I am running a VIDANALYTICS codec engine on DMVA2. The codec engine completely stalls when deleting my codec. I have had issues with this before but for other reasons.
The issue I find is that ACPY3 cannot deinitiliaze the environment and just stalls:
VCA: Delete...
VCA: Deleting VCA codecs
VCA: Deleting VCA Counting Line codec
@210,212,516us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_releaseDmaChannels> Enter (algs=0x65a6e0, dmaFxnsArray=0x65a6e8, numAlgs=1)
@210,212,793us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels(0x407a3000, 0x5eafd8)
@210,212,981us: [+5 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels: Got 8 DMA channels!
@210,213,120us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_releaseDmaChannels> Free 8 channels
@210,213,245us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - freeChannels> Enter (dmaTab=0x5eafd8, numChan=8)
@210,213,365us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _freeChannels> Freeing channel 6669720
@210,213,482us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_freeChannels> Enter (channelTab=0x4bd39be8, numChan=1)
@210,213,609us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_freeChannels> Calling deinit on protocol on Channel 0
@210,213,735us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_deInitEnv > Enter (handle=0x65c598)
The last bit of code ran is this in framework_components_2_25_03_07/packages/ti/sdo/fc/acpy3:
* ======== ACPY3_deInitEnv ========
static Bool ACPY3_deInitEnv(IDMA3_Handle handle)
Void *scratchEnv;
GT_1trace(CURTRACE, GT_ENTER,
"ACPY3_deInitEnv > Enter (handle=0x%x)\n", handle);
GT_assert(CURTRACE, handle->protocol == &ACPY3_PROTOCOL);
scratchEnv = ((ACPY3_MoreEnv *)(handle->env))->scratchEnv;
if (scratchEnv != NULL) {
scratchEnv = (Void *)((Uns)scratchEnv - handle->numPaRams * PARAMSIZE);
* Restore original values of numTccs and numPaRams, since
* ACPY3_setFinal() may have changed them.
handle->numTccs = ((ACPY3_MoreEnv *)(handle->env))->numTccs;
handle->numPaRams = ((ACPY3_MoreEnv *)(handle->env))->numPaRams;
/* Restore env pointer */
handle->env = (Void *)((Uns)handle->env - handle->numPaRams * PARAMSIZE);
/* Restore scratch env pointer */
*((unsigned *)(handle->env)) = (unsigned)scratchEnv;
_ACPY3_exit();
GT_0trace(CURTRACE, GT_ENTER, "ACPY3_deInitEnv > Enter (status=TRUE)\n");
return (TRUE);
I have the following DVSDK components:
- framework_components_2_25_03_07
- codec_engine_2_24
- xdais_6_24
I have included my codec code and the log.
/*! \brief This structure defines TI's implementation of the IDMA3 interface
* for the VCA_COUNTING_LINE_UDPANALYTICS module.
IDMA3_Fxns VCA_COUNTING_LINE_UDPANALYTICS_IDMA3 =
{ // Module_vendor_interface
&VCA_COUNTING_LINE_UDPANALYTICS_IALG, // IALG functions
VCA_COUNTING_LINE_UDPANALYTICS_dmaChangeChannels, // ChangeChannels
VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannelCnt, // GetChannelCnt
VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels, // GetChannels
VCA_COUNTING_LINE_UDPANALYTICS_dmaInit // Initialize logical channels
// Documentation is defined in vca_counting_line_udpanalytics_priv.h
void VCA_COUNTING_LINE_UDPANALYTICS_dmaChangeChannels(IALG_Handle handle, IDMA3_ChannelRec dmaTab[])
VCA_COUNTING_LINE_UDPANALYTICS_Obj *pVcaObj = (VCA_COUNTING_LINE_UDPANALYTICS_Obj*)handle;
unsigned int i = 0;
// Check we have a VCA object
if (!pVcaObj)
return;
// Function enter tracing statement
UTILS_trace( pVcaObj->traceHandle, UTILS_TRACE_ENTER, "%s(%08p, %08p)\n", __func__, handle, dmaTab);
// Validate the DMA table
if (!handle)
UTILS_trace(pVcaObj->traceHandle, UTILS_TRACE_ERROR, "%s: The DMA table input parameter is NULL.\n", __func__);
return;
// Copy over the new DMA channels
for (i = 0; i < VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.numDmaChannels; i++)
VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.dmaHandles[i] = dmaTab[i].handle;
Uns VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannelCnt()
return VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.numDmaChannels;
Uns VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels(IALG_Handle handle, IDMA3_ChannelRec dmaTab[])
unsigned int i = 0;
if (!pVcaObj)
// Don't request any handles.
return 0;
if (!handle)
return 0;
/* Request logical DMA channels for use with ACPY3
* AND with environment size obtained from ACPY3 implementation
* AND with high priority.
dmaTab[i].handle = VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.dmaHandles[i];
dmaTab[i].numTransfers = 1;
dmaTab[i].numWaits = 1;
dmaTab[i].priority = IDMA3_PRIORITY_HIGH;
dmaTab[i].persistent = FALSE;
dmaTab[i].protocol = &ACPY3_PROTOCOL;
// Success
UTILS_trace( pVcaObj->traceHandle, UTILS_TRACE_INFO, "%s: Got %u DMA channels!\n", __func__, VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.numDmaChannels);
Int VCA_COUNTING_LINE_UDPANALYTICS_dmaInit(IALG_Handle handle, IDMA3_ChannelRec dmaTab[])
unsigned int i = 0;
int status = IALG_EOK;
if (!pVcaObj)
return IALG_EFAIL;
if (!dmaTab)
return IALG_EFAIL;
// Copy over the DMA handles
for( i = 0; i < VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.numDmaChannels; i++ )
UTILS_trace( pVcaObj->traceHandle, UTILS_TRACE_VERBOSE, "%s: Copied %u DMA channels over.\n", __func__, VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.numDmaChannels);
// Success
UTILS_trace( pVcaObj->traceHandle, UTILS_TRACE_INFO, "%s: Initialized DMA correctly!\n", __func__);
return status;
void VCA_COUNTING_LINE_UDPANALYTICS_activate( IALG_Handle handle )
int i = 0;
// Activate all the DMA channels
_ACPY3_activate( VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.dmaHandles[i] );
void VCA_COUNTING_LINE_UDPANALYTICS_deactivate( IALG_Handle handle )
int i = 0;
// Deactivate all DMA channels
_ACPY3_deactivate( VCA_COUNTING_LINE_UDPANALYTICS_MODULEPARAMS.dmaHandles[i] );
AVSERVER MAIN: Create TPP Tsks ...
VCA: Received CMD = 0x0300
VCA: Create...
VCA: tppStream is valid.
