Hi All
I am working on customized board based on AM3517evm.
I am using PSP 04.02.00.07, i have successfully modified the code of board-am3517evm.c and included driver for SX8652 in kernel.
During boot time my code gets stuck at calibration of touchscreen, as shown following, i am not able to understand a reason for this:
U-Boot 2010.06 (Apr 02 2012 - 12:13:51)
OMAP34xx/35xx-GP ES1.0, CPU-OPP2 L3-165MHz
AM3517EVM Board + LPDDR/NAND
I2C: ready
DRAM: 256 MiB
NAND: HW ECC [Kernel/FS layout] selected
No NAND device found!!!
0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Die ID #62aa0001000000000160ae2c05015012
Net: davinci_emac_initialize
Ethernet PHY: GENERIC @ 0x00
DaVinci EMAC
Hit any key to stop autoboot: 0
AM3517_EVM # boot
No MMC card found
Booting from tftpboot ...
BOOTP broadcast 1
DHCP client bound to address 10.0.0.13
Using DaVinci EMAC device
TFTP from server 10.0.0.11; our IP address is 10.0.0.13
Filename 'uImage'.
Load address: 0x83000000
Loading: #################################################################
done
Bytes transferred = 3038428 (2e5cdc hex)
## Booting kernel from Legacy Image at 83000000 ...
Image Name: Linux-2.6.37
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3038364 Bytes = 2.9 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 2.6.37 (root@analinearpc-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #3 Mon Apr 2 15:33:42 IST 2012
[ 0.000000] CPU: ARMv7 Processor [411fc087] revision 7 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3517/AM3517 EVM
[ 0.000000] Reserving 4194304 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM3517 ES1.1 (l2cache iva sgx neon isp )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x10000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 31488
[ 0.000000] Kernel command line: mem=128M console=ttyO2,115200n8 noinitrd rw root=/dev/nfs nfsroot=10.0.0.11:/workdir/filesysm,nolock ip=dhcp rootdelay=3
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 124MB = 124MB total
[ 0.000000] Memory: 112552k/112552k available, 18520k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc003a000 ( 200 kB)
[ 0.000000] .text : 0xc003a000 - 0xc05a1984 (5535 kB)
[ 0.000000] .data : 0xc05a2000 - 0xc0759b20 (1759 kB)
[ 0.000000] NR_IRQS:375
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/96/600 MHz
[ 0.000000] omap_hwmod: i2c1: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c2: softreset failed (waited 10000 usec)
[ 0.000000] omap_hwmod: i2c3: softreset failed (waited 10000 usec)
[ 0.000000] Reprogramming SDRC clock to 96000000 Hz
[ 0.000000] dpll3_m2_clk rate change failed: -22
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] GPMC revision 5.0
[ 0.000000] Trying to install interrupt handler for IRQ368
[ 0.000000] Trying to install interrupt handler for IRQ369
[ 0.000000] Trying to install interrupt handler for IRQ370
[ 0.000000] Trying to install interrupt handler for IRQ371
[ 0.000000] Trying to install interrupt handler for IRQ372
[ 0.000000] Trying to install interrupt handler for IRQ373
[ 0.000000] Trying to install interrupt handler for IRQ374
[ 0.000000] Trying to install type control for IRQ375
[ 0.000000] Trying to set irq flags for IRQ375
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Lock dependency validator: Copyright (c) 2006 Red Hat, Inc., Ingo Molnar
[ 0.000000] ... MAX_LOCKDEP_SUBCLASSES: 8
[ 0.000000] ... MAX_LOCK_DEPTH: 48
[ 0.000000] ... MAX_LOCKDEP_KEYS: 8191
[ 0.000000] ... CLASSHASH_SIZE: 4096
[ 0.000000] ... MAX_LOCKDEP_ENTRIES: 16384
[ 0.000000] ... MAX_LOCKDEP_CHAINS: 32768
[ 0.000000] ... CHAINHASH_SIZE: 16384
[ 0.000000] memory used by lock dependency info: 3951 kB
[ 0.000000] per task-struct memory footprint: 2304 bytes
[ 0.000000] Calibrating delay loop... 601.84 BogoMIPS (lpj=2351104)
[ 0.000000] pid_max: default: 32768 minimum: 301
[ 0.000000] Security Framework initialized
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] regulator: core version 0.5
[ 0.000000] regulator: dummy:
