Other Parts Discussed in Thread: OMAP3530
I'm experiencing a problem with the following fragment of code, which is executed at the very beginning of my app, hence it does not create any type of conflict with any other component:
Char* engineName = ENGINENAME;
Engine_Handle* engine
// Initialize Codec Engine runtime
CERuntime_init();
// Initialize Davinci Multimedia Application Interface (MUST be called after CERuntime_init()!!!)
Dmai_init();
// Open the codec engine
*engine = Engine_open(engineName, NULL, NULL);
// H264 Decoder
Vdec2_Handle hVd = NULL;
VIDDEC2_Params decParams = Vdec2_Params_DEFAULT;
decParams.size = sizeof(VIDDEC2_Params);
VIDDEC2_DynamicParams decDynParams = Vdec2_DynamicParams_DEFAULT;
decParams.maxWidth = 320;//gbl.acq_width;
decParams.maxHeight = 240;//gbl.acq_height;
decParams.maxFrameRate = (options.gui ? GUI_FPS*1000 : NOGUI_FPS*1000); // This is 25000
decParams.forceChromaFormat = XDM_YUV_422ILE;
hVd = Vdec2_create(*engine, "h264dec", &decParams, &decDynParams);
if(!hVd) {
ERR("Failed to create video decoder: %s\n", videoDecoders[DECODER_ID].codecName);
return DAVINCI_FAILURE;
My software configuration for this app is the following: DVSDK 4.01.00.09, DMAI 2.20.00.14, C6Accel 1.01.00.07. Obviously, in the case of the aforementioned fragment, I'm just using DMAI. I'm using an ad-hoc codec server, based on the cs.x64P provided with the DVSDK, with some ad-hoc configuration. I attach here my server.tcf, server.cfg, and memmap.tci files to let you see my configuration 7711.codec_server_conf.tar.gz.
Furthermore, I also provide my app with another .cfg file, which I report here:
var System = xdc.useModule('xdc.runtime.System');
var SysStd = xdc.useModule('xdc.runtime.SysStd');
System.SupportProxy = SysStd;
var osalGlobal = xdc.useModule('ti.sdo.ce.osal.Global');
osalGlobal.runtimeEnv = osalGlobal.DSPLINK_LINUX;
* ======== Engine Configuration ========
var Engine = xdc.useModule('ti.sdo.ce.Engine');
/*var stabEngine = Engine.createFromServer(
"dmai_stab",
"./c6accel_omap3530.x64P",
"ti.c6accel_unitservers.omap3530"
"dmai_stab",
"./bin/cs.x64P",
"ti.sdo.server.cs"
/* Load support for the 'Davinci Multimedia Application Interface' module */
var DMAI = xdc.loadPackage('ti.sdo.dmai');
/* CMEM Configuration */
var CMEM = xdc.useModule('ti.sdo.linuxutils.cmem.CMEM');
/* SDMA Configuration */
var SDMA = xdc.useModule('ti.sdo.linuxutils.sdma.SDMA');
/* SCPY Configuration */
var SCPY = xdc.useModule('ti.sdo.fc.scpy.SCPY');
/* DSP Debug */
var GT = xdc.useModule("ti.sdo.utils.trace.GT");
var GTINFRA = xdc.useModule("ti.sdo.fc.utils.gtinfra.GTINFRA");
GTINFRA.runtimeEnv = GTINFRA.NONE;
GT.MALLOCFXN = "myMalloc";
GT.PRINTFXN = "printfCaller";
//Switch to debug + trace profile for all FC modules
xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug_trace";
xdc.loadPackage("ti.sdo.fc.dman3").profile = "debug_trace";
xdc.loadPackage("ti.sdo.fc.acpy3").profile = "debug_trace";
The problem I get when I run my app (with CE_DEBUG=3) is the following:
@0,238,772us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> Enter(0x18)
@0,238,864us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> return (0x93c68)
@0,239,047us: [+0 T:0x425a5620 S:0xbe86eb0c] OG - Global_atexit> enter (fxn=0x52228)
@0,239,108us: [+0 T:0x425a5620 S:0xbe86eae4] OM - Memory_alloc> Enter(0x18)
@0,239,138us: [+0 T:0x425a5620 S:0xbe86eae4] OM - Memory_alloc> return (0x93cb8)
@0,239,169us: [+0 T:0x425a5620 S:0xbe86eb04] OG - Global_atexit> enter (fxn=0x51054)
@0,239,230us: [+0 T:0x425a5620 S:0xbe86eb0c] OG - Global_atexit> enter (fxn=0x53a04)
@0,239,291us: [+0 T:0x425a5620 S:0xbe86eb04] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,239,322us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> Enter(0x14)
@0,239,352us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> return (0x93d38)
@0,239,383us: [+0 T:0x425a5620 S:0xbe86eb04] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x93d38]
@0,239,413us: [+0 T:0x425a5620 S:0xbe86eb04] ti.sdo.ce.osal.Sem - Sem_create> count: 0
@0,239,444us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> Enter(0x14)
