Greetings,
I have the SEVM4430G with the 4460 ES 1.1 processor upgrade from SVTronics. I'm using this drop: http://www.omappedia.com/wiki/L27.IS.2.P2_OMAP4_Icecream_Sandwich_Release_Notes
The kernel is hanging during the OMAP4 Power Management initialization sequence...
Here is the serial output:
Texas Instruments X-Loader 1.41 (Apr 2 2012 - 17:27:12)
OMAP4460: 1.5 GHz capable SOM
Starting OS Bootloader from EMMC ...
U-Boot 1.1.4-4AI.5^0 (Apr 2 2012 - 17:28:12)
Load address: 0x80e80000
DRAM: 1024 MB
Flash: 0 kB
Using default environment
In: serial
Out: serial
Err: serial
efi partition table:
256 128K xloader
512 256K bootloader
1024 128K misc
2048 16M efs
34816 16K crypto
34848 8M recovery
51232 8M boot
67616 512M system
1116192 256M cache
1640480 29630M userdata
Net: KS8851SNL
Hit any key to stop autoboot: 3 ### 2 ### 1 ### 0
kernel @ 80008000 (4249464)
ramdisk @ 81000000 (164670)
I2C read: I/O error
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.8-00006-gba85feb (tyler@Hammer) (gcc version 4.4.1 (Sourcery G++ Lite 2010q1-202) ) #1 SMP PREEMPT Mon Apr 2 18:02:13 PDT 2012
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: OMAP4 blaze board
[ 0.000000] Reserving 16777216 bytes SDRAM for VRAM
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] OMAP4460 ES1.1
[ 0.000000] SRAM: Mapped pa 0x40300000 to va 0xfe400000 size: 0xd000
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat c083c000, node_mem_map c1029000
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] HighMem zone: 1792 pages used for memmap
[ 0.000000] HighMem zone: 92416 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1834000 s7072 r8192 d13408 u32768
[ 0.000000] pcpu-alloc: s7072 r8192 d13408 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 124928
[ 0.000000] Kernel command line: console=ttyO2,115200n8 mem=1G vmalloc=768M androidboot.console=ttyO2 omap_wdt.timer_margin=30 androidboot.serialno=1B58002200000001 androidboot.bootloader=U-Boot_1.1.4-4AI.5^0
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 496MB = 496MB total
[ 0.000000] Memory: 489344k/489344k available, 559232k reserved, 376832K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xc8800000 - 0xf8000000 ( 760 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc004e000 ( 280 kB)
[ 0.000000] .text : 0xc004e000 - 0xc07d0000 (7688 kB)
[ 0.000000] .data : 0xc07d0000 - 0xc083cb60 ( 435 kB)
[ 0.000000] .bss : 0xc083cb84 - 0xc09c2fa0 (1562 kB)
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:410
[ 0.000000] omap_hwmod: dpll_mpu_m2_ck: missing clockdomain for dpll_mpu_m2_ck.
[ 0.000000] OMAP clockevent source: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000030] Calibrating delay loop... 1392.74 BogoMIPS (lpj=5439488)
[ 0.007904] pid_max: default: 32768 minimum: 301
[ 0.070678] Mount-cache hash table entries: 512
[ 0.070678] Initializing cgroup subsys debug
[ 0.070678] Initializing cgroup subsys cpuacct
[ 0.070678] Initializing cgroup subsys freezer
[ 0.071533] CPU: Testing write buffer coherency: ok
[ 0.071685] L310 cache controller enabled
[ 0.071838] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x5e470000, Cache size: 1048576 B
[ 0.149963] CPU1: Booted secondary processor
[ 0.220245] Brought up 2 CPUs
[ 0.220336] SMP: Total of 2 processors activated (2792.83 BogoMIPS).
[ 0.223754] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for emif_fw
[ 0.223754] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_instr
[ 0.223785] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_1
[ 0.223785] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l3_main_2
[ 0.223815] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_abe
[ 0.223815] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_cfg
[ 0.223846] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_per
[ 0.223846] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for l4_wkup
[ 0.223846] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for mpu_private
[ 0.223846] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for sl2if
[ 0.223968] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for thermal_sensor
[ 0.223968] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ohci
[ 0.223999] omap_hwmod: _populate_mpu_rt_base found no _mpu_rt_va for usbhs_ehci
[ 0.223999] omap_hwmod: l3_div_ck: missing clockdomain for l3_div_ck.
