Other Parts Discussed in Thread: TMDS64EVM, SK-AM64B, SYSCONFIG, AM6441, AM6442, AM6421
Hi Bin Liu,
We need to confirm whether the approach we are currently using to bypass the EEPROM is correct or not.
Hi Manish,
There is no a "configurable" way to bypass EEPROM detect in U-Boot, but I don't recommend the approach you posted above, as it only provides partial content of the EEPROM, it might cause issues in other places where need different information in EEPROM.
If you don't change any of the U-Boot code, the EEPROM detect routine would fail due to absence of EEPROM on custom boards, but the boot process will move on. If your custom board devicetree file is still named as k3-am642-r5-evm.dtb and ti/k3-am642-evm.dtb, you don't need to change anything in U-Boot.
If your custom board uses different dtb filenames, what I recommend is to just set CONFIG_DEFAULT_DEVICE_TREE to the devicetree filename for the custom board directly in board defconfig, for both r5_defconfig and a53_defconfig.
Hi Bin Liu,
As per your suggestion, I changed the CONFIG_DEFAULT_DEVICE_TREE for both R5 and A53 to k3-am642-evm.dtb.
sqm@2sqmx4q2:~/SSD/home/manish/Siemens/backup/buildroot/output/build/uboot-2024.07/configs$ cat am64x_evm_a53_defconfig
CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am642-evm"
sqm@2sqmx4q2:~/SSD/home/manish/Siemens/backup/buildroot/output/build/uboot-2024.07/configs$ cat am64x_evm_r5_defconfig
CONFIG_DEFAULT_DEVICE_TREE="k3-am642-r5-evm"
After removing the patch that was previously added to bypass the EEPROM error, we are now seeing the following issue during boot:
U-Boot SPL 2024.07 (May 22 2026 - 19:51:23 +0530)
SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)')
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed -121
SPL initial stack usage: 13368 bytes
As you mentioned, the boot process should continue even if EEPROM detection fails. However, in our case, the board disconnects afterward, and we are unable to flash the remaining files.
Our board is based on the EVM, and we are modifying k3-am642-evm.dts. However, the changes made in this DTS are not getting applied. Surprisingly, when we make the same changes in k3-am642-sk.dts, the changes take effect correctly.
Hi Manish,
I thought you have updated to 2026.01 U-Boot, but now just realized you go back to 2024.07 U-Boot after fixed the USB DFU issue.
I will review the code to see what could be wrong.
Hi, Bin Liu,
Yes, I had updated U-Boot to 2026.01 earlier, but I was facing some issues with that build. So, the current setup is based on a fresh build using 2024.07 after fixing the USB DFU issue.
After applying the DTS changes you suggested earlier, we are now able to boot all three bootloaders successfully, on 2024.07. However, the EEPROM issue is still not resolved.
I also checked the same EEPROM issue with the 2026.01 version, and the issue was still persisting there as well.
If needed, I can also port these changes back to the 2026.01 version and test again.
Don't move to 2026.01 yet. Let me check why only changes in k3-am642-sk.dts has effect but k3-am642-evm.dts doesn't. I thought it should be opposite.
I am in the middle of a debug. I will work on your case in a day or two. (By the way, next Monday is a holiday in US, the office is closed.)
Hi Manish,
Our board is based on the EVM, and we are modifyingk3-am642-evm.dts. However, the changes made in this DTS are not getting applied. Surprisingly, when we make the same changes ink3-am642-sk.dts, the changes take effect correctly.
I am unable to reproduce the issue. Here is what I tested.
In the SDK 10.1 U-Boot, I patched it as
diff --git a/arch/arm/dts/k3-am642-evm.dts b/arch/arm/dts/k3-am642-evm.dts
index 50e80436b068..94e61f162372 100644
--- a/arch/arm/dts/k3-am642-evm.dts
+++ b/arch/arm/dts/k3-am642-evm.dts
@@ -15,7 +15,7 @@
compatible = "ti,am642-evm", "ti,am642";
- model = "Texas Instruments AM642 EVM";
+ model = "Texas Instruments AM642 EVM 1";
chosen {
stdout-path = &main_uart0;
@@ -39,7 +39,7 @@
bootph-all;
device_type = "memory";
/* 2G RAM */
- reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
+ reg = <0x00000000 0x80000000 0x00000000 0x40000000>;
reserved-memory {
diff --git a/board/ti/common/Kconfig b/board/ti/common/Kconfig
index 821f02b09fc4..f133af692450 100644
--- a/board/ti/common/Kconfig
+++ b/board/ti/common/Kconfig
@@ -13,7 +13,7 @@ config EEPROM_BUS_ADDRESS
config EEPROM_CHIP_ADDRESS
hex "Board EEPROM's I2C chip address"
range 0 0xff
- default 0x50
+ default 0x60
depends on TI_I2C_BOARD_DETECT
It basically changed the EEPROM I2C address to 0x60 which doesn't exist on the EVM. This will make board EEPROM detect to fail. I ran this new U-Boot binaries on the EVM (TMDS64EVM), and the console log (attached below) shows k3-am642-evm.dts changes are taken, the board DDR is now 1GB.
U-Boot SPL 2024.04-dirty (May 26 2026 - 12:04:49 -0500) Resetting on cold boot to workaround ErrataID:i2331 Please resend tiboot3.bin in case of UART/DFU boot resetting ... U-Boot SPL 2024.04-dirty (May 26 2026 - 12:04:49 -0500) SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)') EEPROM not available at 0x60, trying to read at 0x61 Reading on-board EEPROM at 0x61 failed -121 SPL initial stack usage: 13392 bytes Trying to boot from MMC2 Authentication passed Authentication passed Loading Environment from nowhere... OK Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.11.0(release):v2.11.0-906-g58b25570c9-dirty NOTICE: BL31: Built : 04:20:32, Nov 1 2024 I/TC: I/TC: OP-TEE version: 4.4.0-dev (gcc version 13.3.0 (GCC)) #1 Fri Oct 18 17:45:27 UTC 2024 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)') I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: SA2UL TRNG initialized I/TC: SA2UL Drivers initialized I/TC: HUK Initialized I/TC: Primary CPU switching to normal world boot U-Boot SPL 2024.04-dirty (May 26 2026 - 12:04:57 -0500) SYSFW ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)') EEPROM not available at 0x60, trying to read at 0x61 Reading on-board EEPROM at 0x61 failed -121 Trying to boot from MMC2 Authentication passed Authentication passed U-Boot 2024.04-dirty (May 26 2026 - 12:04:57 -0500) SoC: AM64X SR2.0 HS-FS Model: Texas Instruments AM642 EVM 1 EEPROM not available at 0x60, trying to read at 0x61 Reading on-board EEPROM at 0x61 failed -121 DRAM: 1 GiB Core: 98 devices, 31 uclasses, devicetree: separate NAND: 0 MiB MMC: mmc@fa10000: 0, mmc@fa00000: 1 Loading Environment from nowhere... OK In: serial@2800000 Out: serial@2800000 Err: serial@2800000 EEPROM not available at 0x60, trying to read at 0x61 Reading on-board EEPROM at 0x61 failed -121 Net: eth0: ethernet@8000000port@1 Warning: icssg1-eth-port@0 (eth2) using random MAC address - 32:e2:4e:7a:49:c9 , eth2: icssg1-eth-port@0 Hit any key to stop autoboot: 0 =>
When running the same U-Boot binaries on the SK (SK-AM64B), the console log stops at the DDR init, because without EEPROM detected, U-Boot by default takes k3-am642-evm.dtb, not k3-am642-sk.dtb.
Hi Bin Liu,
But in my case, if I remove the patch that is being used to bypass the EEPROM check, I get the error: “EEPROM not detected” followed by a disconnect issue. What should I do in this case?
Also, is there any further debugging I can do from my side to identify the root cause?
If you meant for the following messages, I have them too in my log above. They are expected when EEPROM doesn't exist.
EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121
what disconnect? DFU? Please provide details.
U-Boot SPL 2024.07 (May 27 2026 - 16:18:35 +0530) Resetting on cold boot to workaround ErrataID:i2331 Please resend tiboot3.bin in case of UART/DFU boot resetting ... U-Boot SPL 2024.07 (May 27 2026 - 16:18:35 +0530) SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 board_fit_config_name_match in. is_am64x. SPL initial stack usage: 13368 bytes
If we do not bypass the EEPROM detection, the board gets disconnected during DFU flashing, and we are unable to flash the remaining bootloader binaries.
In U-Boot source code, the DDR configuration data file is "k3-am64-evm-ddr4-1600MTs.dtsi", which is included in k3-am642-r5-evm.dts.
Did you update your custom board DDR config to file k3-am642-r5-evm.dts?
The failure in your u-boot log seems showing your DDR config data file was added to k3-am642-r5-sk.dts. (Or you updated your DDR config data to file k3-am64-sk-lp4-1600MTs.dtsi).
Hi Bin Liu,
Thanks for the clarification.
Our custom board is using LPDDR4 memory. After checking the DTS files, we observed:
k3-am642-r5-evm.dts includes:#include "k3-am64-evm-ddr4-1600MTs.dtsi"
k3-am642-r5-sk.dts includes:#include "k3-am64-sk-lp4-1600MTs.dtsi"
Currently, when the SK DTS path is selected, the board boots correctly. However, when we try to use the EVM DTS path, the boot hangs during DDR initialization.
Could this issue be happening because our custom board is LPDDR4 based, while the EVM R5 DTS is using DDR4 configuration?
Hi Manish,
Does your custom board use exactly the same LPDDR4 memory as that on the SK, and you never generated DDR config data in SYSCONFIG tool and updated it in U-Boot devicetree?
If so, you would need to update k3-am642-r5-evm.dts to include "k3-am64-sk-lp4-1600MTs.dtsi" instead. This should solve the issue.
Hi Bin Liu,
As suggested, using k3-am64-sk-lp4-1600MTs.dtsi in k3-am642-r5-evm.dts is working. The board is no longer disconnecting after the EEPROM error, and we are now able to flash the remaining bootloaders successfully using DFU.
Could you please confirm whether this change is required only in ti-k3-r5-loader-2024.07, or do we also need to apply the same DTS changes in u-boot-2024.07?
Manish
Logs :U-Boot SPL 2024.07 (May 28 2026 - 11:57:39 +0530)
resetting ...
Trying to boot from DFU
#############################################DOWNLOAD ... OK
Ctrl+C to exit ...
Loading Environment from MMC... *** Warning - No MMC card found, using default environment
init_env from device 10 not supported!
NOTICE: BL31: Built : 12:19:51, May 20 2026
I/TC:
I/TC: OP-TEE version: Unknown_4.9 (gcc version 14.3.0 (Buildroot 2026.05-rc1-31-gc17d110b10)) #1 Wed May 20 06:47:35 UTC 2026 aarch64
I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)')
I/TC: EIP76D TRNG initialized
I/TC: Disabling output console
U-Boot SPL 2024.07 (May 27 2026 - 16:54:51 +0530)
Ctrl+C to exit ...
U-Boot 2024.07 (May 27 2026 - 16:54:51 +0530)
DRAM: 2 GiB
Core: 62 devices, 30 uclasses, devicetree: separate
In: serial@2800000
Out: serial@2800000
Err: serial@2800000
Net: Could not get PHY for mdio@f00: addr 0
am65_cpsw_nuss_port ethernet@8000000port@1: phy_connect() failed
No ethernet found.
Hi Manish,
Could you please confirm whether this change is required only inti-k3-r5-loader-2024.07
Yes, the DDR config is only included in R5 SPL, which does the DDR initialization. However,
As suggested, usingk3-am64-sk-lp4-1600MTs.dtsiink3-am642-r5-evm.dtsis working.
you can not simply use this DDR config data file for your custom board. One obvious problem you can see is that your DDR is 512MB, but the U-Boot log shows DRAM is 2GB.
You need to use the SYSCONFIG tool to generate the new file for the DDR device for your board.
Hi Bin Liu,
Yes, I am facing this issue. After enabling the NAND configuration and trying to boot the kernel, the build hangs at the following logs:
[ 1.008215] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 1.018076] optee: probing for conduit method.
After this point, no further kernel logs are printed and the system appears to be stuck.
Logs attached:
Yes, very likely the kernel issue is caused by the incorrectly configured DDR.
You need to generate the DDR config for the DDR memory used on your board, using the SYSCONFIG tool.
Hi Bin Liu,
1) As suggested, we generated a custom DDR config using the SysConfig tool. However, we have a doubt — do we need to modify any parameters manually, or can we proceed with the default settings?
2) In the main dts do we need to make any changes in the memory
memory@80000000 {
bootph-all;
/* 2G RAM */
Please find the custom DTSI attached for your reference.