VCA: Casting tppConfig (0X651E50)
VCA: Creating VCA algorithm
VCA: Allocating 6800 Bytes for VCA object
VCA: Allocated 6800 Bytes for VCA object
VCA: Creation parameters:
VCA: createPrm.ceNames:
TPP_VCASYS_COUNTING_LINE = vca_counting_line
TPP_VCASYS_CORE = vca_core
TPP_VCASYS_RULES = vca_rules
VCA: createPrm.engineHandle = 0X5DD688
VCA: createPrm.maxWidth = 1280
VCA: createPrm.maxHeight = 768
VCA: createPrm.maxCoreWidth = 320
VCA: createPrm.maxCoreHeight = 192
VCA: createPrm.dataFormat = 2
VCA: createPrm.maxFrameRate = 30000
VCA: createPrm.maxRules = 100
VCA: Starting VCA Counting Line codec on 0X5DD688
@164,228,407us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_initObj(0x407a3000, 0x651460, (nil), 0x4bd39c64)
@164,228,587us: [+1 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_initObj: Copying the create parameters.
@164,228,729us: [+1 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_initObj: Copying the memory table.
@164,228,861us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - ALG_CL_init(0x4bd39884)
@164,228,984us: [+1 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - ALG_CL_init: Counting Line Algorithm Context at 0x480e9000
@164,229,105us: [+1 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - ALG_CL_init: Stored tracing handle 0x480e8000
@164,229,224us: [+1 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - ALG_CL_init: Stored input colour format 9
@164,247,221us: [+5 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - ALG_CL_init: Successfully initialized the counting line algorithm!
@164,247,466us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Enter (groupId=2, algHandle=0x65a6e0, dmaFxns=0x4bd3991c, numAlgs=1)
@164,247,707us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getNumAssignedTccs> Enter
@164,247,828us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - getNumAssignedTccs> Max TCC is 0x20
@164,247,934us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getNumAssignedTccs> Exit
@164,248,030us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getNumAssignedTccs> Enter
@164,248,130us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - getNumAssignedTccs> Max TCC is 0x0
@164,248,223us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getNumAssignedTccs> Exit
@164,248,582us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Created shared memory, key = 0x4e414d44
@164,248,808us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - Initializing DMAN3 shared data
@164,249,418us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - updateTccAllocationTable> Enter
@164,249,580us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - updateTccAllocationTable> Exit
@164,249,689us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - updateTccAllocationTable> Enter
@164,249,785us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - updateTccAllocationTable> Exit
@164,249,888us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> segid = 0, size = 0x34, align = 0x4
@164,249,993us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining before allocation: 0x3b50
@164,250,090us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining after allocation: 0x3b1c
@164,250,190us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> returning base address: 0x4839c4b0
@164,250,288us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> segid = 0, size = 0xc0, align = 0x4
@164,250,387us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining before allocation: 0x3b1c
@164,250,484us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining after allocation: 0x3a5c
@164,250,579us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> returning base address: 0x4839c4e4
@164,700,917us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> segid = 0, size = 0x34, align = 0x4
@164,701,141us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining before allocation: 0x3a5c
@164,701,256us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining after allocation: 0x3a28
@164,701,786us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> returning base address: 0x4839c5a4
@164,701,921us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> segid = 0, size = 0xc0, align = 0x4
@164,702,033us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining before allocation: 0x3a28
@164,702,169us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> bytes remaining after allocation: 0x3968
@164,702,281us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3 shmAlloc> returning base address: 0x4839c5d8
@164,702,389us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Null PaRam is 0
@164,702,487us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 0 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,702,628us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 1 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,702,757us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 2 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,702,873us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 3 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,702,986us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 4 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,703,097us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 5 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,703,213us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 6 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,703,324us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Qdma channel 7 is pointing to the nullPaRam. Change its trigger word bit to 0x7 so it doesn't get triggered when we modify the null PaRam
@164,703,437us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Setting static bit of null paRam (address = 0x483a0000)
@164,703,593us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - checkDMAN3Configuration> Enter
@164,703,706us: [+6 T:0x4bd3a490] ti.sdo.fc.dman3 - checkDMAN3Configuration> DMAN3 max PaRam entries configured to be 128, hardware reads 256
@164,703,889us: [+6 T:0x4bd3a490] ti.sdo.fc.dman3 - checkDMAN3Configuration> DMAN3 max TCs configured to be 8, hardware reads 4
@164,704,000us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - checkDMAN3Configuration> Exit (status=0)
@164,704,102us: [+6 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> DMAN3 SOC-specific configuration different from hardware, continuing with configured values
@164,704,207us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - _initQdmaConfiguration> Enter
@164,704,332us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - _initQdmaConfiguration> Exit
@164,704,471us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - _DMAN3_initImpl> Exiting, _DMAN3_data = 0x4839c000
@164,704,644us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels(0x407a3000, 0x5f0248)
@164,704,783us: [+5 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels: Got 8 DMA channels!
@165,036,425us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Alg 0x407a3000:
@165,036,604us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Total Channels requested 8, PaRams requested 8, Tccs requested 8
@165,036,770us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Enter (pContext=0x4bd398c8, groupId=2, nTccs=8, nPaRams=8)
@165,036,904us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Context exists for groupId 2, context 0x4839c150
@165,037,016us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Creating context for group 2 Tccs 8 PaRams 8
@165,037,182us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Enter (pContext=0x4bd39884, groupId=2, nTccs=8, nPaRams=8)
@165,037,315us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Allocate memory for the context
@165,037,420us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Allocate 8 tccs
@165,037,528us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Next free tcc index 0
@165,037,632us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Allocate 8 paRams
@165,037,775us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> NextpaRam index 96
@165,037,885us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Exit (status=0)
@165,037,989us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Exit (status=DMAN3_SOK)
@165,038,091us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Context 0x4839c150
@165,038,227us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels(0x407a3000, 0x5f0248)
@165,038,360us: [+5 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels: Got 8 DMA channels!
