DM3730 OTG Host instable with FS devices
Other Parts Discussed in Thread: TPS65950, DM3730
I'm using DM3730 OTG Host port (interfaced with TPS65950) with a Linux software.
Everything seems working perfectly with High Speed (USB 2.0) devices but when using a FS (USB1.1) Hub, the same devices (mass-storage, Serial converter) doesn't work very well.
This behavior is true with Linux kernel and U-Boot
I activated debug in musb driver and it seems that sometimes, timeout occurs instead of TX interrupts (in the case of usb_control_msg).
This issue seems very close to Errata 11 of TPS 69650 but it deals with 4-pin serial mode and in our case, we are using default mode (8 bit synchronous)
Has anyone seen similar issues ?
Has anyone tested OTG Host port with FS devices ?
Thanks for any help,
Martin
