Other Parts Discussed in Thread: 4430, TWL6030, TMP105
Hi
I am using blaze with 4430 with kernel 3.0 using this checkout
git checkout 7e8957f6091917a778c35f95a6673c5a9783ed6f
I can see only android logo and automatically reboots
with an error msg CUSTOM SRESP error with SOURCE:L4 PER2
here is my error log
Texas Instruments X-Loader 1.41 (Jun 3 2011 - 18:52:38)
mmc read: Invalid size
Starting OS Bootloader from MMC/SD1 ...
U-Boot 1.1.4-L27.13.1^0 (Jul 22 2011 - 11:54:00)
Load address: 0x80e80000
DRAM: 1024 MB
Flash: 0 kB
Using default environment
In: serial
Out: serial
Err: serial
efi partition table:
256 128K xloader
512 256K bootloader
2048 8M recovery
18432 8M boot
34816 512M system
1083392 256M cache
1607680 512M userdata
2656256 2183M media
Net: KS8851SNL
Hit any key to stop autoboot: 0
kernel @ 80008000 (4248876)
ramdisk @ 81000000 (164635)
I2C read: I/O error
Blaze/SDP Board.
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.8-00216-g7e8957f (sandeep@sandeep) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #1 SMP PREEMPT Sun Mar 18 18:2
[ 0.000000] CPU: ARMv7 Processor [411fc092] revision 2 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 blaze board
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4430 ES2.2
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat c083bfe0, node_mem_map c1029000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] HighMem zone: 1792 pages used for memmap
[ 0.000000] HighMem zone: 92416 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1833000 s7072 r8192 d13408 u32768
[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 124928
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_margin=30
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 496MB = 496MB total
[ 0.000000] Memory: 489348k/489348k available, 559228k reserved, 376832K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc004e000 ( 280 kB)
[ 0.000000] .text : 0xc004e000 - 0xc07cf000 (7684 kB)
[ 0.000000] .data : 0xc07d0000 - 0xc083cb40 ( 435 kB)
[ 0.000000] .bss : 0xc083cb64 - 0xc09c2f80 (1562 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Calibrating delay loop... 2007.19 BogoMIPS (lpj=7839744)
[ 0.015686] pid_max: default: 32768 minimum: 301
[ 0.070617] Mount-cache hash table entries: 512
[ 0.070617] Initializing cgroup subsys debug
[ 0.070617] Initializing cgroup subsys cpuacct
[ 0.070617] Initializing cgroup subsys freezer
[ 0.071472] CPU: Testing write buffer coherency: ok
[ 0.071624] L310 cache controller enabled
[ 0.071838] l2x0: 16 ways, CACHE_ID 0x410000c4, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[ 0.149963] CPU1: Booted secondary processor
[ 0.220275] Brought up 2 CPUs
[ 0.220306] SMP: Total of 2 processors activated (4022.78 BogoMIPS).
[ 0.220489] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[ 0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[ 0.222961] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[ 0.222991] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.222991] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.222991] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.222991] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.223022] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[ 0.223022] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.223114] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[ 0.223114] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[ 0.223114] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.230987] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.232940] print_constraints: dummy:
[ 0.232940] NET: Registered protocol family 16
[ 0.232940] GPMC revision 6.0
[ 0.234497] EMIF0 is enabled with IRQ142
[ 0.234558] EMIF1 is enabled with IRQ143
[ 0.234588] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.234588]
[ 0.234924] OMAP GPIO hardware version 0.1
[ 0.235870] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.236328] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.238372] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.238372] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.470245] Modem NOT detected
[ 0.470245] Modem state properly updated to state 0
[ 0.471221] omap_disp_led_init: Configuring as one display LED
[ 0.595703] HSI: skipping omap_device registration
[ 0.595703] OMAP DMA hardware revision 0.0
[ 0.595703] omap_rproc_get_pool: carveout memory is unavailable: 0x0, 0x0
[ 0.603149] bio: create slab <bio-0> at 0
