[FAQ] Bad Block management in AM64x ROM on GPMC-NAND booting
Part Number: AM6442
Other Parts Discussed in Thread: TMDS64EVM
AM64x boot ROM supports booting from parallel GPMC-NAND.
From "4.4.10 GPMC NAND Boot" in AM64x TRM
"AM64x ROM only supports boot from ONFI 1.0 compatible 8 bit parallel NAND memory up to 2Gbytes in size
connected to GPMC CS0 with the following geometries:
• 2Kbyte page and spare area of at least 64 bytes or
• 4Kbyte page size and spare area of at least 128 bytes"
Please refer to AM64x TRM "Chapter 4 Initialization" for details on GPMC NAND support by boot rom.
The FAQ discusses how the Bad Block (BB) in GPMC-NAND is handled in AM64x ROM when loading the first stage user BootLoader (BL) from GPMC-NAND with BB. The FAQ uses u-boot flashing/booting from GPMC-NAND with BB on TMDS64EVM [1] and [2] using AM64x Linux SDK 10.0.7.4 [3] as an example.
[1]. TMDS64EVM www.ti.com/.../TMDS64EVM
[2]. TI reference NAND card (TMDS64DC02EVM)
[3]. www.ti.com/.../10.00.07.04
There's a companion FAQ on how to flash and boot u-boot from parallel GPMC NAND on AM64x
https://e2e.ti.com/support/processors-group/processors/f/791/t/1406344
  • Key Components of GPMC-NAND Bad Block Management
    Bad block management ensures that unreliable or factory-defective areas of the NAND flash are identified and bypassed to prevent data corruption.
    - Bad Block Markers (BBM): Factory-set bad blocks are identified by a non-0xFF value in a specific byte of the OOB (Out-of-Band) area of the first or second page of an erase block.
    - Bad Block Table (BBT): To avoid scanning the entire flash at every boot, the Linux kernel typically maintains a BBT.
    Key Details for GPMC-NAND Bad Block Marker (BBM) in u-boot
    - Marker Location: u-boot scans for a non-0xFF value at a specific offset (first or second byte) in the OOB area of the first page of each block.
    - Block-Level Status: If a bad block marker is found, the entire block (i.e. 128KB or 256KB) is marked as bad and skipped during nand read/write operations.
    - Scanning Policy: Because scanning every page would be too slow, the convention is to only check the OOB of the first or first two pages to determine if the whole block is unreliable.
    Consistency on Bad Block Marker (BBM)
    It is critical that ROM, SPL/u-boot and the Linux kernel use the same BBM scheme, otherwise, one might incorrectly identify good blocks as bad or fail to see existing bad block markers.
    Simplified logic for bad block skipping in ROM
    Similar to SPL (Secondary Program Loader), ROM primarily rely on a pre-scanned, factory-marked Bad Block Marker or a simple BBM scanned at runtime to support bad block skipping: During the boot process, ROM reads the OOB area of the first page of each block. If the Bad Block Marker is not 0xFF, ROM simply skips that entire block and moves to the next block, ROM continues this until finish reading the user's SPL.
    Logs from u-boot flashing/booting from GPMC-NAND with BB
    1. am64_10.0.7.4_nand_flash_bb#0.log: The u-boot log from flashing gpmc-nand with the BB @0x0
    As shown in the log, the BB @0x0 is detected by u-boot based on the BBM from reading OOB of the first page of the block, and the BB @0x0 is skipped in gpmc-nand erase operation. During gpmc-nand flashing, u-boot skip the BB @0x0, and flash SPL to the next gpmc-nand block @0x40000 instead.
    2. am64_10.0.7.4_nand_boot_bb#0.log: the working u-boot gpmc-nand booting log with the BB @0x0
    The BB @0x0 is scanned, and detected by ROM based on the BBM from reading OOB of the first page of the block, and SPL is loaded from the next gpmc-nand block @0x40000 to internal SRAM to boot by ROM.
    U-Boot SPL 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    Resetting on cold boot to workaround ErrataID:i2331
    Please resend tiboot3.bin in case of UART/DFU boot
    resetting ...
    SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    SPL initial stack usage: 13392 bytes
    Detected: TMDS64DC02EVM rev E1
    Trying to boot from MMC2
    Authentication passed
    Loading Environment from MMC... *** Warning - No MMC card found, using default environment
    Starting ATF on ARM64 core...
    NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
    NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
    I/TC:
    I/TC: OP-TEE version: 4.2.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Apr 12 09:51:21 UTC 2024 aarch64
    I/TC: WARNING: This OP-TEE configuration might be insecure!
    I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
    I/TC: Primary CPU initializing
    I/TC: GIC redistributor base address not provided
    I/TC: Assuming default GIC group status and modifier
    I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
    I/TC: HUK Initialized
    I/TC: Activated SA2UL device
    I/TC: Enabled firewalls for SA2UL TRNG device
    I/TC: SA2UL TRNG initialized
    I/TC: SA2UL Drivers initialized
    I/TC: Primary CPU switching to normal world boot
    U-Boot 2024.04-ti-gfda88f8bcea3 (Jul 26 2024 - 11:00:12 +0000)
    SoC:   AM64X SR2.0 HS-FS
    Model: Texas Instruments AM642 EVM
    Board: AM64-GPEVM rev C
    DRAM:  2 GiB
    Core:  102 devices, 33 uclasses, devicetree: separate
    NAND:  1024 MiB
    MMC:   mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    Net:   eth0: ethernet@8000000port@1, eth2: icssg1-eth-port@0
    Hit any key to stop autoboot:  2  0
    => md.l 0x43000030 1
    43000030: 00000243                             C...