[ 0.224243] omap_hwmod: l4_div_ck: missing clockdomain for l4_div_ck.
[ 0.232482] omap_hwmod: mcpdm: cannot be enabled (3)
[ 0.234710] print_constraints: dummy:
[ 0.234710] NET: Registered protocol family 16
[ 0.235351] GPMC revision 6.0
[ 0.235931] EMIF0 is enabled with IRQ142
[ 0.235931] EMIF1 is enabled with IRQ143
[ 0.236846] Last reset was cold reset (PRM_RSTST=0x1)
[ 0.236877]
[ 0.237365] OMAP GPIO hardware version 0.1
[ 0.238952] omap_mux_init: Add partition: #1: core, flags: 2
[ 0.240722] omap_mux_init: Add partition: #2: wkup, flags: 2
[ 0.242309] omap_mux_get_by_name: Could not find signal uart1_cts.uart1_cts
[ 0.242309] omap_hwmod_mux_init: Could not allocate device mux entry
[ 0.470245] Modem NOT detected
[ 0.470275] Modem state properly updated to state 0
[ 0.471466] omap_disp_led_init: Configuring as one display LED
[ 0.597839] HSI: skipping omap_device registration
[ 0.597839] OMAP DMA hardware revision 0.0
[ 0.597839] omap_rproc_get_pool: carveout memory is unavailable: 0x0, 0x0
[ 0.608093] bio: create slab <bio-0> at 0
[ 0.608886] print_constraints: vwl1271: 1800 mV
[ 0.609283] i2c-core: driver [twl] using legacy suspend method
[ 0.609283] i2c-core: driver [twl] using legacy resume method
[ 0.609283] SCSI subsystem initialized
[ 0.610839] usbcore: registered new interface driver usbfs
[ 0.611022] usbcore: registered new interface driver hub
[ 0.611145] usbcore: registered new device driver usb
[ 0.611907] omap_i2c omap_i2c.1: bus 1 rev4.0 at 400 kHz
[ 0.611907] Skipping twl internal clock init and using bootloader value (unknown osc rate)
[ 0.615509] twl6030: PIH (irq 39) chaining IRQs 368..387
[ 0.617828] print_constraints: VUSB: 3300 mV normal standby
[ 1.548370] PC detected
[ 1.548889] twl6030_usb twl6030_usb: Initialized TWL6030 USB module
[ 1.549591] print_constraints: VMMC: 1200 <--> 3000 mV at 1800 mV normal standby
[ 1.550109] print_constraints: VPP: 1800 <--> 2500 mV at 1900 mV normal standby
[ 1.550537] print_constraints: VUSIM: 1200 <--> 2900 mV at 1800 mV normal standby
[ 1.551330] print_constraints: VCXIO: 1800 mV normal standby
[ 1.552124] print_constraints: VDAC: 1800 mV normal standby
[ 1.552642] print_constraints: VAUX1_6030: 1000 <--> 3000 mV at 2800 mV normal standby
[ 1.553253] print_constraints: VAUX2_6030: 1200 <--> 2800 mV at 1800 mV normal standby
[ 1.553680] print_constraints: VAUX3_6030: 1000 <--> 3000 mV at 1200 mV normal standby
[ 1.554656] print_constraints: CLK32KG:
[ 1.555450] print_constraints: VANA: 2100 mV normal standby
[ 1.555450] print_constraints: VOUT: 4075 <--> 4950 mV at 3825 mV normal standby
[ 1.556427] tps6130x 1-0033: Read from reg 0x7 failed
[ 1.556427] tps6130x 1-0033: failed to access device
[ 1.556976] tps6130x: probe of 1-0033 failed with error -121
[ 1.557128] omap_i2c omap_i2c.2: bus 2 rev4.0 at 400 kHz
[ 1.557434] omap_i2c omap_i2c.3: bus 3 rev4.0 at 400 kHz
[ 1.558013] omap_i2c omap_i2c.4: bus 4 rev4.0 at 400 kHz
[ 1.558990] omap-rproc omap-rproc.0: dsp is available
[ 1.558990] omap-rproc omap-rproc.1: ipu is available
[ 1.558990] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 1.559265] Bluetooth: Core ver 2.16
[ 1.559265] NET: Registered protocol family 31
[ 1.559265] Bluetooth: HCI device and connection manager initialized
[ 1.560028] Bluetooth: HCI socket layer initialized
[ 1.560028] Bluetooth: L2CAP socket layer initialized
[ 1.560058] Bluetooth: SCO socket layer initialized
[ 1.560058] Switching to clocksource 32k_counter
[ 1.562255] musb-hdrc: version 6.0, musb-dma, otg (peripheral+host)
[ 1.563995] Switched to NOHz mode on CPU #0
[ 1.564056] Switched to NOHz mode on CPU #1
