[FAQ] TDA4VL-Q1: ECC Self Test Procedure
Part Number: TDA4VL-Q1
What is the effort required by the system integrator to enable and test ECC on the different IPs on the SoC using ECC aggregators?
    Please refer to the table below for details on how each ECC endpoint can be tested using ECC aggregators -
    ECC Type Inject Type Accessible Mem Checker Type Single bit injection possible? Test Procedure Double bits injection possible? Test Procedure
    ECC Wrapper
    Inject only NO N/A Yes SDL APIs can be used only for error injection. Error detection and correction is a part of the IP itself. Yes SDL APIs can be used only for error injection by forcefully setting the error status bits. Error detection and correction is a part of the IP itself.
    Inject with error capture YES N/A Yes SDL APIs can be used, memory access also a part of the SDL ecc_func_app in sdl/test Yes SDL APIs can be used, memory access also a part of the SDL ecc_func_app in sdl/test
    Inject with error capture NO N/A Yes
    SDL APIs can be used only to inject error
    Details on memory access to trigger error available in - [FAQ] TDA4VL-Q1: ECC Testing Procedure for Inaccessible RAM IDs and [FAQ] TDA4VH-Q1: ECC Testing Procedure for Inaccessible RAM IDs
    No
    SDL APIs can be used only to inject error by forcefully setting the error status bits. No requirement to perform a memory access.
    EDC Interconnect
    NO
    Redundant Yes SDL APIs can be used, no memory access required. Refer ecc_func_app in sdl/test No N/A
    Parity Yes SDL APIs can be used, no memory access required. Refer ecc_func_app in sdl/test No N/A
    Error Detect and Correct Yes SDL APIs can be used, no memory access required. Refer ecc_func_app in sdl/test Yes SDL APIs can be used, no memory access required. Refer ecc_func_app in sdl/test
    YES Redundant Yes SDL APIs can be used, no memory access required. Refer ecc_func_app in sdl/test No N/A
    For details on the meaning and types of ECC endpoints, please refer - [FAQ] TDA4VM: Types of ECC Aggregators, RAM IDs and Error Injection
    Josiitaa
