Ramakrishna,
DSP is not a linux module, so insmod wo't work.
You should use
./firmware_loader 0 dsp.xe74 start
to load teh DSP.
Vimal
Hi Ramakrishna,
In addition, please also have a look at the Software Developers Guide in the EZSDK's docs/ directory. This has introductory material on you how to run different sample applications, the overall software stack.
I am using ./firmware_loader 0 dsp.xe74 start only. But it Hangs..
After enabling syslink logs I came to know processor IDLE..!
Is there any setting or clock setting to enable DSP.?
Hi, Ramakrishna,
Did you solve this problem after a while? I appreciate any input here.
Yuanwei