[ 1.763122] musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
[ 1.763122] musb-hdrc: MHDRC RTL version 2.0
[ 1.763153] musb-hdrc: setup fifo_mode 4
[ 1.763153] musb-hdrc: 28/31 max ep, 16384/16384 memory
[ 1.763397] musb-hdrc musb-hdrc: USB OTG mode controller at fc0ab000 using DMA, IRQ 124
[ 1.763793] NET: Registered protocol family 2
[ 1.764251] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.765167] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 1.765167] TCP bind hash table entries: 4096 (order: 4, 98304 bytes)
[ 1.765167] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.765472] TCP reno registered
[ 1.765472] UDP hash table entries: 64 (order: 0, 4096 bytes)
[ 1.765533] UDP-Lite hash table entries: 64 (order: 0, 4096 bytes)
[ 1.765960] NET: Registered protocol family 1
[ 1.766418] RPC: Registered named UNIX socket transport module.
[ 1.766418] RPC: Registered udp transport module.
[ 1.766448] RPC: Registered tcp transport module.
[ 1.766448] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.766662] Trying to unpack rootfs image as initramfs...
[ 1.781219] Freeing initrd memory: 160K
[ 2.490020] omap_init_opp_table: no hwmod or odev for hsi, [22] cannot add OPPs.
[ 2.490020] omap_init_opp_table: no hwmod or odev for hsi, [23] cannot add OPPs.
[ 2.772216] ram_console: got buffer at a0000000, size 200000
[ 2.772430] ram_console: uncorrectable error in header
[ 2.772430] ram_console: no valid data in buffer (sig = 0x4b468246)
[ 2.789062] console [ram-1] enabled
[ 2.789154] omap-iommu omap-iommu.0: ducati registered
[ 2.789916] omap-iommu omap-iommu.1: tesla registered
[ 2.796081] highmem bounce pool size: 64 pages
[ 2.796081] ashmem: initialized
[ 2.804779] fuse init (API version 7.16)
[ 2.804779] msgmni has been set to 220
[ 2.804779] Registering char device tf_driver (122:0)
[ 2.806457] SMCAG01.06e1.0 D
[ 2.808532] io scheduler noop registered
[ 2.808532] io scheduler deadline registered
[ 2.808532] io scheduler cfq registered (default)
[ 2.808990] start plist test
[ 2.814208] end plist test
[ 2.818054] OMAP DSS rev 4.0
[ 2.842315] dsscomp: initializing.
[ 2.843078] misc dsscomp: display0=taal
[ 2.843078] misc dsscomp: display1=hdmi_panel
[ 2.843353] misc dsscomp: found 2 displays and 4 overlays
[ 2.843749] could not allocate slot
[ 2.844146] omap-rproc omap-rproc.1: powering up ipu
[ 2.844421] virtio_rpmsg_bus virtio0: rpmsg backend virtproc probed successfully
[ 2.845397] virtio_rpmsg_bus virtio1: rpmsg backend virtproc probed successfully
[ 2.845397] omap_uart.0: ttyO0 at MMIO 0x4806a000 (irq = 104) is a OMAP UART0
[ 2.865081] omap_uart.1: ttyO1 at MMIO 0x4806c000 (irq = 105) is a OMAP UART1
[ 2.904174] omap_uart.2: ttyO2 at MMIO 0x48020000 (irq = 106) is a OMAP UART2
[ 4.041076] console [ttyO2] enabled
[ 4.138519] omap_uart.3: ttyO3 at MMIO 0x4806e000 (irq = 102) is a OMAP UART3
[ 4.279266] omap_ion_probe: adding heap secure_input of type 2 with ba300000@5a00000
[ 4.288238] omap_ion_probe: adding heap tiler of type 4 with ada00000@6000000
[ 4.296295] omap_ion_probe: adding heap nonsecure_tiler of type 4 with a0200000@2000000
[ 4.305450] PVR: PVRCore_Init
[ 4.309173] PVR: PVRSRVDriverProbe(pDevice=c78a4800)
[ 4.314819] PVR: SGX register base: 0x56000000
[ 4.319915] PVR: SGX register size: 65535
[ 4.324432] PVR: SGX IRQ: 53
[ 4.327789] PVR: EnableSystemClocks: Enabling System Clocks
[ 4.334136] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency (EBUSY) [167, drivers/gpu/pvr/omap4/sysutils_linux.c]
[ 4.347229] PVR_K:(Warning): EnableSGXClocks: Unable to scale SGX frequency (EBUSY) [167, drivers/gpu/pvr/omap4/sysutils_linux.c]
[ 4.360565] PVR: PVRCore_Init: major device 251
