Setting _c_int00 on ARM on OMAP-L138 verification
Other Parts Discussed in Thread: OMAP-L138, SYSBIOS, OMAPL138
I hope somebody from TI can help me, or if another community member has already solved this problem on the OMAP-L138 they can help...I am using SYS/BIOS on both cores and am embracing the RTSC environment and using .cfg files for all of my configurations (except this one).
I read the article for setting the _c_int00 address (http://processors.wiki.ti.com/index.php/Accessing_c_int00) using SYS/BIOS and it works perfectly for the DSP core, but the same steps don't seem to work for the ARM side.  The same steps taken seem to have no effect!
I created a command file in the DSP's CCS 4.2 project with the same syntax...
 SECTIONS {
   .text:_c_int00 > 0x11800000
...for the DSP core since I am running that app in internal memory.  I also added the file name of my .cmd file to the "Linker Command File:" field of the CCS Build General tab of the Properties for that project.
The linker map file shows the correct placement for the _c_int00 code...
               TMS320C6x Linker PC v7.0.5
>> Linked Tue Mar 13 16:23:53 2012
OUTPUT FILE NAME:   <FilterProcessor.out>
ENTRY POINT SYMBOL: "_c_int00"  address: 11800000
MEMORY CONFIGURATION
         name            origin    length      used     unused   attr    fill
  IROM                  11700000   00100000  00000000  00100000  R  X
  IRAM                  11800000   00040000  00018075  00027f8b  RW X
  L3_CBA_RAM            80000000   00020000  00000000  00020000  RW X
  DDR                   c3000000   01000000  00000000  01000000  RW X
SECTION ALLOCATION MAP
output                                  attributes/
section   page    origin      length       input sections
.pinit     0    11800000    00000000     UNINITIALIZED
.data      0    11800000    00000000     UNINITIALIZED
xdc.meta   0    11800000    000000d7     COPY SECTION
                  11800000    000000d7     FilterProcessor.p674.obj (xdc.meta)
.text:_c_int00
*          0    11800000    00000060
                  11800000    00000060     FilterProcessor.p674.obj (.text:_c_int00)
.text      0    11800060    0000fc40
But doing the same for the ARM core with a similar memory map as the Logic PD EVM (we have more memory on our product, but it starts at the same location in DDR -- 0x C3000000) -- my .cmd file in this project is...
 SECTIONS {
   .text:_c_int00 > 0xc3000000
...but the map file shows the following placement for the _c_int00 code on the ARM...
                  TMS470 Linker PC v4.6.6
>> Linked Tue Mar 13 16:57:04 2012
OUTPUT FILE NAME:   <CommunicationsProcessor.out>
ENTRY POINT SYMBOL: "_c_int00"  address: c320a2f8
  DDR                   c3000000   00300000  0021a2bd  000e5d43  RW X
  BUFFER_DATA           c3300000   00d00000  00000000  00d00000  RW
  IRAM                  ffff0000   00002000  00000368  00001c98  RW X
SEGMENT ALLOCATION MAP
run origin  load origin   length   init length attrs members
c3000000    c3000000    0017b160   00000000    rw-
  c3000000    c3000000    0017b160   00000000    rw- .bss
c317b160    c317b160    00000020   00000020    r-x
  c317b160    c317b160    00000020   00000020    r-x .text.1
c317b180    c317b180    0005fcdc   0005fcdc    rw-
  c317b180    c317b180    0005fcdc   0005fcdc    rw- .far
c31dae5c    c31dae5c    00034ca8   00034ca8    r-x
  c31dae5c    c31dae5c    00034344   00034344    r-x .text.2
  c320f1a0    c320f1a0    00000964   00000964    r-- .const.1
c320fb04    c320fb04    00006cfc   000004fc    rw-
  c320fb04    c320fb04    000004fc   000004fc    rw- .data.1
  c3210000    c3210000    00004000   00000000    rw- ti.sysbios.family.arm.arm9.mmuTableSection
  c3214000    c3214000    00002800   00000000    rw- .taskStackSection
c3216800    c3216800    00001299   00001299    r--
  c3216800    c3216800    00001299   00001299    r-- .const.2
c3217a9c    c3217a9c    00001c8c   00000c8c    rw-
  c3217a9c    c3217a9c    00000c8c   00000c8c    rw- .data.2
  c3218728    c3218728    00001000   00000000    rw- .stack
c3219728    c3219728    00000200   00000200    rw-
  c3219728    c3219728    00000200   00000200    rw- .args
c3219928    c3219928    00000998   00000998    r--
  c3219928    c3219928    00000998   00000998    r-- .cinit
ffff0000    ffff0000    00000368   00000368    r-x
  ffff0000    ffff0000    00000040   00000040    r-- .vecs
  ffff0040    ffff0040    00000328   00000328    r-x .vectorTable
output                                  attributes/
.init_array
*          0    c3000000    00000000     UNINITIALIZED
.bss       0    c3000000    0017b160     UNINITIALIZED
                  c3000000    000b0000     firmwareUtils.obj (.bss:fileImage)
                  c30b0000    00080000     commProcessor.pe9.obj (.bss:ti_sysbios_heaps_HeapMem_Instance_State_0_buf__A)
                  c3130000    000445c0     memoryUtils.obj (.bss:memTrace)
                  c31745c0    00001f40     dataSort.obj (.bss:triggers)
                  c3176500    00000b00     ti.drv.omapl138.ae9 : ethdriver.oe9 (.bss:rcv_pkt)
                  c3177000    00000b00                         : ethdriver.oe9 (.bss:send_pkt)
                  c3177b00    00000800     tcpFalcon.obj (.bss:cmdBuffer)
                  c3178300    00000800     tcpFalcon.obj (.bss:rspBuffer)
                  c3178b00    00000800     commProcessor.pe9.obj (.bss:xdc_runtime_LoggerBuf_Instance_State_0_entryArr__A)
                  c3179300    0000047c     ti.drv.omapl138.ae9 : csl_emac.oe9 (.bss:localDev)
                  c317977c    00000400     commProcessor.pe9.obj (.bss:ti_sysbios_family_arm_da830_Hwi_Module_State_0_fiqStack__A)
                  c3179b7c    00000400     commProcessor.pe9.obj (.bss:xdc_runtime_SysMin_Module_State_0_outbuf__A)
                  c3179f7c    000002d0     nettool.lib : daemon.oe9 (.bss:drec)
                  c317a24c    00000120     rtsv5_A_le_eabi.lib : trgmsg.obj (.bss:__CIOBUF_)
                  c317a36c    00000100     stack.lib : igmp.oe9 (.bss:igmp)
                  c317a46c    00000100     commProcessor.pe9.obj (.bss:ti_sysbios_family_arm_da830_Hwi_Module_State_0_irqStack__A)
                  c317a56c    00000004     cmdProc.obj (.bss)
                  c317a570    00000100     dataSort.obj (.bss:triggerGroup)
                  c317a670    000000c8     rtsv5_A_le_eabi.lib : trgdrv.obj (.bss:result$1)
                  c317a738    000000b8     stack.lib : tcp6in.oe9 (.bss:tcp6_stats)
                  c317a7f0    000000b8               : tcp.oe9 (.bss:tcps)
                  c317a8a8    000000b4     netctrl.lib : netsrv.oe9 (.bss:ipcfgcopy)
                  c317a95c    000000a0     rtsv5_A_le_eabi.lib : defs.obj (.bss:_tmpnams)
                  c317a9fc    000000a0     miniPrintf.lib : miniPrintf.oe9 (.bss:tmpstr$1)
                  c317aa9c    00000080     commProcessor.pe9.obj (.bss:ti_sysbios_family_arm_exc_Exception_Module_State_0_excStack__A)
                  c317ab1c    00000070     os.lib : mem_bios6.oe9 (.bss)
                  c317ab8c    00000070     stack.lib : ipv6.oe9 (.bss)
                  c317abfc    00000068               : ip.oe9 (.bss:ips)
                  c317ac64    00000064               : nimu.oe9 (.bss:nimu_mcb)
                  c317acc8    00000060     nettool.lib : daemon.oe9 (.bss:pollitem)
                  c317ad28    00000058     stack.lib : ipv6.oe9 (.bss:ipv6mcb)
                  c317ad80    0000004c               : icmp.oe9 (.bss:_ICMPIn)
                  c317adcc    0000004c               : icmp.oe9 (.bss:_ICMPOut)
                  c317ae18    00000044     firmwareUtils.obj (.bss:spiFlashInfo)
                  c317ae5c    00000040     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.bss:StatusRegister$2)
                  c317ae9c    00000040     cmdProc.obj (.bss:moduleCmds)
                  c317aedc    00000030     commProcessor.pe9.obj (.bss)
                  c317af0c    00000028     stack.lib : vlan.oe9 (.bss:vlan_mcb)
                  c317af34    00000024     netctrl.lib : netsrv.oe9 (.bss:oscfgcopy)
                  c317af58    00000024     stack.lib : igmp.oe9 (.bss)
                  c317af7c    00000024               : udp6.oe9 (.bss:udp6_stats)
                  c317afa0    00000024               : udp.oe9 (.bss:udps)
                  c317afc4    00000020     conditioner.obj (.bss)
                  c317afe4    00000020     netHooks.obj (.bss)
                  c317b004    0000001c     ti.drv.omapl138.ae9 : ethdriver.oe9 (.bss)
                  c317b020    00000019     firmwareUtils.obj (.bss)
                  c317b039    00000003     --HOLE--
                  c317b03c    00000018     hal_timer_bios.lib : lltimer_bios6.oe9 (.bss)
                  c317b054    00000018     netctrl.lib : netctrl.oe9 (.bss)
                  c317b06c    00000018     stack.lib : icmpv6.oe9 (.bss)
                  c317b084    00000018     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.bss)
                  c317b09c    00000014     dataSort.obj (.bss)
                  c317b0b0    00000014     stack.lib : rtc.oe9 (.bss)
                  c317b0c4    00000010               : raw.oe9 (.bss)
                  c317b0d4    00000010               : raw6.oe9 (.bss)
                  c317b0e4    00000010               : raweth.oe9 (.bss)
                  c317b0f4    0000000c     os.lib : pbm.oe9 (.bss)
                  c317b100    0000000c     stack.lib : tcp.oe9 (.bss)
                  c317b10c    0000000c               : udp.oe9 (.bss)
                  c317b118    00000008     falconMain.obj (.bss)
                  c317b120    00000008     nettool.lib : daemon.oe9 (.bss)
                  c317b128    00000008     rtsv5_A_le_eabi.lib : trgdrv.obj (.bss)
                  c317b130    00000008     spiFlash.obj (.bss)
                  c317b138    00000008     stack.lib : ip.oe9 (.bss)
                  c317b140    00000008               : nimupppoe.oe9 (.bss)
                  c317b148    00000004     nettool.lib : ipaddr.oe9 (.bss)
                  c317b14c    00000004     rtsv5_A_le_eabi.lib : strtok.obj (.bss)
                  c317b150    00000004     stack.lib : ipv6_frag.oe9 (.bss)
                  c317b154    00000004               : lli6.oe9 (.bss)
                  c317b158    00000004               : rawethsock_pcb.oe9 (.bss)
                  c317b15c    00000004               : rtable.oe9 (.bss)
xdc.meta   0    c3000000    000000da     COPY SECTION
                  c3000000    000000da     commProcessor.pe9.obj (xdc.meta)
.neardata
*          0    c317b160    00000000     UNINITIALIZED
.rodata    0    c317b160    00000000     UNINITIALIZED
.text.1    0    c317b160    00000020
                  c317b160    00000020     stack.lib : bind.oe9 (.text:BindIPHost2IF)
.far       0    c317b180    0005fcdc
                  c317b180    00052b00     os.lib : pbm.oe9 (.far:NDK_PACKETMEM) [fill = 0]
                  c31cdc80    0000c1c0            : mem_bios6.oe9 (.far:NDK_MMBUFFER) [fill = 0]
                  c31d9e40    00000a00     miniPrintf.lib : miniPrintf.oe9 (.far:NDK_OBJMEM) [fill = 0]
                  c31da840    00000600     os.lib : ossys.oe9 (.far:NDK_OBJMEM) [fill = 0]
                  c31dae40    0000001c            : mem_bios6.oe9 (.far:NDK_MMBUFFER1)
.text.2    0    c31dae5c    00034344
                  c31dae5c    00001288     stack.lib : tcp6in.oe9 (.text:TCP6Input)
                  c31dc0e4    000011dc               : tcpin.oe9 (.text:TcpInput)
                  c31dd2c0    00001030     conditioner.obj (.text)
                  c31de2f0    00000d18     stack.lib : tcpout.oe9 (.text:TcpOutput)
                  c31df008    00000cdc               : tcp6out.oe9 (.text:TCP6Output)
                  c31dfce4    00000c08     dataSort.obj (.text)
                  c31e08ec    00000b4c     stack.lib : md5.oe9 (.text:MD5Transform)
                  c31e1438    000008d0     firmwareUtils.obj (.text)
                  c31e1d08    00000804     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Mmu_initTableBuf__I)
                  c31e250c    000007b4     spiFlash.obj (.text)
                  c31e2cc0    0000071c     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:EMAC_open)
                  c31e33dc    0000063c     stack.lib : lcp.oe9 (.text:lcpInput)
                  c31e3a18    00000630               : ipout.oe9 (.text:IPTxPacket)
                  c31e4048    00000600               : ipin.oe9 (.text:IPRxPacket)
                  c31e4648    000005c8     rtsv5_A_le_eabi.lib : lowlev.obj (.text)
                  c31e4c10    00000580     stack.lib : icmpv6_ndisc.oe9 (.text:ICMPv6RecvRA)
                  c31e5190    00000544     cmdProc.obj (.text)
                  c31e56d4    00000533     commProcessor.pe9.obj (.text:xdc_runtime_System_doPrint__I)
                  c31e5c07    00000001     --HOLE-- [fill = 0]
                  c31e5c08    000004f8     rtsv5_A_le_eabi.lib : trgdrv.obj (.text)
                  c31e6100    000004d8     memoryUtils.obj (.text)
                  c31e65d8    000004c8     stack.lib : ipcp.oe9 (.text:ipcpInput)
                  c31e6aa0    000004c4     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.text:MDIO_timerTick)
                  c31e6f64    0000047c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_exc_Exception_excHandler__I)
                  c31e73e0    00000474     stack.lib : bind6.oe9 (.text:Bind6New)
                  c31e7854    00000450               : fileuser.oe9 (.text:fdPoll)
                  c31e7ca4    0000042c               : route6.oe9 (.text:Rt6Create)
                  c31e80d0    0000040c               : sock6.oe9 (.text:Sock6Connect)
                  c31e84dc    000003ec               : sock.oe9 (.text:SockSet)
                  c31e88c8    000003e0     nettool.lib : httpclie.oe9 (.text:httpClientProcess)
                  c31e8ca8    000003ac     stack.lib : ipfrag.oe9 (.text:IPReasm)
                  c31e9054    00000380               : nimupppoe.oe9 (.text:pppoeInputS)
                  c31e93d4    00000360               : icmpin.oe9 (.text:ICMPInput)
                  c31e9734    00000360               : lli6.oe9 (.text:LLI6TimerCheck)
                  c31e9a94    00000360     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_update__E)
                  c31e9df4    00000358     stack.lib : udp.oe9 (.text:UdpInput)
                  c31ea14c    0000032c               : nimuppp.oe9 (.text:pppEvent)
                  c31ea478    00000314               : sock.oe9 (.text:SockRecv)
                  c31ea78c    0000030c               : icmpv6_ndisc.oe9 (.text:ICMPv6RecvNS)
                  c31eaa98    0000030c               : sock6.oe9 (.text:Sock6Recv)
                  c31eada4    00000300     rtsv5_A_le_eabi.lib : fopen.obj (.text)
