AM62P: DDR throughput comparison
Part Number: AM62P
In order to compare AM62P and AM62x DDR performance at the same condition, configure 62P DDR to 16bit 800MHz, its stress-ng stream result is much lower than that of AM62x.
  #1. Default SDK configuration, AM62P 32bit 1600MHz:
root@am62pxx-evm:~# k3conf dump clock | grep DDR
| F/w Capabilities | 0x27f7: GEN DEEP_SLP MCU_ONLY PART_IO DM_MGD_LPM IO+DDR_RET IO_ISO DM-SPLT  |
|   157     |    40    | DEV_BOARD0_DDR0_CK0_IN        | CLK_STATE_READY     | 250000000       |
|   170     |     0    | DEV_DDR32SS0_DDR_PLL_DIVH_CLK4_OBSCLK_OUT_CLK                                                       | CLK_STATE_READY     | 0               |
|   170     |     1    | DEV_DDR32SS0_DDRSS_DDR_PLL_CLK        | CLK_STATE_READY     | 800000000       |
|   170     |     2    | DEV_DDR32SS0_DDRSS_TCK        | CLK_STATE_READY     | 0               |
|   170     |     3    | DEV_DDR32SS0_PLL_CTRL_CLK        | CLK_STATE_READY     | 500000000       |
|   228     |    16    | DEV_OBSCLK0_MUX_SEL_DEV_VD_CLK_PARENT_SAM67_DDR_WRAP_MAIN_0_DDR_PLL_DIVH_CLK4_OBSCLK_OUT_CLK        | CLK_STATE_READY     | 0               |
root@am62pxx-evm:~
root@am62pxx-evm:~# stress-ng --stream 4 --stream-l3-size 64M --metrics-brief --timeout 120s
stress-ng: info:  [1552] setting to a 2 mins run per stressor
stress-ng: info:  [1552] dispatching hogs: 4 stream
stress-ng: info:  [1553] stream: using cache size of 65536K
stress-ng: info:  [1553] stream: stressor loosely based on a variant of the STREAM benchmark code
stress-ng: info:  [1553] stream: do NOT submit any of these results to the STREAM benchmark results
stress-ng: info:  [1553] stream: using 3 cache sized buffers for stream operations, total 49152K per stream instance
stress-ng: info:  [1555] stream: memory rate: 371.70 MB read/sec, 247.80 MB write/sec, 32.48 double precision Mflop/sec (instance 2)
stress-ng: info:  [1556] stream: memory rate: 364.43 MB read/sec, 242.95 MB write/sec, 31.84 double precision Mflop/sec (instance 3)
stress-ng: info:  [1553] stream: memory rate: 369.67 MB read/sec, 246.45 MB write/sec, 32.30 double precision Mflop/sec (instance 0)
stress-ng: info:  [1554] stream: memory rate: 370.98 MB read/sec, 247.32 MB write/sec, 32.42 double precision Mflop/sec (instance 1)
stress-ng: metrc: [1552] stressor       bogo ops real time  usr time  sys time   bogo ops/s     bogo ops/s
stress-ng: metrc: [1552]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: metrc: [1552] stream             1841    120.27    119.22      0.49        15.31          15.38
stress-ng: info:  [1552] skipped: 0
stress-ng: info:  [1552] passed: 4: stream (4)
stress-ng: info:  [1552] failed: 0
stress-ng: info:  [1552] metrics untrustworthy: 0
stress-ng: info:  [1552] successful run completed in 2 mins
root@am62pxx-evm:~#
#2. AM62P 16bit 800MHz:
root@am62pxx-evm:~#  k3conf dump clock |grep DDR
|   170     |     1    | DEV_DDR32SS0_DDRSS_DDR_PLL_CLK        | CLK_STATE_READY     | 400000000       |
stress-ng: info:  [1863] setting to a 2 mins run per stressor
stress-ng: info:  [1863] dispatching hogs: 4 stream
stress-ng: info:  [1864] stream: using cache size of 65536K
stress-ng: info:  [1864] stream: stressor loosely based on a variant of the STREAM benchmark code
stress-ng: info:  [1864] stream: do NOT submit any of these results to the STREAM benchmark results
stress-ng: info:  [1864] stream: using 3 cache sized buffers for stream operations, total 49152K per stream instance
stress-ng: info:  [1866] stream: memory rate: 183.29 MB read/sec, 122.19 MB write/sec, 16.02 double precision Mflop/sec (instance 2)