@0,239,474us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> return (0x93d50)
@0,239,505us: [+0 T:0x425a5620 S:0xbe86eb04] ti.sdo.ce.osal.Sem - Leaving Sem_create> sem[0x93d50]
@0,239,535us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> Enter(0x18)
@0,239,566us: [+0 T:0x425a5620 S:0xbe86eaec] OM - Memory_alloc> return (0x93d68)
@0,239,596us: [+0 T:0x425a5620 S:0xbe86eae4] OT - Thread_create> Enter (fxn=0x4f298, attrs=0x0)
@0,239,627us: [+0 T:0x425a5620 S:0xbe86eacc] OM - Memory_alloc> Enter(0x64)
@0,239,657us: [+0 T:0x425a5620 S:0xbe86eacc] OM - Memory_alloc> return (0x93d88)
@0,240,023us: [+0 T:0x425a5620 S:0xbe86eae4] OT - Thread_create> Exit (task=0x93d88)
@0,240,085us: [+0 T:0x425a5620 S:0xbe86eb0c] OG - Global_atexit> enter (fxn=0x50758)
@0,240,115us: [+0 T:0x425a5620 S:0xbe86eb1c] OG - Global_atexit> enter (fxn=0x4ecb0)
@0,240,146us: [+0 T:0x425a5620 S:0xbe86eb1c] OG - Global_atexit> enter (fxn=0x515a0)
@0,240,207us: [+0 T:0x425a5620 S:0xbe86eb04] ti.sdo.ce.alg - ALG_init> Enter
@0,240,268us: [+0 T:0x425a5620 S:0xbe86eb24] ti.sdo.ce.alg - ALG_init> Exit
@0,240,298us: [+0 T:0x425a5620 S:0xbe86eb1c] OG - Global_atexit> enter (fxn=0x4b334)
@0,240,329us: [+0 T:0x425a5620 S:0xbe86eaf4] OM - Memory_alloc> Enter(0x18)
@0,240,359us: [+0 T:0x425a5620 S:0xbe86eaf4] OM - Memory_alloc> return (0x93fa0)
@0,240,390us: [+0 T:0x425a5620 S:0xbe86eb1c] OG - Global_atexit> enter (fxn=0x53ef4)
@0,240,420us: [+6 T:0x425a5620 S:0xbe86eb0c] CE - Engine_init> CE debugging on (CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@0,240,451us: [+0 T:0x425a5620 S:0xbe86eafc] OG - Global_atexit> enter (fxn=0x4782c)
@0,240,481us: [+0 T:0x425a5620 S:0xbe86eadc] OM - Memory_alloc> Enter(0x18)
@0,240,512us: [+0 T:0x425a5620 S:0xbe86eadc] OM - Memory_alloc> return (0x93fe0)
@0,240,542us: [+0 T:0x425a5620 S:0xbe86eadc] OM - Memory_alloc> Enter(0x18)
@0,240,603us: [+0 T:0x425a5620 S:0xbe86eadc] OM - Memory_alloc> return (0x94000)
@0,240,634us: [+0 T:0x425a5620 S:0xbe86eadc] OM - Memory_alloc> Enter(0x18)
@0,240,664us: [+0 T:0x425a5620 S:0xbe86eadc] OM - Memory_alloc> return (0x94020)
@0,240,695us: [+0 T:0x425a5620 S:0xbe86eb1c] CS - Server_init()
@0,240,725us: [+0 T:0x425a5620 S:0xbe86eb1c] CS - Server_init> Global_useLinkArbiter = 0
@0,240,756us: [+0 T:0x425a5620 S:0xbe86eb1c] OG - Global_atexit> enter (fxn=0x4509c)
@0,240,817us: [+0 T:0x425a5620 S:0xbe86eae4] CE - Engine_open> Enter('dmai_stab', 0x0, 0xbe86eb54)
@0,240,847us: [+0 T:0x425a5620 S:0xbe86eacc] OM - Memory_alloc> Enter(0x34)
@0,240,878us: [+0 T:0x425a5620 S:0xbe86eacc] OM - Memory_alloc> return (0x94090)
@0,240,908us: [+0 T:0x425a5620 S:0xbe86eae4] CE - rserverOpen('cs.x64P'), count = 0
@0,240,970us: [+0 T:0x425a5620 S:0xbe86eaac] OP - Processor_create> Enter(imageName='cs.x64P', linkCfg='(null)', attrs=0xbe86eb38)
@0,241,336us: [+1 T:0x42da7350 S:0x42da6c24] OP - daemon> thread created.
@0,241,397us: [+0 T:0x42da7350 S:0x42da6c24] OP - getCmd_d> Enter (proc=0x42da6c98)
@0,241,427us: [+0 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x93d38] timeout[0xffffffff]
@0,241,855us: [+0 T:0x425a5620 S:0xbe86ea94] OM - Memory_alloc> Enter(0x24)
@0,241,916us: [+0 T:0x425a5620 S:0xbe86ea94] OM - Memory_alloc> return (0x940c8)
@0,241,946us: [+0 T:0x425a5620 S:0xbe86ea8c] OP - doCmd> Enter (cmdId=1, proc=0x940c8)
@0,241,977us: [+0 T:0x425a5620 S:0xbe86ea7c] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x93d38]
@0,242,038us: [+0 T:0x425a5620 S:0xbe86ea8c] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x93d38]
@0,242,068us: [+0 T:0x425a5620 S:0xbe86ea6c] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x93d50] timeout[0xffffffff]
@0,242,129us: [+0 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x93d38] status[0]
@0,242,160us: [+0 T:0x42da7350 S:0x42da6c24] OP - getCmd_d> Exit (result=1)
@0,242,190us: [+0 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Enter(proc=0x940c8)
@0,242,221us: [+0 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.ipc.Power - Power_on> Enter(handle=0x940e4)
@0,242,251us: [+2 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.ipc.Power - Power_on> Opening Local Power Manager for the DSP on /dev/lpm0...