                  c31eb0a4    000002f8     nettool.lib : telnetd.oe9 (.text:telnet_netdata)
                  c31eb39c    000002f0     stack.lib : icmpv6_ndisc.oe9 (.text:ICMPv6RecvRedirect)
                  c31eb68c    000002f0               : nimupppoe.oe9 (.text:pppoeInputC)
                  c31eb97c    000002ec     rtsv5_A_le_eabi.lib : ll_div32.obj (.text)
                  c31ebc68    000002e0     os.lib : mem_bios6.oe9 (.text:_mmCheck)
                  c31ebf48    000002dc     stack.lib : ipv6.oe9 (.text:IPv6IPAddressToString)
                  c31ec224    000002dc     tcpFalcon.obj (.text)
                  c31ec500    000002d4     stack.lib : ipv6_frag.oe9 (.text:IPv6TxFragPacket)
                  c31ec7d4    000002c4     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwPktOpen)
                  c31eca98    000002b4     stack.lib : sock6.oe9 (.text:Sock6Set)
                  c31ecd4c    000002b4     nettool.lib : daemon.oe9 (.text:daemon)
                  c31ed000    000002b0     stack.lib : ipv6out.oe9 (.text:IPv6TxPacket)
                  c31ed2b0    000002a4               : auth.oe9 (.text:chapInput)
                  c31ed554    000002a4               : fileuser.oe9 (.text:fdSelect)
                  c31ed7f8    0000029c               : lliin.oe9 (.text:LLIRxPacket)
                  c31eda94    00000294               : nimuppp.oe9 (.text:pppNew)
                  c31edd28    00000290               : igmp.oe9 (.text:IGMPInput)
                  c31edfb8    00000280               : sock6pcb.oe9 (.text:Sock6PcbBind)
                  c31ee238    00000278     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.text:MDIO_initContinue)
                  c31ee4b0    00000274     stack.lib : lliout.oe9 (.text:LLITxIpPacket)
                  c31ee724    00000268     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_Object__create__S)
                  c31ee98c    00000264     miniPrintf.lib : miniPrintf.oe9 (.text:_int2str)
                  c31eebf0    00000260     stack.lib : icmpv6in.oe9 (.text:ICMPv6RxPacket)
                  c31eee50    00000260               : sock.oe9 (.text:SockNew)
                  c31ef0b0    0000025c               : udp6.oe9 (.text:Udp6Input)
                  c31ef30c    00000254     miniPrintf.lib : miniPrintf.oe9 (.text:_parsearg)
                  c31ef560    00000250     os.lib : mem_bios6.oe9 (.text:mmAlloc)
                  c31ef7b0    0000023c     stack.lib : nimupppoe.oe9 (.text:pppoeSI)
                  c31ef9ec    0000023c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_Object__create__S)
                  c31efc28    0000023a     stack.lib : sb.oe9 (.text:SBRead)
                  c31efe62    00000002     --HOLE-- [fill = 0]
                  c31efe64    00000238               : sock.oe9 (.text:SockConnect)
                  c31f009c    00000231               : icmpv6out.oe9 (.text:ICMPv6SendParameterProblem)
                  c31f02cd    00000003     --HOLE-- [fill = 0]
                  c31f02d0    0000022c               : tcp6.oe9 (.text:TCP6TimeoutCheck)
                  c31f04fc    0000022c               : tcp.oe9 (.text:TcpTimeoutCheck)
                  c31f0728    00000228               : route6.oe9 (.text:Rt6Find)
                  c31f0950    00000224     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:EMAC_close)
                  c31f0b74    00000224     nettool.lib : httpsend.oe9 (.text:SetContentType)
                  c31f0d98    00000220     stack.lib : nimupppoe.oe9 (.text:SendServerMsg)
                  c31f0fb8    00000220     emacHooks.obj (.text)
                  c31f11d8    00000220     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_Instance_finalize__F)
                  c31f13f8    0000021c     stack.lib : bind6.oe9 (.text:Bind6RunDAD)
                  c31f1614    00000218               : sock6pcb.oe9 (.text:Sock6PcbFind)
                  c31f182c    00000207               : icmpv6out.oe9 (.text:ICMPv6SendDstUnreachable)
                  c31f1a33    00000001     --HOLE-- [fill = 0]
                  c31f1a34    00000204     nettool.lib : config.oe9 (.text:CfgAddEntry)
                  c31f1c38    00000204     stack.lib : rtc.oe9 (.text:RTCReport)
                  c31f1e3c    00000204     os.lib : efs.oe9 (.text:efs_filecheck)
                  c31f2040    00000200     stack.lib : sock6.oe9 (.text:Sock6New)
                  c31f2240    000001fd               : icmpv6out.oe9 (.text:ICMPv6SendTimeExceeded)
                  c31f243d    00000003     --HOLE-- [fill = 0]
                  c31f2440    000001fc               : route6.oe9 (.text:Rt6Free)
                  c31f263c    000001fc               : sock.oe9 (.text:SockSend)
                  c31f2838    000001f9               : icmpv6_ndisc.oe9 (.text:ICMPv6RecvNA)
                  c31f2a31    00000003     --HOLE-- [fill = 0]
                  c31f2a34    000001f8               : ipv6_frag.oe9 (.text:IPv6FragReasm)
                  c31f2c2c    000001f8               : sock6.oe9 (.text:Sock6Send)
                  c31f2e24    000001f4               : nimupppoe.oe9 (.text:SendClientMsg)
                  c31f3018    000001e8     commProcessor.pe9.obj (.text:deviceConfig$20)
                  c31f3200    000001e4     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:EmacInit)
                  c31f33e4    000001dc     stack.lib : auth.oe9 (.text:papInput)
                  c31f35c0    000001d4               : udp6.oe9 (.text:Udp6Output)
                  c31f3794    000001d0               : sock6pcb.oe9 (.text:Sock6PcbResolve)
                  c31f3964    000001d0     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_pend__E)
                  c31f3b34    000001cf     commProcessor.pe9.obj (.text:xdc_runtime_System_printfExtend__I)
                  c31f3d03    00000001     --HOLE-- [fill = 0]
                  c31f3d04    000001c8     nettool.lib : daemon.oe9 (.text:DaemonNew)
                  c31f3ecc    000001c6     stack.lib : sb6.oe9 (.text:SB6Read)
                  c31f4092    00000002     --HOLE-- [fill = 0]
                  c31f4094    000001c4               : icmp.oe9 (.text:ICMPGenPacket)
                  c31f4258    000001c4               : nimu.oe9 (.text:NIMUIoctl)
                  c31f441c    000001c0               : bind.oe9 (.text:BindNew)
                  c31f45dc    000001c0               : rtable.oe9 (.text:RtFind)
                  c31f479c    000001c0     nettool.lib : inetaddr.oe9 (.text:inet_aton)
                  c31f495c    000001c0     stack.lib : lcp.oe9 (.text:lcpSendCfg)
                  c31f4b1c    000001c0     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_free__E)
                  c31f4cdc    000001bc     stack.lib : nimuppp.oe9 (.text:pppInput)
                  c31f4e98    000001b4               : icmpv6_ndisc.oe9 (.text:ICMPv6SendNS)
                  c31f504c    000001b4     netctrl.lib : netctrl.oe9 (.text:NC_NetStart)
                  c31f5200    000001b0     stack.lib : pipe.oe9 (.text:PipeRecv)
                  c31f53b0    000001b0               : route.oe9 (.text:RtCreate)
                  c31f5560    000001b0               : udp.oe9 (.text:UdpOutput)
                  c31f5710    000001b0     nettool.lib : telnetd.oe9 (.text:telnet_engine)
                  c31f58c0    000001a8                 : dhcpmain.oe9 (.text:DHCPOpen)
                  c31f5a68    000001a4     stack.lib : sock6int.oe9 (.text:Sock6Notify)
                  c31f5c0c    000001a4               : sockint.oe9 (.text:SockNotify)
                  c31f5db0    000001a0               : lli6.oe9 (.text:LLI6TxIPPacket)
                  c31f5f50    000001a0               : sockpcb.oe9 (.text:SockPcbResolve)
                  c31f60f0    0000019c     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:Emacioctl)
                  c31f628c    0000019c     stack.lib : icmpv6in.oe9 (.text:ICMPv6RecvEchoRequest)
                  c31f6428    0000019c     commProcessor.pe9.obj (.text:xdc_runtime_Core_createObject__I)
                  c31f65c4    00000198     stack.lib : lli6.oe9 (.text:LLI6NeighUnreachStateMachine)
                  c31f675c    00000198               : tcp6out.oe9 (.text:TCP6GenPacket)
                  c31f68f4    00000194               : ipv6_frag.oe9 (.text:IPv6FragQEnqueueFrag)
                  c31f6a88    00000194               : raw.oe9 (.text:RawInput)
                  c31f6c1c    00000194     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_alloc__E)
                  c31f6db0    00000190     nettool.lib : httppars.oe9 (.text:httpParseRecv)
                  c31f6f40    00000190     rtsv5_A_le_eabi.lib : fputs.obj (.text)
                  c31f70d0    0000018c     stack.lib : igmp.oe9 (.text:IGMPSendReply)
                  c31f725c    00000188               : sock6pcb.oe9 (.text:Sock6PcbFindRaw)
                  c31f73e4    00000188               : ipcp.oe9 (.text:ipcpSendCfg)
                  c31f756c    00000184               : route6.oe9 (.text:Rt6Modify)
                  c31f76f0    00000180               : icmpv6_ndisc.oe9 (.text:ICMPv6SendNA)
                  c31f7870    00000180     rtsv5_A_le_eabi.lib : memcpy32.obj (.text)
                  c31f79f0    0000017c     stack.lib : nimu.oe9 (.text:NIMUReceivePacket)
                  c31f7b6c    00000178               : ipv6in.oe9 (.text:IPv6RxPacket)
                  c31f7ce4    00000174               : sb6.oe9 (.text:SB6Write)
                  c31f7e58    00000174               : sb.oe9 (.text:SBWrite)
                  c31f7fcc    00000170               : node.oe9 (.text:NodeTreeFree)
                  c31f813c    0000016c     nettool.lib : dhcpsm.oe9 (.text:dhcpState)
                  c31f82a8    0000016c     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_start__E)
                  c31f8414    00000168     stack.lib : sock.oe9 (.text:SockClose)
                  c31f857c    00000168               : tcpout.oe9 (.text:TcpGenPacket)
                  c31f86e4    00000168     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:emacDequeueRx)
                  c31f884c    00000168     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_postInit__I)
                  c31f89b4    00000168     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_setPri__E)
                  c31f8b1c    00000164     stack.lib : ipv6_exthdrs.oe9 (.text:IPv6ParseHopOptions)
                  c31f8c80    00000160     nettool.lib : dhcpsock.oe9 (.text:dhcpSocketOpen)
                  c31f8de0    0000015c     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:EMAC_sendPacket)
                  c31f8f3c    0000015c     stack.lib : raw6.oe9 (.text:Raw6Input)
                  c31f9098    0000015c     rtsv5_A_le_eabi.lib : dtor_list.obj (.text)
                  c31f91f4    0000015c     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_setPeriodMicroSecs__E)
                  c31f9350    00000158     os.lib : intmgmt_bios6.oe9 (.text:Interrupt_add)
                  c31f94a8    00000158     stack.lib : sockpcb.oe9 (.text:SockPcbBind)
                  c31f9600    00000158     nettool.lib : dhcpsm.oe9 (.text:dhcpIPAdd)
                  c31f9758    00000154     stack.lib : lli6.oe9 (.text:LLI6New)
                  c31f98ac    00000154               : node.oe9 (.text:NodeAdd)
                  c31f9a00    00000154               : rawethsock.oe9 (.text:RawEthSockSet)
                  c31f9b54    00000150               : igmp.oe9 (.text:IGMPJoinHostGroup)
                  c31f9ca4    00000150               : rawethsock.oe9 (.text:RawEthSockNew)
                  c31f9df4    00000150               : tcp6prot.oe9 (.text:TCP6PrSetOption)
                  c31f9f44    00000150               : tcpprot.oe9 (.text:TcpPrSetOption)
                  c31fa094    0000014c               : bind6.oe9 (.text:Bind6GetGlobalAddress)
                  c31fa1e0    0000014c               : ipv6.oe9 (.text:IPv6DisplayIPAddress)
                  c31fa32c    0000014c               : lliout.oe9 (.text:LLIGenArpPacket)
                  c31fa478    0000014c     netctrl.lib : netctrl.oe9 (.text:NetScheduler)
                  c31fa5c4    00000148     stack.lib : raw6.oe9 (.text:Raw6Output)
                  c31fa70c    00000148     nettool.lib : dhcppkt.oe9 (.text:dhcpPacketProcess)
                  c31fa854    00000144     stack.lib : ipv6_frag.oe9 (.text:IPv6ParseFragHdr)
                  c31fa998    00000144     os.lib : task_bios6.oe9 (.text:llEnter)
                  c31faadc    00000144     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_Module_startup__E)
                  c31fac20    00000140     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:EMAC_setReceiveFilter)
                  c31fad60    00000140     stack.lib : ipv6_exthdrs.oe9 (.text:IPv6ParseExtnHeaders)
                  c31faea0    00000140               : socket.oe9 (.text:accept)
                  c31fafe0    00000140     nettool.lib : dhcppkt.oe9 (.text:dhcpVerifyMessage)
                  c31fb120    0000013c     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwPktTxNext)
                  c31fb25c    0000013c     netctrl.lib : netsrv.oe9 (.text:ServiceSpawn)
                  c31fb398    0000013c     stack.lib : auth.oe9 (.text:chapSendMsg)
                  c31fb4d4    0000013c     nettool.lib : httpclie.oe9 (.text:httpGetAuthParams)
                  c31fb610    0000013c     netHooks.obj (.text)
                  c31fb74c    00000138     stack.lib : bind6.oe9 (.text:Bind6Free)
                  c31fb884    00000138               : tcptime.oe9 (.text:TcpTimeoutRexmt)
                  c31fb9bc    00000134               : sock6.oe9 (.text:Sock6Close)
                  c31fbaf0    00000134               : nimupppoe.oe9 (.text:pppoeCtrlMsg)
                  c31fbc24    00000130               : icmp.oe9 (.text:ICMPSendRtAdv)
                  c31fbd54    00000130     nettool.lib : httpsend.oe9 (.text:httpAuthenticationReq)
                  c31fbe84    0000012c     netctrl.lib : netsrv.oe9 (.text:SPIpNet)
                  c31fbfb0    0000012a     stack.lib : mld.oe9 (.text:MLDJoinGroup)
                  c31fc0da    00000002     --HOLE-- [fill = 0]
                  c31fc0dc    00000128               : tcp6time.oe9 (.text:TCP6TimeoutRexmt)
                  c31fc204    00000128               : lli.oe9 (.text:_LLITimeoutCheck)
                  c31fc32c    00000128     dualPort.obj (.text)
                  c31fc454    00000124     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwPktSetRx)
                  c31fc578    00000124     stack.lib : sockint.oe9 (.text:SockCreatePacket)
                  c31fc69c    00000124               : tcp6time.oe9 (.text:TCP6TimeoutKeep)
                  c31fc7c0    00000124     crc8.obj (.text)
                  c31fc8e4    00000124     stack.lib : socket.oe9 (.text:sendto)