[ 0.603424] print_constraints: vwl1271: 1800 mV
[ 0.603424] i2c-core: driver [twl] using legacy suspend method
[ 0.604034] i2c-core: driver [twl] using legacy resume method
[ 0.604034] SCSI subsystem initialized
[ 0.605072] usbcore: registered new interface driver usbfs
[ 0.605072] usbcore: registered new interface driver hub
[ 0.605407] usbcore: registered new device driver usb
[ 0.606018] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.606079] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.609527] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.611389] print_constraints: VUSB: 3300 mV normal standby
[ 0.814453] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 0.815155] print_constraints: VMMC: 1200 <--> 3000 mV at 3000 mV normal standby
[ 0.815551] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 0.815948] print_constraints: VUSIM: 1200 <--> 2900 mV at 1800 mV normal standby
[ 0.816619] print_constraints: VCXIO: 1800 mV normal standby
[ 0.817291] print_constraints: VDAC: 1800 mV normal standby
[ 0.817687] print_constraints: VAUX1_6030: 1000 <--> 3000 mV at 2800 mV normal standby
[ 0.818145] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 0.818572] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 0.819000] print_constraints: CLK32KG:
[ 0.820007] print_constraints: VANA: 2100 mV normal standby
[ 0.820404] print_constraints: VOUT: 4075 <--> 4950 mV at 3825 mV normal standby
[ 0.820800] tps6130x 1-0033: Revision 5
[ 0.821228] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 0.821533] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 0.821960] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 0.822662] omap-rproc omap-rproc.0: dsp is available
[ 0.822662] omap-rproc omap-rproc.1: ipu is available
[ 0.822662] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.822875] Bluetooth: Core ver 2.16
[ 0.822875] NET: Registered protocol family 31
[ 0.822875] Bluetooth: HCI device and connection manager initialized
[ 0.823455] Bluetooth: HCI socket layer initialized
[ 0.823455] Bluetooth: L2CAP socket layer initialized
[ 0.823455] Bluetooth: SCO socket layer initialized
[ 0.823638] Switching to clocksource 32k_counter
[ 0.825103] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 0.825408] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 0.825408] musb-hdrc: MHDRC RTL version 2.0
[ 0.825408] musb-hdrc: setup fifo_mode 4
[ 0.825439] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 0.825622] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
[ 0.826049] NET: Registered protocol family 2
[ 0.826049] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.826263] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.826995] TCP bind hash table entries: 4096 (order: 4, 98304 bytes)
[ 0.826995] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.827239] TCP reno registered
[ 0.827239] UDP hash table entries: 64 (order: 0, 4096 bytes)
[ 0.827301] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[ 0.827301] NET: Registered protocol family 1
[ 0.827972] RPC: Registered named UNIX socket transport module.
[ 0.827972] RPC: Registered udp transport module.
[ 0.828002] RPC: Registered tcp transport module.
[ 0.828002] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.828002] Trying to unpack rootfs image as initramfs...
[ 0.829620] Switched to NOHz mode on CPU #0
[ 0.829650] Switched to NOHz mode on CPU #1
[ 0.838531] Freeing initrd memory: 160K
[ 1.378417] omap_init_opp_table: no hwmod or odev for hsi, [18] cannot add OPPs.
[ 1.378417] omap_init_opp_table: no hwmod or odev for hsi, [19] cannot add OPPs.
[ 1.378417] ram_console: got buffer at a0000000, size 200000
[ 1.379272] ram_console: uncorrectable error in header
[ 1.379272] ram_console: no valid data in buffer (sig = 0x00000000)
[ 1.393341] console [ram-1] enabled
[ 1.393859] omap-iommu omap-iommu.0: ducati registered
[ 1.393859] omap-iommu omap-iommu.1: tesla registered
[ 1.404113] highmem bounce pool size: 64 pages
[ 1.404113] ashmem: initialized
[ 1.410400] fuse init (API version 7.16)
[ 1.410400] msgmni has been set to 220
[ 1.411315] Registering char device tf_driver (122:0)
[ 1.411315] SMCAG01.06e1.0 D
[ 1.413482] io scheduler noop registered
[ 1.413482] io scheduler deadline registered
[ 1.413787] io scheduler cfq registered (default)
[ 1.413787] start plist test
[ 1.417449] end plist test
[ 1.422332] OMAP DSS rev 4.0
[ 1.469451] dsscomp: initializing.
