-03-10 16:07:15.060] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.060] [    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a7100000
    [2026-03-10 16:07:15.076] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [2026-03-10 16:07:15.092] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.092] [    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a7000000
    [2026-03-10 16:07:15.108] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [2026-03-10 16:07:15.124] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.124] [    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a6100000
    [2026-03-10 16:07:15.140] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [2026-03-10 16:07:15.156] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.156] [    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a6000000
    [2026-03-10 16:07:15.172] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [2026-03-10 16:07:15.172] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a5100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.188] [    0.000000] OF: reserved mem: 0x00000000a5100000..0x00000000a5ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a5100000
    [2026-03-10 16:07:15.204] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [2026-03-10 16:07:15.204] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.220] [    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a50fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a5000000
    [2026-03-10 16:07:15.236] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [2026-03-10 16:07:15.236] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.252] [    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a4100000
    [2026-03-10 16:07:15.268] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [2026-03-10 16:07:15.268] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.284] [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a4000000
    [2026-03-10 16:07:15.300] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [2026-03-10 16:07:15.300] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.316] [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a3ffffff (31744 KiB) nomap non-reusable vision-apps-r5f-memory@a2100000
    [2026-03-10 16:07:15.332] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [2026-03-10 16:07:15.332] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.348] [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a2000000
    [2026-03-10 16:07:15.348] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [2026-03-10 16:07:15.364] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.380] [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a1100000
    [2026-03-10 16:07:15.380] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [2026-03-10 16:07:15.396] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.412] [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a1000000
    [2026-03-10 16:07:15.412] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [2026-03-10 16:07:15.428] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.428] [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable vision-apps-r5f-memory@a0100000
    [2026-03-10 16:07:15.444] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [2026-03-10 16:07:15.460] [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [2026-03-10 16:07:15.460] [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable vision-apps-r5f-dma-memory@a0000000
    [2026-03-10 16:07:15.476] [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [2026-03-10 16:07:15.492] [    0.000000] Zone ranges:
    [2026-03-10 16:07:15.492] [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [2026-03-10 16:07:15.508] [    0.000000]   DMA32    empty
    [2026-03-10 16:07:15.508] [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffffff]
    [2026-03-10 16:07:15.508] [    0.000000] Movable zone start for each node
    [2026-03-10 16:07:15.508] [    0.000000] Early memory node ranges
    [2026-03-10 16:07:15.524] [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [2026-03-10 16:07:15.524] [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
    [2026-03-10 16:07:15.524] [    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000abffffff]
    [2026-03-10 16:07:15.540] [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000bfffffff]
    [2026-03-10 16:07:15.540] [    0.000000]   node   0: [mem 0x00000000c0000000-0x00000000ffffffff]
    [2026-03-10 16:07:15.556] [    0.000000]   node   0: [mem 0x0000000880000000-0x000000097fffffff]
    [2026-03-10 16:07:15.556] [    0.000000]   node   0: [mem 0x0000000980000000-0x0000000fffffffff]
    [2026-03-10 16:07:15.556] [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffffff]
    [2026-03-10 16:07:15.668] [    0.000000] psci: probing for conduit method from DT.
    [2026-03-10 16:07:15.668] [    0.000000] psci: PSCIv1.1 detected in firmware.
    [2026-03-10 16:07:15.684] [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [2026-03-10 16:07:15.684] [    0.000000] psci: Trusted OS migration not required
    [2026-03-10 16:07:15.684] [    0.000000] psci: SMC Calling Convention v1.5
    [2026-03-10 16:07:15.684] [    0.000000] percpu: Embedded 22 pages/cpu s51736 r8192 d30184 u90112
    [2026-03-10 16:07:15.700] [    0.000000] Detected PIPT I-cache on CPU0
    [2026-03-10 16:07:15.700] [    0.000000] CPU features: detected: GIC system register CPU interface
    [2026-03-10 16:07:15.716] [    0.000000] CPU features: detected: Spectre-v3a
    [2026-03-10 16:07:15.716] [    0.000000] CPU features: detected: Spectre-BHB
    [2026-03-10 16:07:15.716] [    0.000000] CPU features: detected: ARM erratum 1742098
    [2026-03-10 16:07:15.716] [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [2026-03-10 16:07:15.732] [    0.000000] alternatives: applying boot alternatives
    [2026-03-10 16:07:15.732] [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02880000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospt
    [2026-03-10 16:07:15.780] [    0.000000] Unknown kernel command line parameters "mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(o.
    [2026-03-10 16:07:15.828] [    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
    [2026-03-10 16:07:15.828] [    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [2026-03-10 16:07:15.844] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8388608
    [2026-03-10 16:07:15.844] [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [2026-03-10 16:07:15.860] [    0.000000] software IO TLB: area num 8.
    [2026-03-10 16:07:15.876] [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [2026-03-10 16:07:16.132] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [2026-03-10 16:07:16.132] [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [2026-03-10 16:07:16.148] [    0.000000] rcu:   RCU event tracing is enabled.
    [2026-03-10 16:07:16.148] [    0.000000] rcu:   RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
    [2026-03-10 16:07:16.164] [    0.000000]        Trampoline variant of Tasks RCU enabled.
    [2026-03-10 16:07:16.164] [    0.000000]        Tracing variant of Tasks RCU enabled.
    [2026-03-10 16:07:16.164] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [2026-03-10 16:07:16.180] [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [2026-03-10 16:07:16.180] [    0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
    [2026-03-10 16:07:16.196] [    0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
    [2026-03-10 16:07:16.196] [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [2026-03-10 16:07:16.212] [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [2026-03-10 16:07:16.212] [    0.000000] GICv3: 960 SPIs implemented
    [2026-03-10 16:07:16.212] [    0.000000] GICv3: 0 Extended SPIs implemented
    [2026-03-10 16:07:16.212] [    0.000000] Root IRQ handler: gic_handle_irq
    [2026-03-10 16:07:16.228] [    0.000000] GICv3: GICv3 features: 16 PPIs
    [2026-03-10 16:07:16.228] [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1
    [2026-03-10 16:07:16.228] [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [2026-03-10 16:07:16.244] [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [2026-03-10 16:07:16.244] [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [2026-03-10 16:07:16.244] [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [2026-03-10 16:07:16.260] [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @980800000 (flat, esz 8, psz 64K, shr 0)
    [2026-03-10 16:07:16.276] [    0.000000] ITS: using cache flushing for cmd queue
    [2026-03-10 16:07:16.276] [    0.000000] GICv3: using LPI property table @0x0000000980070000
    [2026-03-10 16:07:16.276] [    0.000000] GIC: using cache flushing for LPI property table
    [2026-03-10 16:07:16.292] [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000980080000
    [2026-03-10 16:07:16.292] [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [2026-03-10 16:07:16.308] [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [2026-03-10 16:07:16.308] [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [2026-03-10 16:07:16.324] [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [2026-03-10 16:07:16.324] [    0.008553] Console: colour dummy device 80x25
    [2026-03-10 16:07:16.340] [    0.013135] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [2026-03-10 16:07:16.340] [    0.023809] pid_max: default: 32768 minimum: 301
    [2026-03-10 16:07:16.340] [    0.028569] LSM: initializing lsm=capability,selinux
    [2026-03-10 16:07:16.356] [    0.033685] SELinux:  Initializing.
    [2026-03-10 16:07:16.356] [    0.037625] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [2026-03-10 16:07:16.372] [    0.045426] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [2026-03-10 16:07:16.372] [    0.055179] rcu: Hierarchical SRCU implementation.
    [2026-03-10 16:07:16.372] [    0.060092] rcu:   Max phase no-delay instances is 1000.
    [2026-03-10 16:07:16.388] [    0.065546] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [2026-03-10 16:07:16.388] [    0.074174] EFI services will not be available.
    [2026-03-10 16:07:16.404] [    0.079042] smp: Bringing up secondary CPUs ...
    [2026-03-10 16:07:16.404] I/TC: Secondary CPU 1 initializing
    [2026-03-10 16:07:16.404] I/TC: Secondary CPU 1 switching to normal world boot
    [2026-03-10 16:07:16.404] I/TC: Secondary CPU 2 initializing
    [2026-03-10 16:07:16.420] I/TC: Secondary CPU 2 switching to normal world boot
    [2026-03-10 16:07:16.420] I/TC: Secondary CPU 3 initializing
    [2026-03-10 16:07:16.420] I/TC: Secondary CPU 3 switching to normal world boot
    [2026-03-10 16:07:16.436] I/TC: Secondary CPU 4 initializing
    [2026-03-10 16:07:16.436] I/TC: Secondary CPU 4 switching to normal world boot
    [2026-03-10 16:07:16.436] I/TC: Secondary CPU 5 initializing
    [2026-03-10 16:07:16.436] I/TC: Secondary CPU 5 switching to normal world boot
    [2026-03-10 16:07:16.452] I/TC: Secondary CPU 6 initializing
    [2026-03-10 16:07:16.452] I/TC: Secondary CPU 6 switching to normal world boot
    [2026-03-10 16:07:16.452] I/TC: Secondary CPU 7 initializing
    [2026-03-10 16:07:16.452] I/TC: Secondary CPU 7 switching to normal world boot
    [2026-03-10 16:07:16.468] [    0.092159] Detected PIPT I-cache on CPU1
    [2026-03-10 16:07:16.468] [    0.092208] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [2026-03-10 16:07:16.468] [    0.092223] GICv3: CPU1: using allocated LPI pending table @0x0000000980090000
    [2026-03-10 16:07:16.484] [    0.092257] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [2026-03-10 16:07:16.484] [    0.100782] Detected PIPT I-cache on CPU2
    [2026-03-10 16:07:16.500] [    0.100812] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [2026-03-10 16:07:16.500] [    0.100825] GICv3: CPU2: using allocated LPI pending table @0x00000009800a0000
    [2026-03-10 16:07:16.500] [    0.100850] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [2026-03-10 16:07:16.516] [    0.109333] Detected PIPT I-cache on CPU3
    [2026-03-10 16:07:16.516] [    0.109365] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [2026-03-10 16:07:16.532] [    0.109377] GICv3: CPU3: using allocated LPI pending table @0x00000009800b0000
    [2026-03-10 16:07:16.532] [    0.109402] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [2026-03-10 16:07:16.532] [    0.117935] Detected PIPT I-cache on CPU4
    [2026-03-10 16:07:16.548] [    0.117999] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [2026-03-10 16:07:16.548] [    0.118013] GICv3: CPU4: using allocated LPI pending table @0x00000009800c0000
    [2026-03-10 16:07:16.564] [    0.118048] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [2026-03-10 16:07:16.564] [    0.126586] Detected PIPT I-cache on CPU5
    [2026-03-10 16:07:16.564] [    0.126625] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [2026-03-10 16:07:16.580] [    0.126639] GICv3: CPU5: using allocated LPI pending table @0x00000009800d0000
    [2026-03-10 16:07:16.580] [    0.126664] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [2026-03-10 16:07:16.596] [    0.135164] Detected PIPT I-cache on CPU6
    [2026-03-10 16:07:16.596] [    0.135206] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [2026-03-10 16:07:16.596] [    0.135219] GICv3: CPU6: using allocated LPI pending table @0x00000009800e0000
    [2026-03-10 16:07:16.612] [    0.135245] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [2026-03-10 16:07:16.612] [    0.143758] Detected PIPT I-cache on CPU7
    [2026-03-10 16:07:16.612] [    0.143801] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [2026-03-10 16:07:16.628] [    0.143814] GICv3: CPU7: using allocated LPI pending table @0x00000009800f0000
    [2026-03-10 16:07:16.628] [    0.143840] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [2026-03-10 16:07:16.644] [    0.143935] smp: Brought up 1 node, 8 CPUs
    [2026-03-10 16:07:16.644] [    0.324941] SMP: Total of 8 processors activated.
    [2026-03-10 16:07:16.644] [    0.329746] CPU: All CPU(s) started at EL2
    [2026-03-10 16:07:16.660] [    0.333936] CPU features: detected: 32-bit EL0 Support
    [2026-03-10 16:07:16.660] [    0.339187] CPU features: detected: CRC32 instructions
    [2026-03-10 16:07:16.660] [    0.344472] alternatives: applying system-wide alternatives
    [2026-03-10 16:07:16.676] [    0.350516] Memory: 25310460K/33554432K available (13056K kernel code, 1258K rwdata, 4676K rodata, 2752K init, 643K bss, 6397412K reserved, 1835008K cma-reserved)
    [2026-03-10 16:07:16.692] [    0.365960] devtmpfs: initialized
    [2026-03-10 16:07:16.708] [    0.381619] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [2026-03-10 16:07:16.708] [    0.391598] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [2026-03-10 16:07:16.740] [    0.421995] 27120 pages in range for non-PLT usage
    [2026-03-10 16:07:16.740] [    0.422011] 518640 pages in range for PLT usage
    [2026-03-10 16:07:16.756] [    0.427153] pinctrl core: initialized pinctrl subsystem
    [2026-03-10 16:07:16.756] [    0.437460] DMI not present or invalid.
    [2026-03-10 16:07:16.756] [    0.443004] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [2026-03-10 16:07:16.772] [    0.450374] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [2026-03-10 16:07:16.772] [    0.458381] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [2026-03-10 16:07:16.788] [    0.467085] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [2026-03-10 16:07:16.788] [    0.475302] audit: initializing netlink subsys (disabled)
    [2026-03-10 16:07:16.804] [    0.480971] audit: type=2000 audit(0.328:1): state=initialized audit_enabled=0 res=1
    [2026-03-10 16:07:16.804] [    0.481205] thermal_sys: Registered thermal governor 'step_wise'
    [2026-03-10 16:07:16.820] [    0.488894] thermal_sys: Registered thermal governor 'power_allocator'
    [2026-03-10 16:07:16.820] [    0.495054] cpuidle: using governor menu
    [2026-03-10 16:07:16.820] [    0.505804] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [2026-03-10 16:07:16.836] [    0.512851] ASID allocator initialised with 65536 entries
    [2026-03-10 16:07:16.836] [    0.523500] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
    [2026-03-10 16:07:16.868] [    0.544342] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [2026-03-10 16:07:16.868] [    0.551296] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [2026-03-10 16:07:16.884] [    0.557702] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [2026-03-10 16:07:16.884] [    0.564639] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [2026-03-10 16:07:16.884] [    0.571044] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [2026-03-10 16:07:16.900] [    0.577980] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [2026-03-10 16:07:16.900] [    0.584384] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [2026-03-10 16:07:16.916] [    0.591321] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [2026-03-10 16:07:16.916] [    0.598658] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [2026-03-10 16:07:16.932] [    0.607745] iommu: Default domain type: Translated
    [2026-03-10 16:07:16.932] [    0.612649] iommu: DMA domain TLB invalidation policy: strict mode
    [2026-03-10 16:07:16.932] [    0.619444] SCSI subsystem initialized
    [2026-03-10 16:07:16.948] [    0.623476] usbcore: registered new interface driver usbfs
    [2026-03-10 16:07:16.948] [    0.629101] usbcore: registered new interface driver hub
    [2026-03-10 16:07:16.948] [    0.634550] usbcore: registered new device driver usb
    [2026-03-10 16:07:16.964] [    0.640007] pps_core: LinuxPPS API ver. 1 registered
    [2026-03-10 16:07:16.964] [    0.645082] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [2026-03-10 16:07:16.980] [    0.654423] PTP clock support registered
    [2026-03-10 16:07:16.980] [    0.658449] EDAC MC: Ver: 3.0.0
    [2026-03-10 16:07:16.980] [    0.661805] scmi_core: SCMI protocol bus registered
    [2026-03-10 16:07:16.980] [    0.666939] FPGA manager framework
    [2026-03-10 16:07:16.996] [    0.670448] Advanced Linux Sound Architecture Driver Initialized.
    [2026-03-10 16:07:16.996] [    0.677160] vgaarb: loaded
    [2026-03-10 16:07:16.996] [    0.680106] clocksource: Switched to clocksource arch_sys_counter
    [2026-03-10 16:07:17.012] [    0.686486] VFS: Disk quotas dquot_6.6.0
    [2026-03-10 16:07:17.012] [    0.690509] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [2026-03-10 16:07:17.028] [    0.701503] Carveout Heap: Exported 960 MiB at 0x0000000a00000000
    [2026-03-10 16:07:17.028] [    0.707797] NET: Registered PF_INET protocol family
    [2026-03-10 16:07:17.028] [    0.713076] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [2026-03-10 16:07:17.044] [    0.725850] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [2026-03-10 16:07:17.060] [    0.734888] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [2026-03-10 16:07:17.060] [    0.742827] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [2026-03-10 16:07:17.076] [    0.751914] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [2026-03-10 16:07:17.076] [    0.760370] TCP: Hash tables configured (established 262144 bind 65536)
    [2026-03-10 16:07:17.092] [    0.767249] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [2026-03-10 16:07:17.092] [    0.774606] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [2026-03-10 16:07:17.108] [    0.782506] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [2026-03-10 16:07:17.108] [    0.788644] RPC: Registered named UNIX socket transport module.
    [2026-03-10 16:07:17.108] [    0.794707] RPC: Registered udp transport module.
    [2026-03-10 16:07:17.124] [    0.799512] RPC: Registered tcp transport module.
    [2026-03-10 16:07:17.124] [    0.804316] RPC: Registered tcp-with-tls transport module.
    [2026-03-10 16:07:17.124] [    0.809920] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [2026-03-10 16:07:17.140] [    0.816504] NET: Registered PF_XDP protocol family
    [2026-03-10 16:07:17.140] [    0.821411] PCI: CLS 0 bytes, default 64
    [2026-03-10 16:07:17.140] [    0.826435] Initialise system trusted keyrings
    [2026-03-10 16:07:17.156] [    0.831095] workingset: timestamp_bits=46 max_order=23 bucket_order=0
    [2026-03-10 16:07:17.156] [    0.837852] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [2026-03-10 16:07:17.156] [    0.843962] NFS: Registering the id_resolver key type
    [2026-03-10 16:07:17.172] [    0.849142] Key type id_resolver registered
    [2026-03-10 16:07:17.172] [    0.853416] Key type id_legacy registered
    [2026-03-10 16:07:17.172] [    0.857524] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [2026-03-10 16:07:17.188] [    0.864374] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [2026-03-10 16:07:17.220] [    0.893776] Key type asymmetric registered
    [2026-03-10 16:07:17.220] [    0.897963] Asymmetric key parser 'x509' registered
    [2026-03-10 16:07:17.220] [    0.902978] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [2026-03-10 16:07:17.236] [    0.910633] io scheduler mq-deadline registered
    [2026-03-10 16:07:17.236] [    0.915267] io scheduler kyber registered
    [2026-03-10 16:07:17.236] [    0.919376] io scheduler bfq registered
    [2026-03-10 16:07:17.252] [    0.925833] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [2026-03-10 16:07:17.252] [    0.931814] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
    [2026-03-10 16:07:17.252] [    0.937883] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
    [2026-03-10 16:07:17.268] [    0.944149] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
    [2026-03-10 16:07:17.268] [    0.949984] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [2026-03-10 16:07:17.268] [    0.956070] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [2026-03-10 16:07:17.284] [    0.961849] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [2026-03-10 16:07:17.284] [    0.968157] ledtrig-cpu: registered to indicate activity on CPUs
    [2026-03-10 16:07:17.300] [    0.978022] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [2026-03-10 16:07:17.316] [    0.991010] loop: module loaded
    [2026-03-10 16:07:17.316] [    0.994820] megasas: 07.727.03.00-rc1
    [2026-03-10 16:07:17.316] [    1.000767] tun: Universal TUN/TAP device driver, 1.6
    [2026-03-10 16:07:17.332] [    1.006531] VFIO - User Level meta-driver version: 0.3
    [2026-03-10 16:07:17.332] [    1.012543] usbcore: registered new interface driver usb-storage
    [2026-03-10 16:07:17.332] [    1.019072] i2c_dev: i2c /dev entries driver
    [2026-03-10 16:07:17.348] [    1.024164] sdhci: Secure Digital Host Controller Interface driver
    [2026-03-10 16:07:17.348] [    1.030481] sdhci: Copyright(c) Pierre Ossman
    [2026-03-10 16:07:17.348] [    1.035065] sdhci-pltfm: SDHCI platform and OF driver helper
    [2026-03-10 16:07:17.364] [    1.041299] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [2026-03-10 16:07:17.364] [    1.048391] usbcore: registered new interface driver usbhid
    [2026-03-10 16:07:17.380] [    1.054086] usbhid: USB HID core driver
    [2026-03-10 16:07:17.380] [    1.058853] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
    [2026-03-10 16:07:17.380] [    1.068760] optee: probing for conduit method.