                  c31fca08    00000124     commProcessor.pe9.obj (.text:xdc_runtime_Startup_startMods__I)
                  c31fcb2c    00000120     falconMain.obj (.text)
                  c31fcc4c    00000120     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_write8__F)
                  c31fcd6c    0000011c     nettool.lib : config.oe9 (.text:CfgRemoveEntry)
                  c31fce88    0000011c     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:EMAC_RxServiceCheck)
                  c31fcfa4    0000011c     stack.lib : sock6pcb.oe9 (.text:Sock6PcbConnect)
                  c31fd0c0    0000011c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_sleep__E)
                  c31fd1dc    0000011a     commProcessor.pe9.obj (.text:ti_ndk_config_ip_init)
                  c31fd2f6    00000002     --HOLE-- [fill = 0]
                  c31fd2f8    00000118     stack.lib : bind6.oe9 (.text:Bind6DADCheck)
                  c31fd410    00000118               : exec.oe9 (.text:ExecOpen)
                  c31fd528    00000118               : icmpin.oe9 (.text:ICMPRevSrcRoute)
                  c31fd640    00000118     netctrl.lib : netsrv.oe9 (.text:ServiceScan)
                  c31fd758    00000118     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:_HwPktPoll)
                  c31fd870    00000118     nettool.lib : dhcpbild.oe9 (.text:dhcpBuildHeader)
                  c31fd988    00000118     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:emacEnqueueTx)
                  c31fdaa0    00000118     rtsv5_A_le_eabi.lib : _io_perm.obj (.text)
                  c31fdbb8    00000118                         : i_div32.obj (.text)
                  c31fdcd0    00000118     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_Object__create__S)
                  c31fdde8    00000118     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_checkStacks__E)
                  c31fdf00    00000114     stack.lib : ipv6_exthdrs.oe9 (.text:IPv6ParseRoutingHdr)
                  c31fe014    00000114               : sockpcb.oe9 (.text:SockPcbFind)
                  c31fe128    00000114     rtsv5_A_le_eabi.lib : setvbuf.obj (.text)
                  c31fe23c    00000110                         : fflush.obj (.text)
                  c31fe34c    0000010c     stack.lib : rtable.oe9 (.text:RtTimeoutCheck)
                  c31fe458    0000010c               : sock6int.oe9 (.text:Sock6CreatePacket)
                  c31fe564    0000010c     nettool.lib : dhcpsm.oe9 (.text:StateBound)
                  c31fe670    00000104     stack.lib : route6.oe9 (.text:Route6LifetimeMgmt)
                  c31fe774    00000104               : tcptime.oe9 (.text:TcpTimeoutKeep)
                  c31fe878    00000100     nettool.lib : config.oe9 (.text:CfgExecute)
                  c31fe978    00000100     stack.lib : fileuser.oe9 (.text:fdClose)
                  c31fea78    00000100     commProcessor.pe9.obj (.text:xdc_runtime_Error_raiseX__F)
                  c31feb78    000000fc     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:EMAC_TxServiceCheck)
                  c31fec74    000000f8     stack.lib : ip.oe9 (.text:IPGetRoute)
                  c31fed6c    000000f8     miniPrintf.lib : miniPrintf.oe9 (.text:_str2str)
                  c31fee64    000000f8     commProcessor.pe9.obj (.text:ti_ndk_config_Global_stackThread)
                  c31fef5c    000000f8     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_schedule__I)
                  c31ff054    000000f4     stack.lib : ipv6.oe9 (.text:IPv6Init)
                  c31ff148    000000f4               : socket.oe9 (.text:getpeername)
                  c31ff23c    000000f4               : socket.oe9 (.text:recv)
                  c31ff330    000000f4     rtsv5_A_le_eabi.lib : u_div32.obj (.text)
                  c31ff424    000000f4     stack.lib : socket.oe9 (.text:send)
                  c31ff518    000000f0               : nimuppp.oe9 (.text:PPPStop)
                  c31ff608    000000f0     miniPrintf.lib : miniPrintf.oe9 (.text:_printf)
                  c31ff6f8    000000f0     stack.lib : socket.oe9 (.text:socket)
                  c31ff7e8    000000f0     commProcessor.pe9.obj (.text:xdc_runtime_Text_putSite__F)
                  c31ff8d8    000000ec     os.lib : ossys.oe9 (.text:DbgPrintf)
                  c31ff9c4    000000ec     auto_init.ae9 : auto_init.oe9 (.text)
                  c31ffab0    000000ec     commProcessor.pe9.obj (.text:initDevice$20)
                  c31ffb9c    000000e8     stack.lib : igmp.oe9 (.text:IGMPMsg)
                  c31ffc84    000000e8     netctrl.lib : netsrv.oe9 (.text:SPRoute)
                  c31ffd6c    000000e8     stack.lib : socket.oe9 (.text:setsockopt)
                  c31ffe54    000000e8     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_Object__create__S)
                  c31fff3c    000000e4     stack.lib : sock6.oe9 (.text:Sock6Check)
                  c3200020    000000e4               : sock.oe9 (.text:SockCheck)
                  c3200104    000000e4     nettool.lib : dhcpbild.oe9 (.text:dhcpBuildRequest)
                  c32001e8    000000e2                 : httpclie.oe9 (.text:httpExtractTag)
                  c32002ca    00000002     --HOLE-- [fill = 0]
                  c32002cc    000000e0                 : config.oe9 (.text:CfgGetNextEntry)
                  c32003ac    000000e0     stack.lib : icmpv6in.oe9 (.text:ICMPv6SocketErrorInterface)
                  c320048c    000000e0               : ipv6_frag.oe9 (.text:IPv6FindFragQ)
                  c320056c    000000e0     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:Interrupt_init)
                  c320064c    000000e0     nettool.lib : dhcpsm.oe9 (.text:StateRenewRebind)
                  c320072c    000000e0     os.lib : task_bios6.oe9 (.text:TaskGetEnv)
                  c320080c    000000e0     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:emacEnqueueRx)
                  c32008ec    000000e0     nettool.lib : telnetd.oe9 (.text:telnet_termdata)
                  c32009cc    000000dc     stack.lib : bind6.oe9 (.text:Bind6Msg)
                  c3200aa8    000000dc     netctrl.lib : netctrl.oe9 (.text:NC_SystemOpen)
                  c3200b84    000000dc     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:RxPacket)
                  c3200c60    000000dc     nettool.lib : dhcpsm.oe9 (.text:StateRequesting)
                  c3200d3c    000000dc     stack.lib : auth.oe9 (.text:papSendCfg)
                  c3200e18    000000dc     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_Object__create__S)
                  c3200ef4    000000d8     stack.lib : ip.oe9 (.text:IPMsg)
                  c3200fcc    000000d8               : sockpcb.oe9 (.text:SockPcbCtlError)
                  c32010a4    000000d8               : auth.oe9 (.text:authInit)
                  c320117c    000000d4               : nimu.oe9 (.text:NIMURegister)
                  c3201250    000000d4     os.lib : pbm.oe9 (.text:PBM_free)
                  c3201324    000000d4            : task_bios6.oe9 (.text:TaskSetEnv)
                  c32013f8    000000d4     nettool.lib : httpsend.oe9 (.text:httpSendStatusLine)
                  c32014cc    000000d0     stack.lib : igmp.oe9 (.text:IGMPDoMCast)
                  c320159c    000000d0     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:emacDequeueTx)
                  c320166c    000000d0     os.lib : mem_bios6.oe9 (.text:mmInitPage)
                  c320173c    000000d0     nettool.lib : telnetd.oe9 (.text:telnetClientProcess)
                  c320180c    000000cc     os.lib : pbm.oe9 (.text:PBM_alloc)
                  c32018d8    000000cc     stack.lib : sockpcb.oe9 (.text:SockPcbConnect)
                  c32019a4    000000cc     nettool.lib : daemon.oe9 (.text:dchild)
                  c3201a70    000000cc     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_Object__create__S)
                  c3201b3c    000000c9     stack.lib : nimu.oe9 (.text:NIMUAddEthernetHeader)
                  c3201c05    00000003     --HOLE-- [fill = 0]
                  c3201c08    000000c8               : pipe.oe9 (.text:PipeSend)
                  c3201cd0    000000c8               : raw.oe9 (.text:RawOutput)
                  c3201d98    000000c8               : socket.oe9 (.text:bind)
                  c3201e60    000000c8               : lcp.oe9 (.text:lcpReject)
                  c3201f28    000000c8     os.lib : mem_bios6.oe9 (.text:mmBulkAlloc)
                  c3201ff0    000000c8     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_run__I)
                  c32020b8    000000c4     nettool.lib : config.oe9 (.text:CfgGetEntry)
                  c320217c    000000c4     stack.lib : raweth.oe9 (.text:RawEthRxPacket)
                  c3202240    000000c4               : sock6pcb.oe9 (.text:Sock6PcbResolveChain)
                  c3202304    000000c4               : vlan.oe9 (.text:VLANDeinit)
                  c32023c8    000000c4     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_Object__create__S)
                  c320248c    000000c4     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_schedule__I)
                  c3202550    000000c4     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_startup__E)
                  c3202614    000000c4     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_idleFxn__E)
                  c32026d8    000000c4     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_setFilterLevel__F)
                  c320279c    000000c0     nettool.lib : daemon.oe9 (.text:DaemonFree)
                  c320285c    000000c0     stack.lib : igmp.oe9 (.text:IGMPLeaveHostGroup)
                  c320291c    000000c0               : md5.oe9 (.text:MD5Update)
                  c32029dc    000000c0               : rtable.oe9 (.text:RtFlush)
                  c3202a9c    000000c0               : tcp6prot.oe9 (.text:TCP6PrAttach)
                  c3202b5c    000000c0               : tcpprot.oe9 (.text:TcpPrAttach)
                  c3202c1c    000000c0     nettool.lib : telnetd.oe9 (.text:TelnetOpen)
                  c3202cdc    000000c0     stack.lib : rtable.oe9 (.text:_RtNodeInsert)
                  c3202d9c    000000c0     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_dispatchIRQC__I)
                  c3202e5c    000000bf     stack.lib : sb6.oe9 (.text:SB6New)
                  c3202f1b    00000001     --HOLE-- [fill = 0]
                  c3202f1c    000000bc     os.lib : mem_bios6.oe9 (.text:mmFree)
                  c3202fd8    000000bc     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_write4__F)
                  c3203094    000000b8     stack.lib : bind6.oe9 (.text:Bind6LifetimeMgmt)
                  c320314c    000000b8     netctrl.lib : netsrv.oe9 (.text:NS_BootTask)
                  c3203204    000000b8     stack.lib : raweth.oe9 (.text:RawEthTxPacket)
                  c32032bc    000000b8     nettool.lib : dhcptags.oe9 (.text:dhcpDecodeType)
                  c3203374    000000b4     stack.lib : igmp.oe9 (.text:IGMPJoin)
                  c3203428    000000b4               : node.oe9 (.text:NodeTreeNew)
                  c32034dc    000000b4               : rtable.oe9 (.text:RtWalkNext)
                  c3203590    000000b4               : sock6.oe9 (.text:Sock6Shutdown)
                  c3203644    000000b4     nettool.lib : http.oe9 (.text:httpOpen)
                  c32036f8    000000b4                 : httpsend.oe9 (.text:httpSendErrorHTML)
                  c32037ac    000000b4     stack.lib : lcp.oe9 (.text:lcpOpen)
                  c3203860    000000b4     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_exit__E)
                  c3203914    000000b3     stack.lib : nimuppp.oe9 (.text:pppAddIP)
                  c32039c7    00000001     --HOLE-- [fill = 0]
                  c32039c8    000000b0               : ipv6_frag.oe9 (.text:IPv6FragMsg)
                  c3203a78    000000b0     netctrl.lib : netsrv.oe9 (.text:ServiceKill)
                  c3203b28    000000b0     stack.lib : sock6.oe9 (.text:Sock6Accept)
                  c3203bd8    000000b0               : sock.oe9 (.text:SockAccept)
                  c3203c88    000000b0               : sock.oe9 (.text:SockShutdown)
                  c3203d38    000000b0               : tcp6time.oe9 (.text:TCP6XmitTimer)
                  c3203de8    000000b0               : tcptime.oe9 (.text:TcpXmitTimer)
                  c3203e98    000000b0     rtsv5_A_le_eabi.lib : memset32.obj (.text)
                  c3203f48    000000b0     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_getFilterLevel__F)
                  c3203ff8    000000b0     commProcessor.pe9.obj (.text:xdc_runtime_Text_putMod__F)
                  c32040a8    000000af     stack.lib : fileuser.oe9 (.text:fdOpenSession)
                  c3204157    00000001     --HOLE-- [fill = 0]
                  c3204158    000000ad               : nimuppp.oe9 (.text:pppFree)
                  c3204205    00000003     --HOLE-- [fill = 0]
                  c3204208    000000ac     nettool.lib : config.oe9 (.text:CfgFree)
                  c32042b4    000000ac                 : config.oe9 (.text:CfgGetEntryCnt)
                  c3204360    000000ac     stack.lib : lli.oe9 (.text:LLINew)
                  c320440c    000000ac               : node.oe9 (.text:NodeFind)
                  c32044b8    000000ac               : rawethsock.oe9 (.text:RawEthSockCheck)
                  c3204564    000000ac     netctrl.lib : netsrv.oe9 (.text:SPConfig)
                  c3204610    000000ac     stack.lib : udp.oe9 (.text:UdpChecksum)
                  c32046bc    000000ac     os.lib : mem_bios6.oe9 (.text:_mmInit)
                  c3204768    000000a8     stack.lib : file.oe9 (.text:FdWaitEvent)
                  c3204810    000000a8               : igmp.oe9 (.text:IGMPTimer)
                  c32048b8    000000a8               : lli6.oe9 (.text:LLI6Find)
                  c3204960    000000a8               : lli6.oe9 (.text:LLI6Update)
                  c3204a08    000000a8               : sock6int.oe9 (.text:Sock6ValidateRoute)
                  c3204ab0    000000a8               : vlan.oe9 (.text:VLANReceivePacket)
                  c3204b58    000000a8     miniPrintf.lib : miniPrintf.oe9 (.text:printstr)
                  c3204c00    000000a8     rtsv5_A_le_eabi.lib : trgmsg.obj (.text)
                  c3204ca8    000000a8     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_enter__E)
                  c3204d50    000000a8     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_workFunc__E)
                  c3204df8    000000a4     stack.lib : node.oe9 (.text:NodeNew)