[ 1.469451] misc dsscomp: display0=taal
[ 1.470275] misc dsscomp: display1=hdmi_panel
[ 1.470275] misc dsscomp: found 2 displays and 4 overlays
[ 1.470703] could not allocate slot
[ 1.471069] omap-rproc omap-rproc.1: powering up ipu
[ 1.471282] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[ 1.472259] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[ 1.472259] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 1.503417] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 1.597137] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 2.689300] console [ttyO2] enabled
[ 2.831542] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 2.995727] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 3.004669] omap_ion_probe: adding heap tiler of type 4 with ada00000@6000000
[ 3.012664] omap_ion_probe: adding heap nonsecure_tiler of type 4 with a0200000@2000000
[ 3.021667] PVR: PVRCore_Init
[ 3.025299] PVR: PVRSRVDriverProbe(pDevice=c78a4800)
[ 3.030975] PVR: SGX register base: 0x56000000
[ 3.036010] PVR: SGX register size: 65535
[ 3.040496] PVR: SGX IRQ: 53
[ 3.040557] PVR: EnableSystemClocks: Enabling System Clocks
[ 3.050048] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency (EBUSY) [167, drivers/gpu/pvr/omap4/sysutils_linux.c]
[ 3.063171] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency (EBUSY) [167, drivers/gpu/pvr/omap4/sysutils_linux.c]
[ 3.076232] PVR: PVRCore_Init: major device 251
[ 3.081481] brd: module loaded
[ 3.086547] loop: module loaded
[ 3.096191] (stk) :sysfs entries created
[ 3.100585] (stk) : debugfs entries created
[ 3.105407] No CPUfreq policy at this point.
[ 3.119079] ks8851 spi1.0: message enable is 0
[ 3.128692] ks8851 spi1.0: eth0: revision 0, MAC 16:47:24:fa:10:ce, IRQ 194
[ 3.136566] PPP generic driver version 2.4.2
[ 3.141387] PPP Deflate Compression module registered
[ 3.147155] PPP BSD Compression module registered
[ 3.153015] PPP MPPE Compression module registered
[ 3.158355] NET: Registered protocol family 24
[ 3.165039] usbcore: registered new interface driver zd1201
[ 3.170989] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.183044] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 4.189392] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 4.197723] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 4.214355] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 4.220764] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.228332] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.236297] usb usb1: Product: OMAP-EHCI Host Controller
[ 4.242248] usb usb1: Manufacturer: Linux 3.0.8-00216-g7e8957f ehci_hcd
[ 4.249542] usb usb1: SerialNumber: ehci-omap.0
[ 4.255126] hub 1-0:1.0: USB hub found
[ 4.259307] hub 1-0:1.0: 3 ports detected
[ 4.292602] usbcore: registered new interface driver cdc_acm
[ 4.298889] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.307800] Initializing USB Mass Storage driver...
[ 4.313293] usbcore: registered new interface driver usb-storage
[ 4.319976] USB Mass Storage support registered.
[ 4.325256] usbcore: registered new interface driver usbserial
[ 4.331726] usbserial: USB Serial Driver core
[ 4.538238] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 4.545837] android_usb gadget: Number of LUNs=1
[ 4.551025] lun0: LUN: removable file: (no medium)
[ 4.556579] android_usb gadget: android_usb ready
[ 4.561859] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 4.567596] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[ 4.575683] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.583190] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.591217] usb usb2: Product: MUSB HDRC host driver
[ 4.596771] usb usb2: Manufacturer: Linux 3.0.8-00216-g7e8957f musb-hcd
[ 4.604064] usb usb2: SerialNumber: musb-hdrc
[ 4.609252] hub 2-0:1.0: USB hub found
[ 4.613525] hub 2-0:1.0: 1 port detected
[ 4.618286] mousedev: PS/2 mouse device common for all mice
[ 4.625000] input: omap4-keypad as /devices/platform/omap/omap4-keypad/input/input0
[ 4.639129] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[ 4.651733] tm12xx_ts 2-004b: resetting device (reg 0x62)
[ 4.793365] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[ 4.801696] tm12xx_ts 2-004b: no button capabilities found
[ 4.809051] tm12xx_ts: product ID: TM1217 family:1 fw:9
[ 4.815185] input: syn_tm12xx_ts_1 as /devices/platform/omap/omap_i2c.2/i2c-2/2-004b/input/input1
[ 4.825988] tm12xx_ts 2-004b: device status: 0x0, no error
[ 4.833740] tm12xx_ts 3-004b: resetting device (reg 0x62)
[ 4.975982] tm12xx_ts 3-004b: no button capabilities found
[ 4.988311] CMA3000 Acclerometer : Revision 10
[ 4.993835] tm12xx_ts: product ID: TM1217 family:1 fw:9
[ 4.999786] input: syn_tm12xx_ts_2 as /devices/platform/omap/omap_i2c.3/i2c-3/3-004b/input/input2
[ 5.010589] tm12xx_ts 3-004b: device status: 0x0, no error
[ 5.042602] input: cma3000-acclerometer as /devices/virtual/input/input3
[ 5.089660] bh1780 3-0029: Ambient Light Sensor, Rev : 1
[ 5.095672] input: bh1780gli as /devices/virtual/input/input4
[ 5.103149] bmp085 4-0077: BMP085 ver. 1.0 found.