// SPDX-License-Identifier: GPL-2.0+ /* * This file was generated with the * AM64x SysConfig DDR Configuration Tool for AM64x, AM625, AM623, AM62Ax, AM62Px, AM62Dx, AM62Lx v0.10.40 * Thu May 28 2026 18:40:20 GMT+0530 (India Standard Time) * DDR Type: LPDDR4 * F0 = 50MHz F1 = NA F2 = 800MHz * Density (per channel): 4Gb * Write DBI: Enable * Number of Ranks: 1 */ #define DDRSS_PLL_FHS_CNT 3 #define DDRSS_PLL_FREQUENCY_1 400000000 #define DDRSS_PLL_FREQUENCY_2 400000000 #define DDRSS_SDRAM_IDX 13 #define DDRSS_REGION_IDX 15 #define DDRSS_TOOL_VERSION "0.10.40" #define DDRSS_CTL_0_DATA 0x00000B00 #define DDRSS_CTL_1_DATA 0x00000000 #define DDRSS_CTL_2_DATA 0x00000000 #define DDRSS_CTL_3_DATA 0x00000000 #define DDRSS_CTL_4_DATA 0x00000000 #define DDRSS_CTL_5_DATA 0x00000000 #define DDRSS_CTL_6_DATA 0x00000000 #define DDRSS_CTL_7_DATA 0x00002710 #define DDRSS_CTL_8_DATA 0x000186A0 #define DDRSS_CTL_9_DATA 0x00000005 #define DDRSS_CTL_10_DATA 0x00000064 #define DDRSS_CTL_11_DATA 0x00027100 #define DDRSS_CTL_12_DATA 0x00186A00 #define DDRSS_CTL_13_DATA 0x00000005 #define DDRSS_CTL_14_DATA 0x00000640 #define DDRSS_CTL_15_DATA 0x00027100 #define DDRSS_CTL_16_DATA 0x00186A00 #define DDRSS_CTL_17_DATA 0x00000005 #define DDRSS_CTL_18_DATA 0x00000640 #define DDRSS_CTL_19_DATA 0x01010100 #define DDRSS_CTL_20_DATA 0x01010100 #define DDRSS_CTL_21_DATA 0x01000110 #define DDRSS_CTL_22_DATA 0x02010002 #define DDRSS_CTL_23_DATA 0x0000000A #define DDRSS_CTL_24_DATA 0x000186A0 #define DDRSS_CTL_25_DATA 0x00000000 #define DDRSS_CTL_26_DATA 0x00000000 #define DDRSS_CTL_27_DATA 0x00000000 #define DDRSS_CTL_28_DATA 0x00000000 #define DDRSS_CTL_29_DATA 0x00020200 #define DDRSS_CTL_30_DATA 0x00000000 #define DDRSS_CTL_31_DATA 0x00000000 #define DDRSS_CTL_32_DATA 0x00000000 #define DDRSS_CTL_33_DATA 0x00000000 #define DDRSS_CTL_34_DATA 0x08000010 #define DDRSS_CTL_35_DATA 0x00002020 #define DDRSS_CTL_36_DATA 0x00000000 #define DDRSS_CTL_37_DATA 0x00000000 #define DDRSS_CTL_38_DATA 0x0000040C #define DDRSS_CTL_39_DATA 0x00000000 #define DDRSS_CTL_40_DATA 0x0000081C #define DDRSS_CTL_41_DATA 0x00000000 #define DDRSS_CTL_42_DATA 0x0000081C #define DDRSS_CTL_43_DATA 0x00000000 #define DDRSS_CTL_44_DATA 0x05000804 #define DDRSS_CTL_45_DATA 0x00000700 #define DDRSS_CTL_46_DATA 0x09090004 #define DDRSS_CTL_47_DATA 0x00000203 #define DDRSS_CTL_48_DATA 0x00320007 #define DDRSS_CTL_49_DATA 0x09090023 #define DDRSS_CTL_50_DATA 0x0000190F #define DDRSS_CTL_51_DATA 0x00320007 #define DDRSS_CTL_52_DATA 0x09090023 #define DDRSS_CTL_53_DATA 0x0900190F #define DDRSS_CTL_54_DATA 0x000A0A09 #define DDRSS_CTL_55_DATA 0x040006DB #define DDRSS_CTL_56_DATA 0x09092004 #define DDRSS_CTL_57_DATA 0x00000C0A #define DDRSS_CTL_58_DATA 0x06006DB0 #define DDRSS_CTL_59_DATA 0x09092006 #define DDRSS_CTL_60_DATA 0x00000C0A #define DDRSS_CTL_61_DATA 0x06006DB0 #define DDRSS_CTL_62_DATA 0x03042006 #define DDRSS_CTL_63_DATA 0x04050002 #define DDRSS_CTL_64_DATA 0x100F100F #define DDRSS_CTL_65_DATA 0x01010008 #define DDRSS_CTL_66_DATA 0x041F1F07 #define DDRSS_CTL_67_DATA 0x03111103 #define DDRSS_CTL_68_DATA 0x00001111 #define DDRSS_CTL_69_DATA 0x00000101 #define DDRSS_CTL_70_DATA 0x00000000 #define DDRSS_CTL_71_DATA 0x01000000 #define DDRSS_CTL_72_DATA 0x00130803 #define DDRSS_CTL_73_DATA 0x000000BB #define DDRSS_CTL_74_DATA 0x00000130 #define DDRSS_CTL_75_DATA 0x00000C28 #define DDRSS_CTL_76_DATA 0x00000130 #define DDRSS_CTL_77_DATA 0x00000C28 #define DDRSS_CTL_78_DATA 0x00000005 #define DDRSS_CTL_79_DATA 0x0000000A #define DDRSS_CTL_80_DATA 0x00000010 #define DDRSS_CTL_81_DATA 0x00000098 #define DDRSS_CTL_82_DATA 0x0000017E #define DDRSS_CTL_83_DATA 0x00000098 #define DDRSS_CTL_84_DATA 0x0000017E #define DDRSS_CTL_85_DATA 0x03004000 #define DDRSS_CTL_86_DATA 0x00001201 #define DDRSS_CTL_87_DATA 0x00060005 #define DDRSS_CTL_88_DATA 0x00000006 #define DDRSS_CTL_89_DATA 0x00000000 #define DDRSS_CTL_90_DATA 0x05121208 #define DDRSS_CTL_91_DATA 0x05030A05 #define DDRSS_CTL_92_DATA 0x05030C06 #define DDRSS_CTL_93_DATA 0x01030C06 #define DDRSS_CTL_94_DATA 0x02010201 #define DDRSS_CTL_95_DATA 0x00001401 #define DDRSS_CTL_96_DATA 0x01360014 #define DDRSS_CTL_97_DATA 0x01360136 #define DDRSS_CTL_98_DATA 0x00000136 #define DDRSS_CTL_99_DATA 0x00000000 #define DDRSS_CTL_100_DATA 0x05010303 #define DDRSS_CTL_101_DATA 0x0C040505 #define DDRSS_CTL_102_DATA 0x06050203 #define DDRSS_CTL_103_DATA 0x030C0605 #define DDRSS_CTL_104_DATA 0x05060502 #define DDRSS_CTL_105_DATA 0x03030306 #define DDRSS_CTL_106_DATA 0x03010000 #define DDRSS_CTL_107_DATA 0x00010000 #define DDRSS_CTL_108_DATA 0x00000000 #define DDRSS_CTL_109_DATA 0x01000000 #define DDRSS_CTL_110_DATA 0x80104002 #define DDRSS_CTL_111_DATA 0x00040003 #define DDRSS_CTL_112_DATA 0x00040005 #define DDRSS_CTL_113_DATA 0x00030000 #define DDRSS_CTL_114_DATA 0x00050004 #define DDRSS_CTL_115_DATA 0x00000004 #define DDRSS_CTL_116_DATA 0x00040003 #define DDRSS_CTL_117_DATA 0x00040005 #define DDRSS_CTL_118_DATA 0x00000000 #define DDRSS_CTL_119_DATA 0x00002EC0 #define DDRSS_CTL_120_DATA 0x00002EC0 #define DDRSS_CTL_121_DATA 0x00002EC0 #define DDRSS_CTL_122_DATA 0x00002EC0 #define DDRSS_CTL_123_DATA 0x00002EC0 #define DDRSS_CTL_124_DATA 0x00000000 #define DDRSS_CTL_125_DATA 0x0000051D #define DDRSS_CTL_126_DATA 0x00030A00 #define DDRSS_CTL_127_DATA 0x00030A00 #define DDRSS_CTL_128_DATA 0x00030A00 #define DDRSS_CTL_129_DATA 0x00030A00 #define DDRSS_CTL_130_DATA 0x00030A00 #define DDRSS_CTL_131_DATA 0x00000000 #define DDRSS_CTL_132_DATA 0x00005518 #define DDRSS_CTL_133_DATA 0x00030A00 #define DDRSS_CTL_134_DATA 0x00030A00 #define DDRSS_CTL_135_DATA 0x00030A00 #define DDRSS_CTL_136_DATA 0x00030A00 #define DDRSS_CTL_137_DATA 0x00030A00 #define DDRSS_CTL_138_DATA 0x00000000 #define DDRSS_CTL_139_DATA 0x00005518 #define DDRSS_CTL_140_DATA 0x00000000 #define DDRSS_CTL_141_DATA 0x00000000 #define DDRSS_CTL_142_DATA 0x00000000 #define DDRSS_CTL_143_DATA 0x00000000 #define DDRSS_CTL_144_DATA 0x00000000 #define DDRSS_CTL_145_DATA 0x00000000 #define DDRSS_CTL_146_DATA 0x00000000 #define DDRSS_CTL_147_DATA 0x00000000 #define DDRSS_CTL_148_DATA 0x00000000 #define DDRSS_CTL_149_DATA 0x00000000 #define DDRSS_CTL_150_DATA 0x00000000 #define DDRSS_CTL_151_DATA 0x00000000 #define DDRSS_CTL_152_DATA 0x00000000 #define DDRSS_CTL_153_DATA 0x00000000 #define DDRSS_CTL_154_DATA 0x00000000 #define DDRSS_CTL_155_DATA 0x00000000 #define DDRSS_CTL_156_DATA 0x03050000 #define DDRSS_CTL_157_DATA 0x03050305 #define DDRSS_CTL_158_DATA 0x00000000 #define DDRSS_CTL_159_DATA 0x07010A09 #define DDRSS_CTL_160_DATA 0x000E0A09 #define DDRSS_CTL_161_DATA 0x010A0900 #define DDRSS_CTL_162_DATA 0x0E0A0907 #define DDRSS_CTL_163_DATA 0x0A090000 #define DDRSS_CTL_164_DATA 0x0A090701 #define DDRSS_CTL_165_DATA 0x0000080E #define DDRSS_CTL_166_DATA 0x00040003 #define DDRSS_CTL_167_DATA 0x00000007 #define DDRSS_CTL_168_DATA 0x00000000 #define DDRSS_CTL_169_DATA 0x00000000 #define DDRSS_CTL_170_DATA 0x00000000 #define DDRSS_CTL_171_DATA 0x00000000 #define DDRSS_CTL_172_DATA 0x00000000 #define DDRSS_CTL_173_DATA 0x00000000 #define DDRSS_CTL_174_DATA 0x01000000 #define DDRSS_CTL_175_DATA 0x00000000 #define DDRSS_CTL_176_DATA 0x00001500 #define DDRSS_CTL_177_DATA 0x0000100E #define DDRSS_CTL_178_DATA 0x00000002 #define DDRSS_CTL_179_DATA 0x00000000 #define DDRSS_CTL_180_DATA 0x00000001 #define DDRSS_CTL_181_DATA 0x00000002 #define DDRSS_CTL_182_DATA 0x00000C00 #define DDRSS_CTL_183_DATA 0x00001000 #define DDRSS_CTL_184_DATA 0x00000C00 #define DDRSS_CTL_185_DATA 0x00001000 #define DDRSS_CTL_186_DATA 0x00000C00 #define DDRSS_CTL_187_DATA 0x00001000 #define DDRSS_CTL_188_DATA 0x00000000 #define DDRSS_CTL_189_DATA 0x00000000 #define DDRSS_CTL_190_DATA 0x00000000 #define DDRSS_CTL_191_DATA 0x00000000 #define DDRSS_CTL_192_DATA 0x0005000A #define DDRSS_CTL_193_DATA 0x0404000D #define DDRSS_CTL_194_DATA 0x0000000D #define DDRSS_CTL_195_DATA 0x005000A0 #define DDRSS_CTL_196_DATA 0x060600C8 #define DDRSS_CTL_197_DATA 0x000000C8 #define DDRSS_CTL_198_DATA 0x005000A0 #define DDRSS_CTL_199_DATA 0x060600C8 #define DDRSS_CTL_200_DATA 0x000000C8 #define DDRSS_CTL_201_DATA 0x00000000 #define DDRSS_CTL_202_DATA 0x00000000 #define DDRSS_CTL_203_DATA 0x00000000 #define DDRSS_CTL_204_DATA 0x00000000 #define DDRSS_CTL_205_DATA 0x00000004 #define DDRSS_CTL_206_DATA 0x00000000 #define DDRSS_CTL_207_DATA 0x00000000 #define DDRSS_CTL_208_DATA 0x00000024 #define DDRSS_CTL_209_DATA 0x00000012 #define DDRSS_CTL_210_DATA 0x00000000 #define DDRSS_CTL_211_DATA 0x00000024 #define DDRSS_CTL_212_DATA 0x00000012 #define DDRSS_CTL_213_DATA 0x00000000 #define DDRSS_CTL_214_DATA 0x00000004 #define DDRSS_CTL_215_DATA 0x00000000 #define DDRSS_CTL_216_DATA 0x00000000 #define DDRSS_CTL_217_DATA 0x00000024 #define DDRSS_CTL_218_DATA 0x00000012 #define DDRSS_CTL_219_DATA 0x00000000 #define DDRSS_CTL_220_DATA 0x00000024 #define DDRSS_CTL_221_DATA 0x00000012 #define DDRSS_CTL_222_DATA 0x00000000 #define DDRSS_CTL_223_DATA 0x00000000 #define DDRSS_CTL_224_DATA 0x00000031 #define DDRSS_CTL_225_DATA 0x000000B1 #define DDRSS_CTL_226_DATA 0x000000B1 #define DDRSS_CTL_227_DATA 0x00000031 #define DDRSS_CTL_228_DATA 0x000000B1 #define DDRSS_CTL_229_DATA 0x000000B1 #define DDRSS_CTL_230_DATA 0x00000000 #define DDRSS_CTL_231_DATA 0x00000000 #define DDRSS_CTL_232_DATA 0x00000000 #define DDRSS_CTL_233_DATA 0x00000000 #define DDRSS_CTL_234_DATA 0x00000000 #define DDRSS_CTL_235_DATA 0x00000000 #define DDRSS_CTL_236_DATA 0x00000000 #define DDRSS_CTL_237_DATA 0x00000000 #define DDRSS_CTL_238_DATA 0x00000000 #define DDRSS_CTL_239_DATA 0x00000000 #define DDRSS_CTL_240_DATA 0x00000000 #define DDRSS_CTL_241_DATA 0x00000000 #define DDRSS_CTL_242_DATA 0x00000000 #define DDRSS_CTL_243_DATA 0x00000000 #define DDRSS_CTL_244_DATA 0x00000000 #define DDRSS_CTL_245_DATA 0x00000000 #define DDRSS_CTL_246_DATA 0x00000000 #define DDRSS_CTL_247_DATA 0x00000000 #define DDRSS_CTL_248_DATA 0x00000000 #define DDRSS_CTL_249_DATA 0x00000000 #define DDRSS_CTL_250_DATA 0x00000000 #define DDRSS_CTL_251_DATA 0x00000000 #define DDRSS_CTL_252_DATA 0x00000000 #define DDRSS_CTL_253_DATA 0x00000000 #define DDRSS_CTL_254_DATA 0x46004646 #define DDRSS_CTL_255_DATA 0x00002746 #define DDRSS_CTL_256_DATA 0x00000027 #define DDRSS_CTL_257_DATA 0x00000027 #define DDRSS_CTL_258_DATA 0x00000027 #define DDRSS_CTL_259_DATA 0x00000027 #define DDRSS_CTL_260_DATA 0x00000027 #define DDRSS_CTL_261_DATA 0x00000000 #define DDRSS_CTL_262_DATA 0x00000000 #define DDRSS_CTL_263_DATA 0x0000000F #define DDRSS_CTL_264_DATA 0x0000000F #define DDRSS_CTL_265_DATA 0x0000000F #define DDRSS_CTL_266_DATA 0x0000000F #define DDRSS_CTL_267_DATA 0x0000000F #define DDRSS_CTL_268_DATA 0x0000000F #define DDRSS_CTL_269_DATA 0x00000000 #define DDRSS_CTL_270_DATA 0x00001000 #define DDRSS_CTL_271_DATA 0x00000015 #define DDRSS_CTL_272_DATA 0x00000015 #define DDRSS_CTL_273_DATA 0x00000010 #define DDRSS_CTL_274_DATA 0x00000015 #define DDRSS_CTL_275_DATA 0x00000015 #define DDRSS_CTL_276_DATA 0x00000020 #define DDRSS_CTL_277_DATA 0x00010000 #define DDRSS_CTL_278_DATA 0x00000100 #define DDRSS_CTL_279_DATA 0x00000000 #define DDRSS_CTL_280_DATA 0x00000000 #define DDRSS_CTL_281_DATA 0x00000101 #define DDRSS_CTL_282_DATA 0x00000000 #define DDRSS_CTL_283_DATA 0x00000000 #define DDRSS_CTL_284_DATA 0x00000000 #define DDRSS_CTL_285_DATA 0x00000000 #define DDRSS_CTL_286_DATA 0x00000000 #define DDRSS_CTL_287_DATA 0x00000000 #define DDRSS_CTL_288_DATA 0x00000000 #define DDRSS_CTL_289_DATA 0x00000000 #define DDRSS_CTL_290_DATA 0x0C181511 #define DDRSS_CTL_291_DATA 0x00000304 #define DDRSS_CTL_292_DATA 0x00000000 #define DDRSS_CTL_293_DATA 0x00000000 #define DDRSS_CTL_294_DATA 0x00000000 #define DDRSS_CTL_295_DATA 0x00000000 #define DDRSS_CTL_296_DATA 0x00000000 #define DDRSS_CTL_297_DATA 0x00000000 #define DDRSS_CTL_298_DATA 0x00000000 #define DDRSS_CTL_299_DATA 0x00000000 #define DDRSS_CTL_300_DATA 0x00000000 #define DDRSS_CTL_301_DATA 0x00000000 #define DDRSS_CTL_302_DATA 0x00000000 #define DDRSS_CTL_303_DATA 0x00000000 #define DDRSS_CTL_304_DATA 0x00000000 #define DDRSS_CTL_305_DATA 0x00020000 #define DDRSS_CTL_306_DATA 0x00400100 #define DDRSS_CTL_307_DATA 0x00080032 #define DDRSS_CTL_308_DATA 0x01000200 #define DDRSS_CTL_309_DATA 0x03200040 #define DDRSS_CTL_310_DATA 0x00020018 #define DDRSS_CTL_311_DATA 0x00400100 #define DDRSS_CTL_312_DATA 0x00180320 #define DDRSS_CTL_313_DATA 0x00030000 #define DDRSS_CTL_314_DATA 0x00280028 #define DDRSS_CTL_315_DATA 0x00000100 #define DDRSS_CTL_316_DATA 0x01010000 #define DDRSS_CTL_317_DATA 0x00000202 #define DDRSS_CTL_318_DATA 0x0FFF0000 #define DDRSS_CTL_319_DATA 0x000FFF00 #define DDRSS_CTL_320_DATA 0xFFFFFFFF #define DDRSS_CTL_321_DATA 0x00FFFF00 #define DDRSS_CTL_322_DATA 0x0B000000 #define DDRSS_CTL_323_DATA 0x0001FFFF #define DDRSS_CTL_324_DATA 0x01010101 #define DDRSS_CTL_325_DATA 0x01010101 #define DDRSS_CTL_326_DATA 0x00000118 #define DDRSS_CTL_327_DATA 0x00000C01 #define DDRSS_CTL_328_DATA 0x01000100 #define DDRSS_CTL_329_DATA 0x00000000 #define DDRSS_CTL_330_DATA 0x00000000 #define DDRSS_CTL_331_DATA 0x01030303 #define DDRSS_CTL_332_DATA 0x00000001 #define DDRSS_CTL_333_DATA 0x00000000 #define DDRSS_CTL_334_DATA 0x00000000 #define DDRSS_CTL_335_DATA 0x00000000 #define DDRSS_CTL_336_DATA 0x00000000 #define DDRSS_CTL_337_DATA 0x00000000 #define DDRSS_CTL_338_DATA 0x00000000 #define DDRSS_CTL_339_DATA 0x00000000 #define DDRSS_CTL_340_DATA 0x00000000 #define DDRSS_CTL_341_DATA 0x00000000 #define DDRSS_CTL_342_DATA 0x00000000 #define DDRSS_CTL_343_DATA 0x00000000 #define DDRSS_CTL_344_DATA 0x00000000 #define DDRSS_CTL_345_DATA 0x00000000 #define DDRSS_CTL_346_DATA 0x00000000 #define DDRSS_CTL_347_DATA 0x00000000 #define DDRSS_CTL_348_DATA 0x00000000 #define DDRSS_CTL_349_DATA 0x00000000 #define DDRSS_CTL_350_DATA 0x00000000 #define DDRSS_CTL_351_DATA 0x00000000 #define DDRSS_CTL_352_DATA 0x00000000 #define DDRSS_CTL_353_DATA 0x00000000 #define DDRSS_CTL_354_DATA 0x00000000 #define