@0,242,343us: [+2 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.ipc.Power - Power_on> Turning on DSP power...
@0,242,495us: [+2 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.ipc.Power - Power_on> return (0)
@0,242,526us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Initializing DSP PROC...
@0,246,554us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Using DspLink config data for entry #0 [server 'cs.x64P']
@0,246,615us: [+0 T:0x42da7350 S:0x42da6c0c] OM - Memory_alloc> Enter(0x230)
@0,246,646us: [+0 T:0x42da7350 S:0x42da6c0c] OM - Memory_alloc> return (0x94128)
@0,246,829us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #0 to Link configuration: name='DDR2', startAddress=0x87900000, sizeInBytes=0x600000, shared=1, syncd=0
@0,246,890us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x87f01000, sizeInBytes=0xff000, shared=1, syncd=0
@0,246,920us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x87f00000, sizeInBytes=0x1000, shared=1, syncd=0
@0,246,951us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #3 to Link configuration: name='L4PER', startAddress=0x49000000, sizeInBytes=0x100000, shared=0, syncd=0
@0,246,981us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #4 to Link configuration: name='IRAM', startAddress=0x5c7f8000, sizeInBytes=0x8000, shared=1, syncd=0
@0,247,043us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #5 to Link configuration: name='L1DSRAM', startAddress=0x5cf04000, sizeInBytes=0x10000, shared=1, syncd=0
@0,247,073us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #6 to Link configuration: name='L1PSRAM', startAddress=0x5ce00000, sizeInBytes=0x4000, shared=1, syncd=0
@0,247,104us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #7 to Link configuration: name='DDRALGHEAP', startAddress=0x86e00000, sizeInBytes=0xb00000, shared=0, syncd=0
@0,247,134us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #8 to Link configuration: name='L4CORE', startAddress=0x48000000, sizeInBytes=0x1000000, shared=0, syncd=0
@0,247,195us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Found 'CMEM' entry, adjusting base and size according to CMEM_getBlock()
@0,247,226us: [+0 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Setting CMEM base to 0x86300000, size to 0xb00000
@0,247,256us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Adding DSP segment #9 to Link configuration: name='CMEM', startAddress=0x86300000, sizeInBytes=0xb00000, shared=0, syncd=0
@0,247,287us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> DODSPCTRL was=0; now=0
@0,247,348us: [+3 T:0x42da7350 S:0x42da6bc4] OP - LINKCFG_Object generated for PROC_setup(0x8ed50) ...
@0,247,378us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->gppObject->
@0,247,409us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "ARM9"
@0,247,439us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxMsgqs = 0x82
@0,247,470us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxChnlQueue = 0x10
@0,247,500us: [+3 T:0x42da7350 S:0x42da6bc4] OP - poolTableId = 0xffffffff
@0,247,531us: [+3 T:0x42da7350 S:0x42da6bc4] OP - numPools = 0x0
@0,247,561us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,247,592us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->dspObject->
@0,247,622us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "OMAP3530"
@0,247,653us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspArch = 0x2
@0,247,683us: [+3 T:0x42da7350 S:0x42da6bc4] OP - loaderName = "COFF"
@0,247,714us: [+3 T:0x42da7350 S:0x42da6bc4] OP - autoStart = FALSE
@0,247,744us: [+3 T:0x42da7350 S:0x42da6bc4] OP - execName = "DEFAULT.OUT"
@0,247,744us: [+3 T:0x42da7350 S:0x42da6bc4] OP - doDspCtrl = DSP_BootMode_Boot_NoPwr
@0,247,775us: [+3 T:0x42da7350 S:0x42da6bc4] OP - resumeAddr = 0x87f00020
@0,247,805us: [+3 T:0x42da7350 S:0x42da6bc4] OP - resetVector = 0x87f00000
@0,247,836us: [+3 T:0x42da7350 S:0x42da6bc4] OP - resetCodeSize = 0x1000
@0,247,866us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maduSize = 0x1
@0,247,897us: [+3 T:0x42da7350 S:0x42da6bc4] OP - cpuFreq = 0x6ddd0
@0,247,928us: [+3 T:0x42da7350 S:0x42da6bc4] OP - endian = 0x3
@0,247,958us: [+3 T:0x42da7350 S:0x42da6bc4] OP - wordSwap = 0x0
@0,247,989us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memTableId = 0x0
@0,248,019us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntries = 0xa
@0,248,050us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkDrvId = 0x0
@0,248,080us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg1 = 0xffffffff
@0,248,111us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg2 = 0xffffffff
@0,248,111us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg3 = 0x0
@0,248,141us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg4 = 0x0
@0,248,172us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg5 = 0xffffffff
@0,248,202us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,248,233us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->linkDrvObjects->
@0,248,263us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "SHMDRV"
@0,248,294us: [+3 T:0x42da7350 S:0x42da6bc4] OP - hshkPollCount = 0x989680
@0,248,324us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,248,355us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsTableId = 0x0
@0,248,385us: [+3 T:0x42da7350 S:0x42da6bc4] OP - numIpsEntries = 0x1
@0,248,416us: [+3 T:0x42da7350 S:0x42da6bc4] OP - poolTableId = 0x0
@0,248,446us: [+3 T:0x42da7350 S:0x42da6bc4] OP - numPools = 0x1
@0,248,446us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dataTableId = 0x0
@0,248,477us: [+3 T:0x42da7350 S:0x42da6bc4] OP - numDataDrivers = 0x1
@0,248,507us: [+3 T:0x42da7350 S:0x42da6bc4] OP - mqtId = 0x0
@0,248,538us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ringIoTableId = 0x0
@0,248,568us: [+3 T:0x42da7350 S:0x42da6bc4] OP - mplistTableId = 0x0
@0,248,599us: [+3 T:0x42da7350 S:0x42da6bc4] OP - mpcsTableId = 0x0
@0,248,629us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,248,660us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->memTables[0][i].