    [2026-03-10 16:07:17.396] I/TC: Reserved shared memory is enabled
    [2026-03-10 16:07:17.396] I/TC: Dynamic shared memory is enabled
    [2026-03-10 16:07:17.396] I/TC: Normal World virtualization support is disabled
    [2026-03-10 16:07:17.412] I/TC: Asynchronous notifications are disabled
    [2026-03-10 16:07:17.412] [    1.073331] optee: revision 4.7 (a9690ae39995af36)
    [2026-03-10 16:07:17.412] [    1.089786] optee: dynamic shared memory is enabled
    [2026-03-10 16:07:17.412] [    1.100059] optee: initialized driver
    [2026-03-10 16:07:17.428] [    1.100173] random: crng init done
    [2026-03-10 16:07:17.428] [    1.105286] Initializing XFRM netlink socket
    [2026-03-10 16:07:17.428] [    1.111651] NET: Registered PF_PACKET protocol family
    [2026-03-10 16:07:17.444] [    1.116864] Key type dns_resolver registered
    [2026-03-10 16:07:17.444] [    1.125341] registered taskstats version 1
    [2026-03-10 16:07:17.444] [    1.129681] Loading compiled-in X.509 certificates
    [2026-03-10 16:07:17.460] [    1.142149] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 16:07:17.556] [    1.232068] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [2026-03-10 16:07:17.556] [    1.238464] pca953x 3-0020: supply vcc not found, using dummy regulator
    [2026-03-10 16:07:17.572] [    1.245292] pca953x 3-0020: using no AI
    [2026-03-10 16:07:17.588] [    1.265185] pca953x 3-0022: supply vcc not found, using dummy regulator
    [2026-03-10 16:07:17.588] [    1.272003] pca953x 3-0022: using AI
    [2026-03-10 16:07:17.604] [    1.276903] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [2026-03-10 16:07:17.604] [    1.282972] pca953x 4-0020: supply vcc not found, using dummy regulator
    [2026-03-10 16:07:17.604] [    1.289787] pca953x 4-0020: using no AI
    [2026-03-10 16:07:17.620] [    1.308593] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
    [2026-03-10 16:07:17.636] [    1.314469] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [2026-03-10 16:07:17.636] [    1.323018] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [2026-03-10 16:07:17.652] [    1.332288] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [2026-03-10 16:07:17.668] [    1.340964] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [2026-03-10 16:07:17.668] [    1.353548] ti-udma 311a0000.dma-controller: Number of rings: 48
    [2026-03-10 16:07:17.684] [    1.361253] ti-udma 311a0000.dma-controller: Channels: 48 (bchan: 0, tchan: 16, rchan: 32)
    [2026-03-10 16:07:17.684] [    1.371218] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [2026-03-10 16:07:17.700] [    1.381109] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [2026-03-10 16:07:17.700] [    1.387873] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [2026-03-10 16:07:17.716] [    1.397445] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [2026-03-10 16:07:17.732] [    1.407607] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [2026-03-10 16:07:17.732] [    1.414375] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [2026-03-10 16:07:17.748] [    1.422534] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 271, base_baud = 6000000) is a 8250
    [2026-03-10 16:07:17.748] [    1.432244] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 272, base_baud = 3000000) is a 8250
    [2026-03-10 16:07:17.768] [    1.441100] printk: legacy console [ttyS2] enabled
    [2026-03-10 16:07:17.768] [    1.450823] printk: legacy bootconsole [ns16550a0] disabled
    [2026-03-10 16:07:17.784] [    1.465924] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 16:07:17.832] [    1.512114] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 16:07:17.848] [    1.523019] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [2026-03-10 16:07:17.848] [    1.531349] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 16:07:17.864] [    1.538558] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 16:07:17.864] [    1.545961] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [2026-03-10 16:07:17.880] [    1.555997] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 16:07:17.880] [    1.568773] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [2026-03-10 16:07:17.928] [    1.608112] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 16:07:17.944] [    1.618784] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [2026-03-10 16:07:17.944] [    1.626915] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 16:07:17.960] [    1.634038] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 16:07:17.960] [    1.641253] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
    [2026-03-10 16:07:17.976] [    1.651660] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
    [2026-03-10 16:07:17.976] [    1.660509] mmc0: CQHCI version 5.10
    [2026-03-10 16:07:18.024] [    1.700679] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [2026-03-10 16:07:18.104] [    1.792164] mmc0: Command Queue Engine enabled
    [2026-03-10 16:07:18.120] [    1.796611] mmc0: new HS400 MMC card at address 0001
    [2026-03-10 16:07:18.120] [    1.801949] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [2026-03-10 16:07:18.120] [    1.807403]  mmcblk0: p1 p2
    [2026-03-10 16:07:18.136] [    1.810474] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [2026-03-10 16:07:18.136] [    1.816027] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [2026-03-10 16:07:18.136] [    1.821541] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [2026-03-10 16:07:18.248] [    1.929619] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [2026-03-10 16:07:18.264] [    1.937416] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [2026-03-10 16:07:18.264] [    1.944922] j721e-pcie 2900000.pcie:       IO 0x4000001000..0x4000100fff -> 0x0000001000
    [2026-03-10 16:07:18.280] [    1.953016] j721e-pcie 2900000.pcie:      MEM 0x4000101000..0x40ffffffff -> 0x0000101000
    [2026-03-10 16:07:18.280] [    1.961102] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [2026-03-10 16:07:19.400] [    3.076728] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [2026-03-10 16:07:19.400] [    3.083016] pci_bus 0000:00: root bus resource [bus 00-ff]
    [2026-03-10 16:07:19.400] [    3.088496] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x1000-0x100fff])
    [2026-03-10 16:07:19.416] [    3.097525] pci_bus 0000:00: root bus resource [mem 0x4000101000-0x40ffffffff] (bus address [0x00101000-0xffffffff])
    [2026-03-10 16:07:19.432] [    3.108054] pci 0000:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
    [2026-03-10 16:07:19.432] [    3.115350] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [2026-03-10 16:07:19.448] [    3.125003] pci 0000:00:00.0: PCI bridge to [bus 00]
    [2026-03-10 16:07:19.448] [    3.129961] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
    [2026-03-10 16:07:19.448] [    3.136043] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
    [2026-03-10 16:07:19.464] [    3.142833] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
    [2026-03-10 16:07:19.464] [    3.150646] pci 0000:00:00.0: supports D1
    [2026-03-10 16:07:19.480] [    3.154647] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [2026-03-10 16:07:19.480] [    3.162473] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [2026-03-10 16:07:19.496] [    3.170585] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [2026-03-10 16:07:19.496] [    3.177208] pci 0000:00:00.0: PCI bridge to [bus 01]
    [2026-03-10 16:07:19.496] [    3.182173] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
    [2026-03-10 16:07:19.512] [    3.187821] pci_bus 0000:00: resource 5 [mem 0x4000101000-0x40ffffffff]
    [2026-03-10 16:07:19.512] [    3.194480] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [2026-03-10 16:07:19.528] [    3.201301] pcieport 0000:00:00.0: PME: Signaling with IRQ 534
    [2026-03-10 16:07:19.528] [    3.207300] pcieport 0000:00:00.0: AER: enabled with IRQ 534
    [2026-03-10 16:07:19.528] [    3.213227] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [2026-03-10 16:07:19.544] [    3.220719] j721e-pcie 2910000.pcie:       IO 0x4100001000..0x4100100fff -> 0x0000001000
    [2026-03-10 16:07:19.544] [    3.228806] j721e-pcie 2910000.pcie:      MEM 0x4100101000..0x41ffffffff -> 0x0000101000
    [2026-03-10 16:07:19.560] [    3.236890] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [2026-03-10 16:07:20.664] [    4.348375] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [2026-03-10 16:07:20.680] [    4.354638] pci_bus 0001:00: root bus resource [bus 00-ff]
    [2026-03-10 16:07:20.680] [    4.360126] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x1000-0x100fff])
    [2026-03-10 16:07:20.696] [    4.369417] pci_bus 0001:00: root bus resource [mem 0x4100101000-0x41ffffffff] (bus address [0x00101000-0xffffffff])
    [2026-03-10 16:07:20.696] [    4.379941] pci 0001:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
    [2026-03-10 16:07:20.712] [    4.387237] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [2026-03-10 16:07:20.712] [    4.396889] pci 0001:00:00.0: PCI bridge to [bus 00]
    [2026-03-10 16:07:20.728] [    4.401846] pci 0001:00:00.0:   bridge window [io  0x0000-0x0fff]
    [2026-03-10 16:07:20.728] [    4.407929] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
    [2026-03-10 16:07:20.728] [    4.414709] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
    [2026-03-10 16:07:20.744] [    4.422520] pci 0001:00:00.0: supports D1
    [2026-03-10 16:07:20.744] [    4.426520] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [2026-03-10 16:07:20.760] [    4.434319] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [2026-03-10 16:07:20.760] [    4.442430] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [2026-03-10 16:07:20.776] [    4.449041] pci 0001:00:00.0: PCI bridge to [bus 01]
    [2026-03-10 16:07:20.776] [    4.454003] pci_bus 0001:00: resource 4 [io  0x100000-0x1fffff]
    [2026-03-10 16:07:20.776] [    4.459910] pci_bus 0001:00: resource 5 [mem 0x4100101000-0x41ffffffff]
    [2026-03-10 16:07:20.792] [    4.466554] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [2026-03-10 16:07:20.792] [    4.473322] pcieport 0001:00:00.0: PME: Signaling with IRQ 536
    [2026-03-10 16:07:20.792] [    4.479293] pcieport 0001:00:00.0: AER: enabled with IRQ 536
    [2026-03-10 16:07:20.808] [    4.485766] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [2026-03-10 16:07:20.808] [    4.496154] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [2026-03-10 16:07:20.824] [    4.509162] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
    [2026-03-10 16:07:20.840] [    4.516216] Creating 7 MTD partitions on "47040000.spi.0":
    [2026-03-10 16:07:20.840] [    4.521709] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [2026-03-10 16:07:20.840] [    4.527949] 0x000000080000-0x000000280000 : "ospi.tispl"
    [2026-03-10 16:07:20.856] [    4.533867] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [2026-03-10 16:07:20.856] [    4.539955] 0x000000680000-0x0000006c0000 : "ospi.env"
    [2026-03-10 16:07:20.872] [    4.545681] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [2026-03-10 16:07:20.872] [    4.552006] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [2026-03-10 16:07:20.872] [    4.557966] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [2026-03-10 16:07:20.904] [    4.585714] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
    [2026-03-10 16:07:20.920] [    4.592767] Creating 7 MTD partitions on "47050000.spi.0":
    [2026-03-10 16:07:20.920] [    4.598261] 0x000000000000-0x000000080000 : "qspi.tiboot3"
    [2026-03-10 16:07:20.920] [    4.604368] 0x000000080000-0x000000280000 : "qspi.tispl"
    [2026-03-10 16:07:20.936] [    4.610349] 0x000000280000-0x000000680000 : "qspi.u-boot"
    [2026-03-10 16:07:20.936] [    4.616344] 0x000000680000-0x0000006c0000 : "qspi.env"
    [2026-03-10 16:07:20.936] [    4.622069] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
    [2026-03-10 16:07:20.952] [    4.628414] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
    [2026-03-10 16:07:20.952] [    4.634383] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
    [2026-03-10 16:07:20.968] [    4.641067] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 16:07:21.000] [    4.688111] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 16:07:21.016] [    4.698928] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [2026-03-10 16:07:21.032] [    4.707246] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 16:07:21.032] [    4.714456] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 16:07:21.048] [    4.721832] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [2026-03-10 16:07:21.064] [    4.738905] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [2026-03-10 16:07:21.064] [    4.748664] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 16:07:21.080] [    4.761451] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [2026-03-10 16:07:21.112] [    4.800109] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 16:07:21.128] [    4.810946] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [2026-03-10 16:07:21.144] [    4.819108] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 16:07:21.144] [    4.826231] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 16:07:21.160] [    4.833491] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [2026-03-10 16:07:21.176] [    4.850404] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [2026-03-10 16:07:21.176] [    4.860974] clk: Disabling unused clocks
    [2026-03-10 16:07:21.192] [    4.861235] mmc1: CQHCI version 5.10
    [2026-03-10 16:07:21.192] [    4.877144] PM: genpd: Disabling unused power domains
    [2026-03-10 16:07:21.200] [    4.882302] ALSA device list:
    [2026-03-10 16:07:21.200] [    4.885339]   No soundcards found.
    [2026-03-10 16:07:21.232] [    4.906676] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [2026-03-10 16:07:21.232] [    4.914268] Waiting for root device PARTUUID=076c4a2a-02...
    [2026-03-10 16:07:21.296] [    4.977149] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [2026-03-10 16:07:21.296] [    4.984175] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
    [2026-03-10 16:07:21.312] [    4.992992]  mmcblk1: p1 p2
    [2026-03-10 16:07:21.504] [    5.188445] EXT4-fs (mmcblk1p2): recovery complete
    [2026-03-10 16:07:21.520] [    5.194333] EXT4-fs (mmcblk1p2): mounted filesystem d1eb63e9-b2b2-4688-9715-01bef2133809 r/w with ordered data mode. Quota mode: none.
    [2026-03-10 16:07:21.520] [    5.206470] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [2026-03-10 16:07:21.536] [    5.218351] devtmpfs: mounted
    [2026-03-10 16:07:21.536] [    5.222358] Freeing unused kernel memory: 2752K
    [2026-03-10 16:07:21.552] [    5.226983] Run /sbin/init as init process
    [2026-03-10 16:07:21.760] [    5.432894] systemd[1]: System time before build time, advancing clock.
    [2026-03-10 16:07:21.791] [    5.471953] NET: Registered PF_INET6 protocol family
    [2026-03-10 16:07:21.792] [    5.477593] Segment Routing with IPv6
    [2026-03-10 16:07:21.807] [    5.481276] In-situ OAM (IOAM) with IPv6
    [2026-03-10 16:07:21.839] [    5.516552] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO)
    [2026-03-10 16:07:21.872] [    5.548419] systemd[1]: Detected architecture arm64.
    [2026-03-10 16:07:21.872] Welcome to Arago 2025.01!
    [2026-03-10 16:07:21.887]
    [2026-03-10 16:07:21.888] [    5.566178] systemd[1]: Hostname set to <j784s4-evm>.
    [2026-03-10 16:07:22.160] [    5.845404] systemd[1]: Queued start job for default target Graphical Interface.
    [2026-03-10 16:07:22.207] [    5.891026] systemd[1]: Created slice Slice /system/getty.
    [2026-03-10 16:07:22.223] [  OK  ] Created slice Slice /system/getty.
    [2026-03-10 16:07:22.223] [    5.909131] systemd[1]: Created slice Slice /system/modprobe.
    [2026-03-10 16:07:22.240] [  OK  ] Created slice Slice /system/modprobe.
    [2026-03-10 16:07:22.255] [    5.929029] systemd[1]: Created slice Slice /system/serial-getty.
    [2026-03-10 16:07:22.256] [  OK  ] Created slice Slice /system/serial-getty.
    [2026-03-10 16:07:22.271] [    5.948867] systemd[1]: Created slice User and Session Slice.
    [2026-03-10 16:07:22.272] [  OK  ] Created slice User and Session Slice.
    [2026-03-10 16:07:22.287] [    5.968270] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [2026-03-10 16:07:22.288] [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [2026-03-10 16:07:22.304] [    5.988233] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [2026-03-10 16:07:22.319] [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [2026-03-10 16:07:22.320] [    6.008179] systemd[1]: Expecting device /dev/ttyS2...
    [2026-03-10 16:07:22.335]          Expecting device /dev/ttyS2...
    [2026-03-10 16:07:22.336] [    6.020207] systemd[1]: Reached target Path Units.
    [2026-03-10 16:07:22.351] [  OK  ] Reached target Path Units.
    [2026-03-10 16:07:22.352] [    6.032162] systemd[1]: Reached target Remote File Systems.
    [2026-03-10 16:07:22.352] [  OK  ] Reached target Remote File Systems.
    [2026-03-10 16:07:22.367] [    6.048162] systemd[1]: Reached target Slice Units.
    [2026-03-10 16:07:22.367] [  OK  ] Reached target Slice Units.
    [2026-03-10 16:07:22.384] [    6.060163] systemd[1]: Reached target Swaps.
    [2026-03-10 16:07:22.384] [  OK  ] Reached target Swaps.
    [2026-03-10 16:07:22.432] [    6.118809] systemd[1]: Listening on RPCbind Server Activation Socket.
    [2026-03-10 16:07:22.448] [  OK  ] Listening on RPCbind Server Activation Socket.
    [2026-03-10 16:07:22.448] [    6.136253] systemd[1]: Reached target RPC Port Mapper.
    [2026-03-10 16:07:22.464] [  OK  ] Reached target RPC Port Mapper.
    [2026-03-10 16:07:22.480] [    6.157622] systemd[1]: Listening on Process Core Dump Socket.
    [2026-03-10 16:07:22.480] [  OK  ] Listening on Process Core Dump Socket.
    [2026-03-10 16:07:22.496] [    6.176304] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [2026-03-10 16:07:22.496] [  OK  ] Listening on initctl Compatibility Named Pipe.
    [2026-03-10 16:07:22.512] [    6.196651] systemd[1]: Listening on Journal Audit Socket.
    [2026-03-10 16:07:22.527] [  OK  ] Listening on Journal Audit Socket.
    [2026-03-10 16:07:22.528] [    6.216383] systemd[1]: Listening on Journal Socket (/dev/log).
    [2026-03-10 16:07:22.544] [  OK  ] Listening on Journal Socket (/dev/log).
    [2026-03-10 16:07:22.560] [    6.236412] systemd[1]: Listening on Journal Socket.
    [2026-03-10 16:07:22.560] [  OK  ] Listening on Journal Socket.
    [2026-03-10 16:07:22.576] [    6.252427] systemd[1]: Listening on Network Service Netlink Socket.
    [2026-03-10 16:07:22.576] [  OK  ] Listening on Network Service Netlink Socket.
    [2026-03-10 16:07:22.591] [    6.276385] systemd[1]: Listening on udev Control Socket.
    [2026-03-10 16:07:22.607] [  OK  ] Listening on udev Control Socket.
    [2026-03-10 16:07:22.608] [    6.292348] systemd[1]: Listening on udev Kernel Socket.
    [2026-03-10 16:07:22.624] [  OK  ] Listening on udev Kernel Socket.
    [2026-03-10 16:07:22.624] [    6.308367] systemd[1]: Listening on User Database Manager Socket.
    [2026-03-10 16:07:22.640] [  OK  ] Listening on User Database Manager Socket.
    [2026-03-10 16:07:22.688] [    6.368321] systemd[1]: Mounting Huge Pages File System...
    [2026-03-10 16:07:22.688]          Mounting Huge Pages File System...
    [2026-03-10 16:07:22.704] [    6.382309] systemd[1]: Mounting POSIX Message Queue File System...
    [2026-03-10 16:07:22.704]          Mounting POSIX Message Queue File System...
    [2026-03-10 16:07:22.720] [    6.402499] systemd[1]: Mounting Kernel Debug File System...
    [2026-03-10 16:07:22.720]          Mounting Kernel Debug File System...
    [2026-03-10 16:07:22.736] [    6.416381] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [2026-03-10 16:07:22.751] [    6.433713] systemd[1]: Mounting Temporary Directory /tmp...
    [2026-03-10 16:07:22.751]          Mounting Temporary Directory /tmp...
    [2026-03-10 16:07:22.767] [    6.454667] systemd[1]: Starting Create List of Static Device Nodes...
    [2026-03-10 16:07:22.783]          Starting Create List of Static Device Nodes...
    [2026-03-10 16:07:22.799] [    6.474241] systemd[1]: Starting Load Kernel Module configfs...
    [2026-03-10 16:07:22.799]          Starting Load Kernel Module configfs...
    [2026-03-10 16:07:22.815] [    6.490624] systemd[1]: Starting Load Kernel Module drm...
    [2026-03-10 16:07:22.815]          Starting Load Kernel Module drm...
    [2026-03-10 16:07:22.831] [    6.506539] systemd[1]: Starting Load Kernel Module fuse...
    [2026-03-10 16:07:22.831]          Starting Load Kernel Module fuse...
    [2026-03-10 16:07:22.847] [    6.525294] systemd[1]: Starting Start psplash boot splash screen...
    [2026-03-10 16:07:22.847]          Starting Start psplash boot splash screen...
    [2026-03-10 16:07:22.863] [    6.541883] fuse: init (API version 7.41)
    [2026-03-10 16:07:22.864] [    6.550253] systemd[1]: Starting RPC Bind...
    [2026-03-10 16:07:22.879]          Starting RPC Bind...
    [2026-03-10 16:07:22.880] [    6.560345] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [2026-03-10 16:07:22.895] [    6.576568] systemd[1]: Starting Journal Service...
    [2026-03-10 16:07:22.896]          Starting Journal Service...
    [2026-03-10 16:07:22.911] [    6.595388] systemd[1]: Starting Load Kernel Modules...
    [2026-03-10 16:07:22.928]          Starting Load Kernel Modules...
    [2026-03-10 16:07:22.928] [    6.614741] systemd[1]: Starting Generate network units from Kernel command line...
    [2026-03-10 16:07:22.944]          Starting Generate network units from Kernel command line...
    [2026-03-10 16:07:22.944] [    6.629918] cryptodev: loading out-of-tree module taints kernel.
    [2026-03-10 16:07:22.960] [    6.636727] sysctl table check failed: ioctl/(null) procname is null
    [2026-03-10 16:07:22.960] [    6.637267] systemd-journald[173]: Collecting audit messages is enabled.
    [2026-03-10 16:07:22.976] [    6.643081] sysctl table check failed: ioctl/(null) No proc_handler
    [2026-03-10 16:07:22.976] [    6.656032] cryptodev: driver 1.14 loaded.
    [2026-03-10 16:07:23.008] [    6.692563] systemd[1]: Starting Remount Root and Kernel File Systems...
    [2026-03-10 16:07:23.024]          Starting Remount Root and Kernel File Systems...
    [2026-03-10 16:07:23.039] [    6.718925] systemd[1]: Starting Coldplug All udev Devices...
    [2026-03-10 16:07:23.040]          Starting Coldplug All udev Devices...
    [2026-03-10 16:07:23.056] [    6.739988] systemd[1]: Started RPC Bind.
    [2026-03-10 16:07:23.056] [    6.740427] EXT4-fs (mmcblk1p2): re-mounted d1eb63e9-b2b2-4688-9715-01bef2133809.
    [2026-03-10 16:07:23.072] [  OK  ] Started RPC Bind.
    [2026-03-10 16:07:23.087] [    6.765454] systemd[1]: Started Journal Service.
    [2026-03-10 16:07:23.087] [  OK  ] Started Journal Service.
    [2026-03-10 16:07:23.103] [  OK  ] Mounted Huge Pages File System.
    [2026-03-10 16:07:23.119] [  OK  ] Mounted POSIX Message Queue File System.
    [2026-03-10 16:07:23.136] [  OK  ] Mounted Kernel Debug File System.
    [2026-03-10 16:07:23.151] [  OK  ] Mounted Temporary Directory /tmp.
    [2026-03-10 16:07:23.168] [  OK  ] Finished Create List of Static Device Nodes.
    [2026-03-10 16:07:23.183] [  OK  ] Finished Load Kernel Module configfs.
    [2026-03-10 16:07:23.184] [  OK  ] Finished Load Kernel Module drm.
    [2026-03-10 16:07:23.199] [  OK  ] Finished Load Kernel Module fuse.
    [2026-03-10 16:07:23.215] [FAILED] Failed to start Start psplash boot splash screen.
    [2026-03-10 16:07:23.215] See 'systemctl status psplash-start.service' for details.
