VPSS module load fails using load-hd-firmware.sh script
Guru 10685 points
I'm trying to get the TI supplied init scripts for the video working.
I have tried running load-hd-firmware.sh line by line but it fails:
# PATH=$PATH:/usr/share/ti/ti-media-controller-utils
# HDVICP2_ID=1
# HDVPSS_ID=2
#         modprobe syslink
SysLink version : 2.00.05.85
SysLink module created on Date:Feb 27 2012 Time:16:33:30
#         until [[ -e /dev/syslinkipc_ProcMgr && -e /dev/syslinkipc_ClientNotify
Mgr ]]
>         do
>             sleep 0.5
>         done
#         firmware_loader $HDVPSS_ID /usr/share/ti/ti-media-controller-utils/dm816x_hdvpss.xem3 start
FIRMWARE: Memory map bin file not passed
Usage : firmware_loader <Processor Id> <Location of Firmware> <start|stop> [Location of Mem map bin file]
FIRMWARE: Default memory configuration is used
MemCfg: DCMM (Dynamically Configurable Memory Map) Version :  2.1.1.1
FIRMWARE: Memory Configuration status : In Progress
FIRMWARE: 2 start Successful
#         modprobe vpss sbufaddr=0xBFB00000 mode=hdmi:1080p-60,dvo2:1080p-60,hdc
omp:1080p-60 i2c_mode=1
notify_shm_drv_sendevent failed! status = 0xfffffff0
notify_send_event failed! status = 0xfffffff0
VPSS_CORE : Failed to init fvid2 interface,
vpss: probe of vpss failed with error -22
VPSS_CORE : failed to register ti81xx-vpss driver
modprobe: can't load module vpss (kernel/drivers/video/ti81xx/vpss/vpss.ko): No such device
My kernel parameters are as follows:
console=ttyO2,115200n8 mem=364M mem=324M@0x9F900000 earlyprintk notifyk.vpssm3_sva=0xA0000000 vram=50M ti816xfb.vram=0:16M,1:16M,2:6M ip=dhcp vmalloc=500M
Has anyone else had this problem with EZSDK 5.03.01.15?
Ralph
P.S.
Why does it say use "notifyk.vpssm3_sva=0xA0000000" in this webpage but in the "mksdboot.sh" script in the EZSDK it says to use "notifyk.vpssm3_sva=0xBF900000"?????
  • Okay, I've fixed it. The Video Capture User Guide webpage is WRONG!
    In EZSDK 5.03.01.15 you should still use "notifyk.vpssm3_sva=0xBF900000" as a kernel parameter.
    I also updated the wrong webpage :-)
