Other Parts Discussed in Thread: TVP5146
hi
im using dm365 and tvp5146 decoder with ntsc input
here is full info
/ # gst-launch -e v4l2src input-src=composite always-copy=false num-buffers=1000
! 'video/x-raw-yuv,format=(fourcc)NV12, width=640, height=480,pitch=736' ! queu
e ! dmaiaccel ! dmaienc_h264 encodingpreset=2 ratecontrol=4 ! qtmux ! filesink l
ocation=kk.mp4 --gst-debug=v4l2:5
(gst-launch-0.10:1156): GStreamer-CRITICAL **: gst_debug_log_valist: assertion `category != NULL' failed
Setting pipeline to PAUSED ...
davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
0:00:01.60658684vpfe-capture vpfe-capture: IPIPE Chained
2 1156pfe-capture vpfe-capture: Resizer present
0m 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/Leopard: switch to tvp5146 SD video input
v4l2_calls.c:501:gst_v4l2_open:<tvp514x 1-005d: tvp5146 (Version - 0x03) found at 0xba (DaVinci I2C adapter)
v4l2src0> Trying to open device /dev/video0
0:00:01.618260550 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:83:gst_v4l2_get_capabilities:<v4l2src0> getting capabilities
0:00:01.619126300 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:91:gst_v4l2_get_capabilities:<v4l2src0> driver: 'vpfe-capture'
0:00:01.619869925 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:92:gst_v4l2_get_capabilities:<v4l2src0> card: 'DM365 Leopard'
0:00:01.620570384 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:93:gst_v4l2_get_capabilities:<v4l2src0> bus_info: 'VPFE'
0:00:01.621257384 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:94:gst_v4l2_get_capabilities:<v4l2src0> version: 00000001
0:00:01.621890050 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:95:gst_v4l2_get_capabilities:<v4l2src0> capabilites: 04000001
0:00:01.622609259 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:127:gst_v4l2_fill_lists:<v4l2src0> getting enumerations
0:00:01.623220217 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:130:gst_v4l2_fill_lists:<v4l2src0> channels
0:00:01.624037050 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:964:gst_v4l2_set_input:<v4l2src0> trying to set input to 0
0:00:02.270073377 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:938:gst_v4l2_get_input:<v4l2src0> trying to get input
0:00:02.270892252 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:948:gst_v4l2_get_input:<v4l2src0> input: 0
0:00:02.271584461 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:198:gst_v4l2_fill_lists:<v4l2src0> index: 0
0:00:02.272272211 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:199:gst_v4l2_fill_lists:<v4l2src0> name: 'Composite'
0:00:02.272908752 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:200:gst_v4l2_fill_lists:<v4l2src0> type: 00000002
0:00:02.273592544 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:201:gst_v4l2_fill_lists:<v4l2src0> audioset: 00000000
0:00:02.274228585 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:202:gst_v4l2_fill_lists:<v4l2src0> std: 000000000000b0ff
0:00:02.274936044 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:203:gst_v4l2_fill_lists:<v4l2src0> status: 00000000
0:00:02.276964419 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:246:gst_v4l2_fill_lists:<v4l2src0> norms
0:00:02.277687627 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'NTSC', fps: 30000 / 1001
0:00:02.279232586 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'NTSC-M', fps: 30000 / 1001
0:00:02.280219919 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'NTSC-M-JP', fps: 30000 / 1001
0:00:02.281142003 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'NTSC-M-KR', fps: 30000 / 1001
0:00:02.282096836 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'PAL', fps: 25 / 1
0:00:02.283027336 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'PAL-BG', fps: 25 / 1
0:00:02.283937878 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'PAL-H', fps: 25 / 1
0:00:02.284882169 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'PAL-I', fps: 25 / 1
0:00:02.285820919 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:274:gst_v4l2_fill_lists:<v4l2src0> 'PAL-DK', fps: 25 / 1
0:00:02.286729086 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:287:gst_v4l2_fill_lists:<v4l2src0> controls+menus
0:00:02.287384669 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980900
0:00:02.288124794 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:388:gst_v4l2_fill_lists:<v4l2src0> Adding ControlID Brightness (980900)
0:00:02.290174919 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980901
0:00:02.290910211 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:388:gst_v4l2_fill_lists:<v4l2src0> Adding ControlID Contrast (980901)
0:00:02.624492713 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980902
0:00:02.625227588 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:388:gst_v4l2_fill_lists:<v4l2src0> Adding ControlID Saturation (980902)
0:00:02.626099046 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980903
0:00:02.626865254 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:388:gst_v4l2_fill_lists:<v4l2src0> Adding ControlID Hue (980903)
0:00:02.627667796 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980904
0:00:02.628408379 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980904
0:00:02.629249630 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980905
0:00:02.630002796 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980905
0:00:02.630658963 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980906
0:00:02.631400504 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980906
0:00:02.632044463 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980907