    [2026-03-10 16:07:23.231] [DEPEND] Dependency failed for Start psplas…temd progress communication helper.
    [2026-03-10 16:07:23.247] [  OK  ] Finished Load Kernel Modules.
    [2026-03-10 16:07:23.263] [  OK  ] Finished Generate network units from Kernel command line.
    [2026-03-10 16:07:23.279] [  OK  ] Finished Remount Root and Kernel File Systems.
    [2026-03-10 16:07:23.344]          Mounting FUSE Control File System...
    [2026-03-10 16:07:23.359]          Mounting Kernel Configuration File System...
    [2026-03-10 16:07:23.391]          Starting Flush Journal to Persistent Storage...
    [2026-03-10 16:07:23.407]          Starting Apply Kernel Variables...
    [2026-03-10 16:07:23.407]          Starting Create Static Device Nodes in /dev gr[    7.095464] systemd-journald[173]: Received client request to flush runtime journal.
    [2026-03-10 16:07:23.423] acefully...
    [2026-03-10 16:07:23.439] [  OK  ] Mounted FUSE Control File System.
    [2026-03-10 16:07:23.455] [  OK  ] Mounted Kernel Configuration File System.
    [2026-03-10 16:07:23.471] [  OK  ] Finished Flush Journal to Persistent Storage.
    [2026-03-10 16:07:23.487] [  OK  ] Finished Apply Kernel Variables.
    [2026-03-10 16:07:23.503] [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
    [2026-03-10 16:07:23.567]          Starting Create Static Device Nodes in /dev...
    [2026-03-10 16:07:23.584] [  OK  ] Finished Create Static Device Nodes in /dev.
    [2026-03-10 16:07:23.599] [  OK  ] Finished Coldplug All udev Devices.
    [2026-03-10 16:07:23.616] [  OK  ] Reached target Preparation for Local File Systems.
    [2026-03-10 16:07:23.632]          Mounting /var/volatile...
    [2026-03-10 16:07:23.632] [    7.317972] audit: type=1334 audit(1748544503.880:2): prog-id=6 op=LOAD
    [2026-03-10 16:07:23.648] [    7.324622] audit: type=1334 audit(1748544503.888:3): prog-id=7 op=LOAD
    [2026-03-10 16:07:23.648]          Starting Rule-based Manager for Device Events and Files...
    [2026-03-10 16:07:23.664] [  OK  ] Mounted /var/volatile.
    [2026-03-10 16:07:23.680]          Starting Load/Save OS Random Seed...
    [2026-03-10 16:07:23.695] [  OK  ] Reached target Local File Systems.
    [2026-03-10 16:07:23.696]          Starting Create System Files and Directories...
    [2026-03-10 16:07:23.743] [  OK  ] Finished Load/Save OS Random Seed.
    [2026-03-10 16:07:23.759] [  OK  ] Finished Create System Files and Directories.
    [2026-03-10 16:07:23.775] [    7.460323] audit: type=1334 audit(1748544504.024:4): prog-id=8 op=LOAD
    [2026-03-10 16:07:23.823]          Starting Network Name Resolution...
    [2026-03-10 16:07:23.823] [    7.506175] audit: type=1334 audit(1748544504.068:5): prog-id=9 op=LOAD
    [2026-03-10 16:07:23.839]          Starting Network Time Synchronization...
    [2026-03-10 16:07:23.839]          Starting Record System Boot/Shutdown in UTMP...
    [2026-03-10 16:07:23.855] [    7.543786] audit: type=1334 audit(1748544504.104:6): prog-id=10 op=LOAD
    [2026-03-10 16:07:23.871] [    7.550553] audit: type=1334 audit(1748544504.112:7): prog-id=11 op=LOAD
    [2026-03-10 16:07:23.871] [    7.557285] audit: type=1334 audit(1748544504.120:8): prog-id=12 op=LOAD
    [2026-03-10 16:07:23.887]          Starting User Database Manager...
    [2026-03-10 16:07:23.903] [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [2026-03-10 16:07:23.951] [  OK  ] Started User Database Manager.
    [2026-03-10 16:07:23.967] [  OK  ] Started Rule-based Manager for Device Events and Files.
    [2026-03-10 16:07:24.015] [  OK  ] Found device /dev/ttyS2.
    [2026-03-10 16:07:24.159] [  OK  ] Started Network Time Synchronization.
    [2026-03-10 16:07:24.160] [  OK  ] Started Network Name Resolution.
    [2026-03-10 16:07:24.319] [  OK  ] Reached target Host and Network Name Lookups.
    [2026-03-10 16:07:24.336] [  OK  ] Reached target System Initialization.
    [2026-03-10 16:07:24.352] [  OK  ] Started Daily Cleanup of Temporary Directories.
    [2026-03-10 16:07:24.367] [  OK  ] Reached target System Time Set.
    [2026-03-10 16:07:24.383] [    8.070454] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [2026-03-10 16:07:24.399] [  OK  ] Started Daily rotation of log files.
    [2026-03-10 16:07:24.415] [  OK  ] Reached target Timer Units.
    [2026-03-10 16:07:24.415] [    8.095443] CAN device driver interface
    [2026-03-10 16:07:24.415] [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [2026-03-10 16:07:24.431] [    8.115489] mc: Linux media interface: v0.10
    [2026-03-10 16:07:24.431] [  OK  ] Listening on D-Bus System Message Bus Socket.
    [2026-03-10 16:07:24.463] [    8.147052] videodev: Linux video capture interface: v2.00
    [2026-03-10 16:07:24.480]          Starting Docker Socket for the API...
    [2026-03-10 16:07:24.480] [    8.156404] PVR_K:  268: Read BVNC 36.53.104.796 from HW device registers
    [2026-03-10 16:07:24.480] [    8.156425] at24 0-0050: supply vcc not found, using dummy regulator
    [2026-03-10 16:07:24.496] [    8.167545] PVR_K:  268: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [2026-03-10 16:07:24.511] [    8.184329] [drm] Initialized pvr 25.2.6850647 for 4e20000000.gpu on minor 0
    [2026-03-10 16:07:24.512] [    8.186986] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [2026-03-10 16:07:24.512] [    8.197363] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 16:07:24.528] [    8.213920] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    8.228546] m_can_platform 40528000.can: m_can device registered (irq=657, version=32)
    [2026-03-10 16:07:24.559]
                              [2026-03-10 16:07:24.559] [    8.233123] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 16:07:24.575] [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [2026-03-10 16:07:24.575] [    8.264197] audit: type=1334 audit(1748544806.776:9): prog-id=13 op=LOAD
    [2026-03-10 16:07:24.591]          Starting D-Bus System Message Bus...
    [2026-03-10 16:07:24.592] [    8.271726] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 16:07:24.607] [    8.272469] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [2026-03-10 16:07:24.607] [    8.295002] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 16:07:24.623]          Starting Reboot and dump vmcore via kexec.[    8.302104] platform 41000000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:24.639] [    8.308681] m_can_platform 40568000.can: m_can device registered (irq=665, version=32)
    [2026-03-10 16:07:24.640] ..
    [2026-03-10 16:07:24.640] [    8.314281] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [2026-03-10 16:07:24.655] [    8.322512] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 16:07:24.656] [    8.338689] remoteproc remoteproc0: 41000000.r5f is available
    [2026-03-10 16:07:24.671] [    8.342245] m_can_platform 26a1000.can: m_can device registered (irq=668, version=32)
    [2026-03-10 16:07:24.671] [    8.345191] remoteproc remoteproc0: attaching to 41000000.r5f
    [2026-03-10 16:07:24.672] [  OK  ] Listening on Docker Socket for the [    8.361865] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [2026-03-10 16:07:24.688] API.
    [2026-03-10 16:07:24.688] [    8.374315] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [2026-03-10 16:07:24.703] [    8.374716] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [2026-03-10 16:07:24.704] [    8.392051] vdec 4210000.video-codec: OPP table not found in device tree
    [2026-03-10 16:07:24.719] [    8.404698] remoteproc remoteproc1: 64800000.dsp is available
    [2026-03-10 16:07:24.735] [    8.409682] virtio_rpmsg_bus virtio0: rpmsg host is online
    [2026-03-10 16:07:24.735] [    8.410527] remoteproc remoteproc1: attaching to 64800000.dsp
    [2026-03-10 16:07:24.736] [    8.417835] rproc-virtio rproc-virtio.8.auto: registered virtio0 (type 7)
    [2026-03-10 16:07:24.751] [    8.422072] remoteproc remoteproc1: unsupported resource 65538
    [2026-03-10 16:07:24.751] [    8.428495] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [2026-03-10 16:07:24.767] [    8.428537] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
    [2026-03-10 16:07:24.767] [    8.428743] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [2026-03-10 16:07:24.783] [    8.434484] rproc-virtio rproc-virtio.9.auto: assigned reserved memory node vision-apps-c71-dma-memory@b2000000
    [2026-03-10 16:07:24.783] [    8.435112] virtio_rpmsg_bus virtio1: rpmsg host is online
    [2026-03-10 16:07:24.799] [    8.442239] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:24.799] [    8.449526] platform 41400000.r5f: configured R5F for remoteproc mode
    [2026-03-10 16:07:24.799] [    8.468538] vdec 4210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [2026-03-10 16:07:24.815] [    8.472690] rproc-virtio rproc-virtio.9.auto: registered virtio1 (type 7)
    [2026-03-10 16:07:24.815] [    8.472950] platform 41400000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a1000000
    [2026-03-10 16:07:24.831] [    8.473865] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [2026-03-10 16:07:24.847] [    8.473881] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [2026-03-10 16:07:24.847] [    8.473886] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [2026-03-10 16:07:24.863] [    8.473891] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [2026-03-10 16:07:24.864] [    8.474286] remoteproc remoteproc2: 41400000.r5f is available
    [2026-03-10 16:07:24.879] [    8.474416] remoteproc remoteproc2: Direct firmware load for j784s4-mcu-r5f0_1-fw failed with error -2
    [2026-03-10 16:07:24.880] [    8.474424] remoteproc remoteproc2: powering up 41400000.r5f
    [2026-03-10 16:07:24.895] [    8.474442] remoteproc remoteproc2: Direct firmware load for j784s4-mcu-r5f0_1-fw failed with error -2
    [2026-03-10 16:07:24.896] [    8.474447] remoteproc remoteproc2: request_firmware failed: -2
    [2026-03-10 16:07:24.911] [    8.479353] vdec 4210000.video-codec: Product Code:      0x521c
    [2026-03-10 16:07:24.911] [    8.479358] vdec 4210000.video-codec: Firmware Revision: 363254
    [2026-03-10 16:07:24.912] [    8.599047] remoteproc remoteproc1: remote processor 64800000.dsp is now attached
    [2026-03-10 16:07:24.927] [    8.599104] platform 5c00000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:24.928] [  OK  ] Created slice Slice /system/tee-sup[    8.609297] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
    [2026-03-10 16:07:24.944] plicant.
    [2026-03-10 16:07:24.944] [    8.610704] m_can_platform 40568000.can mcu_mcan1: renamed from can1
    [2026-03-10 16:07:24.959] [    8.613048] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [2026-03-10 16:07:24.960] [    8.616931] vdec 4220000.video-codec: OPP table not found in device tree
    [2026-03-10 16:07:24.975] [    8.622152] vdec 4220000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [2026-03-10 16:07:24.975] [    8.622165] vdec 4220000.video-codec: Product Code:      0x521c
    [2026-03-10 16:07:24.991] [    8.622169] vdec 4220000.video-codec: Firmware Revision: 363254
    [2026-03-10 16:07:24.991] [    8.628443] scsi host0: ufshcd
    [2026-03-10 16:07:24.991] [    8.630920] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [2026-03-10 16:07:25.007] [    8.648693] remoteproc remoteproc4: 65800000.dsp is available
    [2026-03-10 16:07:25.007] [    8.658875] m_can_platform 26a1000.can main_mcan16: renamed from can2
    [2026-03-10 16:07:25.008] [    8.659262] remoteproc remoteproc4: attaching to 65800000.dsp
    [2026-03-10 16:07:25.023] [    8.681971] remoteproc remoteproc3: 5c00000.r5f is available
    [2026-03-10 16:07:25.024] [    8.686747] remoteproc remoteproc4: unsupported resource 65538
    [2026-03-10 16:07:25.024] [    8.687183] m_can_platform 40528000.can mcu_mcan0: renamed from can0
    [2026-03-10 16:07:25.040] [    8.692985] remoteproc remoteproc3: attaching to 5c00000.r5f
    [2026-03-10 16:07:25.040] [    8.698719] rproc-virtio rproc-virtio.10.auto: assigned reserved memory node vision-apps-c71_1-dma-memory@b4000000
    [2026-03-10 16:07:25.055] [    8.704724] rproc-virtio rproc-virtio.11.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [2026-03-10 16:07:25.056] [    8.710988] virtio_rpmsg_bus virtio2: rpmsg host is online
    [2026-03-10 16:07:25.071] [    8.714949] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.072] [    8.717660] virtio_rpmsg_bus virtio3: rpmsg host is online
    [2026-03-10 16:07:25.087] [    8.717863] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [2026-03-10 16:07:25.088] [    8.718715] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [2026-03-10 16:07:25.103] [    8.719664] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [2026-03-10 16:07:25.103] [    8.722276] rproc-virtio rproc-virtio.10.auto: registered virtio2 (type 7)
    [2026-03-10 16:07:25.104] [    8.725378] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.119] [    8.732924] rproc-virtio rproc-virtio.11.auto: registered virtio3 (type 7)
    [2026-03-10 16:07:25.119] [    8.742783] remoteproc remoteproc4: remote processor 65800000.dsp is now attached
    [2026-03-10 16:07:25.135] [    8.748268] remoteproc remoteproc3: remote processor 5c00000.r5f is now attached
    [2026-03-10 16:07:25.135] [    8.758396] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
    [2026-03-10 16:07:25.151] [    8.761359] platform 5d00000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:25.151] [    8.770785] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
    [2026-03-10 16:07:25.167] [    8.778101] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [2026-03-10 16:07:25.167] [    8.785644] remoteproc remoteproc5: 66800000.dsp is available
    [2026-03-10 16:07:25.184] [    8.793134] remoteproc remoteproc6: 5d00000.r5f is available
    [2026-03-10 16:07:25.184] [    8.799351] remoteproc remoteproc5: attaching to 66800000.dsp
    [2026-03-10 16:07:25.184] [    8.806159] remoteproc remoteproc6: attaching to 5d00000.r5f
    [2026-03-10 16:07:25.199] [    8.813969] remoteproc remoteproc5: unsupported resource 65538
    [2026-03-10 16:07:25.200] [    8.821353] rproc-virtio rproc-virtio.13.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [2026-03-10 16:07:25.215] [    8.830692] rproc-virtio rproc-virtio.12.auto: assigned reserved memory node vision-apps-c71_2-dma-memory@b6000000
    [2026-03-10 16:07:25.216] [    8.837542] virtio_rpmsg_bus virtio4: rpmsg host is online
    [2026-03-10 16:07:25.231] [    8.844397] virtio_rpmsg_bus virtio5: rpmsg host is online
    [2026-03-10 16:07:25.232] [    8.844417] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.232] [    8.847645] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.247] [    8.852568] rproc-virtio rproc-virtio.13.auto: registered virtio4 (type 7)
    [2026-03-10 16:07:25.248] [    8.858314] rproc-virtio rproc-virtio.12.auto: registered virtio5 (type 7)
    [2026-03-10 16:07:25.263] [    8.863945] remoteproc remoteproc6: remote processor 5d00000.r5f is now attached
    [2026-03-10 16:07:25.263] [    8.866134] platform 5e00000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:25.279] [    8.869729] remoteproc remoteproc5: remote processor 66800000.dsp is now attached
    [2026-03-10 16:07:25.279] [    8.875754] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
    [2026-03-10 16:07:25.295] [    8.882148] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
    [2026-03-10 16:07:25.295] [    8.891969] remoteproc remoteproc7: 5e00000.r5f is available
    [2026-03-10 16:07:25.311] [    8.902709] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
    [2026-03-10 16:07:25.311] [    8.907296] remoteproc remoteproc7: attaching to 5e00000.r5f
    [2026-03-10 16:07:25.312] [    8.912998] remoteproc remoteproc8: 67800000.dsp is available
    [2026-03-10 16:07:25.327] [    8.920117] rproc-virtio rproc-virtio.14.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a5000000
    [2026-03-10 16:07:25.327] [    8.926875] remoteproc remoteproc8: attaching to 67800000.dsp
    [2026-03-10 16:07:25.343] [    8.934286] virtio_rpmsg_bus virtio6: rpmsg host is online
    [2026-03-10 16:07:25.343] [    8.940838] remoteproc remoteproc8: unsupported resource 65538
    [2026-03-10 16:07:25.343] [    8.940978] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.359] [    8.948030] rproc-virtio rproc-virtio.14.auto: registered virtio6 (type 7)
    [2026-03-10 16:07:25.359] [    8.954214] rproc-virtio rproc-virtio.15.auto: assigned reserved memory node vision-apps-c71_3-dma-memory@b8000000
    [2026-03-10 16:07:25.375] [    8.961667] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached
    [2026-03-10 16:07:25.375] [    8.971321] virtio_rpmsg_bus virtio7: rpmsg host is online
    [2026-03-10 16:07:25.391] [    8.974445] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.392] [    8.980757] platform 5f00000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:25.407] [    8.986031] rproc-virtio rproc-virtio.15.auto: registered virtio7 (type 7)
    [2026-03-10 16:07:25.407] [    8.992764] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [2026-03-10 16:07:25.423] [    8.998262] remoteproc remoteproc8: remote processor 67800000.dsp is now attached
    [2026-03-10 16:07:25.423] [    9.004431] remoteproc remoteproc9: 5f00000.r5f is available
    [2026-03-10 16:07:25.423] [    9.110542] remoteproc remoteproc9: attaching to 5f00000.r5f
    [2026-03-10 16:07:25.439] [  OK  ] Reached target Socket Units.
    [2026-03-10 16:07:25.439] [    9.116439] rproc-virtio rproc-virtio.16.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [2026-03-10 16:07:25.455] [    9.132625] virtio_rpmsg_bus virtio8: rpmsg host is online
    [2026-03-10 16:07:25.455] [    9.138146] rproc-virtio rproc-virtio.16.auto: registered virtio8 (type 7)
    [2026-03-10 16:07:25.471] [    9.138955] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.471] [    9.145017] remoteproc remoteproc9: remote processor 5f00000.r5f is now attached
    [2026-03-10 16:07:25.471] [  OK  ] Started D-Bus System Message Bus    9.161232] platform 5900000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:25.487] m.
    [2026-03-10 16:07:25.487] [    9.171339] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [2026-03-10 16:07:25.503] [    9.181067] remoteproc remoteproc10: 5900000.r5f is available
    [2026-03-10 16:07:25.503] [    9.186877] remoteproc remoteproc10: attaching to 5900000.r5f
    [2026-03-10 16:07:25.519] [  OK  ] Finished Reboot and dump vmcore via[    9.192887] rproc-virtio rproc-virtio.17.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [2026-03-10 16:07:25.535]  kexec.
    [2026-03-10 16:07:25.535] [    9.208945] virtio_rpmsg_bus virtio9: rpmsg host is online
    [2026-03-10 16:07:25.535] [    9.215025] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.535] [    9.215160] rproc-virtio rproc-virtio.17.auto: registered virtio9 (type 7)
    [2026-03-10 16:07:25.551] [    9.229043] remoteproc remoteproc10: remote processor 5900000.r5f is now attached
    [2026-03-10 16:07:25.551] [    9.236927] platform 5a00000.r5f: configured R5F for IPC-only mode
    [2026-03-10 16:07:25.567] [    9.243278] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [2026-03-10 16:07:25.567] [    9.252917] remoteproc remoteproc11: 5a00000.r5f is available
    [2026-03-10 16:07:25.583] [    9.258726] remoteproc remoteproc11: attaching to 5a00000.r5f
    [2026-03-10 16:07:25.583] [    9.264740] rproc-virtio rproc-virtio.18.auto: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [2026-03-10 16:07:25.599] [    9.275566] virtio_rpmsg_bus virtio10: rpmsg host is online
    [2026-03-10 16:07:25.599] [    9.281245] rproc-virtio rproc-virtio.18.auto: registered virtio10 (type 7)
    [2026-03-10 16:07:25.615] [    9.281633] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
    [2026-03-10 16:07:25.615] [    9.288245] remoteproc remoteproc11: remote processor 5a00000.r5f is now attached
    [2026-03-10 16:07:25.616] [    9.303016] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.631] [    9.310242] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.632] [    9.317443] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.647] [    9.324650] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.648] [    9.331864] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.663] [    9.339045] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.663] [    9.346200] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.679] [    9.353378] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.679] [    9.361169] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.695] [    9.368887] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.695] [    9.376486] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.711] [    9.384177] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.711] [    9.391870] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.712] [    9.399547] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.727] [    9.407918] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.notifyservice addr 0x18
    [2026-03-10 16:07:25.728] [    9.416110] virtio_rpmsg_bus virtio3: creating channel ti.ethfw.ethdevice addr 0x22
    [2026-03-10 16:07:25.744] [    9.423934] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.744] [    9.431621] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.775] [  OK  ] Created slice Slice /system/systemd[    9.451459] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
    [2026-03-10 16:07:25.776] -fsck.
    [2026-03-10 16:07:25.791]          Expecting device /dev/mmcblk0p1...
    [2026-03-10 16:07:25.791] [    9.470787] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.807]          Expecting device /dev/mmcblk0p2...
    [2026-03-10 16:07:25.807] [    9.481911] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
    [    9.494562] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
    [2026-03-10 16:07:25.823]
    [2026-03-10 16:07:25.839] [  OK  ] Reached target Basic System.
