hdmi frame buffer
Other Parts Discussed in Thread: TWL6030, WL1271, 4430
I cant get the display on omap4430 panda board through hdmi as well as dvi
Her is my log.
Whats the problem i cannnot setup the framebuffer
U-Boot 1.1.4-g1632ce3f-dirty (Apr  4 2011 - 13:13:46)
Load address: 0x80e80000
DRAM:  1024 MB
Flash:  0 kB
Using default environment
In:    serial
Out:   serial
Err:   serial
efi partition table:
     256     128K xloader
     512     256K bootloader
    2048       8M boot
   18432     256M system
  542720     256M cache
 1067008     512M userdata
 2115584    2451M media
Net:   KS8851SNL
Hit any key to stop autoboot:  0
kernel   @ 80008000 (4011960)
ramdisk  @ 81000000 (163071)
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.0.8-gebb6cb6-dirty (sandeep@sandeep) (gcc versi2
[    0.000000] CPU: ARMv7 Processor [411fc092] revision 2 (ARMv7), cr=10c5387f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cace
[    0.000000] Machine: OMAP4 Panda board
[    0.000000] Truncating RAM at 80000000-bfffffff to -afffffff (vmalloc regio.
[    0.000000] Reserving 33554432 bytes SDRAM for VRAM
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] OMAP4430 ES2.2
[    0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[    0.000000] On node 0 totalpages: 186112
[    0.000000] free_area_init_node: node 0, pgdat c07c7040, node_mem_map c093b0
[    0.000000]   Normal zone: 1536 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 184576 pages, LIFO batch:31
[    0.000000] PERCPU: Embedded 7 pages/cpu @c0f45000 s6912 r8192 d13568 u32768
[    0.000000] pcpu-alloc: s6912 r8192 d13568 u32768 alloc=8*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total p6
[    0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G androidboot.2
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 512MB 215MB = 727MB total
[    0.000000] Memory: 727804k/1235464k available, 75256k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xf0800000 - 0xf8000000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .init : 0xc0008000 - 0xc0047000   ( 252 kB)
[    0.000000]       .text : 0xc0047000 - 0xc0768000   (7300 kB)
[    0.000000]       .data : 0xc0768000 - 0xc07c7820   ( 383 kB)
[    0.000000]        .bss : 0xc07c7844 - 0xc093ace8   (1486 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2,1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:410
[    0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2.
[    0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[    0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every s
[    0.000061] Calibrating delay loop... 2007.19 BogoMIPS (lpj=7839744)
[    0.015716] pid_max: default: 32768 minimum: 301
[    0.015716] Mount-cache hash table entries: 512
[    0.070678] Initializing cgroup subsys debug
[    0.070678] Initializing cgroup subsys cpuacct
[    0.071441] Initializing cgroup subsys freezer
[    0.071441] CPU: Testing write buffer coherency: ok
[    0.071746] L310 cache controller enabled
[    0.071868] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x5e470000, Cache B
[    0.149993] CPU1: Booted secondary processor
[    0.220336] Brought up 2 CPUs
[    0.220336] SMP: Total of 2 processors activated (4022.78 BogoMIPS).
