Poor Performance with dm368 h264 endcoder using gstreamer
Other Parts Discussed in Thread: TVP7002
My Setup:
DM368EVM
DVSDK 4.02
Video input: 720p30 via Component
My Pipeline is as follow:
root@dm368-evm:~# gst-launch -v v4l2src always-copy=FALSE num-buffers=800 input-
src=component ! video/x-raw-yuv, format=\(fourcc\)NV12, width=1280, height=720,
framerate=\(fraction\)30/1 ! queue ! TIVidenc1 codecName=h264enc engineName=code
cServer byteStream=FALSE ! dmaiperf print-arm-load=true ! qtmux ! filesink locat
ion=/mnt/output_gen_.mp4
Setting pipeline to PAUSED ...
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
davinci_previewer davinci_previewer.2: ipipe_set_preview_config
vpfe-capture vpfe-capture: IPIPE Chained
vpfe-capture vpfe-capture: Resizer present
EVM: switch to tvp7002 HD video input
vpfe-capture vpfe-capture: width = 1, height = 1, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 16, height = 1, bpp = 2, bytesperline = 32, sizeimage = 32
vpfe-capture vpfe-capture: width = 32768, height = 32768, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 2176, height = 1536, bpp = 2, bytesperline = 4352, sizeimage = 6684672
vpfe-capture vpfe-capture: width = 1, height = 1, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 32, height = 1, bpp = 1, bytesperline = 32, sizeimage = 48
vpfe-capture vpfe-capture: width = 32768, height = 32768, bpp = 1
vpfe-capture vpfe-capture: adjusted width = 2176, height = 1536, bpp = 1, bytesperline = 2176, sizeimage = 5013504
vpfe-capture vpfe-capture: width = 8, height = 2, bpp = 2
vpfe-capture vpfe-capture: adjusted width = 16, height = 2, bpp = 2, bytesperline = 32, sizeimage = 64
vpfe-capture vpfe-capture: width = 32775, height = 32769, bpp = 2
(gst-launch-0.10:1607): GStreamer-WARNING **: pad v4l2src0:src rvpfe-capture vpfe-capture: width = 1280, height = 720, bpp = 1
eturned caps whivpfe-capture vpfe-capture: adjusted width = 1280, height = 720, bpp = 1, bytesperline = 1280, sizeimage = 1382400
ch are not a reavpfe-capture vpfe-capture: width = 1280, height = 720, bpp = 1
l subset of its vpfe-capture vpfe-capture: adjusted width = 1280, height = 720, bpp = 1, bytesperline = 1280, sizeimage = 1382400
template caps
/GstPipeline:pipver_nr_lines: 719eline0/GstV4l2Sr
c:v4l2src0: queue-size = 3
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1
Pipeline is live and does not need PREROLL ...
WARNING: from element /GstPipeline:pipeline0/GstDmaiperf:dmaiperf0: There is no codec present that can handle the stream's type.
Additional debug info:
gsttidmaiperf.c(285): gst_dmaiperf_start (): /GstPipeline:pipeline0/GstDmaiperf:dmaiperf0:
Engine name not specified, not printing DSP information
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstTIVidenc1:tividenc10.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)1280, height=(int)720, framerate=(fraction)30/1
/GstPipeline:pipeline0/GstTIVidenc1:tividenc10.GstPad:src: caps = video/x-h264, framerate=(fraction)30/1, width=(int)1280, height=(int)720, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d081240
/GstPipeline:pipeline0/GstDmaiperf:dmaiperf0.GstPad:src: caps = video/x-h264, framerate=(fraction)30/1, width=(int)1280, height=(int)720, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d08124290
/GstPipeline:pipeline0/GstDmaiperf:dmaiperf0.GstPad:sink: caps = video/x-h264, framerate=(fraction)30/1, width=(int)1280, height=(int)720, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d0812420
INFO:
Timestamp: 0:43:35.092316996; bps: 0; fps: 0; CPU: 0;
/GstPipeline:pipeline0/GstQTMux:qtmux0.GstPad:video_00: caps = video/x-h264, framerate=(fraction)30/1, width=(int)1280, height=(int)720, codec_data=(buffer)01640028ffe1005a67640028ad84054562b8ac5474202a2b15c562a3a1015158ae2b151d080a8ac57158a8e84054562b8ac5474202a2b15c562a3a10248521393c9f27e4fe4fc9f279b9b34d081242900
/GstPipeline:pipeline0/GstFileSink:filesink0.GstPad:sink: caps = video/quicktime, variant=(string)apple
INFO:
Timestamp: 0:43:36.156518040; bps: 192821; fps: 8; CPU: 85;
INFO:
Timestamp: 0:43:37.205626581; bps: 176287; fps: 8; CPU: 85;
INFO:
Timestamp: 0:43:38.250689246; bps: 132915; fps: 8; CPU: 84;
INFO:
Timestamp: 0:43:39.303775412; bps: 130142; fps: 8; CPU: 83;
INFO:
Timestamp: 0:43:40.347953579; bps: 112289; fps: 8; CPU: 84;
INFO:
Timestamp: 0:43:41.392907035; bps: 114027; fps: 8; CPU: 85;
INFO:
Timestamp: 0:43:42.444034077; bps: 126837; fps: 8; CPU: 84;
INFO:
Timestamp: 0:43:43.488741119; bps: 117098; fps: 8; CPU: 84;
INFO:
Timestamp: 0:43:44.532101538; bps: 115101; fps: 8; CPU: 85;
INFO:
Timestamp: 0:43:45.584553872; bps: 136063; fps: 8; CPU: 84;
I also tried this Pipeline without the qtmux element, but same poor performance. Is this a problem with the TIVidenc element or is something wrong with my Pipeline? 720p30 should not be a problem for DM368, but 85% cpu usage for 8 fps? Found a report about poor encoding performance here, but there hasn´t been any reply:
https://texinst1.gforgegroup.com/gf/project/gstreamer_ti/forum/?_forum_action=ForumMessageBrowse&thread_id=4236&action=ForumBrowse&forum_id=187