    => nand info
    Device 0: nand0, sector size 256 KiB
      Page size         4096 b
      OOB size           256 b
      Erase size      262144 b
      ecc strength         8 bits
      ecc step size      512 b
      subpagesize       1024 b
      options       0x0000400c
      bbt options   0x00000000
    => mtd list
    SF: Detected s28hs512t with page size 256 Bytes, erase size 256 KiB, total 64 MiB
    List of MTD devices:
    * nand0
      - device: nand@0,0
      - parent: memory-controller@3b000000
      - driver: gpmc-nand
      - path: /bus@f4000/memory-controller@3b000000/nand@0,0
      - type: NAND flash
      - block size: 0x40000 bytes
      - min I/O: 0x1000 bytes
      - OOB size: 256 bytes
      - OOB available: 142 bytes
      - ECC strength: 8 bits
      - ECC step size: 512 bytes
      - bitflip threshold: 6 bits
      - 0x000000000000-0x000040000000 : "nand0"
    	  - 0x000000000000-0x000000200000 : "NAND.tiboot3"
    	  - 0x000000200000-0x000000400000 : "NAND.tispl"
    	  - 0x000000400000-0x000000600000 : "NAND.tiboot3.backup"
    	  - 0x000000600000-0x000000a00000 : "NAND.u-boot"
    	  - 0x000000a00000-0x000000a40000 : "NAND.u-boot-env"
    	  - 0x000000a40000-0x000000a80000 : "NAND.u-boot-env.backup"
    	  - 0x000000a80000-0x000040000000 : "NAND.file-system"
    * nor0
      - device: flash@0
      - parent: spi@fc40000
      - driver: jedec_spi_nor
      - path: /bus@f4000/bus@fc00000/spi@fc40000/flash@0
      - type: NOR flash
      - min I/O: 0x1 bytes
      - 0x000000000000-0x000004000000 : "nor0"
    	  - 0x000000000000-0x000000100000 : "ospi.tiboot3"
    	  - 0x000000100000-0x000000300000 : "ospi.tispl"
    	  - 0x000000300000-0x000000700000 : "ospi.u-boot"
    	  - 0x000000700000-0x000000740000 : "ospi.env"
    	  - 0x000000740000-0x000000780000 : "ospi.env.backup"
    	  - 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    	  - 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    => nand bad
    Device 0 bad blocks:
      0x00000000
    => nand erase.chip
    NAND erase.chip: device 0 whole chip
    Skipping bad block at  0x00000000
    Erasing at 0x40000 --   0% complete.
    Erasing at 0xa00000 --   1% complete.
    Erasing at 0x1440000 --   2% complete.
    Erasing at 0x1e80000 --   3% complete.
    Erasing at 0x28c0000 --   4% complete.
    Erasing at 0x3300000 --   5% complete.
    Erasing at 0x3d40000 --   6% complete.
    Erasing at 0x4780000 --   7% complete.
    Erasing at 0x51c0000 --   8% complete.
    Erasing at 0x5c00000 --   9% complete.
    Erasing at 0x6640000 --  10% complete.
    Erasing at 0x7080000 --  11% complete.
    Erasing at 0x7ac0000 --  12% complete.
    Erasing at 0x8500000 --  13% complete.
    Erasing at 0x8f40000 --  14% complete.
    Erasing at 0x9980000 --  15% complete.
    Erasing at 0xa3c0000 --  16% complete.
    Erasing at 0xae00000 --  17% complete.
    Erasing at 0xb840000 --  18% complete.
    Erasing at 0xc280000 --  19% complete.
    Erasing at 0xccc0000 --  20% complete.
    Erasing at 0xd700000 --  21% complete.
    Erasing at 0xe140000 --  22% complete.
    Erasing at 0xeb80000 --  23% complete.
    Erasing at 0xf5c0000 --  24% complete.
    Erasing at 0xffc0000 --  25% complete.
    Erasing at 0x10a00000 --  26% complete.
    Erasing at 0x11440000 --  27% complete.
    Erasing at 0x11e80000 --  28% complete.
    Erasing at 0x128c0000 --  29% complete.
    Erasing at 0x13300000 --  30% complete.
    Erasing at 0x13d40000 --  31% complete.
    Erasing at 0x14780000 --  32% complete.
    Erasing at 0x151c0000 --  33% complete.
    Erasing at 0x15c00000 --  34% complete.
    Erasing at 0x16640000 --  35% complete.
    Erasing at 0x17080000 --  36% complete.
    Erasing at 0x17ac0000 --  37% complete.
    Erasing at 0x18500000 --  38% complete.
    Erasing at 0x18f40000 --  39% complete.
    Erasing at 0x19980000 --  40% complete.
    Erasing at 0x1a3c0000 --  41% complete.
    Erasing at 0x1ae00000 --  42% complete.
    Erasing at 0x1b840000 --  43% complete.