    [2026-03-10 16:07:25.840] [    9.520616] ti_cpsw_proxy_client virtio3.ti.ethfw.ethdevice.-1.34: 1 Virtual Switch Port(s), 1 Virtual MAC Only Port(s)
    [2026-03-10 16:07:25.855] [    9.533008] ti_cpsw_proxy_client virtio3.ti.ethfw.ethdevice.-1.34: Virt Port: 25, Type: Switch Port, Iface: eth2, Num TX: 2, Num RX: 1, Token: 2500
    [2026-03-10 16:07:25.871] [    9.546210] ti_cpsw_proxy_client virtio3.ti.ethfw.ethdevice.-1.34: Virt Port: 1, Type: MAC Port, Iface: eth3, Num TX: 1, Num RX: 1, Token: 100
    [2026-03-10 16:07:25.919]          Starting Save/Restore Sound Card State...
    [2026-03-10 16:07:25.935] [  OK  ] Started Job spooling tools.
    [2026-03-10 16:07:25.951]          Starting Avahi mDNS/DNS-SD Stack...
    [2026-03-10 16:07:25.983] [  OK  ] Started Periodic Command Scheduler.
    [2026-03-10 16:07:25.999]          Starting Print notice about GPLv3 packages...
    [2026-03-10 16:07:26.015]          Starting IPv6 Packet Filtering Framework...
    [2026-03-10 16:07:26.016]          Starting IPv4 Packet Filtering Framework...
    [2026-03-10 16:07:26.031] [  OK  ] Started irqbalance daemon.
    [2026-03-10 16:07:26.032] [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
    [2026-03-10 16:07:26.032]          Starting Telephony service...
    [2026-03-10 16:07:26.047]          Starting Expand the rootfs part[    9.723933] audit: type=1334 audit(1748544808.236:10): prog-id=14 op=LOAD
    [2026-03-10 16:07:26.048] iti…to full size of the boot device....
    [2026-03-10 16:07:26.063] [  OK      9.735657] audit: type=1334 audit(1748544808.248:11): prog-id=15 op=LOAD
    [2026-03-10 16:07:26.064] 0m] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [2026-03-10 16:07:26.079]          Starting User Login Management...
    [2026-03-10 16:07:26.080]          Starting Virtual Console Setup...
    [2026-03-10 16:07:26.080] [  OK  ] Started TEE Supplicant on teepriv0.
    [2026-03-10 16:07:26.095]          Starting Telnet Server...
    [2026-03-10 16:07:26.095] [  OK  ] Finished Save/Restore Sound Card State.
    [2026-03-10 16:07:26.096] [  OK  ] Finished IPv6 Packet Filtering Framework.
    [2026-03-10 16:07:26.111] [  OK  ] Finished IPv4 Packet Filtering Framework.
    [2026-03-10 16:07:26.111] [  OK  ] Found device /dev/mmcblk1p1.
    [2026-03-10 16:07:26.127] [  OK  ] Finished Telnet Server.
    [2026-03-10 16:07:26.127] [  OK  ] Found device /dev/mmcblk0p1.
    [2026-03-10 16:07:26.143] [  OK  ] Found device /dev/mmcblk0p2.
    [2026-03-10 16:07:26.143] [  OK  ] Reached target Preparation for Network.
    [2026-03-10 16:07:26.159] [  OK  ] Reached target Sound Card.
    [2026-03-10 16:07:26.160]          Starting File System Check on /dev/mmcblk0p1...
    [2026-03-10 16:07:26.175]          Starting File System Check on /dev/mmcblk0p2...
    [2026-03-10 16:07:26.175]          Starting File System Check on /dev/mmcblk1p1...
    [2026-03-10 16:07:26.176]          Starting Network Configuration...
    [2026-03-10 16:07:26.191] [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [2026-03-10 16:07:26.239] [  OK  ] Started User Login Management.
    [2026-03-10 16:07:26.239] [  OK  ] Started Telephony service.
    [2026-03-10 16:07:26.303] [  OK  ] Finished File System Check on /dev/mmcblk0p1.
    [2026-03-10 16:07:26.351]          Mounting /run/media/boot-mmcblk0p1...
    [2026-03-10 16:07:26.383] [  OK  ] Mounted /run/media/boot-mmcblk0p1.
    [2026-03-10 16:07:26.463] [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [2026-03-10 16:07:26.479] [   10.158985] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [2026-03-10 16:07:26.495] [   10.171318] Bluetooth: Core ver 2.22
    [2026-03-10 16:07:26.495] [   10.175031] NET: Registered PF_BLUETOOTH protocol family
    [2026-03-10 16:07:26.495] [   10.180383] Bluetooth: HCI device and connection manager initialized
    [2026-03-10 16:07:26.511] [   10.186755] Bluetooth: HCI socket layer initialized
    [2026-03-10 16:07:26.511] [   10.191678] Bluetooth: L2CAP socket layer initialized
    [2026-03-10 16:07:26.512] [   10.196792] Bluetooth: SCO socket layer initialized
    [2026-03-10 16:07:26.543] [   10.218895] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [2026-03-10 16:07:26.543] [   10.224906] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [2026-03-10 16:07:26.559] [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [  OK  ] Finished Virtual Console Setup.
    [  OK  ] Finished File System Check on /dev/mmcblk0p2.
    [2026-03-10 16:07:26.623]          Mounting /run/media/rootfs-mmcblk0p2...
    [2026-03-10 16:07:26.623] [  OK  ] Finished File System Check on /dev/mmcblk1p1.
    [2026-03-10 16:07:26.639]          Mounting /run/media/boot-mmcblk1p1...
    [2026-03-10 16:07:26.671] [  OK  ] Started Network Configuration.
    [2026-03-10 16:07:26.671] [  OK  ] Reached target Network.
    [2026-03-10 16:07:26.671]          Starting containerd container runtime...
    [2026-03-10 16:07:26.687]          Starting LLDP daemon...
    [2026-03-10 16:07:26.687] [  OK  ] Started Netperf Benchmark Server   10.367169] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [2026-03-10 16:07:26.703] m.
    [2026-03-10 16:07:26.703] [   10.380565] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [2026-03-10 16:07:26.704]          Starting Simple Network Management Protocol (SNMP) Daemon....
    [2026-03-10 16:07:26.719]          Starting Permit User Ses[   10.396420] EXT4-fs (mmcblk0p2): mounted filesystem ec704a2a-2dbb-4ffd-adfb-f620d177de91 r/w with ordered data mode. Quota mode: none.
    [2026-03-10 16:07:26.735] sions...
    [2026-03-10 16:07:26.735] [   10.408504] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [2026-03-10 16:07:26.736] [   10.423149] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [2026-03-10 16:07:26.751] [  OK  ] Mounted /run/media/rootfs-mmcblk0p2.
    [2026-03-10 16:07:26.767] [   10.444222] ti_cpsw_proxy_client virtio3.ti.ethfw.ethdevice.-1.34: started port 25 on interface eth2
    [2026-03-10 16:07:26.767] [  OK  ] Finished Permit User Sessions.
    [2026-03-10 16:07:26.783] [   10.462911] ti_cpsw_proxy_client virtio3.ti.ethfw.ethdevice.-1.34: started port 1 on interface eth3
    [2026-03-10 16:07:26.799] [   10.480847] ti_cpsw_proxy_client virtio3.ti.ethfw.ethdevice.-1.34: 01:80:c2:00:00:0e is reserved for EthFw
    [2026-03-10 16:07:26.815] [  OK  ] Started emptty display manager.
    [2026-03-10 16:07:26.831] [  OK  ] Started Getty on tty1.
    [2026-03-10 16:07:26.831] [  OK  ] Started Serial Getty on ttyS2.
    [2026-03-10 16:07:26.832] [  OK  ] Reached target Login Prompts.
    [2026-03-10 16:07:26.863] [  OK  ] Started LLDP daemon.
    [2026-03-10 16:07:26.959] [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [2026-03-10 16:07:27.631] [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [2026-03-10 16:07:28.367] [  OK  ] Started containerd container runtime.
    [2026-03-10 16:07:29.391] ***************************************************************
    [2026-03-10 16:07:29.407] ***************************************************************
    [2026-03-10 16:07:29.407] NOTICE: This file system contains the following GPL-3.0 packages:
    [2026-03-10 16:07:29.408]       adwaita-icon-theme-symbolic
    [2026-03-10 16:07:29.423]       autoconf
    [2026-03-10 16:07:29.423]       bash-dev
    [2026-03-10 16:07:29.423]       bc
    [2026-03-10 16:07:29.423]       binutils
    [2026-03-10 16:07:29.423]       cifs-utils
    [2026-03-10 16:07:29.423]       coreutils-stdbuf
    [2026-03-10 16:07:29.423]       cpio
    [2026-03-10 16:07:29.423]       cpp-symlinks
    [2026-03-10 16:07:29.423]       dosfstools
    [2026-03-10 16:07:29.423]       elfutils-dev
    [2026-03-10 16:07:29.424]       findutils
    [2026-03-10 16:07:29.424]       g++-symlinks
    [2026-03-10 16:07:29.439]       g++
    [2026-03-10 16:07:29.439]       gawk
    [2026-03-10 16:07:29.439]       gcc-symlinks
    [2026-03-10 16:07:29.439]       gdb
    [2026-03-10 16:07:29.439]       gdbserver
    [2026-03-10 16:07:29.439]       gettext
    [2026-03-10 16:07:29.439]       glmark2
    [2026-03-10 16:07:29.439]       gnu-config
    [2026-03-10 16:07:29.439]       grub-common
    [2026-03-10 16:07:29.439]       grub-editenv
    [2026-03-10 16:07:29.439]       grub-efi
    [2026-03-10 16:07:29.439]       gzip
    [2026-03-10 16:07:29.439]       hidapi
    [2026-03-10 16:07:29.439]       kbd-dev
    [2026-03-10 16:07:29.439]       kbd-keymaps-pine
    [2026-03-10 16:07:29.440]       less
    [2026-03-10 16:07:29.440]       libasm1
    [2026-03-10 16:07:29.455]       libatomic-dev
    [2026-03-10 16:07:29.455]       libatomic1
    [2026-03-10 16:07:29.455]       libbfd
    [2026-03-10 16:07:29.455]       libdebuginfod1
    [2026-03-10 16:07:29.455]       libdw1
    [2026-03-10 16:07:29.455]       libelf1
    [2026-03-10 16:07:29.455]       libgcc-s-dev
    [2026-03-10 16:07:29.455]       libgcc1
    [2026-03-10 16:07:29.455]       libgdbm-compat4
    [2026-03-10 16:07:29.455]       libgdbm-dev
    [2026-03-10 16:07:29.455]       libgdbm6
    [2026-03-10 16:07:29.455]       libgettextlib
    [2026-03-10 16:07:29.455]       libgettextsrc
    [2026-03-10 16:07:29.455]       libgmp-dev
    [2026-03-10 16:07:29.471]       libgmp10
    [2026-03-10 16:07:29.471]       libgmpxx4
    [2026-03-10 16:07:29.471]       libgnutls-dev
    [2026-03-10 16:07:29.471]       libgnutls-openssl27
    [2026-03-10 16:07:29.471]       libgomp1
    [2026-03-10 16:07:29.471]       libidn2-0
    [2026-03-10 16:07:29.471]       libidn2-dev
    [2026-03-10 16:07:29.471]       libmpc3
    [2026-03-10 16:07:29.471]       libmpfr6
    [2026-03-10 16:07:29.471]       libopcodes
    [2026-03-10 16:07:29.471]       libqt6shadertools-dev
    [2026-03-10 16:07:29.471]       libqt6shadertools-plugins
    [2026-03-10 16:07:29.487]       libqt6shadertools-qmlplugins
    [2026-03-10 16:07:29.487]       libqt6shadertools6
    [2026-03-10 16:07:29.487]       libreadline-dev
    [2026-03-10 16:07:29.487]       libreadline8
    [2026-03-10 16:07:29.487]       libstdc++-dev
    [2026-03-10 16:07:29.487]       libstdc++6
    [2026-03-10 16:07:29.487]       libtasn1-dev
    [2026-03-10 16:07:29.487]       libunistring-dev
    [2026-03-10 16:07:29.487]       libunistring5
    [2026-03-10 16:07:29.487]       m4
    [2026-03-10 16:07:29.487]       make
    [2026-03-10 16:07:29.487]       nettle-dev
    [2026-03-10 16:07:29.503]       nettle
    [2026-03-10 16:07:29.503]       parted
    [2026-03-10 16:07:29.503]       piglit
    [2026-03-10 16:07:29.503]       qtbase-dev
    [2026-03-10 16:07:29.503]       qtbase-examples
    [2026-03-10 16:07:29.503]       qtbase-plugins
    [2026-03-10 16:07:29.503]       qtbase-qmlplugins
    [2026-03-10 16:07:29.503]       qtbase-staticdev
    [2026-03-10 16:07:29.503]       qtdeclarative-dev
    [2026-03-10 16:07:29.503]       qtdeclarative-plugins
    [2026-03-10 16:07:29.503]       qtdeclarative-qmlplugins
    [2026-03-10 16:07:29.519]       qtdeclarative-staticdev
    [2026-03-10 16:07:29.519]       qtlanguageserver-dev
    [2026-03-10 16:07:29.519]       qtlanguageserver-plugins
    [2026-03-10 16:07:29.519]       qtlanguageserver-qmlplugins
    [2026-03-10 16:07:29.519]       qtlanguageserver-staticdev
    [2026-03-10 16:07:29.535]       qtsvg-dev
    [2026-03-10 16:07:29.535]       qtsvg-plugins
    [2026-03-10 16:07:29.535]       qtsvg-qmlplugins
    [2026-03-10 16:07:29.535]       qtwayland-dev
    [2026-03-10 16:07:29.535]       qtwayland-plugins
    [2026-03-10 16:07:29.535]       qtwayland-qmlplugins
    [2026-03-10 16:07:29.535]       tar
    [2026-03-10 16:07:29.535]       which
    [2026-03-10 16:07:29.535] If you do not wish to distribute GPL-3.0 components please remove
    [2026-03-10 16:07:29.551] the above packages prior to distribution.  This can be done using
    [2026-03-10 16:07:29.551] the opkg remove command.  i.e.:
    [2026-03-10 16:07:29.551]     opkg remove <package>
    [2026-03-10 16:07:29.551] Where <package> is the name printed in the list above
    [2026-03-10 16:07:29.567]
    [2026-03-10 16:07:29.567] NOTE: If the package is a dependency of another package you
    [2026-03-10 16:07:29.567]       will be notified of the dependent packages.  You should
    [2026-03-10 16:07:29.567]       use the --force-removal-of-dependent-packages option to
    [2026-03-10 16:07:29.583]       also remove the dependent packages as well
    [2026-03-10 16:07:29.583] ***************************************************************
    [2026-03-10 16:07:29.599] [  OK  ] Finished Print notice about GPLv3 packages.
    [2026-03-10 16:07:29.615] [  OK  ] Reached target Multi-User System.
    [2026-03-10 16:07:29.631] [  OK  ] Reached target Graphical Interface.
    [2026-03-10 16:07:29.695]          Starting Record Runlevel Change in UTMP...
    [2026-03-10 16:07:29.711] [  OK  ] Finished Record Runlevel Change in UTMP.
    [2026-03-10 16:07:30.431] [   14.117111] kauditd_printk_skb: 2 callbacks suppressed
    [2026-03-10 16:07:30.447] [   14.117122] audit: type=1006 audit(1748544812.632:14): pid=1251 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [2026-03-10 16:07:30.463] [   14.136034] audit: type=1300 audit(1748544812.632:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffe3006e38 a2=4 a3=1 items=0 ppid=1 pid=1251 auid=1000 uid=0 gid=)
    [2026-03-10 16:07:30.479] [   14.163916] audit: type=1327 audit(1748544812.632:14): proctitle="(systemd)"
    [2026-03-10 16:07:30.767]
    [2026-03-10 16:07:30.767]  _____                    _____           _         _
    [2026-03-10 16:07:30.767] |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    [2026-03-10 16:07:30.783] |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    [2026-03-10 16:07:30.783] |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
    [2026-03-10 16:07:30.783]               |___|                    |___|
    [2026-03-10 16:07:30.799]
    [2026-03-10 16:07:30.799] Arago Project j784s4-evm ttyS2
    [2026-03-10 16:07:30.799] Arago 2025.01 j784s4-evm ttyS2
    [2026-03-10 16:07:30.799] j784s4-evm login: [   19.652724] platform connector-dp0: deferred probe pending: platform: supplier regulator-dp0-prw not ready
    [2026-03-10 16:07:35.983] [   19.662377] platform connector-dp1: deferred probe pending: platform: supplier regulator-dp1-prw not ready
    CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.8 | VT102 | Offline | ttyUSB4
    Falcon Boot flow:
    Time taken : 2.7 sec( Upto Starting Kernel Print...)
    U-Boot SPL 2025.01-ti-g38bf52655fb4-dirty (Mar 10 2026 - 15:52:59 +0530)
    [2026-03-10 15:58:30.902] SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 15:58:31.062] Initialized 4 DRAM controllers
    [2026-03-10 15:58:31.174] SPL initial stack usage: 13584 bytes
    [2026-03-10 15:58:31.174] Trying to boot from MMC2
    [2026-03-10 15:58:31.270] Skipping authentication on GP device
    [2026-03-10 15:58:31.286] Skipping authentication on GP device
    [2026-03-10 15:58:31.286] Before spl_board_prepare_for_boot
    [2026-03-10 15:58:31.286] Loading falcon payload from MMC2
    [2026-03-10 15:58:32.262] Skipping authentication on GP device
    [2026-03-10 15:58:32.598] Skipping authentication on GP device
    [2026-03-10 15:58:32.646] Set bootargs to: console=ttyS2,115200n8 root=PARTUUID=076c4a2a-02 rootwait
    [2026-03-10 15:58:32.678] Loading Environment from nowhere... OK
    [2026-03-10 15:58:32.694] Starting ATF on ARM64 core...
    [2026-03-10 15:58:32.694] NOTICE:  BL31: v2.13.0(debug):v2.13.0-259-ge0c4d3903-dirty
    [2026-03-10 15:58:32.710] NOTICE:  BL31: Built : 05:44:44, Feb 17 2026
    [2026-03-10 15:58:32.710] INFO:    GICv3 without legacy support detected.
    [2026-03-10 15:58:32.710] INFO:    ARM GICv3 driver initialized in EL3
    [2026-03-10 15:58:32.710] INFO:    Maximum SPI INTID supported: 991
    [2026-03-10 15:58:32.726] INFO:    SYSFW ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 15:58:32.726] INFO:    BL31: Initializing runtime services
    [2026-03-10 15:58:32.726] INFO:    BL31: cortex_a72: CPU workaround for erratum 1319367 was applied
    [2026-03-10 15:58:32.742] INFO:    BL31: cortex_a72: CPU workaround for CVE 2018_3639 was applied
    [2026-03-10 15:58:32.742] INFO:    BL31: cortex_a72: CPU workaround for CVE 2022_23960 was applied
    [2026-03-10 15:58:32.758] INFO:    BL31: Preparing for EL3 exit to normal world
    [2026-03-10 15:58:32.758] INFO:    Entry point address = 0x82000000
    [2026-03-10 15:58:32.758] INFO:    SPSR = 0x3c9
    [2026-03-10 15:58:33.625] [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [2026-03-10 15:58:33.625] [    0.000000] Linux version 6.12.57-ti-g31b07ab8dfbc-dirty (a0507176@a0507176-HP-Z2-Tower-G9-Workstation-Desktop-PC) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 26
    [2026-03-10 15:58:33.641] [    0.000000] KASLR disabled due to lack of seed
    [2026-03-10 15:58:33.657] [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [2026-03-10 15:58:33.657] [    0.000000] efi: UEFI not found.
