RDK audio error when expending 4 chs to 16 chs
hi all
my hardware = ti8168evm + VS daughter card
my software = DVRRDK_01.08.00.15
first > i have modified files(demo & kernel) referring to DM814X_DVR_RDK_DemoGuide.pdf
second > rebuild demo and kernel
third > errors occur when running the demo    below is the log
 Audio Settings Menu
 1: Set   Audio Storage Path
 2: Start Audio Capture
 3: Stop  Audio Capture
 4: Start Audio Playback
 5: Stop  Audio Playback
 p: Previous Menu
 Enter Choice: 1
 Enter file write path : /home
 Selected file write path [/home]
Store path set to /home
Trying to set storage path to /home
 Audio Settings Menu
 p: Previous Menu
 Enter Choice: 2
 Select AUDIO CAPTURE CH ID [0 .. 15] : 0
 Selected CH ID = 0
Removing /home/01/record01.pcm
Removing /home/01/record02.pcm
Removing /home/01/record03.pcm
Removing /home/01/record04.pcm
Removing /home/01/record05.pcm
Removing /home/01/record06.pcm
Removing /home/01/record07.pcm
Removing /home/01/record08.pcm
Removing /home/01/record09.pcm
Removing /home/01/record10.pcm
 Audio Settings Menu
 p: Previous Menu
 Enter Choice: Opened /home/01/record01.pcm for recording..
 AUDIO >>  CAPTURE ERROR Broken pipe, capture wont continue...
fourth> i have test in the DVRRDK_01.09.00.16 and DVRRDK_01.06.00.11
              the result is the same as DVRRDK_01.08.00.15
why ???????????????????????????????????????????
thank you for any help