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] ------------[ cut here ]------------
[ 0.000000] WARNING: at arch/arm/mach-omap2/pm.c:94 _init_omap_device+0x84/0xa4()
[ 0.000000] _init_omap_device: could not find omap_hwmod for iva
[ 0.000000] Modules linked in:
[ 0.000000] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c00713fc>] (warn_slowpath_common+0x4c/0x64)
[ 0.000000] [<c00713fc>] (warn_slowpath_common+0x4c/0x64) from [<c0071494>] (warn_slowpath_fmt+0x2c/0x3c)
[ 0.000000] [<c0071494>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0051a14>] (_init_omap_device+0x84/0xa4)
[ 0.000000] [<c0051a14>] (_init_omap_device+0x84/0xa4) from [<c0010110>] (omap2_common_pm_init+0x2c/0x10c)
[ 0.000000] [<c0010110>] (omap2_common_pm_init+0x2c/0x10c) from [<c003a3b8>] (do_one_initcall+0xc8/0x1a0)
[ 0.000000] [<c003a3b8>] (do_one_initcall+0xc8/0x1a0) from [<c0008690>] (kernel_init+0x94/0x14c)
[ 0.000000] [<c0008690>] (kernel_init+0x94/0x14c) from [<c0045590>] (kernel_thread_exit+0x0/0x8)
[ 0.000000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.000000] OMAP GPIO hardware version 2.5
[ 0.000000] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.000000] Display initialized successfully
[ 0.000000] _omap_mux_init_gpio: Multiple gpio paths (2) for gpio126
[ 0.000000] Found NOR on CS1
[ 0.000000] Registering NOR on CS1
[ 0.000000] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.000000] OMAP DMA hardware revision 4.0
[ 0.140716] bio: create slab <bio-0> at 0
[ 0.151000] SCSI subsystem initialized
[ 0.169097] usbcore: registered new interface driver usbfs
[ 0.170989] usbcore: registered new interface driver hub
[ 0.172698] usbcore: registered new device driver usb
[ 0.180694] omap_device: omap_i2c.1: new worst case activate latency 0: 61035
[ 0.180908] omap_i2c omap_i2c.1: bus 1 rev3.12 at 400 kHz
[ 0.185180] omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
[ 0.185668] omap_i2c omap_i2c.2: bus 2 rev3.12 at 400 kHz
[ 0.190856] pca953x 2-0021: failed reading register
[ 0.191040] pca953x: probe of 2-0021 failed with error -121
[ 0.191253] omap_device: omap_i2c.2: new worst case deactivate latency 0: 61035
[ 0.191680] omap_i2c omap_i2c.3: bus 3 rev3.12 at 400 kHz
[ 0.195281] tca6416-keypad 3-0020: tca6416_read_reg failed, reg: 1, error: -121
[ 0.195404] tca6416-keypad: probe of 3-0020 failed with error -121
[ 0.197021] pca953x 3-0021: failed reading register
[ 0.197082] pca953x: probe of 3-0021 failed with error -121
[ 0.205810] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.211669] Switching to clocksource 32k_counter
[ 0.381591] musb-hdrc: version 6.0, host, debug=0
[ 0.382293] musb-hdrc musb-hdrc.0: degrade from otg to host-only mode
[ 0.382354] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.384460] <6>Waiting for PHY clock good...
[ 0.401336] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 0.403442] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[ 0.404632] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.404663] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.404693] usb usb1: Product: MUSB HDRC host driver
[ 0.404693] usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
[ 0.404724] usb usb1: SerialNumber: musb-hdrc.0
[ 0.411682] hub 1-0:1.0: USB hub found
[ 0.412109] hub 1-0:1.0: 1 port detected
[ 0.417938] musb-hdrc musb-hdrc.0: USB Host mode controller at c8810000 using DMA, IRQ 71
[ 0.420440] NET: Registered protocol family 2
[ 0.421386] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.424011] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.424377] TCP bind hash table entries: 4096 (order: 5, 180224 bytes)
[ 0.426696] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.426818] TCP reno registered
[ 0.426849] UDP hash table entries: 64 (order: 0, 6144 bytes)
[ 0.427276] UDP-Lite hash table entries: 64 (order: 0, 6144 bytes)
[ 0.428558] NET: Registered protocol family 1
[ 0.430908] RPC: Registered udp transport module.