0:00:02.632781338 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980907
0:00:02.633428004 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980908
0:00:02.634156129 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980908
0:00:02.634808129 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980909
0:00:02.635548838 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980909
0:00:02.636199796 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098090a
0:00:02.636932921 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098090a
0:00:02.637584171 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098090b
0:00:02.638352421 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098090b
0:00:02.639175421 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098090c
0:00:02.972466802 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098090c
0:00:02.973137593 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098090d
0:00:02.973881635 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098090d
0:00:02.974528468 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098090e
0:00:02.975267718 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098090e
0:00:02.975915593 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098090f
0:00:02.976653301 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098090f
0:00:02.977304885 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980910
0:00:02.978037676 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980910
0:00:02.978694551 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980911
0:00:02.979612802 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980911
0:00:02.980265302 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980912
0:00:02.981016052 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:388:gst_v4l2_fill_lists:<v4l2src0> Adding ControlID Gain, Automatic (980912)
0:00:02.981872843 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980913
0:00:02.982585843 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980913
0:00:02.983293093 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980914
0:00:02.983983552 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980914
0:00:02.984680427 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980915
0:00:02.985374676 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980915
0:00:02.986079760 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980916
0:00:02.986776010 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980916
0:00:03.319257802 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980917
0:00:03.319977344 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980917
0:00:03.320709677 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980918
0:00:03.321405719 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980918
0:00:03.322116552 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980919
0:00:03.322850135 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980919
0:00:03.323564760 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098091a
0:00:03.324251844 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098091a
0:00:03.324969385 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098091b
0:00:03.325705010 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098091b
0:00:03.326384052 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098091c
0:00:03.327123219 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098091c
0:00:03.327789719 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098091d
0:00:03.328525427 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098091d
0:00:03.329368886 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098091e
0:00:03.330121386 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098091e
0:00:03.330778927 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 0098091f
0:00:03.331510261 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 0098091f
0:00:03.332170677 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980920
0:00:03.332904802 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980920
0:00:03.333567052 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:312:gst_v4l2_fill_lists:<v4l2src0> checking control 00980921
0:00:03.665833300 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:318:gst_v4l2_fill_lists:<v4l2src0> skipping control 00980921
0:00:03.666512509 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:297:gst_v4l2_fill_lists:<v4l2src0> checking private CIDs
0:00:03.667176633 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:456:gst_v4l2_fill_lists:<v4l2src0> done
0:00:03.667757008 1156 0x15018 INFO v4l2 ../../../src/sys/v4l2/v4l2_calls.c:560:gst_v4l2_open:<v4l2src0> Opened device 'DM365 Leopard' (/dev/video0) successfully
0:00:03.668706967 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:664:gst_v4l2_get_norm:<v4l2src0> getting norm
0:00:03.880084262 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:728:gst_v4l2_set_norm:<v4l2src0> trying to set norm to b000
0:00:03.881646761 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:938:gst_v4l2_get_input:<v4l2src0> trying to get input
0:00:03.882388136 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:948:gst_v4l2_get_input:<v4l2src0> input: 0
0:00:03.897258178 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:920:gst_v4l2_object_fill_format_list:<v4l2src0> getting src format enumerations
0:00:03.897998428 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:938:gst_v4l2_object_fill_format_list:<v4l2src0> index: 0
0:00:03.898707470 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:939:gst_v4l2_object_fill_format_list:<v4l2src0> type: 1
0:00:03.901582803 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:940:gst_v4l2_object_fill_format_list:<v4l2src0> flags: 00000000