[ 5.108520] input: bmp085 as /devices/virtual/input/input5
[ 5.114776] bmp085 4-0077: Succesfully initialized bmp085!
[ 5.121154] twl6030_pwrbutton_probe: Enter
[ 5.126068] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input6
[ 5.139190] input: hmc5843 as /devices/virtual/input/input7
[ 5.145599] sfh7741_probe: Proximity sensor
[ 5.150390] input: sfh7741 as /devices/platform/sfh7741.1/input/input8
[ 5.161071] using rtc device, twl_rtc, for alarms
[ 5.166107] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 5.173339] i2c /dev entries driver
[ 5.177764] lirc_dev: IR Remote Control driver registered, major 248
[ 5.184936] IR NEC protocol handler initialized
[ 5.189941] IR RC5(x) protocol handler initialized
[ 5.195343] IR RC6 protocol handler initialized
[ 5.200347] IR JVC protocol handler initialized
[ 5.205383] IR Sony protocol handler initialized
[ 5.210479] IR RC5 (streamzap) protocol handler initialized
[ 5.216644] IR LIRC bridge handler initialized
[ 5.221649] Linux video capture interface: v2.00
[ 5.226898] dmm: probe base: fd300000, irq 145
[ 5.256683] twl6030_bci twl6030_bci: Battery Voltage at Bootup is 3632 mV
[ 5.269378] lm75 3-0048: hwmon0: sensor 'tmp105'
[ 6.269012] omap_i2c omap_i2c.4: controller timed out
[ 6.274871] ------------[ cut here ]------------
[ 6.279998] WARNING: at arch/arm/mach-omap2/omap_l3_noc.c:135 l3_interrupt_handler+0x2e0/0x380()
[ 6.289733] CUSTOM SRESP error with SOURCE:L4 PER2
[ 6.295074] Modules linked in:
[ 6.298553] Backtrace:
[ 6.301391] [<c0059224>] (dump_backtrace+0x0/0x110) from [<c0603490>] (dump_stack+0x18/0x1c)
[ 6.310729] r6:00000087 r5:c007d358 r4:c782bbe8 r3:c782a000
[ 6.317291] [<c0603478>] (dump_stack+0x0/0x1c) from [<c00a0cc0>] (warn_slowpath_common+0x5c/0x6c)
[ 6.327087] [<c00a0c64>] (warn_slowpath_common+0x0/0x6c) from [<c00a0d74>] (warn_slowpath_fmt+0x38/0x40)
[ 6.337585] r8:00000002 r7:c8834b48 r6:00080003 r5:c08002e4 r4:c8834b00
[ 6.345092] r3:00000009
[ 6.348175] [<c00a0d3c>] (warn_slowpath_fmt+0x0/0x40) from [<c007d358>] (l3_interrupt_handler+0x2e0/0x380)
[ 6.358825] r3:c0731260 r2:c0731164
[ 6.362976] [<c007d078>] (l3_interrupt_handler+0x0/0x380) from [<c00e8624>] (handle_irq_event_percpu+0x58/0x188)
[ 6.374206] [<c00e85cc>] (handle_irq_event_percpu+0x0/0x188) from [<c00e8798>] (handle_irq_event+0x44/0x64)
[ 6.384979] [<c00e8754>] (handle_irq_event+0x0/0x64) from [<c00eaf5c>] (handle_fasteoi_irq+0xa4/0x10c)
[ 6.395263] r6:0000002a r5:c07d3b8c r4:c07d3b40 r3:c004c4f0
[ 6.401824] [<c00eaeb8>] (handle_fasteoi_irq+0x0/0x10c) from [<c00e8148>] (generic_handle_irq+0x40/0x48)
[ 6.412292] r5:c004ceb0 r4:c07e2588
[ 6.416442] [<c00e8108>] (generic_handle_irq+0x0/0x48) from [<c004e060>] (asm_do_IRQ+0x60/0xc0)
[ 6.426086] [<c004e000>] (asm_do_IRQ+0x0/0xc0) from [<c00549c8>] (__irq_svc+0x48/0xe0)
[ 6.434844] Exception stack(0xc782bcd8 to 0xc782bd20)
[ 6.440429] bcc0: 00000080 00000028
[ 6.449493] bce0: 00000028 00000000 c78fd000 c07d2080 c78fd000 c782be20 0000601f c03c87f4