    [2026-03-10 15:58:33.657] [    0.000000] Reserved memory: created CMA memory pool at 0x0000000f90000000, size 1792 MiB
    [2026-03-10 15:58:33.673] [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [2026-03-10 15:58:33.673] [    0.000000] OF: reserved mem: 0x0000000f90000000..0x0000000fffffffff (1835008 KiB) map reusable linux,cma
    [2026-03-10 15:58:33.689] [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [2026-03-10 15:58:33.689] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [2026-03-10 15:58:33.705] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.706] [    0.000000] OF: reserved mem: 0x00000000a0000000..0x00000000a00fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a0000000
    [2026-03-10 15:58:33.721] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [2026-03-10 15:58:33.737] [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.737] [    0.000000] OF: reserved mem: 0x00000000a0100000..0x00000000a0ffffff (15360 KiB) nomap non-reusable r5f-memory@a0100000
    [2026-03-10 15:58:33.753] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [2026-03-10 15:58:33.753] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.769] [    0.000000] OF: reserved mem: 0x00000000a1000000..0x00000000a10fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a1000000
    [2026-03-10 15:58:33.785] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [2026-03-10 15:58:33.785] [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.801] [    0.000000] OF: reserved mem: 0x00000000a1100000..0x00000000a1ffffff (15360 KiB) nomap non-reusable r5f-memory@a1100000
    [2026-03-10 15:58:33.801] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [2026-03-10 15:58:33.817] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.817] [    0.000000] OF: reserved mem: 0x00000000a2000000..0x00000000a20fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a2000000
    [2026-03-10 15:58:33.833] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [2026-03-10 15:58:33.833] [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.849] [    0.000000] OF: reserved mem: 0x00000000a2100000..0x00000000a2ffffff (15360 KiB) nomap non-reusable r5f-memory@a2100000
    [2026-03-10 15:58:33.865] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [2026-03-10 15:58:33.865] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.881] [    0.000000] OF: reserved mem: 0x00000000a3000000..0x00000000a30fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a3000000
    [2026-03-10 15:58:33.881] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [2026-03-10 15:58:33.897] [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.913] [    0.000000] OF: reserved mem: 0x00000000a3100000..0x00000000a3ffffff (15360 KiB) nomap non-reusable r5f-memory@a3100000
    [2026-03-10 15:58:33.914] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [2026-03-10 15:58:33.929] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.929] [    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a40fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a4000000
    [2026-03-10 15:58:33.945] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [2026-03-10 15:58:33.945] [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.961] [    0.000000] OF: reserved mem: 0x00000000a4100000..0x00000000a4ffffff (15360 KiB) nomap non-reusable r5f-memory@a4100000
    [2026-03-10 15:58:33.977] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [2026-03-10 15:58:33.977] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [2026-03-10 15:58:33.993] [    0.000000] OF: reserved mem: 0x00000000a5000000..0x00000000a50fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a5000000
    [2026-03-10 15:58:33.994] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [2026-03-10 15:58:34.009] [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.025] [    0.000000] OF: reserved mem: 0x00000000a5100000..0x00000000a5ffffff (15360 KiB) nomap non-reusable r5f-memory@a5100000
    [2026-03-10 15:58:34.025] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [2026-03-10 15:58:34.041] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.041] [    0.000000] OF: reserved mem: 0x00000000a6000000..0x00000000a60fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a6000000
    [2026-03-10 15:58:34.057] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [2026-03-10 15:58:34.058] [    0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.073] [    0.000000] OF: reserved mem: 0x00000000a6100000..0x00000000a6ffffff (15360 KiB) nomap non-reusable r5f-memory@a6100000
    [2026-03-10 15:58:34.089] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [2026-03-10 15:58:34.089] [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.105] [    0.000000] OF: reserved mem: 0x00000000a7000000..0x00000000a70fffff (1024 KiB) nomap non-reusable r5f-dma-memory@a7000000
    [2026-03-10 15:58:34.105] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [2026-03-10 15:58:34.121] [    0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.121] [    0.000000] OF: reserved mem: 0x00000000a7100000..0x00000000a7ffffff (15360 KiB) nomap non-reusable r5f-memory@a7100000
    [2026-03-10 15:58:34.137] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [2026-03-10 15:58:34.153] [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.153] [    0.000000] OF: reserved mem: 0x00000000a8000000..0x00000000a80fffff (1024 KiB) nomap non-reusable c71-dma-memory@a8000000
    [2026-03-10 15:58:34.169] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [2026-03-10 15:58:34.169] [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.185] [    0.000000] OF: reserved mem: 0x00000000a8100000..0x00000000a8ffffff (15360 KiB) nomap non-reusable c71-memory@a8100000
    [2026-03-10 15:58:34.201] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [2026-03-10 15:58:34.201] [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a9000000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.217] [    0.000000] OF: reserved mem: 0x00000000a9000000..0x00000000a90fffff (1024 KiB) nomap non-reusable c71-dma-memory@a9000000
    [2026-03-10 15:58:34.217] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [2026-03-10 15:58:34.233] [    0.000000] OF: reserved mem: initialized node c71-memory@a9100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.233] [    0.000000] OF: reserved mem: 0x00000000a9100000..0x00000000a9ffffff (15360 KiB) nomap non-reusable c71-memory@a9100000
    [2026-03-10 15:58:34.249] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [2026-03-10 15:58:34.265] [    0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.265] [    0.000000] OF: reserved mem: 0x00000000aa000000..0x00000000aa0fffff (1024 KiB) nomap non-reusable c71-dma-memory@aa000000
    [2026-03-10 15:58:34.281] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
    [2026-03-10 15:58:34.281] [    0.000000] OF: reserved mem: initialized node c71-memory@aa100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.297] [    0.000000] OF: reserved mem: 0x00000000aa100000..0x00000000aaffffff (15360 KiB) nomap non-reusable c71-memory@aa100000
    [2026-03-10 15:58:34.313] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
    [2026-03-10 15:58:34.313] [    0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.329] [    0.000000] OF: reserved mem: 0x00000000ab000000..0x00000000ab0fffff (1024 KiB) nomap non-reusable c71-dma-memory@ab000000
    [2026-03-10 15:58:34.329] [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
    [2026-03-10 15:58:34.345] [    0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
    [2026-03-10 15:58:34.345] [    0.000000] OF: reserved mem: 0x00000000ab100000..0x00000000abffffff (15360 KiB) nomap non-reusable c71-memory@ab100000
    [2026-03-10 15:58:34.361] [    0.000000] Zone ranges:
    [2026-03-10 15:58:34.361] [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [2026-03-10 15:58:34.377] [    0.000000]   DMA32    empty
    [2026-03-10 15:58:34.377] [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000fffffffff]
    [2026-03-10 15:58:34.377] [    0.000000] Movable zone start for each node
    [2026-03-10 15:58:34.377] [    0.000000] Early memory node ranges
    [2026-03-10 15:58:34.393] [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [2026-03-10 15:58:34.393] [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000abffffff]
    [2026-03-10 15:58:34.393] [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000ffffffff]
    [2026-03-10 15:58:34.409] [    0.000000]   node   0: [mem 0x0000000880000000-0x0000000fffffffff]
    [2026-03-10 15:58:34.409] [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000fffffffff]
    [2026-03-10 15:58:34.425] [    0.000000] psci: probing for conduit method from DT.
    [2026-03-10 15:58:34.425] [    0.000000] psci: PSCIv1.1 detected in firmware.
    [2026-03-10 15:58:34.425] [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [2026-03-10 15:58:34.441] [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    [2026-03-10 15:58:34.441] [    0.000000] psci: SMC Calling Convention v1.5
    [2026-03-10 15:58:34.441] [    0.000000] percpu: Embedded 22 pages/cpu s51736 r8192 d30184 u90112
    [2026-03-10 15:58:34.457] [    0.000000] Detected PIPT I-cache on CPU0
    [2026-03-10 15:58:34.457] [    0.000000] CPU features: detected: GIC system register CPU interface
    [2026-03-10 15:58:34.457] [    0.000000] CPU features: detected: Spectre-v3a
    [2026-03-10 15:58:34.457] [    0.000000] CPU features: detected: Spectre-BHB
    [2026-03-10 15:58:34.473] [    0.000000] CPU features: detected: ARM erratum 1742098
    [2026-03-10 15:58:34.473] [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [2026-03-10 15:58:34.489] [    0.000000] alternatives: applying boot alternatives
    [2026-03-10 15:58:34.489] [    0.000000] Kernel command line: console=ttyS2,115200n8 root=PARTUUID=076c4a2a-02 rootwait
    [2026-03-10 15:58:34.489] [    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
    [2026-03-10 15:58:34.505] [    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
    [2026-03-10 15:58:34.505] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 8388608
    [2026-03-10 15:58:34.521] [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [2026-03-10 15:58:34.521] [    0.000000] software IO TLB: area num 8.
    [2026-03-10 15:58:34.521] [    0.000000] software IO TLB: mapped [mem 0x00000000fbfff000-0x00000000fffff000] (64MB)
    [2026-03-10 15:58:34.537] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [2026-03-10 15:58:34.537] [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [2026-03-10 15:58:34.553] [    0.000000] rcu:   RCU event tracing is enabled.
    [2026-03-10 15:58:34.553] [    0.000000] rcu:   RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=8.
    [2026-03-10 15:58:34.553] [    0.000000]        Trampoline variant of Tasks RCU enabled.
    [2026-03-10 15:58:34.569] [    0.000000]        Tracing variant of Tasks RCU enabled.
    [2026-03-10 15:58:34.569] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [2026-03-10 15:58:34.585] [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [2026-03-10 15:58:34.585] [    0.000000] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
    [2026-03-10 15:58:34.585] [    0.000000] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
    [2026-03-10 15:58:34.601] [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [2026-03-10 15:58:34.601] [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [2026-03-10 15:58:34.617] [    0.000000] GICv3: 960 SPIs implemented
    [2026-03-10 15:58:34.617] [    0.000000] GICv3: 0 Extended SPIs implemented
    [2026-03-10 15:58:34.618] [    0.000000] Root IRQ handler: gic_handle_irq
    [2026-03-10 15:58:34.618] [    0.000000] GICv3: GICv3 features: 16 PPIs
    [2026-03-10 15:58:34.633] [    0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=0
    [2026-03-10 15:58:34.633] [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [2026-03-10 15:58:34.633] [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [2026-03-10 15:58:34.649] [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [2026-03-10 15:58:34.649] [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [2026-03-10 15:58:34.665] [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
    [2026-03-10 15:58:34.665] [    0.000000] ITS: using cache flushing for cmd queue
    [2026-03-10 15:58:34.665] [    0.000000] GICv3: using LPI property table @0x0000000880070000
    [2026-03-10 15:58:34.681] [    0.000000] GIC: using cache flushing for LPI property table
    [2026-03-10 15:58:34.681] [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000880080000
    [2026-03-10 15:58:34.697] [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [2026-03-10 15:58:34.697] [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [2026-03-10 15:58:34.697] [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [2026-03-10 15:58:34.713] [    0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [2026-03-10 15:58:34.729] [    0.000335] Console: colour dummy device 80x25
    [2026-03-10 15:58:34.729] [    0.000382] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [2026-03-10 15:58:34.745] [    0.000387] pid_max: default: 32768 minimum: 301
    [2026-03-10 15:58:34.745] [    0.000434] LSM: initializing lsm=capability,selinux
    [2026-03-10 15:58:34.745] [    0.000476] SELinux:  Initializing.
    [2026-03-10 15:58:34.745] [    0.000855] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [2026-03-10 15:58:34.761] [    0.000916] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [2026-03-10 15:58:34.761] [    0.002484] rcu: Hierarchical SRCU implementation.
    [2026-03-10 15:58:34.777] [    0.002489] rcu:   Max phase no-delay instances is 1000.
    [2026-03-10 15:58:34.777] [    0.002608] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
    [2026-03-10 15:58:34.777] [    0.002924] EFI services will not be available.
    [2026-03-10 15:58:34.793] [    0.003153] smp: Bringing up secondary CPUs ...
    [2026-03-10 15:58:34.793] [    0.003628] Detected PIPT I-cache on CPU1
    [2026-03-10 15:58:34.793] [    0.003677] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [2026-03-10 15:58:34.809] [    0.003690] GICv3: CPU1: using allocated LPI pending table @0x0000000880090000
    [2026-03-10 15:58:34.809] [    0.003722] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [2026-03-10 15:58:34.825] [    0.004278] Detected PIPT I-cache on CPU2
    [2026-03-10 15:58:34.825] [    0.004308] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [2026-03-10 15:58:34.826] [    0.004321] GICv3: CPU2: using allocated LPI pending table @0x00000008800a0000
    [2026-03-10 15:58:34.841] [    0.004345] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [2026-03-10 15:58:34.841] [    0.004817] Detected PIPT I-cache on CPU3
    [2026-03-10 15:58:34.841] [    0.004850] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [2026-03-10 15:58:34.857] [    0.004862] GICv3: CPU3: using allocated LPI pending table @0x00000008800b0000
    [2026-03-10 15:58:34.857] [    0.004886] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [2026-03-10 15:58:34.873] [    0.005403] Detected PIPT I-cache on CPU4
    [2026-03-10 15:58:34.873] [    0.005465] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [2026-03-10 15:58:34.873] [    0.005479] GICv3: CPU4: using allocated LPI pending table @0x00000008800c0000
    [2026-03-10 15:58:34.889] [    0.005513] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [2026-03-10 15:58:34.889] [    0.006043] Detected PIPT I-cache on CPU5
    [2026-03-10 15:58:34.889] [    0.006080] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [2026-03-10 15:58:34.905] [    0.006093] GICv3: CPU5: using allocated LPI pending table @0x00000008800d0000
    [2026-03-10 15:58:34.906] [    0.006117] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [2026-03-10 15:58:34.921] [    0.006605] Detected PIPT I-cache on CPU6
    [2026-03-10 15:58:34.921] [    0.006645] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [2026-03-10 15:58:34.922] [    0.006658] GICv3: CPU6: using allocated LPI pending table @0x00000008800e0000
    [2026-03-10 15:58:34.937] [    0.006683] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [2026-03-10 15:58:34.937] [    0.007181] Detected PIPT I-cache on CPU7
    [2026-03-10 15:58:34.953] [    0.007223] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [2026-03-10 15:58:34.953] [    0.007236] GICv3: CPU7: using allocated LPI pending table @0x00000008800f0000
    [2026-03-10 15:58:34.953] [    0.007260] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [2026-03-10 15:58:34.969] [    0.007339] smp: Brought up 1 node, 8 CPUs
    [2026-03-10 15:58:34.969] [    0.007344] SMP: Total of 8 processors activated.
    [2026-03-10 15:58:34.969] [    0.007347] CPU: All CPU(s) started at EL2
    [2026-03-10 15:58:34.985] [    0.007349] CPU features: detected: 32-bit EL0 Support
    [2026-03-10 15:58:34.985] [    0.007352] CPU features: detected: CRC32 instructions
    [2026-03-10 15:58:34.985] [    0.007392] alternatives: applying system-wide alternatives
    [2026-03-10 15:58:35.001] [    0.007751] Memory: 30757596K/33554432K available (13056K kernel code, 1258K rwdata, 4676K rodata, 2752K init, 643K bss, 950276K reserved, 1835008K cma-reserved)
    [2026-03-10 15:58:35.017] [    0.008399] devtmpfs: initialized
    [2026-03-10 15:58:35.017] [    0.020398] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [2026-03-10 15:58:35.018] [    0.020412] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [2026-03-10 15:58:35.033] [    0.044364] 27120 pages in range for non-PLT usage
    [2026-03-10 15:58:35.033] [    0.044373] 518640 pages in range for PLT usage
    [2026-03-10 15:58:35.033] [    0.044585] pinctrl core: initialized pinctrl subsystem
    [2026-03-10 15:58:35.049] [    0.044921] DMI not present or invalid.
    [2026-03-10 15:58:35.049] [    0.046578] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [2026-03-10 15:58:35.049] [    0.047883] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [2026-03-10 15:58:35.065] [    0.048608] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [2026-03-10 15:58:35.065] [    0.049304] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [2026-03-10 15:58:35.081] [    0.049341] audit: initializing netlink subsys (disabled)
    [2026-03-10 15:58:35.081] [    0.049491] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
    [2026-03-10 15:58:35.097] [    0.049719] thermal_sys: Registered thermal governor 'step_wise'
    [2026-03-10 15:58:35.097] [    0.049721] thermal_sys: Registered thermal governor 'power_allocator'
    [2026-03-10 15:58:35.098] [    0.049744] cpuidle: using governor menu
    [2026-03-10 15:58:35.113] [    0.049813] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [2026-03-10 15:58:35.113] [    0.049925] ASID allocator initialised with 65536 entries
    [2026-03-10 15:58:35.114] [    0.055601] /bus@100000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@100000/interrupt-controller@1800000
    [2026-03-10 15:58:35.129] [    0.055711] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
    [2026-03-10 15:58:35.145] [    0.055933] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [2026-03-10 15:58:35.145] [    0.055940] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
    [2026-03-10 15:58:35.161] [    0.055963] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [2026-03-10 15:58:35.161] [    0.055984] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
    [2026-03-10 15:58:35.177] [    0.055994] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
    [2026-03-10 15:58:35.177] [    0.060182] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
    [2026-03-10 15:58:35.193] [    0.063394] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
    [2026-03-10 15:58:35.209] [    0.063434] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [2026-03-10 15:58:35.209] [    0.063449] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
    [2026-03-10 15:58:35.225] [    0.063604] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [2026-03-10 15:58:35.225] [    0.063836] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [2026-03-10 15:58:35.241] [    0.063874] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/dss@4a00000
    [2026-03-10 15:58:35.241] [    0.063912] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
    [2026-03-10 15:58:35.257] [    0.063946] /bus@100000/dss@4a00000: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
    [2026-03-10 15:58:35.257] [    0.064821] /bus@100000/bridge@a000000: Fixed dependency cycle(s) with /connector-dp0
    [2026-03-10 15:58:35.273] [    0.064875] /connector-dp0: Fixed dependency cycle(s) with /bus@100000/bridge@a000000
    [2026-03-10 15:58:35.273] [    0.065588] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /connector-dp1
    [2026-03-10 15:58:35.289] [    0.065642] /connector-dp1: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
    [2026-03-10 15:58:35.305] [    0.066141] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [2026-03-10 15:58:35.305] [    0.066143] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [2026-03-10 15:58:35.305] [    0.066146] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [2026-03-10 15:58:35.321] [    0.066148] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [2026-03-10 15:58:35.321] [    0.066150] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [2026-03-10 15:58:35.337] [    0.066152] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [2026-03-10 15:58:35.337] [    0.066154] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [2026-03-10 15:58:35.337] [    0.066156] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [2026-03-10 15:58:35.353] [    0.067110] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [2026-03-10 15:58:35.353] [    0.067546] iommu: Default domain type: Translated
    [2026-03-10 15:58:35.369] [    0.067549] iommu: DMA domain TLB invalidation policy: strict mode
    [2026-03-10 15:58:35.369] [    0.068309] SCSI subsystem initialized
    [2026-03-10 15:58:35.369] [    0.068510] usbcore: registered new interface driver usbfs
    [2026-03-10 15:58:35.385] [    0.068527] usbcore: registered new interface driver hub
    [2026-03-10 15:58:35.385] [    0.068545] usbcore: registered new device driver usb
    [2026-03-10 15:58:35.385] [    0.068860] pps_core: LinuxPPS API ver. 1 registered
    [2026-03-10 15:58:35.401] [    0.068862] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [2026-03-10 15:58:35.401] [    0.068868] PTP clock support registered
    [2026-03-10 15:58:35.401] [    0.068887] EDAC MC: Ver: 3.0.0
    [2026-03-10 15:58:35.417] [    0.069048] scmi_core: SCMI protocol bus registered
    [2026-03-10 15:58:35.417] [    0.069201] FPGA manager framework
    [2026-03-10 15:58:35.417] [    0.069246] Advanced Linux Sound Architecture Driver Initialized.
    [2026-03-10 15:58:35.417] [    0.069726] vgaarb: loaded
    [2026-03-10 15:58:35.433] [    0.069918] clocksource: Switched to clocksource arch_sys_counter
    [2026-03-10 15:58:35.433] [    0.070065] VFS: Disk quotas dquot_6.6.0
    [2026-03-10 15:58:35.433] [    0.070076] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [2026-03-10 15:58:35.449] [    0.073719] NET: Registered PF_INET protocol family
    [2026-03-10 15:58:35.449] [    0.074032] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [2026-03-10 15:58:35.449] [    0.079075] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
    [2026-03-10 15:58:35.465] [    0.079224] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [2026-03-10 15:58:35.465] [    0.079242] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [2026-03-10 15:58:35.481] [    0.080052] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
    [2026-03-10 15:58:35.481] [    0.080903] TCP: Hash tables configured (established 262144 bind 65536)
    [2026-03-10 15:58:35.497] [    0.081010] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [2026-03-10 15:58:35.497] [    0.081322] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
    [2026-03-10 15:58:35.513] [    0.081731] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [2026-03-10 15:58:35.513] [    0.082097] RPC: Registered named UNIX socket transport module.
    [2026-03-10 15:58:35.513] [    0.082100] RPC: Registered udp transport module.
    [2026-03-10 15:58:35.529] [    0.082102] RPC: Registered tcp transport module.
    [2026-03-10 15:58:35.529] [    0.082104] RPC: Registered tcp-with-tls transport module.
    [2026-03-10 15:58:35.529] [    0.082105] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [2026-03-10 15:58:35.545] [    0.082111] NET: Registered PF_XDP protocol family
    [2026-03-10 15:58:35.545] [    0.082126] PCI: CLS 0 bytes, default 64
    [2026-03-10 15:58:35.545] [    0.083089] Initialise system trusted keyrings
    [2026-03-10 15:58:35.561] [    0.083191] workingset: timestamp_bits=46 max_order=23 bucket_order=0
    [2026-03-10 15:58:35.561] [    0.083360] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [2026-03-10 15:58:35.561] [    0.083499] NFS: Registering the id_resolver key type
    [2026-03-10 15:58:35.577] [    0.083514] Key type id_resolver registered
    [2026-03-10 15:58:35.577] [    0.083516] Key type id_legacy registered
    [2026-03-10 15:58:35.577] [    0.083527] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [2026-03-10 15:58:35.593] [    0.083530] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [2026-03-10 15:58:35.593] [    0.105386] Key type asymmetric registered
    [2026-03-10 15:58:35.593] [    0.105391] Asymmetric key parser 'x509' registered
    [2026-03-10 15:58:35.609] [    0.105428] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [2026-03-10 15:58:35.609] [    0.105519] io scheduler mq-deadline registered
    [2026-03-10 15:58:35.609] [    0.105523] io scheduler kyber registered
    [2026-03-10 15:58:35.625] [    0.105538] io scheduler bfq registered
    [2026-03-10 15:58:35.625] [    0.108163] pinctrl-single 4301c000.pinctrl: 13 pins, size 52
    [2026-03-10 15:58:35.625] [    0.108263] pinctrl-single 4301c038.pinctrl: 11 pins, size 44
    [2026-03-10 15:58:35.641] [    0.108446] pinctrl-single 4301c068.pinctrl: 72 pins, size 288
    [2026-03-10 15:58:35.641] [    0.108736] pinctrl-single 4301c190.pinctrl: 1 pins, size 4
    [2026-03-10 15:58:35.641] [    0.108873] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [2026-03-10 15:58:35.657] [    0.109238] pinctrl-single 104200.pinctrl: 20 pins, size 80
    [2026-03-10 15:58:35.657] [    0.109315] pinctrl-single 104280.pinctrl: 8 pins, size 32
    [2026-03-10 15:58:35.657] [    0.110070] ledtrig-cpu: registered to indicate activity on CPUs
    [2026-03-10 15:58:35.673] [    0.113891] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [2026-03-10 15:58:35.673] [    0.120465] loop: module loaded
    [2026-03-10 15:58:35.673] [    0.121113] megasas: 07.727.03.00-rc1
    [2026-03-10 15:58:35.689] [    0.123334] tun: Universal TUN/TAP device driver, 1.6
    [2026-03-10 15:58:35.689] [    0.123939] VFIO - User Level meta-driver version: 0.3
    [2026-03-10 15:58:35.689] [    0.124720] usbcore: registered new interface driver usb-storage
    [2026-03-10 15:58:35.705] [    0.125126] i2c_dev: i2c /dev entries driver
    [2026-03-10 15:58:35.705] [    0.125888] sdhci: Secure Digital Host Controller Interface driver
    [2026-03-10 15:58:35.705] [    0.125890] sdhci: Copyright(c) Pierre Ossman
    [2026-03-10 15:58:35.705] [    0.126063] sdhci-pltfm: SDHCI platform and OF driver helper
    [2026-03-10 15:58:35.721] [    0.126507] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [2026-03-10 15:58:35.721] [    0.127021] usbcore: registered new interface driver usbhid
    [2026-03-10 15:58:35.737] [    0.127023] usbhid: USB HID core driver
    [2026-03-10 15:58:35.737] [    0.127897] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 (0,8000003f) counters available
    [2026-03-10 15:58:35.737] [    0.128233] optee: probing for conduit method.