@165,038,516us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Enter (context=0x4839c150, alg=0x407a3000, groupId=2, dmaTab=0x5f0248, numChans=8)
@165,038,676us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 0
@165,038,796us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0248, memRec=0x4bd39834)
@165,038,905us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,039,003us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[0]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,039,160us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 1
@165,039,268us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0260, memRec=0x4bd39834)
@165,039,505us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,039,623us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[1]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,039,749us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 2
@165,039,852us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0278, memRec=0x4bd39834)
@165,039,956us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,040,054us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[2]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,040,171us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 3
@165,040,273us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0290, memRec=0x4bd39834)
@165,040,378us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,040,503us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[3]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,040,629us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 4
@165,040,729us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f02a8, memRec=0x4bd39834)
@165,373,360us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,373,511us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[4]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,373,642us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 5
@165,373,748us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f02c0, memRec=0x4bd39834)
@165,373,848us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,373,945us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[5]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,374,061us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 6
@165,374,165us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f02d8, memRec=0x4bd39834)
@165,374,267us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,374,441us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[6]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,374,564us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 7
@165,374,691us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f02f0, memRec=0x4bd39834)
@165,374,800us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@165,374,900us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[7]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@165,375,019us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 0, size 0x40, align 0x20, scratchEnv 0x0
@165,375,135us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[0]: size=0x28, align=0x4 heapId=0
@165,375,262us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[0]: size=0x28, align=0x4, heapId=0, base=0x65c598
@165,375,388us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@165,375,493us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@165,375,611us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[0]: size=0x40, align=0x20, heapId=0, base=0x651b40
@165,375,729us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@165,375,827us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x65c598, dmaTab=0x5f0248, qdmaChannel=0, env=0x651b40, scratchEnv=0x0, context=0x4839c150)
@165,375,947us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x651b40
@165,376,085us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@165,376,186us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c00, tcc Table 0x4839c000
@165,376,287us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@165,376,382us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x65c598)
@165,376,480us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@165,376,573us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - initQdmaSettings> Enter
@165,376,695us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - initQdmaSettings > Exit
@165,376,888us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@165,377,015us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@165,377,125us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@165,377,228us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@165,377,326us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@165,377,447us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[0].handle's paRamAddr 0x483a0c00
@165,377,559us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 96 (Addr 0x483a0c00)
@165,710,362us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@165,710,509us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 32
@165,710,680us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 1, size 0x40, align 0x20, scratchEnv 0x0
@165,710,812us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[1]: size=0x28, align=0x4 heapId=0
@165,710,947us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[1]: size=0x28, align=0x4, heapId=0, base=0x651460
@165,711,073us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@165,711,181us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@165,711,349us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[1]: size=0x40, align=0x20, heapId=0, base=0x5e4aa0
@165,711,485us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@165,711,662us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x651460, dmaTab=0x5f0260, qdmaChannel=1, env=0x5e4aa0, scratchEnv=0x0, context=0x4839c150)
@165,711,801us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x5e4aa0
@165,711,917us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@165,712,099us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c20, tcc Table 0x4839c001
@165,712,214us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@165,712,312us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x651460)
@165,712,409us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@165,712,497us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@165,712,590us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@165,712,688us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@165,712,784us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@165,712,883us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@165,712,998us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[1].handle's paRamAddr 0x483a0c20
@165,713,114us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 97 (Addr 0x483a0c20)
@165,713,214us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@165,713,311us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 33
@165,713,408us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 2, size 0x40, align 0x20, scratchEnv 0x0
@165,713,518us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[2]: size=0x28, align=0x4 heapId=0
@165,713,641us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[2]: size=0x28, align=0x4, heapId=0, base=0x5e4af0
@165,713,763us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
@165,713,864us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@165,713,980us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[2]: size=0x40, align=0x20, heapId=0, base=0x5e4b40
@165,714,099us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@165,714,201us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5e4af0, dmaTab=0x5f0278, qdmaChannel=2, env=0x5e4b40, scratchEnv=0x0, context=0x4839c150)
@165,714,318us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x5e4b40
@165,714,462us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@165,714,559us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c40, tcc Table 0x4839c002
@166,047,289us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@166,047,435us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5e4af0)
@166,047,549us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@166,047,703us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@166,047,814us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@166,047,916us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@166,048,018us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
@166,048,120us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@166,048,213us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[2].handle's paRamAddr 0x483a0c40
@166,048,318us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 98 (Addr 0x483a0c40)
@166,048,415us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@166,048,513us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 34
@166,048,650us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 3, size 0x40, align 0x20, scratchEnv 0x0
@166,048,766us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[3]: size=0x28, align=0x4 heapId=0
@166,048,899us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[3]: size=0x28, align=0x4, heapId=0, base=0x659730
@166,049,027us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 3
@166,049,132us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@166,049,246us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[3]: size=0x40, align=0x20, heapId=0, base=0x659780
@166,049,501us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@166,049,622us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x659730, dmaTab=0x5f0290, qdmaChannel=3, env=0x659780, scratchEnv=0x0, context=0x4839c150)
@166,049,750us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x659780
@166,049,863us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@166,049,988us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c60, tcc Table 0x4839c003
@166,050,099us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@166,050,201us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x659730)
@166,050,301us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@166,050,390us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@166,050,486us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@166,050,584us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@166,050,683us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
@166,050,785us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@166,050,879us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[3].handle's paRamAddr 0x483a0c60
@166,050,987us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 99 (Addr 0x483a0c60)
@166,051,085us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@166,051,187us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 35
@166,051,284us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 4, size 0x40, align 0x20, scratchEnv 0x0
@166,051,438us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[4]: size=0x28, align=0x4 heapId=0
@166,051,571us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[4]: size=0x28, align=0x4, heapId=0, base=0x6597d0
@166,051,696us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@166,384,250us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@166,384,416us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[4]: size=0x40, align=0x20, heapId=0, base=0x659820
@166,384,543us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@166,384,643us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x6597d0, dmaTab=0x5f02a8, qdmaChannel=0, env=0x659820, scratchEnv=0x0, context=0x4839c150)
@166,384,761us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x659820
@166,384,870us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@166,384,963us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c80, tcc Table 0x4839c004
@166,385,061us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@166,385,159us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x6597d0)
@166,385,257us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@166,385,343us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@166,385,433us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@166,385,562us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@166,385,729us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@166,385,835us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@166,385,931us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[4].handle's paRamAddr 0x483a0c80
@166,386,037us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 100 (Addr 0x483a0c80)
@166,386,139us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@166,386,232us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 36
@166,386,330us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 5, size 0x40, align 0x20, scratchEnv 0x0
@166,386,443us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[5]: size=0x28, align=0x4 heapId=0
@166,386,566us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[5]: size=0x28, align=0x4, heapId=0, base=0x659870
@166,386,688us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@166,386,788us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@166,386,927us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[5]: size=0x40, align=0x20, heapId=0, base=0x651c60
@166,387,056us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@166,387,164us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x659870, dmaTab=0x5f02c0, qdmaChannel=1, env=0x651c60, scratchEnv=0x0, context=0x4839c150)
@166,387,287us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x651c60
@166,387,398us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@166,387,491us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0ca0, tcc Table 0x4839c005
@166,387,589us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@166,387,680us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x659870)
@166,387,777us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@166,387,862us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@166,387,952us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@166,388,047us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@166,388,145us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@166,388,243us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@166,721,230us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[5].handle's paRamAddr 0x483a0ca0
@166,721,388us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 101 (Addr 0x483a0ca0)
@166,721,501us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@166,721,602us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 37
@166,721,701us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 6, size 0x40, align 0x20, scratchEnv 0x0
@166,721,811us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[6]: size=0x28, align=0x4 heapId=0
@166,721,938us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[6]: size=0x28, align=0x4, heapId=0, base=0x651cc0
@166,722,135us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
@166,722,251us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@166,722,367us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[6]: size=0x40, align=0x20, heapId=0, base=0x651d00
@166,722,511us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@166,722,615us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x651cc0, dmaTab=0x5f02d8, qdmaChannel=2, env=0x651d00, scratchEnv=0x0, context=0x4839c150)
@166,722,737us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x651d00
@166,722,849us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@166,722,939us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0cc0, tcc Table 0x4839c006
@166,723,038us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@166,723,136us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x651cc0)
@166,723,231us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@166,723,319us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@166,723,411us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@166,723,506us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@166,723,601us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
@166,723,701us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@166,723,794us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[6].handle's paRamAddr 0x483a0cc0
@166,723,933us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 102 (Addr 0x483a0cc0)
@166,724,034us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@166,724,133us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 38
@166,724,228us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 7, size 0x40, align 0x20, scratchEnv 0x0
@166,724,342us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[7]: size=0x28, align=0x4 heapId=0
@166,724,463us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[7]: size=0x28, align=0x4, heapId=0, base=0x651d60
@166,724,585us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 3
@166,724,688us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@166,724,803us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[7]: size=0x40, align=0x20, heapId=0, base=0x651da0
@166,724,917us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@166,725,014us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x651d60, dmaTab=0x5f02f0, qdmaChannel=3, env=0x651da0, scratchEnv=0x0, context=0x4839c150)
@166,725,135us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x651da0
@167,056,774us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@167,056,923us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0ce0, tcc Table 0x4839c007
@167,057,037us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@167,057,138us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x651d60)
@167,057,240us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@167,057,565us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@167,057,692us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@167,057,798us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@167,057,898us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
@167,058,002us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@167,058,136us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[7].handle's paRamAddr 0x483a0ce0
@167,058,245us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 103 (Addr 0x483a0ce0)
@167,058,343us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@167,058,438us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 39
@167,058,607us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Exit (status=0)
@167,058,757us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaInit(0x407a3000, 0x5f0248)
@167,058,896us: [+1 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaInit: Copied 8 DMA channels over.
