Other Parts Discussed in Thread: TVP5158, TVP7002
I have few queries about HDVPSS of Netra and centaurus device.
1) Does TI have any solution which can multiplex 2 1080p stream and generate BT.1120 output?
2) Can user set output level of Video DAC of DM816x device? e.g: In default state Video DAC of Netra gives 0.5Vpp. Is it possible to configure output to 1Vpp through register setting?
3) Can HD-DAC in DM816x run 2x over sampled? If we have video format whose base pixel clock is in the range of 40-43MHz, is it possible to output video at 2x over sample?
4) Analog video outputs of DM814x and DM816x have different output level? Is it possible to have identical circuit at the output of video DACs of both the device.
5) Is it possible to operate DM814x SD DAC output at 54MHz oversampled?
Swapnil