@0,248,690us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #0:
@0,248,721us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x0
@0,248,752us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "DDR2"
@0,254,306us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x87900000
@0,254,367us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x87900000
@0,254,397us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,254,428us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x600000
@0,254,458us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = TRUE
@0,254,580us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,254,611us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #1:
@0,254,641us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x1
@0,254,672us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "DSPLINKMEM"
@0,254,702us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x87f01000
@0,254,733us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x87f01000
@0,254,763us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,254,794us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0xff000
@0,254,825us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = TRUE
@0,254,855us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,254,886us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #2:
@0,254,916us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x2
@0,254,916us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "RESET_VECTOR"
@0,254,947us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x87f00000
@0,254,977us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x87f00000
@0,255,008us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,255,038us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x1000
@0,255,069us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = TRUE
@0,255,099us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,255,130us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #3:
@0,255,160us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x3
@0,255,191us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "L4PER"
@0,255,221us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x49000000
@0,255,252us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x49000000
@0,255,252us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,255,282us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x100000
@0,255,313us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = FALSE
@0,255,343us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,255,374us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #4:
@0,255,404us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x4
@0,255,435us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "IRAM"
@0,255,465us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x5c7f8000
@0,255,496us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x107f8000
@0,255,526us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,255,557us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x8000
@0,255,587us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = TRUE
@0,255,587us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,255,618us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #5:
@0,255,648us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x5
@0,255,679us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "L1DSRAM"
@0,255,710us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x5cf04000
@0,255,740us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x10f04000
@0,255,771us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,255,801us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x10000
@0,255,832us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = TRUE
@0,255,862us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,255,893us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #6:
@0,255,923us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x6
@0,255,954us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "L1PSRAM"
@0,255,984us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x5ce00000
@0,256,015us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x10e00000
@0,256,045us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,256,076us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x4000
@0,256,106us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = TRUE
@0,256,137us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,256,167us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #7:
@0,256,198us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x7
@0,256,228us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "DDRALGHEAP"
@0,256,259us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x86e00000
@0,256,289us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x86e00000
@0,256,289us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,256,320us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0xb00000
@0,256,350us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = FALSE
@0,256,381us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,256,411us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #8:
@0,256,442us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x8
@0,256,472us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "L4CORE"
@0,256,503us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x48000000
@0,256,533us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x48000000
@0,256,564us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,256,595us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0x1000000
@0,256,625us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = FALSE
@0,256,656us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,256,686us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #9:
@0,256,686us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry = 0x9
@0,256,717us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "CMEM"
@0,256,747us: [+3 T:0x42da7350 S:0x42da6bc4] OP - physAddr = 0x86300000
@0,256,778us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspVirtAddr = 0x86300000
@0,256,808us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppVirtAddr = 0xffffffff
@0,256,839us: [+3 T:0x42da7350 S:0x42da6bc4] OP - size = 0xb00000
@0,256,869us: [+3 T:0x42da7350 S:0x42da6bc4] OP - shared = FALSE
@0,256,900us: [+3 T:0x42da7350 S:0x42da6bc4] OP - syncd = FALSE
@0,256,930us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,256,961us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->ipsTables[0][i].
@0,256,991us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #0:
@0,256,991us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "IPS"
@0,257,022us: [+3 T:0x42da7350 S:0x42da6bc4] OP - numIpsEvents = 0x20
@0,257,052us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,261,813us: [+3 T:0x42da7350 S:0x42da6bc4] OP - gppIntId = 0x1a
@0,261,905us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspIntId = 0x37
@0,261,935us: [+3 T:0x42da7350 S:0x42da6bc4] OP - dspIntVectorId = 0x5
@0,261,966us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg1 = 0x2faf080
@0,261,996us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg2 = 0x0
@0,262,027us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,262,057us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->poolTables[0][i].
@0,262,149us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,262,210us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->dataTables[0][i].