    [2026-03-10 15:58:35.753] [    0.128240] optee: api uid mismatch
    [2026-03-10 15:58:35.753] [    0.128242] optee firmware:optee: probe with driver optee failed with error -22
    [2026-03-10 15:58:35.753] [    0.129624] Initializing XFRM netlink socket
    [2026-03-10 15:58:35.769] [    0.129640] NET: Registered PF_PACKET protocol family
    [2026-03-10 15:58:35.769] [    0.129688] Key type dns_resolver registered
    [2026-03-10 15:58:35.769] [    0.133811] registered taskstats version 1
    [2026-03-10 15:58:35.769] [    0.134108] Loading compiled-in X.509 certificates
    [2026-03-10 15:58:35.785] [    0.141364] ti-sci 44083000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.2.8--v11.02.08 (Fancy Rat)')
    [2026-03-10 15:58:35.785] [    0.224919] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz
    [2026-03-10 15:58:35.801] [    0.225657] pca953x 3-0020: supply vcc not found, using dummy regulator
    [2026-03-10 15:58:35.801] [    0.225710] pca953x 3-0020: using no AI
    [2026-03-10 15:58:35.801] [    0.238979] pca953x 3-0022: supply vcc not found, using dummy regulator
    [2026-03-10 15:58:35.817] [    0.239030] pca953x 3-0022: using AI
    [2026-03-10 15:58:35.817] [    0.240239] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [2026-03-10 15:58:35.817] [    0.240717] pca953x 4-0020: supply vcc not found, using dummy regulator
    [2026-03-10 15:58:35.833] [    0.240762] pca953x 4-0020: using no AI
    [2026-03-10 15:58:35.833] [    0.254390] omap_i2c 2030000.i2c: bus 4 rev0.12 at 400 kHz
    [2026-03-10 15:58:35.833] [    0.255015] pca953x 5-0020: supply vcc not found, using dummy regulator
    [2026-03-10 15:58:35.849] [    0.255076] pca953x 5-0020: using no AI
    [2026-03-10 15:58:35.849] [    0.270278] /connector-dp1: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
    [2026-03-10 15:58:35.865] [    0.270310] /bus@100000/dsi@4800000: Fixed dependency cycle(s) with /bus@100000/i2c@2040000/dsi-edp-bridge@2c
    [2026-03-10 15:58:35.865] [    0.270343] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /connector-dp1
    [2026-03-10 15:58:35.881] [    0.270375] /bus@100000/i2c@2040000/dsi-edp-bridge@2c: Fixed dependency cycle(s) with /bus@100000/dsi@4800000
    [2026-03-10 15:58:35.881] [    0.270498] omap_i2c 2040000.i2c: bus 5 rev0.12 at 400 kHz
    [2026-03-10 15:58:35.897] [    0.271150] pca953x 6-0020: supply vcc not found, using dummy regulator
    [2026-03-10 15:58:35.897] [    0.271194] pca953x 6-0020: using no AI
    [2026-03-10 15:58:35.897] [    0.286242] omap_i2c 2050000.i2c: bus 6 rev0.12 at 400 kHz
    [2026-03-10 15:58:35.913] [    0.286367] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [2026-03-10 15:58:35.913] [    0.286461] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [2026-03-10 15:58:35.929] [    0.286557] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [2026-03-10 15:58:35.929] [    0.286767] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [2026-03-10 15:58:35.945] [    0.292795] ti-udma 311a0000.dma-controller: Number of rings: 48
    [2026-03-10 15:58:35.945] [    0.294339] ti-udma 311a0000.dma-controller: Channels: 48 (bchan: 0, tchan: 16, rchan: 32)
    [2026-03-10 15:58:35.961] [    0.295833] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [2026-03-10 15:58:35.961] [    0.295838] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [2026-03-10 15:58:35.977] [    0.295841] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [2026-03-10 15:58:35.977] [    0.297897] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [2026-03-10 15:58:35.993] [    0.297902] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [2026-03-10 15:58:35.993] [    0.297905] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [2026-03-10 15:58:36.009] [    0.298586] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 275, base_baud = 6000000) is a 8250
    [2026-03-10 15:58:36.009] [    0.299224] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 276, base_baud = 3000000) is a 8250
    [2026-03-10 15:58:36.025] [    0.299273] printk: legacy console [ttyS2] enabled
    [2026-03-10 15:58:36.025] [    2.708159] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 15:58:36.073] [    2.753922] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 15:58:36.089] [    2.764833] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [2026-03-10 15:58:36.089] [    2.773150] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 15:58:36.105] [    2.780360] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 15:58:36.105] [    2.787783] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [2026-03-10 15:58:36.121] [    2.797840] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 15:58:36.137] [    2.810610] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [2026-03-10 15:58:36.169] [    2.849922] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 15:58:36.185] [    2.860601] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [2026-03-10 15:58:36.185] [    2.868734] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 15:58:36.201] [    2.875863] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 15:58:36.201] [    2.883095] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:250000000, add_val:3 pps:0
    [2026-03-10 15:58:36.217] [    2.893525] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010c, freq:250000000, add_val:3 pps:0
    [2026-03-10 15:58:36.217] [    2.902552] mmc0: CQHCI version 5.10
    [2026-03-10 15:58:36.265] [    2.947364] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [2026-03-10 15:58:36.361] [    3.042214] mmc0: Command Queue Engine enabled
    [2026-03-10 15:58:36.361] [    3.046662] mmc0: new HS400 MMC card at address 0001
    [2026-03-10 15:58:36.377] [    3.052062] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [2026-03-10 15:58:36.377] [    3.057565]  mmcblk0: p1 p2
    [2026-03-10 15:58:36.377] [    3.060685] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [2026-03-10 15:58:36.377] [    3.066279] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [2026-03-10 15:58:36.393] [    3.071806] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [2026-03-10 15:58:36.489] [    3.170964] tps6594-rtc tps6594-rtc.4.auto: registered as rtc0
    [2026-03-10 15:58:36.505] [    3.179628] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [2026-03-10 15:58:36.505] [    3.187137] j721e-pcie 2900000.pcie:       IO 0x4000001000..0x4000100fff -> 0x0000001000
    [2026-03-10 15:58:36.521] [    3.195227] j721e-pcie 2900000.pcie:      MEM 0x4000101000..0x40ffffffff -> 0x0000101000
    [2026-03-10 15:58:36.521] [    3.203315] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [2026-03-10 15:58:37.641] [    4.318565] j721e-pcie 2900000.pcie: PCI host bridge to bus 0000:00
    [2026-03-10 15:58:37.641] [    4.324860] pci_bus 0000:00: root bus resource [bus 00-ff]
    [2026-03-10 15:58:37.657] [    4.330353] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x1000-0x100fff])
    [2026-03-10 15:58:37.657] [    4.339385] pci_bus 0000:00: root bus resource [mem 0x4000101000-0x40ffffffff] (bus address [0x00101000-0xffffffff])
    [2026-03-10 15:58:37.673] [    4.349920] pci 0000:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
    [2026-03-10 15:58:37.673] [    4.357217] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [2026-03-10 15:58:37.689] [    4.366869] pci 0000:00:00.0: PCI bridge to [bus 00]
    [2026-03-10 15:58:37.689] [    4.371827] pci 0000:00:00.0:   bridge window [io  0x0000-0x0fff]
    [2026-03-10 15:58:37.689] [    4.377912] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
    [2026-03-10 15:58:37.705] [    4.384692] pci 0000:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
    [2026-03-10 15:58:37.705] [    4.392503] pci 0000:00:00.0: supports D1
    [2026-03-10 15:58:37.721] [    4.396504] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
    [2026-03-10 15:58:37.721] [    4.404182] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [2026-03-10 15:58:37.737] [    4.412297] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
    [2026-03-10 15:58:37.737] [    4.418914] pci 0000:00:00.0: PCI bridge to [bus 01]
    [2026-03-10 15:58:37.737] [    4.423877] pci_bus 0000:00: resource 4 [io  0x0000-0xfffff]
    [2026-03-10 15:58:37.753] [    4.429527] pci_bus 0000:00: resource 5 [mem 0x4000101000-0x40ffffffff]
    [2026-03-10 15:58:37.753] [    4.436187] pcieport 0000:00:00.0: of_irq_parse_pci: failed with rc=-22
    [2026-03-10 15:58:37.769] [    4.443003] pcieport 0000:00:00.0: PME: Signaling with IRQ 538
    [2026-03-10 15:58:37.769] [    4.449017] pcieport 0000:00:00.0: AER: enabled with IRQ 538
    [2026-03-10 15:58:37.769] [    4.454954] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [2026-03-10 15:58:37.785] [    4.462449] j721e-pcie 2910000.pcie:       IO 0x4100001000..0x4100100fff -> 0x0000001000
    [2026-03-10 15:58:37.785] [    4.470541] j721e-pcie 2910000.pcie:      MEM 0x4100101000..0x41ffffffff -> 0x0000101000
    [2026-03-10 15:58:37.801] [    4.478628] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [2026-03-10 15:58:38.905] [    5.586045] j721e-pcie 2910000.pcie: PCI host bridge to bus 0001:00
    [2026-03-10 15:58:38.905] [    5.592312] pci_bus 0001:00: root bus resource [bus 00-ff]
    [2026-03-10 15:58:38.921] [    5.597789] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x1000-0x100fff])
    [2026-03-10 15:58:38.921] [    5.607079] pci_bus 0001:00: root bus resource [mem 0x4100101000-0x41ffffffff] (bus address [0x00101000-0xffffffff])
    [2026-03-10 15:58:38.937] [    5.617603] pci 0001:00:00.0: [104c:b012] type 01 class 0x060400 PCIe Root Port
    [2026-03-10 15:58:38.937] [    5.624898] pci_bus 0001:00: 2-byte config write to 0001:00:00.0 offset 0x4 may corrupt adjacent RW1C bits
    [2026-03-10 15:58:38.953] [    5.634551] pci 0001:00:00.0: PCI bridge to [bus 00]
    [2026-03-10 15:58:38.953] [    5.639509] pci 0001:00:00.0:   bridge window [io  0x0000-0x0fff]
    [2026-03-10 15:58:38.969] [    5.645591] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff]
    [2026-03-10 15:58:38.969] [    5.652371] pci 0001:00:00.0:   bridge window [mem 0x00000000-0x000fffff 64bit pref]
    [2026-03-10 15:58:38.985] [    5.660182] pci 0001:00:00.0: supports D1
    [2026-03-10 15:58:38.985] [    5.664182] pci 0001:00:00.0: PME# supported from D0 D1 D3hot
    [2026-03-10 15:58:38.985] [    5.671867] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
    [2026-03-10 15:58:39.001] [    5.679977] pci_bus 0001:01: busn_res: [bus 01-ff] end is updated to 01
    [2026-03-10 15:58:39.001] [    5.686589] pci 0001:00:00.0: PCI bridge to [bus 01]
    [2026-03-10 15:58:39.017] [    5.691550] pci_bus 0001:00: resource 4 [io  0x100000-0x1fffff]
    [2026-03-10 15:58:39.017] [    5.697464] pci_bus 0001:00: resource 5 [mem 0x4100101000-0x41ffffffff]
    [2026-03-10 15:58:39.017] [    5.704112] pcieport 0001:00:00.0: of_irq_parse_pci: failed with rc=-22
    [2026-03-10 15:58:39.033] [    5.710895] pcieport 0001:00:00.0: PME: Signaling with IRQ 540
    [2026-03-10 15:58:39.033] [    5.716864] pcieport 0001:00:00.0: AER: enabled with IRQ 540
    [2026-03-10 15:58:39.049] [    5.723320] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [2026-03-10 15:58:39.049] [    5.733717] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [2026-03-10 15:58:39.065] [    5.746667] 7 fixed-partitions partitions found on MTD device 47040000.spi.0
    [2026-03-10 15:58:39.065] [    5.753718] Creating 7 MTD partitions on "47040000.spi.0":
    [2026-03-10 15:58:39.081] [    5.759215] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [2026-03-10 15:58:39.081] [    5.765515] 0x000000080000-0x000000280000 : "ospi.tispl"
    [2026-03-10 15:58:39.097] [    5.771476] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [2026-03-10 15:58:39.097] [    5.777524] 0x000000680000-0x0000006c0000 : "ospi.env"
    [2026-03-10 15:58:39.098] [    5.783283] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [2026-03-10 15:58:39.113] [    5.789681] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [2026-03-10 15:58:39.113] [    5.795695] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [2026-03-10 15:58:39.145] [    5.826886] 7 fixed-partitions partitions found on MTD device 47050000.spi.0
    [2026-03-10 15:58:39.145] [    5.833937] Creating 7 MTD partitions on "47050000.spi.0":
    [2026-03-10 15:58:39.161] [    5.839411] 0x000000000000-0x000000080000 : "qspi.tiboot3"
    [2026-03-10 15:58:39.161] [    5.845559] 0x000000080000-0x000000280000 : "qspi.tispl"
    [2026-03-10 15:58:39.177] [    5.851581] 0x000000280000-0x000000680000 : "qspi.u-boot"
    [2026-03-10 15:58:39.177] [    5.857609] 0x000000680000-0x0000006c0000 : "qspi.env"
    [2026-03-10 15:58:39.177] [    5.863374] 0x0000006c0000-0x000000700000 : "qspi.env.backup"
    [2026-03-10 15:58:39.193] [    5.869726] 0x000000800000-0x000003fc0000 : "qspi.rootfs"
    [2026-03-10 15:58:39.193] [    5.875721] 0x000003fc0000-0x000004000000 : "qspi.phypattern"
    [2026-03-10 15:58:39.209] [    5.882438] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 15:58:39.241] [    5.929921] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 15:58:39.257] [    5.940734] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [2026-03-10 15:58:39.273] [    5.949061] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 15:58:39.273] [    5.956272] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 15:58:39.289] [    5.963701] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:1
    [2026-03-10 15:58:39.305] [    5.980427] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [2026-03-10 15:58:39.305] [    5.990136] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [2026-03-10 15:58:39.321] [    6.002924] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [2026-03-10 15:58:39.353] [    6.041937] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [2026-03-10 15:58:39.369] [    6.052770] davinci_mdio c200f00.mdio: phy[0]: device c200f00.mdio:00, driver TI DP83867
    [2026-03-10 15:58:39.385] [    6.060924] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [2026-03-10 15:58:39.385] [    6.068047] am65-cpsw-nuss c200000.ethernet: ALE Table size 64, Policers 8
    [2026-03-10 15:58:39.401] [    6.075337] am65-cpsw-nuss c200000.ethernet: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
    [2026-03-10 15:58:39.417] [    6.091951] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [2026-03-10 15:58:39.417] [    6.102331] clk: Disabling unused clocks
    [2026-03-10 15:58:39.433] [    6.106602] mmc1: CQHCI version 5.10
    [2026-03-10 15:58:39.433] [    6.120019] PM: genpd: Disabling unused power domains
    [2026-03-10 15:58:39.443] [    6.125174] ALSA device list:
    [2026-03-10 15:58:39.443] [    6.128211]   No soundcards found.
    [2026-03-10 15:58:39.458] [    6.146457] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [2026-03-10 15:58:39.474] [    6.154042] Waiting for root device PARTUUID=076c4a2a-02...
    [2026-03-10 15:58:39.538] [    6.214947] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [2026-03-10 15:58:39.538] [    6.221972] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
    [2026-03-10 15:58:39.554] [    6.230642]  mmcblk1: p1 p2
    [2026-03-10 15:58:39.554] [    6.237905] EXT4-fs (mmcblk1p2): INFO: recovery required on readonly filesystem
    [2026-03-10 15:58:39.570] [    6.245219] EXT4-fs (mmcblk1p2): write access will be enabled during recovery
    [2026-03-10 15:58:39.938] [    6.618726] EXT4-fs (mmcblk1p2): orphan cleanup on readonly fs
    [2026-03-10 15:58:39.938] [    6.625653] EXT4-fs (mmcblk1p2): recovery complete
    [2026-03-10 15:58:39.954] [    6.636305] EXT4-fs (mmcblk1p2): mounted filesystem d1eb63e9-b2b2-4688-9715-01bef2133809 ro with ordered data mode. Quota mode: none.
    [2026-03-10 15:58:39.970] [    6.648356] VFS: Mounted root (ext4 filesystem) readonly on device 179:98.
    [2026-03-10 15:58:39.986] [    6.662391] devtmpfs: mounted
    [2026-03-10 15:58:39.986] [    6.666381] Freeing unused kernel memory: 2752K
    [2026-03-10 15:58:39.986] [    6.670986] Run /sbin/init as init process
    [2026-03-10 15:58:40.178] [    6.863334] systemd[1]: System time before build time, advancing clock.
    [2026-03-10 15:58:40.226] [    6.904188] NET: Registered PF_INET6 protocol family
    [2026-03-10 15:58:40.226] [    6.909844] Segment Routing with IPv6
    [2026-03-10 15:58:40.226] [    6.913516] In-situ OAM (IOAM) with IPv6
    [2026-03-10 15:58:40.258] [    6.943331] systemd[1]: systemd 255.21^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO)
    [2026-03-10 15:58:40.290] [    6.975212] systemd[1]: Detected architecture arm64.
    [2026-03-10 15:58:40.306]
    [2026-03-10 15:58:40.306] Welcome to Arago 2025.01!
    [2026-03-10 15:58:40.306] [    6.991946] systemd[1]: Hostname set to <j784s4-evm>.
    [2026-03-10 15:58:40.578] [    7.251106] systemd[1]: Queued start job for default target Graphical Interface.
    [2026-03-10 15:58:40.610] [    7.288823] systemd[1]: Created slice Slice /system/getty.
    [2026-03-10 15:58:40.610] [  OK  ] Created slice Slice /system/getty.
    [2026-03-10 15:58:40.626] [    7.306961] systemd[1]: Created slice Slice /system/modprobe.
    [2026-03-10 15:58:40.626] [  OK  ] Created slice Slice /system/modprobe.
    [2026-03-10 15:58:40.642] [    7.326849] systemd[1]: Created slice Slice /system/serial-getty.
    [2026-03-10 15:58:40.658] [  OK  ] Created slice Slice /system/serial-getty.
    [2026-03-10 15:58:40.658] [    7.346662] systemd[1]: Created slice User and Session Slice.
    [2026-03-10 15:58:40.674] [  OK  ] Created slice User and Session Slice.
    [2026-03-10 15:58:40.690] [    7.366071] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [2026-03-10 15:58:40.690] [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [2026-03-10 15:58:40.706] [    7.386037] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [2026-03-10 15:58:40.706] [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [2026-03-10 15:58:40.722] [    7.405992] systemd[1]: Expecting device /dev/ttyS2...
    [2026-03-10 15:58:40.738]          Expecting device /dev/ttyS2...
    [2026-03-10 15:58:40.738] [    7.418010] systemd[1]: Reached target Path Units.
    [2026-03-10 15:58:40.738] [  OK  ] Reached target Path Units.
    [2026-03-10 15:58:40.754] [    7.429974] systemd[1]: Reached target Remote File Systems.
    [2026-03-10 15:58:40.754] [  OK  ] Reached target Remote File Systems.
    [2026-03-10 15:58:40.770] [    7.445970] systemd[1]: Reached target Slice Units.
    [2026-03-10 15:58:40.770] [  OK  ] Reached target Slice Units.
    [2026-03-10 15:58:40.770] [    7.457971] systemd[1]: Reached target Swaps.
    [2026-03-10 15:58:40.786] [  OK  ] Reached target Swaps.
    [2026-03-10 15:58:40.818] [    7.504288] systemd[1]: Listening on RPCbind Server Activation Socket.
    [2026-03-10 15:58:40.834] [  OK  ] Listening on RPCbind Server Activation Socket.
    [2026-03-10 15:58:40.834] [    7.522061] systemd[1]: Reached target RPC Port Mapper.
    [2026-03-10 15:58:40.850] [  OK  ] Reached target RPC Port Mapper.
    [2026-03-10 15:58:40.866] [    7.543274] systemd[1]: Listening on Process Core Dump Socket.
    [2026-03-10 15:58:40.866] [  OK  ] Listening on Process Core Dump Socket.
    [2026-03-10 15:58:40.882] [    7.562120] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [2026-03-10 15:58:40.882] [  OK  ] Listening on initctl Compatibility Named Pipe.
    [2026-03-10 15:58:40.898] [    7.582477] systemd[1]: Listening on Journal Audit Socket.
    [2026-03-10 15:58:40.914] [  OK  ] Listening on Journal Audit Socket.
    [2026-03-10 15:58:40.914] [    7.598181] systemd[1]: Listening on Journal Socket (/dev/log).
    [2026-03-10 15:58:40.930] [  OK  ] Listening on Journal Socket (/dev/log).
    [2026-03-10 15:58:40.930] [    7.614230] systemd[1]: Listening on Journal Socket.
    [2026-03-10 15:58:40.946] [  OK  ] Listening on Journal Socket.
    [2026-03-10 15:58:40.946] [    7.626240] systemd[1]: Listening on Network Service Netlink Socket.
    [2026-03-10 15:58:40.946] [  OK  ] Listening on Network Service Netlink Socket.
    [2026-03-10 15:58:40.962] [    7.648924] systemd[1]: Listening on udev Control Socket.
    [2026-03-10 15:58:40.978] [  OK  ] Listening on udev Control Socket.
    [2026-03-10 15:58:40.978] [    7.666151] systemd[1]: Listening on udev Kernel Socket.
    [2026-03-10 15:58:40.994] [  OK  ] Listening on udev Kernel Socket.
    [2026-03-10 15:58:40.994] [    7.682175] systemd[1]: Listening on User Database Manager Socket.
    [2026-03-10 15:58:41.010] [  OK  ] Listening on User Database Manager Socket.
    [2026-03-10 15:58:41.042] [    7.730142] systemd[1]: Mounting Huge Pages File System...
    [2026-03-10 15:58:41.058]          Mounting Huge Pages File System...
    [2026-03-10 15:58:41.058] [    7.744096] systemd[1]: Mounting POSIX Message Queue File System...
