AM623: eMMC configuration and initialization sequence
Part Number: AM623
I list eMMC dts from all SDK to below table. it was stable/not changing untill SDK11.01.
  sdk8.3 sdk8.04 sdk8.05 sdk8.06 sdk9.0 sdk9.1 sdk9.2.1.9 sdk9.2.1.10 sdk10.00 sdk10.1 sdk11.00 sdk11.01 sdk11.02 sdk12.00
eMMC     sdhci0: mmc@fa10000 {
        compatible = "ti,am62-sdhci";
        reg = <0x00 0xfa10000 0x00 0x260>, <0x00 0xfa18000 0x00 0x134>;
        interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
        power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>;
        clocks = <&k3_clks 57 5>, <&k3_clks 57 6>;
        clock-names = "clk_ahb", "clk_xin";
        assigned-clocks = <&k3_clks 57 6>;
        assigned-clock-parents = <&k3_clks 57 8>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        ti,trm-icp = <0x2>;
        bus-width = <8>;
        ti,clkbuf-sel = <0x7>;
        ti,otap-del-sel-legacy = <0x0>;
        ti,otap-del-sel-mmc-hs = <0x0>;
        ti,otap-del-sel-ddr52 = <0x9>;
        ti,otap-del-sel-hs200 = <0x6>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        ti,trm-icp = <0x2>;
        bus-width = <8>;
        ti,otap-del-sel-ddr52 = <0x5>;
        ti,otap-del-sel-hs200 = <0x5>;
        ti,itap-del-sel-legacy = <0xa>;
        ti,itap-del-sel-mmc-hs = <0x1>;
        reg = <0x00 0x0fa10000 0x00 0x1000>, <0x00 0x0fa18000 0x00 0x400>;
        bus-width = <8>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        status = "disabled";
        bus-width = <8>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        bus-width = <8>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        bus-width = <8>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        ti,itap-del-sel-legacy = <0x0>;
        ti,itap-del-sel-mmc-hs = <0x0>;
        bus-width = <8>;
        mmc-ddr-1_8v;
        mmc-hs200-1_8v;
        bus-width = <8>;
        mmc-hs200-1_8v;
        bus-width = <8>;
        mmc-hs200-1_8v;
        bus-width = <8>;
        mmc-hs200-1_8v;
Questions:
#1.  mmc-ddr-1_8v; is removed until SDK11.01, is it for DDR50 mode?
#2.  The clock items are removed after SDK10.1, what is the impacts as it exists in SDK9.2.
#3.    ti,otap-del-sel-ddr52 = <0x5>; is removed after SDK10.0.  will DDR52 mode be configured during initialization if it exist?
#4. When initialize eMMC, will the driver configure it from low to higher speed one by one according to otap/itap paramter items? or get the highest capability from eMMC, configure to the highest speed in one step?
If customer keeps on old SDK8.3 and SDK9.2, should they change the dts to that of SDK12 to remove mmc-ddr-1_8v, clock item, and  ti,otap-del-sel-ddr52 = <0x5>; will that work?
    Yes, as per the following commit.
    git.ti.com/.../
    Please check if the commit message is sufficient
    git.ti.com/.../
    No, if there is a higher speed mode available.
    It configures in the highest mode possible by checking the card capabilities and the DTS properties.
    I am not sure about the clock changes but removing the DDR50 related properties should not cause issues.
  • It configures in the highest mode possible by checking the card capabilities and the DTS properties.
    If the eMMC supports HS200, no matter mmc-ddr-1_8v and ti,otap-del-sel-ddr52 = <0x5>;exist or not, it won't matter. and won't have 50MHz eMMC_CLK stage before entering HS200 mode?
    BTW, what is the mode configured by ROM code stage? is it 25MHz legacy SDR mode?
  • and won't have 50MHz eMMC_CLK stage before entering HS200 mode?
    The eMMC HS200 initialization sequence doesn't involve the DDR50 speed mode.
    I will have to check.
  • The eMMC HS200 initialization sequence doesn't involve the DDR50 speed mode.
    But customer captured all frequency during booting up with SDK9.2.1.09: 400K---25M---400K---25M---50M---400K---50M---200M
    below is the 50MHz DDR stage.
    uboot k3-am62-main.dtsi
    		bus-width = <8>;
    		mmc-ddr-1_8v;
    		mmc-hs200-1_8v;
    Seems it is negotiating from low to high clock frequency across dts parameter. And asked AI got same conclusion.
  • The HS400 mode does involve switching to DDR but not HS200.
    git.ti.com/.../mmc.c
  • From this thread, the clock frequency changing procedure is answered.
     AM625: eMMC clock frequency changing during startup
    400K(tiboot3)---25M---400K(tispl)---25M---50M---400K(kernel)---50M---200M
    As used falcon boot, there is not UBOOT stage, and as HS200 is not stable, so removed HS200 from UBOOT dts, then configured to highest parameter DDR52 mode in tispl.