    Erasing at 0x1c280000 --  44% complete.
    Erasing at 0x1ccc0000 --  45% complete.
    Erasing at 0x1d700000 --  46% complete.
    Erasing at 0x1e140000 --  47% complete.
    Erasing at 0x1eb80000 --  48% complete.
    Erasing at 0x1f5c0000 --  49% complete.
    Erasing at 0x1ffc0000 --  50% complete.
    Erasing at 0x20a00000 --  51% complete.
    Erasing at 0x21440000 --  52% complete.
    Erasing at 0x21e80000 --  53% complete.
    Erasing at 0x228c0000 --  54% complete.
    Erasing at 0x23300000 --  55% complete.
    Erasing at 0x23d40000 --  56% complete.
    Erasing at 0x24780000 --  57% complete.
    Erasing at 0x251c0000 --  58% complete.
    Erasing at 0x25c00000 --  59% complete.
    Erasing at 0x26640000 --  60% complete.
    Erasing at 0x27080000 --  61% complete.
    Erasing at 0x27ac0000 --  62% complete.
    Erasing at 0x28500000 --  63% complete.
    Erasing at 0x28f40000 --  64% complete.
    Erasing at 0x29980000 --  65% complete.
    Erasing at 0x2a3c0000 --  66% complete.
    Erasing at 0x2ae00000 --  67% complete.
    Erasing at 0x2b840000 --  68% complete.
    Erasing at 0x2c280000 --  69% complete.
    Erasing at 0x2ccc0000 --  70% complete.
    Erasing at 0x2d700000 --  71% complete.
    Erasing at 0x2e140000 --  72% complete.
    Erasing at 0x2eb80000 --  73% complete.
    Erasing at 0x2f5c0000 --  74% complete.
    Erasing at 0x2ffc0000 --  75% complete.
    Erasing at 0x30a00000 --  76% complete.
    Erasing at 0x31440000 --  77% complete.
    Erasing at 0x31e80000 --  78% complete.
    Erasing at 0x328c0000 --  79% complete.
    Erasing at 0x33300000 --  80% complete.
    Erasing at 0x33d40000 --  81% complete.
    Erasing at 0x34780000 --  82% complete.
    Erasing at 0x351c0000 --  83% complete.
    Erasing at 0x35c00000 --  84% complete.
    Erasing at 0x36640000 --  85% complete.
    Erasing at 0x37080000 --  86% complete.
    Erasing at 0x37ac0000 --  87% complete.
    Erasing at 0x38500000 --  88% complete.
    Erasing at 0x38f40000 --  89% complete.
    Erasing at 0x39980000 --  90% complete.
    Erasing at 0x3a3c0000 --  91% complete.
    Erasing at 0x3ae00000 --  92% complete.
    Erasing at 0x3b840000 --  93% complete.
    Erasing at 0x3c280000 --  94% complete.
    Erasing at 0x3ccc0000 --  95% complete.
    Erasing at 0x3d700000 --  96% complete.
    Erasing at 0x3e140000 --  97% complete.
    Erasing at 0x3eb80000 --  98% complete.
    Erasing at 0x3f5c0000 --  99% complete.
    Erasing at 0x3ffc0000 -- 100% complete.
    OK
    => nand dump 0x0
    Page 00000000 dump:
    	ff ff ff ff ff ff ff ff  ff ff ff ff ff ff ff ff
    OOB:
    	00 ff ff ff ff ff ff ff
    => ls mmc 1
                EFI/
     21029376   Image
       619289   tiboot3-am64x-gp-evm.bin
       621878   tiboot3-am64x_sr2-hs-evm.bin
       621878   tiboot3-am64x_sr2-hs-fs-evm.bin
      1023711   tispl.bin
      1362319   u-boot.img
          574   uEnv.txt
                am64_10.1.10.4_prebuilt/
                .Trash-1000/
                am64_11.1.5.3_prebuilt/
                am64_binman/
                System Volume Information/
                am64_gpmc-nand_bin/
          128   ospi_phy_pattern
         8126   dec_keyring_gen_sign_note.txt
                am64_10.0.7.4_prebuilt/
                tifs_trace_bin/
       620662   tiboot3.bin
    10 file(s), 9 dir(s)
    => load mmc 1 ${loadaddr} tiboot3.bin
    620662 bytes read in 69 ms (8.6 MiB/s)
    => nand write ${loadaddr} NAND.tiboot3 ${filesize}
    NAND write: device 0 offset 0x0, size 0x97876
    Skip bad block 0x00000000
     620662 bytes written: OK
    => load mmc 1 ${loadaddr} tispl.bin
    1023711 bytes read in 85 ms (11.5 MiB/s)
    => nand write ${loadaddr} NAND.tispl ${filesize}
    NAND write: device 0 offset 0x200000, size 0xf9edf
     1023711 bytes written: OK
    => load mmc 1 ${loadaddr} u-boot.img
    1362319 bytes read in 99 ms (13.1 MiB/s)
    => nand write ${loadaddr} NAND.u-boot ${filesize}
    NAND write: device 0 offset 0x600000, size 0x14c98f
     1362319 bytes written: OK
    resetting ...
    Trying to boot from NAND
    init_env from device 11 not supported!
