hi,
Recently released a new DEMO: Capture Encode/Decode Display application
http://processors.wiki.ti.com/index.php/Latency_Measurement_on_Capture_Encode_Decode_Display_Demo
But i run error..
root@dm814x-evm:/test# ./runCaptureEncodeDecodeDisplay
VPSS_GRPX : please open fb1 node first.
Simple mixer control 'Left PGA Mixer Mic3L',0
Capabilities: pswitch pswitch-joined penum
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Left PGA Mixer Mic3R',0
Mono: Playback [on]
Simple mixer control 'Right PGA Mixer Mic3L',0
Mono: Playback [on]
Simple mixer control 'Right PGA Mixer Mic3R',0
Mono: Playback [on]
numid=1,iface=MIXER,name='PCM Playback Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
: values=96,96
| dBscale-min=-63.50dB,step=0.50dB,mute=0
numid=37,iface=MIXER,name='PGA Capture Volume'
; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
: values=90,90
| dBscale-min=0.00dB,step=0.50dB,mute=0
bit_rate: 6000000
frame_rate: 60
num_frames: 5000
mode: 1080p
capture_id: 0
display_id: 0
Capture-DEI-Encode-Decode-Scale-Display example
OMX_Init completed
UIAClient is ready to send a UIA configuration command
UIAClient received UIA_CONFIGURE_ACK
UIAClient is done sending requests
before IL_ClientInit
ilclient going on1
capture compoenent is created
control TVP compoenent is created
Buffer Size computed: 3110400
set input port params (width = 1920, height = 1080)enable capture output port
got eventEnable/Disable Event
dei compoenent is created
set output port params (width = 1920, height = 1080)set output port params (widt
h = 1920, height = 1080)set number of channelsset input resolutionset output res
olutionenable dei input port
enable dei output port 0
enable dei output port 1
encoder compoenent is created
decoder compoenent is created
PADX: 32 PADY: 24
level set is 12
scalar compoenent is created
set output resolution
enable scalar input port
enable scalar output port
found handle 0x148638 for component OMX.TI.VPSSM3.VFDC
got display handle
found handle 0x14c140 for component OMX.TI.VPSSM3.CTRL.DC
Buffer Size computed: 4147200
set input port params (width = 1920, height = 1080)setting input and output memo
ry type to defaultenable input port
connect call for capture-Dei
connect call for dei- encoder
connect call for encode- decode
connect call for decoder-scalar
connect call for scalar-display
got event*** unrecoverable error: OMX_ErrorUndefined (0x80001001)
Press a key to proceed
why?
can you help me?
zhan