@0,262,240us: [+3 T:0x42da7350 S:0x42da6bc4] OP - entry #0:
@0,262,271us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "ZCPYDATA"
@0,262,301us: [+3 T:0x42da7350 S:0x42da6bc4] OP - baseChnlId = 0x0
@0,262,301us: [+3 T:0x42da7350 S:0x42da6bc4] OP - numChannels = 0x10
@0,262,332us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxBufSize = 0x4000
@0,262,362us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,262,393us: [+3 T:0x42da7350 S:0x42da6bc4] OP - poolId = 0x0
@0,262,423us: [+3 T:0x42da7350 S:0x42da6bc4] OP - queuePerChnl = 0x1
@0,262,454us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsId = 0x0
@0,262,484us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsEventNo = 0x1
@0,262,515us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg1 = 0x0
@0,262,545us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg2 = 0x0
@0,262,576us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,262,606us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->mqtObjects->
@0,262,606us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "ZCPYMQT"
@0,262,637us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,262,668us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxMsgSize = 0xffffffff
@0,262,698us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsId = 0x0
@0,262,729us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsEventNo = 0x0
@0,262,759us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg1 = 0x0
@0,262,790us: [+3 T:0x42da7350 S:0x42da6bc4] OP - arg2 = 0x0
@0,262,820us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,262,851us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->ringIoObjects->
@0,262,881us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "RINGIOTABLE"
@0,262,912us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,262,912us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxEntries = 0x40
@0,262,942us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsId = 0x0
@0,262,973us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsEventNo = 0x2
@0,263,003us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,263,034us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->mplistObjects->
@0,263,064us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "MPLISTTABLE"
@0,263,095us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,263,125us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxEntries = 0x40
@0,263,156us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsId = 0xffffffff
@0,263,186us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsEventNo = 0xffffffff
@0,263,217us: [+3 T:0x42da7350 S:0x42da6bc4] OP -
@0,263,217us: [+3 T:0x42da7350 S:0x42da6bc4] OP - linkCfg->dspConfigs[0]->mpcsObjects->
@0,263,247us: [+3 T:0x42da7350 S:0x42da6bc4] OP - name = "MPCS"
@0,263,278us: [+3 T:0x42da7350 S:0x42da6bc4] OP - memEntry = 0x1
@0,263,308us: [+3 T:0x42da7350 S:0x42da6bc4] OP - maxEntries = 0x100
@0,263,339us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsId = 0xffffffff
@0,263,369us: [+3 T:0x42da7350 S:0x42da6bc4] OP - ipsEventNo = 0xffffffff
@0,264,377us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Attaching to DSP PROC...
@0,301,455us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Opening MSGQ pool...
@0,301,761us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Loading cs.x64P on DSP (1 args)...
@0,733,798us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Starting DSP PROC...
@0,761,721us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> Opening remote transport...
@0,769,503us: [+0 T:0x42da7350 S:0x42da6c0c] ti.sdo.ce.ipc.Power - Power_connect> Enter (handle=0x940f0)
@0,769,595us: [+2 T:0x42da7350 S:0x42da6c0c] ti.sdo.ce.ipc.Power - Power_connect> Calling LPM_connect to connect to the DSP power handler...
@0,769,839us: [+0 T:0x42da7350 S:0x42da6c0c] ti.sdo.ce.ipc.Power - Power_connect> return (0)
@0,769,931us: [+2 T:0x42da7350 S:0x42da6c24] OP - Processor_create_d> return (1)
@0,769,961us: [+0 T:0x42da7350 S:0x42da6c14] ti.sdo.ce.osal.Sem - Entered Sem_post> sem[0x93d50]
@0,770,022us: [+0 T:0x425a5620 S:0xbe86ea6c] ti.sdo.ce.osal.Sem - Leaving Sem_pend> sem[0x93d50] status[0]
@0,770,053us: [+0 T:0x425a5620 S:0xbe86ea8c] OP - doCmd> Exit (result=1)
@0,770,083us: [+0 T:0x425a5620 S:0xbe86eaac] OP - Processor_create> return (0x940c8)
@0,770,114us: [+0 T:0x425a5620 S:0xbe86eae4] CE - rserverOpen('cs.x64P'): 0x8fdc8 done.
@0,770,175us: [+0 T:0x425a5620 S:0xbe86eacc] OM - Memory_alloc> Enter(0x27)
@0,770,205us: [+0 T:0x425a5620 S:0xbe86eacc] OM - Memory_alloc> return (0x944c0)
@0,770,327us: [+0 T:0x425a5620 S:0xbe86eabc] OC - Comm_create> Enter(queueName='dmai_stab_1135_0', queue=0x940a0, attrs=0x0)
@0,770,358us: [+0 T:0x425a5620 S:0xbe86eaa4] OM - Memory_alloc> Enter(0x4)
@0,770,388us: [+0 T:0x425a5620 S:0xbe86eaa4] OM - Memory_alloc> return (0x944f0)
@0,770,694us: [+0 T:0x425a5620 S:0xbe86eabc] OC - Comm_create> return (0x944f0)
@0,770,724us: [+0 T:0x425a5620 S:0xbe86eac4] OM - Memory_free> Enter(0x944c0, 0x27)
@0,770,785us: [+0 T:0x425a5620 S:0xbe86eac4] OM - Memory_free> return (0x1)
@0,770,816us: [+0 T:0x425a5620 S:0xbe86eac4] OC - Comm_alloc> Enter(poolId=0x0, msg=0x940ac, size=1592)
@0,770,877us: [+0 T:0x425a5620 S:0xbe86eac4] OC - Comm_alloc> msg=0x435b8880, returning (0)
@0,770,907us: [+0 T:0x425a5620 S:0xbe86eaac] OC - Comm_locate> Enter(queueName='rmsq', queue=0x9409c)
@0,771,609us: [+0 T:0x425a5620 S:0xbe86eaac] OC - Comm_locate> return (0)
@0,771,670us: [+0 T:0x425a5620 S:0xbe86eae4] CE - checkServer(0x94090)
@0,771,762us: [+0 T:0x425a5620 S:0xbe86eab4] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,771,823us: [+0 T:0x425a5620 S:0xbe86eab4] OC - Comm_put> return (0)
@0,771,884us: [+0 T:0x425a5620 S:0xbe86eaac] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eb50, timeout=-1)
@0,771,975us: [+0 T:0x425a5620 S:0xbe86eaac] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@0,772,006us: [+0 T:0x425a5620 S:0xbe86eae4] CE - rmsInit> RMS initialized(0x94090); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=3
@0,772,036us: [+0 T:0x425a5620 S:0xbe86eabc] CE - Engine_setTrace> Enter(engine=0x94090, mask='*+01234567,GT_prefix=12345,GT_time=3')
@0,772,158us: [+1 T:0x425a5620 S:0xbe86eabc] CE - Engine_setTrace> Requesting DSP set trace ...
