Hi
We are evaluating if AM335X is suitable for the DAB/DRM solution. Can I use external ADC, running at 8.192MHz, 10bit parallel, to do the Software defined rradio application?
ccchou
Hi
ccchou
It may be possible to use GPMC, but GPMC may be shared with other external devices. Your application would need to manage interleaving of data transfers with the ADC which may require very periodic data transfers.
Have you considered using an Audio codec connected to McASP. McASP was specifically designed for digital audio I/O.
The only official PRUSSv2 feature set supported by TI is the Industrial communications protocols included in the Industrial SDK: http://www.ti.com/tool/sysbiossdk-ind-sitara.
Paul
