I am working at :
HW: DM8168 + vs daughter card.
SDK: dvrrdk 2.0.0.23
sorry, i am not familiar with sdk. I want connect links as as follows, but nothing display and stored.
my questions: 1、Is the connect ok? 2、 Which links i set wrong? What i should do? Thanks
| Capture (YUV422I) |
| 4 CH D1 60fps |
DEI
DEI-SC
422
SW Mosaic 0
dup
2 1 0
| | nsf
---------- + | | +-------IPCM3OUT(VPSS)------IPCM3IN(VID)----ENC-----IPCBITS_RTOSOUT(VID)-----IPCBITS_HLOSIN(HOST)----------FILEOUT
DISPLAY 1 DISPLAY 0
------------- ------------- <tied>
<SDTV> <On-Chip HDMI> --------- <VGA>
PAL/NTSC 1080p60 1080p60
log:
7887: SYSTEM: System Common Init in progress !!!
7887: SYSTEM: IPC init in progress !!!
7897: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
7899: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
7900: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
7902: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
7902: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
7903: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
7904: SYSTEM: Notify register to [DSP] line 0, event 12 ...
7904: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
7905: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
7905: SYSTEM: IPC init DONE !!!
7906: SYSTEM: Creating ListMP [HOST_IPC_OUT_28] in region 0 ...
7909: SYSTEM: Creating ListMP [HOST_IPC_IN_28] in region 0 ...
7910: SYSTEM: ListElem Shared Addr = 0x466d5e80
7911: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
7914: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
7915: SYSTEM: ListElem Shared Addr = 0x466ee780
7917: SYSTEM: Creating ListMP [HOST_IPC_OUT_23] in region 0 ...
7919: SYSTEM: Creating ListMP [HOST_IPC_IN_23] in region 0 ...
7921: SYSTEM: ListElem Shared Addr = 0x46707080
7922: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
7924: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
7926: SYSTEM: ListElem Shared Addr = 0x46726680
7927: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
7929: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
7931: SYSTEM: ListElem Shared Addr = 0x46745c80
7931: SYSTEM: System Common Init Done !!!
+++ Vcap_configVideoDecoder, 1917: deviceI2cInstId 2
CAPTURE: Detected video (720x288@50Hz, 1)!!!
TVP5158: 0x58: Downloading patch ...
TVP5158: 0x58: Downloading patch ... DONE !!!
TVP5158: 0x58: 5158:0002:0302
[m3vpss ] +++ System_displayCtrlInit, 353 VENC_A outputClk 148500
[m3vpss ] Vps_platformControl, 499 error!
[m3vpss ] 29476: CAPTURE: Create in progress !!!
[m3vpss ] 29507: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Pixel-mux Embedded Sync] !!!
[m3vpss ] CAPTURE::HEAPID:0 USED:192
[m3vpss ] 29576: CAPTURE: Create Done !!!
[m3vpss ] 29576: DEI : Create in progress !!!
[m3vpss ] +++ DeiLink_drvCreateFvidObj, 715: pObj->drvCreateArgs.numCh 4
[m3vpss ] 29712: DEI : Loading Up-scaling Co-effs
[m3vpss ] 29712: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] DEI:HEAPID:0 USED:64
[m3vpss ] DEI:HEAPID:1 USED:8064
[m3vpss ] 29712: DEI : Create Done !!!
[m3vpss ] 29713: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 17
[m3vpss ] 29885: SWMS : VipScReq is FALSE!!!
[m3vpss ] 29889: SWMS : Loading Up-scaling Co-effs ...
[m3vpss ] 29890: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 29890: SWMS : ******* Configuring clock 32 secs...
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 29
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data |
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format|
[m3vpss ] --------------------------------------------------------------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 704 x 480 | 1408 / 1408 | NON-TILED | 56, 85 | 360 x 240 | 3840 / 0 | NON-TILED | OFF | 0 | 422I |
[m3vpss ] 1 | 1 | 0, 0 | 704 x 480 | 1408 / 1408 | NON-TILED | 416, 85 | 360 x 240 | 3840 / 0 | NON-TILED | OFF | 0 | 422I |
[m3vpss ] 2 | 2 | 0, 0 | 704 x 480 | 1408 / 1408 | NON-TILED | 56, 325 | 360 x 240 | 3840 / 0 | NON-TILED | OFF | 0 | 422I |
[m3vpss ] 3 | 3 | 0, 0 | 704 x 480 | 1408 / 1408 | NON-TILED | 416, 325 | 360 x 240 | 3840 / 0 | NON-TILED | OFF | 0 | 422I |
[m3vpss ]
[m3vpss ] 29892: SWMS: Create Done !!!