DDRSS_CTL_355_DATA 0x00000000 #define DDRSS_CTL_356_DATA 0x00000000 #define DDRSS_CTL_357_DATA 0x00000000 #define DDRSS_CTL_358_DATA 0x00000000 #define DDRSS_CTL_359_DATA 0x00000000 #define DDRSS_CTL_360_DATA 0x00000000 #define DDRSS_CTL_361_DATA 0x00000000 #define DDRSS_CTL_362_DATA 0x00000000 #define DDRSS_CTL_363_DATA 0x00000000 #define DDRSS_CTL_364_DATA 0x00000000 #define DDRSS_CTL_365_DATA 0x00000000 #define DDRSS_CTL_366_DATA 0x00000000 #define DDRSS_CTL_367_DATA 0x00000000 #define DDRSS_CTL_368_DATA 0x00000000 #define DDRSS_CTL_369_DATA 0x00000000 #define DDRSS_CTL_370_DATA 0x00000000 #define DDRSS_CTL_371_DATA 0x01000101 #define DDRSS_CTL_372_DATA 0x01010001 #define DDRSS_CTL_373_DATA 0x00010101 #define DDRSS_CTL_374_DATA 0x01050503 #define DDRSS_CTL_375_DATA 0x05020201 #define DDRSS_CTL_376_DATA 0x08080C0C #define DDRSS_CTL_377_DATA 0x00080308 #define DDRSS_CTL_378_DATA 0x000B030E #define DDRSS_CTL_379_DATA 0x000B0310 #define DDRSS_CTL_380_DATA 0x0B0B0810 #define DDRSS_CTL_381_DATA 0x01000000 #define DDRSS_CTL_382_DATA 0x03020301 #define DDRSS_CTL_383_DATA 0x04000102 #define DDRSS_CTL_384_DATA 0x1B000004 #define DDRSS_CTL_385_DATA 0x00000176 #define DDRSS_CTL_386_DATA 0x00000200 #define DDRSS_CTL_387_DATA 0x00000200 #define DDRSS_CTL_388_DATA 0x00000200 #define DDRSS_CTL_389_DATA 0x00000200 #define DDRSS_CTL_390_DATA 0x00000693 #define DDRSS_CTL_391_DATA 0x00000E9C #define DDRSS_CTL_392_DATA 0x03050202 #define DDRSS_CTL_393_DATA 0x00250201 #define DDRSS_CTL_394_DATA 0x00001850 #define DDRSS_CTL_395_DATA 0x00000200 #define DDRSS_CTL_396_DATA 0x00000200 #define DDRSS_CTL_397_DATA 0x00000200 #define DDRSS_CTL_398_DATA 0x00000200 #define DDRSS_CTL_399_DATA 0x00006D68 #define DDRSS_CTL_400_DATA 0x0000F320 #define DDRSS_CTL_401_DATA 0x070D0402 #define DDRSS_CTL_402_DATA 0x00250405 #define DDRSS_CTL_403_DATA 0x00001850 #define DDRSS_CTL_404_DATA 0x00000200 #define DDRSS_CTL_405_DATA 0x00000200 #define DDRSS_CTL_406_DATA 0x00000200 #define DDRSS_CTL_407_DATA 0x00000200 #define DDRSS_CTL_408_DATA 0x00006D68 #define DDRSS_CTL_409_DATA 0x0000F320 #define DDRSS_CTL_410_DATA 0x070D0402 #define DDRSS_CTL_411_DATA 0x00000405 #define DDRSS_CTL_412_DATA 0x00000000 #define DDRSS_CTL_413_DATA 0x0302000A #define DDRSS_CTL_414_DATA 0x01000500 #define DDRSS_CTL_415_DATA 0x01010001 #define DDRSS_CTL_416_DATA 0x00010001 #define DDRSS_CTL_417_DATA 0x01010001 #define DDRSS_CTL_418_DATA 0x02010000 #define DDRSS_CTL_419_DATA 0x00000200 #define DDRSS_CTL_420_DATA 0x02000201 #define DDRSS_CTL_421_DATA 0x10100600 #define DDRSS_CTL_422_DATA 0x00202020 #define DDRSS_PI_0_DATA 0x00000B00 #define DDRSS_PI_1_DATA 0x00000000 #define DDRSS_PI_2_DATA 0x00000000 #define DDRSS_PI_3_DATA 0x01000000 #define DDRSS_PI_4_DATA 0x00000001 #define DDRSS_PI_5_DATA 0x00010064 #define DDRSS_PI_6_DATA 0x00000000 #define DDRSS_PI_7_DATA 0x00000000 #define DDRSS_PI_8_DATA 0x00000000 #define DDRSS_PI_9_DATA 0x00000000 #define DDRSS_PI_10_DATA 0x00000000 #define DDRSS_PI_11_DATA 0x00000002 #define DDRSS_PI_12_DATA 0x00000005 #define DDRSS_PI_13_DATA 0x00010001 #define DDRSS_PI_14_DATA 0x08000000 #define DDRSS_PI_15_DATA 0x00010300 #define DDRSS_PI_16_DATA 0x00000005 #define DDRSS_PI_17_DATA 0x00000000 #define DDRSS_PI_18_DATA 0x00000000 #define DDRSS_PI_19_DATA 0x00000000 #define DDRSS_PI_20_DATA 0x00000000 #define DDRSS_PI_21_DATA 0x00000000 #define DDRSS_PI_22_DATA 0x00000000 #define DDRSS_PI_23_DATA 0x00010000 #define DDRSS_PI_24_DATA 0x280A0001 #define DDRSS_PI_25_DATA 0x00000000 #define DDRSS_PI_26_DATA 0x00010000 #define DDRSS_PI_27_DATA 0x00003200 #define DDRSS_PI_28_DATA 0x00000000 #define DDRSS_PI_29_DATA 0x00000000 #define DDRSS_PI_30_DATA 0x01010102 #define DDRSS_PI_31_DATA 0x00000000 #define DDRSS_PI_32_DATA 0x00000000 #define DDRSS_PI_33_DATA 0x00000000 #define DDRSS_PI_34_DATA 0x00000001 #define DDRSS_PI_35_DATA 0x000000AA #define DDRSS_PI_36_DATA 0x00000055 #define DDRSS_PI_37_DATA 0x000000B5 #define DDRSS_PI_38_DATA 0x0000004A #define DDRSS_PI_39_DATA 0x00000056 #define DDRSS_PI_40_DATA 0x000000A9 #define DDRSS_PI_41_DATA 0x000000A9 #define DDRSS_PI_42_DATA 0x000000B5 #define DDRSS_PI_43_DATA 0x00000000 #define DDRSS_PI_44_DATA 0x00000000 #define DDRSS_PI_45_DATA 0x00010100 #define DDRSS_PI_46_DATA 0x00000015 #define DDRSS_PI_47_DATA 0x000007D0 #define DDRSS_PI_48_DATA 0x00000300 #define DDRSS_PI_49_DATA 0x00000000 #define DDRSS_PI_50_DATA 0x00000000 #define DDRSS_PI_51_DATA 0x01000000 #define DDRSS_PI_52_DATA 0x00010101 #define DDRSS_PI_53_DATA 0x01000000 #define DDRSS_PI_54_DATA 0x03000000 #define DDRSS_PI_55_DATA 0x00000000 #define DDRSS_PI_56_DATA 0x00001701 #define DDRSS_PI_57_DATA 0x00000000 #define DDRSS_PI_58_DATA 0x00000000 #define DDRSS_PI_59_DATA 0x00000000 #define DDRSS_PI_60_DATA 0x0A0A140A #define DDRSS_PI_61_DATA 0x10020101 #define DDRSS_PI_62_DATA 0x01000210 #define DDRSS_PI_63_DATA 0x05000404 #define DDRSS_PI_64_DATA 0x00010001 #define DDRSS_PI_65_DATA 0x0001000E #define DDRSS_PI_66_DATA 0x01010100 #define DDRSS_PI_67_DATA 0x00010000 #define DDRSS_PI_68_DATA 0x00000034 #define DDRSS_PI_69_DATA 0x00000000 #define DDRSS_PI_70_DATA 0x00000000 #define DDRSS_PI_71_DATA 0x0000FFFF #define DDRSS_PI_72_DATA 0x00000000 #define DDRSS_PI_73_DATA 0x00000000 #define DDRSS_PI_74_DATA 0x00000000 #define DDRSS_PI_75_DATA 0x00000000 #define DDRSS_PI_76_DATA 0x01000000 #define DDRSS_PI_77_DATA 0x08020100 #define DDRSS_PI_78_DATA 0x00020000 #define DDRSS_PI_79_DATA 0x00010002 #define DDRSS_PI_80_DATA 0x00000001 #define DDRSS_PI_81_DATA 0x00020001 #define DDRSS_PI_82_DATA 0x00020002 #define DDRSS_PI_83_DATA 0x00000000 #define DDRSS_PI_84_DATA 0x00000000 #define DDRSS_PI_85_DATA 0x00000000 #define DDRSS_PI_86_DATA 0x00000000 #define DDRSS_PI_87_DATA 0x00000000 #define DDRSS_PI_88_DATA 0x00000000 #define DDRSS_PI_89_DATA 0x00000000 #define DDRSS_PI_90_DATA 0x00000000 #define DDRSS_PI_91_DATA 0x00000400 #define DDRSS_PI_92_DATA 0x0A090B0C #define DDRSS_PI_93_DATA 0x04060708 #define DDRSS_PI_94_DATA 0x01000005 #define DDRSS_PI_95_DATA 0x00000800 #define DDRSS_PI_96_DATA 0x00000000 #define DDRSS_PI_97_DATA 0x00010008 #define DDRSS_PI_98_DATA 0x00000000 #define DDRSS_PI_99_DATA 0x0000AA00 #define DDRSS_PI_100_DATA 0x00000000 #define DDRSS_PI_101_DATA 0x00010000 #define DDRSS_PI_102_DATA 0x00000000 #define DDRSS_PI_103_DATA 0x00000000 #define DDRSS_PI_104_DATA 0x00000000 #define DDRSS_PI_105_DATA 0x00000000 #define DDRSS_PI_106_DATA 0x00000000 #define DDRSS_PI_107_DATA 0x00000000 #define DDRSS_PI_108_DATA 0x00000000 #define DDRSS_PI_109_DATA 0x00000000 #define DDRSS_PI_110_DATA 0x00000000 #define DDRSS_PI_111_DATA 0x00000000 #define DDRSS_PI_112_DATA 0x00000000 #define DDRSS_PI_113_DATA 0x00000000 #define DDRSS_PI_114_DATA 0x00000000 #define DDRSS_PI_115_DATA 0x00000000 #define DDRSS_PI_116_DATA 0x00000000 #define DDRSS_PI_117_DATA 0x00000000 #define DDRSS_PI_118_DATA 0x00000000 #define DDRSS_PI_119_DATA 0x00000000 #define DDRSS_PI_120_DATA 0x00000000 #define DDRSS_PI_121_DATA 0x00000000 #define DDRSS_PI_122_DATA 0x00000000 #define DDRSS_PI_123_DATA 0x00000000 #define DDRSS_PI_124_DATA 0x00000008 #define DDRSS_PI_125_DATA 0x00000000 #define DDRSS_PI_126_DATA 0x00000000 #define DDRSS_PI_127_DATA 0x00000000 #define DDRSS_PI_128_DATA 0x00000000 #define DDRSS_PI_129_DATA 0x00000000 #define DDRSS_PI_130_DATA 0x00000000 #define DDRSS_PI_131_DATA 0x00000000 #define DDRSS_PI_132_DATA 0x00000000 #define DDRSS_PI_133_DATA 0x00010000 #define DDRSS_PI_134_DATA 0x00000000 #define DDRSS_PI_135_DATA 0x00000000 #define DDRSS_PI_136_DATA 0x0000000A #define DDRSS_PI_137_DATA 0x000186A0 #define DDRSS_PI_138_DATA 0x00000100 #define DDRSS_PI_139_DATA 0x00000000 #define DDRSS_PI_140_DATA 0x00000000 #define DDRSS_PI_141_DATA 0x00000000 #define DDRSS_PI_142_DATA 0x00000000 #define DDRSS_PI_143_DATA 0x00000000 #define DDRSS_PI_144_DATA 0x01000000 #define DDRSS_PI_145_DATA 0x00010003 #define DDRSS_PI_146_DATA 0x02000101 #define DDRSS_PI_147_DATA 0x01030001 #define DDRSS_PI_148_DATA 0x00010400 #define DDRSS_PI_149_DATA 0x06000105 #define DDRSS_PI_150_DATA 0x01070001 #define DDRSS_PI_151_DATA 0x00000000 #define DDRSS_PI_152_DATA 0x00000000 #define DDRSS_PI_153_DATA 0x00000000 #define DDRSS_PI_154_DATA 0x00010001 #define DDRSS_PI_155_DATA 0x00000000 #define DDRSS_PI_156_DATA 0x00000000 #define DDRSS_PI_157_DATA 0x00000000 #define DDRSS_PI_158_DATA 0x00000000 #define DDRSS_PI_159_DATA 0x00010000 #define DDRSS_PI_160_DATA 0x00000004 #define DDRSS_PI_161_DATA 0x00000000 #define DDRSS_PI_162_DATA 0x00000000 #define DDRSS_PI_163_DATA 0x00000000 #define DDRSS_PI_164_DATA 0x00000800 #define DDRSS_PI_165_DATA 0x00780078 #define DDRSS_PI_166_DATA 0x00101001 #define DDRSS_PI_167_DATA 0x00000034 #define DDRSS_PI_168_DATA 0x00000042 #define DDRSS_PI_169_DATA 0x00020042 #define DDRSS_PI_170_DATA 0x02000200 #define DDRSS_PI_171_DATA 0x00000004 #define DDRSS_PI_172_DATA 0x0000080C #define DDRSS_PI_173_DATA 0x00081C00 #define DDRSS_PI_174_DATA 0x001C0000 #define DDRSS_PI_175_DATA 0x00000013 #define DDRSS_PI_176_DATA 0x000000BB #define DDRSS_PI_177_DATA 0x00000130 #define DDRSS_PI_178_DATA 0x00000C28 #define DDRSS_PI_179_DATA 0x00000130 #define DDRSS_PI_180_DATA 0x04000C28 #define DDRSS_PI_181_DATA 0x01010404 #define DDRSS_PI_182_DATA 0x00001501 #define DDRSS_PI_183_DATA 0x001D001D #define DDRSS_PI_184_DATA 0x01000100 #define DDRSS_PI_185_DATA 0x00000100 #define DDRSS_PI_186_DATA 0x00000000 #define DDRSS_PI_187_DATA 0x05050503 #define DDRSS_PI_188_DATA 0x01010C0C #define DDRSS_PI_189_DATA 0x01010101 #define DDRSS_PI_190_DATA 0x000C0C0A #define DDRSS_PI_191_DATA 0x00000000 #define DDRSS_PI_192_DATA 0x00000000 #define DDRSS_PI_193_DATA 0x04000000 #define DDRSS_PI_194_DATA 0x04020808 #define DDRSS_PI_195_DATA 0x04040204 #define DDRSS_PI_196_DATA 0x00090031 #define DDRSS_PI_197_DATA 0x00110039 #define DDRSS_PI_198_DATA 0x00110039 #define DDRSS_PI_199_DATA 0x01010101 #define DDRSS_PI_200_DATA 0x0002000D #define DDRSS_PI_201_DATA 0x000200C8 #define DDRSS_PI_202_DATA 0x010000C8 #define DDRSS_PI_203_DATA 0x000E000E #define DDRSS_PI_204_DATA 0x00C90100 #define DDRSS_PI_205_DATA 0x010000C9 #define DDRSS_PI_206_DATA 0x00C900C9 #define DDRSS_PI_207_DATA 0x321E3200 #define DDRSS_PI_208_DATA 0x0101321E #define DDRSS_PI_209_DATA 0x0A070601 #define DDRSS_PI_210_DATA 0x0D09070D #define DDRSS_PI_211_DATA 0x0D09070D #define DDRSS_PI_212_DATA 0x000C000D #define DDRSS_PI_213_DATA 0x00001000 #define DDRSS_PI_214_DATA 0x00000C00 #define DDRSS_PI_215_DATA 0x00001000 #define DDRSS_PI_216_DATA 0x00000C00 #define DDRSS_PI_217_DATA 0x02001000 #define DDRSS_PI_218_DATA 0x0016000D #define DDRSS_PI_219_DATA 0x001600C8 #define DDRSS_PI_220_DATA 0x000000C8 #define DDRSS_PI_221_DATA 0x00001900 #define DDRSS_PI_222_DATA 0x32000056 #define DDRSS_PI_223_DATA 0x06000101 #define DDRSS_PI_224_DATA 0x001D0204 #define DDRSS_PI_225_DATA 0x32120058 #define DDRSS_PI_226_DATA 0x05000101 #define DDRSS_PI_227_DATA 0x001D0408 #define DDRSS_PI_228_DATA 0x32120058 #define DDRSS_PI_229_DATA 0x05000101 #define DDRSS_PI_230_DATA 0x00000408 #define DDRSS_PI_231_DATA 0x05030900 #define DDRSS_PI_232_DATA 0x00040900 #define DDRSS_PI_233_DATA 0x0000062B #define DDRSS_PI_234_DATA 0x20010004 #define DDRSS_PI_235_DATA 0x0A0A0A03 #define DDRSS_PI_236_DATA 0x11090000 #define DDRSS_PI_237_DATA 0x1009000F #define DDRSS_PI_238_DATA 0x000062B8 #define DDRSS_PI_239_DATA 0x20030023 #define DDRSS_PI_240_DATA 0x0C0A0C0C #define DDRSS_PI_241_DATA 0x11090000 #define DDRSS_PI_242_DATA 0x1009000F #define DDRSS_PI_243_DATA 0x000062B8 #define DDRSS_PI_244_DATA 0x20030023 #define DDRSS_PI_245_DATA 0x0C0A0C0C #define DDRSS_PI_246_DATA 0x00000000 #define DDRSS_PI_247_DATA 0x00000176 #define DDRSS_PI_248_DATA 0x00000E9C #define DDRSS_PI_249_DATA 0x00001850 #define DDRSS_PI_250_DATA 0x0000F320 #define DDRSS_PI_251_DATA 0x00001850 #define DDRSS_PI_252_DATA 0x0000F320 #define DDRSS_PI_253_DATA 0x01360014 #define DDRSS_PI_254_DATA 0x03030136 #define DDRSS_PI_255_DATA 0x00000003 #define DDRSS_PI_256_DATA 0x00000000 #define DDRSS_PI_257_DATA 0x05030503 #define DDRSS_PI_258_DATA 0x00000503 #define DDRSS_PI_259_DATA 0x00002710 #define DDRSS_PI_260_DATA 0x000186A0 #define DDRSS_PI_261_DATA 0x00000005 #define DDRSS_PI_262_DATA 0x00000064 #define DDRSS_PI_263_DATA 0x00000014 #define DDRSS_PI_264_DATA 0x00027100 #define DDRSS_PI_265_DATA 0x000186A0 #define DDRSS_PI_266_DATA 0x00000005 #define DDRSS_PI_267_DATA 0x00000640 #define DDRSS_PI_268_DATA 0x00000136 #define DDRSS_PI_269_DATA 0x00027100 #define DDRSS_PI_270_DATA 0x000186A0 #define DDRSS_PI_271_DATA 0x00000005 #define DDRSS_PI_272_DATA 0x00000640 #define DDRSS_PI_273_DATA 0x01000136 #define DDRSS_PI_274_DATA 0x00320040 #define DDRSS_PI_275_DATA 0x00010008 #define DDRSS_PI_276_DATA 0x03200040 #define DDRSS_PI_277_DATA 0x00010018 #define DDRSS_PI_278_DATA 0x03200040 #define DDRSS_PI_279_DATA 0x00000318 #define DDRSS_PI_280_DATA 0x00280028 #define DDRSS_PI_281_DATA 0x03040404 #define DDRSS_PI_282_DATA 0x00000303 #define DDRSS_PI_283_DATA 0x02020101 #define DDRSS_PI_284_DATA 0x67676767 #define