Part Number: AM623
Other Parts Discussed in Thread: SK-AM62, SK-AM62B, TPS65219
We are currently working on a custom board using the AM6234 processor. We are experiencing issues when attempting to boot from an SD card using DDR50 mode.
While the system boots successfully in High Speed (HS) mode, switching to DDR50 results in the initialization errors shown in the log below.
Hardware Configurations & Observations:
Voltage: We have confirmed that the SD card I/O voltage successfully switches and drops to 1.8V for the higher speed modes.
Schematic: The interface circuitry for the SD card signals is designed following the AM62x EVM (SK-AM62) reference.
Status: High Speed mode is stable, but DDR50 fails consistently.
Error Log:
U-Boot SPL 2025.01-gd2a72467939e-dirty (Mar 26 2026 - 16:32:58 +0800) SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)') Changed A53 CPU frequency to 1250000000Hz (T grade) in DT SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Authentication passed Authentication passed Authentication passed Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.13.0(release):v2.13.0-240-gd90bb650fe-dirty NOTICE: BL31: Built : 21:37:18, Jun 23 2025 U-Boot SPL 2025.01-gd2a72467939e-dirty (Mar 26 2026 - 16:36:07 +0800) SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)') SPL initial stack usage: 2032 bytes Trying to boot from MMC2 Authentication passed Authentication passed U-Boot 2025.01-gd2a72467939e-dirty (Mar 26 2026 - 16:36:07 +0800) SoC: AM62X SR1.0 HS-FS Model: Texas Instruments AM625 SK DRAM: 2 GiB Core: 83 devices, 32 uclasses, devicetree: separate MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from SPIFlash... SF: Detected w25q64dw with page size 256 Bytes, erase size 4 KiB, total 8 MiB OK In: serial Out: serial Err: serial Net: Ethaddr Address in environment is 00:19:15:f4:5c:4e eth0: ethernet@8000000port@1 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 574 bytes read in 1 ms (560.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... 19511808 bytes read in 810 ms (23 MiB/s) 62679 bytes read in 6 ms (10 MiB/s) Working FDT set to 88000000 ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Working FDT set to 88000000 Loading Device Tree to 000000008feed000, end 000000008fffffff ... OK Working FDT set to 8feed000 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.12.35-tecom+ (tecom@ubuntu-2204) (aarch64-oe-linux-gcc (GCC) 13.4.0, GNU ld (GNU Binutils) 2.42.0.20240723) #16 SMP PREEMPT_RT Thu Jan 22 14:48:57 CST 2026 [ 0.000000] Machine model: Texas Instruments AM625 SK [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] printk: legacy bootconsole [ns16550a0] enabled [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000f7600000, size 128 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x00000000f7600000..0x00000000ff5fffff (131072 KiB) map reusable linux,cma [ 0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000 [ 0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000 [ 0.000000] OF: reserved mem: 0x00000000ff700000..0x00000000ffffffff (9216 KiB) nomap non-reusable framebuffer@ff700000 [ 0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB [ 0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB [ 0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000 [ 0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool [ 0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000080000000-0x000000008007ffff] [ 0.000000] node 0: [mem 0x0000000080080000-0x000000009c7fffff] [ 0.000000] node 0: [mem 0x000000009c800000-0x000000009e6fffff] [ 0.000000] node 0: [mem 0x000000009e700000-0x000000009e7fffff] [ 0.000000] node 0: [mem 0x000000009e800000-0x000000009fffffff] [ 0.000000] node 0: [mem 0x00000000a0000000-0x00000000ff6fffff] [ 0.000000] node 0: [mem 0x00000000ff700000-0x00000000ffffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.5 [ 0.000000] percpu: Embedded 23 pages/cpu s54704 r8192 d31312 u94208 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) lot=26D1 product=SDX500P root=PARTUUID=076c4a2a-02 rw rootfstype=ext4 rootwait [ 0.000000] Unknown kernel command line parameters "mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) lot=26D1 product=SDX500P", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 524288 [ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off [ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 2MB [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x00000000f5100000-0x00000000f5300000] (2MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4. [ 0.000000] rcu: RCU_SOFTIRQ processing moved to rcuc kthreads. [ 0.000000] No expedited grace period (rcu_normal_after_boot). [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] Root IRQ handler: 0xffff8000800100bc [ 0.000000] GICv3: GICv3 features: 16 PPIs [ 0.000000] GICv3: GICD_CTRL.DS=0, SCR_EL3.FIQ=1 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19 [ 0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x0000000080440000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000 [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000000] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.000386] Console: colour dummy device 80x25 [ 0.000453] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=200000) [ 0.000471] pid_max: default: 32768 minimum: 301 [ 0.000558] LSM: initializing lsm=capability [ 0.000760] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.000791] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear) [ 0.003282] rcu: Hierarchical SRCU implementation. [ 0.003293] rcu: Max phase no-delay instances is 400. [ 0.073811] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.095376] EFI services will not be available. [ 0.153728] smp: Bringing up secondary CPUs ... [ 0.260767] Detected