What is the purpose of AIF2 timer(AT) i.e, PHY &RadT Timer? On what basis the value of clock counter and frame counter are determine for both the PHY and RadT timer?
What is the specific device that you are refering to?
Alex
The device is C6618 processor and i need to implement CPRI interface between REC & RE using AIF2 in LTE mode.For this i need to understand the timers and basically the values of their counters.I mean how the values can be determine.
Deepali
I will move you to the correct forum. The clocks and timer forum covers discrete clocking solutions and we are no experts on DSPs.
Alex
Deepali,
There isn't a C6618 device, I suspect you mean the TCI6618 device. All TCI66x device support is done through your local FAE and is not supported on the e2e forums. Please contact your local FAE for direct support.
Chad
