TDA4VEN-Q1: Slow struct assignment on TDA4VEN MCU R5F
Part Number: TDA4VEN-Q1
Other Parts Discussed in Thread: AWR2944
Environment:
Device: TDA4VEN
SDK: 11.0.0
Core: MCU domain R5F (MCU Channel)
Compiler options: Release, -Os
Measurement method: Check GTC time before and after the loop
Issue Description:
I am running a for loop on the MCU R5F that involves swapping a struct of about 80 bytes. Each swap performs 3 struct assignments, and the outer loop runs 3100 times. The total time is about 5.8 ms. The same code takes about 3 ms on the TI AWR2944 MCU R5F. TDA4VEN is noticeably slower.
I placed .text, .bss, and .data into TCM and 512KB OCRAM separately, and the timing is almost the same (about 5.8 ms).
Currently, with -Os and -O3, the timing is about the same.
Test Code:
typedef struct
    float f32ObjX;
    float f32ObjY;
}G_MAP_ObjCoor_struct_t;
typedef struct
	G_MAP_ObjCoor_struct_t				    strObjCarCoor;
	G_MAP_ObjCoor_struct_t				    strObjOdoCoor;
	uint8       e_feature_type;
    uint8         e_match_type;
    uint8         e_signalway;
    float                                   f32_angle;
    float                                   PointCar_angle;
	uint64                                  u64_timestamp;
    uint8                                   u8_vaild_pro;
	sint8								    s8Cluster_Id;
	uint8                                   u8_exist_prob;
#if 0
    uint8                                   u8_high_prob;
    uint8                                   u8_low_prob;
#endif
	uint8								    u8_PointHeightType;
    sint8                                   s8_PointHeightProba;
    uint8                                   u8_is_sharp;
    uint8                                   u8_is_line;
    uint8                                   u8_is_line_ep;
	uint8								    u8_PointCloud_Id;
	uint8								    u8_is_used;
    uint8                                   u8_is_ML_Used;
    uint8                                   u8_MeasType;
    uint8                                   u8_MasterSnsId;
    uint8                                   u8_ListenSnsId;
    uint8                                   u8_Point_index;
    uint8                                   u8_Confidence;
    uint8                                   u8_is_history;
    uint8                                   u8_is_New;
    uint8                                   u8_PointCloudArea;
    uint16                                  u16_PointToCarDist;
    uint16                                  u16_MasterEchoDist;
    uint16                                  u16_ListenEchoDist;
    uint16                                  u16_MasterEchoHeight;
    uint16                                  u16_ListenEchoHeight;
    uint16                                  u16_MasterSecondDis;
    uint16                                  u16_ListenSecondDis;
    uint16                                  u16_MasterSecondHeight;
    uint16                                  u16_ListenSecondHeight;
}G_MapPointCloud_struct_t1;
volatile G_MapPointCloud_struct_t1 dat1;
volatile G_MapPointCloud_struct_t1 dat2;
volatile G_MapPointCloud_struct_t1 dat3;
void Bsw_20ms_Task(void *args)
    memset((void *)&dat1, 0x5a, sizeof(G_MapPointCloud_struct_t1));
    memset((void *)&dat2, 0xa5, sizeof(G_MapPointCloud_struct_t1));
    memset((void *)&dat3, 0x7e, sizeof(G_MapPointCloud_struct_t1));
    time1 = GetGTCTime();
    for(uint16 i = 0; i < 3100; i++)
        dat1 = dat2;
        dat2 = dat3;
        dat3 = dat1;
    time2 = GetGTCTime();
    printf("time = %llu\n", time2 - time1);
How can I optimize the execution speed in this case? Does TI have any suggestions?
Best regards
Bingxian
