hi every one
I am using the Blaze board (not Blaze Tablet) to run Android 4.0 system which have the Linux kernel 3.0.8.
the u-boot ,x-loader ,file system and kernel is downloaded and built by the [L27.IS.2.P2 OMAP4 Icecream Sandwich Release Notes] which is recorded in http://omappedia.org/wiki/L27.IS.2.P2_OMAP4_Icecream_Sandwich_Release_Notes .
Now the Android can work and display on this board. but if system enter the Power Down state , I press any key try to wake up the system ,but the system is reset. the part of log is below
[ 929.658538] wl1271: ERROR command execute failure 16
[ 929.665130] ------------[ cut here ]------------
[ 929.680511] WARNING: at /home/zhong/pm_wk/27.IS.2/mydroid/hardware/ti/wlan/mac80211/compat/drivers/net/wireless/wl12xx/cmd.c:107 wl1271_cmd_send+0x38c/0x3e4 [wl12xx]()
[ 929.703216] Modules linked in: wl12xx_sdio wl12xx mac80211 cfg80211 compat [last unloaded: wl12xx_sdio]
[ 929.717956] Backtrace:
[ 929.722015] [<c0059224>] (dump_backtrace+0x0/0x110) from [<c0603610>] (dump_stack+0x18/0x1c)
[ 929.731628] r6:0000006b r5:bf09b72c r4:00000000 r3:c5c94000
[ 929.738098] [<c06035f8>] (dump_stack+0x0/0x1c) from [<c00a0d24>] (warn_slowpath_common+0x5c/0x6c)
[ 929.747894] [<c00a0cc8>] (warn_slowpath_common+0x0/0x6c) from [<c00a0d58>] (warn_slowpath_null+0x24/0x2c)
[ 929.758422] r8:00000100 r7:c5d0d764 r6:00011af4 r5:fffffffb r4:c5d0d260
[ 929.765869] r3:00000009
[ 929.769012] [<c00a0d34>] (warn_slowpath_null+0x0/0x2c) from [<bf09b72c>] (wl1271_cmd_send+0x38c/0x3e4 [wl12xx])
[ 929.780212] [<bf09b3a0>] (wl1271_cmd_send+0x0/0x3e4 [wl12xx]) from [<bf09c678>] (wl1271_cmd_template_set+0xdc/0x120 [wl12xx])
[ 929.792572] [<bf09c59c>] (wl1271_cmd_template_set+0x0/0x120 [wl12xx]) from [<bf09cb10>] (wl1271_cmd_build_probe_req+0xa4/0x104 [wl12xx])
[ 929.806549] [<bf09ca6c>] (wl1271_cmd_build_probe_req+0x0/0x104 [wl12xx]) from [<bf0acb08>] (wl1271_scan_send+0x210/0x43c [wl12xx])
[ 929.819244] r6:c5d0d586 r5:c5d0d260 r4:c633d800
[ 929.824737] [<bf0ac8f8>] (wl1271_scan_send+0x0/0x43c [wl12xx]) from [<bf0acd9c>] (wl1271_scan_stm+0x68/0x1f0 [wl12xx])
[ 929.836608] [<bf0acd34>] (wl1271_scan_stm+0x0/0x1f0 [wl12xx]) from [<bf0acfb4>] (wl1271_scan+0x90/0xc8 [wl12xx])
[ 929.847747] r6:c67bc800 r5:c5d0c380 r4:c5d0d260 r3:00001403
[ 929.854125] [<bf0acf24>] (wl1271_scan+0x0/0xc8 [wl12xx]) from [<bf0951b4>] (wl1271_op_hw_scan+0x98/0xb4 [wl12xx])
[ 929.865447] r5:c5d0d29c r4:c5d0d260
[ 929.869659] [<bf09511c>] (wl1271_op_hw_scan+0x0/0xb4 [wl12xx]) from [<bf03e9d0>] (__ieee80211_start_scan+0x16c/0x220 [mac80211])
[ 929.882354] [<bf03e864>] (__ieee80211_start_scan+0x0/0x220 [mac80211]) from [<bf03ec18>] (ieee80211_request_scan+0x30/0x4c [mac80211])
[ 929.895446] r7:c67bc200 r6:c5c04000 r5:c67bc200 r4:c5c04480
[ 929.902313] [<bf03ebe8>] (ieee80211_request_scan+0x0/0x4c [mac80211]) from [<bf04f7f4>] (ieee80211_scan+0x88/0xa0 [mac80211])
[ 929.914550] r5:c5d0c000 r4:c5c95c40
[ 929.919006] [<bf04f76c>] (ieee80211_scan+0x0/0xa0 [mac80211]) from [<bf019200>] (nl80211_trigger_scan+0x308/0x560 [cfg80211])
[ 929.931335] r4:c5c95c40 r3:bf04f76c
[ 929.935516] [<bf018ef8>] (nl80211_trigger_scan+0x0/0x560 [cfg80211]) from [<c04d7a24>] (genl_rcv_msg+0x1f4/0x234)
[ 929.946746] [<c04d7830>] (genl_rcv_msg+0x0/0x234) from [<c04d5f40>] (netlink_rcv_skb+0xc4/0xe0)
[ 929.956390] [<c04d5e7c>] (netlink_rcv_skb+0x0/0xe0) from [<c04d7828>] (genl_rcv+0x24/0x2c)
[ 929.965362] r6:c5ce2400 r5:000000d0 r4:c6359180 r3:00000000
[ 929.971710] [<c04d7804>] (genl_rcv+0x0/0x2c) from [<c04d5b4c>] (netlink_unicast+0x2cc/0x358)
[ 929.987396] r4:c78fe400 r3:00000000
[ 929.987426] [<c04d5880>] (netlink_unicast+0x0/0x358) from [<c04d6518>] (netlink_sendmsg+0x210/0x330)
[ 929.987426] [<c04d6308>] (netlink_sendmsg+0x0/0x330) from [<c04989d4>] (sock_sendmsg+0xa4/0xb8)
[ 929.987457] [<c0498930>] (sock_sendmsg+0x0/0xb8) from [<c049a504>] (__sys_sendmsg+0x2d8/0x2e8)