DDRSS_PI_285_DATA 0x00000000 #define DDRSS_PI_286_DATA 0x55000000 #define DDRSS_PI_287_DATA 0x00000000 #define DDRSS_PI_288_DATA 0x3C00005A #define DDRSS_PI_289_DATA 0x00005500 #define DDRSS_PI_290_DATA 0x00005A00 #define DDRSS_PI_291_DATA 0x0D100F3C #define DDRSS_PI_292_DATA 0x0003020E #define DDRSS_PI_293_DATA 0x00000001 #define DDRSS_PI_294_DATA 0x01000000 #define DDRSS_PI_295_DATA 0x00020201 #define DDRSS_PI_296_DATA 0x00000000 #define DDRSS_PI_297_DATA 0x00000000 #define DDRSS_PI_298_DATA 0x00000004 #define DDRSS_PI_299_DATA 0x00000000 #define DDRSS_PI_300_DATA 0x00000031 #define DDRSS_PI_301_DATA 0x00000000 #define DDRSS_PI_302_DATA 0x00000000 #define DDRSS_PI_303_DATA 0x00000000 #define DDRSS_PI_304_DATA 0x00100F27 #define DDRSS_PI_305_DATA 0x00000000 #define DDRSS_PI_306_DATA 0x00000024 #define DDRSS_PI_307_DATA 0x00000012 #define DDRSS_PI_308_DATA 0x000000B1 #define DDRSS_PI_309_DATA 0x00000000 #define DDRSS_PI_310_DATA 0x00000000 #define DDRSS_PI_311_DATA 0x46000000 #define DDRSS_PI_312_DATA 0x00150F27 #define DDRSS_PI_313_DATA 0x00000000 #define DDRSS_PI_314_DATA 0x00000024 #define DDRSS_PI_315_DATA 0x00000012 #define DDRSS_PI_316_DATA 0x000000B1 #define DDRSS_PI_317_DATA 0x00000000 #define DDRSS_PI_318_DATA 0x00000000 #define DDRSS_PI_319_DATA 0x46000000 #define DDRSS_PI_320_DATA 0x00150F27 #define DDRSS_PI_321_DATA 0x00000000 #define DDRSS_PI_322_DATA 0x00000004 #define DDRSS_PI_323_DATA 0x00000000 #define DDRSS_PI_324_DATA 0x00000031 #define DDRSS_PI_325_DATA 0x00000000 #define DDRSS_PI_326_DATA 0x00000000 #define DDRSS_PI_327_DATA 0x00000000 #define DDRSS_PI_328_DATA 0x00100F27 #define DDRSS_PI_329_DATA 0x00000000 #define DDRSS_PI_330_DATA 0x00000024 #define DDRSS_PI_331_DATA 0x00000012 #define DDRSS_PI_332_DATA 0x000000B1 #define DDRSS_PI_333_DATA 0x00000000 #define DDRSS_PI_334_DATA 0x00000000 #define DDRSS_PI_335_DATA 0x46000000 #define DDRSS_PI_336_DATA 0x00150F27 #define DDRSS_PI_337_DATA 0x00000000 #define DDRSS_PI_338_DATA 0x00000024 #define DDRSS_PI_339_DATA 0x00000012 #define DDRSS_PI_340_DATA 0x000000B1 #define DDRSS_PI_341_DATA 0x00000000 #define DDRSS_PI_342_DATA 0x00000000 #define DDRSS_PI_343_DATA 0x46000000 #define DDRSS_PI_344_DATA 0x00150F27 #define DDRSS_PHY_0_DATA 0x04F00000 #define DDRSS_PHY_1_DATA 0x00000000 #define DDRSS_PHY_2_DATA 0x00030200 #define DDRSS_PHY_3_DATA 0x00000000 #define DDRSS_PHY_4_DATA 0x00000000 #define DDRSS_PHY_5_DATA 0x01000000 #define DDRSS_PHY_6_DATA 0x03000400 #define DDRSS_PHY_7_DATA 0x00000001 #define DDRSS_PHY_8_DATA 0x00000001 #define DDRSS_PHY_9_DATA 0x00000000 #define DDRSS_PHY_10_DATA 0x00000000 #define DDRSS_PHY_11_DATA 0x01010000 #define DDRSS_PHY_12_DATA 0x00010000 #define DDRSS_PHY_13_DATA 0x00C00001 #define DDRSS_PHY_14_DATA 0x00CC0008 #define DDRSS_PHY_15_DATA 0x00660601 #define DDRSS_PHY_16_DATA 0x00000003 #define DDRSS_PHY_17_DATA 0x00000000 #define DDRSS_PHY_18_DATA 0x00000000 #define DDRSS_PHY_19_DATA 0x0000AAAA #define DDRSS_PHY_20_DATA 0x00005555 #define DDRSS_PHY_21_DATA 0x0000B5B5 #define DDRSS_PHY_22_DATA 0x00004A4A #define DDRSS_PHY_23_DATA 0x00005656 #define DDRSS_PHY_24_DATA 0x0000A9A9 #define DDRSS_PHY_25_DATA 0x0000B7B7 #define DDRSS_PHY_26_DATA 0x00004848 #define DDRSS_PHY_27_DATA 0x00000000 #define DDRSS_PHY_28_DATA 0x00000000 #define DDRSS_PHY_29_DATA 0x08000000 #define DDRSS_PHY_30_DATA 0x0F000008 #define DDRSS_PHY_31_DATA 0x00000F0F #define DDRSS_PHY_32_DATA 0x00E4E400 #define DDRSS_PHY_33_DATA 0x00071020 #define DDRSS_PHY_34_DATA 0x000C0020 #define DDRSS_PHY_35_DATA 0x00062000 #define DDRSS_PHY_36_DATA 0x00000000 #define DDRSS_PHY_37_DATA 0x55555555 #define DDRSS_PHY_38_DATA 0xAAAAAAAA #define DDRSS_PHY_39_DATA 0x55555555 #define DDRSS_PHY_40_DATA 0xAAAAAAAA #define DDRSS_PHY_41_DATA 0x00005555 #define DDRSS_PHY_42_DATA 0x01000100 #define DDRSS_PHY_43_DATA 0x00800180 #define DDRSS_PHY_44_DATA 0x00000001 #define DDRSS_PHY_45_DATA 0x00000000 #define DDRSS_PHY_46_DATA 0x00000000 #define DDRSS_PHY_47_DATA 0x00000000 #define DDRSS_PHY_48_DATA 0x00000000 #define DDRSS_PHY_49_DATA 0x00000000 #define DDRSS_PHY_50_DATA 0x00000000 #define DDRSS_PHY_51_DATA 0x00000000 #define DDRSS_PHY_52_DATA 0x00000000 #define DDRSS_PHY_53_DATA 0x00000000 #define DDRSS_PHY_54_DATA 0x00000000 #define DDRSS_PHY_55_DATA 0x00000000 #define DDRSS_PHY_56_DATA 0x00000000 #define DDRSS_PHY_57_DATA 0x00000000 #define DDRSS_PHY_58_DATA 0x00000000 #define DDRSS_PHY_59_DATA 0x00000000 #define DDRSS_PHY_60_DATA 0x00000000 #define DDRSS_PHY_61_DATA 0x00000000 #define DDRSS_PHY_62_DATA 0x00000000 #define DDRSS_PHY_63_DATA 0x00000000 #define DDRSS_PHY_64_DATA 0x00000000 #define DDRSS_PHY_65_DATA 0x00000104 #define DDRSS_PHY_66_DATA 0x00000000 #define DDRSS_PHY_67_DATA 0x00000000 #define DDRSS_PHY_68_DATA 0x00000000 #define DDRSS_PHY_69_DATA 0x00000000 #define DDRSS_PHY_70_DATA 0x00000000 #define DDRSS_PHY_71_DATA 0x00000000 #define DDRSS_PHY_72_DATA 0x041F07FF #define DDRSS_PHY_73_DATA 0x00000000 #define DDRSS_PHY_74_DATA 0x01CC0B01 #define DDRSS_PHY_75_DATA 0x1003CC0B #define DDRSS_PHY_76_DATA 0x20000140 #define DDRSS_PHY_77_DATA 0x07FF0200 #define DDRSS_PHY_78_DATA 0x0000DD01 #define DDRSS_PHY_79_DATA 0x00100303 #define DDRSS_PHY_80_DATA 0x00000000 #define DDRSS_PHY_81_DATA 0x00000000 #define DDRSS_PHY_82_DATA 0x00021000 #define DDRSS_PHY_83_DATA 0x00100010 #define DDRSS_PHY_84_DATA 0x00100010 #define DDRSS_PHY_85_DATA 0x00100010 #define DDRSS_PHY_86_DATA 0x00100010 #define DDRSS_PHY_87_DATA 0x02000010 #define DDRSS_PHY_88_DATA 0x51516041 #define DDRSS_PHY_89_DATA 0x31C06000 #define DDRSS_PHY_90_DATA 0x07AB0340 #define DDRSS_PHY_91_DATA 0x0000C0C0 #define DDRSS_PHY_92_DATA 0x04050000 #define DDRSS_PHY_93_DATA 0x00000504 #define DDRSS_PHY_94_DATA 0x42100010 #define DDRSS_PHY_95_DATA 0x010C053E #define DDRSS_PHY_96_DATA 0x000F0C1D #define DDRSS_PHY_97_DATA 0x01000140 #define DDRSS_PHY_98_DATA 0x007A0120 #define DDRSS_PHY_99_DATA 0x00000C00 #define DDRSS_PHY_100_DATA 0x000001CC #define DDRSS_PHY_101_DATA 0x20100200 #define DDRSS_PHY_102_DATA 0x00000005 #define DDRSS_PHY_103_DATA 0x76543210 #define DDRSS_PHY_104_DATA 0x00000008 #define DDRSS_PHY_105_DATA 0x034C034C #define DDRSS_PHY_106_DATA 0x034C034C #define DDRSS_PHY_107_DATA 0x034C034C #define DDRSS_PHY_108_DATA 0x034C034C #define DDRSS_PHY_109_DATA 0x0000034C #define DDRSS_PHY_110_DATA 0x00008000 #define DDRSS_PHY_111_DATA 0x00800080 #define DDRSS_PHY_112_DATA 0x00800080 #define DDRSS_PHY_113_DATA 0x00800080 #define DDRSS_PHY_114_DATA 0x00800080 #define DDRSS_PHY_115_DATA 0x00800080 #define DDRSS_PHY_116_DATA 0x00800080 #define DDRSS_PHY_117_DATA 0x00800080 #define DDRSS_PHY_118_DATA 0x00800080 #define DDRSS_PHY_119_DATA 0x01800080 #define DDRSS_PHY_120_DATA 0x01000000 #define DDRSS_PHY_121_DATA 0x00000000 #define DDRSS_PHY_122_DATA 0x00000000 #define DDRSS_PHY_123_DATA 0x00080200 #define DDRSS_PHY_124_DATA 0x00000000 #define DDRSS_PHY_125_DATA 0x0000F0F0 #define DDRSS_PHY_126_DATA 0x00000000 #define DDRSS_PHY_127_DATA 0x00000000 #define DDRSS_PHY_128_DATA 0x00000000 #define DDRSS_PHY_129_DATA 0x00000000 #define DDRSS_PHY_130_DATA 0x00000000 #define DDRSS_PHY_131_DATA 0x00000000 #define DDRSS_PHY_132_DATA 0x00000000 #define DDRSS_PHY_133_DATA 0x00000000 #define DDRSS_PHY_134_DATA 0x00000000 #define DDRSS_PHY_135_DATA 0x00000000 #define DDRSS_PHY_136_DATA 0x00000000 #define DDRSS_PHY_137_DATA 0x00000000 #define DDRSS_PHY_138_DATA 0x00000000 #define DDRSS_PHY_139_DATA 0x00000000 #define DDRSS_PHY_140_DATA 0x00000000 #define DDRSS_PHY_141_DATA 0x00000000 #define DDRSS_PHY_142_DATA 0x00000000 #define DDRSS_PHY_143_DATA 0x00000000 #define DDRSS_PHY_144_DATA 0x00000000 #define DDRSS_PHY_145_DATA 0x00000000 #define DDRSS_PHY_146_DATA 0x00000000 #define DDRSS_PHY_147_DATA 0x00000000 #define DDRSS_PHY_148_DATA 0x00000000 #define DDRSS_PHY_149_DATA 0x00000000 #define DDRSS_PHY_150_DATA 0x00000000 #define DDRSS_PHY_151_DATA 0x00000000 #define DDRSS_PHY_152_DATA 0x00000000 #define DDRSS_PHY_153_DATA 0x00000000 #define DDRSS_PHY_154_DATA 0x00000000 #define DDRSS_PHY_155_DATA 0x00000000 #define DDRSS_PHY_156_DATA 0x00000000 #define DDRSS_PHY_157_DATA 0x00000000 #define DDRSS_PHY_158_DATA 0x00000000 #define DDRSS_PHY_159_DATA 0x00000000 #define DDRSS_PHY_160_DATA 0x00000000 #define DDRSS_PHY_161_DATA 0x00000000 #define DDRSS_PHY_162_DATA 0x00000000 #define DDRSS_PHY_163_DATA 0x00000000 #define DDRSS_PHY_164_DATA 0x00000000 #define DDRSS_PHY_165_DATA 0x00000000 #define DDRSS_PHY_166_DATA 0x00000000 #define DDRSS_PHY_167_DATA 0x00000000 #define DDRSS_PHY_168_DATA 0x00000000 #define DDRSS_PHY_169_DATA 0x00000000 #define DDRSS_PHY_170_DATA 0x00000000 #define DDRSS_PHY_171_DATA 0x00000000 #define DDRSS_PHY_172_DATA 0x00000000 #define DDRSS_PHY_173_DATA 0x00000000 #define DDRSS_PHY_174_DATA 0x00000000 #define DDRSS_PHY_175_DATA 0x00000000 #define DDRSS_PHY_176_DATA 0x00000000 #define DDRSS_PHY_177_DATA 0x00000000 #define DDRSS_PHY_178_DATA 0x00000000 #define DDRSS_PHY_179_DATA 0x00000000 #define DDRSS_PHY_180_DATA 0x00000000 #define DDRSS_PHY_181_DATA 0x00000000 #define DDRSS_PHY_182_DATA 0x00000000 #define DDRSS_PHY_183_DATA 0x00000000 #define DDRSS_PHY_184_DATA 0x00000000 #define DDRSS_PHY_185_DATA 0x00000000 #define DDRSS_PHY_186_DATA 0x00000000 #define DDRSS_PHY_187_DATA 0x00000000 #define DDRSS_PHY_188_DATA 0x00000000 #define DDRSS_PHY_189_DATA 0x00000000 #define DDRSS_PHY_190_DATA 0x00000000 #define DDRSS_PHY_191_DATA 0x00000000 #define DDRSS_PHY_192_DATA 0x00000000 #define DDRSS_PHY_193_DATA 0x00000000 #define DDRSS_PHY_194_DATA 0x00000000 #define DDRSS_PHY_195_DATA 0x00000000 #define DDRSS_PHY_196_DATA 0x00000000 #define DDRSS_PHY_197_DATA 0x00000000 #define DDRSS_PHY_198_DATA 0x00000000 #define DDRSS_PHY_199_DATA 0x00000000 #define DDRSS_PHY_200_DATA 0x00000000 #define DDRSS_PHY_201_DATA 0x00000000 #define DDRSS_PHY_202_DATA 0x00000000 #define DDRSS_PHY_203_DATA 0x00000000 #define DDRSS_PHY_204_DATA 0x00000000 #define DDRSS_PHY_205_DATA 0x00000000 #define DDRSS_PHY_206_DATA 0x00000000 #define DDRSS_PHY_207_DATA 0x00000000 #define DDRSS_PHY_208_DATA 0x00000000 #define DDRSS_PHY_209_DATA 0x00000000 #define DDRSS_PHY_210_DATA 0x00000000 #define DDRSS_PHY_211_DATA 0x00000000 #define DDRSS_PHY_212_DATA 0x00000000 #define DDRSS_PHY_213_DATA 0x00000000 #define DDRSS_PHY_214_DATA 0x00000000 #define DDRSS_PHY_215_DATA 0x00000000 #define DDRSS_PHY_216_DATA 0x00000000 #define DDRSS_PHY_217_DATA 0x00000000 #define DDRSS_PHY_218_DATA 0x00000000 #define DDRSS_PHY_219_DATA 0x00000000 #define DDRSS_PHY_220_DATA 0x00000000 #define DDRSS_PHY_221_DATA 0x00000000 #define DDRSS_PHY_222_DATA 0x00000000 #define DDRSS_PHY_223_DATA 0x00000000 #define DDRSS_PHY_224_DATA 0x00000000 #define DDRSS_PHY_225_DATA 0x00000000 #define DDRSS_PHY_226_DATA 0x00000000 #define DDRSS_PHY_227_DATA 0x00000000 #define DDRSS_PHY_228_DATA 0x00000000 #define DDRSS_PHY_229_DATA 0x00000000 #define DDRSS_PHY_230_DATA 0x00000000 #define DDRSS_PHY_231_DATA 0x00000000 #define DDRSS_PHY_232_DATA 0x00000000 #define DDRSS_PHY_233_DATA 0x00000000 #define DDRSS_PHY_234_DATA 0x00000000 #define DDRSS_PHY_235_DATA 0x00000000 #define DDRSS_PHY_236_DATA 0x00000000 #define DDRSS_PHY_237_DATA 0x00000000 #define DDRSS_PHY_238_DATA 0x00000000 #define DDRSS_PHY_239_DATA 0x00000000 #define DDRSS_PHY_240_DATA 0x00000000 #define DDRSS_PHY_241_DATA 0x00000000 #define DDRSS_PHY_242_DATA 0x00000000 #define DDRSS_PHY_243_DATA 0x00000000 #define DDRSS_PHY_244_DATA 0x00000000 #define DDRSS_PHY_245_DATA 0x00000000 #define DDRSS_PHY_246_DATA 0x00000000 #define DDRSS_PHY_247_DATA 0x00000000 #define DDRSS_PHY_248_DATA 0x00000000 #define DDRSS_PHY_249_DATA 0x00000000 #define DDRSS_PHY_250_DATA 0x00000000 #define DDRSS_PHY_251_DATA 0x00000000 #define DDRSS_PHY_252_DATA 0x00000000 #define DDRSS_PHY_253_DATA 0x00000000 #define DDRSS_PHY_254_DATA 0x00000000 #define DDRSS_PHY_255_DATA 0x00000000 #define DDRSS_PHY_256_DATA 0x04F00000 #define DDRSS_PHY_257_DATA 0x00000000 #define DDRSS_PHY_258_DATA 0x00030200 #define DDRSS_PHY_259_DATA 0x00000000 #define DDRSS_PHY_260_DATA 0x00000000 #define DDRSS_PHY_261_DATA 0x01000000 #define DDRSS_PHY_262_DATA 0x03000400 #define DDRSS_PHY_263_DATA 0x00000001 #define DDRSS_PHY_264_DATA 0x00000001 #define DDRSS_PHY_265_DATA 0x00000000 #define DDRSS_PHY_266_DATA 0x00000000 #define DDRSS_PHY_267_DATA 0x01010000 #define DDRSS_PHY_268_DATA 0x00010000 #define DDRSS_PHY_269_DATA 0x00C00001 #define DDRSS_PHY_270_DATA 0x00CC0008 #define DDRSS_PHY_271_DATA 0x00660601 #define DDRSS_PHY_272_DATA 0x00000003 #define DDRSS_PHY_273_DATA 0x00000000 #define DDRSS_PHY_274_DATA 0x00000000 #define DDRSS_PHY_275_DATA 0x0000AAAA #define DDRSS_PHY_276_DATA 0x00005555 #define DDRSS_PHY_277_DATA 0x0000B5B5 #define DDRSS_PHY_278_DATA 0x00004A4A #define DDRSS_PHY_279_DATA 0x00005656 #define DDRSS_PHY_280_DATA 0x0000A9A9 #define DDRSS_PHY_281_DATA 0x0000B7B7 #define DDRSS_PHY_282_DATA 0x00004848 #define DDRSS_PHY_283_DATA 0x00000000 #define DDRSS_PHY_284_DATA 0x00000000 #define DDRSS_PHY_285_DATA 0x08000000 #define DDRSS_PHY_286_DATA 0x0F000008 #define DDRSS_PHY_287_DATA 0x00000F0F #define DDRSS_PHY_288_DATA 0x00E4E400 #define DDRSS_PHY_289_DATA 0x00071020 #define DDRSS_PHY_290_DATA 0x000C0020 #define DDRSS_PHY_291_DATA 0x00062000 #define DDRSS_PHY_292_DATA 0x00000000 #define DDRSS_PHY_293_DATA 0x55555555 #define DDRSS_PHY_294_DATA 0xAAAAAAAA #define DDRSS_PHY_295_DATA 0x55555555 #define DDRSS_PHY_296_DATA 0xAAAAAAAA #define DDRSS_PHY_297_DATA 0x00005555 #define DDRSS_PHY_298_DATA 0x01000100 #define DDRSS_PHY_299_DATA 0x00800180 #define DDRSS_PHY_300_DATA 0x00000000 #define DDRSS_PHY_301_DATA 0x00000000 #define DDRSS_PHY_302_DATA 0x00000000 #define DDRSS_PHY_303_DATA 0x00000000 #define DDRSS_PHY_304_DATA 0x00000000 #define DDRSS_PHY_305_DATA 0x00000000 #define DDRSS_PHY_306_DATA 0x00000000 #define DDRSS_PHY_307_DATA 0x00000000 #define DDRSS_PHY_308_DATA 0x00000000 #define DDRSS_PHY_309_DATA 0x00000000 #define DDRSS_PHY_310_DATA 0x00000000 #define DDRSS_PHY_311_DATA 0x00000000 #define DDRSS_PHY_312_DATA 0x00000000 #define DDRSS_PHY_313_DATA 0x00000000 #define DDRSS_PHY_314_DATA 0x00000000 #define DDRSS_PHY_315_DATA 0x00000000 #define DDRSS_PHY_316_DATA 0x00000000 #define DDRSS_PHY_317_DATA 0x00000000 #define DDRSS_PHY_318_DATA 0x00000000 #define DDRSS_PHY_319_DATA 0x00000000 #define DDRSS_PHY_320_DATA 0x00000000 #define DDRSS_PHY_321_DATA 0x00000104 #define DDRSS_PHY_322_DATA 0x00000000 #define DDRSS_PHY_323_DATA 0x00000000 #define DDRSS_PHY_324_DATA 0x00000000 #define DDRSS_PHY_325_DATA 0x00000000 #define DDRSS_PHY_326_DATA 0x00000000 #define DDRSS_PHY_327_DATA 0x00000000 #define DDRSS_PHY_328_DATA 0x041F07FF #define DDRSS_PHY_329_DATA 0x00000000 #define DDRSS_PHY_330_DATA 0x01CC0B01 #define DDRSS_PHY_331_DATA 0x1003CC0B #define DDRSS_PHY_332_DATA 0x20000140 #define DDRSS_PHY_333_DATA 0x07FF0200 #define DDRSS_PHY_334_DATA 0x0000DD01 #define DDRSS_PHY_335_DATA 0x00100303 #define DDRSS_PHY_336_DATA 0x00000000 #define DDRSS_PHY_337_DATA 0x00000000 #define DDRSS_PHY_338_DATA 0x00021000 #define DDRSS_PHY_339_DATA 0x00100010 #define DDRSS_PHY_340_DATA 0x00100010 #define DDRSS_PHY_341_DATA 0x00100010 #define DDRSS_PHY_342_DATA 0x00100010 #define DDRSS_PHY_343_DATA 0x02000010 #define DDRSS_PHY_344_DATA 0x51516041 #define DDRSS_PHY_345_DATA 0x31C06000 #define DDRSS_PHY_346_DATA 0x07AB0340 #define DDRSS_PHY_347_DATA 0x0000C0C0 #define DDRSS_PHY_348_DATA 0x04050000 #define DDRSS_PHY_349_DATA 0x00000504 #define DDRSS_PHY_350_DATA 0x42100010 #define DDRSS_PHY_351_DATA 0x010C053E #define DDRSS_PHY_352_DATA 0x000F0C1D #define DDRSS_PHY_353_DATA 0x01000140 #define DDRSS_PHY_354_DATA 0x007A0120 #define DDRSS_PHY_355_DATA 0x00000C00 #define DDRSS_PHY_356_DATA 0x000001CC #define DDRSS_PHY_357_DATA 0x20100200 #define DDRSS_PHY_358_DATA 0x00000005 #define DDRSS_PHY_359_DATA 0x76543210 #define DDRSS_PHY_360_DATA 0x00000008 #define DDRSS_PHY_361_DATA 0x034C034C #define DDRSS_PHY_362_DATA 0x034C034C #define DDRSS_PHY_363_DATA 0x034C034C #define DDRSS_PHY_364_DATA 0x034C034C #define DDRSS_PHY_365_DATA 0x0000034C #define DDRSS_PHY_366_DATA 0x00008000 #define DDRSS_PHY_367_DATA 0x00800080 #define DDRSS_PHY_368_DATA 0x00800080 #define DDRSS_PHY_369_DATA 0x00800080 #define DDRSS_PHY_370_DATA 0x00800080 #define DDRSS_PHY_371_DATA 0x00800080 #define DDRSS_PHY_372_DATA 0x00800080 #define DDRSS_PHY_373_DATA 0x00800080 #define DDRSS_PHY_374_DATA 0x00800080 #define DDRSS_PHY_375_DATA 0x01800080 #define DDRSS_PHY_376_DATA 0x01000000 #define DDRSS_PHY_377_DATA 0x00000000 #define DDRSS_PHY_378_DATA 0x00000000 #define DDRSS_PHY_379_DATA 0x00080200 #define DDRSS_PHY_380_DATA 0x00000000 #define DDRSS_PHY_381_DATA 0x0000F0F0 #define DDRSS_PHY_382_DATA 0x00000000 #define DDRSS_PHY_383_DATA 0x00000000 #define DDRSS_PHY_384_DATA 0x00000000 #define DDRSS_PHY_385_DATA 0x00000000 #define DDRSS_PHY_386_DATA 0x00000000 #define DDRSS_PHY_387_DATA 0x00000000 #define DDRSS_PHY_388_DATA 0x00000000 #define DDRSS_PHY_389_DATA 0x00000000 #define DDRSS_PHY_390_DATA 0x00000000 #define DDRSS_PHY_391_DATA 0x00000000 #define DDRSS_PHY_392_DATA 0x00000000 #define DDRSS_PHY_393_DATA 0x00000000 #define DDRSS_PHY_394_DATA 0x00000000 #define DDRSS_PHY_395_DATA 0x00000000 #define DDRSS_PHY_396_DATA 0x00000000 #define DDRSS_PHY_397_DATA 0x00000000 #define DDRSS_PHY_398_DATA 0x00000000 #define DDRSS_PHY_399_DATA 0x00000000 #define DDRSS_PHY_400_DATA 0x00000000 #define DDRSS_PHY_401_DATA 0x00000000 #define DDRSS_PHY_402_DATA 0x00000000 #define DDRSS_PHY_403_DATA 0x00000000 #define DDRSS_PHY_404_DATA 0x00000000 #define DDRSS_PHY_405_DATA 0x00000000 #define DDRSS_PHY_406_DATA 0x00000000 #define DDRSS_PHY_407_DATA 0x00000000 #define DDRSS_PHY_408_DATA 0x00000000 #define DDRSS_PHY_409_DATA 0x00000000 #define DDRSS_PHY_410_DATA 0x00000000 #define DDRSS_PHY_411_DATA 0x00000000 #define DDRSS_PHY_412_DATA 0x00000000 #define DDRSS_PHY_413_DATA 0x00000000 #define DDRSS_PHY_414_DATA 0x00000000 #define DDRSS_PHY_415_DATA 0x00000000 #define DDRSS_PHY_416_DATA 0x00000000 #define DDRSS_PHY_417_DATA 0x00000000 #define DDRSS_PHY_418_DATA 0x00000000 #define DDRSS_PHY_419_DATA 0x00000000 #define DDRSS_PHY_420_DATA 0x00000000 #define DDRSS_PHY_421_DATA 0x00000000 #define DDRSS_PHY_422_DATA 0x00000000 #define DDRSS_PHY_423_DATA 0x00000000 #define DDRSS_PHY_424_DATA 0x00000000 #define DDRSS_PHY_425_DATA 0x00000000 #define DDRSS_PHY_426_DATA 0x00000000 #define DDRSS_PHY_427_DATA 0x00000000 #define DDRSS_PHY_428_DATA 0x00000000 #define DDRSS_PHY_429_DATA 0x00000000 #define DDRSS_PHY_430_DATA 0x00000000 #define DDRSS_PHY_431_DATA 0x00000000 #define DDRSS_PHY_432_DATA 0x00000000 #define DDRSS_PHY_433_DATA 0x00000000 #define DDRSS_PHY_434_DATA 0x00000000 #define DDRSS_PHY_435_DATA 0x00000000 #define DDRSS_PHY_436_DATA 0x00000000 #define DDRSS_PHY_437_DATA 0x00000000 #define DDRSS_PHY_438_DATA 0x00000000 #define DDRSS_PHY_439_DATA 0x00000000 #define DDRSS_PHY_440_DATA 0x00000000 #define DDRSS_PHY_441_DATA 0x00000000 #define DDRSS_PHY_442_DATA 0x00000000 #define DDRSS_PHY_443_DATA 0x00000000 #define DDRSS_PHY_444_DATA 0x00000000 #define DDRSS_PHY_445_DATA 0x00000000 #define DDRSS_PHY_446_DATA 0x00000000 #define DDRSS_PHY_447_DATA 0x00000000 #define DDRSS_PHY_448_DATA 0x00000000 #define DDRSS_PHY_449_DATA 0x00000000 #define DDRSS_PHY_450_DATA 0x00000000 #define DDRSS_PHY_451_DATA 0x00000000 #define DDRSS_PHY_452_DATA 0x00000000 #define DDRSS_PHY_453_DATA 0x00000000 #define DDRSS_PHY_454_DATA 0x00000000 #define DDRSS_PHY_455_DATA 0x00000000 #define DDRSS_PHY_456_DATA 0x00000000 #define DDRSS_PHY_457_DATA 0x00000000 #define DDRSS_PHY_458_DATA 0x00000000 #define DDRSS_PHY_459_DATA 0x00000000 #define DDRSS_PHY_460_DATA 0x00000000 #define DDRSS_PHY_461_DATA 0x00000000 #define DDRSS_PHY_462_DATA 0x00000000 #define DDRSS_PHY_463_DATA 0x00000000 #define DDRSS_PHY_464_DATA 0x00000000 #define DDRSS_PHY_465_DATA 0x00000000 #define DDRSS_PHY_466_DATA 0x00000000 #define DDRSS_PHY_467_DATA 0x00000000 #define DDRSS_PHY_468_DATA 0x00000000 #define DDRSS_PHY_469_DATA 0x00000000 #define DDRSS_PHY_470_DATA 0x00000000 #define DDRSS_PHY_471_DATA 0x00000000 #define DDRSS_PHY_472_DATA 0x00000000 #define DDRSS_PHY_473_DATA 0x00000000 #define DDRSS_PHY_474_DATA 0x00000000 #define DDRSS_PHY_475_DATA 0x00000000 #define DDRSS_PHY_476_DATA 0x00000000 #define DDRSS_PHY_477_DATA 0x00000000 #define DDRSS_PHY_478_DATA 0x00000000 #define DDRSS_PHY_479_DATA 0x00000000 #define DDRSS_PHY_480_DATA 0x00000000 #define DDRSS_PHY_481_DATA 0x00000000 #define DDRSS_PHY_482_DATA 0x00000000 #define DDRSS_PHY_483_DATA 0x00000000 #define DDRSS_PHY_484_DATA 0x00000000 #define DDRSS_PHY_485_DATA 0x00000000 #define DDRSS_PHY_486_DATA 0x00000000 #define DDRSS_PHY_487_DATA 0x00000000 #define DDRSS_PHY_488_DATA 0x00000000 #define DDRSS_PHY_489_DATA 0x00000000 #define DDRSS_PHY_490_DATA 0x00000000 #define DDRSS_PHY_491_DATA 0x00000000 #define DDRSS_PHY_492_DATA 0x00000000 #define DDRSS_PHY_493_DATA 0x00000000 #define DDRSS_PHY_494_DATA 0x00000000 #define DDRSS_PHY_495_DATA 0x00000000 #define DDRSS_PHY_496_DATA 0x00000000 #define DDRSS_PHY_497_DATA 0x00000000 #define DDRSS_PHY_498_DATA 0x00000000 #define DDRSS_PHY_499_DATA 0x00000000 #define DDRSS_PHY_500_DATA 0x00000000 #define DDRSS_PHY_501_DATA 0x00000000 #define DDRSS_PHY_502_DATA 0x00000000 #define DDRSS_PHY_503_DATA 0x00000000 #define DDRSS_PHY_504_DATA 0x00000000 #define DDRSS_PHY_505_DATA 0x00000000 #define DDRSS_PHY_506_DATA 0x00000000 #define DDRSS_PHY_507_DATA 0x00000000 #define DDRSS_PHY_508_DATA 0x00000000 #define DDRSS_PHY_509_DATA 0x00000000 #define DDRSS_PHY_510_DATA 0x00000000 #define DDRSS_PHY_511_DATA 0x00000000 #define DDRSS_PHY_512_DATA 0x00000000 #define DDRSS_PHY_513_DATA 0x00000000 #define DDRSS_PHY_514_DATA 0x00000000 #define DDRSS_PHY_515_DATA 0x00000000 #define DDRSS_PHY_516_DATA 0x00000000 #define DDRSS_PHY_517_DATA 0x00000100 #define DDRSS_PHY_518_DATA 0x00000200 #define DDRSS_PHY_519_DATA 0x00000000 #define DDRSS_PHY_520_DATA 0x00000000 #define DDRSS_PHY_521_DATA 0x00000000 #define DDRSS_PHY_522_DATA 0x00000000 #define DDRSS_PHY_523_DATA 0x00400000 #define DDRSS_PHY_524_DATA 0x00000080 #define DDRSS_PHY_525_DATA 0x00DCBA98 #define DDRSS_PHY_526_DATA 0x03000000 #define DDRSS_PHY_527_DATA 0x00200000 #define DDRSS_PHY_528_DATA 0x00000000 #define DDRSS_PHY_529_DATA 0x00000000 #define DDRSS_PHY_530_DATA 0x00000000 #define DDRSS_PHY_531_DATA 0x00000000 #define DDRSS_PHY_532_DATA 0x0000002A #define DDRSS_PHY_533_DATA 0x00000015 #define DDRSS_PHY_534_DATA 0x00000015 #define DDRSS_PHY_535_DATA 0x0000002A #define DDRSS_PHY_536_DATA 0x00000033 #define DDRSS_PHY_537_DATA 0x0000000C #define DDRSS_PHY_538_DATA 0x0000000C #define DDRSS_PHY_539_DATA 0x00000033 #define DDRSS_PHY_540_DATA 0x0A418820 #define DDRSS_PHY_541_DATA 0x003F0000 #define DDRSS_PHY_542_DATA 0x000F013F #define DDRSS_PHY_543_DATA 0x0000000F #define DDRSS_PHY_544_DATA 0x020002CC #define DDRSS_PHY_545_DATA 0x00030000 #define DDRSS_PHY_546_DATA 0x00000300 #define DDRSS_PHY_547_DATA 0x00000300 #define DDRSS_PHY_548_DATA 0x00000300 #define DDRSS_PHY_549_DATA 0x00000300 #define DDRSS_PHY_550_DATA 0x00000300 #define DDRSS_PHY_551_DATA 0x42080010 #define DDRSS_PHY_552_DATA 0x0000803E #define DDRSS_PHY_553_DATA 0x00000003 #define DDRSS_PHY_554_DATA 0x00000002 #define DDRSS_PHY_555_DATA 0x00000000 #define DDRSS_PHY_556_DATA 0x00000000 #define DDRSS_PHY_557_DATA 0x00000000 #define DDRSS_PHY_558_DATA 0x00000000 #define DDRSS_PHY_559_DATA 0x00000000 #define DDRSS_PHY_560_DATA 0x00000000 #define DDRSS_PHY_561_DATA 0x00000000 #define DDRSS_PHY_562_DATA 0x00000000 #define DDRSS_PHY_563_DATA 0x00000000 #define DDRSS_PHY_564_DATA 0x00000000 #define DDRSS_PHY_565_DATA 0x00000000 #define DDRSS_PHY_566_DATA 0x00000000 #define DDRSS_PHY_567_DATA 0x00000000 #define DDRSS_PHY_568_DATA 0x00000000 #define DDRSS_PHY_569_DATA 0x00000000 #define DDRSS_PHY_570_DATA 0x00000000 #define DDRSS_PHY_571_DATA 0x00000000 #define DDRSS_PHY_572_DATA 0x00000000 #define DDRSS_PHY_573_DATA 0x00000000 #define DDRSS_PHY_574_DATA 0x00000000 #define DDRSS_PHY_575_DATA 0x00000000 #define DDRSS_PHY_576_DATA 0x00000000 #define DDRSS_PHY_577_DATA 0x00000000 #define DDRSS_PHY_578_DATA 0x00000000 #define DDRSS_PHY_579_DATA 0x00000000 #define DDRSS_PHY_580_DATA 0x00000000 #define DDRSS_PHY_581_DATA 0x00000000 #define DDRSS_PHY_582_DATA 0x00000000 #define DDRSS_PHY_583_DATA 0x00000000 #define DDRSS_PHY_584_DATA 0x00000000 #define DDRSS_PHY_585_DATA 0x00000000 #define DDRSS_PHY_586_DATA 0x00000000 #define DDRSS_PHY_587_DATA 0x00000000 #define DDRSS_PHY_588_DATA 0x00000000 #define DDRSS_PHY_589_DATA 0x00000000 #define DDRSS_PHY_590_DATA 0x00000000 #define DDRSS_PHY_591_DATA 0x00000000 #define DDRSS_PHY_592_DATA 0x00000000 #define DDRSS_PHY_593_DATA 0x00000000 #define DDRSS_PHY_594_DATA 0x00000000 #define DDRSS_PHY_595_DATA 0x00000000 #define DDRSS_PHY_596_DATA 0x00000000 #define DDRSS_PHY_597_DATA 0x00000000 #define DDRSS_PHY_598_DATA 0x00000000 #define DDRSS_PHY_599_DATA 0x00000000 #define DDRSS_PHY_600_DATA 0x00000000 #define DDRSS_PHY_601_DATA 0x00000000 #define DDRSS_PHY_602_DATA 0x00000000 #define DDRSS_PHY_603_DATA 0x00000000 #define DDRSS_PHY_604_DATA 0x00000000 #define DDRSS_PHY_605_DATA 0x00000000 #define DDRSS_PHY_606_DATA 0x00000000 #define DDRSS_PHY_607_DATA 0x00000000 #define DDRSS_PHY_608_DATA 0x00000000 #define DDRSS_PHY_609_DATA 0x00000000 #define DDRSS_PHY_610_DATA 0x00000000 #define DDRSS_PHY_611_DATA 0x00000000 #define DDRSS_PHY_612_DATA 0x00000000 #define DDRSS_PHY_613_DATA 0x00000000 #define DDRSS_PHY_614_DATA 0x00000000 #define DDRSS_PHY_615_DATA 0x00000000 #define DDRSS_PHY_616_DATA 0x00000000 #define DDRSS_PHY_617_DATA 0x00000000 #define DDRSS_PHY_618_DATA 0x00000000 #define DDRSS_PHY_619_DATA 0x00000000 #define DDRSS_PHY_620_DATA 0x00000000 #define DDRSS_PHY_621_DATA 0x00000000 #define DDRSS_PHY_622_DATA 0x00000000 #define DDRSS_PHY_623_DATA 0x00000000 #define DDRSS_PHY_624_DATA 0x00000000 #define DDRSS_PHY_625_DATA 0x00000000 #define DDRSS_PHY_626_DATA 0x00000000 #define DDRSS_PHY_627_DATA 0x00000000 #define DDRSS_PHY_628_DATA 0x00000000 #define