[ 4.372711] brd: module loaded
[ 4.379547] loop: module loaded
[ 4.383270] (stk) :sysfs entries created
[ 4.383270] (stk) : debugfs entries created
[ 4.403198] ks8851 spi1.0: message enable is 0
[ 4.412658] ks8851 spi1.0: eth0: revision 1, MAC 62:e3:97:6c:6f:e6, IRQ 194
[ 4.420532] PPP generic driver version 2.4.2
[ 4.425415] PPP Deflate Compression module registered
[ 4.431213] PPP BSD Compression module registered
[ 4.437377] PPP MPPE Compression module registered
[ 4.442749] NET: Registered protocol family 24
[ 4.449981] usbcore: registered new interface driver zd1201
[ 4.456268] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.490020] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 5.496490] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 5.504882] ehci-omap ehci-omap.0: irq 109, io mem 0x4a064c00
[ 5.521331] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 5.527893] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.535552] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.543670] usb usb1: Product: OMAP-EHCI Host Controller
[ 5.549652] usb usb1: Manufacturer: Linux 3.0.8-00006-gba85feb ehci_hcd
[ 5.557037] usb usb1: SerialNumber: ehci-omap.0
[ 5.562744] hub 1-0:1.0: USB hub found
[ 5.567047] hub 1-0:1.0: 3 ports detected
[ 5.601684] usbcore: registered new interface driver cdc_acm
[ 5.601684] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.617156] Initializing USB Mass Storage driver...
[ 5.622802] usbcore: registered new interface driver usb-storage
[ 5.629547] USB Mass Storage support registered.
[ 5.634857] usbcore: registered new interface driver usbserial
[ 5.641510] usbserial: USB Serial Driver core
[ 5.848754] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 5.856445] android_usb gadget: Number of LUNs=1
[ 5.861724] lun0: LUN: removable file: (no medium)
[ 5.867309] android_usb gadget: android_usb ready
[ 5.872741] musb-hdrc musb-hdrc: MUSB HDRC host driver
[ 5.878570] musb-hdrc musb-hdrc: new USB bus registered, assigned bus number 2
[ 5.886779] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.894409] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.902526] usb usb2: Product: MUSB HDRC host driver
[ 5.908111] usb usb2: Manufacturer: Linux 3.0.8-00006-gba85feb musb-hcd
[ 5.915588] usb usb2: SerialNumber: musb-hdrc
[ 5.920989] hub 2-0:1.0: USB hub found
[ 5.925323] hub 2-0:1.0: 1 port detected
[ 5.930297] mousedev: PS/2 mouse device common for all mice
[ 5.936645] input: omap4-keypad as /devices/platform/omap/omap4-keypad/input/input0
[ 5.952026] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[ 5.965179] tm12xx_ts 2-004b: resetting device (reg 0x62)
[ 6.106292] tm12xx_ts 2-004b: no button capabilities found
[ 6.112823] tm12xx_ts: Synaptic TM12xx Touchscreen Driver found man id 1 (1)
[ 6.121276] tm12xx_ts: product ID: TM1217 family:1 fw:9
[ 6.127502] input: syn_tm12xx_ts_1 as /devices/platform/omap/omap_i2c.2/i2c-2/2-004b/input/input1
[ 6.138854] tm12xx_ts 2-004b: device status: 0x0, no error
[ 6.148406] tm12xx_ts 3-004b: resetting device (reg 0x62)
[ 6.296783] CMA3000 Acclerometer : Revision 10
[ 6.307281] tm12xx_ts 3-004b: no button capabilities found
[ 6.314727] tm12xx_ts: product ID: TM1217 family:1 fw:9
[ 6.320739] input: syn_tm12xx_ts_2 as /devices/platform/omap/omap_i2c.3/i2c-3/3-004b/input/input2
[ 6.331970] tm12xx_ts 3-004b: device status: 0x0, no error
[ 6.341583] input: cma3000-acclerometer as /devices/virtual/input/input3
[ 6.469207] bh1780 3-0029: Ambient Light Sensor, Rev : 1
[ 6.469207] input: bh1780gli as /devices/virtual/input/input4
[ 6.483062] bmp085 4-0077: BMP085 ver. 1.0 found.