[ 0.430938] RPC: Registered tcp transport module.
[ 0.430969] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.432464] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.436065] omap_init_opp_table: no hwmod or odev for iva, [9] cannot add OPPs.
[ 0.443237] AM3517 Linux PSP version 04.02.00.07 (AM3517EVM)
[ 0.616149] VFS: Disk quotas dquot_6.5.2
[ 0.616302] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.619964] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.621307] msgmni has been set to 219
[ 0.627502] io scheduler noop registered
[ 0.627563] io scheduler deadline registered
[ 0.627838] io scheduler cfq registered (default)
[ 0.696655] OMAP DSS rev 2.0
[ 0.696838] omapdss supply vdds_dsi not found, using dummy regulator
[ 0.697540] OMAP DISPC rev 3.0
[ 0.697570] omapdss supply vdda_dac not found, using dummy regulator
[ 0.697723] OMAP VENC rev 2
[ 0.699462] OMAP DSI rev 1.0
[ 1.027984] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.040344] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.043151] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.045074] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.936279] console [ttyO2] enabled
[ 2.001220] brd: module loaded
[ 2.033599] loop: module loaded
[ 2.045867] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.053253] physmap platform flash device: 08000000 at 08000000
[ 2.066986] physmap-flash physmap-flash.0: map_probe failed
[ 2.081665] omap2-nand driver initializing
[ 2.086669] No NAND device found.
[ 2.090515] No NAND device found.
[ 2.141723] davinci_mdio davinci_mdio: davinci mdio revision 1.5
[ 2.147949] davinci_mdio davinci_mdio: detected phy mask fffffffe
[ 2.158233] davinci_mdio: probed
[ 2.161621] davinci_mdio davinci_mdio: phy[0]: device ffffffff:00, driver SMSC LAN8710/LAN8720
[ 2.171875] vcan: Virtual CAN interface driver
[ 2.176635] CAN device driver interface
[ 2.180694] TI High End CAN Controller Driver 0.7
[ 2.189910] ti_hecc ti_hecc: device registered (reg_base=c8890000, irq=24)
[ 2.200805] usbcore: registered new interface driver cdc_ether
[ 2.207977] usbcore: registered new interface driver dm9601
[ 2.213928] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.221160] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 3.235351] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.241638] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 3.250274] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.266723] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.273284] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.280456] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.288024] usb usb2: Product: OMAP-EHCI Host Controller
[ 3.293609] usb usb2: Manufacturer: Linux 2.6.37 ehci_hcd
[ 3.299285] usb usb2: SerialNumber: ehci-omap.0
[ 3.309326] hub 2-0:1.0: USB hub found
[ 3.313568] hub 2-0:1.0: 3 ports detected
[ 3.353820] Initializing USB Mass Storage driver...
[ 3.360198] usbcore: registered new interface driver usb-storage
[ 3.366577] USB Mass Storage support registered.
[ 3.372619] usbcore: registered new interface driver usbtest
[ 3.383148] mice: PS/2 mouse device common for all mice
[ 3.393707] get_pendown_state from pdata: c005b6f8
[ 3.399169] sx8652 spi1.0: touchscreen, irq 225
[ 3.406188] input: SX8652 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input0
[ 3.433319] rtc-s35390a 1-0030: error resetting chip
[ 3.451843] rtc-s35390a: probe of 1-0030 failed with error -5
[ 3.458953] i2c /dev entries driver
[ 3.470855] Linux video capture interface: v2.00
[ 3.478881] usbcore: registered new interface driver uvcvideo
[ 3.484863] USB Video Class driver (v1.0.0)
[ 3.489318] vpfe_init
[ 3.492645] vpfe-capture vpfe-capture: v4l2 device registered
[ 3.502044] vpfe-capture vpfe-capture: video device registered
[ 3.511535] tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
[ 3.519165] omap_device: omap_i2c.3: new worst case activate latency 0: 122070
[ 3.527069] tvp514x 3-005c: Write: retry ... 0
[ 3.548187] tvp514x 3-005c: Write: retry ... 1
[ 3.571533] tvp514x 3-005c: Write: retry ... 2
[ 3.594970] tvp514x 3-005c: Write: retry ... 3
[ 3.618377] tvp514x 3-005c: Write: retry ... 4
[ 3.641815] tvp514x 3-005c: Write: retry ... 5
[ 3.665252] tvp514x 3-005c: Write failed. Err[-121]
[ 3.670349] tvp514x 3-005c: Unable to turn on decoder
[ 3.675872] tvp514x 3-005c: Read: retry ... 0
[ 3.696502] tvp514x 3-005c: Read: retry ... 1
[ 3.720520] tvp514x 3-005c: Read: retry ... 2
[ 3.743408] tvp514x 3-005c: Read: retry ... 3
[ 3.766815] tvp514x 3-005c: Read: retry ... 4
[ 3.790252] tvp514x 3-005c: Read: retry ... 5
[ 3.813690] tvp514x 3-005c: Unable to query std
[ 3.818420] vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered
[ 3.827331] vpfe_register_ccdc_device: DM6446 CCDC
[ 3.832702] DM6446 CCDC is registered with vpfe.