    [2026-03-10 15:58:41.074]          Mounting POSIX Message Queue File System...
    [2026-03-10 15:58:41.090] [    7.764263] systemd[1]: Mounting Kernel Debug File System...
    [2026-03-10 15:58:41.090]          Mounting Kernel Debug File System...
    [2026-03-10 15:58:41.106] [    7.782274] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [2026-03-10 15:58:41.122] [    7.799641] systemd[1]: Mounting Temporary Directory /tmp...
    [2026-03-10 15:58:41.122]          Mounting Temporary Directory /tmp...
    [2026-03-10 15:58:41.138] [    7.820887] systemd[1]: Starting Create List of Static Device Nodes...
    [2026-03-10 15:58:41.154]          Starting Create List of Static Device Nodes...
    [2026-03-10 15:58:41.154] [    7.840159] systemd[1]: Starting Load Kernel Module configfs...
    [2026-03-10 15:58:41.170]          Starting Load Kernel Module configfs...
    [2026-03-10 15:58:41.170] [    7.856446] systemd[1]: Starting Load Kernel Module drm...
    [2026-03-10 15:58:41.186]          Starting Load Kernel Module drm...
    [2026-03-10 15:58:41.186] [    7.872296] systemd[1]: Starting Load Kernel Module fuse...
    [2026-03-10 15:58:41.202]          Starting Load Kernel Module fuse...
    [2026-03-10 15:58:41.218] [    7.893339] systemd[1]: Starting Start psplash boot splash screen...
    [2026-03-10 15:58:41.218]          Starting Start psplash boot splash screen...
    [2026-03-10 15:58:41.218] [    7.906387] fuse: init (API version 7.41)
    [2026-03-10 15:58:41.234] [    7.915930] systemd[1]: Starting RPC Bind...
    [2026-03-10 15:58:41.234]          Starting RPC Bind...
    [2026-03-10 15:58:41.250] [    7.928476] systemd[1]: Starting File System Check on Root Device...
    [2026-03-10 15:58:41.250]          Starting File System Check on Root Device...
    [2026-03-10 15:58:41.266] [    7.949862] systemd[1]: Starting Journal Service...
    [2026-03-10 15:58:41.266]          Starting Journal Service...
    [2026-03-10 15:58:41.282] [    7.968638] systemd[1]: Starting Load Kernel Modules...
    [2026-03-10 15:58:41.298]          Starting Load Kernel Modules...
    [2026-03-10 15:58:41.298] [    7.976894] systemd[1]: Starting Generate network units from Kernel command line...
    [2026-03-10 15:58:41.298]          Starting Generate network units from Kernel co[    7.989624] systemd[1]: Starting Coldplug All udev Devices...
    [2026-03-10 15:58:41.314] mmand line...
    [2026-03-10 15:58:41.314]          Starting Coldplug All udev Devices...
    [2026-03-10 15:58:41.330] [    8.003086] systemd[1]: Started RPC Bind.
    [2026-03-10 15:58:41.330] [  OK  ] Started RPC Bind.
    [2026-03-10 15:58:41.330] [    8.009946] systemd[1]: Mounted Huge Pages File System.
    [2026-03-10 15:58:41.346] [    8.015242] cryptodev: loading out-of-tree module taints kernel.
    [2026-03-10 15:58:41.346] [  OK  ] Mounted Huge Pages File System.[    8.025695] systemd[1]: Mounted POSIX Message Queue File System.
    [2026-03-10 15:58:41.362]
    [2026-03-10 15:58:41.362] [    8.026070] sysctl table check failed: ioctl/(null) procname is null
    [2026-03-10 15:58:41.362] [    8.043391] sysctl table check failed: ioctl/(null) No proc_handler
    [2026-03-10 15:58:41.362] [    8.043397] cryptodev: driver 1.14 loaded.
    [2026-03-10 15:58:41.378] [    8.047066] systemd-journald[177]: Collecting audit messages is enabled.
    [2026-03-10 15:58:41.378] [  OK  ] Mounted POSIX Message Queue File Sy[    8.060999] systemd[1]: Mounted Kernel Debug File System.
    [2026-03-10 15:58:41.394] stem.
    [2026-03-10 15:58:41.394] [    8.071827] systemd[1]: Mounted Temporary Directory /tmp.
    [2026-03-10 15:58:41.394] [  OK  ] Mounted Kernel Debug File System.
    [2026-03-10 15:58:41.410] [  OK  ] Mounted Temporary Directory /tmp.
    [2026-03-10 15:58:41.426] [    8.106855] systemd[1]: Finished Create List of Static Device Nodes.
    [2026-03-10 15:58:41.426] [  OK  ] Finished Create List of Static Device Nodes.
    [2026-03-10 15:58:41.442] [    8.130489] systemd[1]: Started Journal Service.
    [2026-03-10 15:58:41.458] [  OK  ] Started Journal Service.
    [2026-03-10 15:58:41.458] [  OK  ] Finished Load Kernel Module configfs.
    [2026-03-10 15:58:41.474] [  OK  ] Finished Load Kernel Module drm.
    [2026-03-10 15:58:41.490] [  OK  ] Finished Load Kernel Module fuse.
    [2026-03-10 15:58:41.506] [FAILED] Failed to start Start psplash boot splash screen.
    [2026-03-10 15:58:41.506] See 'systemctl status psplash-start.service' for details.
    [2026-03-10 15:58:41.522] [DEPEND] Dependency failed for Start psplas…temd progress communication helper.
    [2026-03-10 15:58:41.522] [  OK  ] Finished File System Check on Root Device.
    [2026-03-10 15:58:41.538] [  OK  ] Finished Load Kernel Modules.
    [2026-03-10 15:58:41.554] [  OK  ] Finished Generate network units from Kernel command line.
    [2026-03-10 15:58:41.618]          Mounting FUSE Control File System...
    [2026-03-10 15:58:41.634]          Mounting Kernel Configuration File System...
    [2026-03-10 15:58:41.650]          Starting Remount Root and Kernel File Systems...
    [2026-03-10 15:58:41.666]          Starting Apply Kernel Variables...
    [2026-03-10 15:58:41.666]          Starting Create Static Device Nodes in /dev gracefully...
    [2026-03-10 15:58:41.682] [  OK  ] Mounted FUSE Control File System.
    [2026-03-10 15:58:41.698] [  OK  ] Mounted Kernel Configuration File System.
    [2026-03-10 15:58:41.714] [    8.396348] EXT4-fs (mmcblk1p2): re-mounted d1eb63e9-b2b2-4688-9715-01bef2133809 r/w.
    [2026-03-10 15:58:41.730] [  OK  ] Finished Remount Root and Kernel File Systems.
    [2026-03-10 15:58:41.730] [  OK  ] Finished Apply Kernel Variables.
    [2026-03-10 15:58:41.746] [  OK  ] Finished Create Static Device Nodes in /dev gracefully.
    [2026-03-10 15:58:41.794]          Starting Flush Journal to Persistent Storage...
    [2026-03-10 15:58:41.810] [    8.486950] systemd-journald[177]: Received client request to flush runtime journal.
    [2026-03-10 15:58:41.810]          Starting Create Static Device Nodes in /dev...
    [2026-03-10 15:58:41.826] [  OK  ] Finished Flush Journal to Persistent Storage.
    [2026-03-10 15:58:41.842] [  OK  ] Finished Create Static Device Nodes in /dev.
    [2026-03-10 15:58:41.858] [  OK  ] Reached target Preparation for Local File Systems.
    [2026-03-10 15:58:41.874]          Mounting /var/volatile...
    [2026-03-10 15:58:41.874] [    8.559997] audit: type=1334 audit(1748544503.692:2): prog-id=6 op=LOAD
    [2026-03-10 15:58:41.890] [    8.566663] audit: type=1334 audit(1748544503.700:3): prog-id=7 op=LOAD
    [2026-03-10 15:58:41.890]          Starting Rule-based Manager for Device Events and Files...
    [2026-03-10 15:58:41.906] [  OK  ] Mounted /var/volatile.
    [2026-03-10 15:58:41.922]          Starting Load/Save OS Random Seed...
    [2026-03-10 15:58:41.922] [  OK  ] Reached target Local File Systems.
    [2026-03-10 15:58:41.938]          Starting Create System Files and Directories...
    [2026-03-10 15:58:41.954] [  OK  ] Finished Coldplug All udev Devices.
    [2026-03-10 15:58:42.002] [  OK  ] Finished Create System Files and Directories.
    [2026-03-10 15:58:42.018] [    8.692816] audit: type=1334 audit(1748544503.824:4): prog-id=8 op=LOAD
    [2026-03-10 15:58:42.050]          Starting Network Name Resolution...
    [2026-03-10 15:58:42.066] [    8.739915] audit: type=1334 audit(1748544503.872:5): prog-id=9 op=LOAD
    [2026-03-10 15:58:42.066]          Starting Network Time Synchronization...
    [2026-03-10 15:58:42.082]          Starting Record System Boot/Shutdown in UTMP...
    [2026-03-10 15:58:42.098] [    8.777329] audit: type=1334 audit(1748544503.908:6): prog-id=10 op=LOAD
    [2026-03-10 15:58:42.098] [    8.784125] audit: type=1334 audit(1748544503.916:7): prog-id=11 op=LOAD
    [2026-03-10 15:58:42.114] [    8.790856] audit: type=1334 audit(1748544503.924:8): prog-id=12 op=LOAD
    [2026-03-10 15:58:42.114]          Starting User Database Manager...
    [2026-03-10 15:58:42.130] [  OK  ] Finished Record System Boot/Shutdown in UTMP.
    [2026-03-10 15:58:42.178] [  OK  ] Started User Database Manager.
    [2026-03-10 15:58:42.194] [  OK  ] Started Rule-based Manager for Device Events and Files.
    [2026-03-10 15:58:42.258] [  OK  ] Found device /dev/ttyS2.
    [2026-03-10 15:58:42.338] [  OK  ] Started Network Time Synchronization.
    [2026-03-10 15:58:42.338] [  OK  ] Started Network Name Resolution.
    [2026-03-10 15:58:42.354] [  OK  ] Reached target Host and Network Name Lookups.
    [2026-03-10 15:58:42.370] [  OK  ] Reached target System Initialization.
    [2026-03-10 15:58:42.386] [  OK  ] Started Daily Cleanup of Temporary Directories.
    [2026-03-10 15:58:42.386] [  OK  ] Reached target System Time Set.
    [2026-03-10 15:58:42.402] [  OK  ] Started Daily rotation of log files.
    [2026-03-10 15:58:42.418] [  OK  ] Reached target Timer Units.
    [2026-03-10 15:58:42.434] [  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
    [2026-03-10 15:58:42.450] [  OK  ] Listening on D-Bus System Message Bus Socket.
    [2026-03-10 15:58:42.466]          Starting Docker Socket for the API...
    [2026-03-10 15:58:42.466] [    9.153960] random: crng init done
    [2026-03-10 15:58:42.514] [  OK  ] Listening on dropbear.socket.
    [2026-03-10 15:58:42.530] [  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
    [2026-03-10 15:58:42.546] [    9.224838] audit: type=1334 audit(1748544686.000:9): prog-id=13 op=LOAD
    [2026-03-10 15:58:42.546]          Starting D-Bus System Message Bus...
    [2026-03-10 15:58:42.578]          Starting Reboot and dump vmcore via kexec...
    [2026-03-10 15:58:42.593] [  OK  ] Finished Load/Save OS Random Seed.
    [2026-03-10 15:58:42.609] [  OK  ] Listening on Docker Socket for the API.
    [2026-03-10 15:58:42.625] [  OK  ] Finished Reboot and dump vmcore via kexec.
    [2026-03-10 15:58:42.641] [    9.317105] CAN device driver interface
    [2026-03-10 15:58:42.706] [    9.394689] cdns-mhdp8546 a000000.bridge: error -EINVAL: invalid resource (null)
    [2026-03-10 15:58:42.722] [    9.402211] cdns-mhdp8546 a000000.bridge: Failed to get SAPB memory resource, HDCP not supported
    [2026-03-10 15:58:42.738] [    9.406398] at24 0-0050: supply vcc not found, using dummy regulator
    [2026-03-10 15:58:42.738] [    9.411036] mc: Linux media interface: v0.10
    [2026-03-10 15:58:42.753] [    9.434231] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
    [2026-03-10 15:58:42.754] [    9.434812] PVR_K:  266: Read BVNC 36.53.104.796 from HW device registers
    [2026-03-10 15:58:42.770] [  OK  ] Started D-Bus System Message Bus    9.448137] PVR_K:  266: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [2026-03-10 15:58:42.786] m.
    [2026-03-10 15:58:42.786] [    9.450163] videodev: Linux video capture interface: v2.00
    [2026-03-10 15:58:42.801] [    9.479628] [drm] Initialized pvr 25.2.6850647 for 4e20000000.gpu on minor 0
    [2026-03-10 15:58:42.802] [    9.482377] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_rproc_init failed, ret = -517
    [2026-03-10 15:58:42.817] [    9.502912] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
    [2026-03-10 15:58:42.849] [    9.533997] m_can_platform 26a1000.can: m_can device registered (irq=665, version=32)
    [2026-03-10 15:58:42.866] [    9.547016] gpio-mux mux-controller: 2-way mux-controller registered
    [2026-03-10 15:58:42.881] [    9.556015] remoteproc remoteproc0: releasing 41000000.r5f
    [2026-03-10 15:58:42.898] [    9.575844] m_can_platform 40528000.can: m_can device registered (irq=666, version=32)
    [2026-03-10 15:58:42.898] [    9.576884] k3_r5_rproc bus@100000:r5fss@5c00000: k3_r5_cluster_rproc_init failed, ret = -517
    [2026-03-10 15:58:42.914] [    9.594222] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 15:58:42.929] [    9.607696] remoteproc remoteproc0: releasing 5c00000.r5f
    [2026-03-10 15:58:42.930] [    9.614620] m_can_platform 40568000.can: m_can device registered (irq=668, version=32)
    [2026-03-10 15:58:42.945] [    9.619721] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 15:58:42.946] [    9.624595] k3_r5_rproc bus@100000:r5fss@5e00000: k3_r5_cluster_rproc_init failed, ret = -517
    [2026-03-10 15:58:42.961] [    9.630105] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 15:58:42.962] [    9.630543] vdec 4210000.video-codec: OPP table not found in device tree
    [2026-03-10 15:58:42.977] [    9.630592] m_can_platform 2741000.can: m_can device registered (irq=671, version=32)
    [2026-03-10 15:58:42.978] [    9.651803] vdec 4210000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [2026-03-10 15:58:42.978] [    9.666673] vdec 4210000.video-codec: Product Code:      0x521c
    [2026-03-10 15:58:42.994] [    9.672632] vdec 4210000.video-codec: Firmware Revision: 363254
    [2026-03-10 15:58:42.994] [    9.674199] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [2026-03-10 15:58:43.010] [    9.685441] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 15:58:43.010] [  OK  ] Reached target Socket Units.
    [2026-03-10 15:58:43.026] [    9.697283] platform 41000000.r5f: configured R5F for IPC-only mode
    [2026-03-10 15:58:43.026] [    9.700740] remoteproc remoteproc0: releasing 5e00000.r5f
    [2026-03-10 15:58:43.026] [    9.703892] vdec 4220000.video-codec: OPP table not found in device tree
    [2026-03-10 15:58:43.042] [    9.706520] vdec 4220000.video-codec: Added wave5 driver with caps: 'ENCODE' 'DECODE'
    [2026-03-10 15:58:43.042] [    9.706530] vdec 4220000.video-codec: Product Code:      0x521c
    [2026-03-10 15:58:43.058] [    9.706534] vdec 4220000.video-codec: Firmware Revision: 363254
    [2026-03-10 15:58:43.058] [    9.709043] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 15:58:43.074] [    9.709103] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [2026-03-10 15:58:43.074] [    9.710346] remoteproc remoteproc1: 41000000.r5f is available
    [2026-03-10 15:58:43.074] [    9.710414] remoteproc remoteproc1: attaching to 41000000.r5f
    [2026-03-10 15:58:43.090] [    9.711682] rproc-virtio rproc-virtio.8.auto: assigned reserved memory node r5f-dma-memory@a0000000
    [2026-03-10 15:58:43.090] [    9.714625] virtio_rpmsg_bus virtio0: rpmsg host is online
    [2026-03-10 15:58:43.106] [    9.720297] platform 5900000.r5f: configured R5F for remoteproc mode
    [2026-03-10 15:58:43.106] [    9.720856] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
    [2026-03-10 15:58:43.121] [    9.728685] remoteproc remoteproc0: 5900000.r5f is available
    [2026-03-10 15:58:43.121] [    9.730075] rproc-virtio rproc-virtio.8.auto: registered virtio0 (type 7)
    [2026-03-10 15:58:43.122] [    9.730484] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [2026-03-10 15:58:43.137] [    9.733120] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [2026-03-10 15:58:43.138] [    9.751898] m_can_platform 26a1000.can main_mcan16: renamed from can0
    [2026-03-10 15:58:43.154] [    9.755420] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [2026-03-10 15:58:43.154] [    9.755829] platform 5a00000.r5f: configured R5F for remoteproc mode
    [2026-03-10 15:58:43.170] [    9.761264] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [2026-03-10 15:58:43.170] [    9.767381] platform 41400000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [2026-03-10 15:58:43.185] [    9.768248] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [2026-03-10 15:58:43.186] [    9.768258] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [2026-03-10 15:58:43.201] [    9.768262] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [2026-03-10 15:58:43.217] [    9.768266] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [2026-03-10 15:58:43.218] [    9.770129] platform 5a00000.r5f: assigned reserved memory node r5f-dma-memory@a7000000
    [2026-03-10 15:58:43.234] [    9.770605] remoteproc remoteproc2: 5a00000.r5f is available
    [2026-03-10 15:58:43.234] [    9.777529] remoteproc remoteproc0: powering up 5900000.r5f
    [2026-03-10 15:58:43.234] [    9.781772] platform 41400000.r5f: configured R5F for IPC-only mode
    [2026-03-10 15:58:43.250] [    9.788131] remoteproc remoteproc0: Booting fw image j784s4-main-r5f2_0-fw, size 625916
    [2026-03-10 15:58:43.250] [    9.796559] platform 41400000.r5f: assigned reserved memory node r5f-dma-memory@a1000000
    [2026-03-10 15:58:43.266] [    9.808985] scsi host0: ufshcd
    [2026-03-10 15:58:43.266] [    9.817157] remoteproc remoteproc3: 41400000.r5f is available
    [2026-03-10 15:58:43.266] [    9.823425] remoteproc remoteproc2: powering up 5a00000.r5f
    [2026-03-10 15:58:43.282] [    9.829626] remoteproc remoteproc3: attaching to 41400000.r5f
    [2026-03-10 15:58:43.282] [    9.829639] remoteproc remoteproc3: carveout rsc has non zero reserved bytes
    [2026-03-10 15:58:43.298] [    9.829643] remoteproc remoteproc3: Failed to process resources: -22
    [2026-03-10 15:58:43.298] [    9.830117] remoteproc remoteproc0: bad phdr da 0xa7100000 mem 0x8c
    [2026-03-10 15:58:43.298] [    9.830125] remoteproc remoteproc0: Failed to load program segments: -22
    [2026-03-10 15:58:43.314] [    9.832006] m_can_platform 40568000.can mcu_mcan1: renamed from can2
    [2026-03-10 15:58:43.314] [    9.837151] remoteproc remoteproc2: Booting fw image j784s4-main-r5f2_1-fw, size 163008
    [2026-03-10 15:58:43.330] [    9.843717] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: error -EINVAL: rproc_add failed
    [2026-03-10 15:58:43.330] [    9.844146] m_can_platform 40528000.can mcu_mcan0: renamed from can1
    [2026-03-10 15:58:43.346] [    9.863934] scsi 0:0:0:49488: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [2026-03-10 15:58:43.346] [    9.872677] remoteproc remoteproc1: detached remote processor 41000000.r5f
    [2026-03-10 15:58:43.361] [    9.882999] m_can_platform 2741000.can main_mcan4: renamed from can3
    [2026-03-10 15:58:43.362] [    9.883535] scsi 0:0:0:49476: Well-known LUN    TOSHIBA  THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6
    [2026-03-10 15:58:43.362] [    9.884442] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
    [2026-03-10 15:58:43.378] [    9.893082] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: k3_r5_cluster_rproc_init failed, ret = -22
    [2026-03-10 15:58:43.393] [   10.067452] k3_r5_rproc bus@100000:bus@28380000:r5fss@41000000: probe with driver k3_r5_rproc failed with error -22
    [2026-03-10 15:58:43.394] [  OK  ] Reached target Basic System.
    [2026-03-10 15:58:43.425] [   10.103576] remoteproc remoteproc3: releasing 41400000.r5f
    [2026-03-10 15:58:43.425] [   10.109264] remoteproc remoteproc1: releasing 41000000.r5f
    [2026-03-10 15:58:43.441] [   10.116449] platform 5c00000.r5f: configured R5F for remoteproc mode
    [2026-03-10 15:58:43.441] [   10.123342] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [2026-03-10 15:58:43.457] [  OK  ] Started Job spooling tools.
