AM62L: What's the situation when we programming efuse failed.
Part Number: AM62L
Hello, Expert.
As titile descrption, customer wants to know is it possible to recover AM62L once programming e-fuse failed. I think the cause should be like as below.
(1) If we stop VPP supply when keywriter programs key, that's mean efuse value may be consistent. Can AM62L boot w/ non-signature firmware?
(2) If we interrupt keywriter execution. (ex, power off the board), that's mean efuse value may be consistent. Can AM62L boot w/ non-signature firmware?
(3) Follow item (1)/(2), can we recover AM62L to initial state?
(4) How do we know keywriter write keys success or not?
I already check this link.
https://software-dl.ti.com/processor-sdk-linux/esd/AM62LX/12_00_00_07_04/exports/docs/linux/Foundational_Components/U-Boot/UG-Key-Writer-Lite.html
Thank You.
Gibbs
  • Hi Gibbs,
    Please review <6.8 VPP Specifications for One-Time Programmable (OTP) eFuses> in AM62L datasheet on VPP.
    - 6.8.3 Programming Sequence
    - 6.8.4 Impact to Your Hardware Warranty
    For your questions:
    - #1/#2/#3, the operation is in violation with the required OTP key programming sequence, and the result is unpredictable.
    - #4, check the return status (successful or not ) when calling the key programming function.
    -Hong