[ 3.839385] omap_device: omap_wdt.-1: new worst case activate latency 0: 30517
[ 3.849761] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.856231] omap_device: omap_wdt.-1: new worst case deactivate latency 0: 30517
[ 3.884063] usbcore: registered new interface driver usbhid
[ 3.889892] usbhid: USB HID core driver
[ 3.899139] usbcore: registered new interface driver snd-usb-audio
[ 3.913238] OMAP3517 / AM3517 EVM SoC init
[ 3.920684] AIC23 Audio Codec 0.1
[ 3.924896] tlv320aic23_write cannot write 000 to register R15
[ 3.932006] tlv320aic23_write cannot write 047 to register R6
[ 3.938293] tlv320aic23_write cannot write 004 to register R5
[ 3.945800] tlv320aic23_write cannot write 117 to register R0
[ 3.954223] tlv320aic23_write cannot write 117 to register R1
[ 3.960510] tlv320aic23_write cannot write 010 to register R4
[ 3.966796] tlv320aic23_write cannot write 070 to register R2
[ 3.973083] tlv320aic23_write cannot write 070 to register R3
[ 3.979400] tlv320aic23_write cannot write 001 to register R9
[ 3.991302] asoc: tlv320aic23-hifi <-> omap-mcbsp-dai.0 mapping ok
[ 4.007629] ALSA device list:
[ 4.010925] #0: am3517evm
[ 4.013824] oprofile: hardware counters not available
[ 4.019134] oprofile: using timer interrupt.
[ 4.024658] TCP cubic registered
[ 4.028015] Initializing XFRM netlink socket
[ 4.032806] NET: Registered protocol family 17
[ 4.037628] NET: Registered protocol family 15
[ 4.042358] can: controller area network core (rev 20090105 abi 8)
[ 4.049438] NET: Registered protocol family 29
[ 4.054199] can: raw protocol (rev 20090105)
[ 4.058898] can: broadcast manager protocol (rev 20090105 t)
[ 4.065643] Registering the dns_resolver key type
[ 4.071472] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 4.082153] ThumbEE CPU extension supported.
[ 4.103607] Power Management for TI OMAP3.
[ 4.161315] clock: disabling unused clocks to save power
[ 4.288940] Console: switching to colour frame buffer device 160x50
[ 4.317840] omapdss DPI: Could not find exact pixel clock. Requested 68900 kHz, got 72000 kHz
[ 4.393035] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 4.400360] omap_vout omap_vout: Buffer Size = 3686400
[ 4.411560] omap_vout omap_vout: : registered and initialized video device 1
[ 4.419250] omap_vout omap_vout: Buffer Size = 3686400
[ 4.428985] omap_vout omap_vout: : registered and initialized video device 2
[ 4.947479] davinci_mdio davinci_mdio: resetting idled controller
[ 4.955108] net eth0: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=ffffffff:00, id=7c0f1)
[ 5.969818] Sending DHCP requests ..
