Part Number: AM625
Other Parts Discussed in Thread: TPS65912, PCM3060, PCM3168A, SYSCONFIG
Hello Team,
I am using the image tisdk-default-image-rt-beagleplay-ti-12.00.00.07.04.rootfs.wic and can successfully boot my BeaglePlay board. I believe UART, Ethernet, and I2C interfaces are enabled and working.
However, SPI is not enabled. It is not listed under /dev, and upon checking the DTB file, I found that the SPI nodes appear to be in a disabled state.
I attempted to convert the DTB to DTS and modify it to enable SPI, but I was unable to complete the process successfully.
Could you please suggest how to enable SPI support in this image?
Thanks & Regards
Aparna C Nair