@167,059,025us: [+5 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaInit: Initialized DMA correctly!
@167,059,138us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@167,059,241us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,059,474us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[0].handle's paRamAddr 0x483a0c00
@167,059,616us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 96 (Addr 0x483a0c00)
@167,059,727us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,059,829us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 32
@167,059,928us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@167,060,028us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,060,121us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[1].handle's paRamAddr 0x483a0c20
@167,060,275us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 97 (Addr 0x483a0c20)
@167,060,398us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,060,504us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 33
@167,060,608us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
@167,060,705us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,060,824us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[2].handle's paRamAddr 0x483a0c40
@167,060,937us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 98 (Addr 0x483a0c40)
@167,061,040us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,061,137us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 34
@167,061,237us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
@167,061,334us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,061,427us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[3].handle's paRamAddr 0x483a0c60
@167,061,958us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 99 (Addr 0x483a0c60)
@167,393,712us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,393,854us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 35
@167,393,962us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@167,394,065us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,394,166us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[4].handle's paRamAddr 0x483a0c80
@167,394,269us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 100 (Addr 0x483a0c80)
@167,394,367us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,394,462us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 36
@167,394,555us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@167,394,650us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,394,744us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[5].handle's paRamAddr 0x483a0ca0
@167,394,846us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 101 (Addr 0x483a0ca0)
@167,394,945us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,395,078us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 37
@167,395,180us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
@167,395,277us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,395,368us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[6].handle's paRamAddr 0x483a0cc0
@167,395,469us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 102 (Addr 0x483a0cc0)
@167,395,565us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,395,659us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 38
@167,395,753us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
@167,395,844us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@167,395,938us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[7].handle's paRamAddr 0x483a0ce0
@167,396,038us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 103 (Addr 0x483a0ce0)
@167,396,138us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@167,396,232us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 39
@167,396,394us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Exit (status=0)
VCA: Started the VCA Counting Line codec on 0X5DD688
VCA: Setting the counting line runtime parameters
VCA: Processing VCA Counting Line control command 0X1
@167,396,968us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_control(0x407a3000, 1, 0x4bd39c00, 0x4bd39aa8)
@167,397,134us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - _setParams(0x407a3000, 0x4bd39c00, 0x4bd39aa8)
@167,397,268us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - ALG_CL_setInputFrameSize(0x480e9000, 1280, 768)
VCA: Processed VCA Counting Line control command 0X1
VCA: Set the counting line runtime parameters
VCA: Processing VCA Counting Line control command 0X108
@167,397,837us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_control(0x407a3000, 264, 0x4bd39c34, 0x4bd39aa8)
@167,397,992us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - _setDebugData(0x407a3000, 0x4bd39c34, 0x4bd39aa8)
VCA: Processed VCA Counting Line control command 0X108
VCA: Starting VCA Core codec on 0X5DD688
GetMsgThdFromWebBuff cond wait
@167,419,009us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Enter (groupId=2, algHandle=0x651e20, dmaFxns=0x4bd39ad4, numAlgs=1)
@167,419,535us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Alg 0x483a3000:
@167,419,692us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Total Channels requested 10, PaRams requested 10, Tccs requested 10
@167,751,486us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Enter (pContext=0x4bd39a80, groupId=2, nTccs=10, nPaRams=10)
@167,751,650us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Context exists for groupId 2, context 0x4839c150
@167,751,770us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Existing context has insufficient tccs and PaRams: params: 8, tccs: 8, refCount: 8
@167,751,879us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Creating context for group -1 Tccs 10 PaRams 10
@167,751,986us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Enter (pContext=0x4bd39a3c, groupId=-1, nTccs=10, nPaRams=10)
@167,752,092us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Allocate memory for the context
@167,752,207us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Allocate 10 tccs
@167,752,319us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Next free tcc index 8
@167,752,422us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Allocate 10 paRams
@167,752,522us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> NextpaRam index 104
@167,752,624us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createContext> Exit (status=0)
@167,752,746us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Exit (status=DMAN3_SOK)
@167,752,917us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Context 0x65c4e8
@167,753,042us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Enter (context=0x65c4e8, alg=0x483a3000, groupId=2, dmaTab=0x5f04e8, numChans=10)
@167,753,186us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 0
@167,753,297us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f04e8, memRec=0x4bd399ec)
@167,753,403us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@167,753,498us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[0]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@167,753,615us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 1
@167,753,713us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0500, memRec=0x4bd399ec)
@167,753,813us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@167,753,909us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[1]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@167,754,028us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 2
@167,754,152us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0518, memRec=0x4bd399ec)
@167,754,262us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@167,754,360us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[2]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@167,754,474us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 3
@167,754,571us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0530, memRec=0x4bd399ec)
@167,754,670us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@167,754,762us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[3]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@167,754,876us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 4
@167,754,973us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0548, memRec=0x4bd399ec)
@167,755,074us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@167,755,174us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[4]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@167,755,287us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 5
@167,755,384us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0560, memRec=0x4bd399ec)
@167,755,484us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@168,088,453us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[5]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@168,088,619us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 6
@168,088,732us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0578, memRec=0x4bd399ec)
@168,088,841us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@168,088,942us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[6]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@168,089,059us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 7
@168,089,159us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f0590, memRec=0x4bd399ec)
@168,089,265us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@168,089,475us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[7]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@168,089,614us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 8
@168,089,750us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f05a8, memRec=0x4bd399ec)
@168,089,864us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@168,089,963us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[8]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@168,090,082us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 9
@168,090,182us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x5f05c0, memRec=0x4bd399ec)
@168,090,286us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@168,090,383us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[9]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@168,090,503us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 0, size 0x40, align 0x20, scratchEnv 0x0
@168,090,616us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[0]: size=0x28, align=0x4 heapId=0
@168,090,745us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[0]: size=0x28, align=0x4, heapId=0, base=0x65c528
@168,090,869us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@168,090,972us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@168,091,116us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[0]: size=0x40, align=0x20, heapId=0, base=0x5f0800
@168,091,247us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@168,091,353us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x65c528, dmaTab=0x5f04e8, qdmaChannel=0, env=0x5f0800, scratchEnv=0x0, context=0x65c4e8)
@168,091,479us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x5f0800
@168,091,593us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@168,091,687us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0d00, tcc Table 0x4839c008
@168,091,788us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@168,091,885us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x65c528)
@168,091,982us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@168,092,072us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@168,092,168us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@168,092,267us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@168,092,368us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@168,092,495us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@168,425,399us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[0].handle's paRamAddr 0x483a0d00