0:00:03.902257886 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:942:gst_v4l2_object_fill_format_list:<v4l2src0> description: 'YCbCr 4:2:2 Interleaved UYVY'
0:00:03.902980678 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:944:gst_v4l2_object_fill_format_list:<v4l2src0> pixelformat: UYVY
0:00:03.903807303 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:938:gst_v4l2_object_fill_format_list:<v4l2src0> index: 1
0:00:03.904521053 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:939:gst_v4l2_object_fill_format_list:<v4l2src0> type: 1
0:00:03.905172636 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:940:gst_v4l2_object_fill_format_list:<v4l2src0> flags: 00000000
0:00:03.905869636 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:942:gst_v4l2_object_fill_format_list:<v4l2src0> description: 'Y/CbCr 4:2:0 - Semi planar'
0:00:03.906586345 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:944:gst_v4l2_object_fill_format_list:<v4l2src0> pixelformat: NV12
0:00:03.907461678 1156 0x15018 INFO v4l2 ../../../src/sys/v4l2/gstv4l2object.c:957:gst_v4l2_object_fill_format_list:<v4l2src0> got 2 format(s):
0:00:03.908108761 1156 0x15018 INFO v4l2 ../../../src/sys/v4l2/gstv4l2object.c:963:gst_v4l2_object_fill_format_list:<v4l2src0> UYVY
0:00:03.908888261 1156 0x15018 INFO v4l2 ../../../src/sys/v4l2/gstv4l2object.c:963:gst_v4l2_object_fill_format_list:<v4l2src0> NV12
0:00:03.910168887 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1656:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Enumerating frame sizes
0:00:03.911126053 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1767:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Failed to enumerate frame sizes for pixelformat UYVY (Invalid argument)
0:00:03.911914137 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1874:gst_v4l2_object_get_nearest_size:<v4l2src0> getting nearest size to 1x1 with format UYVY
0:00:03.912798137 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1963:gst_v4l2_object_get_nearest_size:<v4l2src0> got nearest size 16x2
0:00:03.913502553 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1874:gst_v4l2_object_get_nearest_size:<v4l2src0> getting nearest size to 32768x32768 with format UYVY
0:00:04.247016719 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1963:gst_v4l2_object_get_nearest_size:<v4l2src0> got nearest size 2176x2196
0:00:04.248361177 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1656:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Enumerating frame sizes
0:00:04.249463511 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1767:gst_v4l2_object_probe_caps_for_format:<v4l2src0> Failed to enumerate frame sizes for pixelformat NV12 (Invalid argument)
0:00:04.250255511 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1874:gst_v4l2_object_get_nearest_size:<v4l2src0> getting nearest size to 1x1 with format NV12
0:00:04.251126886 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1963:gst_v4l2_object_get_nearest_size:<v4l2src0> got nearest size 32x2
0:00:04.251821469 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1874:gst_v4l2_object_get_nearest_size:<v4l2src0> getting nearest size to 32768x32768 with format NV12
0:00:04.252729719 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1963:gst_v4l2_object_get_nearest_size:<v4l2src0> got nearest size 2176x2196
0:00:04.258296219 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2object.c:1981:gst_v4l2_object_set_format:<v4l2src0> Setting format to 640x480, format NV12
0:00:04.262001428 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:333:gst_v4l2_buffer_pool_new:<v4l2src0> STREAMING, requesting 2 MMAP buffers
0:00:04.262781470 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:343:gst_v4l2_buffer_pool_new:<v4l2src0> count: 3
0:00:04.263495345 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:344:gst_v4l2_buffer_pool_new:<v4l2src0> type: 1
0:00:04.264140136 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:345:gst_v4l2_buffer_pool_new:<v4l2src0> memory: 1
0:00:04.264815594 1156 0x15018 WARN v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:351:gst_v4l2_buffer_pool_new:<v4l2src0> using 3 buffers instead
0:00:04.265901844 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:149:gst_v4l2_buffer_new:<v4l2src0> creating buffer 0, 0xad0b8 in pool 0xc62e8
0:00:04.266796011 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:161:gst_v4l2_buffer_new:<v4l2src0> index: 0
0:00:04.267514886 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:162:gst_v4l2_buffer_new:<v4l2src0> type: 1
0:00:04.268157886 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:163:gst_v4l2_buffer_new:<v4l2src0> bytesused: 0
0:00:04.268840844 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:164:gst_v4l2_buffer_new:<v4l2src0> flags: 00000000
0:00:04.269688012 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:165:gst_v4l2_buffer_new:<v4l2src0> field: 0
0:00:04.270363470 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:166:gst_v4l2_buffer_new:<v4l2src0> memory: 1
0:00:04.603310844 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:169:gst_v4l2_buffer_new:<v4l2src0> MMAP offset: 0
0:00:04.603980636 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:170:gst_v4l2_buffer_new:<v4l2src0> length: 460800
0:00:04.604671177 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:171:gst_v4l2_buffer_new:<v4l2src0> input: 0
0:00:04.606760886 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:149:gst_v4l2_buffer_new:<v4l2src0> creating buffer 1, 0xad158 in pool 0xc62e8
0:00:04.607693052 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:161:gst_v4l2_buffer_new:<v4l2src0> index: 1