                  c3204e9c    000000a4     os.lib : task_bios6.oe9 (.text:llExit)
                  c3204f40    000000a4            : mem_bios6.oe9 (.text:mmBulkFree)
                  c3204fe4    000000a4     stack.lib : nimuppp.oe9 (.text:pppAddClient)
                  c3205088    000000a4     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_hwiBeginHook__E)
                  c320512c    000000a4     stack.lib : lliin.oe9 (.text:updateRtTable)
                  c32051d0    000000a2               : sb.oe9 (.text:SBNew)
                  c3205272    00000002     --HOLE-- [fill = 0]
                  c3205274    000000a0               : bind.oe9 (.text:BindFree)
                  c3205314    000000a0               : ipin.oe9 (.text:IPRouteIP)
                  c32053b4    000000a0               : rtc.oe9 (.text:RTCMsg)
                  c3205454    000000a0               : sockpcb.oe9 (.text:SockPcbFindRaw)
                  c32054f4    000000a0               : tcp.oe9 (.text:TcpChecksum)
                  c3205594    000000a0     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_Instance_finalize__F)
                  c3205634    000000a0     commProcessor.pe9.obj (.text:xdc_runtime_Memory_alloc__F)
                  c32056d4    0000009c     stack.lib : ipv6_frag.oe9 (.text:IPv6CreateFragQ)
                  c3205770    0000009c               : ipv6.oe9 (.text:IPv6GetSubnetMaskFromBits)
                  c320580c    0000009c               : rawethsock_pcb.oe9 (.text:RawEthSockPcbAttach)
                  c32058a8    0000009c               : route.oe9 (.text:RtRedirect)
                  c3205944    0000009c     netctrl.lib : netsrv.oe9 (.text:SPService)
                  c32059e0    0000009c     stack.lib : sock6.oe9 (.text:Sock6Listen)
                  c3205a7c    0000009c               : sock.oe9 (.text:SockListen)
                  c3205b18    0000009c     nettool.lib : dhcpsm.oe9 (.text:StateSelecting)
                  c3205bb4    0000009c     stack.lib : socket.oe9 (.text:listen)
                  c3205c50    0000009b     commProcessor.pe9.obj (.text:ti_ndk_config_Global_NetworkIPAddr$0)
                  c3205ceb    00000001     --HOLE-- [fill = 0]
                  c3205cec    00000098     nettool.lib : config.oe9 (.text:CfgSetExecuteOrder)
                  c3205d84    00000098     stack.lib : tcpprot.oe9 (.text:TcpValidateMetrics)
                  c3205e1c    00000098     hal_timer_bios.lib : lltimer_bios6.oe9 (.text:llTimerTick)
                  c3205eb4    00000098     rtsv5_A_le_eabi.lib : fclose.obj (.text)
                  c3205f4c    00000098     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_restoreHwi__E)
                  c3205fe4    00000098     commProcessor.pe9.obj (.text:xdc_runtime_System_formatNum__I)
                  c320607c    00000097     nettool.lib : httpsend.oe9 (.text:httpSendFullResponse)
                  c3206113    00000001     --HOLE-- [fill = 0]
                  c3206114    00000094     stack.lib : bind6.oe9 (.text:Bind6GetLinkLocalAddress)
                  c32061a8    00000094               : mld.oe9 (.text:MLDLeaveGroup)
                  c320623c    00000094               : nimu.oe9 (.text:NIMUIoctlSpecialCmd)
                  c32062d0    00000094               : route6.oe9 (.text:Rt6FindDefaultRouter)
                  c3206364    00000094               : route.oe9 (.text:RtRemove)
                  c32063f8    00000094               : auth.oe9 (.text:authGetPassword)
                  c320648c    00000090     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwPktClose)
                  c320651c    00000090     stack.lib : ipv6.oe9 (.text:IPv6Layer4ComputeChecksum)
                  c32065ac    00000090     os.lib : pbm.oe9 (.text:PBMQ_enq)
                  c320663c    00000090            : semaphore_bios6.oe9 (.text:SemCreate)
                  c32066cc    00000090     stack.lib : tcp6prot.oe9 (.text:TCP6PrInherit)
                  c320675c    00000090               : tcpprot.oe9 (.text:TcpPrInherit)
                  c32067ec    00000090     nettool.lib : dhcptags.oe9 (.text:dhcpBuildOptions)
                  c320687c    00000090     commProcessor.pe9.obj (.text:xdc_runtime_Core_deleteObject__I)
                  c320690c    0000008d     stack.lib : tcp6time.oe9 (.text:TCP6TimeoutSackRexmt)
                  c3206999    00000003     --HOLE-- [fill = 0]
                  c320699c    0000008d               : tcptime.oe9 (.text:TcpTimeoutSackRexmt)
                  c3206a29    00000003     --HOLE-- [fill = 0]
                  c3206a2c    0000008c               : icmpv6out.oe9 (.text:IsICMPv6ErrorPkt)
                  c3206ab8    0000008c               : nimu.oe9 (.text:NIMUShutdown)
                  c3206b44    0000008c               : lli.oe9 (.text:_LLIExpListInsert)
                  c3206bd0    0000008c               : rtable.oe9 (.text:_RtExpListInsert)
                  c3206c5c    0000008c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_post__E)
                  c3206ce8    0000008c     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_stop__E)
                  c3206d74    0000008c     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_addTask__E)
                  c3206e00    00000088     stack.lib : node.oe9 (.text:NodeDeRef)
                  c3206e88    00000088               : rawethsock.oe9 (.text:RawEthSockSend)
                  c3206f10    00000088               : tcp6prot.oe9 (.text:TCP6PrDetach)
                  c3206f98    00000088               : tcpprot.oe9 (.text:TcpPrDetach)
                  c3207020    00000088               : timer.oe9 (.text:TimerListInsert)
                  c32070a8    00000088               : auth.oe9 (.text:authStart)
                  c3207130    00000088               : file.oe9 (.text:fdint_lockfd)
                  c32071b8    00000088               : file.oe9 (.text:fdint_unlockfd)
                  c3207240    00000088     rtsv5_A_le_eabi.lib : cpy_tbl.obj (.text)
                  c32072c8    00000084     stack.lib : mld.oe9 (.text:MLDFindMulticastNode)
                  c320734c    00000084               : node.oe9 (.text:NodeWalk)
                  c32073d0    00000084               : route.oe9 (.text:RtNew)
                  c3207454    00000084               : bind6.oe9 (.text:_Bind6FindByHostInList)
                  c32074d8    00000084               : bind6.oe9 (.text:_Bind6FindByNetInList)
                  c320755c    00000084     os.lib : efs.oe9 (.text:efs_fopen)
                  c32075e0    00000084     nettool.lib : httpclie.oe9 (.text:httpGetMimeBits)
                  c3207664    00000084     rtsv5_A_le_eabi.lib : atoi.obj (.text)
                  c32076e8    00000084     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_Instance_finalize__F)
                  c320776c    00000084     commProcessor.pe9.obj (.text:xdc_runtime_Text_visitRope2__I)
                  c32077f0    00000080     stack.lib : igmp.oe9 (.text:IGMPLeave)
                  c3207870    00000080               : sock6.oe9 (.text:Sock6Disconnect)
                  c32078f0    00000080               : sock6int.oe9 (.text:Sock6SpawnAbort)
                  c3207970    00000080               : sockint.oe9 (.text:SockSpawnAbort)
                  c32079f0    00000080     nettool.lib : config.oe9 (.text:_CfgEntryScan)
                  c3207a70    00000080     os.lib : efs.oe9 (.text:efs_internal_remove)
                  c3207af0    00000080     rtsv5_A_le_eabi.lib : fseek.obj (.text)
                  c3207b70    00000080     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_swiBeginHook__E)
                  c3207bf0    0000007c     nettool.lib : config.oe9 (.text:CfgEntryDeRef)
                  c3207c6c    0000007c     stack.lib : ipfrag.oe9 (.text:IPReasmFree)
                  c3207ce8    0000007c     os.lib : pbm.oe9 (.text:PBM_copy)
                  c3207d64    0000007c            : pbm.oe9 (.text:PBM_open)
                  c3207de0    0000007c     stack.lib : tcp6prot.oe9 (.text:TCP6PrSendOOB)
                  c3207e5c    0000007c               : tcp6prot.oe9 (.text:TCP6ValidateMetrics)
                  c3207ed8    0000007c               : tcpprot.oe9 (.text:TcpPrSendOOB)
                  c3207f54    0000007c     os.lib : mem_bios6.oe9 (.text:mmCopy)
                  c3207fd0    0000007c     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_Object__create__S)
                  c320804c    0000007c     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_getStats__E)
                  c32080c8    0000007c     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_removeTask__E)
                  c3208144    00000078     stack.lib : rawethsock_pcb.oe9 (.text:RawEthSockPcbDetach)
                  c32081bc    00000078               : sock6pcb.oe9 (.text:Sock6CleanPcb)
                  c3208234    00000078               : sockint.oe9 (.text:SockValidateRoute)
                  c32082ac    00000078     os.lib : task_bios6.oe9 (.text:TaskCreate)
                  c3208324    00000078     nettool.lib : dhcpbild.oe9 (.text:dhcpBuildDecline)
                  c320839c    00000078     stack.lib : lcp.oe9 (.text:lcpInit)
                  c3208414    00000078     rtsv5_A_le_eabi.lib : exit.obj (.text)
                  c320848c    00000078     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_handlerSELF__I)
                  c3208504    00000078     ti.sysbios.family.arm.exc.ae9 : Exception_asm.oe9 (.text:ti_sysbios_family_arm_exc_Exception_excHandlerAsm__I)
                  c320857c    00000078     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_post__E)
                  c32085f4    00000078     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_unblockI__E)
                  c320866c    00000078     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_taskSwitchHook__E)
                  c32086e4    00000074     nettool.lib : config.oe9 (.text:CfgNew)
                  c3208758    00000074     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:EmacStart)
                  c32087cc    00000074     stack.lib : lli.oe9 (.text:LLIGetValidTime)
                  c3208840    00000074               : lli.oe9 (.text:LLIMsg)
                  c32088b4    00000074               : md5.oe9 (.text:MD5Final)
                  c3208928    00000074               : tcp6prot.oe9 (.text:TCP6PrDisconnect)
                  c320899c    00000074               : tcpprot.oe9 (.text:TcpPrDisconnect)
                  c3208a10    00000070               : lli6.oe9 (.text:LLI6Msg)
                  c3208a80    00000070     nettool.lib : ipaddr.oe9 (.text:NtAddNetwork)
                  c3208af0    00000070                 : ipaddr.oe9 (.text:NtIfIdx2Ip)
                  c3208b60    00000070     stack.lib : route6.oe9 (.text:Route6Msg)
                  c3208bd0    00000070               : sockpcb.oe9 (.text:SockPcbResolveChain)
                  c3208c40    00000070     hal_timer_bios.lib : lltimer_bios6.oe9 (.text:llTimerGetTime)
                  c3208cb0    00000070     os.lib : mem_bios6.oe9 (.text:mmZeroInit)
                  c3208d20    0000006c     nettool.lib : dhcpmain.oe9 (.text:DHCPClose)
                  c3208d8c    0000006c     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwRxInt)
                  c3208df8    0000006c                         : ethdriver.oe9 (.text:HwTxInt)
                  c3208e64    0000006c     stack.lib : icmp.oe9 (.text:ICMPChecksum)
                  c3208ed0    0000006c     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.text:MDIO_initPHY)
                  c3208f3c    0000006c     stack.lib : pipe.oe9 (.text:PipeCheck)
                  c3208fa8    0000006c               : rtable.oe9 (.text:RouteMsg)
                  c3209014    0000006c               : sock6.oe9 (.text:Sock6Bind)
                  c3209080    0000006c               : tcp6prot.oe9 (.text:TCP6PrCtlError)
                  c32090ec    0000006c               : tcpprot.oe9 (.text:TcpPrCtlError)
                  c3209158    0000006c               : rtable.oe9 (.text:_RtNodeRemove)
                  c32091c4    0000006c     ti.sysbios.family.arm.da830.ae9 : Hwi_asm.oe9 (.text:_ti_sysbios_family_arm_da830_Hwi_dispatchIRQ__I)
                  c3209230    0000006c     rtsv5_A_le_eabi.lib : copy_decompress_rle.obj (.text:decompress:rle)
                  c320929c    0000006c     nettool.lib : httpsend.oe9 (.text:httpSendErrorResponse)
                  c3209308    0000006c     stack.lib : lcp.oe9 (.text:lcpSendTerm)
                  c3209374    0000006c     powerSleepCtrl.obj (.text)
                  c32093e0    0000006c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Mmu_disable__E)
                  c320944c    0000006c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_handlerLOWER__I)
                  c32094b8    0000006c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_handlerNONE__I)
                  c3209524    0000006c     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_getCount__E)
                  c3209590    0000006c     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_hwiEndHook__E)
                  c32095fc    00000068     nettool.lib : config.oe9 (.text:CfgEntryGetData)
                  c3209664    00000068     stack.lib : icmpv6in.oe9 (.text:ICMPv6RecvDstUnreachable)
                  c32096cc    00000068               : ipv6_frag.oe9 (.text:IPv6ReasmTimeout)
                  c3209734    00000068               : nimu.oe9 (.text:NIMUUnregister)
                  c320979c    00000068               : node.oe9 (.text:NodeUpdatePL)
                  c3209804    00000068               : rtable.oe9 (.text:RtWalkBegin)
                  c320986c    00000068               : rtable.oe9 (.text:RtWalkEnd)
                  c32098d4    00000068               : tcp6prot.oe9 (.text:TCP6Drop)
                  c320993c    00000068               : tcpprot.oe9 (.text:TcpDrop)
                  c32099a4    00000068     ti.sysbios.family.arm.da830.ae9 : Hwi_asm.oe9 (.text:_ti_sysbios_family_arm_da830_Hwi_init__I)
                  c3209a0c    00000068     stack.lib : fileuser.oe9 (.text:fdCloseSession)
                  c3209a74    00000068     rtsv5_A_le_eabi.lib : strtok.obj (.text)
                  c3209adc    00000066     stack.lib : timer.oe9 (.text:TimerNew)
                  c3209b42    00000002     --HOLE-- [fill = 0]
                  c3209b44    00000064               : lliin.oe9 (.text:LLIValidateRoute)
                  c3209ba8    00000064               : sb6.oe9 (.text:SB6SetMax)
                  c3209c0c    00000064               : sb.oe9 (.text:SBSetMax)
                  c3209c70    00000064               : sock6.oe9 (.text:Sock6GetName)
                  c3209cd4    00000064               : sock.oe9 (.text:SockDisconnect)