[    0.220520] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_w
[    0.220520] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_inr
[    0.222930] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_ma1
[    0.222930] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_ma2
[    0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[    0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[    0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[    0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkp
[    0.222991] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_pe
[    0.222991] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[    0.223083] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhsi
[    0.223083] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[    0.230987] omap_hwmod: mcpdm: cannot be enabled (3)
[    0.233001] print_constraints: dummy:
[    0.233001] NET: Registered protocol family 16
[    0.233001] GPMC revision 6.0
[    0.234527] EMIF0 is enabled with IRQ142
[    0.234527] EMIF1 is enabled with IRQ143
[    0.234619] Last reset was warm software cold reset (PRM_RSTST=0x3)
[    0.234619]
[    0.234649] HSI: device registered as omap_hwmod: hsi
[    0.234893] OMAP GPIO hardware version 0.1
[    0.236236] omap_mux_init: Add partition: #1: core, flags: 2
[    0.236236] omap_mux_init: Add partition: #2: wkup, flags: 2
[    0.237304] ram_console: got buffer at a0000000, size 200000
[    0.237304] ram_console: uncorrectable error in header
[    0.237304] ram_console: no valid data in buffer (sig = 0x2aeb6ace)
[    0.244812] console [ram-1] enabled
[    0.244873] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[    0.245758] omap_hwmod_mux_init: Could not allocate device mux entry
[    0.255035] OMAP DMA hardware revision 0.0
[    0.260894] bio: create slab <bio-0> at 0
[    0.261260] print_constraints: vwl1271: 1800 mV
[    0.262237] SCSI subsystem initialized
[    0.262237] usbcore: registered new interface driver usbfs
[    0.262237] usbcore: registered new interface driver hub
[    0.262817] usbcore: registered new device driver usb
[    0.274963] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[    0.275024] Skipping twl internal clock init and using bootloader value (un)
[    0.276031] twl6030: PIH (irq 39) chaining IRQs 368..387
[    0.277648] print_constraints: VUSB: 3300 mV normal standby
[    0.481048] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[    0.482147] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal sty
[    0.482666] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal stay
[    0.483001] print_constraints: VCXIO: 1800 mV normal standby
[    0.483001] print_constraints: VDAC: 1800 mV normal standby
[    0.483825] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV nory
[    0.484313] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV nory
[    0.485260] print_constraints: CLK32KG:
[    0.485260] print_constraints: VANA: 2100 mV normal standby
[    0.493713] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[    0.509399] omap_i2c omap_i2c.3: bus 3 rev4.0 at 100 kHz
[    0.524963] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[    0.525512] omap-rproc omap-rproc.0: dsp is available
[    0.525512] omap-rproc omap-rproc.1: ipu is available
[    0.525512] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.526489] Bluetooth: Core ver 2.16
[    0.526489] NET: Registered protocol family 31
[    0.526489] Bluetooth: HCI device and connection manager initialized
[    0.526885] Bluetooth: HCI socket layer initialized
[    0.526885] Bluetooth: L2CAP socket layer initialized
[    0.527069] Bluetooth: SCO socket layer initialized
[    0.527465] cfg80211: Calling CRDA to update world regulatory domain
[    0.528289] Switching to clocksource 32k_counter
[    0.529724] musb-hdrc: version 6.0, musb-dma, peripheral
[    0.529998] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bu)
[    0.530242] musb-hdrc: MHDRC RTL version 2.0
[    0.530242] musb-hdrc: setup fifo_mode 4
[    0.530456] musb-hdrc: 28/31 max ep, 16384/16384 memory
[    0.530456] musb-hdrc musb-hdrc: USB Peripheral mode controller at fc0ab0004
[    0.531036] NET: Registered protocol family 2
[    0.531341] IP route cache hash table entries: 32768 (order: 5, 131072 byte)
[    0.532379] TCP established hash table entries: 131072 (order: 8, 1048576 b)
[    0.532806] Switched to NOHz mode on CPU #0
[    0.532836] Switched to NOHz mode on CPU #1
[    0.533020] TCP bind hash table entries: 65536 (order: 8, 1572864 bytes)
[    0.536285] TCP: Hash tables configured (established 131072 bind 65536)
[    0.536285] TCP reno registered
[    0.536285] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.536285] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.539154] NET: Registered protocol family 1
[    0.539154] Trying to unpack rootfs image as initramfs...
[    0.549652] Freeing initrd memory: 156K
[    0.872222] omap-iommu omap-iommu.0: ducati registered
[    0.873321] omap-iommu omap-iommu.1: tesla registered
[    0.888397] ashmem: initialized
[    0.892639] fuse init (API version 7.16)
[    0.892639] msgmni has been set to 1421
[    0.896087] io scheduler noop registered
[    0.896240] io scheduler deadline registered
[    0.896240] io scheduler cfq registered (default)
[    0.896484] start plist test
[    0.901489] end plist test
[    0.905120] OMAP DSS rev 4.0
[    0.912536] dsscomp: initializing.
[    0.912536] misc dsscomp: display0=generic_dpi_panel
[    0.913085] misc dsscomp: display1=hdmi_panel
[    0.913085] misc dsscomp: found 2 displays and 4 overlays
[    0.913604] could not allocate slot
[    0.913970] omap-rproc omap-rproc.1: powering up ipu
[    0.914215] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successy
[    0.914215] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successy
[    0.915588] rpmsg_virtio TX: 28 00 00 00 64 00 00 00 35 00 00 00 00 00 00 0.
[    0.915588] rpmsg_virtio TX: 72 70 6d 73 67 2d 72 65 73 6d 67 72 00 00 00 0.
