How to configure AM335x CLKOUT2 output to 25Mhz from mater oscillator 24Mhz ?
Thanks & Regards
Keldy
Hi James,
i choose the L3Fclock (core PLL) as souce of CLKOUT2. Am i correct with my configuration below?
CONF_XDMA_EVENT_INTR1 = 0x3; //set pin mux to mode 3
CM_CLKMODE_DPLL_CORE = 0x04; // set PLL to bypass mode
while(CM_IDLEST_DPLL_CORE != 0x00000100); //wait ST_MN_BYPASS = 1 to ensure PLL is in bypass
CM_CLKSEL_DPLL_CORE = (1000 << 0x8) | 23; // set DPLL_MULT = 1000, set DPLL_DIV = 23, Core PLL = 1GHz
CM_DIV_M4_DPLL_CORE = 10; //CORE_CLKOUTM4 = 200 MHZ
CM_CLKMODE_DPLL_CORE = 0x7; //set DPLL in lock mode
while(CM_IDLEST_DPLL_CORE != 0x1); //wait to ensure DPLL in lock mode
CM_CLKOUT_CTRL = 0xB9; // enable CLKOUT2, select L3 clock, divide 8 (200Mhz /8 = 25Mhz)
Thanks & Regards
Keldy
