Is there is any conflict in NDK and EDMA3 on C6670?
I am trying to run NDK and EDMA3 on C6670. I observe that when NDK present in system CSL_EDMA3GetHwStatus will block indefinitely and will not return. Please let me know if some conflict is present between EDMA3 and NDK. I found some threads but not sure if this issue still present on C6670.
http://e2e.ti.com/support/dsp/tms320c6000_high_performance_dsps/f/115/t/12343.aspx
Parshant
  • Hi Parshant,
    Are you running NDK and then try this function, or using these two in one projects. i can try out in my system, if you can share some more info. also do you know where exactly the code hangs. you can put break point in the csl_edma3GetHwStatus.c file.
    arun.