[    0.915588] rpmsg_virtio TX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0.
[    0.915832] rpmsg_virtio TX: 64 00 00 00 00 00 00 00                       .
[    0.915832] rpmsg_virtio TX: 28 00 00 00 64 00 00 00 35 00 00 00 00 00 00 0.
[    0.916168] rpmsg_virtio TX: 72 70 6d 73 67 2d 72 65 73 6d 67 72 00 00 00 0.
[    0.916168] rpmsg_virtio TX: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0.
[    0.916534] rpmsg_virtio TX: 64 00 00 00 00 00 00 00                       .
[    0.916534] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UAR0
[    0.958221] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UAR1
[    0.958221] in hpd work 1, state=0
[    0.958251] omapdss HDMI: ENTER hdmi_display_enable
[    1.020660] in hpd work 2, state=1
[    1.091064] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UAR2
[    1.672821] edid[000] = 00 ff ff ff ff ff ff 00 1e 6d e1 57 d0 1e 00 00
[    1.672821] edid[010] = 07 15 01 03 80 30 1b 78 ea 95 35 a1 59 57 9f 27
[    1.672851] edid[020] = 0e 50 54 a5 4b 00 b3 00 81 80 81 8f 71 4f 01 01
[    1.672851] edid[030] = 01 01 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
[    1.672851] edid[040] = 45 00 dd 0c 11 00 00 1e 00 00 00 fd 00 38 4b 1e
[    1.672882] edid[050] = 53 0f 00 0a 20 20 20 20 20 20 00 00 00 fc 00 45
[    1.672882] edid[060] = 32 32 36 30 0a 20 20 20 20 20 20 20 00 00 00 ff
[    1.672912] edid[070] = 00 31 30 37 4c 54 4c 4d 30 37 38 38 38 0a 01 85
[    1.672912] edid[080] = 02 03 1d f1 4a 90 04 03 01 14 12 05 1f 10 13 23
[    1.672912] edid[090] = 09 07 07 83 01 00 00 65 03 0c 00 10 00 02 3a 80
[    1.672943] edid[0a0] = 18 71 38 2d 40 58 2c 45 00 fe 22 11 00 00 1e 01
[    1.672943] edid[0b0] = 1d 80 18 71 1c 16 20 58 2c 25 00 fe 22 11 00 00
[    1.672973] edid[0c0] = 9e 01 1d 00 72 51 d0 1e 20 6e 28 55 00 fe 22 11
[    1.672973] edid[0d0] = 00 00 1e 8c 0a d0 8a 20 e0 2d 10 10 3e 96 00 fe
[    1.672973] edid[0e0] = 22 11 00 00 18 00 00 00 00 00 00 00 00 00 00 00
[    1.673004] edid[0f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 e6
[    1.673004] edid[100] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673034] edid[110] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673034] edid[120] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673065] edid[130] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673065] edid[140] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673065] edid[150] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673095] edid[160] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673095] edid[170] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673126] edid[180] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673126] edid[190] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673126] edid[1a0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673156] edid[1b0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673156] edid[1c0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673187] edid[1d0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673187] edid[1e0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673187] edid[1f0] = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[    1.673217] panel size 48 by 27
[    2.393890] console [ttyO2] enabled
[    2.466003] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UAR3
[    2.614562] PVR: PVRCore_Init
[    2.618011] PVR: PVRSRVDriverProbe(pDevice=ed4ade00)
[    2.623779] PVR: SGX register base: 0x56000000
[    2.628784] PVR: SGX register size: 65535
[    2.633270] PVR: SGX IRQ: 53
[    2.633270] PVR: EnableSystemClocks: Enabling System Clocks
[    2.633270] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency]
[    2.655761] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency]
[    2.668823] PVR: PVRCore_Init: major device 251
[    2.676910] brd: module loaded
[    2.684722] loop: module loaded
[    2.688842] (stk) :sysfs entries created
[    2.688842] (stk) : debugfs entries created
[    2.700683] PPP generic driver version 2.4.2
[    2.705780] PPP Deflate Compression module registered
[    2.711517] PPP BSD Compression module registered
[    2.717437] PPP MPPE Compression module registered
[    2.722778] NET: Registered protocol family 24
[    2.727813] usbcore: registered new interface driver asix
[    2.735351] usbcore: registered new interface driver cdc_ether
[    2.741882] usbcore: registered new interface driver smsc95xx
[    2.748413] usbcore: registered new interface driver net1080
[    2.751007] usbcore: registered new interface driver cdc_subset
[    2.761352] usbcore: registered new interface driver zaurus
[    2.767669] cdc_ncm: 04-Aug-2011
[    2.767669] usbcore: registered new interface driver cdc_ncm
[    2.771331] usbcore: registered new interface driver zd1201
[    2.771331] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.791351] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[    2.791351] ehci-omap ehci-omap.0: new USB bus registered, assigned bus num1
[    2.805999] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[    2.821105] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[    2.821105] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.835144] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumbe1
[    2.843200] usb usb1: Product: OMAP-EHCI Host Controller
[    2.849090] usb usb1: Manufacturer: Linux 3.0.8-gebb6cb6-dirty ehci_hcd
[    2.856445] usb usb1: SerialNumber: ehci-omap.0
[    2.861846] hub 1-0:1.0: USB hub found
[    2.866180] hub 1-0:1.0: 3 ports detected
[    2.896942] usbcore: registered new interface driver cdc_acm
[    2.903320] cdc_acm: USB Abstract Control Model driver for USB modems and Is
[    2.912170] Initializing USB Mass Storage driver...