    I/TC:
    DRAM:  2 GiB
    NAND:  1024 MiB
    In:    serial@2800000
    Out:   serial@2800000
    Err:   serial@2800000
    43000030: 0000025b                             [...
    => nand info
      Page size         4096 b
      OOB size           256 b
      Erase size      262144 b
      ecc strength         8 bits
      ecc step size      512 b
      subpagesize       1024 b
      options       0x0000400c
    => mtd list
    * nand0
      - device: nand@0,0
      - driver: gpmc-nand
      - type: NAND flash
    * nor0
      - device: flash@0
      - type: NOR flash
    => nand bad
      0x00000000
    => nand dump 0x0
    Page 00000000 dump:
    OOB:
    => nand dump 0x3f000
    Page 0003f000 dump:
    OOB:
    => nand dump 0x40000
    Page 00040000 dump:
    	30 82 07 f6 30 82 05 de  a0 03 02 01 02 02 14 16
    	67 fa a4 5f 68 db c9 8b  a1 f8 73 df da 79 1f 5a
    	83 25 02 30 0d 06 09 2a  86 48 86 f7 0d 01 01 0d
    	05 00 30 81 9d 31 0b 30  09 06 03 55 04 06 13 02
    	55 53 31 0b 30 09 06 03  55 04 08 0c 02 54 58 31
    	0f 30 0d 06 03 55 04 07  0c 06 44 61 6c 6c 61 73
    	31 27 30 25 06 03 55 04  0a 0c 1e 54 65 78 61 73
    	20 49 6e 73 74 72 75 6d  65 6e 74 73 20 49 6e 63
    	6f 72 70 6f 72 61 74 65  64 31 13 30 11 06 03 55
    	04 0b 0c 0a 50 72 6f 63  65 73 73 6f 72 73 31 13
    	30 11 06 03 55 04 03 0c  0a 54 49 20 53 75 70 70
    	6f 72 74 31 1d 30 1b 06  09 2a 86 48 86 f7 0d 01
    	09 01 16 0e 73 75 70 70  6f 72 74 40 74 69 2e 63
    	6f 6d 30 1e 17 0d 32 34  30 37 32 38 31 32 31 32
    	33 30 5a 17 0d 32 34 30  38 32 37 31 32 31 32 33
    	30 5a 30 81 9d 31 0b 30  09 06 03 55 04 06 13 02
    	6f 6d 30 82 02 22 30 0d  06 09 2a 86 48 86 f7 0d
    	01 01 01 05 00 03 82 02  0f 00 30 82 02 0a 02 82
    	02 01 00 bf 14 ae 49 d8  7f 72 d3 6b 23 cd eb 48
    	0e 65 dc 22 4d f2 0e 4f  82 f6 ed b5 f2 dd db 7c
    	91 fa 6e 59 ff d5 f7 b6  de 04 1d 8a cc d2 95 d9
    	d1 e0 c4 c1 f8 50 bf ff  48 0c 91 22 50 9a 4c 7b
    	8b f3 96 0a 28 26 b3 a4  d9 e0 a9 55 41 1a fb 3e
    	5b 27 6c bf ca c0 71 af  2f 72 22 ee 46 01 25 62
    	ad 3e c7 04 f6 b1 18 b6  2c c0 12 6e 0f e2 9b 3e
    	e5 a6 a0 a8 06 45 03 41  17 4e 16 1f a9 74 d6 84
    	4e d6 79 a7 10 b8 11 a9  0e 92 1f 25 dd 7f b1 f2
    	d1 b9 f2 68 d8 33 59 4b  82 7d 77 cc d1 9c fa 23
    	b4 fb 58 88 f2 cd ea d5  16 f2 2c 75 2d fa 62 c3
    	c1 09 6e e0 06 70 e0 b5  07 09 99 62 d9 d6 e4 e7
    	6c 6d c8 82 07 50 93 f7  e2 d8 ed d1 5f e3 d0 9e
    	cf 93 54 d9 5f dd 5d ce  37 60 f1 ab 14 8a 04 7b
    	65 a7 ba 7f df 45 45 7c  4b a1 5b ae 4e c6 94 3d
    	8c 4e 87 d2 94 3c a4 f3  9f da fc f2 36 7c e7 0d
    	ad 5a 42 37 f1 2a 81 d0  6e a1 a7 67 03 1e 87 ed
    	00 bb 73 4a 68 28 31 a2  82 9a a3 04 c1 e8 87 ff
    	45 7e aa c1 9f d4 3b 05  c7 83 fd 21 71 fe bd 7f
    	38 c9 16 19 52 0e e6 03  33 8d 1d 1e c9 36 1c cd
    	4e 9d 82 29 88 cd 9b 2a  be 6c 5f 7b b2 b2 3a 79
    	00 6a 7d f5 ad 1a 9d 1e  cd 58 2a cf 5e f4 4e 80