[ 929.987457] r7:c5c95ec8 r6:00000000 r5:c698f800 r4:c5c95f64
[ 929.987487] [<c049a22c>] (__sys_sendmsg+0x0/0x2e8) from [<c049a6f8>] (sys_sendmsg+0x44/0x70)
[ 929.987518] [<c049a6b4>] (sys_sendmsg+0x0/0x70) from [<c0054f00>] (ret_fast_syscall+0x0/0x30)
[ 929.987518] r6:000a9668 r5:00094c3c r4:00094c30
[ 929.987548] ---[ end trace 34d511f07d1f0098 ]---
[ 929.987579] wl1271: WARNING cmd set_template failed: -5
[ 929.987609] wl1271: ERROR PROBE request template failed
[ 929.988098] wl1271: Reading FW panic log
[ 929.988525] First address of fwlogger = 0x23fd
[ 929.988647] wl1271: ERROR sdio read failed (-22)
[ 929.988677] wl1271: Hardware recovery in progress. FW ver: Rev 7.3.7.0.79 pc: 0x0
[ 929.988677] wl1271: down
[ 929.988861] ieee80211 phy2: Hardware restart was requested
[ 930.282104] DSSCOMP: dsscomp_late_resume
[ 930.487518] wl1271: CMD_ROLE_ENABLE: 00000000: 00 05 00 c9 82 48 ed 2f
[ 930.495513] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000000: 00 00 00 00 19 00 00 00 00 00 00 00 00 00 00 00
[ 930.507781] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000010: 00 00 00 00 00 00 00 ec f6 00 0c 18 f8 fc 00 08
[ 930.519805] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000020: 10 f0 f8 00 0a 14 00 00 00 00 00 00 00 00 00 00
[ 930.530456] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 930.542663] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 930.554412] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000050: ee f4 f8 fe 05 ea f3 fa 01 06 e5 f1 fa 02 07 01
[ 930.565338] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000060: d9 01 80 00 1d 1f 22 26 27 29 25 1d 1f 22 26 27
[ 930.577453] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000070: 27 24 16 1d 1e 20 24 25 22 50 50 50 50 50 50 50
[ 930.588256] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000080: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[ 930.599304] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000090: 50 50 50 50 50 01 02 02 02 02 00 02 17 17 17 1a
[ 930.610046] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000a0: 16 17 1a 17 00 00 00 00 00 00 00 00 00 00 00 00
[ 930.620727] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000b0: 00 00 00 00 10 1e 2d 00 9a 01 ae 01 c2 01 cc 01
[ 930.631347] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000c0: db 01 db 01 d1 01 80 80 80 80 80 80 80 00 00 00
[ 930.642120] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000d0: 00 00 00 00 1c 1e 21 23 25 50 25 18 1e 21 23 25
[ 930.652770] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000e0: 50 24 16 1c 1e 20 20 50 1e 50 50 50 50 50 50 50
[ 930.663513] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000f0: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[ 930.674194] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000100: 50 50 50 50 50 50 50 50 50 50 50 50 01 02 02 02
[ 930.685089] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000110: 02 00 02 10 10 10 10 10 10 10 00 00 00 00 00 00
[ 930.695831] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 930.706512] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 930.717163] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000140: 00 00 00 00 00 00 00 00 00 00 00 10 10 10 10 10
[ 930.727874] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000150: 10 10 1e 2d
[ 930.767791] wl1271: RATE_MGMT: 00000000: ff 00 00 7d 00 20 00 08 00 10 a4 1f 05 04 0a 04
[ 930.776824] wl1271: RATE_MGMT: 00000010: 0d 0a 08 02 0c 00 00 00 00 00 00 00 00 00 00 00
[ 930.787139] wl1271: RATE_MGMT: 00000020: 00 00 00 00
[ 930.793273] wl1271: firmware booted (Rev 7.3.7.0.79)
[ 939.088989] wl1271: down
[ 939.643035] wl1271: CMD_ROLE_ENABLE: 00000000: 00 03 00 c9 82 48 ed 2f
[ 939.650482] wl1271: CMD_ROLE_ENABLE: 00000000: 01 00 00 c9 82 48 ed 2f
