Problen with building mutex example for 6678
i'm trying to build the mutex example code, but the xdc, package is taking lot of time to build the pakage(its stuck @ 50%), and not proceeding any further.
xdctools_3_22_04_46 package is the js trying to build, pls help in this regard
  • Pratheek,
    are you building in CCS? If yes, please go to Project Properties->CCS Build->XDCtools->Advanced Options, and turn on -v option? Then post the whole console log output.
  • Sasha Slijepcevic said:
    Pratheek,
    # making package.mak (because of C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46/packages/xdc/bld/bld.js) ...
    C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46/xs -Dxdc.path="C:/PROGRA~1/TEXASI~1/bios_6_32_05_54/packages;C:/PROGRA~1/TEXASI~1/ipc_1_23_05_40/packages;C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46/packages;.." -Dxdc.root=C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46 -Dxdc.hostOS=Windows -Dconfig.importPath=".;C:/PROGRA~1/TEXASI~1/bios_6_32_05_54/packages;C:/PROGRA~1/TEXASI~1/ipc_1_23_05_40/packages;C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46/packages;..;C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46;C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46/etc" -Dxdc.bld.targets="" -DTOOLS= -f C:/PROGRA~1/TEXASI~1/xdctools_3_22_04_46/packages/xdc/bld/bld.js ./config.bld package.bld package.mak
  • the ccs is getiing stuck @ 50%, its opening lot of gmake process and finally crashes my system as no memory is available
  • A possible cause of infinite loops in gmake is that one or more of your files have a modification date set in the future relative to time on your computer. Compare the date and the time on the file 'bld.js' with your computer time.