    	ab 3b 4f dd f8 d4 de 34  a2 c4 20 d9 59 19 2d 85
    	02 5e 1f 68 b1 4c 8d b9  11 06 e9 2d 76 b5 58 8c
    	50 a8 37 6e 66 78 6f 83  30 46 4d 34 9f b4 18 4a
    	b9 bb fa 7b c5 ae d6 32  10 84 84 6c 3f 9a 80 33
    	35 fc 4d bc d5 6e 60 54  50 cf 7e 6d 80 97 04 fa
    	8f 0b 20 fd bd 98 2b a1  37 bd 59 fd 4a ec 45 a1
    	09 8b 17 c9 72 14 33 b7  05 5e 12 5d e2 5a 1d ce
    	21 54 f6 e1 ea d5 55 aa  27 eb 4d 09 df 19 40 82
    	2e 66 89 17 65 d9 6e b3  d6 38 4e 8d 61 16 d6 74
    	d4 de 16 5f 51 19 d5 42  b8 83 d2 c8 de 4b a9 69
    	97 b6 8d 02 03 01 00 01  a3 82 02 2a 30 82 02 26
    	30 0c 06 03 55 1d 13 04  05 30 03 01 01 ff 30 12
    	06 09 2b 06 01 04 01 82  26 01 03 04 05 30 03 02
    	01 01 30 82 01 a5 06 09  2b 06 01 04 01 82 26 01
    	09 04 82 01 96 30 82 01  92 02 03 09 70 7c 02 01
    	04 30 61 02 01 01 02 01  10 02 01 00 04 04 70 00
    	00 00 02 03 05 f1 d4 06  09 60 86 48 01 65 03 04
    	02 03 04 40 e9 20 9e 05  02 75 73 3c 92 72 61 2c
    	c3 cf 6a b1 2d 49 41 45  07 e0 90 18 dd fe 15 18
    	8d c1 69 7a 57 51 75 f6  bf ba 6b 56 40 39 09 38
    	cf 41 86 f0 75 fe 04 57  e1 38 9b ed 2b 63 34 12
    	df bf ca d0 30 61 02 01  02 02 01 00 02 01 00 04
    	04 00 04 40 00 02 03 03  70 00 06 09 60 86 48 01
    	65 03 04 02 03 04 40 7f  4d 42 b4 49 22 c1 67 2f
    	87 51 c7 6c d8 9a 17 7a  59 72 e3 2f 71 84 3e 96
    	6d c9 4d 1a 78 db 33 c9  c7 86 32 9b 73 aa af af
    	dd 56 87 80 14 e2 6c d1  8f df 24 80 78 c2 23 be
    	53 2d 7d ef 6e 7e 91 30  60 02 01 12 02 01 00 02
    	01 00 04 04 00 07 b0 00  02 02 08 14 06 09 60 86
    	48 01 65 03 04 02 03 04  40 ee 2b 7d 78 3a 37 52
    	70 72 5a 70 c6 da a7 19  c8 53 5c d6 31 9d 76 c3
    	e8 8f 96 5f 8a 0a 14 61  34 f3 0e 26 e5 8a 46 15
    	1a 13 9b ba 26 45 fe 31  97 ea a7 49 95 8e b9 24
    	d2 99 80 77 4f c0 b6 20  6f 30 60 02 01 03 02 01
    	00 02 01 00 04 04 00 00  00 00 02 02 06 94 06 09
    	60 86 48 01 65 03 04 02  03 04 40 ed 9c c6 29 ce
    	1b 6f df c7 6a 83 2f 83  24 5d 92 0f ae 36 05 5e
    	a8 99 7a bf 1e 9a 94 ad  08 83 37 19 51 e1 af b1
    	ea f0 9f 46 13 16 c0 7a  85 a8 40 3c f7 b9 af 9c
    	92 91 8c ab d0 3a b4 e6  31 66 be 30 3a 06 09 2b
    	06 01 04 01 82 26 01 08  04 2d 30 2b 04 20 00 00
    	00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00
    	00 00 00 00 00 00 00 00  00 00 00 00 00 00 02 01
    	04 02 01 00 02 01 00 30  1d 06 03 55 1d 0e 04 16
    	04 14 04 df bb b3 84 14  77 25 0c cb 2e 33 a4 7d
    	4d 85 59 12 fb e5 30 0d  06 09 2a 86 48 86 f7 0d
    	01 01 0d 05 00 03 82 02  01 00 12 4a 47 fd f2 20
    	ab ed ec 59 4f 30 fe 3d  7f 42 68 b2 2d ae f5 62
    	4c 7e 3d 39 f5 f7 f1 e5  a2 8e 75 75 44 fc 28 cf
    	bc 18 3d fd 09 b5 80 48  b8 6f f2 d9 59 e3 56 37
    	73 00 c9 93 5a 87 fa 6b  a5 11 3d f4 86 d0 dc dc
    	4c 28 e3 2f eb ba dd 13  d1 94 87 30 4e f1 32 44
    	c1 fd bb 93 a5 99 93 8b  cb fe 85 66 64 e2 08 2e