[m3vpss ] 29895: DUP : Create Done !!!
[m3vpss ] 29895: NSF: Create in progress !!!
[m3vpss ]
[m3vpss ] *** UTILS: DM_TIMER[2] KHz = 27000 Khz ***
[m3vpss ]
[m3video] 29992: IPC_IN_M3 : Create in progress !!!
[m3video] 29992: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 29993: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3vpss ] NSF::HEAPID:0 USED:128
[m3video] +++ IpcInM3Link_create, 139: Id 10000002, inTskInfo.numQue 0
[m3vpss ] NSF::HEAPID:1 USED:4928
[m3video] 29993: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3vpss ] 29991: NSF: Create Done !!!
[m3video] +++ IpcInM3Link_create, 145: Id 20000000, inTskInfo.numQue 2
[m3vpss ] 29991: IPC_OUT_M3 : Create in progress !!!
[m3video] +++ IpcInM3Link_create, 161: Id 10000002, inTskInfo.numQue 2
[m3vpss ] 29992: IPC_OUT_M3 : Create Done !!!
[m3video] 29996: IPC_IN_M3 : Create Done !!!
[m3video] 29997: ENCODE: Create in progress ... !!!
[m3video] +++ EncLink_codecCreate, 1055: prevLinkId 10000002, prevLinkQueId 0, inTskInfo.numQue 2
[m3video] +++ EncLink_codecCreate, 1104: pObj->inQueInfo.numCh 1
[m3video] 30065: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 2000 Kbps ...
[host] IpcBitsInLink_tskMain:Entered
[host] 12319: IPC_BITS_IN : Create in progress !!!
[host] 12319: IPC_BITS_IN : ListMPOpen start !!!
[host] 12319: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_28] ...
12321: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_28] ...
[host] 12323: IPC_BITS_IN : ListMPOpen done !!!
[host] 12324: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 12324: IPC_BITS_IN : Create Done !!!
[m3vpss ] 30123: DISPLAY: Create in progress !!!
[m3video] ENCLINK_H264:HEAPID:0 USED:128712
[m3vpss ] vpsDdrvSetFmtIoctl,1555
[m3video] 30113: ENCODE: All CH Create ... DONE !!!
[m3vpss ] DisplayLink_drvSetFmt,658 status 0
[m3vpss ] 30124: DISPLAY: Create Done !!!
[m3vpss ] 30124: DISPLAY: Create in progress !!!
[m3video] ENCLINK:HEAPID:0 USED:128832
[m3vpss ] 30124: DISPLAY: 41: Field Separate Mode ENABLED for Que 0 !!!
[m3video] 30115: ENCODE: Create ... DONE !!!
[m3video] 30115: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] 30125: DISPLAY: Create Done !!!
[m3video] 30117: IPC_BITS_OUT : Create Done !!!
[m3vpss ] +++ DeiLink_tskMain,51 cmd 3003
[m3vpss ] 30131: DISPLAY: Start in progress !!!
[host] 12341: IPC_BITS_IN : Recevived 0 bitbufs !!!
[host] 12357: IPC_BITS_IN : Recevived 0 bitbufs !!!
[host] 12373: IPC_BITS_IN : Recevived 0 bitbufs !!!
[host] 12389: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30187: DISPLAY: Start Done !!!
[m3vpss ] +++ DisplayLink_tskRun,43 cmd 500
[m3vpss ] 30187: DISPLAY: HDDAC(BP0) : 35 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[host] 12405: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30187: DISPLAY: UNDERFLOW COUNT: HDMI(BP0) 1, HDDAC(BP0) 1, DVO2(BP1) 0, SDDAC(SEC1) 0
[m3vpss ] 30188: SYSTEM : Heap Free Space (System = 21216 bytes, SR0 = 14274432 bytes, FrmBuf = 268661632 bytes,
[m3vpss ] BitBuf = 87579392 bytes, Mbx = 10238 msgs)
[host] 12421: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30188: DISPLAY: Deque 1 frames
[m3vpss ] 30135: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30189: DISPLAY: Start in progress !!!
[m3vpss ] 30149: bios6 DISPLAY: Deque 0 frames
[host] 12437: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30163: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30178: bios6 DISPLAY: Deque 0 frames
[host] 12453: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30237: DISPLAY: Start Done !!!
