Other Parts Discussed in Thread: OMAPL138
I have 2 OMAPL138 on our prototype.
I'm able to load flash and boot only one of them.
For the other one, I have
1) Able to do flashing both boot and app images similar to the 1st chip
2) Able to run BOOT code under debugger and it loads and runs APP out of Flash
3) But NOT able to boot by itself, even with correct setting boot pins [7:0] 0000-0110 as the 1st chip
After power up, I see chip select activated in the 1st SPI flash, but not the 2nd one. Needless to say that the 2nd SPI flash chip select is activated if I use Debugger to run BOOT code to load and run APP code from 2nd SPI flash
You have any idea for me to look at ?
~Duy-Ky