@0,772,189us: [+0 T:0x425a5620 S:0xbe86ea8c] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,772,220us: [+0 T:0x425a5620 S:0xbe86ea8c] OC - Comm_put> return (0)
@0,772,250us: [+0 T:0x425a5620 S:0xbe86ea84] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eb04, timeout=-1)
@0,772,311us: [+0 T:0x42da7350 S:0x42da6c24] ti.sdo.ce.osal.Sem - Leaving Sem_post> sem[0x93d50]
@0,772,342us: [+0 T:0x42da7350 S:0x42da6c24] OP - getCmd_d> Enter (proc=0x42da6c98)
@0,772,372us: [+0 T:0x42da7350 S:0x42da6c04] ti.sdo.ce.osal.Sem - Entered Sem_pend> sem[0x93d38] timeout[0xffffffff]
@0,774,508us: [+0 T:0x425a5620 S:0xbe86ea84] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@0,774,630us: [+0 T:0x425a5620 S:0xbe86eabc] CE - Engine_setTrace> return(0)
@0,774,661us: [+4 T:0x425a5620 S:0xbe86eae4] CE - Engine_open> engine->server = 0x8fdc8
@0,774,691us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,774,752us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> return (0)
@0,774,783us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eae4, timeout=-1)
@0,774,936us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
[DSP] @0x000005a0:[T:0x00000000] server - main> Welcome to DSP server's main().
[DSP] @0,054,335tk: [+0 T:0x87b4d374 S:0x87b5d2ec] OG - Global_setSpecialTrace> enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
[DSP] @0,054,440tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - Global_setSpecialTrace> This program was built with the following packages:
[DSP] @0,054,505tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.targets.rts6000 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/packages/ti/targets/rts6000/) [1, 0, 0, 0]
[DSP] @0,054,595tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.fc.global (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/framework-components_2_25_03_07/packages/ti/sdo/fc/global/) [1, 0, 0]
[DSP] @0,054,686tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.c6accel (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/c6accel_1_01_00_07/soc/packages/ti/c6accel/) [1, 0, 0]
[DSP] @0,054,769tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.aachedec (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/aachedec/) [1, 0, 0]
[DSP] @0,054,863tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.deinterlacer (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/deinterlacer/) [1, 0, 0]
[DSP] @0,054,958tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.g711dec (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/g711dec/) [1, 0, 0]
[DSP] @0,055,051tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.g711enc (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/g711enc/) [1, 0, 0]
[DSP] @0,055,143tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.h264enc (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/h264enc/) [1, 0, 0]
[DSP] @0,055,236tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.jpegdec (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/jpegdec/) [1, 0, 0]
[DSP] @0,055,328tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.jpegenc (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/jpegenc/) [1, 0, 0]
[DSP] @0,055,420tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.mpeg2dec (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/mpeg2dec/) [1, 0, 0]
[DSP] @0,055,513tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.mpeg4enc (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/mpeg4enc/) [1, 0, 0]
[DSP] @0,055,606tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.utils.trace (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/framework-components_2_25_03_07/packages/ti/sdo/utils/trace/) [1, 0, 0]
[DSP] @0,055,699tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.xdais (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdais_6_26_00_02/packages/ti/xdais/) [1, 2.0, 1]
[DSP] @0,055,778tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.rtdx (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages/ti/rtdx/) [2, 0, 0, 5]
[DSP] @0,055,858tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.psl (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages/ti/psl/) [5, 0, 0, 0]
[DSP] @0,055,937tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.pmi (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages/ti/pmi/) [1, 0, 0, 0]
[DSP] @0,056,017tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.pscl (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages/ti/pscl/) [1, 0, 0, 0]
[DSP] @0,056,096tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.bios (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/dspbios_5_41_03_17/packages/ti/bios/) [5, 2, 5, 28]
[DSP] @0,056,178tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.fc.dskt2 (/home/gabriele/ti-dvsdk_dm3730-evm_4_@0,786,441us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,786,532us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> return (0)
@0,786,776us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eae4, timeout=-1)
@0,786,837us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
01_00_09/framework-components_2_25_03_07/packages/ti/sdo/fc/dskt2/) [1, 0, 4]
[DSP] @0,056,267tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.fc.dman3 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/framework-components_2_25_03_07/packages/ti/sdo/fc/dman3/) [1, 0, 4]
[DSP] @0,056,356tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.global (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/global/) [1, 0, 0]
[DSP] @0,056,445tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.xdais.dm (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdais_6_26_00_02/packages/ti/xdais/dm/) [1, 0, 5]