[ 6.458557] bd00: ffff6d22 c782bd3c ffff6d22 c782bd20 c03c8414 c03c8490 40000113 ffffffff
[ 6.467529] r7:00000001 r6:0000002a r5:fa240100 r4:ffffffff
[ 6.474182] [<c03c83fc>] (omap_i2c_wait_for_bb+0x0/0xb4) from [<c03c88bc>] (omap_i2c_xfer+0xc8/0x6b4)
[ 6.484344] r6:c78fd000 r5:c06323bc r4:c78fd0a8 r3:000002fc
[ 6.490936] [<c03c87f4>] (omap_i2c_xfer+0x0/0x6b4) from [<c03c5440>] (i2c_transfer+0xb8/0xec)
[ 6.500366] [<c03c5388>] (i2c_transfer+0x0/0xec) from [<c03c58dc>] (i2c_smbus_xfer+0x3bc/0x61c)
[ 6.510009] [<c03c5520>] (i2c_smbus_xfer+0x0/0x61c) from [<c03c5f98>] (i2c_default_probe+0xa0/0xdc)
[ 6.519927] [<c03c5ef8>] (i2c_default_probe+0x0/0xdc) from [<c03c6124>] (i2c_do_add_adapter+0x150/0x204)
[ 6.530364] r5:c7afd800 r4:c06339b6
[ 6.534545] [<c03c5fd4>] (i2c_do_add_adapter+0x0/0x204) from [<c03c6208>] (__process_new_driver+0x30/0x38)
[ 6.545227] [<c03c61d8>] (__process_new_driver+0x0/0x38) from [<c030b540>] (bus_for_each_dev+0x68/0x94)
[ 6.555541] [<c030b4d8>] (bus_for_each_dev+0x0/0x94) from [<c03c446c>] (i2c_for_each_dev+0x3c/0x50)
[ 6.565551] r7:c08285ac r6:c03c61d8 r5:c081f028 r4:c081f010
[ 6.572174] [<c03c4430>] (i2c_for_each_dev+0x0/0x50) from [<c03c451c>] (i2c_register_driver+0x74/0xbc)
[ 6.582397] r7:c002ef4c r6:00000000 r5:00000000 r4:c08285ac
[ 6.589050] [<c03c44a8>] (i2c_register_driver+0x0/0xbc) from [<c002ef68>] (sensors_lm75_init+0x1c/0x20)
[ 6.599426] r5:c003f6b0 r4:c083cb80
[ 6.603546] [<c002ef4c>] (sensors_lm75_init+0x0/0x20) from [<c004e628>] (do_one_initcall+0x3c/0x18c)
[ 6.613647] [<c004e5ec>] (do_one_initcall+0x0/0x18c) from [<c00083e4>] (kernel_init+0xb0/0x13c)
[ 6.623291] r9:00000000 r8:00000000 r7:00000013 r6:c00a54ec r5:c003f6b0
[ 6.630798] r4:c003f308
[ 6.633941] [<c0008334>] (kernel_init+0x0/0x13c) from [<c00a54ec>] (do_exit+0x0/0x720)
[ 6.642639] r5:c0008334 r4:00000000
[ 6.646850] ---[ end trace 4e0371974a6491d3 ]---
[ 6.651947] Master 0x0 MPU
[ 6.655609] L4 PER2 OPCODE 0x00000000
[ 31.666503] Master 0x0 MPU
[ 31.670196] L4 PER2 OPCODE 0x00000000
[ 31.675323] OMAP Watchdog Timer Rev 0x00: initial timeout 30 sec
[ 31.683532] device-mapper: uevent: version 1.0.3
[ 31.689025] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 31.698486] Bluetooth: HCI UART driver ver 2.2
[ 31.703460] Bluetooth: HCI H4 protocol initialized
[ 31.708801] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 31.715911] hdev c7b98000
[ 31.719879] HCI device registered (hdev c7b98000)
[ 31.722290] hci0 c7b98000
[ 31.722290] (stc): st_register(2)
[ 31.722290] (stc): chnl_id list empty :2
[ 31.722320] (stk) : st_kim_start
[ 31.745574] cpuidle: using governor ladder
[ 31.750427] cpuidle: using governor menu
[ 31.760162] Registered led device: omap4:green:debug0
[ 31.766021] Registered led device: omap4:green:debug1
[ 31.771728] Registered led device: omap4:green:debug2
[ 31.777770] Registered led device: omap4:green:debug3
[ 31.783477] Registered led device: omap4:green:debug4
[ 31.789276] Registered led device: omap4:blue:user