    	7f 89 e7 3b 1f 3b 07 05  4f 1e b1 0a f5 8e 55 e1
    	60 c9 ff 90 e4 3b 18 2b  86 2a 44 bf f5 82 c5 ba
    	e0 a3 71 ff 72 20 56 d4  7c 8c f9 3d 80 fd d3 2c
    	e2 3d 95 68 8b 8f ad 3a  44 16 55 39 20 e8 33 9c
    	11 43 bd 6a e7 17 61 35  09 dd f3 55 78 42 27 45
    	90 d2 1e 78 bf c8 8c e8  f5 39 e0 bb 22 b8 26 1e
    	2c 17 a0 58 85 3b 5e 0e  88 02 c3 6b 60 aa 1b 08
    	ab c0 af 9f f4 e8 fa 48  fc 5a bb 00 6d e4 a1 5f
    	63 9f 67 76 72 5a 1f a6  aa 64 13 76 90 e8 c7 d9
    	98 6b bb 8e 86 40 c0 f7  09 40 2b be 2e 6c fa d6
    	dc 7d 9b 5d e4 0e 2b 26  3e ec b0 0b 99 09 47 7a
    	1b bb 33 c0 c0 dc f0 e6  98 59 ef 87 17 ef ac f9
    	e2 12 a3 f7 50 d9 0e 25  90 a0 dd bb a6 2d ff 93
    	af c7 f9 3f c6 83 c9 d7  f4 fc bd 20 c0 9b 91 6d
    	2a d9 77 58 b9 8a 37 c9  ed ad 22 3f 55 bf 95 73
    	48 5a 76 29 c1 81 56 1f  1c be ba 53 55 ee c6 37
    	cc f9 f5 69 df 76 68 c5  b7 46 7c 65 3a 2e ad 86
    	e3 f2 7c f8 86 f8 75 57  c5 88 53 b4 af e5 35 f7
    	b0 30 eb 47 ff 94 32 d1  c8 f1 ae 5e ce 2f 1c 28
    	c6 fa 4e 5c fb d7 f7 48  ca 95 0d 0b 02 65 19 da
    	a2 86 53 d0 b8 5b 76 c6  c1 17 89 a3 ab cc 59 36
    	4d 16 b4 a1 9e 91 8f 5a  06 aa 1b 52 76 a9 d0 29
    	84 bf f4 be 14 4b 1a d7  58 f3 f1 f8 cb 5b 7e c3
    	02 68 65 7f c4 90 31 85  c0 a0 87 b0 43 40 35 90
    	9c 42 8d 34 e8 31 5d 74  aa 02 8f c9 93 00 cc 90
    	88 74 de b0 ae 5e ac 87  22 07 18 f0 9f e5 18 f0
    	9f e5 18 f0 9f e5 18 f0  9f e5 18 f0 9f e5 18 f0
    	9f e5 18 f0 9f e5 18 f0  9f e5 44 00 00 70 40 00
    	00 70 40 00 00 70 40 00  00 70 40 00 00 70 40 00
    	00 70 40 00 00 70 40 00  00 70 fe ff ff ea 0f 00
    	00 ea 00 00 0f e1 1f 10  00 e2 1a 00 31 e3 1f 00
    	c0 13 13 00 80 13 c0 00  80 e3 00 f0 29 e1 10 0f
    	11 ee 02 0a c0 e3 10 0f  01 ee 1d 00 00 eb 8a 03
    	00 eb 15 0f 07 ee 4f f0  7f f5 6f f0 7f f5 1e ff
    	2f e1 ee ff ff ea 00 00  a0 e3 17 0f 08 ee 15 0f
    	07 ee d5 0f 07 ee 4f f0  7f f5 6f f0 7f f5 10 0f
    	11 ee 02 0a c0 e3 07 00  c0 e3 02 00 80 e3 02 0b
    	80 e3 01 0a 80 e3 10 0f  01 ee 0e 50 a0 e1 10 1f
    	10 ee 21 3a a0 e1 0f 30  03 e2 0f 40 01 e2 03 22
    	a0 e1 02 20 84 e1 0c 00  9f e5 07 00 c0 e3 00 d0
    	a0 e1 05 f0 a0 e1 00 00  00 ea 00 b8 19 70 b0 0f
    	10 ee ff 00 00 e2 00 00  50 e3 00 00 00 1a 1e ff
    	2f e1 03 f0 20 e3 fd ff  ff ea 01 48 10 21 00 f0
    	a6 be c4 37 04 70 70 b5  04 9e 04 46 1d 46 09 f0
    	b0 fc 01 1e 06 db 33 46  2a 46 20 46 bd e8 70 40
    	02 f0 e5 be 6f f0 01 00  70 bd 70 b5 06 46 00 20
    	0c 46 15 46 28 f0 51 ff  01 46 10 b1 0a 48 0c f0
    	ca fc 3e b9 21 46 2a 46  28 f0 56 ff 01 46 08 b1
    	06 48 f4 e7 00 20 28 f0  6b ff 01 46 08 b1 03 48
    	ed e7 70 bd 00 bf dc 79  03 70 01 7a 03 70 29 7a
    	03 70 08 b5 06 4b 1b 78  13 b1 a0 f1 ff 40 08 bd
    	04 4b 18 68 00 28 fa d1  03 48 0c f0 a4 fc 04 b8
    	19 70 00 b8 19 70 4d 7a  03 70 02 4b 18 78 80 f0
    	01 00 70 47 00 bf 04 b8  19 70 2d e9 f0 45 04 46