[DSP] @0,056,526tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.utils.xdm (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/utils/xdm/) [1, 0, 2]
[DSP] @0,056,615tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.node (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/node/) [1, 0, 0]
[DSP] @0,056,701tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.ipc.dsplink.dsp (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/dsplink/dsp/) [2, 0, 1]
[DSP] @0,056,796tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.fc.memutils (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/framework-components_2_25_03_07/packages/ti/sdo/fc/memutils/) [1, 0, 0]
[DSP] @0,056,887tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.fc.acpy3 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/framework-components_2_25_03_07/packages/ti/sdo/fc/acpy3/) [1, 0, 4]
[DSP] @0,056,993tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package dsplink.dsp (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/dsplink_1_65_00_02/dsplink/dsp/) [1, 4, 0]
[DSP] @0,057,072tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.bios.utils (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/biosutils_1_02_02/packages/ti/bios/utils/) [2, 0, 2, 02]
[DSP] @0,057,156tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.catalog.c6000 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/packages/ti/catalog/c6000/) [1, 0, 0, 0]
[DSP] @0,057,243tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.catalog (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/packages/ti/catalog/) [1, 0, 0]
[DSP] @0,057,328tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.catalog.arm (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/packages/ti/catalog/arm/) [1, 0, 1, 0]
[DSP] @0,057,413tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.platforms.evm3530 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/xdctools_3_16_03_36/packages/ti/platforms/evm3530/) [1, 0, 0]
[DSP] @0,057,502tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.osal (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/osal/) [2, 0, 2]
[DSP] @0,057,589tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.osal.bios (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/osal/bios/) [2, 0, 1]
[DSP] @0,057,679tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.ipc (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/) [2, 0, 1]
[DSP] @0,057,764tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.ipc.bios (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/ipc/bios/) [2, 0, 1]
[DSP] @0,057,852tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.alg (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/alg/) [1, 0, 1]
[DSP] @0,057,938tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/) [1, 0, 6]
[DSP] @0,058,020tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.bioslog (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/bioslog/) [1, 0, 1]
[DSP] @0,058,109tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG@0,793,429us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,793,521us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> return (0)
@0,793,551us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eae4, timeout=-1)
@0,795,810us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
- package ti.sdo.ce.universal (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/universal/) [1, 0, 0]
[DSP] @0,058,198tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.c6accel.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/c6accel_1_01_00_07/soc/packages/ti/c6accel/ce/) [1, 0, 0]
[DSP] @0,058,283tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.audio1 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/audio1/) [1, 0, 1]
[DSP] @0,058,370tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.aachedec.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/aachedec/ce/) [1, 0, 0]
[DSP] @0,058,465tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.deinterlacer.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/deinterlacer/ce/) [1, 0, 0]
[DSP] @0,058,564tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.speech1 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/speech1/) [1, 0, 1]
[DSP] @0,058,652tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.g711dec.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/g711dec/ce/) [1, 0, 0]
[DSP] @0,058,752tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.g711enc.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/g711enc/ce/) [1, 0, 0]
[DSP] @0,058,846tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.video2 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/video2/) [1, 0, 2]
[DSP] @0,058,934tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.h264dec (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/h264dec/) []
[DSP] @0,059,024tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.h264dec.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/h264dec/ce/) []
[DSP] @0,059,115tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.video1 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/video1/) [1, 0, 2]
[DSP] @0,059,202tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.h264enc.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/h264enc/ce/) [1, 0, 0]
[DSP] @0,059,297tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.ce.image1 (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codec-engine_2_26_01_09/packages/ti/sdo/ce/image1/) [1, 0, 1]
[DSP] @0,059,384tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.jpegdec.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/jpegdec/ce/) [1, 0, 0]
[DSP] @0,059,479tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.jpegenc.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/jpegenc/ce/) [1, 0, 0]