[    2.912170] usbcore: registered new interface driver usb-storage
[    2.924346] USB Mass Storage support registered.
[    2.929687] usbcore: registered new interface driver usbserial
[    2.929687] usbserial: USB Serial Driver core
[    2.936157] USB Serial support registered for Keyspan - (without firmware)
[    2.948699] USB Serial support registered for Keyspan 1 port adapter
[    2.955810] USB Serial support registered for Keyspan 2 port adapter
[    2.962890] USB Serial support registered for Keyspan 4 port adapter
[    2.970031] usbcore: registered new interface driver keyspan
[    2.976440] keyspan: v1.1.5:Keyspan USB to Serial Converter Driver
[    3.185241] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    3.192871] android_usb gadget: Number of LUNs=1
[    3.192871]  lun0: LUN: removable file: (no medium)
[    3.203643] android_usb gadget: android_usb ready
[    3.203643] mousedev: PS/2 mouse device common for all mice
[    3.215332] i2c /dev entries driver
[    3.219757] usb 1-1: new high speed USB device number 2 using ehci-omap
[    3.227172] lirc_dev: IR Remote Control driver registered, major 249
[    3.234863] IR NEC protocol handler initialized
[    3.239929] IR RC5(x) protocol handler initialized
[    3.245208] IR RC6 protocol handler initialized
[    3.250244] IR JVC protocol handler initialized
[    3.255218] IR Sony protocol handler initialized
[    3.260345] IR RC5 (streamzap) protocol handler initialized
[    3.266479] IR LIRC bridge handler initialized
[    3.271453] dmm: probe base: fd300000, irq 145
[    3.278411] device-mapper: uevent: version 1.0.3
[    3.283508] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dmm
[    3.283508] Bluetooth: HCI UART driver ver 2.2
[    3.298065] Bluetooth: HCI H4 protocol initialized
[    3.303405] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[    3.311431] (stc): st_register(2)
[    3.311431] cpuidle: using governor ladder
[    3.311431] cpuidle: using governor menu
[    3.324249] (stc):  chnl_id list empty :2
[    3.328704] (stk) : st_kim_start
[    3.335205] usbcore: registered new interface driver usbhid
[    3.342071] usbhid: USB HID core driver
[    3.346649] logger: created 256K log 'log_main'
[    3.351776] logger: created 256K log 'log_events'
[    3.357177] logger: created 256K log 'log_radio'
[    3.362335] logger: created 256K log 'log_system'
[    3.368438] OMAP HSI: HSI DRIVER Version 0.4.1
[    3.373504] omap_hsi omap_hsi.0: Registering IRQ mpu_p1 (99)
[    3.379760] omap_hsi omap_hsi.0: Registering IRQ mpu_dma (103)
[    3.386383] omap_hsi omap_hsi.0: HSI Hardware REVISION 0x50043101
[    3.395843] SDP4430 SoC init
[    3.396057] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    3.396057] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber0
[    3.397583] hub 1-1:1.0: USB hub found
[    3.399658] hub 1-1:1.0: 5 ports detected
[    3.446960] (stk) :ldisc_install = 1
[    3.454132] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[    3.461395] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[    3.468749] asoc: null-codec-dai <-> Voice mapping ok
[    3.475250] asoc: null-codec-dai <-> Tones mapping ok
[    3.481842] asoc: null-codec-dai <-> Vibra mapping ok
[    3.488067] asoc: null-codec-dai <-> MODEM mapping ok
[    3.494323] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[    3.502197] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[    3.509307] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[    3.516448] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stere
[    3.526489] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[    3.532196] android_work: sent uevent USB_STATE=CONNECTED
[    3.538696] android_work: sent uevent USB_STATE=DISCONNECTED
[    3.545043] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[    3.551269] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[    3.557556] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[    3.563995] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[    3.570892] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[    3.577758] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[    3.584686] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[    3.591918] input: Panda Headset Jack as /devices/platform/soc-audio/sound/0
[    3.600769] mmc0: host does not support reading read-only switch. assuming .