    	9d b0 88 46 17 46 00 21  28 22 05 a8 00 f0 a5 fe
    	00 22 03 92 04 92 4c b1  11 46 01 20 ff f7 ad ff
    	89 4b 01 22 1a 70 1d b0  bd e8 f0 85 87 49 40 20
    	04 f0 22 ff 86 4e 30 60  18 b9 83 49 85 48 0c f0
    	72 fc 07 90 00 f0 4b f9  0f ad 01 46 0a 28 03 90
    	0a d8 02 28 0c d9 c3 1e  07 2b 09 d8 df e8 03 f0
    	15 08 08 08 38 0a 0a 3d  1f 28 03 d0 2a 28 58 d0
    	79 48 e4 e7 4f f4 58 53  03 a9 77 4a 05 a8 00 93
    	00 23 02 f0 ce f8 04 46  17 e0 02 f0 49 fa 2a 46
    	01 46 71 20 0f f0 5a fd  04 46 80 b1 00 20 6f f0
    	12 04 33 68 00 f5 88 22  02 f5 b8 62 04 3b 50 f8
    	04 1b 43 f8 04 1f 82 42  f9 d1 3c b3 1e e0 0f 98
    	01 21 0f f0 fd f9 00 28  e8 d0 00 f5 d8 00 e8 e7
    	03 a9 05 a8 01 f0 79 ff  d5 e7 5b 4b 28 46 32 68
    	5f 49 0c f0 00 fe 5e 4a  5f 49 28 46 14 f0 47 fa
    	04 46 30 b1 14 f0 dd f8  14 f0 db f8 5b 48 21 46
    	9d e7 5a 49 02 f0 0b ff  14 f0 d3 f8 34 68 01 22
    	4d 4b 1a 70 22 68 56 4b  9a 42 09 d0 56 48 0c f0
    	02 fc 4d 4b 01 22 03 a9  05 a8 02 f0 22 f9 aa e7
    	52 49 20 46 09 f0 06 fd  01 1e 01 da 50 48 7e e7
    	50 4a 02 ab 00 95 20 46  ff f7 05 ff 02 1e 03 da
    	4c 49 4c 48 0c f0 e7 fb  0f 9a 00 20 02 99 ff f7
    	0c ff 00 f0 34 fa 04 46  b8 f1 00 0f 00 d0 c0 47
    	d6 f8 00 a0 41 49 50 46  09 f0 e4 fc 06 1e 01 da
    	31 46 db e7 41 4a 02 ab  31 46 50 46 00 95 ff f7
    	e2 fe 02 1e 01 da 3c 49  db e7 0f 9b 20 46 00 93
    	00 23 21 68 02 9a 88 47  80 46 10 b1 01 46 37 48
    	45 e7 37 4a 02 ab 31 46  50 46 00 95 ff f7 cb fe
    	02 1e 01 da 33 49 c4 e7  0f 9b 20 46 00 93 43 46
    	e1 68 02 9a 88 47 80 46  10 b1 01 46 2e 48 2e e7
    	2e 4a 02 ab 31 46 50 46  00 95 ff f7 b4 fe 02 1e
    	01 da 29 49 ad e7 0f 9b  20 46 00 93 43 46 61 68
    	02 9a 88 47 80 46 10 b1  01 46 24 48 17 e7 24 4a
    	02 ab 31 46 50 46 00 95  ff f7 9d fe 02 1e 01 da
    	20 49 96 e7 0f 9b 20 46  00 93 43 46 a1 68 02 9a
    	88 47 01 46 08 b1 1b 48  01 e7 00 2f 3f f4 f3 ae
    	b8 47 f0 e6 00 bf 04 b8  19 70 c0 45 04 00 00 b8
    	19 70 6d 7a 03 70 d0 7a  03 70 a2 7a 03 70 ac 7a
    	03 70 1b c2 03 70 1d 88  03 70 03 7b 03 70 c4 7a
    	03 70 d0 0d fe ed 32 7b  03 70 52 7b 03 70 5a 7b
    	03 70 79 7b 03 70 83 7b  03 70 a8 7b 03 70 b6 7b
    	03 70 de 7b 03 70 e9 7b  03 70 14 7c 03 70 1f 7c
    	03 70 4a 7c 03 70 56 7c  03 70 07 b5 01 f0 57 f8
    	01 a8 0a f0 58 fe 30 b9  01 9b 23 b1 0f f0 ab fa
    	01 20 0f f0 ee fa 03 b0  5d f8 04 fb 08 29 04 d0
    	09 29 0c bf 03 20 01 20  70 47 02 20 70 47 4f f0
    	86 43 1b 6b bf f3 5f 8f  1e 4a 12 68 d2 b9 c3 f3
    	c3 00 42 1e db 09 0e 2a  32 d8 df e8 02 f0 2e 2e
    	2e 22 22 31 31 08 31 0d  31 31 31 2e 24 00 13 f0
    	04 0f 08 bf 09 20 70 47  13 f0 02 0f 14 bf 2a 20
    	0a 20 70 47 c3 f3 40 30  c3 f3 82 23 01 3b 06 2b
    	09 d8 df e8 03 f0 0a 08  14 06 0f 12 04 00 06 20
    	70 47 04 20 70 47 00 20  70 47 00 28 14 bf 2a 20
    	0a 20 70 47 c0 f1 09 00  70 47 03 20 70 47 07 20
