SYSLINK issue while running Gstreamer
I am using the latest EZSDK, 5.03.01.15 for TI816x/ AM389x board and trying to run the Gstreamer application.
I am getting an error from syslink while running the gstreamer app.
Here is what it happens
root@dm816x-evm:~#insmod syslink.ko
root@dm816x-evm:~#./slaveloader startup VPSS-M3 ti816x_hdvpss.xem3
root@dm816x-evm:~#insmod vpss.ko
root@dm816x-evm:~#insmod ti81xxhdmi.ko
root@dm816x-evm:~#insmod ti81xxfb.ko
root@dm816x-evm:~#insmod ti81xxvo.ko
root@dm816x-evm:~#/etc/init.d/matrix-gui-e stop
root@dm816x-evm:~#amixer set PCM 127
root@dm816x-evm:~#export GST_REGISTRY=/tmp/gst_registry.bin
root@dm816x-evm:~#export LD_LIBRARY_PATH=/usr/lib
root@dm816x-evm:~#export GST_PLUGIN_PATH=/usr/lib/gstreamer-0.10
root@dm816x-evm:~#export PATH=/usr/bin:$PATH
root@dm816x-evm:~#export GST_PLUGIN_SCANNER=/usr/libexec/gstreamer-0.10/gst-plugin-scanner
root@dm816x-evm:~# gst-launch-0.10 -v filesrc location=seas.mov ! qtdemux name=
demux demux.audio_00 ! queue ! faad ! alsasink demux.video_00 ! queue ! nal2byte
stream_h264 ! omx_h264dec ! omx_scaler ! omx_ctrl display-mode=OMX_DC_MODE_108
0P_60 ! gstperf ! omx_videosink
Assertion at Line no: 445 in /home/PRDVF/syslink_85/syslink_2_00_05_85/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/Linux/SharedRegionDrv.c: (heapHandle != NULL) : failed
Assertion at Line no: 1344 in /swcoe/sdk/cm/netra/arago-tmp/work/dm816x-evm-none-linux-gnueabi/ti-syslink-2_00_05_85-r4i/syslink_2_00_05_85/packages/ti/syslink/ipc/hlos/usr/HeapMemMP.c: (hpHandle != NULL) : failed
gst-launch-0.10: DmmDelegateHeap.c:193: DmmDelegate_createIpcHeap: Assertion `(heapHandle != 0)' failed.
Aborted
root@dm816x-evm:~#
Please let me know how to solve this.
Thanks in Advance.
Salih