[    3.612182] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[    3.619232] ALSA device list:
[    3.622558]   #0: TI OMAP4 Board
[    3.626098]   #1: OMAP4HDMI
[    3.629241] android_work: sent uevent USB_STATE=CONNECTED
[    3.635314] mmc0: new SDHC card at address e624
[    3.640686] mmcblk0: mmc0:e624 SD08G 7.40 GiB
[    3.640808] GACT probability NOT on
[    3.640808] Mirror/redirect action on
[    3.640808] u32 classifier
[    3.640808]     Actions configured
[    3.640838] Netfilter messages via NETLINK v0.30.
[    3.640899] nf_conntrack version 0.5.0 (11374 buckets, 45496 max)
[    3.641754] ctnetlink v0.93: registering with nfnetlink.
[    3.641784] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.641815] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.642059] xt_time: kernel timezone is -0000
[    3.643737] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.643920] arp_tables: (C) 2002 David S. Miller
[    3.643981] TCP cubic registered
[    3.644531] NET: Registered protocol family 10
[    3.648986] Mobile IPv6
[    3.649017] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.649322] IPv6 over IPv4 tunneling driver
[    3.653533] android_work: sent uevent USB_STATE=DISCONNECTED
[    3.653808] NET: Registered protocol family 17
[    3.653839] NET: Registered protocol family 15
[    3.653961] Bluetooth: RFCOMM TTY layer initialized
[    3.653961] Bluetooth: RFCOMM socket layer initialized
[    3.653961] Bluetooth: RFCOMM ver 1.11
[    3.653991] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.654022] NET: Registered protocol family 35
[    3.654388] lib80211: common routines for IEEE802.11 drivers
[    3.654388] lib80211_crypt: registered algorithm 'NULL'
[    3.654388] VFP support v0.3:
[    3.786834] android_work: did not send uevent (0 0   (null))
[    3.787414] implementor 41 architecture 3 part 30 variant 9 rev 1
[    3.787414] ThumbEE CPU extension supported.
[    3.787445] Registering SWP/SWPB emulation handler
[    3.810180] usb 1-1.1: new high speed USB device number 3 using ehci-omap
[    3.810211] android_work: sent uevent USB_STATE=CONNECTED
[    3.811584] Reprogramming LPDDR2 timings to 400000000 Hz
[    3.814758] Power Management for TI OMAP4.
[    3.815185] OMAP4 PM: Static dependency added between MPUSS <-> EMIF, MPUSS.
[    3.815185] OMAP4 PM: Static dependency added between DUCATI <-> L4_PER/CFG.
[    3.815399] sr_init: No PMIC hook to init smartreflex
[    3.815399] android_work: sent uevent USB_STATE=DISCONNECTED
[    3.815765] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver ind
[    3.815765] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver ind
[    3.815765] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver ind
[    3.816589] SmartReflex class 1.5 driver: initialized (86400000ms)
[    3.824981] clock: disabling unused clocks to save power
[    3.872528] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nomi0
[    3.872558] sr_class1p5_calib_work: iva: Calibration complete: Voltage Nomi0
[    3.872589] sr_class1p5_calib_work: core: Calibration complete: Voltage Nom0
[    3.906372] android_work: sent uevent USB_STATE=CONNECTED
[    3.911773] android_work: sent uevent USB_STATE=DISCONNECTED
[    3.956451] Alternate GPT is invalid, using primary GPT.
