Part Number: TMS320C6655
I'm using TMS320C6655 along with MT25QU128ABA nor flash to store firmware. Nor flash did not boot after upgrade in no boot mode . Nor read verify fails in sector 0 when tried upgrade in Nor boot mode. I'm using proper boot table image image (.dat file) to write into Nor flash. Below is the Norwriter.c code I'm using in my project. Please check and point out for bugs if any.
* Copyright (c) 2011-2015, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* FILE PURPOSE: NOR writer utility
* FILE NAME: norwriter.c
* DESCRIPTION: A simple nor writer using platform lib APIs to program the NOR flash
* with an image that the ibl can read.
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include "platform.h"
#include "types.h"
#include <dsp.h>
#include <errno.h>
/* NOR writer utility version */
char version[] = "01.00.00.04";
uint32_t swap_byte = 0;
/* Memory address to store the write data */
#define WRITE_DATA_ADDRESS 0x80000000
* Structure: NOR_WRITER_INFO_T
* NOR writer control data. This structure should be filled in
* by the user before running
#define MAX_LINE_LENGTH 40
typedef struct NOR_WRITER_INFO_tag
char file_name[MAX_LINE_LENGTH]; /* CCS format data file name */
uint32_t blockSizeBytes; /* The size of each sector */
uint32_t deviceTotalBytes; /* Total number of bytes available in the device */
uint32_t startAddr; /* Start address to write */
uint32_t writeBytes; /* Number of bytes to be written into the device */
uint8_t *writeData; /* Address to store the write data */
uint8_t *readData; /* Address to store the read data */
} NOR_WRITER_INFO_T;
NOR_WRITER_INFO_T norWriterInfo;
/* OSAL functions for Platform Library */
uint8_t *Osal_platformMalloc (uint32_t num_bytes, uint32_t alignment)
return malloc(num_bytes);
void Osal_platformFree (uint8_t *dataPtr, uint32_t num_bytes)
/* Free up the memory */
if (dataPtr)
free(dataPtr);
void Osal_platformSpiCsEnter(void)
return;
void Osal_platformSpiCsExit (void)
return;
* Function: print_platform_errno
void
void
printf ("Returned platform error number is %d\n", platform_errno);
* Function: formBlock
* Form a block of data to write to the NOR. The block is
* created as a byte stream from the 4 byte stream in which
* the MSB is always sent first.
void
formBlock
uint32_t *data,
uint32_t blockSize,
uint8_t *scratch
uint32_t i, j;
/* Convert the data to a byte stream */
for (i = j = 0; j < blockSize; i++, j+=4)
scratch[j+0] = (data[i] >> 24) & 0xff;
scratch[j+1] = (data[i] >> 16) & 0xff;
scratch[j+2] = (data[i] >> 8) & 0xff;
scratch[j+3] = (data[i] >> 0) & 0xff;
* Function: flash_nor
* Write the image to flash.
* Returns TRUE if the image is written successfully
* FALSE if the image write fails
Bool
flash_nor
PLATFORM_DEVICE_info *p_device
uint32_t wPos, wLen;
uint32_t block, start_block;
uint8_t *scrach_block;
if (swap_byte)
scrach_block = malloc(norWriterInfo.blockSizeBytes);
if (scrach_block == NULL)
printf ("Can not allocate scratch block memory!\n");
return (FALSE);
start_block = norWriterInfo.startAddr / norWriterInfo.blockSizeBytes;
/* Program the NOR */
for (block = start_block, wPos = 0; wPos < norWriterInfo.writeBytes; block++, wPos += norWriterInfo.blockSizeBytes)
printf ("Flashing sector %d (%d bytes of %d)\n", block, wPos, norWriterInfo.writeBytes);
wLen = norWriterInfo.blockSizeBytes;
if (norWriterInfo.writeBytes - wPos < norWriterInfo.blockSizeBytes)
wLen = norWriterInfo.writeBytes - wPos;
if (swap_byte)
formBlock((uint32_t *)(&norWriterInfo.writeData[wPos]), norWriterInfo.blockSizeBytes, scrach_block);
else
scrach_block = &norWriterInfo.writeData[wPos];
if (platform_device_write(p_device->handle,
block*norWriterInfo.blockSizeBytes,
scrach_block,
wLen) != Platform_EOK)
printf ("platform_nor_write sector # %d failed!\n", block);
print_platform_errno();
if (swap_byte) free (scrach_block);
return (FALSE);
return (TRUE);
* Function: flash_verify
* Read back the data file that was just flashed. On errors mark the block as bad.
* Returns TRUE if the image verified correctly.