[ 9.954650] PHY: ffffffff:00 - Link is Up - 100/Full
[ 13.290069] ., OK
[ 13.798370] IP-Config: Got DHCP answer from 0.0.0.0, my address is 10.0.0.13
[ 13.808074] IP-Config: Complete:
[ 13.811279] device=eth0, addr=10.0.0.13, mask=255.255.255.0, gw=10.0.0.1,
[ 13.818847] host=10.0.0.13, domain=, nis-domain=(none),
[ 13.824798] bootserver=0.0.0.0, rootserver=10.0.0.11, rootpath=
[ 13.837158] Waiting 3sec before mounting root device...
[ 17.115509] VFS: Mounted root (nfs filesystem) on device 0:14.
[ 17.122222] Freeing init memory: 200K
INIT: version 2.86 booting
Please wait: booting...
Starting udev
[ 20.239410] udevd (629): /proc/629/oom_adj is deprecated, please use /proc/629/oom_score_adj instead.
Root filesystem already rw, not remounting
Caching udev devnodes
Populating dev cachemv: cannot rename '/tmp/devices': No such file or directory
ALSA: Restoring mixer settings...
No state is present for card am3517evm
NOT configuring network interfaces: / is an NFS mount
Found hardware: "" "" "" "" ""
Hardware is initialized using a generic method
[ 47.797088] omap_device: omap_i2c.2: new worst case activate latency 0: 152587
[ 47.805175] tlv320aic23_write cannot write 014 to register R4
hwclock: can't open '/dev/misc/rtc': No such file or directory
Thu Jul 7 13:19:00 UTC 2011
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpd.
No SGX hardware, not starting PVR
Calibrating touchscreen (first time only)xres = 1280, yres = 800
After this i tried changing the filesystem, i changed the filesystem to Angstrom built from narcissus-angstrom
now my code dose not hang.. when touchscreen is touched it gives "division by zero error" every time, and when i try to recalibrate it shows some junk values and dose not wait for the crosshair to be touched, what can be the reason for such a case?
following are the boot messages with angstrom filesystem
U-Boot 2010.06 (Apr 03 2012 - 10:10:50)
I2C: ready
DRAM: 256 MiB
0 MiB
In: serial
Out: serial
Err: serial
DaVinci EMAC
AM3517_EVM # boot
No MMC card found
BOOTP broadcast 1
DHCP client bound to address 10.0.0.7
TFTP from server 10.0.0.5; our IP address is 10.0.0.7
Filename 'uImage'.
done
OK
Starting kernel ...
[ 0.000000] Linux version 2.6.37 (root@analinearpc-laptop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #4 Tue Apr 3 09:55:33 IST 2012
[ 0.000000] Kernel command line: mem=128M console=ttyO2,115200n8 noinitrd rw root=/dev/nfs nfsroot=10.0.0.5:/workdir/filesysm,nolock ip=dhcp rootdelay=3
[ 0.141021] bio: create slab <bio-0> at 0
[ 0.151214] SCSI subsystem initialized
[ 0.169342] usbcore: registered new interface driver usbfs
[ 0.171325] usbcore: registered new interface driver hub
[ 0.172943] usbcore: registered new device driver usb
[ 0.180908] omap_device: omap_i2c.1: new worst case activate latency 0: 61035
[ 0.181152] omap_i2c omap_i2c.1: bus 1 rev3.12 at 400 kHz
[ 0.185394] omap_device: omap_i2c.1: new worst case deactivate latency 0: 30517
[ 0.185882] omap_i2c omap_i2c.2: bus 2 rev3.12 at 400 kHz
[ 0.191070] pca953x 2-0021: failed reading register
[ 0.191284] pca953x: probe of 2-0021 failed with error -121
[ 0.191864] omap_i2c omap_i2c.3: bus 3 rev3.12 at 400 kHz
[ 0.195434] tca6416-keypad 3-0020: tca6416_read_reg failed, reg: 1, error: -121
[ 0.195556] tca6416-keypad: probe of 3-0020 failed with error -121
[ 0.197174] pca953x 3-0021: failed reading register
[ 0.197265] pca953x: probe of 3-0021 failed with error -121
[ 0.205963] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.211853] Switching to clocksource 32k_counter
[ 0.381530] musb-hdrc: version 6.0, host, debug=0
[ 0.382232] musb-hdrc musb-hdrc.0: degrade from otg to host-only mode
[ 0.382293] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[ 0.384368] <6>Waiting for PHY clock good...