DDRSS_PHY_629_DATA 0x00000000 #define DDRSS_PHY_630_DATA 0x00000000 #define DDRSS_PHY_631_DATA 0x00000000 #define DDRSS_PHY_632_DATA 0x00000000 #define DDRSS_PHY_633_DATA 0x00000000 #define DDRSS_PHY_634_DATA 0x00000000 #define DDRSS_PHY_635_DATA 0x00000000 #define DDRSS_PHY_636_DATA 0x00000000 #define DDRSS_PHY_637_DATA 0x00000000 #define DDRSS_PHY_638_DATA 0x00000000 #define DDRSS_PHY_639_DATA 0x00000000 #define DDRSS_PHY_640_DATA 0x00000000 #define DDRSS_PHY_641_DATA 0x00000000 #define DDRSS_PHY_642_DATA 0x00000000 #define DDRSS_PHY_643_DATA 0x00000000 #define DDRSS_PHY_644_DATA 0x00000000 #define DDRSS_PHY_645_DATA 0x00000000 #define DDRSS_PHY_646_DATA 0x00000000 #define DDRSS_PHY_647_DATA 0x00000000 #define DDRSS_PHY_648_DATA 0x00000000 #define DDRSS_PHY_649_DATA 0x00000000 #define DDRSS_PHY_650_DATA 0x00000000 #define DDRSS_PHY_651_DATA 0x00000000 #define DDRSS_PHY_652_DATA 0x00000000 #define DDRSS_PHY_653_DATA 0x00000000 #define DDRSS_PHY_654_DATA 0x00000000 #define DDRSS_PHY_655_DATA 0x00000000 #define DDRSS_PHY_656_DATA 0x00000000 #define DDRSS_PHY_657_DATA 0x00000000 #define DDRSS_PHY_658_DATA 0x00000000 #define DDRSS_PHY_659_DATA 0x00000000 #define DDRSS_PHY_660_DATA 0x00000000 #define DDRSS_PHY_661_DATA 0x00000000 #define DDRSS_PHY_662_DATA 0x00000000 #define DDRSS_PHY_663_DATA 0x00000000 #define DDRSS_PHY_664_DATA 0x00000000 #define DDRSS_PHY_665_DATA 0x00000000 #define DDRSS_PHY_666_DATA 0x00000000 #define DDRSS_PHY_667_DATA 0x00000000 #define DDRSS_PHY_668_DATA 0x00000000 #define DDRSS_PHY_669_DATA 0x00000000 #define DDRSS_PHY_670_DATA 0x00000000 #define DDRSS_PHY_671_DATA 0x00000000 #define DDRSS_PHY_672_DATA 0x00000000 #define DDRSS_PHY_673_DATA 0x00000000 #define DDRSS_PHY_674_DATA 0x00000000 #define DDRSS_PHY_675_DATA 0x00000000 #define DDRSS_PHY_676_DATA 0x00000000 #define DDRSS_PHY_677_DATA 0x00000000 #define DDRSS_PHY_678_DATA 0x00000000 #define DDRSS_PHY_679_DATA 0x00000000 #define DDRSS_PHY_680_DATA 0x00000000 #define DDRSS_PHY_681_DATA 0x00000000 #define DDRSS_PHY_682_DATA 0x00000000 #define DDRSS_PHY_683_DATA 0x00000000 #define DDRSS_PHY_684_DATA 0x00000000 #define DDRSS_PHY_685_DATA 0x00000000 #define DDRSS_PHY_686_DATA 0x00000000 #define DDRSS_PHY_687_DATA 0x00000000 #define DDRSS_PHY_688_DATA 0x00000000 #define DDRSS_PHY_689_DATA 0x00000000 #define DDRSS_PHY_690_DATA 0x00000000 #define DDRSS_PHY_691_DATA 0x00000000 #define DDRSS_PHY_692_DATA 0x00000000 #define DDRSS_PHY_693_DATA 0x00000000 #define DDRSS_PHY_694_DATA 0x00000000 #define DDRSS_PHY_695_DATA 0x00000000 #define DDRSS_PHY_696_DATA 0x00000000 #define DDRSS_PHY_697_DATA 0x00000000 #define DDRSS_PHY_698_DATA 0x00000000 #define DDRSS_PHY_699_DATA 0x00000000 #define DDRSS_PHY_700_DATA 0x00000000 #define DDRSS_PHY_701_DATA 0x00000000 #define DDRSS_PHY_702_DATA 0x00000000 #define DDRSS_PHY_703_DATA 0x00000000 #define DDRSS_PHY_704_DATA 0x00000000 #define DDRSS_PHY_705_DATA 0x00000000 #define DDRSS_PHY_706_DATA 0x00000000 #define DDRSS_PHY_707_DATA 0x00000000 #define DDRSS_PHY_708_DATA 0x00000000 #define DDRSS_PHY_709_DATA 0x00000000 #define DDRSS_PHY_710_DATA 0x00000000 #define DDRSS_PHY_711_DATA 0x00000000 #define DDRSS_PHY_712_DATA 0x00000000 #define DDRSS_PHY_713_DATA 0x00000000 #define DDRSS_PHY_714_DATA 0x00000000 #define DDRSS_PHY_715_DATA 0x00000000 #define DDRSS_PHY_716_DATA 0x00000000 #define DDRSS_PHY_717_DATA 0x00000000 #define DDRSS_PHY_718_DATA 0x00000000 #define DDRSS_PHY_719_DATA 0x00000000 #define DDRSS_PHY_720_DATA 0x00000000 #define DDRSS_PHY_721_DATA 0x00000000 #define DDRSS_PHY_722_DATA 0x00000000 #define DDRSS_PHY_723_DATA 0x00000000 #define DDRSS_PHY_724_DATA 0x00000000 #define DDRSS_PHY_725_DATA 0x00000000 #define DDRSS_PHY_726_DATA 0x00000000 #define DDRSS_PHY_727_DATA 0x00000000 #define DDRSS_PHY_728_DATA 0x00000000 #define DDRSS_PHY_729_DATA 0x00000000 #define DDRSS_PHY_730_DATA 0x00000000 #define DDRSS_PHY_731_DATA 0x00000000 #define DDRSS_PHY_732_DATA 0x00000000 #define DDRSS_PHY_733_DATA 0x00000000 #define DDRSS_PHY_734_DATA 0x00000000 #define DDRSS_PHY_735_DATA 0x00000000 #define DDRSS_PHY_736_DATA 0x00000000 #define DDRSS_PHY_737_DATA 0x00000000 #define DDRSS_PHY_738_DATA 0x00000000 #define DDRSS_PHY_739_DATA 0x00000000 #define DDRSS_PHY_740_DATA 0x00000000 #define DDRSS_PHY_741_DATA 0x00000000 #define DDRSS_PHY_742_DATA 0x00000000 #define DDRSS_PHY_743_DATA 0x00000000 #define DDRSS_PHY_744_DATA 0x00000000 #define DDRSS_PHY_745_DATA 0x00000000 #define DDRSS_PHY_746_DATA 0x00000000 #define DDRSS_PHY_747_DATA 0x00000000 #define DDRSS_PHY_748_DATA 0x00000000 #define DDRSS_PHY_749_DATA 0x00000000 #define DDRSS_PHY_750_DATA 0x00000000 #define DDRSS_PHY_751_DATA 0x00000000 #define DDRSS_PHY_752_DATA 0x00000000 #define DDRSS_PHY_753_DATA 0x00000000 #define DDRSS_PHY_754_DATA 0x00000000 #define DDRSS_PHY_755_DATA 0x00000000 #define DDRSS_PHY_756_DATA 0x00000000 #define DDRSS_PHY_757_DATA 0x00000000 #define DDRSS_PHY_758_DATA 0x00000000 #define DDRSS_PHY_759_DATA 0x00000000 #define DDRSS_PHY_760_DATA 0x00000000 #define DDRSS_PHY_761_DATA 0x00000000 #define DDRSS_PHY_762_DATA 0x00000000 #define DDRSS_PHY_763_DATA 0x00000000 #define DDRSS_PHY_764_DATA 0x00000000 #define DDRSS_PHY_765_DATA 0x00000000 #define DDRSS_PHY_766_DATA 0x00000000 #define DDRSS_PHY_767_DATA 0x00000000 #define DDRSS_PHY_768_DATA 0x00000000 #define DDRSS_PHY_769_DATA 0x00000000 #define DDRSS_PHY_770_DATA 0x00000000 #define DDRSS_PHY_771_DATA 0x00000000 #define DDRSS_PHY_772_DATA 0x00000000 #define DDRSS_PHY_773_DATA 0x00000100 #define DDRSS_PHY_774_DATA 0x00000200 #define DDRSS_PHY_775_DATA 0x00000000 #define DDRSS_PHY_776_DATA 0x00000000 #define DDRSS_PHY_777_DATA 0x00000000 #define DDRSS_PHY_778_DATA 0x00000000 #define DDRSS_PHY_779_DATA 0x00400000 #define DDRSS_PHY_780_DATA 0x00000080 #define DDRSS_PHY_781_DATA 0x00DCBA98 #define DDRSS_PHY_782_DATA 0x03000000 #define DDRSS_PHY_783_DATA 0x00200000 #define DDRSS_PHY_784_DATA 0x00000000 #define DDRSS_PHY_785_DATA 0x00000000 #define DDRSS_PHY_786_DATA 0x00000000 #define DDRSS_PHY_787_DATA 0x00000000 #define DDRSS_PHY_788_DATA 0x0000002A #define DDRSS_PHY_789_DATA 0x00000015 #define DDRSS_PHY_790_DATA 0x00000015 #define DDRSS_PHY_791_DATA 0x0000002A #define DDRSS_PHY_792_DATA 0x00000033 #define DDRSS_PHY_793_DATA 0x0000000C #define DDRSS_PHY_794_DATA 0x0000000C #define DDRSS_PHY_795_DATA 0x00000033 #define DDRSS_PHY_796_DATA 0x00000000 #define DDRSS_PHY_797_DATA 0x00000000 #define DDRSS_PHY_798_DATA 0x000F0000 #define DDRSS_PHY_799_DATA 0x0000000F #define DDRSS_PHY_800_DATA 0x020002CC #define DDRSS_PHY_801_DATA 0x00030000 #define DDRSS_PHY_802_DATA 0x00000300 #define DDRSS_PHY_803_DATA 0x00000300 #define DDRSS_PHY_804_DATA 0x00000300 #define DDRSS_PHY_805_DATA 0x00000300 #define DDRSS_PHY_806_DATA 0x00000300 #define DDRSS_PHY_807_DATA 0x42080010 #define DDRSS_PHY_808_DATA 0x0000803E #define DDRSS_PHY_809_DATA 0x00000003 #define DDRSS_PHY_810_DATA 0x00000002 #define DDRSS_PHY_811_DATA 0x00000000 #define DDRSS_PHY_812_DATA 0x00000000 #define DDRSS_PHY_813_DATA 0x00000000 #define DDRSS_PHY_814_DATA 0x00000000 #define DDRSS_PHY_815_DATA 0x00000000 #define DDRSS_PHY_816_DATA 0x00000000 #define DDRSS_PHY_817_DATA 0x00000000 #define DDRSS_PHY_818_DATA 0x00000000 #define DDRSS_PHY_819_DATA 0x00000000 #define DDRSS_PHY_820_DATA 0x00000000 #define DDRSS_PHY_821_DATA 0x00000000 #define DDRSS_PHY_822_DATA 0x00000000 #define DDRSS_PHY_823_DATA 0x00000000 #define DDRSS_PHY_824_DATA 0x00000000 #define DDRSS_PHY_825_DATA 0x00000000 #define DDRSS_PHY_826_DATA 0x00000000 #define DDRSS_PHY_827_DATA 0x00000000 #define DDRSS_PHY_828_DATA 0x00000000 #define DDRSS_PHY_829_DATA 0x00000000 #define DDRSS_PHY_830_DATA 0x00000000 #define DDRSS_PHY_831_DATA 0x00000000 #define DDRSS_PHY_832_DATA 0x00000000 #define DDRSS_PHY_833_DATA 0x00000000 #define DDRSS_PHY_834_DATA 0x00000000 #define DDRSS_PHY_835_DATA 0x00000000 #define DDRSS_PHY_836_DATA 0x00000000 #define DDRSS_PHY_837_DATA 0x00000000 #define DDRSS_PHY_838_DATA 0x00000000 #define DDRSS_PHY_839_DATA 0x00000000 #define DDRSS_PHY_840_DATA 0x00000000 #define DDRSS_PHY_841_DATA 0x00000000 #define DDRSS_PHY_842_DATA 0x00000000 #define DDRSS_PHY_843_DATA 0x00000000 #define DDRSS_PHY_844_DATA 0x00000000 #define DDRSS_PHY_845_DATA 0x00000000 #define DDRSS_PHY_846_DATA 0x00000000 #define DDRSS_PHY_847_DATA 0x00000000 #define DDRSS_PHY_848_DATA 0x00000000 #define DDRSS_PHY_849_DATA 0x00000000 #define DDRSS_PHY_850_DATA 0x00000000 #define DDRSS_PHY_851_DATA 0x00000000 #define DDRSS_PHY_852_DATA 0x00000000 #define DDRSS_PHY_853_DATA 0x00000000 #define DDRSS_PHY_854_DATA 0x00000000 #define DDRSS_PHY_855_DATA 0x00000000 #define DDRSS_PHY_856_DATA 0x00000000 #define DDRSS_PHY_857_DATA 0x00000000 #define DDRSS_PHY_858_DATA 0x00000000 #define DDRSS_PHY_859_DATA 0x00000000 #define DDRSS_PHY_860_DATA 0x00000000 #define DDRSS_PHY_861_DATA 0x00000000 #define DDRSS_PHY_862_DATA 0x00000000 #define DDRSS_PHY_863_DATA 0x00000000 #define DDRSS_PHY_864_DATA 0x00000000 #define DDRSS_PHY_865_DATA 0x00000000 #define DDRSS_PHY_866_DATA 0x00000000 #define DDRSS_PHY_867_DATA 0x00000000 #define DDRSS_PHY_868_DATA 0x00000000 #define DDRSS_PHY_869_DATA 0x00000000 #define DDRSS_PHY_870_DATA 0x00000000 #define DDRSS_PHY_871_DATA 0x00000000 #define DDRSS_PHY_872_DATA 0x00000000 #define DDRSS_PHY_873_DATA 0x00000000 #define DDRSS_PHY_874_DATA 0x00000000 #define DDRSS_PHY_875_DATA 0x00000000 #define DDRSS_PHY_876_DATA 0x00000000 #define DDRSS_PHY_877_DATA 0x00000000 #define DDRSS_PHY_878_DATA 0x00000000 #define DDRSS_PHY_879_DATA 0x00000000 #define DDRSS_PHY_880_DATA 0x00000000 #define DDRSS_PHY_881_DATA 0x00000000 #define DDRSS_PHY_882_DATA 0x00000000 #define DDRSS_PHY_883_DATA 0x00000000 #define DDRSS_PHY_884_DATA 0x00000000 #define DDRSS_PHY_885_DATA 0x00000000 #define DDRSS_PHY_886_DATA 0x00000000 #define DDRSS_PHY_887_DATA 0x00000000 #define DDRSS_PHY_888_DATA 0x00000000 #define DDRSS_PHY_889_DATA 0x00000000 #define DDRSS_PHY_890_DATA 0x00000000 #define DDRSS_PHY_891_DATA 0x00000000 #define DDRSS_PHY_892_DATA 0x00000000 #define DDRSS_PHY_893_DATA 0x00000000 #define DDRSS_PHY_894_DATA 0x00000000 #define DDRSS_PHY_895_DATA 0x00000000 #define DDRSS_PHY_896_DATA 0x00000000 #define DDRSS_PHY_897_DATA 0x00000000 #define DDRSS_PHY_898_DATA 0x00000000 #define DDRSS_PHY_899_DATA 0x00000000 #define DDRSS_PHY_900_DATA 0x00000000 #define DDRSS_PHY_901_DATA 0x00000000 #define DDRSS_PHY_902_DATA 0x00000000 #define DDRSS_PHY_903_DATA 0x00000000 #define DDRSS_PHY_904_DATA 0x00000000 #define DDRSS_PHY_905_DATA 0x00000000 #define DDRSS_PHY_906_DATA 0x00000000 #define DDRSS_PHY_907_DATA 0x00000000 #define DDRSS_PHY_908_DATA 0x00000000 #define DDRSS_PHY_909_DATA 0x00000000 #define DDRSS_PHY_910_DATA 0x00000000 #define DDRSS_PHY_911_DATA 0x00000000 #define DDRSS_PHY_912_DATA 0x00000000 #define DDRSS_PHY_913_DATA 0x00000000 #define DDRSS_PHY_914_DATA 0x00000000 #define DDRSS_PHY_915_DATA 0x00000000 #define DDRSS_PHY_916_DATA 0x00000000 #define DDRSS_PHY_917_DATA 0x00000000 #define DDRSS_PHY_918_DATA 0x00000000 #define DDRSS_PHY_919_DATA 0x00000000 #define DDRSS_PHY_920_DATA 0x00000000 #define DDRSS_PHY_921_DATA 0x00000000 #define DDRSS_PHY_922_DATA 0x00000000 #define DDRSS_PHY_923_DATA 0x00000000 #define DDRSS_PHY_924_DATA 0x00000000 #define DDRSS_PHY_925_DATA 0x00000000 #define DDRSS_PHY_926_DATA 0x00000000 #define DDRSS_PHY_927_DATA 0x00000000 #define DDRSS_PHY_928_DATA 0x00000000 #define DDRSS_PHY_929_DATA 0x00000000 #define DDRSS_PHY_930_DATA 0x00000000 #define DDRSS_PHY_931_DATA 0x00000000 #define DDRSS_PHY_932_DATA 0x00000000 #define DDRSS_PHY_933_DATA 0x00000000 #define DDRSS_PHY_934_DATA 0x00000000 #define DDRSS_PHY_935_DATA 0x00000000 #define DDRSS_PHY_936_DATA 0x00000000 #define DDRSS_PHY_937_DATA 0x00000000 #define DDRSS_PHY_938_DATA 0x00000000 #define DDRSS_PHY_939_DATA 0x00000000 #define DDRSS_PHY_940_DATA 0x00000000 #define DDRSS_PHY_941_DATA 0x00000000 #define DDRSS_PHY_942_DATA 0x00000000 #define DDRSS_PHY_943_DATA 0x00000000 #define DDRSS_PHY_944_DATA 0x00000000 #define DDRSS_PHY_945_DATA 0x00000000 #define DDRSS_PHY_946_DATA 0x00000000 #define DDRSS_PHY_947_DATA 0x00000000 #define DDRSS_PHY_948_DATA 0x00000000 #define DDRSS_PHY_949_DATA 0x00000000 #define DDRSS_PHY_950_DATA 0x00000000 #define DDRSS_PHY_951_DATA 0x00000000 #define DDRSS_PHY_952_DATA 0x00000000 #define DDRSS_PHY_953_DATA 0x00000000 #define DDRSS_PHY_954_DATA 0x00000000 #define DDRSS_PHY_955_DATA 0x00000000 #define DDRSS_PHY_956_DATA 0x00000000 #define DDRSS_PHY_957_DATA 0x00000000 #define DDRSS_PHY_958_DATA 0x00000000 #define DDRSS_PHY_959_DATA 0x00000000 #define DDRSS_PHY_960_DATA 0x00000000 #define DDRSS_PHY_961_DATA 0x00000000 #define DDRSS_PHY_962_DATA 0x00000000 #define DDRSS_PHY_963_DATA 0x00000000 #define DDRSS_PHY_964_DATA 0x00000000 #define DDRSS_PHY_965_DATA 0x00000000 #define DDRSS_PHY_966_DATA 0x00000000 #define DDRSS_PHY_967_DATA 0x00000000 #define DDRSS_PHY_968_DATA 0x00000000 #define DDRSS_PHY_969_DATA 0x00000000 #define DDRSS_PHY_970_DATA 0x00000000 #define DDRSS_PHY_971_DATA 