[ 6.488586] input: bmp085 as /devices/virtual/input/input5
[ 6.494873] bmp085 4-0077: Succesfully initialized bmp085!
[ 6.501495] twl6030_pwrbutton_probe: Enter
[ 6.506561] input: twl6030_pwrbutton as /devices/platform/omap/omap_i2c.1/i2c-1/1-0049/twl6030_pwrbutton/input/input6
[ 6.519866] input: hmc5843 as /devices/virtual/input/input7
[ 6.526702] sfh7741_probe: Proximity sensor
[ 6.531646] input: sfh7741 as /devices/platform/sfh7741.1/input/input8
[ 6.542694] using rtc device, twl_rtc, for alarms
[ 6.548217] twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
[ 6.555572] i2c /dev entries driver
[ 6.555572] lirc_dev: IR Remote Control driver registered, major 248
[ 6.567504] IR NEC protocol handler initialized
[ 6.572601] IR RC5(x) protocol handler initialized
[ 6.572662] IR RC6 protocol handler initialized
[ 6.583129] IR JVC protocol handler initialized
[ 6.588226] IR Sony protocol handler initialized
[ 6.593475] IR RC5 (streamzap) protocol handler initialized
[ 6.599731] IR LIRC bridge handler initialized
[ 6.604797] Linux video capture interface: v2.00
[ 6.610168] dmm: probe base: fd300000, irq 145
[ 6.755828] twl6030_bci twl6030_bci: Battery Voltage at Bootup is -11 mV
[ 6.781829] lm75 3-0048: hwmon0: sensor 'tmp105'
[ 6.791107] OMAP Watchdog Timer Rev 0x01: initial timeout 30 sec
[ 6.799560] device-mapper: uevent: version 1.0.3
[ 6.805114] device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
[ 6.814636] Bluetooth: HCI UART driver ver 2.2
[ 6.819641] Bluetooth: HCI H4 protocol initialized
[ 6.825103] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 6.833648] (stc): st_register(2)
[ 6.837371] (stc): chnl_id list empty :2
[ 6.842102] cpuidle: using governor ladder
[ 6.846984] cpuidle: using governor menu
[ 6.851501] (stk) : st_kim_start
[ 6.862915] Registered led device: omap4:green:debug0
[ 6.869049] Registered led device: omap4:green:debug1
[ 6.874999] leds-gpio: probe of leds-gpio failed with error -16
[ 6.882110] Registered led device: omap4:green:chrg
[ 6.887817] omap4430_sdp_display_probe:Enter
[ 6.892730] Registered led device: lcd-backlight
[ 6.898498] omap4430_sdp_display_probe:Exit
[ 6.903350] omap4430_keypad_led_probe:Enter
[ 6.908233] Registered led device: keyboard-backlight
[ 6.914489] omap4430_keypad_led_probe:Exit
[ 6.921264] usbcore: registered new interface driver usbhid
[ 6.927612] usbhid: USB HID core driver
[ 6.932464] logger: created 256K log 'log_main'
[ 6.937713] logger: created 256K log 'log_events'
[ 6.943267] logger: created 256K log 'log_radio'
[ 6.948608] logger: created 256K log 'log_system'
[ 6.954162] thermal_governor_dev_register:Adding omap_ondie_governor governor
[ 6.962493] thermal_sensor_dev_register:Found cpu cpu
[ 6.968292] thermal_sensor_dev_register:Adding omap_ondie_sensor sensor
[ 6.971832] (stk) :ldisc_install = 1
[ 6.981597] thermal_sensor_set_temp:No cooling agents for domain cpu
[ 6.989013] omap_report_temp:thermal_sensor_set_temp reports error
[ 6.996307] thermal_sensor_set_temp:No cooling agents for domain cpu
[ 7.003479] thermal_sensor_set_temp:No cooling agents for domain cpu
[ 7.005767] omap_temp_sensor omap_temp_sensor.0: omap_ondie_sensor : 'omap_temp_sensor'
[ 7.006011] thermal_sensor_dev_register:Found cpu cpu
[ 7.006011] thermal_sensor_dev_register:Adding pcb_sensor sensor
[ 7.006103] pcb_temp_sensor pcb_temp_sensor.0: pcb_sensor : 'pcb_temp_sensor'
[ 7.007019] OMAP HSI: HSI driver version 0.4.3
[ 7.007324] OMAP HSI: Platform DRIVER register FAILED: -19
[ 7.007751] usbcore: registered new interface driver snd-usb-audio
[ 7.010467] SDP4430 SoC init
[ 7.016174] twl6040-codec twl6040-codec: couldn't get VDDHF regulator -19
[ 7.068847] omap_report_temp:thermal_sensor_set_temp reports error
[ 7.091613] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 7.099243] thermal_sensor_set_temp:No cooling agents for domain cpu
[ 7.106353] pcb_report_fw_temp:thermal_sensor_set_temp reports error
