Hi ALL,
I was trying to build c674x_aaclcenc_01_00_01_00_elf using the latest ezsdk 5.03 .01.15 on dm8168 but no success so far.
I set "# make oms".
Error log is the below and attaced file;
js: "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/dm81xx/DspAppMain.cfg", line 142: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: can't locate the package 'ti.sdo.codecs.aaclcenc.ce' along the path: '/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/bios_6_32_05_54/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/framework_components_3_21_03_34/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ipc_1_23_05_40/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/syslink_2_00_05_85/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdctools_3_22_04_46/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/codec_engine_3_21_02_25/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src/ti/omx/interfaces/openMaxv11;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264enc_01_00_04_00_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264dec_01_00_00_04_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg2vdec_01_00_03_00_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x_mp3dec_01_41_00_00_elf/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x-aaclcdec_01_41_00_00_elf/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/codecs-dm816x_5_00_00_00/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src/ti/omx/comp/omxbase;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src/ti/omx/omxcore;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_hdvicp20api_01_00_00_19_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/osal_1_21_01_08/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdais_7_21_01_07/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/linuxutils_3_21_00_04/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/uia_1_00_03_25/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4enc_01_00_00_03_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4vdec_01_00_02_05_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_vc1vdec_01_00_00_03_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_jpegvdec_01_00_01_00_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x-aaclcenc_01_41_00_00_elf/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdctools_3_22_04_46/packages;..;'. Ensure that the package path is set correctly.
"./package/cfg/DspAppMain_pe674.cfg", line 370
"./package/cfg/DspAppMain_pe674.cfg", line 449
"./package/cfg/DspAppMain_pe674.cfg", line 357
gmake: *** [package/cfg/DspAppMain_pe674.xdl] Error 1
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264enc_01_00_04_00_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264dec_01_00_00_04_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg2vdec_01_00_03_00_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x_mp3dec_01_41_00_00_elf/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/codecs-dm816x_5_00_00_00/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_hdvicp20api_01_00_00_19_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4enc_01_00_00_03_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4vdec_01_00_02_05_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_vc1vdec_01_00_00_03_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_jpegvdec_01_00_01_00_production/packages" on package path does not exist
Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x-aaclcenc_01_41_00_00_elf/packages" on package path does not exist
js: "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdctools_3_22_04_46/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
make[2]: *** [xdc_configuro] Error 1
make[2]: Leaving directory `/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/dm81xx'
make[1]: *** [dm81xxdspXdc] Error 2
make[1]: Leaving directory `/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src'
make: *** [omx] Error 2
======== all [/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/bin/xdc/dm81xx] ======== # # all files complete. all files complete: Thu Feb 9 20:07:25 JST 2012. make[2]: Leaving directory `/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src' # Configuring XDC packages for dm81xx:c6x make -C /home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/dm81xx xdc_configuro CORE=c6xdsp make[2]: Entering directory `/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/dm81xx' # Invoking configuro... chmod a+x /home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/bin/maketemp_configuro_cmd_c6xdsp.bat /home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/bin/maketemp_configuro_cmd_c6xdsp.bat configuring DspAppMain.xe674 from package/cfg/DspAppMain_pe674.cfg ... warning: ti.platforms.generic.Platform: "./package/cfg/DspAppMain_pe674.cfg", line 324: (xdc.platform.IPlatform.Instance)ti.platforms.generic.Platform.Instance#0 plat: The parameter 'regs' is passed to this platform instance through Build.platformTable, but the instance does not have a configuration parameter with that name. PROGRAM : ............. xdc.cfg.Program CONFIG ARGS : ............. [object Object] js: "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/dm81xx/DspAppMain.cfg", line 142: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: can't locate the package 'ti.sdo.codecs.aaclcenc.ce' along the path: '/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/bios_6_32_05_54/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/framework_components_3_21_03_34/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ipc_1_23_05_40/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/syslink_2_00_05_85/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdctools_3_22_04_46/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/codec_engine_3_21_02_25/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src/ti/omx/interfaces/openMaxv11;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264enc_01_00_04_00_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264dec_01_00_00_04_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg2vdec_01_00_03_00_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x_mp3dec_01_41_00_00_elf/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x-aaclcdec_01_41_00_00_elf/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/codecs-dm816x_5_00_00_00/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src/ti/omx/comp/omxbase;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src/ti/omx/omxcore;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_hdvicp20api_01_00_00_19_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/osal_1_21_01_08/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdais_7_21_01_07/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/linuxutils_3_21_00_04/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/uia_1_00_03_25/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4enc_01_00_00_03_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4vdec_01_00_02_05_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_vc1vdec_01_00_00_03_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_jpegvdec_01_00_01_00_production/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x-aaclcenc_01_41_00_00_elf/packages;/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdctools_3_22_04_46/packages;..;'. Ensure that the package path is set correctly. "./package/cfg/DspAppMain_pe674.cfg", line 370 "./package/cfg/DspAppMain_pe674.cfg", line 449 "./package/cfg/DspAppMain_pe674.cfg", line 357 gmake: *** [package/cfg/DspAppMain_pe674.xdl] Error 1 Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264enc_01_00_04_00_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_h264dec_01_00_00_04_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg2vdec_01_00_03_00_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x_mp3dec_01_41_00_00_elf/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/codecs-dm816x_5_00_00_00/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_hdvicp20api_01_00_00_19_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4enc_01_00_00_03_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_mpeg4vdec_01_00_02_05_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_vc1vdec_01_00_00_03_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/ivahd_jpegvdec_01_00_01_00_production/packages" on package path does not exist Warning: directory "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/c674x-aaclcenc_01_41_00_00_elf/packages" on package path does not exist js: "/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/xdctools_3_22_04_46/packages/xdc/tools/Cmdr.xs", line 51: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. make[2]: *** [xdc_configuro] Error 1 make[2]: Leaving directory `/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/dm81xx' make[1]: *** [dm81xxdspXdc] Error 2 make[1]: Leaving directory `/home/dm8168/ti-ezsdk_dm816x-evm_5_03_01_15/component-sources/omx_05_02_00_30/src' make: *** [omx] Error 2 dm8168@dm8168-desktop:~/ti-ezsdk_dm816x-evm_5_03_01_15$
Please teach how to build aac-lc encoder om dm8168.
With best regards,
-- M.Nakayama