0x00000000 #define DDRSS_PHY_972_DATA 0x00000000 #define DDRSS_PHY_973_DATA 0x00000000 #define DDRSS_PHY_974_DATA 0x00000000 #define DDRSS_PHY_975_DATA 0x00000000 #define DDRSS_PHY_976_DATA 0x00000000 #define DDRSS_PHY_977_DATA 0x00000000 #define DDRSS_PHY_978_DATA 0x00000000 #define DDRSS_PHY_979_DATA 0x00000000 #define DDRSS_PHY_980_DATA 0x00000000 #define DDRSS_PHY_981_DATA 0x00000000 #define DDRSS_PHY_982_DATA 0x00000000 #define DDRSS_PHY_983_DATA 0x00000000 #define DDRSS_PHY_984_DATA 0x00000000 #define DDRSS_PHY_985_DATA 0x00000000 #define DDRSS_PHY_986_DATA 0x00000000 #define DDRSS_PHY_987_DATA 0x00000000 #define DDRSS_PHY_988_DATA 0x00000000 #define DDRSS_PHY_989_DATA 0x00000000 #define DDRSS_PHY_990_DATA 0x00000000 #define DDRSS_PHY_991_DATA 0x00000000 #define DDRSS_PHY_992_DATA 0x00000000 #define DDRSS_PHY_993_DATA 0x00000000 #define DDRSS_PHY_994_DATA 0x00000000 #define DDRSS_PHY_995_DATA 0x00000000 #define DDRSS_PHY_996_DATA 0x00000000 #define DDRSS_PHY_997_DATA 0x00000000 #define DDRSS_PHY_998_DATA 0x00000000 #define DDRSS_PHY_999_DATA 0x00000000 #define DDRSS_PHY_1000_DATA 0x00000000 #define DDRSS_PHY_1001_DATA 0x00000000 #define DDRSS_PHY_1002_DATA 0x00000000 #define DDRSS_PHY_1003_DATA 0x00000000 #define DDRSS_PHY_1004_DATA 0x00000000 #define DDRSS_PHY_1005_DATA 0x00000000 #define DDRSS_PHY_1006_DATA 0x00000000 #define DDRSS_PHY_1007_DATA 0x00000000 #define DDRSS_PHY_1008_DATA 0x00000000 #define DDRSS_PHY_1009_DATA 0x00000000 #define DDRSS_PHY_1010_DATA 0x00000000 #define DDRSS_PHY_1011_DATA 0x00000000 #define DDRSS_PHY_1012_DATA 0x00000000 #define DDRSS_PHY_1013_DATA 0x00000000 #define DDRSS_PHY_1014_DATA 0x00000000 #define DDRSS_PHY_1015_DATA 0x00000000 #define DDRSS_PHY_1016_DATA 0x00000000 #define DDRSS_PHY_1017_DATA 0x00000000 #define DDRSS_PHY_1018_DATA 0x00000000 #define DDRSS_PHY_1019_DATA 0x00000000 #define DDRSS_PHY_1020_DATA 0x00000000 #define DDRSS_PHY_1021_DATA 0x00000000 #define DDRSS_PHY_1022_DATA 0x00000000 #define DDRSS_PHY_1023_DATA 0x00000000 #define DDRSS_PHY_1024_DATA 0x00000000 #define DDRSS_PHY_1025_DATA 0x00000000 #define DDRSS_PHY_1026_DATA 0x00000000 #define DDRSS_PHY_1027_DATA 0x00000000 #define DDRSS_PHY_1028_DATA 0x00000000 #define DDRSS_PHY_1029_DATA 0x00000100 #define DDRSS_PHY_1030_DATA 0x00000200 #define DDRSS_PHY_1031_DATA 0x00000000 #define DDRSS_PHY_1032_DATA 0x00000000 #define DDRSS_PHY_1033_DATA 0x00000000 #define DDRSS_PHY_1034_DATA 0x00000000 #define DDRSS_PHY_1035_DATA 0x00400000 #define DDRSS_PHY_1036_DATA 0x00000080 #define DDRSS_PHY_1037_DATA 0x00DCBA98 #define DDRSS_PHY_1038_DATA 0x03000000 #define DDRSS_PHY_1039_DATA 0x00200000 #define DDRSS_PHY_1040_DATA 0x00000000 #define DDRSS_PHY_1041_DATA 0x00000000 #define DDRSS_PHY_1042_DATA 0x00000000 #define DDRSS_PHY_1043_DATA 0x00000000 #define DDRSS_PHY_1044_DATA 0x0000002A #define DDRSS_PHY_1045_DATA 0x00000015 #define DDRSS_PHY_1046_DATA 0x00000015 #define DDRSS_PHY_1047_DATA 0x0000002A #define DDRSS_PHY_1048_DATA 0x00000033 #define DDRSS_PHY_1049_DATA 0x0000000C #define DDRSS_PHY_1050_DATA 0x0000000C #define DDRSS_PHY_1051_DATA 0x00000033 #define DDRSS_PHY_1052_DATA 0x2307B9AC #define DDRSS_PHY_1053_DATA 0x10000000 #define DDRSS_PHY_1054_DATA 0x000F0000 #define DDRSS_PHY_1055_DATA 0x0000000F #define DDRSS_PHY_1056_DATA 0x020002CC #define DDRSS_PHY_1057_DATA 0x00030000 #define DDRSS_PHY_1058_DATA 0x00000300 #define DDRSS_PHY_1059_DATA 0x00000300 #define DDRSS_PHY_1060_DATA 0x00000300 #define DDRSS_PHY_1061_DATA 0x00000300 #define DDRSS_PHY_1062_DATA 0x00000300 #define DDRSS_PHY_1063_DATA 0x42080010 #define DDRSS_PHY_1064_DATA 0x0000803E #define DDRSS_PHY_1065_DATA 0x00000003 #define DDRSS_PHY_1066_DATA 0x00000002 #define DDRSS_PHY_1067_DATA 0x00000000 #define DDRSS_PHY_1068_DATA 0x00000000 #define DDRSS_PHY_1069_DATA 0x00000000 #define DDRSS_PHY_1070_DATA 0x00000000 #define DDRSS_PHY_1071_DATA 0x00000000 #define DDRSS_PHY_1072_DATA 0x00000000 #define DDRSS_PHY_1073_DATA 0x00000000 #define DDRSS_PHY_1074_DATA 0x00000000 #define DDRSS_PHY_1075_DATA 0x00000000 #define DDRSS_PHY_1076_DATA 0x00000000 #define DDRSS_PHY_1077_DATA 0x00000000 #define DDRSS_PHY_1078_DATA 0x00000000 #define DDRSS_PHY_1079_DATA 0x00000000 #define DDRSS_PHY_1080_DATA 0x00000000 #define DDRSS_PHY_1081_DATA 0x00000000 #define DDRSS_PHY_1082_DATA 0x00000000 #define DDRSS_PHY_1083_DATA 0x00000000 #define DDRSS_PHY_1084_DATA 0x00000000 #define DDRSS_PHY_1085_DATA 0x00000000 #define DDRSS_PHY_1086_DATA 0x00000000 #define DDRSS_PHY_1087_DATA 0x00000000 #define DDRSS_PHY_1088_DATA 0x00000000 #define DDRSS_PHY_1089_DATA 0x00000000 #define DDRSS_PHY_1090_DATA 0x00000000 #define DDRSS_PHY_1091_DATA 0x00000000 #define DDRSS_PHY_1092_DATA 0x00000000 #define DDRSS_PHY_1093_DATA 0x00000000 #define DDRSS_PHY_1094_DATA 0x00000000 #define DDRSS_PHY_1095_DATA 0x00000000 #define DDRSS_PHY_1096_DATA 0x00000000 #define DDRSS_PHY_1097_DATA 0x00000000 #define DDRSS_PHY_1098_DATA 0x00000000 #define DDRSS_PHY_1099_DATA 0x00000000 #define DDRSS_PHY_1100_DATA 0x00000000 #define DDRSS_PHY_1101_DATA 0x00000000 #define DDRSS_PHY_1102_DATA 0x00000000 #define DDRSS_PHY_1103_DATA 0x00000000 #define DDRSS_PHY_1104_DATA 0x00000000 #define DDRSS_PHY_1105_DATA 0x00000000 #define DDRSS_PHY_1106_DATA 0x00000000 #define DDRSS_PHY_1107_DATA 0x00000000 #define DDRSS_PHY_1108_DATA 0x00000000 #define DDRSS_PHY_1109_DATA 0x00000000 #define DDRSS_PHY_1110_DATA 0x00000000 #define DDRSS_PHY_1111_DATA 0x00000000 #define DDRSS_PHY_1112_DATA 0x00000000 #define DDRSS_PHY_1113_DATA 0x00000000 #define DDRSS_PHY_1114_DATA 0x00000000 #define DDRSS_PHY_1115_DATA 0x00000000 #define DDRSS_PHY_1116_DATA 0x00000000 #define DDRSS_PHY_1117_DATA 0x00000000 #define DDRSS_PHY_1118_DATA 0x00000000 #define DDRSS_PHY_1119_DATA 0x00000000 #define DDRSS_PHY_1120_DATA 0x00000000 #define DDRSS_PHY_1121_DATA 0x00000000 #define DDRSS_PHY_1122_DATA 0x00000000 #define DDRSS_PHY_1123_DATA 0x00000000 #define DDRSS_PHY_1124_DATA 0x00000000 #define DDRSS_PHY_1125_DATA 0x00000000 #define DDRSS_PHY_1126_DATA 0x00000000 #define DDRSS_PHY_1127_DATA 0x00000000 #define DDRSS_PHY_1128_DATA 0x00000000 #define DDRSS_PHY_1129_DATA 0x00000000 #define DDRSS_PHY_1130_DATA 0x00000000 #define DDRSS_PHY_1131_DATA 0x00000000 #define DDRSS_PHY_1132_DATA 0x00000000 #define DDRSS_PHY_1133_DATA 0x00000000 #define DDRSS_PHY_1134_DATA 0x00000000 #define DDRSS_PHY_1135_DATA 0x00000000 #define DDRSS_PHY_1136_DATA 0x00000000 #define DDRSS_PHY_1137_DATA 0x00000000 #define DDRSS_PHY_1138_DATA 0x00000000 #define DDRSS_PHY_1139_DATA 0x00000000 #define DDRSS_PHY_1140_DATA 0x00000000 #define DDRSS_PHY_1141_DATA 0x00000000 #define DDRSS_PHY_1142_DATA 0x00000000 #define DDRSS_PHY_1143_DATA 0x00000000 #define DDRSS_PHY_1144_DATA 0x00000000 #define DDRSS_PHY_1145_DATA 0x00000000 #define DDRSS_PHY_1146_DATA 0x00000000 #define DDRSS_PHY_1147_DATA 0x00000000 #define DDRSS_PHY_1148_DATA 0x00000000 #define DDRSS_PHY_1149_DATA 0x00000000 #define DDRSS_PHY_1150_DATA 0x00000000 #define DDRSS_PHY_1151_DATA 0x00000000 #define DDRSS_PHY_1152_DATA 0x00000000 #define DDRSS_PHY_1153_DATA 0x00000000 #define DDRSS_PHY_1154_DATA 0x00000000 #define DDRSS_PHY_1155_DATA 0x00000000 #define DDRSS_PHY_1156_DATA 0x00000000 #define DDRSS_PHY_1157_DATA 0x00000000 #define DDRSS_PHY_1158_DATA 0x00000000 #define DDRSS_PHY_1159_DATA 0x00000000 #define DDRSS_PHY_1160_DATA 0x00000000 #define DDRSS_PHY_1161_DATA 0x00000000 #define DDRSS_PHY_1162_DATA 0x00000000 #define DDRSS_PHY_1163_DATA 0x00000000 #define DDRSS_PHY_1164_DATA 0x00000000 #define DDRSS_PHY_1165_DATA 0x00000000 #define DDRSS_PHY_1166_DATA 0x00000000 #define DDRSS_PHY_1167_DATA 0x00000000 #define DDRSS_PHY_1168_DATA 0x00000000 #define DDRSS_PHY_1169_DATA 0x00000000 #define DDRSS_PHY_1170_DATA 0x00000000 #define DDRSS_PHY_1171_DATA 0x00000000 #define DDRSS_PHY_1172_DATA 0x00000000 #define DDRSS_PHY_1173_DATA 0x00000000 #define DDRSS_PHY_1174_DATA 0x00000000 #define DDRSS_PHY_1175_DATA 0x00000000 #define DDRSS_PHY_1176_DATA 0x00000000 #define DDRSS_PHY_1177_DATA 0x00000000 #define DDRSS_PHY_1178_DATA 0x00000000 #define DDRSS_PHY_1179_DATA 0x00000000 #define DDRSS_PHY_1180_DATA 0x00000000 #define DDRSS_PHY_1181_DATA 0x00000000 #define DDRSS_PHY_1182_DATA 0x00000000 #define DDRSS_PHY_1183_DATA 0x00000000 #define DDRSS_PHY_1184_DATA 0x00000000 #define DDRSS_PHY_1185_DATA 0x00000000 #define DDRSS_PHY_1186_DATA 0x00000000 #define DDRSS_PHY_1187_DATA 0x00000000 #define DDRSS_PHY_1188_DATA 0x00000000 #define DDRSS_PHY_1189_DATA 0x00000000 #define DDRSS_PHY_1190_DATA 0x00000000 #define DDRSS_PHY_1191_DATA 0x00000000 #define DDRSS_PHY_1192_DATA 0x00000000 #define DDRSS_PHY_1193_DATA 0x00000000 #define DDRSS_PHY_1194_DATA 0x00000000 #define DDRSS_PHY_1195_DATA 0x00000000 #define DDRSS_PHY_1196_DATA 0x00000000 #define DDRSS_PHY_1197_DATA 0x00000000 #define DDRSS_PHY_1198_DATA 0x00000000 #define DDRSS_PHY_1199_DATA 0x00000000 #define DDRSS_PHY_1200_DATA 0x00000000 #define DDRSS_PHY_1201_DATA 0x00000000 #define DDRSS_PHY_1202_DATA 0x00000000 #define DDRSS_PHY_1203_DATA 0x00000000 #define DDRSS_PHY_1204_DATA 0x00000000 #define DDRSS_PHY_1205_DATA 0x00000000 #define DDRSS_PHY_1206_DATA 0x00000000 #define DDRSS_PHY_1207_DATA 0x00000000 #define DDRSS_PHY_1208_DATA 0x00000000 #define DDRSS_PHY_1209_DATA 0x00000000 #define DDRSS_PHY_1210_DATA 0x00000000 #define DDRSS_PHY_1211_DATA 0x00000000 #define DDRSS_PHY_1212_DATA 0x00000000 #define DDRSS_PHY_1213_DATA 0x00000000 #define DDRSS_PHY_1214_DATA 0x00000000 #define DDRSS_PHY_1215_DATA 0x00000000 #define DDRSS_PHY_1216_DATA 0x00000000 #define DDRSS_PHY_1217_DATA 0x00000000 #define DDRSS_PHY_1218_DATA 0x00000000 #define DDRSS_PHY_1219_DATA 0x00000000 #define DDRSS_PHY_1220_DATA 0x00000000 #define DDRSS_PHY_1221_DATA 0x00000000 #define DDRSS_PHY_1222_DATA 0x00000000 #define DDRSS_PHY_1223_DATA 0x00000000 #define DDRSS_PHY_1224_DATA 0x00000000 #define DDRSS_PHY_1225_DATA 0x00000000 #define DDRSS_PHY_1226_DATA 0x00000000 #define DDRSS_PHY_1227_DATA 0x00000000 #define DDRSS_PHY_1228_DATA 0x00000000 #define DDRSS_PHY_1229_DATA 0x00000000 #define DDRSS_PHY_1230_DATA 0x00000000 #define DDRSS_PHY_1231_DATA 0x00000000 #define DDRSS_PHY_1232_DATA 0x00000000 #define DDRSS_PHY_1233_DATA 0x00000000 #define DDRSS_PHY_1234_DATA 0x00000000 #define DDRSS_PHY_1235_DATA 0x00000000 #define DDRSS_PHY_1236_DATA 0x00000000 #define DDRSS_PHY_1237_DATA 0x00000000 #define DDRSS_PHY_1238_DATA 0x00000000 #define DDRSS_PHY_1239_DATA 0x00000000 #define DDRSS_PHY_1240_DATA 0x00000000 #define DDRSS_PHY_1241_DATA 0x00000000 #define DDRSS_PHY_1242_DATA 0x00000000 #define DDRSS_PHY_1243_DATA 0x00000000 #define DDRSS_PHY_1244_DATA 0x00000000 #define DDRSS_PHY_1245_DATA 0x00000000 #define DDRSS_PHY_1246_DATA 0x00000000 #define DDRSS_PHY_1247_DATA 0x00000000 #define DDRSS_PHY_1248_DATA 0x00000000 #define DDRSS_PHY_1249_DATA 0x00000000 #define DDRSS_PHY_1250_DATA 0x00000000 #define DDRSS_PHY_1251_DATA 0x00000000 #define DDRSS_PHY_1252_DATA 0x00000000 #define DDRSS_PHY_1253_DATA 0x00000000 #define DDRSS_PHY_1254_DATA 0x00000000 #define DDRSS_PHY_1255_DATA 0x00000000 #define DDRSS_PHY_1256_DATA 0x00000000 #define DDRSS_PHY_1257_DATA 0x00000000 #define DDRSS_PHY_1258_DATA 0x00000000 #define DDRSS_PHY_1259_DATA 0x00000000 #define DDRSS_PHY_1260_DATA 0x00000000 #define DDRSS_PHY_1261_DATA 0x00000000 #define DDRSS_PHY_1262_DATA 0x00000000 #define DDRSS_PHY_1263_DATA 0x00000000 #define DDRSS_PHY_1264_DATA 0x00000000 #define DDRSS_PHY_1265_DATA 0x00000000 #define DDRSS_PHY_1266_DATA 0x00000000 #define DDRSS_PHY_1267_DATA 0x00000000 #define DDRSS_PHY_1268_DATA 0x00000000 #define DDRSS_PHY_1269_DATA 0x00000000 #define DDRSS_PHY_1270_DATA 0x00000000 #define DDRSS_PHY_1271_DATA 0x00000000 #define DDRSS_PHY_1272_DATA 0x00000000 #define DDRSS_PHY_1273_DATA 0x00000000 #define DDRSS_PHY_1274_DATA 0x00000000 #define DDRSS_PHY_1275_DATA 0x00000000 #define DDRSS_PHY_1276_DATA 0x00000000 #define DDRSS_PHY_1277_DATA 0x00000000 #define DDRSS_PHY_1278_DATA 0x00000000 #define DDRSS_PHY_1279_DATA 0x00000000 #define DDRSS_PHY_1280_DATA 0x00000000 #define DDRSS_PHY_1281_DATA 0x00010100 #define DDRSS_PHY_1282_DATA 0x00000000 #define DDRSS_PHY_1283_DATA 0x00000000 #define DDRSS_PHY_1284_DATA 0x00000000 #define DDRSS_PHY_1285_DATA 0x00000000 #define DDRSS_PHY_1286_DATA 0x00050000 #define DDRSS_PHY_1287_DATA 0x04000000 #define DDRSS_PHY_1288_DATA 0x00000055 #define DDRSS_PHY_1289_DATA 0x00000000 #define DDRSS_PHY_1290_DATA 0x00000000 #define DDRSS_PHY_1291_DATA 0x00000000 #define DDRSS_PHY_1292_DATA 0x00000000 #define DDRSS_PHY_1293_DATA 0x00002001 #define DDRSS_PHY_1294_DATA 0x00004001 #define DDRSS_PHY_1295_DATA 0x00020028 #define DDRSS_PHY_1296_DATA 0x01010100 #define DDRSS_PHY_1297_DATA 0x00000000 #define DDRSS_PHY_1298_DATA 0x00000000 #define DDRSS_PHY_1299_DATA 0x0F0F0E06 #define DDRSS_PHY_1300_DATA 0x00010101 #define DDRSS_PHY_1301_DATA 0x010F0004 #define DDRSS_PHY_1302_DATA 0x00000000 #define DDRSS_PHY_1303_DATA 0x00000000 #define DDRSS_PHY_1304_DATA 0x00000064 #define DDRSS_PHY_1305_DATA 0x00000000 #define