                  c3209d38    00000064               : tcp6prot.oe9 (.text:TCP6Close)
                  c3209d9c    00000064               : tcpprot.oe9 (.text:TcpClose)
                  c3209e00    00000064     os.lib : efs.oe9 (.text:efs_filesend)
                  c3209e64    00000064     stack.lib : file.oe9 (.text:fdint_waitevent)
                  c3209ec8    00000064     commProcessor.pe9.obj (.text:ti_sysbios_BIOS_startFunc__I)
                  c3209f2c    00000064     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_restore__E)
                  c3209f90    00000064     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_blockI__E)
                  c3209ff4    00000064     commProcessor.pe9.obj (.text:xdc_runtime_Core_assignParams__I)
                  c320a058    00000060     stack.lib : icmpv6_ndisc.oe9 (.text:ICMPv6RecvRS)
                  c320a0b8    00000060               : mld.oe9 (.text:MLDCreateMulticastNode)
                  c320a118    00000060               : sb6.oe9 (.text:SB6Flush)
                  c320a178    00000060               : sb.oe9 (.text:SBFlush)
                  c320a1d8    00000060               : tcp6prot.oe9 (.text:TCP6PrSend)
                  c320a238    00000060               : tcpprot.oe9 (.text:TcpPrSend)
                  c320a298    00000060               : timer.oe9 (.text:TimerHSTick)
                  c320a2f8    00000060     boot.ae9 : boot.oe9 (.text)
                  c320a358    00000060     nettool.lib : dhcpsm.oe9 (.text:dhcpIPRemove)
                  c320a3b8    00000060                 : dhcptags.oe9 (.text:dhcpOptionsClear)
                  c320a418    00000060     ti.sysbios.family.arm.exc.ae9 : Exception_asm.oe9 (.text:ti_sysbios_family_arm_exc_Exception_init__I)
                  c320a478    00000060     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_swiEndHook__E)
                  c320a4d8    0000005e     stack.lib : nimu.oe9 (.text:NIMUAllocateName)
                  c320a536    00000002     --HOLE-- [fill = 0]
                  c320a538    0000005c     nettool.lib : telnetd.oe9 (.text:CmdWriteCmd)
                  c320a594    0000005c     stack.lib : route.oe9 (.text:RtDeRef)
                  c320a5f0    0000005c               : tcp6time.oe9 (.text:TCP6TimeoutPersist)
                  c320a64c    0000005c               : tcptime.oe9 (.text:TcpTimeoutPersist)
                  c320a6a8    0000005c               : rtc.oe9 (.text:_RTCSendRtAdv)
                  c320a704    0000005c     rtsv5_A_le_eabi.lib : strstr.obj (.text)
                  c320a760    0000005c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_Module_startup__E)
                  c320a7bc    0000005c     commProcessor.pe9.obj (.text:xdc_runtime_SysMin_flush__F)
                  c320a818    00000058     stack.lib : ipfrag.oe9 (.text:IPReasmTimeout)
                  c320a870    00000058               : ipv6out.oe9 (.text:IPv6GetRoute)
                  c320a8c8    00000058               : nimu.oe9 (.text:NIMUInit)
                  c320a920    00000058               : rawethsock.oe9 (.text:RawEthSockNotify)
                  c320a978    00000058               : sock.oe9 (.text:SockGetName)
                  c320a9d0    00000058               : sockpcb.oe9 (.text:SockPcbRtChange)
                  c320aa28    00000058               : tcp6prot.oe9 (.text:TCP6PrConnect)
                  c320aa80    00000058               : tcpprot.oe9 (.text:TcpPrConnect)
                  c320aad8    00000058     nettool.lib : dhcpbild.oe9 (.text:dhcpBuildDiscover)
                  c320ab30    00000054                 : config.oe9 (.text:CfgGetImmediate)
                  c320ab84    00000054     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:GetPacket)
                  c320abd8    00000054     stack.lib : ip.oe9 (.text:IPChecksum)
                  c320ac2c    00000054               : pipe.oe9 (.text:PipeClose)
                  c320ac80    00000054               : sb.oe9 (.text:SBFree)
                  c320acd4    00000054               : sock6.oe9 (.text:Sock6IntAbort)
                  c320ad28    00000054     os.lib : task_bios6.oe9 (.text:TaskCleanup)
                  c320ad7c    00000054     nettool.lib : config.oe9 (.text:_CfgAcquire)
                  c320add0    00000054     hal_timer_bios.lib : lltimer_bios6.oe9 (.text:_llTimerInit)
                  c320ae24    00000054     ti.sysbios.family.arm.ae9 : TaskSupport_asm.oe9 (.text:_ti_sysbios_family_arm_TaskSupport_buildTaskStack)
                  c320ae78    00000054     commProcessor.pe9.obj (.text:malloc)
                  c320aecc    00000054     stack.lib : nimupppoe.oe9 (.text:pppoeInput)
                  c320af20    00000054     os.lib : ossys.oe9 (.text:stricmp)
                  c320af74    00000054     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Mmu_enable__E)
                  c320afc8    00000054     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_restore__E)
                  c320b01c    00000054     commProcessor.pe9.obj (.text:xdc_runtime_Startup_exec__E)
                  c320b070    00000054     commProcessor.pe9.obj (.text:xdc_runtime_SysMin_putch__F)
                  c320b0c4    00000051     commProcessor.pe9.obj (.text:xdc_runtime_Text_printVisFxn__I)
                  c320b115    00000003     --HOLE-- [fill = 0]
                  c320b118    00000050     nettool.lib : config.oe9 (.text:CfgSetService)
                  c320b168    00000050     stack.lib : file.oe9 (.text:FdSignalEvent)
                  c320b1b8    00000050     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.text:MDIO_close)
                  c320b208    00000050     stack.lib : nimu.oe9 (.text:NIMUFindByName)
                  c320b258    00000050     netctrl.lib : netsrv.oe9 (.text:NS_PreBoot)
                  c320b2a8    00000050     os.lib : pbm.oe9 (.text:PBMQ_deq)
                  c320b2f8    00000050     stack.lib : route6.oe9 (.text:Rt6Update)
                  c320b348    00000050     netctrl.lib : netsrv.oe9 (.text:ServiceCallback)
                  c320b398    00000050     stack.lib : sock6pcb.oe9 (.text:Sock6PcbRtChange)
                  c320b3e8    00000050               : sock.oe9 (.text:SockIntAbort)
                  c320b438    00000050               : tcp6time.oe9 (.text:TCP6SetPersist)
                  c320b488    00000050               : tcptime.oe9 (.text:TcpSetPersist)
                  c320b4d8    00000050               : lli.oe9 (.text:_LLIExpListRemove)
                  c320b528    00000050               : rtable.oe9 (.text:_RtExpListRemove)
                  c320b578    00000050     os.lib : efs.oe9 (.text:efs_fclose)
                  c320b5c8    00000050     stack.lib : listlib.oe9 (.text:list_remove_node)
                  c320b618    00000050     os.lib : mem_bios6.oe9 (.text:mmUnInitPage)
                  c320b668    00000050     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_startup__E)
                  c320b6b8    00000050     commProcessor.pe9.obj (.text:xdc_runtime_Text_xprintf__I)
                  c320b708    0000004c     stack.lib : md5.oe9 (.text:Encode)
                  c320b754    0000004c               : icmpv6in.oe9 (.text:ICMPv6RecvParamProblem)
                  c320b7a0    0000004c               : ipv6.oe9 (.text:IPv6CompareAddress)
                  c320b7ec    0000004c     netctrl.lib : netctrl.oe9 (.text:NC_SystemClose)
                  c320b838    0000004c     stack.lib : sb6.oe9 (.text:SB6Free)
                  c320b884    0000004c               : sock.oe9 (.text:SockBind)
                  c320b8d0    0000004c     os.lib : efs.oe9 (.text:efs_findfile)
                  c320b91c    0000004c     nettool.lib : httpsend.oe9 (.text:httpSendEntityLength)
                  c320b968    0000004c     rtsv5_A_le_eabi.lib : fs_toi32.obj (.text)
                  c320b9b4    0000004c                         : fs_tou32.obj (.text)
                  c320ba00    0000004c     commProcessor.pe9.obj (.text:ti_sysbios_BIOS_exitFunc__I)
                  c320ba4c    0000004c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Idle_loop__E)
                  c320ba98    0000004c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_Module_startup__E)
                  c320bae4    00000048     stack.lib : bind.oe9 (.text:BindFindByNet)
                  c320bb2c    00000048     nettool.lib : config.oe9 (.text:CfgEntryInfo)
                  c320bb74    00000048     stack.lib : lli6.oe9 (.text:LLI6IsRouterStatMachine)
                  c320bbbc    00000048               : mld.oe9 (.text:MLDTestGroup)
                  c320bc04    00000048               : nimu.oe9 (.text:NIMUAllocateIndex)
                  c320bc4c    00000048               : nimu.oe9 (.text:NIMUPacketServiceCheck)
                  c320bc94    00000048               : route.oe9 (.text:RtSetFailure)
                  c320bcdc    00000048               : sock6pcb.oe9 (.text:Sock6PcbDetach)
                  c320bd24    00000048               : sockpcb.oe9 (.text:SockCleanPcb)
                  c320bd6c    00000048               : sockpcb.oe9 (.text:SockPcbDetach)
                  c320bdb4    00000048               : timer.oe9 (.text:TimerListRemove)
                  c320bdfc    00000048     nettool.lib : config.oe9 (.text:_CfgRelease)
                  c320be44    00000048     stack.lib : lli.oe9 (.text:_LLITimeoutFlush)
                  c320be8c    00000048     nettool.lib : dhcpsock.oe9 (.text:dhcpPacketSend)
                  c320bed4    00000048     stack.lib : file.oe9 (.text:fdint_setevent)
                  c320bf1c    00000048     rtsv5_A_le_eabi.lib : strncpy.obj (.text)
                  c320bf64    00000048                         : strspn.obj (.text)
                  c320bfac    00000048     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_checkStack:ti_sysbios_hal_Hwi_checkStack)
                  c320bff4    00000048     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_Object__create__S)
                  c320c03c    00000048     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_allBlockedFunction__I)
                  c320c084    00000048     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_Module_startup__E)
                  c320c0cc    00000048     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_taskCreateHook__E)
                  c320c114    00000048     commProcessor.pe9.obj (.text:xdc_runtime_System_rtsExit__I)
                  c320c15c    00000046     commProcessor.pe9.obj (.text:xdc_runtime_Error_print__F)
                  c320c1a2    00000002     --HOLE-- [fill = 0]
                  c320c1a4    00000044     stack.lib : bind6.oe9 (.text:Bind6FindByHost)
                  c320c1e8    00000044               : bind6.oe9 (.text:Bind6FindByNet)
                  c320c22c    00000044     nettool.lib : telnetd.oe9 (.text:CmdWriteBytes)
                  c320c270    00000044     stack.lib : icmpv6in.oe9 (.text:ICMPv6RecvTimeExceeded)
                  c320c2b4    00000044               : igmp.oe9 (.text:IGMPTestGroup)
                  c320c2f8    00000044               : lli6.oe9 (.text:LLI6Free)
                  c320c33c    00000044               : nimuppp.oe9 (.text:PPPSend)
                  c320c380    00000044     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:Queue_pop)
                  c320c3c4    00000044     stack.lib : rawethsock.oe9 (.text:RawEthSockClose)
                  c320c408    00000044               : route.oe9 (.text:RtSetTimeout)
                  c320c44c    00000044               : sockprot.oe9 (.text:SockPrCtlError)
                  c320c490    00000044               : tcp6in.oe9 (.text:TCP6EnterTimeWait)
                  c320c4d4    00000044               : tcp6prot.oe9 (.text:TCP6PrListen)
                  c320c518    00000044               : tcpin.oe9 (.text:TcpEnterTimeWait)
                  c320c55c    00000044               : tcpprot.oe9 (.text:TcpPrListen)
                  c320c5a0    00000044               : vlan.oe9 (.text:VLANInit)
                  c320c5e4    00000044     miniPrintf.lib : miniPrintf.oe9 (.text:printf)
                  c320c628    00000044     rtsv5_A_le_eabi.lib : strcspn.obj (.text)
                  c320c66c    00000044     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateHwi_Object__create__S)
                  c320c6b0    00000044     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_initStack:ti_sysbios_hal_Hwi_initStack)
                  c320c6f4    00000044     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_Timer_getFreq__E)
                  c320c738    00000044     commProcessor.pe9.obj (.text:xdc_runtime_SysMin_output__I)
                  c320c77c    00000040     stack.lib : bind6.oe9 (.text:Bind6FindByIF)
                  c320c7bc    00000040               : bind.oe9 (.text:BindFindByHost)
                  c320c7fc    00000040               : md5.oe9 (.text:Decode)
                  c320c83c    00000040               : ipv6_frag.oe9 (.text:IPv6FragQFree)
                  c320c87c    00000040               : md5.oe9 (.text:MD5Init)
                  c320c8bc    00000040               : nimu.oe9 (.text:NIMUPacketService)
                  c320c8fc    00000040     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:Queue_push)
                  c320c93c    00000040     stack.lib : rawethsock_pcb.oe9 (.text:RawEthSockPcbFind)
                  c320c97c    00000040     nettool.lib : config.oe9 (.text:_CfgEntryProcess)
                  c320c9bc    00000040     ti.sysbios.family.arm.da830.ae9 : Hwi_asm_switch.oe9 (.text:_ti_sysbios_family_xxx_Hwi_switchToIsrStack)
                  c320c9fc    00000040     stack.lib : ipcp.oe9 (.text:ipcpStart)
                  c320ca3c    00000040     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Cache_startup__I)
                  c320ca7c    00000040     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_dispatchFIQC__I)
                  c320cabc    00000040     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateHwi_Handle__label__S)
                  c320cafc    00000040     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_Handle__label__S)
                  c320cb3c    00000040     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_Handle__label__S)
                  c320cb7c    00000040     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_init__I)
                  c320cbbc    00000040     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_pendTimeout__I)
                  c320cbfc    00000040     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_Handle__label__S)
                  c320cc3c    00000040     commProcessor.pe9.obj (.text:xdc_runtime_System_atexit__F)
                  c320cc7c    0000003c     stack.lib : bind.oe9 (.text:BindGetIFByDBCast)