@168,425,555us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 104 (Addr 0x483a0d00)
@168,425,664us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@168,425,762us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 40
@168,425,859us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 1, size 0x40, align 0x20, scratchEnv 0x0
@168,425,967us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[1]: size=0x28, align=0x4 heapId=0
@168,426,090us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[1]: size=0x28, align=0x4, heapId=0, base=0x65c560
@168,426,215us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@168,426,317us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@168,426,428us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[1]: size=0x40, align=0x20, heapId=0, base=0x5f0860
@168,426,542us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@168,426,666us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x65c560, dmaTab=0x5f0500, qdmaChannel=1, env=0x5f0860, scratchEnv=0x0, context=0x65c4e8)
@168,426,795us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x5f0860
@168,426,912us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@168,427,007us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0d20, tcc Table 0x4839c009
@168,427,113us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@168,427,207us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x65c560)
@168,427,307us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@168,427,394us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@168,427,488us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@168,427,582us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@168,427,677us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@168,427,774us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@168,427,937us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[1].handle's paRamAddr 0x483a0d20
@168,428,077us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 105 (Addr 0x483a0d20)
@168,428,188us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@168,428,288us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 41
@168,428,382us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 2, size 0x40, align 0x20, scratchEnv 0x0
@168,428,493us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[2]: size=0x28, align=0x4 heapId=0
@168,428,613us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[2]: size=0x28, align=0x4, heapId=0, base=0x5f08c8
@168,428,734us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
@168,428,835us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@168,428,942us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[2]: size=0x40, align=0x20, heapId=0, base=0x5f0900
@168,429,057us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@168,429,157us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f08c8, dmaTab=0x5f0518, qdmaChannel=2, env=0x5f0900, scratchEnv=0x0, context=0x65c4e8)
@168,429,272us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x5f0900
@168,762,326us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@168,762,882us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0d40, tcc Table 0x4839c00a
@168,763,021us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@168,763,131us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f08c8)
@168,763,232us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@168,763,320us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@168,763,414us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@168,763,511us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@168,763,637us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
@168,763,747us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@168,763,843us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[2].handle's paRamAddr 0x483a0d40
@168,763,946us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 106 (Addr 0x483a0d40)
@168,764,041us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@168,764,135us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 42
@168,764,230us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 3, size 0x40, align 0x20, scratchEnv 0x0
@168,764,341us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[3]: size=0x28, align=0x4 heapId=0
@168,764,462us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[3]: size=0x28, align=0x4, heapId=0, base=0x5f0968
@168,764,583us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 3
@168,764,684us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@168,764,795us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[3]: size=0x40, align=0x20, heapId=0, base=0x5f09a0
@168,764,912us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@168,765,041us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f0968, dmaTab=0x5f0530, qdmaChannel=3, env=0x5f09a0, scratchEnv=0x0, context=0x65c4e8)
@168,765,177us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x5f09a0
@168,765,290us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@168,765,384us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0d60, tcc Table 0x4839c00b
@168,765,482us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@168,765,574us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f0968)
@168,765,672us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@168,765,758us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@168,765,850us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@168,765,943us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@168,766,039us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
@168,766,140us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@168,766,232us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[3].handle's paRamAddr 0x483a0d60
@168,766,333us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 107 (Addr 0x483a0d60)
@168,766,465us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@168,766,565us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 43
@168,766,660us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 4, size 0x40, align 0x20, scratchEnv 0x0
@168,766,772us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[4]: size=0x28, align=0x4 heapId=0
@168,766,891us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[4]: size=0x28, align=0x4, heapId=0, base=0x5f0a08
@169,099,290us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@169,099,564us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@169,099,700us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[4]: size=0x40, align=0x20, heapId=0, base=0x5f0a40
@169,099,884us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@169,100,005us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f0a08, dmaTab=0x5f0548, qdmaChannel=0, env=0x5f0a40, scratchEnv=0x0, context=0x65c4e8)
@169,100,134us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x5f0a40
@169,100,246us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@169,100,340us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0d80, tcc Table 0x4839c00c
@169,100,439us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@169,100,537us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f0a08)
@169,100,666us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@169,100,760us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@169,100,852us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@169,100,950us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@169,101,045us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@169,101,148us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@169,101,240us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[4].handle's paRamAddr 0x483a0d80
@169,101,341us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 108 (Addr 0x483a0d80)
@169,101,434us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@169,101,528us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 44
@169,101,621us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 5, size 0x40, align 0x20, scratchEnv 0x0
@169,101,728us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[5]: size=0x28, align=0x4 heapId=0
@169,101,851us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[5]: size=0x28, align=0x4, heapId=0, base=0x5f0aa8
@169,102,000us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@169,102,114us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@169,102,231us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[5]: size=0x40, align=0x20, heapId=0, base=0x5f0ae0
@169,102,347us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@169,102,446us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f0aa8, dmaTab=0x5f0560, qdmaChannel=1, env=0x5f0ae0, scratchEnv=0x0, context=0x65c4e8)
@169,102,564us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x5f0ae0
@169,102,675us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@169,102,766us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0da0, tcc Table 0x4839c00d
@169,102,865us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@169,102,959us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f0aa8)
@169,103,059us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@169,103,148us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@169,103,238us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@169,434,849us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@169,434,994us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@169,435,106us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@169,435,202us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[5].handle's paRamAddr 0x483a0da0
@169,435,306us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 109 (Addr 0x483a0da0)
@169,435,399us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@169,435,493us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 45
@169,435,587us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 6, size 0x40, align 0x20, scratchEnv 0x0
@169,435,698us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[6]: size=0x28, align=0x4 heapId=0
@169,435,820us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[6]: size=0x28, align=0x4, heapId=0, base=0x5f0b48
@169,435,940us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
@169,436,040us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@169,436,191us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[6]: size=0x40, align=0x20, heapId=0, base=0x5f0b80
@169,436,317us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@169,436,418us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f0b48, dmaTab=0x5f0578, qdmaChannel=2, env=0x5f0b80, scratchEnv=0x0, context=0x65c4e8)
@169,436,566us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x5f0b80
@169,436,685us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@169,436,780us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0dc0, tcc Table 0x4839c00e
@169,436,879us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@169,436,973us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f0b48)
@169,437,073us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@169,437,163us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@169,437,255us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@169,437,353us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@169,437,448us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
@169,437,642us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@169,437,744us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[6].handle's paRamAddr 0x483a0dc0
@169,437,851us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 110 (Addr 0x483a0dc0)
@169,437,947us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@169,438,041us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 46
@169,438,140us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 7, size 0x40, align 0x20, scratchEnv 0x0
@169,438,251us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[7]: size=0x28, align=0x4 heapId=0
