SYSLINK for QNX
How to build TI syslink examples for QNX target DM814x on Windows build environment?
  • Generally same as all other OS's: http://processors.wiki.ti.com/index.php/SysLink_Install_Guide
    • set up products.mak
    • make syslink
    • make samples
    • make install
    Running is a little different, but that SysLink Install Guide has all the details.
    Chris
    I managed to build the Syslink Driver and the applications for QNX platform for TI814x target. But when i try to run the syslink examples (i.e MessageQ). I get the following error
    Can any one tell me how to fix this ? Is syslink functional on QNX. I am using  syslink_2_10_03_20 . Syslink is offcially supported in this version.
    # run syslink_drv
    sh: run: cannot execute - No such file or directory
    # sh run_syslink_drv.sh
    + export TRACE=1
    + export TRACEFAILURE=1
    + syslink_drv
    <1>Trace enabled
    <1>Trace SetFailureReason enabled
    # sh run_messageqapp_debug.sh
    frameq_g                                messageq_ti81xx_dsp.xe674
    inetd.pid                               messageq_ti81xx_videom3.xem3
    libsyslink.so.1                         messageq_ti81xx_vpssm3.xem3
    libsyslink_common.so.1                  resolv.conf
    libsyslink_common_g.so.1                run_messageqapp_debug.sh
    libsyslink_g.so.1                       run_syslink_drv.sh
    libsyslink_slave_loader.so.1            slaveloader
    libsyslink_slave_loader_g.so.1          slaveloader_g
    messageQ                                syslink_drv
    messageQ_g                              syslink_shm
    run_messageqapp.sh        run_messageqapp_debug.sh
    # sh run_messageqapp.sh
    + /dev/shmem/slaveloader_g startup DSP /dev/shmem/messageq_ti81xx_dsp.xe674
    Attached to slave procId 0.
    Loading procId 0.
    Loaded file /dev/shmem/messageq_ti81xx_dsp.xe674 on slave procId 0.
    Started slave procId 0.
    + /dev/shmem/slaveloader_g startup VIDEO-M3 /dev/shmem/messageq_ti81xx_videom3.xem3
    Attached to slave procId 1.
    Loading procId 1.
    Loaded file /dev/shmem/messageq_ti81xx_videom3.xem3 on slave procId 1.
    Started slave procId 1.
    + /dev/shmem/slaveloader_g startup VPSS-M3 /dev/shmem/messageq_ti81xx_vpssm3.xem3
    Attached to slave procId 2.
    Loading procId 2.
    Loaded file /dev/shmem/messageq_ti81xx_vpssm3.xem3 on slave procId 2.
    Started slave procId 2.
    + /dev/shmem/messageQ_g
    MessageQApp sample application
    Run for all supported proc IDs
    Entered MessageQApp_startup
    After Ipc_loadcallback:
        status [0x0]
    <1>Assertion at Line no: 136 in /db/atree/library/trees/sl/sl-c20/src/packages/ti/syslink/product/export/syslink_2_10_03_20/packages/ti/syslink/../../ti/syslink/ipc/hlos/knl/Qnx/Ipc_devctl.c: (out->apiStatus >= 0) : failed
    Error in Ipc_control Ipc_CONTROLCMD_STARTCALLBACK[0xffffffff]
    Leaving MessageQApp_startup ffffffff
    + /dev/shmem/slaveloader_g shutdown VPSS-M3
    Stopped slave procId 2.
    Unloaded slave procId 2.
    Detached from slave procId 2.
    + /dev/shmem/slaveloader_g shutdown VIDEO-M3
    Stopped slave procId 1.
    Unloaded slave procId 1.
    Detached from slave procId 1.
    + /dev/shmem/slaveloader_g shutdown DSP
    Stopped slave procId 0.
    Unloaded slave procId 0.
    Detached from slave procId 0.
    + /dev/shmem/messageQ_g 1 DSP /dev/shmem/messageq_ti81xx_dsp.xe674
    Loading and starting procId [0] with [/dev/shmem/messageq_ti81xx_dsp.xe674]
    Loading procId 0.
    SlaveLoader_startup status [111693824]
        status [0x0]
    - Thanks in Advance.
    Srinivas
  • Hi Srinivas,
    Could you check your products.mak to see what value you have for the variable TI81XXDSP_DMTIMER_FREQ? By default it is set to 32768, but it may or may not match your actual dmtimer frequency (another common value is 20000000). You need to match it up if it isn't already done, otherwise the slave would configure timer interrupts at the wrong rate.
    Let us know afterwards if you are still having issues.
    Vincent
