AM6442: Prebuilt (and custom-built) sbl_null fail when booted via UART
Part Number: AM6442
Dear TI team,
I've been having issues booting my custom-built sbl_null on a custom board via UART. To rule out issues with my build I've tried using the pre-built SBL, and that fails in the same way.
I'm using Tera Term's built-in Transfer -> XMODEM functionality, but I've used tools/boot/uart_bootloader.py with the same result, i.e. ROM was executing again after uart_bootloader.py finished without errors:
The file is apparently transfered just fine, but the NULL bootloader doesn't seem to start up, and instead the ROM appears to executed immediately again, i.e. the output looks like:
[SOCID]CCC[SOCID]
The SOCID on this board is 02000000011a0000616d3634780000000000000048534653000002000000020002a6000000000000b018658ad99dc903c8c9bfb27b12751099920a042ad1dfea7b7ba57369f15546de285edde6a7b39a8bdc40a27b237f8fb1e57f245e80b929c1e28b024aa2ecc6ad0bc40b000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000aeabfba887873ecf9fc13aae04342216fa3923c933f150f17f19c1c8f19ee45e.
This issue is visible when using sbl_null.release.hs_fs.tiimage from MCU+ SDK 11.02.00.24 (md5sum dfde43b0731ebdd4cb06be2b000a6db3) or from MCU+ SDK 11.01, but not visible when booting e.g. sbl_null.debug.hs_fs.tiimage (264d151d2fb9e48974b3b929fe76ba90) from MCU+ SDK 11.02.
When putting the same sbl_null.release.hs_fs.tiimage on an SD card (as tiboot3.bin) it boots just fine.
I've been seeing the same issue with the sbl_null.release.hs_fs.tiimage from MCU+ SDK 11.01.00.17 but not with the prebuilt release NULL bootloader from SDK 11.00.00.15.
My custom bootloader fails when built as a debug build using CCS (both 12.8.1 and 20.4.0), but works when built as a release build. When building my custom bootloader via make (integrated into an MCU+ SDK tree), only the debug build works, not the release build (i.e. same as with the prebuilt SBLs).
  • Is there a known issue concerning SBLs and UART boot mode?
  • How can I debug this issue?
Dominic