    [2026-03-10 15:58:43.458] [   10.132058] remoteproc remoteproc1: 5c00000.r5f is available
    [2026-03-10 15:58:43.458] [   10.143416] platform 5d00000.r5f: configured R5F for remoteproc mode
    [   10.150841] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
    [2026-03-10 15:58:43.489]
    [2026-03-10 15:58:43.489] [   10.164212] remoteproc remoteproc3: 5d00000.r5f is available
    [2026-03-10 15:58:43.489] [   10.173362] [drm] Initialized tidss 1.0.0 for 4a00000.dss on minor 1
    [2026-03-10 15:58:43.505] [   10.179948] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [2026-03-10 15:58:43.505] [   10.180457] remoteproc remoteproc1: powering up 5c00000.r5f
    [2026-03-10 15:58:43.506] [   10.186469] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [2026-03-10 15:58:43.521] [   10.190886] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [2026-03-10 15:58:43.522] [   10.191256] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [2026-03-10 15:58:43.538] [   10.191388] remoteproc remoteproc4: 64800000.dsp is available
    [2026-03-10 15:58:43.538] [   10.191782] remoteproc remoteproc1: Booting fw image j784s4-main-r5f0_0-fw, size 1793608
    [2026-03-10 15:58:43.553] [   10.192397] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a9000000
    [2026-03-10 15:58:43.554] [   10.193091] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [2026-03-10 15:58:43.554] [   10.193226] remoteproc remoteproc5: 65800000.dsp is available
    [2026-03-10 15:58:43.570] [   10.194069] k3-dsp-rproc 66800000.dsp: assigned reserved memory node c71-dma-memory@aa000000
    [2026-03-10 15:58:43.570] [   10.194692] k3-dsp-rproc 66800000.dsp: configured DSP for remoteproc mode
    [2026-03-10 15:58:43.585] [   10.194832] remoteproc remoteproc6: 66800000.dsp is available
    [2026-03-10 15:58:43.586] [   10.195629] k3-dsp-rproc 67800000.dsp: assigned reserved memory node c71-dma-memory@ab000000
    [2026-03-10 15:58:43.601] [   10.196239] k3-dsp-rproc 67800000.dsp: configured DSP for remoteproc mode
    [2026-03-10 15:58:43.601] [   10.196345] remoteproc remoteproc7: 67800000.dsp is available
    [2026-03-10 15:58:43.602] [   10.197843] platform 5e00000.r5f: configured R5F for remoteproc mode
    [2026-03-10 15:58:43.617] [   10.198204] tidss 4a00000.dss: [drm] Cannot find any crtc or sizes
    [2026-03-10 15:58:43.618] [   10.198256] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [2026-03-10 15:58:43.633] [   10.198728] remoteproc remoteproc8: 5e00000.r5f is available
    [2026-03-10 15:58:43.633] [   10.199224] platform 5f00000.r5f: configured R5F for remoteproc mode
    [2026-03-10 15:58:43.634] [   10.199492] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
    [2026-03-10 15:58:43.649] [   10.200130] remoteproc remoteproc9: 5f00000.r5f is available
    [2026-03-10 15:58:43.650] [   10.207013] remoteproc remoteproc1: bad phdr da 0xa2104000 mem 0x148fe9d
    [2026-03-10 15:58:43.665] [   10.342609] remoteproc remoteproc1: Failed to load program segments: -22
    [2026-03-10 15:58:43.665] [  OK  ] Started Periodic Command Scheduler  10.349768] remoteproc remoteproc3: powering up 5d00000.r5f
    [2026-03-10 15:58:43.682] [0m.
    [2026-03-10 15:58:43.682] [   10.360615] remoteproc remoteproc3: Booting fw image j784s4-main-r5f0_1-fw, size 371924
    [2026-03-10 15:58:43.682] [   10.361202] remoteproc remoteproc9: powering up 5f00000.r5f
    [2026-03-10 15:58:43.697] [   10.364481] remoteproc remoteproc8: powering up 5e00000.r5f
    [2026-03-10 15:58:43.697] [   10.364496] remoteproc remoteproc8: Booting fw image j784s4-main-r5f1_0-fw, size 163008
    [2026-03-10 15:58:43.713] [   10.365095] remoteproc remoteproc8: bad phdr da 0xa5100000 mem 0x8c
    [2026-03-10 15:58:43.713] [   10.365101] remoteproc remoteproc8: Failed to load program segments: -22
    [2026-03-10 15:58:43.714] [   10.401173] remoteproc remoteproc9: Booting fw image j784s4-main-r5f1_1-fw, size 163008
    [2026-03-10 15:58:43.729]          Starting Print notice about GPLv3 packages...
    [2026-03-10 15:58:43.745]          Starting IPv6 Packet Filtering Framework...
    [2026-03-10 15:58:43.745]          Starting IPv4 Packet Filtering Framework...
    [2026-03-10 15:58:43.761] [  OK  ] Started irqbalance daemon.
    [2026-03-10 15:58:43.777] [  OK  ] Started Multiple Spanning Tree Protocol Daemon.
    [2026-03-10 15:58:43.778]          Starting Telephony service...
    [2026-03-10 15:58:43.793]          Starting Expand the rootfs partiti…[   10.469561] audit: type=1334 audit(1748544687.244:10): prog-id=14 op=LOAD
    [2026-03-10 15:58:43.794] to full size of the boot device....
    [2026-03-10 15:58:43.794] [  OK  ] St[   10.479119] audit: type=1334 audit(1748544687.256:11): prog-id=15 op=LOAD
    [2026-03-10 15:58:43.810] arted strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
    [2026-03-10 15:58:43.810]          Starting User Login Management...
    [2026-03-10 15:58:43.826]          Starting Telnet Server...
    [2026-03-10 15:58:43.842] [  OK  ] Finished Telnet Server.
    [2026-03-10 15:58:44.386] [   11.070949] remoteproc remoteproc4: powering up 64800000.dsp
    [2026-03-10 15:58:44.402] [   11.076649] remoteproc remoteproc4: Booting fw image j784s4-c71_0-fw, size 14422344
    [2026-03-10 15:58:44.402] [   11.085506] remoteproc remoteproc4: unsupported resource 65538
    [2026-03-10 15:58:44.418] [   11.091387] remoteproc remoteproc4: bad phdr da 0xb2100000 mem 0x98
    [2026-03-10 15:58:44.418] [   11.098368] remoteproc remoteproc4: Failed to load program segments: -22
    [2026-03-10 15:58:44.466] [   11.147494] remoteproc remoteproc7: powering up 67800000.dsp
    [2026-03-10 15:58:44.466] [   11.153203] remoteproc remoteproc6: powering up 66800000.dsp
    [2026-03-10 15:58:44.482] [   11.158891] remoteproc remoteproc5: powering up 65800000.dsp
    [2026-03-10 15:58:44.482] [   11.164554] remoteproc remoteproc5: Booting fw image j784s4-c71_1-fw, size 14815616
    [2026-03-10 15:58:44.497] [   11.172227] remoteproc remoteproc6: Booting fw image j784s4-c71_2-fw, size 14352768
    [2026-03-10 15:58:44.498] [   11.179892] remoteproc remoteproc7: Booting fw image j784s4-c71_3-fw, size 14352768
    [2026-03-10 15:58:44.513] [   11.187861] remoteproc remoteproc6: unsupported resource 65538
    [2026-03-10 15:58:44.514] [   11.193812] remoteproc remoteproc5: unsupported resource 65538
    [2026-03-10 15:58:44.514] [   11.199775] remoteproc remoteproc7: unsupported resource 65538
    [2026-03-10 15:58:44.529] [   11.205636] remoteproc remoteproc5: bad phdr da 0xb4100000 mem 0x98
    [2026-03-10 15:58:44.529] [   11.211929] remoteproc remoteproc7: bad phdr da 0xb8100000 mem 0x98
    [2026-03-10 15:58:44.530] [   11.218210] remoteproc remoteproc6: bad phdr da 0xb6100000 mem 0x98
    [2026-03-10 15:58:44.545] [   11.224480] remoteproc remoteproc7: Failed to load program segments: -22
    [2026-03-10 15:58:44.546] [   11.231196] remoteproc remoteproc5: Failed to load program segments: -22
    [2026-03-10 15:58:44.561] [   11.237899] remoteproc remoteproc6: Failed to load program segments: -22
    [2026-03-10 15:58:44.625] [  OK  ] Started User Login Management.
    [2026-03-10 15:58:44.641] [  OK  ] Finished IPv6 Packet Filtering Framework.
    [2026-03-10 15:58:44.642] [  OK  ] Finished IPv4 Packet Filtering Framework.
    [2026-03-10 15:58:44.769] [  OK  ] Finished Expand the rootfs partition to full size of the boot device..
    [2026-03-10 15:58:44.785] [   11.462074] Bluetooth: Core ver 2.22
    [2026-03-10 15:58:44.785] [   11.465728] NET: Registered PF_BLUETOOTH protocol family
    [2026-03-10 15:58:44.785] [   11.471074] Bluetooth: HCI device and connection manager initialized
    [   11.477452] Bluetooth: HCI socket layer initializedervice.
    [2026-03-10 15:58:44.802] [   11.487532] Bluetooth: L2CAP socket layer initialized
    [2026-03-10 15:58:44.817]
    [2026-03-10 15:58:44.817] [   11.492595] Bluetooth: SCO socket layer initialized
    [2026-03-10 15:58:44.817] [  OK  ] Started Avahi mDNS/DNS-SD Stack.
    [2026-03-10 15:58:44.818] [  OK  ] Created slice Slice /system/systemd-fsck.
    [2026-03-10 15:58:44.834] [  OK  ] Reached target Preparation for Network.
    [2026-03-10 15:58:44.834] [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
    [2026-03-10 15:58:44.865]          Starting Save/Restore Sound Card State...
    [2026-03-10 15:58:44.865]          Starting File System Check on /dev/mmcblk0p1...
    [2026-03-10 15:58:44.866]          Starting File System Check on /dev/mmcblk0p2...
    [2026-03-10 15:58:44.882]          Starting File System Check on /dev/mmcblk1p1...
    [2026-03-10 15:58:44.882]          Starting Network Configuration...
    [2026-03-10 15:58:44.882]          Starting Virtual Console Setup...
    [2026-03-10 15:58:44.897] [  OK  ] Finished Save/Restore Sound Card State.
    [2026-03-10 15:58:44.897] [  OK  ] Reached target Sound Card.
    [2026-03-10 15:58:44.945] [  OK  ] Finished File System Check on /dev/mmcblk0p1.
    [2026-03-10 15:58:44.977]          Mounting /run/media/boot-mmcblk0p1...
    [2026-03-10 15:58:44.993] [  OK  ] Finished File System Check on /dev/mmcblk1p1.
    [2026-03-10 15:58:44.993]          Mounting /run/media/boot-mmcblk1p1...
    [2026-03-10 15:58:45.009] [  OK  ] Mounted /run/media/boot-mmcblk0p1   11.687254] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [2026-03-10 15:58:45.010] 0m.
    [2026-03-10 15:58:45.025] [   11.705391] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [2026-03-10 15:58:45.025] [   11.711360] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [2026-03-10 15:58:45.089] [  OK  ] Finished File System Check on /dev/mmcblk0p2.
    [2026-03-10 15:58:45.121]          Mounting /run/media/rootfs-mmcblk0p2...
    [2026-03-10 15:58:45.137] [  OK  ] Started Network Configuration.
    [2026-03-10 15:58:45.153] [  OK  ] Reached target Network.
    [2026-03-10 15:58:45.153]          Starting containerd container runtime...
    [2026-03-10 15:58:45.154]          Starting LLDP daemon...
    [2026-03-10 15:58:45.169] [  OK  ] Started Netperf Benchmark Server   11.843834] am65-cpsw-nuss 46000000.ethernet eth0: PHY [46000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [2026-03-10 15:58:45.170] m.
    [2026-03-10 15:58:45.170] [   11.858038] am65-cpsw-nuss 46000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [2026-03-10 15:58:45.185]          Starting Simple Network Management Protocol (S[   11.869976] platform 5a00000.r5f: can not power up core1 before core0
    [2026-03-10 15:58:45.201] NMP) Daemon....
    [2026-03-10 15:58:45.201] [   11.878953] remoteproc remoteproc2: can't prepare rproc 5a00000.r5f: -1
    [2026-03-10 15:58:45.201]          Starting Permit User Sessions...
    [2026-03-10 15:58:45.217] [   11.884451] am65-cpsw-nuss c200000.ethernet eth1: PHY [c200f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [2026-03-10 15:58:45.217] [   11.885274] EXT4-fs (mmcblk0p2): mounted filesystem ec704a2a-2dbb-4ffd-adfb-f620d177de91 r/w with ordered data mode. Quota mode: none.
    [2026-03-10 15:58:45.233] [   11.913601] am65-cpsw-nuss c200000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [2026-03-10 15:58:45.234] [  OK  ] Finished Virtual Console Setup.
    [2026-03-10 15:58:45.250] [  OK  ] Mounted /run/media/boot-mmcblk1p1.
    [2026-03-10 15:58:45.250] [  OK  ] Mounted /run/media/rootfs-mmcblk0p2.
    [2026-03-10 15:58:45.266] [  OK  ] Finished Permit User Sessions.
    [2026-03-10 15:58:45.281] [  OK  ] Started emptty display manager.
    [2026-03-10 15:58:45.282] [  OK  ] Started Getty on tty1.
    [2026-03-10 15:58:45.282] [  OK  ] Started Serial Getty on ttyS2.
    [2026-03-10 15:58:45.297] [  OK  ] Reached target Login Prompts.
    [2026-03-10 15:58:45.313] [  OK  ] Started LLDP daemon.
    [2026-03-10 15:58:45.697] [   12.381944] platform 5d00000.r5f: can not power up core1 before core0
    [2026-03-10 15:58:45.713] [   12.388409] remoteproc remoteproc3: can't prepare rproc 5d00000.r5f: -1
    [2026-03-10 15:58:45.729] [   12.413936] platform 5f00000.r5f: can not power up core1 before core0
    [2026-03-10 15:58:45.745] [   12.420388] remoteproc remoteproc9: can't prepare rproc 5f00000.r5f: -1
    [2026-03-10 15:58:45.969] [  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
    [2026-03-10 15:58:46.769] [  OK  ] Started containerd container runtime.
    [2026-03-10 15:58:47.777] ***************************************************************
    [2026-03-10 15:58:47.778] NOTICE: This file system contains the following GPL-3.0 packages:
    [2026-03-10 15:58:47.793]       adwaita-icon-theme-symbolic
    [2026-03-10 15:58:47.793]       autoconf
    [2026-03-10 15:58:47.793]       bash-dev
    [2026-03-10 15:58:47.793]       bc
    [2026-03-10 15:58:47.794]       binutils
    [2026-03-10 15:58:47.794]       cifs-utils
    [2026-03-10 15:58:47.794]       coreutils-stdbuf
    [2026-03-10 15:58:47.794]       cpio
    [2026-03-10 15:58:47.794]       cpp-symlinks
    [2026-03-10 15:58:47.794]       dosfstools
    [2026-03-10 15:58:47.809]       elfutils-dev
    [2026-03-10 15:58:47.809]       findutils
    [2026-03-10 15:58:47.809]       g++-symlinks
    [2026-03-10 15:58:47.809]       gawk
    [2026-03-10 15:58:47.809]       gcc-symlinks
    [2026-03-10 15:58:47.810]       gdb
    [2026-03-10 15:58:47.810]       gdbserver
    [2026-03-10 15:58:47.810]       gettext
    [2026-03-10 15:58:47.810]       glmark2
    [2026-03-10 15:58:47.810]       gnu-config
    [2026-03-10 15:58:47.810]       grub-common
    [2026-03-10 15:58:47.810]       grub-editenv
    [2026-03-10 15:58:47.810]       grub-efi
    [2026-03-10 15:58:47.825]       gzip
    [2026-03-10 15:58:47.825]       hidapi
    [2026-03-10 15:58:47.825]       kbd-dev
    [2026-03-10 15:58:47.825]       kbd-keymaps-pine
    [2026-03-10 15:58:47.825]       less
    [2026-03-10 15:58:47.825]       libasm1
    [2026-03-10 15:58:47.825]       libatomic-dev
    [2026-03-10 15:58:47.825]       libatomic1
    [2026-03-10 15:58:47.825]       libbfd
    [2026-03-10 15:58:47.826]       libdebuginfod1
    [2026-03-10 15:58:47.826]       libdw1
    [2026-03-10 15:58:47.826]       libelf1
    [2026-03-10 15:58:47.826]       libgcc-s-dev
    [2026-03-10 15:58:47.826]       libgcc1
    [2026-03-10 15:58:47.826]       libgdbm-compat4
    [2026-03-10 15:58:47.826]       libgdbm-dev
    [2026-03-10 15:58:47.841]       libgdbm6
    [2026-03-10 15:58:47.841]       libgettextlib
    [2026-03-10 15:58:47.841]       libgettextsrc
    [2026-03-10 15:58:47.841]       libgmp-dev
    [2026-03-10 15:58:47.841]       libgmp10
    [2026-03-10 15:58:47.841]       libgmpxx4
    [2026-03-10 15:58:47.841]       libgnutls-dev
    [2026-03-10 15:58:47.841]       libgnutls-openssl27
    [2026-03-10 15:58:47.842]       libgomp1
    [2026-03-10 15:58:47.842]       libidn2-0
    [2026-03-10 15:58:47.842]       libidn2-dev
    [2026-03-10 15:58:47.842]       libmpc3
    [2026-03-10 15:58:47.842]       libmpfr6
    [2026-03-10 15:58:47.857]       libopcodes
    [2026-03-10 15:58:47.857]       libqt6shadertools-dev
    [2026-03-10 15:58:47.857]       libqt6shadertools-plugins
    [2026-03-10 15:58:47.857]       libqt6shadertools-qmlplugins
    [2026-03-10 15:58:47.857]       libqt6shadertools6
    [2026-03-10 15:58:47.857]       libreadline-dev
    [2026-03-10 15:58:47.858]       libreadline8
    [2026-03-10 15:58:47.858]       libstdc++-dev
    [2026-03-10 15:58:47.858]       libstdc++6
    [2026-03-10 15:58:47.858]       libtasn1-dev
    [2026-03-10 15:58:47.873]       libunistring-dev
    [2026-03-10 15:58:47.873]       libunistring5
    [2026-03-10 15:58:47.873]       m4
    [2026-03-10 15:58:47.873]       make
    [2026-03-10 15:58:47.873]       nettle-dev
    [2026-03-10 15:58:47.873]       parted
    [2026-03-10 15:58:47.873]       piglit
    [2026-03-10 15:58:47.873]       qtbase-dev
    [2026-03-10 15:58:47.874]       qtbase-examples
    [2026-03-10 15:58:47.874]       qtbase-plugins
    [2026-03-10 15:58:47.874]       qtbase-qmlplugins
    [2026-03-10 15:58:47.874]       qtbase-staticdev
    [2026-03-10 15:58:47.889]       qtbase
    [2026-03-10 15:58:47.889]       qtdeclarative-dev
    [2026-03-10 15:58:47.889]       qtdeclarative-plugins
    [2026-03-10 15:58:47.889]       qtdeclarative-qmlplugins
    [2026-03-10 15:58:47.889]       qtdeclarative-staticdev
    [2026-03-10 15:58:47.889]       qtlanguageserver-dev
    [2026-03-10 15:58:47.890]       qtlanguageserver-plugins
    [2026-03-10 15:58:47.890]       qtlanguageserver-qmlplugins
    [2026-03-10 15:58:47.905]       qtlanguageserver-staticdev
    [2026-03-10 15:58:47.905]       qtsvg-dev
    [2026-03-10 15:58:47.905]       qtsvg-plugins
    [2026-03-10 15:58:47.905]       qtsvg-qmlplugins
    [2026-03-10 15:58:47.905]       qtwayland-dev
    [2026-03-10 15:58:47.906]       qtwayland-plugins
    [2026-03-10 15:58:47.906]       qtwayland-qmlplugins
    [2026-03-10 15:58:47.921]       tar
    [2026-03-10 15:58:47.921]       which
    [2026-03-10 15:58:47.921] If you do not wish to distribute GPL-3.0 components please remove
    [2026-03-10 15:58:47.921] the above packages prior to distribution.  This can be done using
    [2026-03-10 15:58:47.922] the opkg remove command.  i.e.:
    [2026-03-10 15:58:47.937]     opkg remove <package>
    [2026-03-10 15:58:47.937] Where <package> is the name printed in the list above
    [2026-03-10 15:58:47.937] NOTE: If the package is a dependency of another package you
    [2026-03-10 15:58:47.937]       will be notified of the dependent packages.  You should
    [2026-03-10 15:58:47.953]       use the --force-removal-of-dependent-packages option to
    [2026-03-10 15:58:47.953]       also remove the dependent packages as well
    [2026-03-10 15:58:47.953] ***************************************************************
    [2026-03-10 15:58:47.969] ***************************************************************
    [2026-03-10 15:58:47.969] [  OK  ] Finished Print notice about GPLv3 packages.
    [2026-03-10 15:58:47.985] [  OK  ] Reached target Multi-User System.
    [2026-03-10 15:58:48.001] [  OK  ] Reached target Graphical Interface.
    [2026-03-10 15:58:48.049]          Starting Record Runlevel Change in UTMP...
    [2026-03-10 15:58:48.081] [  OK  ] Finished Record Runlevel Change in UTMP.
    [2026-03-10 15:58:48.785] [   15.470763] kauditd_printk_skb: 2 callbacks suppressed
    [2026-03-10 15:58:48.801] [   15.470773] audit: type=1006 audit(1748544692.248:14): pid=1260 uid=0 subj=kernel old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
    [2026-03-10 15:58:48.802] [   15.489679] audit: type=1300 audit(1748544692.248:14): arch=c00000b7 syscall=64 success=yes exit=4 a0=8 a1=ffffcdcded58 a2=4 a3=1 items=0 ppid=1 pid=1260 auid=1000 uid=0 gid=)
    [2026-03-10 15:58:48.834] [   15.517540] audit: type=1327 audit(1748544692.248:14): proctitle="(systemd)"
    [2026-03-10 15:58:49.105]
    [2026-03-10 15:58:49.105]  _____                    _____           _         _
    [2026-03-10 15:58:49.121] |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    [2026-03-10 15:58:49.121] |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    [2026-03-10 15:58:49.122] |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
    [2026-03-10 15:58:49.137]               |___|                    |___|
    [2026-03-10 15:58:49.137] Arago Project j784s4-evm ttyS2
    [2026-03-10 15:58:49.137] Arago 2025.01 j784s4-evm ttyS2
    [2026-03-10 15:58:49.138]
    [2026-03-10 15:58:49.138] j784s4-evm login: [   16.866682] PVR_K:  1267: RGX Firmware image 'rgx.fw.36.53.104.796' loaded
    [2026-03-10 15:58:50.193] [   16.880572] PVR_K:  1267: Shader binary image 'rgx.sh.36.53.104.796' loaded
    [2026-03-10 15:58:50.209] [   16.889043] PVR_K:  1267: SLCSize:   262144
    CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.8 | VT102 | Offline | ttyUSB4
    Best Regards
    Gokul Praveen