[ 0.401519] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 0.403656] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[ 0.404846] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.404876] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.404907] usb usb1: Product: MUSB HDRC host driver
[ 0.404907] usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
[ 0.404937] usb usb1: SerialNumber: musb-hdrc.0
[ 0.411926] hub 1-0:1.0: USB hub found
[ 0.412322] hub 1-0:1.0: 1 port detected
[ 0.418121] musb-hdrc musb-hdrc.0: USB Host mode controller at c8810000 using DMA, IRQ 71
[ 0.420654] NET: Registered protocol family 2
[ 0.421630] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.424255] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.424621] TCP bind hash table entries: 4096 (order: 5, 180224 bytes)
[ 0.426940] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.427062] TCP reno registered
[ 0.427093] UDP hash table entries: 64 (order: 0, 6144 bytes)
[ 0.427520] UDP-Lite hash table entries: 64 (order: 0, 6144 bytes)
[ 0.428833] NET: Registered protocol family 1
[ 0.431213] RPC: Registered udp transport module.
[ 0.431243] RPC: Registered tcp transport module.
[ 0.431274] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.432769] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.436431] omap_init_opp_table: no hwmod or odev for iva, [9] cannot add OPPs.
[ 0.443664] AM3517 Linux PSP version 04.02.00.07 (AM3517EVM)
[ 0.616546] VFS: Disk quotas dquot_6.5.2
[ 0.616729] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.620391] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 0.621734] msgmni has been set to 219
[ 0.627960] io scheduler noop registered
[ 0.628021] io scheduler deadline registered
[ 0.628295] io scheduler cfq registered (default)
[ 0.696838] OMAP DSS rev 2.0
[ 0.697052] omapdss supply vdds_dsi not found, using dummy regulator
[ 0.697723] OMAP DISPC rev 3.0
[ 0.697753] omapdss supply vdda_dac not found, using dummy regulator
[ 0.697906] OMAP VENC rev 2
[ 0.699615] OMAP DSI rev 1.0
[ 1.028167] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.040496] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 72) is a OMAP UART0
[ 1.043304] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 73) is a OMAP UART1
[ 1.045257] omap_uart.2: ttyO2 at MMIO 0x49020000 (irq = 74) is a OMAP UART2
[ 1.929016] console [ttyO2] enabled
[ 1.993957] brd: module loaded
[ 2.026306] loop: module loaded
[ 2.038574] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.045959] physmap platform flash device: 08000000 at 08000000
[ 2.059631] physmap-flash physmap-flash.0: map_probe failed
[ 2.074371] omap2-nand driver initializing
[ 2.079498] No NAND device found.
[ 2.083190] No NAND device found.
[ 2.134063] davinci_mdio davinci_mdio: davinci mdio revision 1.5
[ 2.140350] davinci_mdio davinci_mdio: detected phy mask fffffffe
[ 2.150634] davinci_mdio: probed
[ 2.154022] davinci_mdio davinci_mdio: phy[0]: device ffffffff:00, driver SMSC LAN8710/LAN8720
[ 2.164337] vcan: Virtual CAN interface driver
[ 2.169097] CAN device driver interface
[ 2.173156] TI High End CAN Controller Driver 0.7
[ 2.182373] ti_hecc ti_hecc: device registered (reg_base=c8890000, irq=24)
[ 2.193206] usbcore: registered new interface driver cdc_ether
[ 2.200408] usbcore: registered new interface driver dm9601
[ 2.206359] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.213592] ehci-omap.0 supply hsusb0 not found, using dummy regulator
[ 3.227691] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 3.233947] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
[ 3.242584] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 3.259094] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 3.265655] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.272827] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.280395] usb usb2: Product: OMAP-EHCI Host Controller
[ 3.285980] usb usb2: Manufacturer: Linux 2.6.37 ehci_hcd
[ 3.291656] usb usb2: SerialNumber: ehci-omap.0
[ 3.301696] hub 2-0:1.0: USB hub found
[ 3.305938] hub 2-0:1.0: 3 ports detected
[ 3.346191] Initializing USB Mass Storage driver...
[ 3.352722] usbcore: registered new interface driver usb-storage
[ 3.358978] USB Mass Storage support registered.