* FALSE if the image verification failed
Bool
flash_verify
uint32_t rPos, rLen;
uint32_t i, j;
uint32_t *read_data_w;
if (swap_byte)
return (FALSE);
for (block = start_block, rPos = 0; rPos < norWriterInfo.writeBytes; block++, rPos += norWriterInfo.blockSizeBytes)
printf ("Reading and verifying sector %d (%d bytes of %d)\n", block, rPos, norWriterInfo.writeBytes);
if (!swap_byte)
scrach_block = &norWriterInfo.readData[rPos];
/* Read a sector of data */
if(platform_device_read(p_device->handle,
scrach_block,
norWriterInfo.blockSizeBytes) != Platform_EOK)
printf ("Failure in sector %d\n", block);
return (FALSE);
/* Convert the packed data */
if (swap_byte)
read_data_w = (uint32_t *)(&norWriterInfo.readData[rPos]);
for (i = 0, j = 0; i < norWriterInfo.blockSizeBytes; i += 4)
read_data_w[j++] = (scrach_block[i+0] << 24) | (scrach_block[i+1] << 16) | (scrach_block[i+2] << 8) | scrach_block[i+3];
/* Read the data from the file */
rLen = norWriterInfo.blockSizeBytes;
if (norWriterInfo.writeBytes - rPos < norWriterInfo.blockSizeBytes)
rLen = norWriterInfo.writeBytes - rPos;
for (i = rPos; i < rLen; i++)
if (norWriterInfo.readData[i] != norWriterInfo.writeData[i])
printf ("Failure in sector %d, at byte %d, (at byte %d in the data file) expected 0x%08x, read 0x%08x\n",
block, i, rPos, norWriterInfo.writeData[i], norWriterInfo.readData[i]);
return (FALSE);
return (TRUE);
* Function: main
Bool norwriter(uint32_t data_len)
//FILE *fp;
platform_init_flags init_flags;
platform_init_config init_config;
PLATFORM_DEVICE_info *p_device;
//Bool ret;
uint32_t write_addr;
printf("NOR Writer Utility Version %s\n\n", version);
strcpy (norWriterInfo.file_name, "haze.dat");
norWriterInfo.startAddr = 0;
/* Initialize main Platform lib */
memset(&init_config, 0, sizeof(platform_init_config));
memset(&init_flags, 1, sizeof(platform_init_flags));
init_flags.pll = 0;
init_flags.ddr = 0;
init_flags.phy = 0;
if (platform_init(&init_flags, &init_config) != Platform_EOK)
printf ("Platform init failed!\n");
return FALSE;
#if !(defined(_EVMC6657L_))
#if (defined(DEVICE_K2G) || defined(SOC_K2G))
p_device = platform_device_open(PLATFORM_DEVID_NORN25Q128A13ESF40F, 0);
#else
p_device = platform_device_open(PLATFORM_DEVID_NORN25Q128, 0);
#endif
#else
p_device = platform_device_open(PLATFORM_DEVID_NORN25Q032A, 0);
#endif
if (p_device == NULL)
printf ("NOR device open failed!\n");
return FALSE;
norWriterInfo.deviceTotalBytes = p_device->block_count * p_device->page_count * p_device->page_size;
norWriterInfo.blockSizeBytes = p_device->page_count * p_device->page_size;
if ((norWriterInfo.startAddr % norWriterInfo.blockSizeBytes) != 0)
printf ("The start programming address 0x%8x set in %s is not at the beginning of a block, block size = 0x%4x\n",
norWriterInfo.startAddr,
return FALSE;
if (data_len > (norWriterInfo.deviceTotalBytes - norWriterInfo.startAddr))
printf ("The data file is too big to fit into the device.\n");
return FALSE;
norWriterInfo.writeBytes = data_len;
write_addr = WRITE_DATA_ADDRESS;
norWriterInfo.writeData = (uint8_t *)write_addr;
norWriterInfo.readData = (uint8_t *)(write_addr + norWriterInfo.deviceTotalBytes);
printf("writeBytes - %d\n", norWriterInfo.writeBytes);
norWriterInfo.writeBytes += norWriterInfo.blockSizeBytes - 1;
norWriterInfo.writeBytes -= norWriterInfo.writeBytes % norWriterInfo.blockSizeBytes;
/* Write the flash */
if (flash_nor (p_device) == FALSE)
printf ("NOR write failed\n");
platform_device_close(p_device->handle);
return FALSE;
/* verify the flash */
if(flash_verify (p_device) == FALSE)
printf ("NOR read verify failed\n");
return FALSE;
printf ("NOR programming completed successfully\n");
return TRUE;