    	70 47 50 39 04 70 08 b5  ff f7 b9 ff 09 28 0b d1
    	00 20 19 f0 2e f9 38 b1  c2 69 00 21 02 62 01 22
    	bd e8 08 40 18 f0 26 ba  08 bd 08 b5 ff f7 a7 ff
    	09 28 09 d1 00 20 19 f0  1c f9 28 b1 bd e8 08 40
    	01 6a 00 22 18 f0 16 ba  08 bd 37 b5 05 46 ff f7
    	96 ff 00 24 2a 28 0f d1  05 23 28 46 01 94 00 93
    	07 4a 07 4b 08 49 02 f0  a8 fa 04 46 20 b1 06 49
    	02 46 06 48 0c f0 75 fc  20 46 03 b0 30 bd 87 7c
    	03 70 f9 03 04 70 8f 7c  03 70 61 11 04 70 b7 7c
    	03 70 07 b5 ff f7 a9 fd  61 4b 61 49 62 48 d3 f8
    	fc 2b 61 4b 1a 60 0c 22  00 f0 f7 fc 01 21 4f f4
    	70 20 00 f0 10 f9 00 21  4f f0 8a 60 00 f0 0b f9
    	01 21 4f f0 8a 60 00 f0  06 f9 02 21 4f f0 8a 60
    	00 f0 01 f9 03 21 4f f0  8a 60 00 f0 fc f8 04 21
    	4f f0 8a 60 00 f0 f7 f8  06 21 4f f0 8a 60 00 f0
    	f2 f8 00 21 4f f0 86 40  00 f0 ed f8 01 21 4f f0
    	86 40 00 f0 e8 f8 02 21  4f f0 86 40 00 f0 e3 f8
    	03 21 4f f0 86 40 00 f0  de f8 05 21 4f f0 86 40
    	00 f0 d9 f8 06 21 4f f0  86 40 00 f0 d4 f8 01 21
    	4f f0 81 60 00 f0 cf f8  01 f0 99 f9 01 f0 57 fa
    	6a 46 03 21 6c 20 0f f0  51 fb 18 b9 38 49 00 98
    	23 f0 d3 f9 34 48 00 f0  d2 f8 35 4a 36 49 ff f7
    	9c fd 6a 46 35 49 2d 20  0f f0 b2 fb 02 46 18 b1
    	33 49 33 48 0c f0 f5 fb  33 4b d3 f8 78 31 bf f3
    	5f 8f 13 b1 13 f0 40 7f  0b d0 2f 48 0c f0 e9 fb
    	2f 48 0c f0 e6 fb 00 23  1a 46 19 46 18 46 14 f0
    	c8 ff 00 f0 7a f8 ff f7  d0 fe 29 49 6a 46 47 20
    	0f f0 c6 fb 01 46 10 b1  27 48 0c f0 d2 fb 26 49
    	6a 46 47 20 0f f0 bc fb  01 46 10 b1 24 48 0c f0
    	c8 fb 1c 4a d2 f8 70 31  bf f3 5f 8f 23 f4 00 33
    	bf f3 5f 8f 00 21 61 20  c2 f8 70 31 6a 46 0f f0
    	98 fb 01 46 10 b1 1a 48  0c f0 e5 f9 ff f7 bf fe
    	04 28 08 d1 18 49 01 aa  47 20 0f f0 61 fb 10 b1
    	16 48 0c f0 a6 fb 03 b0  5d f8 04 fb 00 bf 00 e0
    	1b 70 00 eb 1b 70 44 39  04 70 50 39 04 70 dd 7c
    	03 70 51 05 00 70 2d 05  00 70 64 a6 04 70 54 11
    	04 70 e5 7c 03 70 00 80  51 04 03 7d 03 70 38 7d
    	03 70 6c 7d 03 70 77 7d  03 70 91 7d 03 70 9d 7d
    	03 70 b6 7d 03 70 94 98  04 70 cc 7d 03 70 07 b5
    	08 49 01 aa 2d 20 0f f0  2b fb 01 46 10 b1 05 48
    	0c f0 a1 f9 01 98 16 f0  28 fc 03 b0 5d f8 04 fb
    	00 bf 64 a6 04 70 f3 7d  03 70 30 b5 8d b0 ff f7
    	e6 ff 20 22 03 ad 04 46  00 f1 d0 01 28 46 0b f0
    	08 ff 94 f8 cd 20 94 f8  cc 10 05 48 00 23 8d f8
    	2c 30 b4 f8 ce 30 00 95  0c f0 4b fb 0d b0 30 bd
    	00 bf 0d 7e 03 70 00 eb  81 30 bf f3 5f 8f 05 4a
    OOB:
    	ff ff 56 bb 64 60 fd 1f
    	c5 1d ad cb dd 20 bf 00
    	60 4f b5 e0 ee 20 7f f9
    	c9 d1 2c ac cd 00 6b 55
    	0e 02 a2 cf 63 a5 e0 f9
    	b2 fd b9 00 57 56 34 9e
    	57 ee 5a 93 3c 32 5c 32
    	10 00 7c ea e4 03 ca 8a
    	29 15 87 ba 3b 29 90 00
    	ed 33 09 e5 59 17 61 32
    	07 49 28 38 5d 00 f0 59
    	52 33 27 40 6d 7b b5 1c
    	1f fd 0b 00 32 15 df ce
    	f1 04 3b 62 5b 1b 19 4f
    	27 00 ff ff ff ff ff ff