[ 31.794708] Registered led device: omap4:red:user
[ 31.800048] Registered led device: omap4:green:user
[ 31.806030] Registered led device: omap4:green:chrg
[ 31.812683] omap4430_sdp_display_probe:Enter
[ 31.819641] Registered led device: lcd-backlight
[ 31.825256] omap4430_sdp_display_probe:Exit
[ 31.827728] (stk) :ldisc_install = 1
[ 31.833984] omap4430_keypad_led_probe:Enter
[ 31.839080] Registered led device: keyboard-backlight
[ 31.845306] omap4430_keypad_led_probe:Exit
[ 31.854888] usbcore: registered new interface driver usbhid
[ 31.861114] usbhid: USB HID core driver
[ 31.865814] logger: created 256K log 'log_main'
[ 31.871002] logger: created 256K log 'log_events'
[ 31.876434] logger: created 256K log 'log_radio'
[ 31.881683] logger: created 256K log 'log_system'
[ 31.887084] thermal_governor_dev_register:Adding omap_ondie_governor governor
[ 31.895874] OMAP HSI: HSI driver version 0.4.3
[ 31.901031] OMAP HSI: Platform DRIVER register FAILED: -19
[ 31.907562] usbcore: registered new interface driver snd-usb-audio
[ 31.916534] SDP4430 SoC init
[ 31.950103] mmc0: new high speed DDR MMC card at address 0001
[ 31.957550] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 31.964599] mmcblk0: mmc0:0001 SEM08G 7.39 GiB
[ 31.969818] mmcblk0boot0: mmc0:0001 SEM08G partition 1 1.00 MiB
[ 31.977050] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 31.983856] mmcblk0boot1: mmc0:0001 SEM08G partition 2 1.00 MiB
[ 31.991394] asoc: null-codec-dai <-> Voice mapping ok
[ 31.998443] asoc: null-codec-dai <-> Tones mapping ok
[ 32.005340] asoc: null-codec-dai <-> Vibra mapping ok
[ 32.011688] asoc: null-codec-dai <-> MODEM mapping ok
[ 32.017944] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 32.025695] Alternate GPT is invalid, using primary GPT.
[ 32.025878] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 32.026916] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 32.028411] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[ 32.029846] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[ 32.030548] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 32.031188] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 32.031860] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 32.032531] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 32.033203] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 32.033874] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 32.034545] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 32.035278] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 32.035949] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 32.036590] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 32.037231] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 32.038879] input: SDP4430 Headset Jack as /devices/platform/soc-audio/sound/card0/input9
[ 32.041412] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 32.041900] ALSA device list:
[ 32.041900] #0: TI OMAP4 Board