@169,438,376us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[7]: size=0x28, align=0x4, heapId=0, base=0x64e730
@169,438,500us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 3
@169,438,599us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@169,438,710us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[7]: size=0x40, align=0x20, heapId=0, base=0x64e780
@169,438,824us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@169,438,952us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64e730, dmaTab=0x5f0590, qdmaChannel=3, env=0x64e780, scratchEnv=0x0, context=0x65c4e8)
@169,771,836us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x64e780
@169,771,996us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@169,772,099us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0de0, tcc Table 0x4839c00f
@169,772,206us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@169,772,305us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64e730)
@169,772,407us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@169,772,495us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@169,772,583us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@169,772,679us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@169,772,773us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
@169,772,869us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@169,773,026us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[7].handle's paRamAddr 0x483a0de0
@169,773,182us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 111 (Addr 0x483a0de0)
@169,773,290us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@169,773,384us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 47
@169,773,484us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 8, size 0x40, align 0x20, scratchEnv 0x0
@169,773,595us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[8]: size=0x28, align=0x4 heapId=0
@169,773,720us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[8]: size=0x28, align=0x4, heapId=0, base=0x64e7d0
@169,773,844us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@169,773,945us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@169,774,055us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[8]: size=0x40, align=0x20, heapId=0, base=0x64e820
@169,774,174us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@169,774,271us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64e7d0, dmaTab=0x5f05a8, qdmaChannel=0, env=0x64e820, scratchEnv=0x0, context=0x65c4e8)
@169,774,394us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x64e820
@169,774,532us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@169,774,634us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0e00, tcc Table 0x4839c010
@169,774,737us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@169,774,832us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64e7d0)
@169,774,930us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@169,775,018us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@169,775,114us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@169,775,211us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@169,775,309us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@169,775,408us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@169,775,501us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[8].handle's paRamAddr 0x483a0e00
@169,775,602us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 112 (Addr 0x483a0e00)
@169,775,696us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@169,775,788us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 48
@169,775,913us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 9, size 0x40, align 0x20, scratchEnv 0x0
@170,108,795us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[9]: size=0x28, align=0x4 heapId=0
@170,108,970us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[9]: size=0x28, align=0x4, heapId=0, base=0x64e870
@170,109,099us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@170,109,279us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@170,109,511us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[9]: size=0x40, align=0x20, heapId=0, base=0x64e8c0
@170,109,637us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@170,109,736us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64e870, dmaTab=0x5f05c0, qdmaChannel=1, env=0x64e8c0, scratchEnv=0x0, context=0x65c4e8)
@170,109,854us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x64e8c0
@170,109,966us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@170,110,084us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0e20, tcc Table 0x4839c011
@170,110,197us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@170,110,294us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64e870)
@170,110,393us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@170,110,481us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@170,110,572us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@170,110,668us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@170,110,766us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@170,110,868us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@170,110,960us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[9].handle's paRamAddr 0x483a0e20
@170,111,062us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 113 (Addr 0x483a0e20)
@170,111,158us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@170,111,251us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 49
@170,111,354us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Exit (status=0)
@170,111,546us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@170,111,672us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,111,772us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[0].handle's paRamAddr 0x483a0d00
@170,111,879us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 104 (Addr 0x483a0d00)
@170,111,977us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,112,070us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 40
@170,112,166us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@170,112,259us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,112,351us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[1].handle's paRamAddr 0x483a0d20
@170,112,452us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 105 (Addr 0x483a0d20)
@170,112,549us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,112,641us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 41
@170,112,731us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
@170,112,850us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,112,949us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[2].handle's paRamAddr 0x483a0d40
@170,445,763us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 106 (Addr 0x483a0d40)
@170,445,910us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,446,019us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 42
@170,446,122us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
@170,446,221us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,446,314us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[3].handle's paRamAddr 0x483a0d60
@170,446,414us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 107 (Addr 0x483a0d60)
@170,446,510us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,446,601us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 43
@170,446,695us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@170,446,787us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,446,879us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[4].handle's paRamAddr 0x483a0d80
@170,446,979us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 108 (Addr 0x483a0d80)
@170,447,118us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,447,213us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 44
@170,447,308us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@170,447,402us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,447,494us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[5].handle's paRamAddr 0x483a0da0
@170,447,594us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 109 (Addr 0x483a0da0)
@170,447,689us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,447,781us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 45
@170,447,873us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
@170,447,967us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,448,059us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[6].handle's paRamAddr 0x483a0dc0
@170,448,160us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 110 (Addr 0x483a0dc0)
@170,448,256us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,448,349us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 46
@170,448,472us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
@170,448,576us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,448,668us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[7].handle's paRamAddr 0x483a0de0
@170,448,769us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 111 (Addr 0x483a0de0)
@170,448,866us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,448,960us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 47
@170,449,052us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@170,449,150us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,449,239us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[8].handle's paRamAddr 0x483a0e00
@170,449,447us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 112 (Addr 0x483a0e00)
@170,449,571us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,449,674us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 48
@170,449,793us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@170,449,901us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@170,449,994us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[9].handle's paRamAddr 0x483a0e20
@170,782,709us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 113 (Addr 0x483a0e20)
@170,782,862us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@170,782,968us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 49
@170,783,112us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Exit (status=0)
VCA: Started the VCA Core codec on 0X5DD688
VCA: Starting VCA Rules codec on 0X5DD688
@170,789,747us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Enter (groupId=2, algHandle=0x5f02e0, dmaFxns=0x4bd3991c, numAlgs=1)
@170,789,965us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Alg 0x485be000:
@170,790,091us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Total Channels requested 8, PaRams requested 8, Tccs requested 8
@170,790,244us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Enter (pContext=0x4bd398c8, groupId=2, nTccs=8, nPaRams=8)
@170,790,372us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Context exists for groupId 2, context 0x4839c150
@170,790,480us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - getContext> Exit (status=DMAN3_SOK)
@170,790,579us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Context 0x4839c150
@170,790,686us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Enter (context=0x4839c150, alg=0x485be000, groupId=2, dmaTab=0x64e910, numChans=8)
@170,790,822us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 0
@170,790,960us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e910, memRec=0x4bd39834)
@170,791,073us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@170,791,176us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[0]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@170,791,292us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 1
@170,791,389us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e928, memRec=0x4bd39834)
@170,791,489us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@170,791,585us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[1]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@170,791,700us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 2
