Makefile dependency problem
I'm trying to build an example where I've added a source file under a new directory (/interface) but the compiler doesn't seem to like the new source file being under a new directory.
I have added the file ipc.c under the /interface directory.
I'm not completely sure where it goes wrong. I've pasted the Makefile.
# ======== Makefile ========
include ../products.mak
srcs = main_host.c interface/ipc.c
objs = $(addprefix bin/$(PROFILE)/obj/,$(patsubst %.c,%.o$(SUFFIX),$(srcs)))
libs = $(SYSLINK_INSTALL_DIR)/packages/ti/syslink/lib/syslink.a_$(PROFILE)
MAKEVARS = \
SYSLINK_INSTALL_DIR=$(SYSLINK_INSTALL_DIR) \
PKGPATH=$(PKGPATH)
all:
@$(ECHO) "!"
@$(ECHO) "! Making $@ ..."
$(MAKE) $(MAKEVARS) PROFILE=debug SUFFIX=v5T togs2_host
$(MAKE) $(MAKEVARS) PROFILE=release SUFFIX=v5T togs2_host
install:
@$(ECHO) "#"
@$(ECHO) "# Making $@ ..."
@$(MKDIR) $(INSTALL_DIR)/debug
$(CP) bin/debug/togs2_host $(INSTALL_DIR)/debug
@$(MKDIR) $(INSTALL_DIR)/release
$(CP) bin/release/togs2_host $(INSTALL_DIR)/release
clean::
$(RMDIR) bin
# ======== rules ========
togs2_host: bin/$(PROFILE)/togs2_host
bin/$(PROFILE)/togs2_host: $(objs) $(libs)
@$(ECHO) "##"
@$(ECHO) "## Making $@ ..."
$(LD) $(LDFLAGS) -o $@ $^ $(LDLIBS)
bin/$(PROFILE)/obj/%.o$(SUFFIX): %.h
bin/$(PROFILE)/obj/%.o$(SUFFIX): %.c
@$(ECHO) "###"
@$(ECHO) "### Making $@ ..."
$(CC) $(CPPFLAGS) $(CFLAGS) -o $@ $<
# ======== create output directories ========
ifneq (clean,$(MAKECMDGOALS))
ifneq (,$(PROFILE))
ifeq (,$(wildcard bin/$(PROFILE)))
$(shell $(MKDIR) -p bin/$(PROFILE))
endif
ifeq (,$(wildcard bin/$(PROFILE)/obj))
$(shell $(MKDIR) -p bin/$(PROFILE)/obj)
endif
endif
endif
# ======== install validation ========
ifeq (install,$(MAKECMDGOALS))
ifeq (,$(INSTALL_DIR))
$(error must specify INSTALL_DIR)
endif
endif
# ======== toolchain macros ========
ifeq (v5T,$(SUFFIX))
CC = $(CS_ARM_INSTALL_DIR)gcc -c -MD -MF $@.dep -march=armv5t
AR = $(CS_ARM_INSTALL_DIR)ar cr
LD = $(CS_ARM_INSTALL_DIR)gcc
CPPFLAGS = -D_REENTRANT -Dxdc_target_name__=GCArmv5T \
-Dxdc_target_types__=gnu/targets/arm/std.h
CFLAGS = -Wall -ffloat-store -fPIC -Wunused -Dfar= $(CCPROFILE_$(PROFILE)) \
-I. -I/interface $(addprefix -I,$(subst +, ,$(PKGPATH)))
LDFLAGS = $(LDPROFILE_$(PROFILE)) -Wall -Wl,-Map=$@.map
LDLIBS = -lpthread -lc
CCPROFILE_debug = -ggdb -D DEBUG
CCPROFILE_release = -O3 -D NDEBUG
LDPROFILE_debug = -ggdb
LDPROFILE_release = -O3
endif
Any suggestions will be greatly appreciated.
Cheers
Rolf CDLtd
