Part Number: AM62A7
Other Parts Discussed in Thread: AM68A
Hi Teams,
I am currently debugging PaddleOCR on the AM62A and AM68A platforms. I found that most of the layers doesnot been supported by TIDL(And can not get correct result when inference via TIDL .).
Could you please advise on how to properly configure the edgeai-tidl-tools to build this model? . Alternatively, do you have any other OCR models that you have successfully debugged and verified that you could recommend. Thanks.
log:
| Conv | p2o.Conv.29 | Stride must be the same along both horizontal and vertical dimensions |
| AveragePool | p2o.AveragePool.0 | Kernel size (3x2) with stride (3x2) not supported |
| ReduceMean | p2o.ReduceMean.0 | Layer 273 - op type ReduceMean, Unknown input dimension, not supported by TIDL |
| Sub | p2o.Sub.0 | Layer 274 - op type Sub, Unknown input dimension, not supported by TIDL |
| Transpose | Transpose_token_0 | Layer 275 - op type Transpose, Unknown input dimension, not supported by TIDL |
| ReduceMean | p2o.ReduceMean.2 | Layer type not supported by TIDL |
| Slice | p2o.Slice.6 | Layer 286 - op type Slice, Unknown input dimension, not supported by TIDL |
| Slice | p2o.Slice.4 | Layer 289 - op type Slice, Unknown input dimension, not supported by TIDL |
| Slice | p2o.Slice.8 | Layer 295 - op type Slice, Unknown input dimension, not supported by TIDL |
| Squeeze | p2o.Squeeze.1 | Layer 287 - op type Squeeze, Unknown input dimension, not supported by TIDL |
| Transpose | Transpose_token_4 | Layer 290 - op type Transpose, Unknown input dimension, not supported by TIDL |
| Transpose | Transpose_token_6 | Layer 296 - op type Transpose, Unknown input dimension, not supported by TIDL |
| Transpose | p2o.Transpose.2 | Layer 288 - op type Transpose, Unknown input dimension, not supported by TIDL |
| Slice | p2o.Slice.15 | Layer 333 - op type Slice, Unknown input dimension, not supported by TIDL |
| Slice | p2o.Slice.13 | Layer 336 - op type Slice, Unknown input dimension, not supported by TIDL |
| Slice | p2o.Slice.17 | Layer 342 - op type Slice, Unknown input dimension, not supported by TIDL |
| Squeeze | p2o.Squeeze.4 | Layer 334 - op type Squeeze, Unknown input dimension, not supported by TIDL |
| Transpose | Transpose_token_11 | Layer 337 - op type Transpose, Unknown input dimension, not supported by TIDL |
| Transpose | Transpose_token_13 | Layer 343 - op type Transpose, Unknown input dimension, not supported by TIDL |
| Transpose | p2o.Transpose.5 | Layer 335 - op type Transpose, Unknown input dimension, not supported by TIDL |