@170,791,795us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e940, memRec=0x4bd39834)
@170,791,897us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@170,791,991us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[2]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@170,792,104us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 3
@170,792,201us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e958, memRec=0x4bd39834)
@170,792,759us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@170,792,905us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[3]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@170,793,038us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 4
@170,793,145us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e970, memRec=0x4bd39834)
@170,793,246us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@170,793,344us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[4]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@170,793,460us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 5
@170,793,557us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e988, memRec=0x4bd39834)
@170,793,680us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@170,793,790us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[5]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@171,126,612us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 6
@171,126,760us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e9a0, memRec=0x4bd39834)
@171,126,874us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@171,126,979us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[6]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@171,127,096us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Channel 7
@171,127,201us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Enter (dmaTab=0x64e9b8, memRec=0x4bd39834)
@171,127,302us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_getEnvMem> Exit
@171,127,395us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Requested memTab[7]: size=0x40, align=0x20, space=IALG_PERSIST, attrs=IALG_DARAM0
@171,127,512us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 0, size 0x40, align 0x20, scratchEnv 0x0
@171,127,623us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[0]: size=0x28, align=0x4 heapId=0
@171,127,746us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[0]: size=0x28, align=0x4, heapId=0, base=0x5f0630
@171,127,901us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@171,128,010us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@171,128,131us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[0]: size=0x40, align=0x20, heapId=0, base=0x5f0680
@171,128,249us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@171,128,347us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f0630, dmaTab=0x64e910, qdmaChannel=0, env=0x5f0680, scratchEnv=0x0, context=0x4839c150)
@171,128,465us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x5f0680
@171,128,576us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@171,128,670us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c00, tcc Table 0x4839c000
@171,128,770us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@171,128,865us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f0630)
@171,128,960us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@171,129,048us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@171,129,147us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@171,129,268us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@171,129,487us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@171,129,600us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@171,129,696us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[0].handle's paRamAddr 0x483a0c00
@171,129,804us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 96 (Addr 0x483a0c00)
@171,129,902us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@171,129,994us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 32
@171,130,087us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 1, size 0x40, align 0x20, scratchEnv 0x0
@171,130,201us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[1]: size=0x28, align=0x4 heapId=0
@171,130,321us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[1]: size=0x28, align=0x4, heapId=0, base=0x5f06d0
@171,130,442us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@171,130,546us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@171,463,548us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[1]: size=0x40, align=0x20, heapId=0, base=0x5f0720
@171,463,712us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@171,463,819us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f06d0, dmaTab=0x64e928, qdmaChannel=1, env=0x5f0720, scratchEnv=0x0, context=0x4839c150)
@171,463,942us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x5f0720
@171,464,053us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@171,464,151us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c20, tcc Table 0x4839c001
@171,464,252us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@171,464,347us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f06d0)
@171,464,445us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@171,464,530us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@171,464,623us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@171,464,717us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@171,464,840us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@171,464,950us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@171,465,044us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[1].handle's paRamAddr 0x483a0c20
@171,465,152us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 97 (Addr 0x483a0c20)
@171,465,250us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@171,465,348us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 33
@171,465,444us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 2, size 0x40, align 0x20, scratchEnv 0x0
@171,465,556us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[2]: size=0x28, align=0x4 heapId=0
@171,465,680us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[2]: size=0x28, align=0x4, heapId=0, base=0x5f0770
@171,465,803us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
@171,465,905us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@171,466,023us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[2]: size=0x40, align=0x20, heapId=0, base=0x5f0300
@171,466,146us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@171,466,275us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f0770, dmaTab=0x64e940, qdmaChannel=2, env=0x5f0300, scratchEnv=0x0, context=0x4839c150)
@171,466,399us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x5f0300
@171,466,508us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@171,466,600us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c40, tcc Table 0x4839c002
@171,466,697us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@171,466,792us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f0770)
@171,466,887us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@171,466,975us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@171,467,067us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@171,467,163us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@171,467,258us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
@171,467,358us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@171,467,449us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[2].handle's paRamAddr 0x483a0c40
@171,800,521us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 98 (Addr 0x483a0c40)
@171,800,663us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@171,800,770us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 34
@171,800,868us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 3, size 0x40, align 0x20, scratchEnv 0x0
@171,800,979us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[3]: size=0x28, align=0x4 heapId=0
@171,801,111us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[3]: size=0x28, align=0x4, heapId=0, base=0x5f07a8
@171,801,235us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 3
@171,801,341us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@171,801,457us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[3]: size=0x40, align=0x20, heapId=0, base=0x64ec20
@171,801,577us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@171,801,677us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x5f07a8, dmaTab=0x64e958, qdmaChannel=3, env=0x64ec20, scratchEnv=0x0, context=0x4839c150)
@171,801,827us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x64ec20
@171,801,948us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@171,802,045us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c60, tcc Table 0x4839c003
@171,802,150us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@171,802,246us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x5f07a8)
@171,802,343us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@171,802,430us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@171,802,521us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@171,802,617us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@171,802,764us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
@171,802,885us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@171,802,987us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[3].handle's paRamAddr 0x483a0c60
@171,803,092us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 99 (Addr 0x483a0c60)
@171,803,222us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@171,803,323us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 35
@171,803,418us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 4, size 0x40, align 0x20, scratchEnv 0x0
@171,803,528us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[4]: size=0x28, align=0x4 heapId=0
@171,803,652us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[4]: size=0x28, align=0x4, heapId=0, base=0x64ec88
@171,803,776us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 0
@171,803,881us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@171,803,994us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[4]: size=0x40, align=0x20, heapId=0, base=0x64ecc0
@171,804,108us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@171,804,206us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64ec88, dmaTab=0x64e970, qdmaChannel=0, env=0x64ecc0, scratchEnv=0x0, context=0x4839c150)
@171,804,321us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 0, env 0x64ecc0
@171,804,429us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@172,136,081us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0c80, tcc Table 0x4839c004
@172,136,236us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@172,136,342us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64ec88)
@172,136,443us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@172,136,561us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@172,136,663us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@172,136,764us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@172,136,864us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):0
@172,136,964us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@172,137,058us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[4].handle's paRamAddr 0x483a0c80
@172,137,166us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 100 (Addr 0x483a0c80)
@172,137,739us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@172,137,879us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 36
@172,138,051us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 5, size 0x40, align 0x20, scratchEnv 0x0