                  c320ccb8    0000003c     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:EmacSend)
                  c320ccf4    0000003c     netctrl.lib : netctrl.oe9 (.text:NC_BootComplete)
                  c320cd30    0000003c     stack.lib : nimu.oe9 (.text:NIMUCreatePacket)
                  c320cd6c    0000003c               : route6.oe9 (.text:Rt6GetNetworkAddr)
                  c320cda8    0000003c               : route6.oe9 (.text:Rt6IsDefaultRoute)
                  c320cde4    0000003c               : route.oe9 (.text:RtFree)
                  c320ce20    0000003c               : listlib.oe9 (.text:list_cat)
                  c320ce5c    0000003c     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_Instance_finalize__F)
                  c320ce98    0000003c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_doTick__I)
                  c320ced4    0000003c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_restoreHwi__E)
                  c320cf10    00000038     nettool.lib : config.oe9 (.text:CfgEntryRef)
                  c320cf48    00000038     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:EmacStop)
                  c320cf80    00000038     stack.lib : exec.oe9 (.text:ExecTimer)
                  c320cfb8    00000038               : nimu.oe9 (.text:NIMUGetNumOfObject)
                  c320cff0    00000038               : sock6pcb.oe9 (.text:Sock6PcbAttach)
                  c320d028    00000038               : sock6prot.oe9 (.text:Sock6PrCtlError)
                  c320d060    00000038               : sockpcb.oe9 (.text:SockPcbAttach)
                  c320d098    00000038               : tcptime.oe9 (.text:TcpTimeoutWait2)
                  c320d0d0    00000038               : vlan.oe9 (.text:VLANFindSourceInterface)
                  c320d108    00000038     nettool.lib : dhcpsock.oe9 (.text:dhcpPacketReceive)
                  c320d140    00000038     stack.lib : listlib.oe9 (.text:list_remove)
                  c320d178    00000038     commProcessor.pe9.obj (.text:rtsLock$8)
                  c320d1b0    00000038     rtsv5_A_le_eabi.lib : strncmp.obj (.text)
                  c320d1e8    00000038     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_reset__F)
                  c320d220    00000034     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:FreePacket)
                  c320d254    00000034                         : csl_mdio.oe9 (.text:MDIO_open)
                  c320d288    00000034     stack.lib : nimu.oe9 (.text:NIMUFindByIndex)
                  c320d2bc    00000034               : nimuppp.oe9 (.text:PPPStart)
                  c320d2f0    00000034               : sock6pcb.oe9 (.text:Sock6PcbCleanup)
                  c320d324    00000034               : sockpcb.oe9 (.text:SockPcbCleanup)
                  c320d358    00000034     ti.sysbios.family.arm.arm9.ae9 : Mmu_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Mmu_enableAsm)
                  c320d38c    00000034     stack.lib : file.oe9 (.text:fdint_getfdt)
                  c320d3c0    00000034               : fileuser.oe9 (.text:fdsetTestEntry)
                  c320d3f4    00000034               : ipcp.oe9 (.text:ipcpInit)
                  c320d428    00000034     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:pqPop)
                  c320d45c    00000034     commProcessor.pe9.obj (.text:rtsUnlock$8)
                  c320d490    00000034     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Cache_disable__E)
                  c320d4c4    00000034     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Cache_enable__E)
                  c320d4f8    00000034     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_Object__delete__S)
                  c320d52c    00000034     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_Object__delete__S)
                  c320d560    00000034     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_Object__delete__S)
                  c320d594    00000034     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_Object__delete__S)
                  c320d5c8    00000034     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_enter__I)
                  c320d5fc    00000034     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_Object__delete__S)
                  c320d630    00000030     stack.lib : bind.oe9 (.text:BindFindByIF)
                  c320d660    00000030     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:EmacPktService)
                  c320d690    00000030     stack.lib : icmpv6in.oe9 (.text:ICMPv6RecvPktTooBig)
                  c320d6c0    00000030     os.lib : intmgmt_bios6.oe9 (.text:Interrupt_delete)
                  c320d6f0    00000030     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:Interrupt_end)
                  c320d720    00000030     stack.lib : lli.oe9 (.text:LLIFree)
                  c320d750    00000030     os.lib : task_bios6.oe9 (.text:NDK_hookCreate)
                  c320d780    00000030     stack.lib : nimu.oe9 (.text:NIMUAddHeader)
                  c320d7b0    00000030               : rtc.oe9 (.text:RTCAddHook)
                  c320d7e0    00000030               : rtc.oe9 (.text:RTCRemoveHook)
                  c320d810    00000030               : tcp6.oe9 (.text:TCP6TimeoutRemove)
                  c320d840    00000030               : tcp6time.oe9 (.text:TCP6TimeoutWait2)
                  c320d870    00000030     os.lib : task_bios6.oe9 (.text:TaskDestroy)
                  c320d8a0    00000030     stack.lib : tcp.oe9 (.text:TcpTimeoutRemove)
                  c320d8d0    00000030               : vlan.oe9 (.text:VLANFindNode)
                  c320d900    00000030     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:emacUpdateStats)
                  c320d930    00000030     stack.lib : fileuser.oe9 (.text:fdSelectAbort)
                  c320d960    00000030     commProcessor.pe9.obj (.text:postInit$12)
                  c320d990    00000030     ti.drv.omapl138.ae9 : csl_emac.oe9 (.text:pqPush)
                  c320d9c0    00000030                         : csl_emac.oe9 (.text:pqPushChain)
                  c320d9f0    00000030     rtsv5_A_le_eabi.lib : strcat.obj (.text)
                  c320da20    00000030     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_arm9_Mmu_Module_startup__E)
                  c320da50    00000030     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateHwi_Object__delete__S)
                  c320da80    00000030     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_Object__delete__S)
                  c320dab0    00000030     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_postInit__I)
                  c320dae0    00000030     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_sleepTimeout__I)
                  c320db10    00000030     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_getGlobalHwiLoad__E)
                  c320db40    00000030     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_getGlobalSwiLoad__E)
                  c320db70    00000030     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_taskDeleteHook__E)
                  c320dba0    00000030     commProcessor.pe9.obj (.text:xdc_runtime_Memory_valloc__F)
                  c320dbd0    0000002c     stack.lib : bind6.oe9 (.text:Bind6IF2IPHost)
                  c320dbfc    0000002c               : exec.oe9 (.text:ExecBroadcast)
                  c320dc28    0000002c               : exec.oe9 (.text:ExecClose)
                  c320dc54    0000002c               : rawethsock_pcb.oe9 (.text:RawEthSockPcbCleanup)
                  c320dc80    0000002c     os.lib : efs.oe9 (.text:efs_loadfunction)
                  c320dcac    0000002c     stack.lib : file.oe9 (.text:fdint_clearevent)
                  c320dcd8    0000002c     nettool.lib : httpsend.oe9 (.text:httpSendClientStr)
                  c320dd04    0000002c     rtsv5_A_le_eabi.lib : args_main.obj (.text)
                  c320dd30    0000002c                         : memchr.obj (.text)
                  c320dd5c    0000002c                         : strcmp.obj (.text)
                  c320dd88    0000002c     miniPrintf.lib : miniPrintf.oe9 (.text:sprintf)
                  c320ddb4    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_disableInterrupt__E)
                  c320dde0    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_enableInterrupt__E)
                  c320de0c    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_handlerALL__I)
                  c320de38    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_Instance_finalize__F)
                  c320de64    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_Module_startup__E)
                  c320de90    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_hal_Timer_Module_startup__E)
                  c320debc    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_Module_startup__E)
                  c320dee8    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_Object__destruct__S)
                  c320df14    0000002c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_put__E)
                  c320df40    00000028     stack.lib : bind.oe9 (.text:BindGetIP)
                  c320df68    00000028               : tcp6in.oe9 (.text:SEQ_GEQ)
                  c320df90    00000028               : tcp6out.oe9 (.text:SEQ_GEQ)
                  c320dfb8    00000028               : tcpin.oe9 (.text:SEQ_GEQ)
                  c320dfe0    00000028               : tcpout.oe9 (.text:SEQ_GEQ)
                  c320e008    00000028               : tcp6in.oe9 (.text:SEQ_GT)
                  c320e030    00000028               : tcp6out.oe9 (.text:SEQ_GT)
                  c320e058    00000028               : tcpin.oe9 (.text:SEQ_GT)
                  c320e080    00000028               : tcpout.oe9 (.text:SEQ_GT)
                  c320e0a8    00000028               : tcp6in.oe9 (.text:SEQ_LEQ)
                  c320e0d0    00000028               : tcp6out.oe9 (.text:SEQ_LEQ)
                  c320e0f8    00000028               : tcpin.oe9 (.text:SEQ_LEQ)
                  c320e120    00000028               : tcpout.oe9 (.text:SEQ_LEQ)
                  c320e148    00000028               : tcp6in.oe9 (.text:SEQ_LT)
                  c320e170    00000028               : tcp6out.oe9 (.text:SEQ_LT)
                  c320e198    00000028               : tcpin.oe9 (.text:SEQ_LT)
                  c320e1c0    00000028               : tcpout.oe9 (.text:SEQ_LT)
                  c320e1e8    00000028               : sock6prot.oe9 (.text:Sock6PrDetach)
                  c320e210    00000028               : sockprot.oe9 (.text:SockPrDetach)
                  c320e238    00000028               : tcp6.oe9 (.text:TCP6TimeoutAdd)
                  c320e260    00000028               : tcp.oe9 (.text:TcpTimeoutAdd)
                  c320e288    00000028               : fileuser.oe9 (.text:fdError)
                  c320e2b0    00000028     commProcessor.pe9.obj (.text:free)
                  c320e2d8    00000028     stack.lib : listlib.oe9 (.text:list_add)
                  c320e300    00000028     rtsv5_A_le_eabi.lib : strchr.obj (.text)
                  c320e328    00000028     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_plug__E)
                  c320e350    00000028     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_Instance_finalize__F)
                  c320e378    00000028     commProcessor.pe9.obj (.text:xdc_runtime_SysMin_abort__F)
                  c320e3a0    00000028     commProcessor.pe9.obj (.text:xdc_runtime_System_aprintf__E)
                  c320e3c8    00000028     commProcessor.pe9.obj (.text:xdc_runtime_System_printf__E)
                  c320e3f0    00000028     commProcessor.pe9.obj (.text:xdc_runtime_System_putchar__I)
                  c320e418    00000024     stack.lib : ip.oe9 (.text:IPRtChange)
                  c320e43c    00000024               : ipv6.oe9 (.text:IPv6IsLinkLocal)
                  c320e460    00000024               : lli6.oe9 (.text:LLI6IsValid)
                  c320e484    00000024               : mld.oe9 (.text:MLDDeleteMulticastNode)
                  c320e4a8    00000024               : nimu.oe9 (.text:NIMUSendPacket)
                  c320e4cc    00000024     nettool.lib : ipaddr.oe9 (.text:RouteHook)
                  c320e4f0    00000024     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:StatusUpdate)
                  c320e514    00000024     ti.sysbios.family.arm.arm9.ae9 : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_wbInv__E)
                  c320e538    00000024     nettool.lib : dhcpsock.oe9 (.text:dhcpSocketClose)
                  c320e55c    00000024     stack.lib : file.oe9 (.text:fdint_freefdt)
                  c320e580    00000024               : lcp.oe9 (.text:lcpClose)
                  c320e5a4    00000024     rtsv5_A_le_eabi.lib : _lock.obj (.text)
                  c320e5c8    00000024                         : ll_lsl32.obj (.text)
                  c320e5ec    00000024     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_startI__E)
                  c320e610    00000024     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_Instance_finalize__F)
                  c320e634    00000024     commProcessor.pe9.obj (.text:xdc_runtime_SysMin_Module_startup__E)
                  c320e658    00000020     stack.lib : lli6.oe9 (.text:LLI6IsDead)
                  c320e678    00000020               : lli6.oe9 (.text:LLI6IsRouter)
                  c320e698    00000020     netctrl.lib : netctrl.oe9 (.text:NC_IPUpdate)
                  c320e6b8    00000020                 : netctrl.oe9 (.text:NC_NetStop)
                  c320e6d8    00000020     stack.lib : sock6int.oe9 (.text:Sock6SetOOBMark)
                  c320e6f8    00000020               : sockint.oe9 (.text:SockSetOOBMark)
                  c320e718    00000020               : timer.oe9 (.text:TimerFree)
                  c320e738    00000020     rtsv5_A_le_eabi.lib : icall32.obj (.text)
                  c320e758    00000020     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_write2__E)
                  c320e778    00000020     commProcessor.pe9.obj (.text:xdc_runtime_Memory_free__E)
                  c320e798    00000020     commProcessor.pe9.obj (.text:xdc_runtime_System_avprintf__F)
                  c320e7b8    00000020     commProcessor.pe9.obj (.text:xdc_runtime_System_vprintf__F)
                  c320e7d8    0000001c     stack.lib : exec.oe9 (.text:ExecHRef)
                  c320e7f4    0000001c               : ipv6.oe9 (.text:IPv6IsMulticast)
                  c320e810    0000001c     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.text:MDIO_getStatus)