[ 7.115783] mmc0: new high speed DDR MMC card at address 0001
[ 7.122680] mmcblk0: mmc0:0001 SEM32G 29.7 GiB
[ 7.128051] mmcblk0boot0: mmc0:0001 SEM32G partition 1 1.00 MiB
[ 7.134887] mmcblk0boot1: mmc0:0001 SEM32G partition 2 1.00 MiB
[ 7.146240] Alternate GPT is invalid, using primary GPT.
[ 7.152313] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10
[ 7.161285] mmcblk0boot1: unknown partition table
[ 7.168487] mmcblk0boot0: unknown partition table
[ 7.291473] mmc2: card claims to support voltages below the defined range. These will be ignored.
[ 7.319641] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[ 7.327239] mmc2: new SDIO card at address 0001
[ 7.779327] twl6040-audio twl6040-audio: timeout waiting for READYINT
[ 7.786590] twl6040-audio twl6040-audio: automatic power-down failed
[ 7.793853] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 12, len 2)
[ 7.802978] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 13, len 2)
[ 7.812133] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 14, len 2)
[ 7.821166] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 15, len 2)
[ 7.830291] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 16, len 2)
[ 7.839416] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 17, len 2)
[ 7.848541] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 18, len 2)
[ 7.857574] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 19, len 2)
[ 7.866699] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 20, len 2)
[ 7.875823] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 21, len 2)
[ 7.884887] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 22, len 2)
[ 7.894012] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 23, len 2)
[ 7.903137] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 31, len 2)
[ 7.912200] twl: i2c_write failed to transfer all messages (addr 0x004b, reg 32, len 2)
[ 7.927673] asoc: null-codec-dai <-> MultiMedia1 mapping ok
[ 7.935394] asoc: null-codec-dai <-> MultiMedia2 mapping ok
[ 7.943450] asoc: null-codec-dai <-> Voice mapping ok
[ 7.950592] asoc: null-codec-dai <-> Tones mapping ok
[ 7.957641] asoc: null-codec-dai <-> Vibra mapping ok
[ 7.964416] asoc: null-codec-dai <-> MODEM mapping ok
[ 7.971008] asoc: null-codec-dai <-> MultiMedia1 LP mapping ok
[ 7.979309] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 7.987060] asoc: twl6040-dl1 <-> mcpdm-dl mapping ok
[ 7.994842] asoc: dmic-hifi <-> omap-dmic-dai-0 mapping ok
[ 7.998443] Invalid Device Structure
[ 7.998474] Failed: change interconnect bandwidth to 0
[ 8.013000] twl6040-codec twl6040-codec: ASoC: Failed to create Aux/FM Stereo In debugfs file
[ 8.023620] asoc: twl6040-dl1 <-> mcpdm-dl1 mapping ok
[ 8.030456] asoc: twl6040-ul <-> mcpdm-ul1 mapping ok
[ 8.037170] asoc: twl6040-dl2 <-> mcpdm-dl2 mapping ok
[ 8.044006] asoc: twl6040-vib <-> mcpdm-vib mapping ok
[ 8.050842] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 8.058197] asoc: Bluetooth <-> omap-mcbsp-dai.0 mapping ok
[ 8.065521] asoc: FM Digital <-> omap-mcbsp-dai.1 mapping ok
[ 8.071929] thermal_sensor_set_temp:No cooling agents for domain cpu
[ 8.080139] asoc: MODEM <-> omap-mcbsp-dai.1 mapping ok
[ 8.086059] omap_report_temp:thermal_sensor_set_temp reports error
[ 8.094024] asoc: dmic-hifi <-> omap-dmic-abe-dai-0 mapping ok
[ 8.101745] asoc: dmic-hifi <-> omap-dmic-abe-dai-1 mapping ok
[ 8.109436] asoc: dmic-hifi <-> omap-dmic-abe-dai-2 mapping ok
[ 8.118652] input: SDP4430 Headset Jack as /devices/platform/soc-audio/sound/card0/input9
[ 8.127838] pcb_read_current_temp:TWL6030_GPADC conversion is invalid -11
[ 8.130981] asoc: hdmi-audio-codec <-> hdmi-audio-dai mapping ok
[ 8.131530] ALSA device list:
[ 8.131530] #0: TI OMAP4 Board
[ 8.131530] #1: OMAP4HDMI
[ 8.131652] GACT probability NOT on
[ 8.131683] Mirror/redirect action on
[ 8.131713] u32 classifier
[ 8.131713] Actions configured
[ 8.131713] Netfilter messages via NETLINK v0.30.