@172,138,186us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[5]: size=0x28, align=0x4 heapId=0
@172,138,318us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[5]: size=0x28, align=0x4, heapId=0, base=0x64ed28
@172,138,447us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 1
@172,138,552us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@172,138,666us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[5]: size=0x40, align=0x20, heapId=0, base=0x64ed60
@172,138,817us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@172,138,919us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64ed28, dmaTab=0x64e988, qdmaChannel=1, env=0x64ed60, scratchEnv=0x0, context=0x4839c150)
@172,139,038us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 1, env 0x64ed60
@172,139,150us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@172,139,243us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0ca0, tcc Table 0x4839c005
@172,139,458us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@172,139,580us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64ed28)
@172,139,684us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@172,139,774us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@172,139,865us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@172,139,962us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@172,140,056us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):1
@172,140,193us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@172,140,291us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[5].handle's paRamAddr 0x483a0ca0
@172,140,394us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 101 (Addr 0x483a0ca0)
@172,140,491us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@172,140,586us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 37
@172,140,682us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 6, size 0x40, align 0x20, scratchEnv 0x0
@172,140,792us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[6]: size=0x28, align=0x4 heapId=0
@172,140,915us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[6]: size=0x28, align=0x4, heapId=0, base=0x64edc8
@172,473,028us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 2
@172,473,186us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@172,473,318us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[6]: size=0x40, align=0x20, heapId=0, base=0x64ee00
@172,473,440us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@172,473,540us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64edc8, dmaTab=0x64e9a0, qdmaChannel=2, env=0x64ee00, scratchEnv=0x0, context=0x4839c150)
@172,473,658us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 2, env 0x64ee00
@172,473,766us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@172,473,856us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0cc0, tcc Table 0x4839c006
@172,473,952us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@172,474,047us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64edc8)
@172,474,148us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@172,474,234us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@172,474,359us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@172,474,462us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@172,474,561us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):2
@172,474,733us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@172,474,834us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[6].handle's paRamAddr 0x483a0cc0
@172,474,939us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 102 (Addr 0x483a0cc0)
@172,475,035us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@172,475,133us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 38
@172,475,233us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Creating channel 7, size 0x40, align 0x20, scratchEnv 0x0
@172,475,344us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Requested mem[7]: size=0x28, align=0x4 heapId=0
@172,475,469us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> IDMA3 Object Allocated mem[7]: size=0x28, align=0x4, heapId=0, base=0x64ee68
@172,475,594us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigning qdmaChannel 3
@172,475,726us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env buffer of size 0x40 requested
@172,475,849us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Env Allocated memTab[7]: size=0x40, align=0x20, heapId=0, base=0x64eea0
@172,475,967us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Initializing IDMA3_handle
@172,476,067us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Enter (handle=0x64ee68, dmaTab=0x64e9b8, qdmaChannel=3, env=0x64eea0, scratchEnv=0x0, context=0x4839c150)
@172,476,189us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Initializing IDMA3 handle with 1 tccs, 1 PaRams, qdmaChannel 3, env 0x64eea0
@172,476,299us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Non-zero env handle
@172,476,392us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> paRam block 0x483a0ce0, tcc Table 0x4839c007
@172,476,518us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Call protocol Init function
@172,476,620us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Enter (handle=0x64ee68)
@172,476,718us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Enter
@172,476,805us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - _ACPY3_init > Exit
@172,476,894us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_initEnv> Exit (status=TRUE)
@172,476,988us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - initHandle> Exit (status=1)
@172,809,975us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Qdma Channel(s):3
@172,810,191us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned PaRam(s):
@172,810,299us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> dmaTab[7].handle's paRamAddr 0x483a0ce0
@172,810,411us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 103 (Addr 0x483a0ce0)
@172,810,510us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Assigned Tcc(s):
@172,810,602us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> 39
@172,810,708us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - createChannels> Exit (status=0)
@172,810,875us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@172,811,002us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@172,811,109us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[0].handle's paRamAddr 0x483a0c00
@172,811,214us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 96 (Addr 0x483a0c00)
@172,811,354us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@172,811,453us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 32
@172,811,551us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@172,811,645us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@172,811,737us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[1].handle's paRamAddr 0x483a0c20
@172,811,840us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 97 (Addr 0x483a0c20)
@172,811,940us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@172,812,035us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 33
@172,812,131us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
@172,812,226us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@172,812,316us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[2].handle's paRamAddr 0x483a0c40
@172,812,419us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 98 (Addr 0x483a0c40)
@172,812,514us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@172,812,610us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 34
@172,812,735us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
@172,812,836us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@172,812,929us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[3].handle's paRamAddr 0x483a0c60
@172,813,032us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 99 (Addr 0x483a0c60)
@172,813,132us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@172,813,226us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 35
@172,813,319us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 0
@172,813,414us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@172,813,506us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[4].handle's paRamAddr 0x483a0c80
@172,813,604us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 100 (Addr 0x483a0c80)
@172,813,701us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@172,813,794us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 36
@172,813,887us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 1
@172,813,979us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@172,814,106us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[5].handle's paRamAddr 0x483a0ca0
@172,814,209us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 101 (Addr 0x483a0ca0)
@172,814,308us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@173,146,934us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 37
@173,147,081us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 2
@173,147,191us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@173,147,288us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[6].handle's paRamAddr 0x483a0cc0
@173,147,397us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 102 (Addr 0x483a0cc0)
@173,147,494us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@173,147,589us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 38
@173,147,685us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Qdma: 3
@173,147,780us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned PaRam(s):
@173,147,871us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> dmaTab[7].handle's paRamAddr 0x483a0ce0
@173,147,974us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 103 (Addr 0x483a0ce0)
@173,148,069us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> Assigned Tcc(s):
@173,148,165us: [+4 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_createChannels> 39
@173,148,345us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_grantDmaChannels> Exit (status=0)
VCA: Started the VCA Rules codec on 0X5DD688
VCA: Allocating counting line intermediate buffers
VCA: Allocating 3 32 byte aligned buffers of size 2048
VCA: Allocating core intermediate buffers
VCA: Allocating 3 32 byte aligned buffers of size 15000
VCA: Allocating rule intermediate buffers
VCA: Allocating 3 32 byte aligned buffers of size 12288
ALG: VidVca: Setting up socket
ALG: VidVca: Opened socket 27
ALG: VidVca: Binded to /tmp/vcactrl
ALG: VidVca: Listened to socket
ALG: VidVca: Changed socket permissions
VCA: Creating VCA algorithm...DONE
VCA: Create...DONE
[SNIP]
AVSERVER UI: Stopping.
AVSERVER API: Sending STOP.
AVSERVER MAIN: Recevied CMD = 0x0401, state = 0x0001
AVSERVER MAIN: Delete TPP Tsks ...
VCA: Delete...
VCA: Deleting VCA codecs
VCA: Deleting VCA Counting Line codec
@210,212,516us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_releaseDmaChannels> Enter (algs=0x65a6e0, dmaFxnsArray=0x65a6e8, numAlgs=1)
@210,212,793us: [+0 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels(0x407a3000, 0x5eafd8)
@210,212,981us: [+5 T:0x4bd3a490] udpanalytics.vca_counting_line.VCA_COUNTING_LINE - VCA_COUNTING_LINE_UDPANALYTICS_dmaGetChannels: Got 8 DMA channels!
@210,213,120us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_releaseDmaChannels> Free 8 channels
@210,213,245us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - freeChannels> Enter (dmaTab=0x5eafd8, numChan=8)
@210,213,365us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - _freeChannels> Freeing channel 6669720
@210,213,482us: [+0 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_freeChannels> Enter (channelTab=0x4bd39be8, numChan=1)
@210,213,609us: [+2 T:0x4bd3a490] ti.sdo.fc.dman3 - DMAN3_freeChannels> Calling deinit on protocol on Channel 0
@210,213,735us: [+0 T:0x4bd3a490] ti.sdo.fc.acpy3 - ACPY3_deInitEnv > Enter (handle=0x65c598)