VIPT I-cache on CPU1 [ 0.260889] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.260913] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000 [ 0.260976] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.429474] Detected VIPT I-cache on CPU2 [ 0.429567] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000 [ 0.429589] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000 [ 0.429634] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.552433] Detected VIPT I-cache on CPU3 [ 0.552524] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000 [ 0.552538] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000 [ 0.552582] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.567226] smp: Brought up 1 node, 4 CPUs [ 0.567233] SMP: Total of 4 processors activated. [ 0.567236] CPU: All CPU(s) started at EL2 [ 0.567240] CPU features: detected: 32-bit EL0 Support [ 0.567244] CPU features: detected: CRC32 instructions [ 0.625347] alternatives: applying system-wide alternatives [ 0.646877] Memory: 1832072K/2097152K available (11648K kernel code, 1454K rwdata, 3096K rodata, 2752K init, 635K bss, 125520K reserved, 131072K cma-reserved) [ 0.655426] devtmpfs: initialized [ 0.668074] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns [ 0.668112] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.674528] 27824 pages in range for non-PLT usage [ 0.674557] 519344 pages in range for PLT usage [ 0.674939] pinctrl core: initialized pinctrl subsystem [ 0.675791] DMI not present or invalid. [ 0.676642] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.678411] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations [ 0.678690] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.679016] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.679536] audit: initializing netlink subsys (disabled) [ 0.679832] audit: type=2000 audit(0.677:1): state=initialized audit_enabled=0 res=1 [ 0.680561] thermal_sys: Registered thermal governor 'step_wise' [ 0.680839] ASID allocator initialised with 65536 entries [ 0.686499] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000 [ 0.686619] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000 [ 0.686725] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector [ 0.692404] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000 [ 0.693635] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector [ 0.699231] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages [ 0.699243] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page [ 0.699248] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages [ 0.699257] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page [ 0.699261] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages [ 0.699264] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page [ 0.699268] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages [ 0.699271] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page [ 1.072078] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected [ 1.074768] iommu: Default domain type: Translated [ 1.074792] iommu: DMA domain TLB invalidation policy: strict mode [ 1.075480] SCSI subsystem initialized [ 1.076009] usbcore: registered new interface driver usbfs [ 1.076056] usbcore: registered new interface driver hub [ 1.076091] usbcore: registered new device driver usb [ 1.076741] pps_core: LinuxPPS API ver. 1 registered [ 1.076747] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.076766] PTP clock support registered [ 1.076816] EDAC MC: Ver: 3.0.0 [ 1.077278] scmi_core: SCMI protocol bus registered [ 1.077704] FPGA manager framework [ 1.077842] Advanced Linux Sound Architecture Driver Initialized. [ 1.081416] vgaarb: loaded [ 1.081860] clocksource: Switched to clocksource arch_sys_counter [ 1.082370] VFS: Disk quotas dquot_6.6.0 [ 1.082451] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.091288] NET: Registered PF_INET protocol family [ 1.091614] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.093313] tcp_listen_portaddr_hash hash table entries: 1024 (order: 3, 40960 bytes, linear) [ 1.093408] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 1.093421] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 1.093711] TCP bind hash table entries: 16384 (order: 8, 1310720 bytes, linear) [ 1.095545] TCP: Hash tables configured (established 16384 bind 16384) [ 1.095843] UDP hash table entries: 1024 (order: 4, 98304 bytes, linear) [ 1.096115] UDP-Lite hash table entries: 1024 (order: 4, 98304 bytes, linear) [ 1.096560] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 1.097280] RPC: Registered named UNIX socket transport module. [ 1.097289] RPC: Registered udp transport module. [ 1.097292] RPC: Registered tcp transport module. [ 1.097294] RPC: Registered tcp-with-tls transport module. [ 1.097297] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.097322] PCI: CLS 0 bytes, default 64 [ 1.099072] Initialise system trusted keyrings [ 1.099362] workingset: timestamp_bits=62 max_order=19 bucket_order=0 [ 1.099778] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.100200] NFS: Registering the id_resolver key type [ 1.100241] Key type id_resolver registered [ 1.100244] Key type id_legacy registered [ 1.100266] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.100278] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 1.100304] ntfs3: Enabled Linux POSIX ACLs support [ 1.100306] ntfs3: Warning: Activated 64 bits per cluster. Windows does not support this [ 1.151004] Key type asymmetric registered [ 1.151023] Asymmetric key parser 'x509' registered [ 1.151128] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 1.151139] io scheduler mq-deadline registered [ 1.151143] io scheduler kyber registered [ 1.151181] io scheduler bfq registered [ 