[ 3.365051] usbcore: registered new interface driver usbtest
[ 3.375579] mice: PS/2 mouse device common for all mice
[ 3.386138] get_pendown_state from pdata: c005b6f8
[ 3.391601] sx8652 spi1.0: touchscreen, irq 225
[ 3.398620] input: SX8652 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input0
[ 3.425689] rtc-s35390a 1-0030: error resetting chip
[ 3.444305] rtc-s35390a: probe of 1-0030 failed with error -5
[ 3.451416] i2c /dev entries driver
[ 3.463287] Linux video capture interface: v2.00
[ 3.471313] usbcore: registered new interface driver uvcvideo
[ 3.477294] USB Video Class driver (v1.0.0)
[ 3.481750] vpfe_init
[ 3.485076] vpfe-capture vpfe-capture: v4l2 device registered
[ 3.494476] vpfe-capture vpfe-capture: video device registered
[ 3.503967] tvp514x 3-005c: tvp514x 3-005c decoder driver registered !!
[ 3.511596] omap_device: omap_i2c.3: new worst case activate latency 0: 122070
[ 3.519531] tvp514x 3-005c: Write: retry ... 0
[ 3.540557] tvp514x 3-005c: Write: retry ... 1
[ 3.563903] tvp514x 3-005c: Write: retry ... 2
[ 3.587341] tvp514x 3-005c: Write: retry ... 3
[ 3.610809] tvp514x 3-005c: Write: retry ... 4
[ 3.634185] tvp514x 3-005c: Write: retry ... 5
[ 3.657623] tvp514x 3-005c: Write failed. Err[-121]
[ 3.662689] tvp514x 3-005c: Unable to turn on decoder
[ 3.668243] tvp514x 3-005c: Read: retry ... 0
[ 3.688873] tvp514x 3-005c: Read: retry ... 1
[ 3.712829] tvp514x 3-005c: Read: retry ... 2
[ 3.735778] tvp514x 3-005c: Read: retry ... 3
[ 3.759185] tvp514x 3-005c: Read: retry ... 4
[ 3.782623] tvp514x 3-005c: Read: retry ... 5
[ 3.806060] tvp514x 3-005c: Unable to query std
[ 3.810791] vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered
[ 3.819671] vpfe_register_ccdc_device: DM6446 CCDC
[ 3.825012] DM6446 CCDC is registered with vpfe.
[ 3.831726] omap_device: omap_wdt.-1: new worst case activate latency 0: 61035
[ 3.842102] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 3.848571] omap_device: omap_wdt.-1: new worst case deactivate latency 0: 30517
[ 3.876342] usbcore: registered new interface driver usbhid
[ 3.882171] usbhid: USB HID core driver
[ 3.891418] usbcore: registered new interface driver snd-usb-audio
[ 3.905517] OMAP3517 / AM3517 EVM SoC init
[ 3.912994] AIC23 Audio Codec 0.1
[ 3.917205] tlv320aic23_write cannot write 000 to register R15
[ 3.924316] tlv320aic23_write cannot write 047 to register R6
[ 3.930572] tlv320aic23_write cannot write 004 to register R5
[ 3.938079] tlv320aic23_write cannot write 117 to register R0
[ 3.946472] omap_device: omap_i2c.2: new worst case deactivate latency 0: 91552
[ 3.954162] tlv320aic23_write cannot write 117 to register R1
[ 3.960449] tlv320aic23_write cannot write 010 to register R4
[ 3.966735] tlv320aic23_write cannot write 070 to register R2
[ 3.973052] tlv320aic23_write cannot write 070 to register R3
[ 3.979309] tlv320aic23_write cannot write 001 to register R9
[ 3.991241] asoc: tlv320aic23-hifi <-> omap-mcbsp-dai.0 mapping ok
[ 4.007659] ALSA device list:
[ 4.019165] oprofile: using timer interrupt.
[ 4.028045] Initializing XFRM netlink socket
[ 4.037658] NET: Registered protocol family 15
[ 4.042388] can: controller area network core (rev 20090105 abi 8)
[ 4.065612] Registering the dns_resolver key type
[ 4.071289] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 4.082000] ThumbEE CPU extension supported.
[ 4.103485] Power Management for TI OMAP3.