[m3video] 30238:DECLINK::links_m3video/iva_dec/decLink_tsk.c:[31]::INTERNAL ERROR:-8
[m3video] Link create should be first cmd.Received Cmd:1
[m3vpss ] 30237: DISPLAY: SDDAC(SEC1): 20 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[host] 12469: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30184: bios6 DISPLAY: Deque 0 frames
[m3vpss ] +++ DeiLink_tskMain,51 cmd 1
[m3vpss ] 30241: SWMS: Start in Progress !!!
[m3vpss ] 30241: SWMS: Start Done !!!
[m3vpss ] +++ SwMsLink_tskRun,41 cmd 500
[m3vpss ] 30241: CAPTURE: Start in progress !!!
[m3vpss ] 30241: CAPTURE: Start Done !!!
[m3vpss ] 30193: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30252: DISPLAY: Deque 1 frames
[m3vpss ] 30199: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30207: bios6 DISPLAY: Deque 0 frames
[host] 12485: IPC_BITS_IN : Recevived 0 bitbufs !!!
[host] 12501: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30222: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30228: bios6 DISPLAY: Deque 0 frames
[host] 12517: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30237: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30251: bios6 DISPLAY: Deque 0 frames
[host] 12533: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30258: bios6 DISPLAY: Deque 0 frames
[host] 12549: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30266: bios6 DISPLAY: Deque 0 frames
[host] 12565: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] 30281: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30287: bios6 DISPLAY: Deque 0 frames
[host] 12581: IPC_BITS_IN : Recevived 0 bitbufs !!!
[m3vpss ] +++ DupLink_tskMain,307 cmd 4
[m3vpss ] DupLink_drvProcessFrames in !!!
[m3vpss ] +++ SwMsLink_getFullFrames,275 in
[m3vpss ] +++ DupLink_drvProcessFrames,141 System_getLinksFullFrames pObj->inFrameList.numFrames 1
[m3vpss ] 30294: DUP: Processing 1 frames !!!
[m3vpss ] 30294: DUP: Processing of 1 frames done !!!
[m3vpss ] +++ NsfLink_tskRun,40 cmd 4
[m3vpss ] 30294: NSF: Processing 1 frames !!!
[m3vpss ] 30348: NSF: Noise Filtering 1 frames !!!
[m3vpss ] +++ DisplayLink_tskRun,43 cmd 4
[m3vpss ] 30297: bios6 DISPLAY: Deque 0 frames
[m3vpss ] 30351: DISPLAY: Queue 538976288 frames
found best resolution: 1920x1080 (28)
Extension block present db 2 23
84
Extension block present db 1 23
84
Extension block present db 3 23
84
84
[host] 13059: IPC_BITS_IN : Recevived 6 bitbufs !!!
[m3video] 30359: IPC_IN_M3 : Recevived 1 frames !!!
[m3vpss ] 30358: NSF: Noise Filtering of 1 frames Done !!!
[m3vpss ] 30358: NSF: No frames available for filtering !!!
[m3vpss ] 30305: NSF: Processing of 1 frames done !!!
[m3video] Channel:0 inputframerate:30 targetfps:30
[m3video] 30374: IPC_IN_M3 : Recevived 0 frames !!!
[m3vpss ] 30358: IPC_OUT_M3 : Received 1 frames !!!
[m3video] 30374: IPC_IN_M3 : Releasing 1 frames !!!
[m3vpss ] 30359: IPC_OUT_M3 : Releasing 0 frames !!!
[m3video] 30375: IPC_BITS_OUT : Received 1 bitbufs !!!
[m3video] 30375: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30311: bios6 DISPLAY: Deque 0 frames
[m3video] 30390: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] +++ CaptureLink_tskRun,67 cmd 4
[m3video] 30390: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30368: CAPTURE: Fields = 0 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[m3video] 30406: IPC_BITS_OUT : Received Notify !!!
[m3video] 30406: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3video] 30422: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30317: bios6 DISPLAY: Deque 0 frames
[m3video] 30423: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30371: DISPLAY: Queue 538976288 frames
[m3video] 30423: IPC_IN_M3 : Recevived 1 frames !!!
[m3vpss ] 30375: IPC_OUT_M3 : Received Notify !!!
[m3video] 30439: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30375: IPC_OUT_M3 : Releasing 1 frames !!!
[m3video] 30440: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30375: NSF: Returned 1 frames to NF channels !!!
[m3video] 30441: IPC_IN_M3 : Recevived 0 frames !!!
[m3video] 30441: IPC_IN_M3 : Releasing 1 frames !!!
[m3vpss ] 30378: DISPLAY: Deque 1 frames
[m3video] 30442: IPC_BITS_OUT : Received 1 bitbufs !!!