                  c320e82c    0000001c     stack.lib : nimu.oe9 (.text:NIMUGetRsvdSizeInfo)
                  c320e848    0000001c     nettool.lib : ipaddr.oe9 (.text:NtRemoveNetwork)
                  c320e864    0000001c     stack.lib : rawethsock_pcb.oe9 (.text:RawEthSockPcbInit)
                  c320e880    0000001c     ti.sysbios.family.arm.ae9 : TaskSupport_asm.oe9 (.text:_ti_sysbios_family_arm_TaskSupport_glue)
                  c320e89c    0000001c     ti.sysbios.family.arm.arm9.ae9 : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_disableL1d__I)
                  c320e8b8    0000001c                                    : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_getEnabled__E)
                  c320e8d4    0000001c     rtsv5_A_le_eabi.lib : copy_zero_init.obj (.text:decompress:ZI)
                  c320e8f0    0000001c                         : copy_decompress_none.obj (.text:decompress:none)
                  c320e90c    0000001c     nettool.lib : inetaddr.oe9 (.text:inet_addr)
                  c320e928    0000001c     rtsv5_A_le_eabi.lib : strcpy.obj (.text)
                  c320e944    0000001c                         : strlen.obj (.text)
                  c320e960    0000001c     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_leave__E)
                  c320e97c    0000001c     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_Object__get__S)
                  c320e998    0000001c     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_restore__E)
                  c320e9b4    0000001c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_remove__E)
                  c320e9d0    0000001c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_Object__get__S)
                  c320e9ec    0000001c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_enabled__E)
                  c320ea08    0000001c     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_Module_startup__E)
                  c320ea24    0000001c     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_Object__get__S)
                  c320ea40    0000001c     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_write0__E)
                  c320ea5c    0000001c     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_write1__E)
                  c320ea78    0000001c     commProcessor.pe9.obj (.text:xdc_runtime_Startup_exec__I)
                  c320ea94    0000001c     commProcessor.pe9.obj (.text:xdc_runtime_System_abort__F)
                  c320eab0    00000018     stack.lib : bind.oe9 (.text:BindIF2IPHost)
                  c320eac8    00000018               : bind.oe9 (.text:BindIFNet2IPHost)
                  c320eae0    00000018     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwPktInit)
                  c320eaf8    00000018                         : csl_mdio.oe9 (.text:MDIO_initStateMachine)
                  c320eb10    00000018     stack.lib : route6.oe9 (.text:Rt6IsLocalRoute)
                  c320eb28    00000018               : sock6prot.oe9 (.text:Sock6PrAttach)
                  c320eb40    00000018               : sock6int.oe9 (.text:Sock6SetOOBData)
                  c320eb58    00000018               : sockprot.oe9 (.text:SockPrAttach)
                  c320eb70    00000018               : sockint.oe9 (.text:SockSetOOBData)
                  c320eb88    00000018     ti.sysbios.family.arm.arm9.ae9 : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_disableL1p__I)
                  c320eba0    00000018                                    : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_enableL1p__I)
                  c320ebb8    00000018                                    : Mmu_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Mmu_disableAsm)
                  c320ebd0    00000018     rtsv5_A_le_eabi.lib : toupper.obj (.text)
                  c320ebe8    00000018     commProcessor.pe9.obj (.text:ti_sysbios_BIOS_setThreadType__E)
                  c320ec00    00000018     commProcessor.pe9.obj (.text:ti_sysbios_BIOS_start__E)
                  c320ec18    00000018     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_dequeue__E)
                  c320ec30    00000018     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_empty__E)
                  c320ec48    00000018     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_enqueue__E)
                  c320ec60    00000018     commProcessor.pe9.obj (.text:ti_sysbios_knl_Semaphore_reset__E)
                  c320ec78    00000018     commProcessor.pe9.obj (.text:ti_sysbios_knl_Swi_disable__E)
                  c320ec90    00000018     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_disable__E)
                  c320eca8    00000018     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_TimestampProvider_rolloverFunc__E)
                  c320ecc0    00000018     commProcessor.pe9.obj (.text:xdc_runtime_Error_check__E)
                  c320ecd8    00000018     commProcessor.pe9.obj (.text:xdc_runtime_Error_init__F)
                  c320ecf0    00000018     commProcessor.pe9.obj (.text:xdc_runtime_System_Module_startup__E)
                  c320ed08    00000018     commProcessor.pe9.obj (.text:xdc_runtime_System_vsprintf__F)
                  c320ed20    00000018     commProcessor.pe9.obj (.text:xdc_runtime_Text_visitRope__I)
                  c320ed38    00000014     stack.lib : exec.oe9 (.text:ExecLowResource)
                  c320ed4c    00000014               : lli6.oe9 (.text:LLI6IncRefCount)
                  c320ed60    00000014               : nimu.oe9 (.text:NIMUSetRsvdSizeInfo)
                  c320ed74    00000014     os.lib : task_bios6.oe9 (.text:NotifyLowResource)
                  c320ed88    00000014            : pbm.oe9 (.text:PBM_close)
                  c320ed9c    00000014     stack.lib : route6.oe9 (.text:Rt6IncRefCount)
                  c320edb0    00000014     os.lib : semaphore_bios6.oe9 (.text:SemDelete)
                  c320edc4    00000014            : task_bios6.oe9 (.text:TaskExit)
                  c320edd8    00000014     hal_timer_bios.lib : lltimer_bios6.oe9 (.text:_llTimerShutdown)
                  c320edec    00000014     ti.sysbios.family.arm.arm9.ae9 : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_enableL1d__I)
                  c320ee00    00000014                                    : Mmu_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Mmu_isEnabled)
                  c320ee14    00000014     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_disable__E)
                  c320ee28    00000014     commProcessor.pe9.obj (.text:xdc_runtime_LoggerBuf_enable__E)
                  c320ee3c    00000014     commProcessor.pe9.obj (.text:xdc_runtime_Memory_calloc__E)
                  c320ee50    00000010     stack.lib : bind6.oe9 (.text:Bind6GetInterfaceHandle)
                  c320ee60    00000010               : bind6.oe9 (.text:Bind6GetLifetime)
                  c320ee70    00000010               : bind.oe9 (.text:BindGetFirst)
                  c320ee80    00000010     nettool.lib : config.oe9 (.text:CfgSetDefault)
                  c320ee90    00000010     stack.lib : lli6.oe9 (.text:LLI6GetNetDevice)
                  c320eea0    00000010               : lli6.oe9 (.text:LLI6SetIncomplete)
                  c320eeb0    00000010     os.lib : task_bios6.oe9 (.text:NDK_hookInit)
                  c320eec0    00000010            : oem_bios6.oe9 (.text:OEMCacheClean)
                  c320eed0    00000010     stack.lib : route6.oe9 (.text:Rt6GetIF)
                  c320eee0    00000010               : route6.oe9 (.text:Rt6GetLLI)
                  c320eef0    00000010               : route6.oe9 (.text:Rt6GetMTU)
                  c320ef00    00000010     ti.sysbios.family.arm.ae9 : TaskSupport_asm.oe9 (.text:_ti_sysbios_family_arm_TaskSupport_swap__E)
                  c320ef10    00000010     ti.sysbios.family.arm.arm9.ae9 : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_wbInvAll__E)
                  c320ef20    00000010     stack.lib : file.oe9 (.text:fdint_signalevent)
                  c320ef30    00000010               : file.oe9 (.text:fdint_signaltimeout)
                  c320ef40    00000010     hal_timer_bios.lib : lltimer_bios6.oe9 (.text:llTimerGetStartTime)
                  c320ef50    00000010     commProcessor.pe9.obj (.text:ti_sysbios_BIOS_getThreadType__E)
                  c320ef60    00000010     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_exc_Exception_Module_startup__E)
                  c320ef70    00000010     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateHwi_enter__E)
                  c320ef80    00000010     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_HwiProxy_disable__E)
                  c320ef90    00000010     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_Params__init__S)
                  c320efa0    00000010     commProcessor.pe9.obj (.text:ti_sysbios_knl_Clock_getTicks__E)
                  c320efb0    00000010     commProcessor.pe9.obj (.text:ti_sysbios_knl_Queue_Object__get__S)
                  c320efc0    00000010     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_Params__init__S)
                  c320efd0    00000010     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_self__E)
                  c320efe0    00000010     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_TimestampProvider_get32__F)
                  c320eff0    00000010     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_TimestampProvider_startTimer__E)
                  c320f000    00000010     commProcessor.pe9.obj (.text:ti_sysbios_utils_Load_taskRegHook__E)
                  c320f010    00000010     commProcessor.pe9.obj (.text:xdc_runtime_System_exit__F)
                  c320f020    0000000c     stack.lib : bind6.oe9 (.text:Bind6SetLifetime)
                  c320f02c    0000000c               : node.oe9 (.text:NodeFree)
                  c320f038    0000000c     os.lib : efs.oe9 (.text:efs_getfilesize)
                  c320f044    0000000c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_getHookContext__E)
                  c320f050    0000000c     commProcessor.pe9.obj (.text:ti_sysbios_knl_Task_setHookContext__E)
                  c320f05c    00000008     stack.lib : bind.oe9 (.text:BindGetIF)
                  c320f064    00000008               : bind.oe9 (.text:BindGetNext)
                  c320f06c    00000008     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.text:EmacPoll)
                  c320f074    00000008     stack.lib : node.oe9 (.text:NodeGetRt)
                  c320f07c    00000008               : node.oe9 (.text:NodeSetRt)
                  c320f084    00000008               : tcp6prot.oe9 (.text:TCP6PrRecv)
                  c320f08c    00000008     os.lib : task_bios6.oe9 (.text:TaskBlock)
                  c320f094    00000008     stack.lib : tcpprot.oe9 (.text:TcpPrRecv)
                  c320f09c    00000008     os.lib : task_bios6.oe9 (.text:_TaskShutdown)
                  c320f0a4    00000008     commProcessor.pe9.obj (.text:__xdc__init)
                  c320f0ac    00000008     hal_ser_stub.lib : llserstb.oe9 (.text:_llSerialInit)
                  c320f0b4    00000008     ti.sysbios.family.arm.arm9.ae9 : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_invL1dAll__E)
                  c320f0bc    00000008                                    : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_invL1pAll__E)
                  c320f0c4    00000008                                    : Cache_asm.oe9 (.text:_ti_sysbios_family_arm_arm9_Cache_wait__E)
                  c320f0cc    00000008     stack.lib : listlib.oe9 (.text:list_get_head)
                  c320f0d4    00000008               : listlib.oe9 (.text:list_get_next)
                  c320f0dc    00000008     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateHwi_leave__E)
                  c320f0e4    00000008     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateHwi_query__E)
                  c320f0ec    00000008     commProcessor.pe9.obj (.text:ti_sysbios_gates_GateMutex_query__E)
                  c320f0f4    00000008     commProcessor.pe9.obj (.text:ti_sysbios_hal_Hwi_HwiProxy_restore__E)
                  c320f0fc    00000008     commProcessor.pe9.obj (.text:ti_sysbios_heaps_HeapMem_isBlocking__E)
                  c320f104    00000008     commProcessor.pe9.obj (.text:ti_sysbios_timers_timer64_TimestampProvider_Module_startup__E)
                  c320f10c    00000008     commProcessor.pe9.obj (.text:xdc_runtime_Error_getMsg__E)
                  c320f114    00000004     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:HwPktShutdown)
                  c320f118    00000004     hal_userled_stub.lib : llled.oe9 (.text:LED_TOGGLE)
                  c320f11c    00000004     stack.lib : nat.oe9 (.text:NatMsg)
                  c320f120    00000004     os.lib : oem_bios6.oe9 (.text:OEMSysCritOff)
                  c320f124    00000004            : oem_bios6.oe9 (.text:OEMSysCritOn)
                  c320f128    00000004     stack.lib : rawethsock_prot.oe9 (.text:RawEthSockPrAttach)
                  c320f12c    00000004               : rawethsock_prot.oe9 (.text:RawEthSockPrDetach)
                  c320f130    00000004     os.lib : semaphore_bios6.oe9 (.text:SemPend)
                  c320f134    00000004            : semaphore_bios6.oe9 (.text:SemPost)
                  c320f138    00000004            : semaphore_bios6.oe9 (.text:SemReset)
                  c320f13c    00000004     ti.drv.omapl138.ae9 : ethdriver.oe9 (.text:StatisticsUpdate)
                  c320f140    00000004     os.lib : task_bios6.oe9 (.text:TaskSelf)
                  c320f144    00000004            : task_bios6.oe9 (.text:TaskSetPri)
                  c320f148    00000004            : task_bios6.oe9 (.text:TaskSleep)
                  c320f14c    00000004     nettool.lib : telnetd.oe9 (.text:TelnetClose)
                  c320f150    00000004     os.lib : task_bios6.oe9 (.text:_TaskInit)
                  c320f154    00000004     hal_ser_stub.lib : llserstb.oe9 (.text:_llSerialServiceCheck)
                  c320f158    00000004                      : llserstb.oe9 (.text:_llSerialShutdown)
                  c320f15c    00000004     hal_userled_stub.lib : llled.oe9 (.text:_llUserLedInit)
                  c320f160    00000004                          : llled.oe9 (.text:_llUserLedShutdown)
                  c320f164    00000004     evminit.obj (.text)
                  c320f168    00000004     nettool.lib : http.oe9 (.text:httpClose)
                  c320f16c    00000004     hal_ser_stub.lib : llserstb.oe9 (.text:llSerialService)
                  c320f170    00000004     rtsv5_A_le_eabi.lib : remove.obj (.text)
                  c320f174    00000004                         : tdeh_init.obj (.text)