[ 4.161102] clock: disabling unused clocks to save power
[ 4.288604] Console: switching to colour frame buffer device 160x50
[ 4.317504] omapdss DPI: Could not find exact pixel clock. Requested 68900 kHz, got 72000 kHz
[ 4.393188] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 4.400512] omap_vout omap_vout: Buffer Size = 3686400
[ 4.411712] omap_vout omap_vout: : registered and initialized video device 1
[ 4.419433] omap_vout omap_vout: Buffer Size = 3686400
[ 4.429199] omap_vout omap_vout: : registered and initialized video device 2
[ 4.947662] davinci_mdio davinci_mdio: resetting idled controller
[ 4.955322] net eth0: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=ffffffff:00, id=7c0f1)
[ 5.970001] Sending DHCP requests ..
[ 8.954833] PHY: ffffffff:00 - Link is Up - 100/Full
[ 13.704315] ., OK
[ 14.212646] IP-Config: Got DHCP answer from 0.0.0.0, my address is 10.0.0.7
[ 14.222534] IP-Config: Complete:
[ 14.225738] device=eth0, addr=10.0.0.7, mask=255.255.255.0, gw=10.0.0.1,
[ 14.233245] host=10.0.0.7, domain=, nis-domain=(none),
[ 14.239105] bootserver=0.0.0.0, rootserver=10.0.0.5, rootpath=
[ 14.250518] Waiting 3sec before mounting root device...
[ 17.737213] VFS: Mounted root (nfs filesystem) on device 0:14.
[ 17.743927] Freeing init memory: 200K
Starting udev
[ 21.917663] udevd (633): /proc/633/oom_adj is deprecated, please use /proc/633/oom_score_adj instead.
Starting portmap daemon: portmap.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Wed Feb 1 07:01:00 GMT 2012
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting lcd4linux: lcd4linux.
[ ok ]rting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Starting GPE display manager: gpe-dm
| | | __ | ---'| '--.| .-'| | |
The Angstrom Distribution am3517-evm ttyO2
Angstrom 2010.7-test-20110311 am3517-evm ttyO2
am3517-evm login: root
root@am3517-evm:~# cd /
root@am3517-evm:/# [ 72.110168] Division by zero in kernel.
[ 72.114318] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.123352] Division by zero in kernel.
[ 72.127410] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.135955] Division by zero in kernel.
[ 72.139953] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.148529] Division by zero in kernel.
[ 72.152526] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.161071] Division by zero in kernel.
[ 72.165100] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.173614] Division by zero in kernel.
[ 72.177581] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.186096] Division by zero in kernel.
[ 72.190093] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.198608] Division by zero in kernel.
[ 72.202606] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.211181] Division by zero in kernel.
[ 72.215179] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.223693] Division by zero in kernel.
[ 72.227691] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.236175] Division by zero in kernel.
[ 72.240203] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.248718] Division by zero in kernel.
[ 72.252716] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
[ 72.261260] Division by zero in kernel.
[ 72.265258] [<c004a348>] (unwind_backtrace+0x0/0xec) from [<c01f58c4>] (Ldiv0+0x8/0x10)
root@am3517-evm:/# ts_test
-sh: ts_test: not found
root@am3517-evm:/# ts_calibrate
selected device is not a touchscreen I understand
Took 2 samples...
Top left : X = -548867996 Y = -548867877
Took 2 samples...
Top right : X = -548867996 Y = -548867877
Took 2 samples...
Bot right : X = -548867996 Y = -548867877
Took 2 samples...
Bot left : X = -548867996 Y = -548867877
Took 2 samples...
Center : X = -548867996 Y = -548867877
-7.359375 -5.433594 5.441406
-4.601562 -3.398438 3.402344
Calibration constants: -482304 -356096 356608 -301568 -222720 222976 65536
root@am3517-evm:/#
Took 2 samples...
Top left : X = -547258268 Y = -547258149
Took 2 samples...
Top right : X = -547258268 Y = -547258149
Took 2 samples...
Bot right : X = -547258268 Y = -547258149
Took 2 samples...
Bot left : X = -547258268 Y = -547258149
Took 2 samples...
Center : X = -547258268 Y = -547258149
-0.409406 -0.000019 0.000018
-0.255879 -0.000012 0.000011
Calibration constants: -26830 -1 1 -16769 0 0 65536
Please help me with this
Thanks in advance!!
Best Regards
Kshitij Kumar