stress-ng: info:  [1864] stream: memory rate: 191.86 MB read/sec, 127.91 MB write/sec, 16.77 double precision Mflop/sec (instance 0)
stress-ng: info:  [1865] stream: memory rate: 181.24 MB read/sec, 120.82 MB write/sec, 15.84 double precision Mflop/sec (instance 1)
stress-ng: info:  [1867] stream: memory rate: 172.29 MB read/sec, 114.86 MB write/sec, 15.05 double precision Mflop/sec (instance 3)
stress-ng: metrc: [1863] stressor       bogo ops real time  usr time  sys time   bogo ops/s     bogo ops/s
stress-ng: metrc: [1863]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: metrc: [1863] stream              908    120.26    340.36      7.11         7.55           2.61
stress-ng: info:  [1863] skipped: 0
stress-ng: info:  [1863] passed: 4: stream (4)
stress-ng: info:  [1863] failed: 0
stress-ng: info:  [1863] metrics untrustworthy: 0
stress-ng: info:  [1863] successful run completed in 2 mins
root@am62pxx-evm:~#
#3. AM62x 16bit 800MHz:
root@am62xx-evm:~# k3conf dump clock |grep DDR
|   157     |    24    | DEV_BOARD0_DDR0_CK0_IN        | CLK_STATE_READY     | 250000000       |
|   157     |    25    | DEV_BOARD0_DDR0_CK0_N_IN        | CLK_STATE_READY     | 0               |
|   157     |    27    | DEV_BOARD0_DDR0_CK0_OUT        | CLK_STATE_READY     | 0               |
|   170     |     0    | DEV_DDR16SS0_DDRSS_DDR_PLL_CLK        | CLK_STATE_READY     | 400000000       |
|   170     |     1    | DEV_DDR16SS0_DDRSS_TCK        | CLK_STATE_READY     | 0               |
|   170     |     2    | DEV_DDR16SS0_PLL_CTRL_CLK        | CLK_STATE_READY     | 500000000       |
root@am62xx-evm:~#
root@am62xx-evm:~# stress-ng --stream 4 --stream-l3-size 64M --metrics-brief --timeout 120s
stress-ng: info:  [5090] setting to a 2 mins run per stressor
stress-ng: info:  [5090] dispatching hogs: 4 stream
stress-ng: info:  [5091] stream: using cache size of 65536K
stress-ng: info:  [5091] stream: stressor loosely based on a variant of the STREAM benchmark code
stress-ng: info:  [5091] stream: do NOT submit any of these results to the STREAM benchmark results
stress-ng: info:  [5091] stream: using 3 cache sized buffers for stream operations, total 49152K per stream instance
stress-ng: info:  [5092] stream: memory rate: 322.11 MB read/sec, 214.74 MB write/sec, 28.15 double precision Mflop/sec (instance 1)
stress-ng: info:  [5091] stream: memory rate: 311.86 MB read/sec, 207.91 MB write/sec, 27.25 double precision Mflop/sec (instance 0)
stress-ng: info:  [5094] stream: memory rate: 315.15 MB read/sec, 210.10 MB write/sec, 27.54 double precision Mflop/sec (instance 3)
stress-ng: info:  [5093] stream: memory rate: 309.62 MB read/sec, 206.41 MB write/sec, 27.06 double precision Mflop/sec (instance 2)
stress-ng: metrc: [5090] stressor       bogo ops real time  usr time  sys time   bogo ops/s     bogo ops/s
stress-ng: metrc: [5090]                           (secs)    (secs)    (secs)   (real time) (usr+sys time)
stress-ng: metrc: [5090] stream             1569    120.18    373.38      6.12        13.06           4.13
stress-ng: info:  [5090] skipped: 0
stress-ng: info:  [5090] passed: 4: stream (4)
stress-ng: info:  [5090] failed: 0
stress-ng: info:  [5090] metrics untrustworthy: 0
stress-ng: info:  [5090] successful run completed in 2 mins
Confirmed 16bit Vs 32bit setting on AM62P board:
16bit:
root@am62pxx-evm:~# devmem2 0x0f308534
/dev/mem opened.
Memory mapped at address 0xffff8ff28000.
Read at address  0x0F308534 (0xffff8ff28534): 0x00010C03
32bit:
/dev/mem opened.
Memory mapped at address 0xffff8263e000.
Read at address  0x0F308534 (0xffff8263e534): 0x00000C03
root@am62pxx-evm:~#
AM62x run at 800MHz 16bit, stream result is close to AM62P 1600MhHz 32bit. which is not reasonable.