                  c320f178    00000004     commProcessor.pe9.obj (.text:ti_ndk_config_Global_NetworkClose$0)
                  c320f17c    00000004     commProcessor.pe9.obj (.text:ti_ndk_config_Global_NetworkOpen$0)
                  c320f180    00000004     commProcessor.pe9.obj (.text:ti_sysbios_family_arm_da830_Hwi_spuriousInt__I)
                  c320f184    00000004     commProcessor.pe9.obj (.text:ti_sysbios_hal_Cache_wbInv__E)
                  c320f188    00000004     miniPrintf.lib : miniPrintf.oe9 (.text:vsprintf)
                  c320f18c    00000004     commProcessor.pe9.obj (.text:xdc_runtime_Memory_alloc__E)
                  c320f190    00000004     commProcessor.pe9.obj (.text:xdc_runtime_Startup_reset__I)
                  c320f194    00000004     commProcessor.pe9.obj (.text:xdc_runtime_System_aprintf_va__F)
                  c320f198    00000004     commProcessor.pe9.obj (.text:xdc_runtime_System_printf_va__F)
                  c320f19c    00000004     commProcessor.pe9.obj (.text:xdc_runtime_System_vsprintf__E)
.const.1   0    c320f1a0    00000964
                  c320f1a0    00000101     rtsv5_A_le_eabi.lib : ctype.obj (.const:_ctypes_)
                  c320f2a1    00000003     --HOLE-- [fill = 0]
                  c320f2a4    000000ee     nettool.lib : httpstr.oe9 (.const:.string)
                  c320f392    00000002     --HOLE-- [fill = 0]
                  c320f394    000000e0     commProcessor.pe9.obj (.const:xdc_runtime_Text_nodeTab__A)
                  c320f474    000000a0     commProcessor.pe9.obj (.const:.string)
                  c320f514    00000075     nettool.lib : httpsend.oe9 (.const:.string)
                  c320f589    00000003     --HOLE-- [fill = 0]
                  c320f58c    00000058     emacHooks.obj (.const:.string)
                  c320f5e4    00000054     stack.lib : sockprot.oe9 (.const:Code2Err)
                  c320f638    00000048     commProcessor.pe9.obj (.const:ti_sysbios_knl_Task_hooks__A)
                  c320f680    0000003d     stack.lib : rtc.oe9 (.const:.string)
                  c320f6bd    00000003     --HOLE-- [fill = 0]
                  c320f6c0    0000003c     commProcessor.pe9.obj (.const:xdc_runtime_LoggerBuf_Module__FXNS__C)
                  c320f6fc    00000038     commProcessor.pe9.obj (.const:ti_sysbios_knl_Task_Object__PARAMS__C)
                  c320f734    00000034     commProcessor.pe9.obj (.const:xdc_runtime_Startup_sfxnTab__A)
                  c320f768    0000002c     commProcessor.pe9.obj (.const:ti_sysbios_family_arm_da830_Hwi_Object__PARAMS__C)
                  c320f794    0000002c     commProcessor.pe9.obj (.const:ti_sysbios_hal_Hwi_Object__PARAMS__C)
                  c320f7c0    00000028     commProcessor.pe9.obj (.const:ti_sysbios_heaps_HeapMem_Module__FXNS__C)
                  c320f7e8    00000024     stack.lib : ipv6.oe9 (.const)
                  c320f80c    00000024     commProcessor.pe9.obj (.const:ti_sysbios_gates_GateHwi_Module__FXNS__C)
                  c320f830    00000024     commProcessor.pe9.obj (.const:ti_sysbios_gates_GateMutex_Module__FXNS__C)
                  c320f854    00000024     commProcessor.pe9.obj (.const:ti_sysbios_knl_Clock_Object__PARAMS__C)
                  c320f878    00000024     commProcessor.pe9.obj (.const:ti_sysbios_knl_Semaphore_Object__PARAMS__C)
                  c320f89c    00000024     commProcessor.pe9.obj (.const:xdc_runtime_LoggerBuf_Object__PARAMS__C)
                  c320f8c0    00000020     commProcessor.pe9.obj (.const:ti_sysbios_family_arm_da830_Hwi_Object__DESC__C)
                  c320f8e0    00000020     commProcessor.pe9.obj (.const:ti_sysbios_gates_GateHwi_Object__DESC__C)
                  c320f900    00000020     commProcessor.pe9.obj (.const:ti_sysbios_gates_GateMutex_Object__DESC__C)
                  c320f920    00000020     commProcessor.pe9.obj (.const:ti_sysbios_hal_Hwi_Object__DESC__C)
                  c320f940    00000020     commProcessor.pe9.obj (.const:ti_sysbios_heaps_HeapMem_Object__DESC__C)
                  c320f960    00000020     commProcessor.pe9.obj (.const:ti_sysbios_heaps_HeapMem_Object__PARAMS__C)
                  c320f980    00000020     commProcessor.pe9.obj (.const:ti_sysbios_knl_Clock_Object__DESC__C)
                  c320f9a0    00000020     commProcessor.pe9.obj (.const:ti_sysbios_knl_Queue_Object__DESC__C)
                  c320f9c0    00000020     commProcessor.pe9.obj (.const:ti_sysbios_knl_Semaphore_Object__DESC__C)
                  c320f9e0    00000020     commProcessor.pe9.obj (.const:ti_sysbios_knl_Task_Object__DESC__C)
                  c320fa00    00000020     commProcessor.pe9.obj (.const:xdc_runtime_LoggerBuf_Object__DESC__C)
                  c320fa20    0000001d     commProcessor.pe9.obj (.const)
                  c320fa3d    00000003     --HOLE-- [fill = 0]
                  c320fa40    0000001a     commProcessor.pe9.obj (.const:xdc_runtime_Startup_sfxnRts__A)
                  c320fa5a    00000002     --HOLE-- [fill = 0]
                  c320fa5c    00000018     commProcessor.pe9.obj (.const:ti_sysbios_gates_GateHwi_Object__PARAMS__C)
                  c320fa74    00000018     commProcessor.pe9.obj (.const:ti_sysbios_gates_GateMutex_Object__PARAMS__C)
                  c320fa8c    00000018     commProcessor.pe9.obj (.const:ti_sysbios_knl_Queue_Object__PARAMS__C)
                  c320faa4    00000018     commProcessor.pe9.obj (.const:ti_sysbios_knl_Swi_hooks__A)
                  c320fabc    00000014     commProcessor.pe9.obj (.const:ti_sysbios_family_arm_da830_Hwi_hooks__A)
                  c320fad0    0000000c     commProcessor.pe9.obj (.const:xdc_runtime_Startup_firstFxns__A)
                  c320fadc    00000008     falconMain.obj (.const)
                  c320fae4    00000008     commProcessor.pe9.obj (.const:ti_sysbios_knl_Idle_funcList__A)
                  c320faec    00000004     commProcessor.pe9.obj (.const:xdc_runtime_IFilterLogger_Interface__BASE__C)
                  c320faf0    00000004     commProcessor.pe9.obj (.const:xdc_runtime_IGateProvider_Interface__BASE__C)
                  c320faf4    00000004     commProcessor.pe9.obj (.const:xdc_runtime_IHeap_Interface__BASE__C)
                  c320faf8    00000004     commProcessor.pe9.obj (.const:xdc_runtime_ILogger_Interface__BASE__C)
                  c320fafc    00000004     commProcessor.pe9.obj (.const:xdc_runtime_IModule_Interface__BASE__C)
                  c320fb00    00000004     commProcessor.pe9.obj (.const:xdc_runtime_Startup_lastFxns__A)
.data.1    0    c320fb04    000004fc
                  c320fb04    00000100     os.lib : intmgmt_bios6.oe9 (.data:hwiTable)
                  c320fc04    000000f0     rtsv5_A_le_eabi.lib : defs.obj (.data:_ftable)
                  c320fcf4    000000b4     stack.lib : exec.oe9 (.data:_ipcfg)
                  c320fda8    00000080     commProcessor.pe9.obj (.data:ti_sysbios_knl_Swi_Module_State_0_readyQ__A)
                  c320fe28    00000080     commProcessor.pe9.obj (.data:ti_sysbios_knl_Task_Module_State_0_readyQ__A)
                  c320fea8    00000078     rtsv5_A_le_eabi.lib : lowlev.obj (.data:_device)
                  c320ff20    00000060     commProcessor.pe9.obj (.data:ti_sysbios_timers_timer64_Timer_Module_State_0_device__A)
                  c320ff80    00000050     rtsv5_A_le_eabi.lib : lowlev.obj (.data:_stream)
                  c320ffd0    00000028     stack.lib : rtc.oe9 (.data)
                  c320fff8    00000008     dataSort.obj (.data)
ti.sysbios.family.arm.arm9.mmuTableSection
*          0    c3210000    00004000     UNINITIALIZED
                  c3210000    00004000     commProcessor.pe9.obj (ti.sysbios.family.arm.arm9.mmuTableSection)
.taskStackSection
*          0    c3214000    00002800     UNINITIALIZED
                  c3214000    00002800     commProcessor.pe9.obj (.taskStackSection)
.const.2   0    c3216800    00001299
                  c3216800    00001299     commProcessor.pe9.obj (.const:xdc_runtime_Text_charTab__A)
.data.2    0    c3217a9c    00000c8c
                  c3217a9c    000007bc     commProcessor.pe9.obj (.data)
                  c3218258    00000050     stack.lib : exec.oe9 (.data:tasks)
                  c32182a8    0000004d     nettool.lib : dhcptags.oe9 (.data:DHCPTypeCode)
                  c32182f5    00000003     --HOLE--
                  c32182f8    00000044                 : httpstr.oe9 (.data)
                  c321833c    00000040     netctrl.lib : netsrv.oe9 (.data:CloseOrder)
                  c321837c    00000040                 : netsrv.oe9 (.data:OpenOrder)
                  c32183bc    00000040     stack.lib : md5.oe9 (.data:PADDING)
                  c32183fc    00000040     nettool.lib : httpsend.oe9 (.data:codestr)
                  c321843c    00000034     stack.lib : tcp6time.oe9 (.data:tcp_backoff)
                  c3218470    00000034               : tcptime.oe9 (.data:tcp_backoff)
                  c32184a4    00000028     ti.drv.omapl138.ae9 : ethdriver.oe9 (.data)
                  c32184cc    00000024     os.lib : ossys.oe9 (.data:_oscfg)
                  c32184f0    00000024            : mem_bios6.oe9 (.data)
                  c3218514    0000001c     emacHooks.obj (.data)
                  c3218530    0000001c     os.lib : task_bios6.oe9 (.data)
                  c321854c    0000001c     ti.drv.omapl138.ae9 : csl_mdio.oe9 (.data)
                  c3218568    00000018     conditioner.obj (.data)
                  c3218580    00000018     netctrl.lib : netctrl.oe9 (.data)
                  c3218598    00000018     stack.lib : sock6pcb.oe9 (.data)
                  c32185b0    00000018               : sockpcb.oe9 (.data)
                  c32185c8    00000014               : rtable.oe9 (.data)
                  c32185dc    00000010     memoryUtils.obj (.data)
                  c32185ec    00000010     nettool.lib : daemon.oe9 (.data)
                  c32185fc    00000010     rtsv5_A_le_eabi.lib : defs.obj (.data)
                  c321860c    00000010     stack.lib : bind6.oe9 (.data)
                  c321861c    00000010               : igmp.oe9 (.data)
                  c321862c    00000010               : nimupppoe.oe9 (.data)
                  c321863c    00000010     ti.drv.omapl138.ae9 : csl_emac.oe9 (.data)
                  c321864c    0000000c     stack.lib : route6.oe9 (.data)
                  c3218658    0000000b               : tcp6out.oe9 (.data)
                  c3218663    00000001     --HOLE--
                  c3218664    0000000b               : tcpout.oe9 (.data)
                  c321866f    00000001     --HOLE--
                  c3218670    00000008     miniPrintf.lib : miniPrintf.oe9 (.data)
                  c3218678    00000008     os.lib : ossys.oe9 (.data)
                  c3218680    00000008     rtsv5_A_le_eabi.lib : _lock.obj (.data)
                  c3218688    00000008                         : exit.obj (.data)
                  c3218690    00000008     stack.lib : exec.oe9 (.data)
                  c3218698    00000008               : icmp.oe9 (.data)
                  c32186a0    00000008               : ip.oe9 (.data)
                  c32186a8    00000008               : ipin.oe9 (.data)
                  c32186b0    00000008               : ipv6_frag.oe9 (.data)
                  c32186b8    00000008               : lli.oe9 (.data)
                  c32186c0    00000008               : tcp.oe9 (.data)
                  c32186c8    00000008               : tcp6.oe9 (.data)
                  c32186d0    00000008               : timer.oe9 (.data)
                  c32186d8    00000008     ti.drv.omapl138.ae9 : nimu_eth.oe9 (.data)
                  c32186e0    00000006     stack.lib : lliout.oe9 (.data)
                  c32186e6    00000002     --HOLE--
                  c32186e8    00000004     hal_timer_bios.lib : lltimer_bios6.oe9 (.data)
                  c32186ec    00000004     netHooks.obj (.data)
                  c32186f0    00000004     netctrl.lib : netsrv.oe9 (.data)
                  c32186f4    00000004     nettool.lib : config.oe9 (.data)
                  c32186f8    00000004                 : httpsend.oe9 (.data)
                  c32186fc    00000004     os.lib : efs.oe9 (.data)
                  c3218700    00000004            : pbm.oe9 (.data)
                  c3218704    00000004     rtsv5_A_le_eabi.lib : dtor_list.obj (.data)
                  c3218708    00000004                         : fopen.obj (.data)
                  c321870c    00000004                         : lowlev.obj (.data)
                  c3218710    00000004                         : stkdepth_vars.obj (.data)
                  c3218714    00000004     stack.lib : bind.oe9 (.data)
                  c3218718    00000004               : ipfrag.oe9 (.data)
                  c321871c    00000004               : lli6.oe9 (.data)
                  c3218720    00000004               : mld.oe9 (.data)
                  c3218724    00000004               : node.oe9 (.data)
.stack     0    c3218728    00001000     UNINITIALIZED
                  c3218728    00001000     --HOLE--
.args      0    c3219728    00000200
                  c3219728    00000200     --HOLE-- [fill = 0]
.cinit     0    c3219928    00000998
                  c3219928    000006b5     (.cinit..data.2.load) [load image, compression = rle]
                  c3219fdd    00000003     --HOLE-- [fill = 0]
                  c3219fe0    00000258     (.cinit..data.1.load) [load image, compression = rle]
                  c321a238    0000003f     (.cinit..far.load) [load image, compression = rle]
                  c321a277    00000001     --HOLE-- [fill = 0]
                  c321a278    0000000c     (__TI_handler_table)
                  c321a284    00000004     --HOLE-- [fill = 0]
                  c321a288    00000008     (.cinit..bss.load) [load image, compression = zero_init]
                  c321a290    00000008     (.cinit..taskStackSection.load) [load image, compression = zero_init]
                  c321a298    00000028     (__TI_cinit_table)
.vecs      0    ffff0000    00000040
                  ffff0000    00000040     commProcessor.pe9.obj (.vecs)
.vectorTable
*          0    ffff0040    00000328
                  ffff0040    00000328     commProcessor.pe9.obj (.vectorTable)
...obviously the .cmd file did not change the default linking that occurs without that file on the ARM.  I verified that I included the .cmd file in my ARM project as I did in the DSP project.  I am currently using the workaround that forces a boot of the ARM at 0xffff000 (a hardware reset) that branches to the _c_init00 location, but I prefer my code to be more elegant.  The compiler seems to separated out the section, but did not relocate it.  Any help is appreciated...
Roy