0:00:04.608371052 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:162:gst_v4l2_buffer_new:<v4l2src0> type: 1
0:00:04.609256927 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:163:gst_v4l2_buffer_new:<v4l2src0> bytesused: 0
0:00:04.609976136 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:164:gst_v4l2_buffer_new:<v4l2src0> flags: 00000000
0:00:04.610656344 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:165:gst_v4l2_buffer_new:<v4l2src0> field: 0
0:00:04.611344594 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:166:gst_v4l2_buffer_new:<v4l2src0> memory: 1
0:00:04.612006469 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:169:gst_v4l2_buffer_new:<v4l2src0> MMAP offset: 462848
0:00:04.612714677 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:170:gst_v4l2_buffer_new:<v4l2src0> length: 460800
0:00:04.613376135 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:171:gst_v4l2_buffer_new:<v4l2src0> input: 0
0:00:04.615526010 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:149:gst_v4l2_buffer_new:<v4l2src0> creating buffer 2, 0xad1f8 in pool 0xc62e8
0:00:04.616655260 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:161:gst_v4l2_buffer_new:<v4l2src0> index: 2
0:00:04.617388510 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:162:gst_v4l2_buffer_new:<v4l2src0> type: 1
0:00:04.618029468 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:163:gst_v4l2_buffer_new:<v4l2src0> bytesused: 0
0:00:04.618739468 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:164:gst_v4l2_buffer_new:<v4l2src0> flags: 00000000
0:00:04.619662302 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:165:gst_v4l2_buffer_new:<v4l2src0> field: 0
0:00:04.620320344 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:166:gst_v4l2_buffer_new:<v4l2src0> memory: 1
0:00:04.620961260 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:169:gst_v4l2_buffer_new:<v4l2src0> MMAP offset: 925696
0:00:04.954147681 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:170:gst_v4l2_buffer_new:<v4l2src0> length: 460800
0:00:04.954820472 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:171:gst_v4l2_buffer_new:<v4l2src0> input: 0
0:00:04.957432847 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:485:gst_v4l2_buffer_pool_qbuf:<v4l2src0> enqueue pool buffer 0
0:00:04.958215722 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:492:gst_v4l2_buffer_pool_qbuf:<v4l2src0> num_live_buffers--: 2
0:00:04.959094973 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:485:gst_v4l2_buffer_pool_qbuf:<v4l2src0> enqueue pool buffer 1
0:00:04.959921181 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:492:gst_v4l2_buffer_pool_qbuf:<v4l2src0> num_live_buffers--: 1
0:00:04.960637598 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:485:gst_v4l2_buffer_pool_qbuf:<v4l2src0> enqueue pool buffer 2
0:00:04.961418681 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:492:gst_v4l2_buffer_pool_qbuf:<v4l2src0> num_live_buffers--: 0
Pipeline is live and does not need PREROLL ...
WARNING: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Video input device did not accept new frame rate setting.
Additional debug info:
../../../src/sys/v4l2/v4l2src_calls.c(342): gst_v4l2src_set_capture (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: Invalid argument
Setting pipeline to PLAYING ...
New clock: GstSystemClock
^CCaught interrupt -- handling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 739770129863 ns.
Setting pipeline to READY ...
0:12:25.029590249 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:430:gst_v4l2_buffer_pool_destroy:<v4l2src0> destroy pool
0:12:25.030435416 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:61:gst_v4l2_buffer_finalize:<v4l2src0> finalizing buffer 0xad0b8 0
0:12:25.031152458 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:80:gst_v4l2_buffer_finalize:<v4l2src0> the pool is shutting down
0:12:25.031826499 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:96:gst_v4l2_buffer_finalize:<v4l2src0> buffer 0xad0b8 (data 0x412f5000, len 460800) not recovered, unmapping
0:12:25.033201041 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:61:gst_v4l2_buffer_finalize:<v4l2src0> finalizing buffer 0xad158 1
0:12:25.033927458 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:80:gst_v4l2_buffer_finalize:<v4l2src0> the pool is shutting down
0:12:25.034611999 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:96:gst_v4l2_buffer_finalize:<v4l2src0> buffer 0xad158 (data 0x41366000, len 460800) not recovered, unmapping
0:12:25.035977791 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:61:gst_v4l2_buffer_finalize:<v4l2src0> finalizing buffer 0xad1f8 2
0:12:25.036715708 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:80:gst_v4l2_buffer_finalize:<v4l2src0> the pool is shutting down
0:12:25.037406416 1156 0x15018 LOG v4l2 ../../../src/sys/v4l2/gstv4l2bufferpool.c:96:gst_v4l2_buffer_finalize:<v4l2src0> buffer 0xad1f8 (data 0x413d7000, len 460800) not recovered, unmapping
Setting pipeline to NULL ...
0:12:25.104160957 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:631:gst_v4l2_close:<v4l2src0> Trying to close /dev/video0
0:12:25.105182124 1156 0x15018 DEBUG v4l2 ../../../src/sys/v4l2/v4l2_calls.c:464:gst_v4l2_empty_lists:<v4l2src0> deleting enumerations
Freeing pipeline ...
this pipeline shud run for some time coz using buffers 1000
i ve tried with out 1000 buffers
its not saving any camera data
-rw-r--r-- 1 root root 494 Feb 13 2012 kk.mp4
only 494 always and the pie line is not stopping automatically i ve to give ctrl c for 100 buffers also
pls solve the prob
kailash
