Other Parts Discussed in Thread: OMAP3530
Dear Adeneo,
I have a question about the comment highlighted in the below file found in C:\WINCE600\PLATFORM\EVM_OMAP3530\SRC\BOOTLOADER\EBOOT\NAND\MAKEFILE.INC
What is that comment referring to and is it accurate? What action should the developer take?
# All rights reserved ADENEO EMBEDDED 2010
!if 0
; Copyright (c) 2007, 2008 BSQUARE Corporation. All rights reserved.
; Texas Instruments OMAP(TM) Platform Software
; (c) Copyright Texas Instruments, Incorporated. All Rights Reserved.
; Use of this software is controlled by the terms and conditions found
; in the license agreement under which this software has been supplied.
!endif
# Take xldr.nb0, ebootnd.nb0 and iplnand.nb0 (WM only) to generate raw files
# Boot ROM requires xldr to be preceeded with two words containing image
# size and destination address. The xldrtocnand.raw file contains these
# two words and is prepended to the xldr image.
# Note that boot ROM expects xldr to be copied into 4 consecutive blocks
# to support data redundancy. Blocks are 128K while xldr is only 16K
# so there will be gaps in each block. For ease of creating the image
# the xldr nb0 file has been configured to be a full 128K minus the
# table of contents.
_FILES=$(_PLATFORMROOT)\$(_TGTPLAT)\files
_SRC=$(_PLATFORMROOT)\$(_TGTPLAT)\src\bootloader\xldr\nand
_TGT=$(_RAWFILETGT)\$(WINCEDEBUG)
_BIN=$(_PLATFORMROOT)\$(_TGTPLAT)\bin
xldr_romimage_raw:
!if "$(NOLINK)" == ""
romimage $(ROMIMAGE_FLAGS) xldrnand.bib
# The OMAP boot ROM will not load the NAND XLDR unless some bytes are modified near the image start
$(_FILES)\fileset.exe $(_TGT)\xldrnand.nb0 0x4 0x3c 0xff
copy /Y $(_FILES)\Logo.bmp $(_TGT)\logo.nb0
!if "$(WINCEREL)"=="1"
xcopy /Q /I $(_TGT)\xldrnand.* $(_FLATRELEASEDIR)
xcopy /Q /I $(_TGT)\logo.nb0 $(_FLATRELEASEDIR)
!endif
!endif
copy /b $(_SRC)\xldrtocnand.raw + $(_TGT)\xldrnand.nb0 $(_TGT)\xldrnand.1block
copy /b $(_TGT)\xldrnand.1block + $(_TGT)\xldrnand.1block + $(_TGT)\xldrnand.1block + $(_TGT)\xldrnand.1block $(_TGT)\xldrnand.4blocks
del $(_TGT)\xldrnand.1block >nul
copy /b $(_TGT)\xldrnand.4blocks + $(_TGT)\ebootnd.nb0 $(_TGT)\OMAP35xx-nand.raw
copy /b $(_TGT)\OMAP35xx-nand.raw + $(_FILES)\Logo.bmp $(_TGT)\OMAP35xx-nand-logo.raw
del $(_TGT)\xldrnand.4blocks >nul
xcopy /Q /I $(_TGT)\*.raw $(_FLATRELEASEDIR)
!endif
!endif