[ 8.131805] nf_conntrack version 0.5.0 (7648 buckets, 30592 max)
[ 8.132995] ctnetlink v0.93: registering with nfnetlink.
[ 8.133331] xt_time: kernel timezone is -0000
[ 8.135833] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.136016] arp_tables: (C) 2002 David S. Miller
[ 8.136077] TCP cubic registered
[ 8.136901] NET: Registered protocol family 10
[ 8.144531] Mobile IPv6
[ 8.144561] IPv6 over IPv4 tunneling driver
[ 8.151123] NET: Registered protocol family 17
[ 8.151153] NET: Registered protocol family 15
[ 8.227233] (stk) :ldisc installation timeout
[ 8.227294] Bluetooth: RFCOMM TTY layer initialized
[ 8.227325] Bluetooth: RFCOMM socket layer initialized
[ 8.227325] Bluetooth: RFCOMM ver 1.11
[ 8.227355] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.227355] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 8.227508] NET: Registered protocol family 35
[ 8.227844] VFP support v0.3:
[ 8.268585] thermal_sensor_set_temp:No cooling agents for domain cpu
[ 8.268646] implementor 41 architecture 3 part 30 variant 9 rev 4
[ 8.268646] ThumbEE CPU extension supported.
[ 8.268676] Registering SWP/SWPB emulation handler
[ 8.276489] Reprogramming LPDDR2 timings to 400000000 Hz
[ 8.298767] pcb_report_fw_temp:thermal_sensor_set_temp reports error
[ 8.298889] thermal_cooling_dev_register:Found cpu cpu
[ 8.298889] thermal_request_temp:Getting temp is not supported for domain cpu
[ 8.299530] Power Management for TI OMAP4.
[ 8.299713] OMAP4 PM: Static dependency added between MPUSS and DUCATI <-> L4_PER/CFG and L3_1.
[ 8.300323] sr_init: No PMIC hook to init smartreflex
[ 8.300537] smartreflex smartreflex.0: omap_sr_probe: SmartReflex driver initialized
[ 8.300720] smartreflex smartreflex.1: omap_sr_probe: SmartReflex driver initialized
[ 8.300903] smartreflex smartreflex.2: omap_sr_probe: SmartReflex driver initialized
[ 8.301269] SmartReflex class 1.5 driver: initialized (86400000ms)
[ 8.310180] clock: disabling unused clocks to save power
[ 8.311096] (stk) :ldisc_install = 0
[ 8.513519] sr_class1p5_calib_work: core Stop sampling: Voltage Nominal=962000 samples=18
[ 8.522979] sr_class1p5_calib_work: core: Calibration complete: Voltage Nominal=962000Calib=848260 margin=10000
[ 8.534118] sr_class1p5_calib_work: mpu Stop sampling: Voltage Nominal=1025000 samples=33
[ 8.543518] sr_class1p5_calib_work: mpu: Calibration complete: Voltage Nominal=1025000Calib=840000 margin=10000
[ 8.555541
At this point the kernel hangs, no kernel panic to debug with. I believe this issue may be related to the PMIC, as my 4430 processor board boots to Android fine. Any help would be much appreciated!
Tyler