1.155649] pinctrl-single 4084000.pinctrl: 34 pins, size 136 [ 1.156507] pinctrl-single f4000.pinctrl: 171 pins, size 684 [ 1.166485] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.180036] loop: module loaded [ 1.181538] megasas: 07.727.03.00-rc1 [ 1.186939] tun: Universal TUN/TAP device driver, 1.6 [ 1.187753] PPP generic driver version 2.4.2 [ 1.188112] PPP BSD Compression module registered [ 1.188119] PPP Deflate Compression module registered [ 1.188163] PPP MPPE Compression module registered [ 1.188168] NET: Registered PF_PPPOX protocol family [ 1.188642] VFIO - User Level meta-driver version: 0.3 [ 1.190302] usbcore: registered new interface driver usb-storage [ 1.191127] i2c_dev: i2c /dev entries driver [ 1.191967] sdhci: Secure Digital Host Controller Interface driver [ 1.191971] sdhci: Copyright(c) Pierre Ossman [ 1.192217] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.192999] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping .... [ 1.194230] usbcore: registered new interface driver usbhid [ 1.194237] usbhid: USB HID core driver [ 1.195402] optee: probing for conduit method. [ 1.195453] optee: revision 4.6 (71785645fa6ce42d) [ 1.195998] optee: dynamic shared memory is enabled [ 1.196934] optee: initialized driver [ 1.197026] random: crng init done [ 1.201164] xt_time: kernel timezone is -0000 [ 1.201446] NET: Registered PF_PACKET protocol family [ 1.201544] Key type dns_resolver registered [ 1.213113] Loading compiled-in X.509 certificates [ 1.229988] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000b '11.1.2--v11.01.02 (Fancy Rat)') [ 1.298108] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000 [ 1.298226] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz [ 1.300289] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz [ 1.301687] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz [ 1.302075] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created [ 1.302404] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created [ 1.304227] ti-udma 485c0100.dma-controller: Number of rings: 82 [ 1.307955] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18) [ 1.311784] ti-udma 485c0000.dma-controller: Number of rings: 150 [ 1.318723] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15) [ 1.322909] printk: legacy console [ttyS2] disabled [ 1.596105] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 237, base_baud = 3000000) is a 8250 [ 1.605021] printk: legacy console [ttyS2] enabled [ 1.605021] printk: legacy console [ttyS2] enabled [ 1.605027] printk: legacy bootconsole [ns16550a0] disabled [ 1.605027] printk: legacy bootconsole [ns16550a0] disabled [ 1.631544] 7 fixed-partitions partitions found on MTD device fc40000.spi.0 [ 1.631565] Creating 7 MTD partitions on "fc40000.spi.0": [ 1.631572] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.634230] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.635945] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.637551] 0x000000680000-0x0000006c0000 : "ospi.env" [ 1.639209] 0x0000006c0000-0x000000700000 : "ospi.env.backup" [ 1.640962] 0x000000800000-0x000003fc0000 : "ospi.rootfs" [ 1.640975] mtd: partition "ospi.rootfs" is out of reach -- disabled [ 1.642561] 0x000003fc0000-0x000004000000 : "ospi.phypattern" [ 1.642579] mtd: partition "ospi.phypattern" is out of reach -- disabled [ 1.644380] cadence-qspi fc40000.spi: Pattern not found. Skipping calibration. [ 1.645496] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006 [ 1.646631] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.679872] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 1.681122] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5 [ 1.681136] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512, Policers 32 [ 1.682345] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1 [ 1.762422] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19 [ 1.769502] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000 [ 1.769692] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector [ 1.777595] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 1.777632] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 1.777787] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports [ 1.777794] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000808020000010 [ 1.778074] xhci-hcd xhci-hcd.0.auto: irq 252, io mem 0x31100000 [ 1.779233] hub 1-0:1.0: USB hub found [ 1.779288] hub 1-0:1.0: 1 port detected [ 1.794686] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode [ 1.827870] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000 [ 2.016003] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver RTL8211F Gigabit Ethernet [ 2.016025] davinci_mdio 8000f00.mdio: phy[2]: device 8000f00.mdio:02, driver RTL8211F Gigabit Ethernet [ 2.017444] clk: Disabling unused clocks [ 2.025887] PM: genpd: Disabling unused power domains [ 2.026007] ALSA device list: [ 2.026014] No soundcards found. [ 2.026774] mmc1: CQHCI version 5.10 [ 2.076555] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit [ 2.077050] Waiting for root device PARTUUID=076c4a2a-02... [ 2.126188] mmc1: error -110 whilst initialising SD card [ 2.503345] mmc1: error -110 whilst initialising SD card [ 2.885967] mmc1: error -110 whilst initialising SD card [ 3.285744] mmc1: error -110 whilst initialising SD card
Questions:
Are there specific timing requirements or tuning steps required for DDR50 on the AM6234 that differ from the EVM defaults?
Does the Linux device tree or U-Boot configuration require additional properties (e.g., specific itapdly or otapdly values) to stabilize the DDR50 connection?Or are there other areas that need adjustment?
Any guidance on troubleshooting this timing or signal integrity issue would be greatly appreciated.