[ 939.658386] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000000: 00 00 00 00 19 00 00 00 00 00 00 00 00 00 00 00
[ 939.669158] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000010: 00 00 00 00 00 00 00 ec f6 00 0c 18 f8 fc 00 08
[ 939.680297] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000020: 10 f0 f8 00 0a 14 00 00 00 00 00 00 00 00 00 00
[ 939.691284] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 939.702575] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 939.713836] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000050: ee f4 f8 fe 05 ea f3 fa 01 06 e5 f1 fa 02 07 01
[ 939.724670] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000060: d9 01 80 00 1d 1f 22 26 27 29 25 1d 1f 22 26 27
[ 939.735504] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000070: 27 24 16 1d 1e 20 24 25 22 50 50 50 50 50 50 50
[ 939.746307] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000080: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[ 939.757049] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000090: 50 50 50 50 50 01 02 02 02 02 00 02 17 17 17 1a
[ 939.767822] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000a0: 16 17 1a 17 00 00 00 00 00 00 00 00 00 00 00 00
[ 939.778717] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000b0: 00 00 00 00 10 1e 2d 00 9a 01 ae 01 c2 01 cc 01
[ 939.789520] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000c0: db 01 db 01 d1 01 80 80 80 80 80 80 80 00 00 00
[ 939.800598] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000d0: 00 00 00 00 1c 1e 21 23 25 50 25 18 1e 21 23 25
[ 939.811370] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000e0: 50 24 16 1c 1e 20 20 50 1e 50 50 50 50 50 50 50
[ 939.822204] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 000000f0: 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50
[ 939.833038] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000100: 50 50 50 50 50 50 50 50 50 50 50 50 01 02 02 02
[ 939.843902] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000110: 02 00 02 10 10 10 10 10 10 10 00 00 00 00 00 00
[ 939.854705] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 939.865539] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 939.876373] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000140: 00 00 00 00 00 00 00 00 00 00 00 10 10 10 10 10
[ 939.887237] wl1271: TEST_CMD_INI_FILE_RADIO_PARAM: 00000150: 10 10 1e 2d
[ 939.963989] wl1271: RATE_MGMT: 00000000: ff 00 00 7d 00 20 00 08 00 10 a4 1f 05 04 0a 04
[ 939.973083] wl1271: RATE_MGMT: 00000010: 0d 0a 08 02 0c 00 00 00 00 00 00 00 00 00 00 00
[ 939.985931] wl1271: RATE_MGMT: 00000020: 00 00 00 00
[ 939.993927] wl1271: firmware booted (Rev 7.3.7.0.79)
[ 940.004638] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 940.235565] wl1271: CMD_ROLE_START: 00000000: 00 00 06 00 01 00 00 00 00 00 00 00 00 00 00 00
[ 940.247253] wl1271: CMD_ROLE_START: 00000010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 940.258789] wl1271: CMD_ROLE_START: 00000020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 940.268218] wl1271: CMD_ROLE_START: 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 940.399902] wl1271: down
[ 962.064147] SysRq : Emergency Remount R/O
[ 962.096954] Emergency Remount complete
[ 962.369659] PVR: PVRSRVDriverShutdown(pDevice=c78a4800)
[ 962.375610] PVR: SysSystemPrePowerState: Entering state D3
[ 962.382019] PVR: Uninstalling device LISR on IRQ 53 with cookie c790a500
[ 962.393157] PVR: DisableSystemClocks: Disabling System Clocks
[ 962.464447] Disabling non-boot CPUs ...
[ 962.490631] CPU1: shutdown
[ 962.494781] Power down.
Texas Instruments X-Loader 1.41 (Feb 9 2012 - 10:18:02)
OMAP4460: 1.5 GHz capable SOM
mmc read: Invalid size
Starting OS Bootloader from MMC/SD1 ...
did anybody meet this problem, where may be wrong , please teach me.