[m3vpss ] 30325: bios6 DISPLAY: Deque 0 frames
[m3video] 30442: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3video] 30454: IPC_BITS_OUT : Received Notify !!!
[m3video] 30455: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30382: CAPTURE: Dequeued 4 frames !!!
[m3video] 30470: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] +++ DeiLink_tskMain,51 cmd 4
[m3video] 30470: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30383: DEI : Received 4 IN frames !!!
[m3video] 30486: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30383: DEI : Submitting 4 frames !!!
[m3video] 30487: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30390: DEI : Completed 4 frames !!!
[m3video] 30489: IPC_IN_M3 : Recevived 1 frames !!!
[m3vpss ] 30390: DEI : Released 4 IN frames !!!
[m3video] 30502: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30390: CAPTURE: Queued back 4 frames !!!
[m3video] 30505: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30391: DEI : Submitting 0 frames !!!
[m3video] 30506: IPC_IN_M3 : Recevived 0 frames !!!
[m3vpss ] 30391: IPC_OUT_M3 : Received Notify !!!
[m3video] 30507: IPC_IN_M3 : Releasing 1 frames !!!
[m3vpss ] 30391: IPC_OUT_M3 : Releasing 0 frames !!!
[m3video] 30507: IPC_BITS_OUT : Received 1 bitbufs !!!
[m3video] 30508: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30339: bios6 DISPLAY: Deque 0 frames
[m3video] 30518: IPC_BITS_OUT : Received Notify !!!
[m3video] 30518: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30399: CAPTURE: Dequeued 4 frames !!!
[m3video] 30534: IPC_BITS_OUT : Received Notify !!!
[m3video] 30534: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30400: DEI : Received 4 IN frames !!!
[m3video] 30551: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30400: DEI : Submitting 4 frames !!!
[host] 13075: IPC_BITS_IN : Recevived 0 bitbufs !!!
[host] 13398: IPC_BITS_IN : Recevived 0 bitbufs !!!
[host] IPC_BITSINLINK:!WARNING!.Commands not being processed by link.TimeSinceLastAlloc:160,TimeSinceLastFree:13219 [m3video] 30553: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3video] 30554: IPC_IN_M3 : Recevived 1 frames !!!
[m3vpss ] 30349: bios6 DISPLAY: Deque 0 frames
[m3video] 30567: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30406: DEI : Completed 4 frames !!!
[m3video] 30568: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30406: DEI : Released 4 IN frames !!!
[m3video] 30570: IPC_IN_M3 : Recevived 0 frames !!!
[m3vpss ] 30406: CAPTURE: Queued back 4 frames !!!
[m3video] 30572: IPC_IN_M3 : Releasing 1 frames !!!
[m3vpss ] 30407: DEI : Submitting 0 frames !!!
[m3video] 30573: IPC_BITS_OUT : Received 1 bitbufs !!!
[m3video] 30573: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3video] 30583: IPC_BITS_OUT : Received Notify !!!
[m3video] 30584: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3video] 30599: IPC_BITS_OUT : Received Notify !!!
[m3vpss ] 30353: DUP: Processing 1 frames !!!
[m3video] 30600: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30353: DUP: Processing of 1 frames done !!!
[m3video] 30616: IPC_BITS_OUT : Received Notify !!!
[m3video] 30618: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30354: NSF: Processing 1 frames !!!
[m3video] 30622: IPC_IN_M3 : Recevived 1 frames !!!
[m3vpss ] 30408: NSF: Noise Filtering 1 frames !!!
[m3video] 30631: IPC_BITS_OUT : Received Notify !!!
[m3video] 30632: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30354: SWMS: Processing 4 frames !!!
[m3video] 30638: IPC_IN_M3 : Recevived 0 frames !!!
[m3vpss ] 30354: SWMS: Processing of 4 frames done !!!
[m3video] 30640: IPC_IN_M3 : Releasing 1 frames !!!
[m3video] 30640: IPC_BITS_OUT : Received 1 bitbufs !!!
[m3vpss ] 30355: bios6 DISPLAY: Deque 0 frames
[m3video] 30641: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30410: DISPLAY: Queue 538976288 frames
[m3video] 30647: IPC_BITS_OUT : Received Notify !!!
[m3video] 30648: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3video] 30663: IPC_BITS_OUT : Received Notify !!!
[m3video] 30664: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30416: CAPTURE: Dequeued 4 frames !!!
[m3video] 30679: IPC_BITS_OUT : Received Notify !!!
[m3video] 30680: IPC_BITS_OUT : Releasing 0 bitbufs !!!
[m3vpss ] 30417: DEI : Received 4 IN frames !!!