[    3.962310]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
[    4.002410] android_work: sent uevent USB_STATE=CONNECTED
[    4.060333] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    4.067993] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumb0
[    4.079010] smsc95xx v1.0.4
[    4.087921] mmc1: card claims to support voltages below the defined range. .
[    4.108428] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    4.116851] mmc1: new SDIO card at address 0001
[    4.183197] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-ehci-omap.9
[    4.247344] cannot apply mgr(lcd) on inactive device
[    4.253173] omapfb omapfb: failed to apply dispc config
[    4.259094] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nomi0
[    4.269714] cannot apply mgr(lcd2) on inactive device
[    4.275543] omapfb omapfb: failed to apply dispc config
[    4.281829] omapdss DPI: Could not find exact pixel clock. Requested 74250 z
[    4.293609] regulator_init_complete: VANA: incomplete constraints, leaving n
[    4.302551] regulator_init_complete: VCXIO: incomplete constraints, leavingn
[    4.311126] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    4.319671] Freeing init memory: 252K
[    4.328247] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom.
[    4.489532] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nomi0
[    4.536560] sr_class1p5_calib_work: core: Calibration complete: Voltage Nom0
[    4.548309] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nomi0
[    4.579193] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode.)
[    4.606903] (stk) :ldisc installation timeout
[    4.612121] (stk) :ldisc_install = 0
[    5.770812] (stk) : timed out waiting for ldisc to be un-installed
[    5.884338] (stk) :ldisc_install = 1
[    6.186004] EXT4-fs (mmcblk0p6): recovery complete
[    6.195892] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode.)
[    6.210845] EXT4-fs (mmcblk0p5): VFS: Can't find ext4 filesystem
[    6.324005] init: cannot find '/system/etc/install-recovery.sh', disabling '
[    6.338836] wl1271: ERROR could not get nvs file: -2
[    6.338897] omap-rproc omap-rproc.1: rproc_loader_cont: failed to load ducan
[    6.341064] android_usb: already disabled
[    6.341064] adb_bind_config
[    6.348571] adb_open
[    6.373931] wl1271: loaded
[    6.377777] wl1271: initialized
shell@android:/ $ [    7.053100] (stk) :ldisc installation timeout
[    7.058441] (stk) :ldisc_install = 0
[    7.103210] PVR: Installing MISR with cookie c0830818
[    7.110321] PVR: Installing device LISR SGX ISR on IRQ 53 with cookie ed5660
[    7.118835] PVR: OSUnMapPhysToLin: unmapping 65535 bytes from f0b20000
[    7.130981] PVR: SysFinalise: Version string: SGX revision = 1.2.0
[    8.216156] (stk) : timed out waiting for ldisc to be un-installed
[    8.356445] (stk) :ldisc_install = 1
[    9.519042] (stk) :ldisc installation timeout
[    9.525665] (stk) :ldisc_install = 0
[   10.684783] (stk) : timed out waiting for ldisc to be un-installed
[   10.812652] (stk) :ldisc_install = 1
[   11.966064] (stk) :ldisc installation timeout
[   11.971282] (stk) :ldisc_install = 0
[   13.130096] (stk) : timed out waiting for ldisc to be un-installed
[   13.259399] (stk) :ldisc_install = 1
[   14.419342] (stk) :ldisc installation timeout
[   14.424468] (stk) :ldisc_install = 0
[   15.583190] (stk) : timed out waiting for ldisc to be un-installed
[   15.710052] (stk) :ldisc_install = 1
[   16.864471] (stk) :ldisc installation timeout
[   16.869506] (stk) :ldisc_install = 0
[   18.036376] (stk) : timed out waiting for ldisc to be un-installed
[   18.045318] Bluetooth: st_register failed -22
[   19.579986] warning: `zygote' uses 32-bit capabilities (legacy support in u)
[   19.622558] alarm_set_rtc: no RTC, time will be lost on reboot
[   33.485656] request_suspend_state: wakeup (3->0) at 33480590823 (1970-01-02)
[   33.896850] init: no such service 'dhcpcd_eth0:-h android-57acb936b99c2cf3 '
[   33.913452] init: no such service 'dhcpcd_eth0:-h android-57acb936b99c2cf3 '
[   34.083282] acc_open
[   34.086395] acc_release
[  102.084503] request_suspend_state: sleep (0->3) at 102079498294 (1970-01-02)
[  102.096374] DSSCOMP: dsscomp_early_suspend
[  102.115509] DSSCOMP: blanked screen