DDRSS_PHY_1306_DATA 0x00000000 #define DDRSS_PHY_1307_DATA 0x01020103 #define DDRSS_PHY_1308_DATA 0x0F020102 #define DDRSS_PHY_1309_DATA 0x03030303 #define DDRSS_PHY_1310_DATA 0x03030303 #define DDRSS_PHY_1311_DATA 0x00041B42 #define DDRSS_PHY_1312_DATA 0x00005201 #define DDRSS_PHY_1313_DATA 0x00000000 #define DDRSS_PHY_1314_DATA 0x00000000 #define DDRSS_PHY_1315_DATA 0x00000000 #define DDRSS_PHY_1316_DATA 0x00000000 #define DDRSS_PHY_1317_DATA 0x00000000 #define DDRSS_PHY_1318_DATA 0x00000000 #define DDRSS_PHY_1319_DATA 0x07030101 #define DDRSS_PHY_1320_DATA 0x00005400 #define DDRSS_PHY_1321_DATA 0x000040A2 #define DDRSS_PHY_1322_DATA 0x00024410 #define DDRSS_PHY_1323_DATA 0x00004410 #define DDRSS_PHY_1324_DATA 0x00004410 #define DDRSS_PHY_1325_DATA 0x00004410 #define DDRSS_PHY_1326_DATA 0x00004410 #define DDRSS_PHY_1327_DATA 0x00004410 #define DDRSS_PHY_1328_DATA 0x00004410 #define DDRSS_PHY_1329_DATA 0x00004410 #define DDRSS_PHY_1330_DATA 0x00004410 #define DDRSS_PHY_1331_DATA 0x00004410 #define DDRSS_PHY_1332_DATA 0x00000000 #define DDRSS_PHY_1333_DATA 0x00000076 #define DDRSS_PHY_1334_DATA 0x00000400 #define DDRSS_PHY_1335_DATA 0x00000008 #define DDRSS_PHY_1336_DATA 0x00000000 #define DDRSS_PHY_1337_DATA 0x00000000 #define DDRSS_PHY_1338_DATA 0x00000000 #define DDRSS_PHY_1339_DATA 0x00000000 #define DDRSS_PHY_1340_DATA 0x00000000 #define DDRSS_PHY_1341_DATA 0x03000000 #define DDRSS_PHY_1342_DATA 0x00000000 #define DDRSS_PHY_1343_DATA 0x00000000 #define DDRSS_PHY_1344_DATA 0x00000000 #define DDRSS_PHY_1345_DATA 0x04102006 #define DDRSS_PHY_1346_DATA 0x00041020 #define DDRSS_PHY_1347_DATA 0x01C98C98 #define DDRSS_PHY_1348_DATA 0x3F400000 #define DDRSS_PHY_1349_DATA 0x3F3F1F3F #define DDRSS_PHY_1350_DATA 0x0000001F #define DDRSS_PHY_1351_DATA 0x00000000 #define DDRSS_PHY_1352_DATA 0x00000000 #define DDRSS_PHY_1353_DATA 0x00000000 #define DDRSS_PHY_1354_DATA 0x00000001 #define DDRSS_PHY_1355_DATA 0x00000000 #define DDRSS_PHY_1356_DATA 0x00000000 #define DDRSS_PHY_1357_DATA 0x00000000 #define DDRSS_PHY_1358_DATA 0x00000000 #define DDRSS_PHY_1359_DATA 0x76543210 #define DDRSS_PHY_1360_DATA 0x00040198 #define DDRSS_PHY_1361_DATA 0x00000000 #define DDRSS_PHY_1362_DATA 0x00000000 #define DDRSS_PHY_1363_DATA 0x00000000 #define DDRSS_PHY_1364_DATA 0x00040700 #define DDRSS_PHY_1365_DATA 0x00000000 #define DDRSS_PHY_1366_DATA 0x00000000 #define DDRSS_PHY_1367_DATA 0x00000000 #define DDRSS_PHY_1368_DATA 0x00000002 #define DDRSS_PHY_1369_DATA 0x00000000 #define DDRSS_PHY_1370_DATA 0x00000000 #define DDRSS_PHY_1371_DATA 0x0001F7C2 #define DDRSS_PHY_1372_DATA 0x00020002 #define DDRSS_PHY_1373_DATA 0x00000000 #define DDRSS_PHY_1374_DATA 0x00001142 #define DDRSS_PHY_1375_DATA 0x03020000 #define DDRSS_PHY_1376_DATA 0x00000080 #define DDRSS_PHY_1377_DATA 0x03900390 #define DDRSS_PHY_1378_DATA 0x03900390 #define DDRSS_PHY_1379_DATA 0x03900390 #define DDRSS_PHY_1380_DATA 0x03900390 #define DDRSS_PHY_1381_DATA 0x03000300 #define DDRSS_PHY_1382_DATA 0x03000300 #define DDRSS_PHY_1383_DATA 0x00000300 #define DDRSS_PHY_1384_DATA 0x00000300 #define DDRSS_PHY_1385_DATA 0x00000300 #define DDRSS_PHY_1386_DATA 0x00000300 #define DDRSS_PHY_1387_DATA 0x3183BF77 #define DDRSS_PHY_1388_DATA 0x00000000 #define DDRSS_PHY_1389_DATA 0x0C000DFF #define DDRSS_PHY_1390_DATA 0x30000DFF #define DDRSS_PHY_1391_DATA 0x3F0DFF11 #define DDRSS_PHY_1392_DATA 0x01990000 #define DDRSS_PHY_1393_DATA 0x780DFFCC #define DDRSS_PHY_1394_DATA 0x00000C11 #define DDRSS_PHY_1395_DATA 0x00018011 #define DDRSS_PHY_1396_DATA 0x0089FF00 #define DDRSS_PHY_1397_DATA 0x000C3F11 #define DDRSS_PHY_1398_DATA 0x01990000 #define DDRSS_PHY_1399_DATA 0x000C3F91 #define DDRSS_PHY_1400_DATA 0x01990000 #define DDRSS_PHY_1401_DATA 0x3F0DFF11 #define DDRSS_PHY_1402_DATA 0x01990000 #define DDRSS_PHY_1403_DATA 0x00018011 #define DDRSS_PHY_1404_DATA 0x0089FF00 #define DDRSS_PHY_1405_DATA 0x20040004
Hi Manish,
1) As suggested, we generated a custom DDR config using the SysConfig tool. However, we have a doubt — do we need to modify any parameters manually, or can we proceed with the default settings?
I only support Linux BSP and am not really familiar with DDR itself, but the SYSCONFIG tool has an README at the top of the tool page, please follow it to generate the DDR config data file.
2) In the main dts do we need to make any changes in the memory
You need to update the size in the "reg" property.
Hi Bin Liu,
We are currently trying a custom DDR configuration, but we are encountering the following error while booting the kernel on the custom board.
ERROR: Failed to get response (-19) ERROR: Transfer send failed (-19) ERROR: Request to start core failed: -19 [ 0.099782] psci: failed to boot CPU1 (-22) [ 0.104093] CPU1: failed to boot: -22 [ 0.107936] smp: Brought up 1 node, 1 CPU
Hi Manish,
This error messages mean that likely the DM firmware is crashed.
I checked the DDR used on the custom board. It is LPDDR4 MT53E256M16D1FW (512 MB).
Your custom board has 512MiB DDR, but your U-Boot console log still shows 2GiB at line 52. Did you update the DDR size in the U-Boot devicetree?
By the way, the boot log line 95 shows kernel 6.10.0 is used. Please note that v6.10.0 is not a LTS kernel, and it is not used in any of the TI Processor SDK releases.
Hi, BIn Liu,
1. We updated the memory configuration from 2 GB to 512 MB as suggested. However, after making this change, U-Boot is hanging after the following log messages: DRAM: 512 MiB
. Could you please help us understand what might be causing this issue?
What we have tried :
Updated the memory configuration from 2 GB to 512 MB.
Included the custom DDR configuration .dtsi file in the device tree.
Adjusted the reserved memory regions to match the 512 MB memory layout.
Memory node :
memory@80000000 {
bootph-all;
device_type = "memory";
/* 512 RAM */
reg = <0x00000000 0x80000000 0x00000000 0x20000000>;
//reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
/* OP-TEE: top of DDR, 24 MB */
secure_ddr: optee@87800000 {
reg = <0x00 0x87800000 0x00 0x01800000>;
alignment = <0x1000>;
no-map;
/* R5FSS0 Core0 */
main_r5fss0_core0_dma_memory_region: r5f-dma-memory@89000000 {
compatible = "shared-dma-pool";
reg = <0x00 0x89000000 0x00 0x100000>;
no-map;
main_r5fss0_core0_memory_region: r5f-memory@89100000 {
reg = <0x00 0x89100000 0x00 0xf00000>;
no-map;
/* R5FSS0 Core1 */
main_r5fss0_core1_dma_memory_region: r5f-dma-memory@8a000000 {
reg = <0x00 0x8a000000 0x00 0x100000>;
no-map;
main_r5fss0_core1_memory_region: r5f-memory@8a100000 {
reg = <0x00 0x8a100000 0x00 0xf00000>;
no-map;
/* R5FSS1 Core0 */
main_r5fss1_core0_dma_memory_region: r5f-dma-memory@8b000000 {
reg = <0x00 0x8b000000 0x00 0x100000>;
no-map;
main_r5fss1_core0_memory_region: r5f-memory@8b100000 {
reg = <0x00 0x8b100000 0x00 0xf00000>;
no-map;
/* R5FSS1 Core1 */
main_r5fss1_core1_dma_memory_region: r5f-dma-memory@8c000000 {
reg = <0x00 0x8c000000 0x00 0x100000>;
no-map;
main_r5fss1_core1_memory_region: r5f-memory@8c100000 {
reg = <0x00 0x8c100000 0x00 0xf00000>;
no-map;
/* IPC Shared Memory */
rtos_ipc_memory_region: ipc-memories@8e000000 {
reg = <0x00 0x8e000000 0x00 0x00800000>;
no-map;
U-Boot SPL 2024.07 (Jun 02 2026 - 11:15:29 +0530) Resetting on cold boot to workaround ErrataID:i2331 Please resend tiboot3.bin in case of UART/DFU boot resetting ... U-Boot SPL 2024.07 (Jun 02 2026 - 11:15:29 +0530) SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 SPL initial stack usage: 13368 bytes Trying to boot from DFU ############################################DOWNLOAD ... OK Ctrl+C to exit ... Authentication passed Authentication passed Loading Environment from MMC... *** Warning - No MMC card found, using default environment init_env from device 10 not supported! Authentication passed Authentication passed Starting ATF on ARM64 core... NOTICE: BL31: v2.11.0(release):v2.11 NOTICE: BL31: Built : 12:19:51, May 20 2026 I/TC: I/TC: OP-TEE version: Unknown_4.9 (gcc version 14.3.0 (Buildroot 2026.05-rc1-31-gc17d110b10)) #1 Wed May 20 06:47:35 UTC 2026 aarch64 I/TC: WARNING: This OP-TEE configuration might be insecure! I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html I/TC: Primary CPU initializing I/TC: GIC redistributor base address not provided I/TC: Assuming default GIC group status and modifier I/TC: SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)') I/TC: Activated SA2UL device I/TC: Enabled firewalls for SA2UL TRNG device I/TC: EIP76D TRNG initialized I/TC: SA2UL Drivers initialized I/TC: HUK Initialized I/TC: Disabling output console U-Boot SPL 2024.07 (Jun 02 2026 - 11:46:51 +0530) SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)') EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 Trying to boot from DFU #####DOWNLOAD ... OK Ctrl+C to exit ... Authentication passed Authentication passed U-Boot 2024.07 (Jun 02 2026 - 11:46:51 +0530) SoC: AM64X SR2.0 HS-FS Model: Texas Instruments AM642 EVM EEPROM not available at 0x50, trying to read at 0x51 Reading on-board EEPROM at 0x51 failed -121 DRAM: 512 MiB
Hi Manish,
Please add the following config in U-Boot configs/am64x_evm_a53_defconfig to see if it resolves the issue.
CONFIG_SYS_MEM_TOP_HIDE=0x02500000
Hi Bin Liu,
Thanks for the suggestion. After applying the changes, we are now able to boot the custom board successfully. However, the issue we were encountering earlier is still present.
[ 0.083458] smp: Bringing up secondary CPUs ... ERROR: Failed to get response (-19) ERROR: Transfer send failed (-19) ERROR: Request to start core failed: -19 [ 0.099712] psci: failed to boot CPU1 (-22) [ 0.104024] CPU1: failed to boot: -22
20260603_Custom_Board_Boot_Logs.zip
Currently, we have modified only the memory node to match the 512 MB DDR configuration, while the reserved memory nodes remain unchanged from the default DTS configuration.
Hi Manish,
I am unable to explain what could cause this (-19) error, and am unable to reproduce it on AM64x EVM with SDK v11.1 either after adjusted memory size to 512MB in U-Boot devicetree.
But please apply the following kernel (not U-Boot) devicetree to remove the reserved memory regions which are outside of 512MB to see if the CPI1 error still happens.
diff --git a/arch/arm64/boot/dts/ti/k3-am642-evm.dts b/arch/arm64/boot/dts/ti/k3-am642-evm.dts
index 0bc42c8f179e..ae47bfc6f266 100644
--- a/arch/arm64/boot/dts/ti/k3-am642-evm.dts
+++ b/arch/arm64/boot/dts/ti/k3-am642-evm.dts
@@ -40,7 +40,7 @@ memory@80000000 {
bootph-all;
/* 2G RAM */
- reg = <0x00000000 0x80000000 0x00000000 0x80000000>;
+ reg = <0x00000000 0x80000000 0x00000000 0x20000000>;
reserved-memory {
@@ -53,7 +53,7 @@ secure_ddr: optee@9e800000 {
no-map;
main_r5fss0_core0_dma_memory_region: r5f-dma-memory@a0000000 {
reg = <0x00 0xa0000000 0x00 0x100000>;
@@ -119,6 +119,7 @@ rtos_ipc_memory_region: ipc-memories@a5000000 {
no-map;
evm_12v0: regulator-0 {
@@ -781,7 +782,7 @@ mbox_m4_0: mbox-m4-0 {
ti,mbox-tx = <1 0 2>;
&main_r5fss0_core0 {
mboxes = <&mailbox0_cluster2 &mbox_main_r5fss0_core0>;
memory-region = <&main_r5fss0_core0_dma_memory_region>,
@@ -812,7 +813,7 @@ &mcu_m4fss {
<&mcu_m4fss_memory_region>;
status = "okay";
/* main domain timers 8 to 11 are used by TI MCU FW */
&main_timer8 {
status = "reserved";Hi Bin Liu,
I applied the patch you provided, but we are still encountering the same error.
I have attached the DTS file on which the patch was applied for your reference.
Please let me know if you need any additional information.
Manish.
Hi Manish,
Do you use AM6441 device? AM6441 only has one A53, the second A53 doesn't exist, so the kernel error messages are expected, you can ignore them.
Hi Manish,
Can you please double check the board indeed uses AM6442 not AM6441? The error code -19 in the kernel message means -ENODEV, no such device.
Please check the AM64x Datasheet, AM6421 has only one A53. This is why kernel enabling the second A53 (CPU1) fails.
If you don't want kernel to print those error messages, please apply the following kernel devicetree patch to remove the second A53 information.
index dedaa2ca3341..c25c63e02cce 100644
@@ -286,6 +286,14 @@ icssg1_emac1: port@1 {
+&cluster0 {
+ /delete-node/ core1;
+&main_rti1 {
+ status = "disabled";
&main_pmx0 {
main_mmc1_pins_default: main-mmc1-pins-default {
pinctrl-single,pins = <
Hi Bin Liu,
Thanks for resolving the issue, Please can you look through this thread
e2e.ti.com/.../6371865
I see Schuyler has been responding on that thread.
I only do Linux BSP support and know very little about network anyway.
Hi Bin Liu,
Could you please advise which Linux kernel version, U-Boot version, and Buildroot version should be used for building an image for the AM64 board?
I checked the documentation below, but I could not find the AM64-specific Buildroot repository or defconfig:
Could you please point me to the correct repository and share the AM64 Buildroot defconfig file
Manish
Hi Bin Liu,
Created the new thread : e2e.ti.com/.../am6422-looking-for-buildroot-defconfig-and-version-support-for-tmds64evm-am6441-and-custom-board
Thanks.