[DSP] @0,059,576tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.mpeg2dec.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/mpeg2dec/ce/) [1, 0, 0]
[DSP] @0,059,671tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.mpeg4dec (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/mpeg4dec/) []
[DSP] @0,059,761tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.mpeg4dec.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/mpeg4dec/ce/) []
[DSP] @0,059,854tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.codecs.mpeg4enc.ce (/home/gabriele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/codecs/mpeg4enc/ce/) [1, 0, 0]
[DSP] @0,059,950tk: [+4 T:0x87b4d374 S:0x87b5d2ec] OG - package ti.sdo.server.cs (/home/gabri@0,801,242us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,801,394us: [+0 T:0x425a5620 S:0xbe86ea4c] OC - Comm_put> return (0)
@0,801,425us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eae4, timeout=-1)
@0,801,516us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
ele/ti-dvsdk_dm3730-evm_4_01_00_09/codecs-omap3530_4_01_00_00/packages/ti/sdo/server/cs/) [1, 0, 0]
[DSP] @0,060,039tk: [+0 T:0x87b4d374 S:0x87b5d2ec] OG - Global_setSpecialTrace> return
[DSP] @0,062,263tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - processRmsCmd(0x87f048a8, 4056): cmd = 5
[DSP] @0,062,329tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,099,056tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - processRmsCmd(0x87f048a8, 4056): cmd = 5
[DSP] @0,099,120tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,120,896tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - processRmsCmd(0x87f048a8, 4056): cmd = 5
[DSP] @0,120,959tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - remote time = 0x0, trace buffer size = 4032
[DSP] @0,145,442tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - processRmsCmd(0x87f048a8, 4056): cmd = 5
[DSP] @0,145,502tk: [+0 T:0x87b4d374 S:0x87b5d334] CR - remote time = 0x0, trace buffer size = 4032
@0,802,401us: [+0 T:0x425a5620 S:0xbe86ea7c] CE - Engine_fwriteTrace> returning count [13461]
@0,802,462us: [+0 T:0x425a5620 S:0xbe86ea9c] CE - Engine_initFromServer(0x94090)
@0,802,493us: [+0 T:0x425a5620 S:0xbe86ea74] CE - Engine_getNumServerAlgs(0x94090 0xbe86eaf0)
@0,802,523us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,802,585us: [+0 T:0x425a5620 S:0xbe86ea44] OC - Comm_put> return (0)
@0,802,615us: [+0 T:0x425a5620 S:0xbe86ea3c] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86eabc, timeout=-1)
@0,802,707us: [+0 T:0x425a5620 S:0xbe86ea3c] OC - Comm_get> MSGQ_get() status=0x8000, return (0)
@0,802,737us: [+0 T:0x425a5620 S:0xbe86ea74] CE - Engine_getNumServerAlgs number of server algs = 12
@0,802,768us: [+0 T:0x425a5620 S:0xbe86ea74] CE - Engine_getNumServerAlgs exit 0
@0,802,798us: [+2 T:0x425a5620 S:0xbe86ea9c] CE - Engine_initFromServer> Number of remote algs statically configured in engine: 12
@0,802,829us: [+2 T:0x425a5620 S:0xbe86ea9c] CE - Engine_initFromServer> Number of statically configured remote algs = number of server algs: 12
@0,802,859us: [+0 T:0x425a5620 S:0xbe86ea9c] CE - Engine_initFromServer> Returning 0
@0,802,890us: [+0 T:0x425a5620 S:0xbe86eae4] CE - Engine_open> return(606352)
@0,802,951us: [+0 T:0x425a5620 S:0xbe86ea34] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_create> Enter (engine=0x94090, name='h264dec', params=0xbe86eba8)
@0,803,012us: [+0 T:0x425a5620 S:0xbe86ea04] CV - VISA_create(0x94090, 'h264dec', 0xbe86eba8, 0x2340, 'ti.sdo.ce.video2.IVIDDEC2')
@0,803,073us: [+0 T:0x425a5620 S:0xbe86e8fc] CV - VISA_create2(0x94090, 'h264dec', 0xbe86eba8, 0x1c, 0x2340, 'ti.sdo.ce.video2.IVIDDEC2')
@0,803,103us: [+0 T:0x425a5620 S:0xbe86e8e4] OM - Memory_alloc> Enter(0x34)
@0,803,134us: [+0 T:0x425a5620 S:0xbe86e8e4] OM - Memory_alloc> return (0x946d0)
@0,803,164us: [+0 T:0x425a5620 S:0xbe86e8e4] OM - Memory_alloc> Enter(0x4)
@0,803,195us: [+0 T:0x425a5620 S:0xbe86e8e4] OM - Memory_alloc> return (0x94708)
@0,803,225us: [+0 T:0x425a5620 S:0xbe86e8dc] OC - Comm_alloc> Enter(poolId=0x0, msg=0x94708, size=2340)
@0,803,286us: [+0 T:0x425a5620 S:0xbe86e8dc] OC - Comm_alloc> msg=0x435b9880, returning (0)
@0,803,317us: [+0 T:0x425a5620 S:0xbe86e884] CE - Engine_createNode(0x94090, 'h264dec', 2340, 0xbe86eba8, 0x1c, 0xbe86e9f8)
@0,803,347us: [+0 T:0x425a5620 S:0xbe86e884] CE - Engine> allocNode Enter(engine=0x94090, impId='h264dec')
@0,803,378us: [+0 T:0x425a5620 S:0xbe86e86c] OM - Memory_alloc> Enter(0x20)
@0,803,408us: [+0 T:0x425a5620 S:0xbe86e86c] OM - Memory_alloc> return (0x94718)
@0,803,439us: [+0 T:0x425a5620 S:0xbe86e884] CE - Engine> allocNode(). Calling (Comm_create(gppfromnode_1135_1, 0x94720, NULL)
@0,803,470us: [+0 T:0x425a5620 S:0xbe86e85c] OC - Comm_create> Enter(queueName='gppfromnode_1135_1', queue=0x94720, attrs=0x0)
@0,803,500us: [+0 T:0x425a5620 S:0xbe86e844] OM - Memory_alloc> Enter(0x4)
@0,803,531us: [+0 T:0x425a5620 S:0xbe86e844] OM - Memory_alloc> return (0x94740)
@0,814,975us: [+0 T:0x425a5620 S:0xbe86e85c] OC - Comm_create> return (0x94740)
@0,815,066us: [+0 T:0x425a5620 S:0xbe86e864] OC - Comm_put> Enter(queue=0x0, msg=0x435b8880)
@0,815,158us: [+0 T:0x425a5620 S:0xbe86e864] OC - Comm_put> return (0)
@0,815,188us: [+0 T:0x425a5620 S:0xbe86e85c] OC - Comm_get> Enter(queue=0x10000, msg=0xbe86e90c, timeout=-1)
As you can see, the app simply hangs on this Comm_get call.
I tried with different video codecs, such as mpeg4enc and h264enc, and it perfectly works. The problem seems to appear when using video decoders (both mpeg4dec and h264dec), and I think it could be due to some bad memory configuration in my files. It is also weird that I can't see any DSP tracing, even if it should be enabled.
Any idea how to solve this?
Thanks for your support.
Gabriele
